I need know how is your experience with Ubuntu 20.04.1
GTX56O
Hardware configuration: rx570 itx 4gb no oc
Post by GTX56O »
The Ubuntu focal fossa 20.04.01, with folding at home with AMD RX5700XT.
Is good option?
MeeLee
Re: I need know how is your experience with Ubuntu 20.04.1
Post by MeeLee »
Go for 18.04 if you're just starting out. The FAHControl bugs aren't ironed out yet on anything past 18.10 (which is also no longer supported).
I think the RX5700XT is close to an RTX2060 in PPD, if I'm not mistaken.
GTX56O
Post by GTX56O »
MeeLee wrote:Go for 18.04 if you're just starting out. The FAHControl bugs aren't ironed out yet on anything past 18.10 (which is also no longer supported).
FAH Control is possible install, because the version 7.7 have python 3. Only works the cpu.
GTX56O
Post by GTX56O »
. But he say disabled in my gpu.
I have install
https://www.amd.com/en/support/kb/relea ... inux-20-20
Radeon™ Software for Linux® version 20.20 for Ubuntu 20.04
Post by Neil-B »
you may well also need the opencl dev drivers and iirc adding to the video group?
