AMD Ryzen 5 4650 Pro iGPU utilization [RESOLVED]
Darryl
Post by Darryl »
Hello all, just posting this post to create crumbs for other noobs who have obtained a AMD RYZEN "Renoir" 4350GE, 4350G, 4650GE, 4650G or 4670GE , 4670G or "PRO" processer through grey market channels looking for help maximizing their iGPU performance in crunching units.
I just installed FAH about a week ago and noticed the GPU utilization was virtually nonexistent even with the slider on 'HIGH' .
The GPU core count was showing as '1' and the work unit 'time to complete' clocks on the GPU slot were something on the order of 24 hours or more. ( Pentium 4 level)
CPU numbers look good. Showing 11 CPUS crunching units up at a rate of one every 90-120 minutes or so. No worries there. But it seems the iGPU is barely there.
I confirmed via task manager and the iGPU utilization in windows was approx 1% on the older client.
STEPS UNDERTAKE SO FAR : Updated client to latest rev 7.6.21 and now GPU shows 14:0 which tells me the new version is at least 'seeing' the hardware (7 CU's on Amd Renoir model 4650 Pro) but the apparent speed of work being completed and client utilization of the iGPU cores appears to have increased.
Based on windows task manager says utilization is now approx 4% on average +/- 1%.
So while there is some improvement, I think there is obviously a lot more the hardware can do. I'm running a Asrock 570 Steel Legend board with excellent cooling and even under load, my temps are well below throttle (60-65C) The slight bump in utilization did not touch my temps - another indicator the cores are being underutilized.
I'm guessing this is a known issue but the numbers of processors on the street at this time is so minute that it is not a priority and probably on the list of 'things to do' in future to be addressed in future client revs and that's fine. If it's on the list I'll wait.
MY Q: Is there anything I can do RIGHT NOW to force the client to utilize at least some of those iGPU CU cores to a higher degree?
Thank you.
Darryl from Tom's Hardware team.
PS: I was futzing around in windows task manager and discovered the default data display is 3D and if you hit the drop menu you have other options including two "compute" graphs. Now HERE is where I see some utilization.
Compute 0 IS zero.
Compute 1 is running 98-100% with occasional dips to 96-97, so it appears there IS some crunch going on. I timed the current at the .001 percent level (takes 7 seconds to go from 58.25 to 58.26 and extrapolated) and it looks like 19 hours to complete but work units vary in size so I cant rely on that.
Log is copied below:
18:16:27:WU01:FS01:0x22:*********************** Log Started 2020-10-27T18:16:27Z ***********************
18:16:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:16:27:WU01:FS01:0x22:       Core: Core22
18:16:27:WU01:FS01:0x22:       Type: 0x22
18:16:27:WU01:FS01:0x22:    Version: 0.0.13
18:16:27:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:16:27:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:16:27:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:16:27:WU01:FS01:0x22:       Date: Sep 19 2020
18:16:27:WU01:FS01:0x22:       Time: 02:35:58
18:16:27:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:16:27:WU01:FS01:0x22:     Branch: core22-0.0.13
18:16:27:WU01:FS01:0x22:   Compiler: Visual C++ 2015
18:16:27:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:16:27:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
18:16:27:WU01:FS01:0x22:   Platform: win32 10
18:16:27:WU01:FS01:0x22:       Bits: 64
18:16:27:WU01:FS01:0x22:       Mode: Release
18:16:27:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:16:27:WU01:FS01:0x22:             <peastman@stanford.edu>
18:16:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9648 -checkpoint 15
18:16:27:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
18:16:27:WU01:FS01:0x22:             -gpu-usage 100
18:16:27:WU01:FS01:0x22:************************************ libFAH ************************************
18:16:27:WU01:FS01:0x22:       Date: Sep 7 2020
18:16:27:WU01:FS01:0x22:       Time: 19:09:56
18:16:27:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:16:27:WU01:FS01:0x22:     Branch: HEAD
18:16:27:WU01:FS01:0x22:************************************ CBang *************************************
18:16:27:WU01:FS01:0x22:       Time: 19:08:30
18:16:27:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:16:27:WU01:FS01:0x22:************************************ System ************************************
