Hi
Im new at f@h and a complete luser. Technically not skilled at all, but thought I can at least install f@h and let my pc do the rest. After finishing 2 WUs - gpu is still running - cpu is stuck on ready. Where's the mistake/what can I do?
Hope someone can help.
Hortu
cpu stuck on ready
Re: cpu stuck on ready
Recently, my CPU is also not busy 100% of the time. I believe its more a shortage/server problem on F@H side.
Ok, thanks Nilem. Then I'll simply wait
Welcome to the F@H Forum Hortu,
More work is in the pipeline to elevate CPU WU shortage. However, if you're in doubt, can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