18:16:27:WU01:FS01:0x22:        CPU: AMD Ryzen 5 PRO 4650G with Radeon Graphics
18:16:27:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
18:16:27:WU01:FS01:0x22:       CPUs: 12
18:16:27:WU01:FS01:0x22:     Memory: 15.39GiB
18:16:27:WU01:FS01:0x22:Free Memory: 10.39GiB
18:16:27:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:16:27:WU01:FS01:0x22: OS Version: 6.2
18:16:27:WU01:FS01:0x22:Has Battery: false
18:16:27:WU01:FS01:0x22: On Battery: false
18:16:27:WU01:FS01:0x22: UTC Offset: -4
18:16:27:WU01:FS01:0x22:        PID: 7352
18:16:27:WU01:FS01:0x22:        CWD: C:\Users\d3055\AppData\Roaming\FAHClient\work
18:16:27:WU01:FS01:0x22:************************************ OpenMM ************************************
18:16:27:WU01:FS01:0x22:   Revision: 189320d0
18:16:27:WU01:FS01:0x22:********************************************************************************
18:16:27:WU01:FS01:0x22:Project: 14906 (Run 443, Clone 2, Gen 62)
18:16:27:WU01:FS01:0x22:Unit: 0x0000005d81d59d695f4ec9d38b7e2553
18:16:27:WU01:FS01:0x22:Digital signatures verified
18:16:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:16:27:WU01:FS01:0x22:Version 0.0.13
18:16:27:WU00:FS00:Core PID:9072
18:16:27:WU00:FS00:FahCore 0xa7 started
18:16:28:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
18:16:28:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
18:16:28:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
18:16:28:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
18:16:28:WU00:FS00:0xa7:*********************** Log Started 2020-10-27T18:16:27Z ***********************
18:16:28:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:16:28:WU00:FS00:0xa7:       Type: 0xa7
18:16:28:WU00:FS00:0xa7:       Core: Gromacs
18:16:28:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8560 -checkpoint 15 -np
18:16:28:WU00:FS00:0xa7:             11
18:16:28:WU00:FS00:0xa7:************************************ CBang *************************************
18:16:28:WU00:FS00:0xa7:       Date: Nov 27 2019
18:16:28:WU00:FS00:0xa7:       Time: 03:40:09
18:16:28:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:16:28:WU00:FS00:0xa7:     Branch: master
18:16:28:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:16:28:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:16:28:WU00:FS00:0xa7:   Platform: win32 10
18:16:28:WU00:FS00:0xa7:       Bits: 64
18:16:28:WU00:FS00:0xa7:       Mode: Release
18:16:28:WU00:FS00:0xa7:************************************ System ************************************
18:16:28:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 PRO 4650G with Radeon Graphics
18:16:28:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
18:16:28:WU00:FS00:0xa7:       CPUs: 12
18:16:28:WU00:FS00:0xa7:     Memory: 15.39GiB
18:16:28:WU00:FS00:0xa7:Free Memory: 10.37GiB
18:16:28:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:16:28:WU00:FS00:0xa7: OS Version: 6.2
18:16:28:WU00:FS00:0xa7:Has Battery: false
18:16:28:WU00:FS00:0xa7: On Battery: false
18:16:28:WU00:FS00:0xa7: UTC Offset: -4
18:16:28:WU00:FS00:0xa7:        PID: 9072
18:16:28:WU00:FS00:0xa7:        CWD: C:\Users\d3055\AppData\Roaming\FAHClient\work
18:16:28:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:16:28:WU00:FS00:0xa7:    Version: 0.0.19
18:16:28:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:16:28:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:16:28:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:16:28:WU00:FS00:0xa7:       Date: Nov 25 2019
18:16:28:WU00:FS00:0xa7:       Time: 17:12:41
18:16:28:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:16:28:WU00:FS00:0xa7:************************************ Build *************************************
18:16:28:WU00:FS00:0xa7:       SIMD: avx_256
18:16:28:WU00:FS00:0xa7:********************************************************************************
18:16:28:WU00:FS00:0xa7:Project: 14258 (Run 0, Clone 3323, Gen 70)
18:16:28:WU00:FS00:0xa7:Unit: 0x00000050cedfaa925f6a38b326a769de
18:16:28:WU00:FS00:0xa7:Digital signatures verified
18:16:28:WU00:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
18:16:28:WU00:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -x frame70.xtc -cpi state.cpt -cpt 15 -nt 10
18:16:28:WU00:FS00:0xa7:Steps: first=17500000 total=250000
18:16:28:WU01:FS01:0x22:There are 3 platforms available.
18:16:28:WU01:FS01:0x22:Platform 0: Reference
18:16:28:WU01:FS01:0x22:Platform 1: CPU
18:16:28:WU01:FS01:0x22:Platform 2: OpenCL
18:16:28:WU01:FS01:0x22:  opencl-device 0 specified
18:16:29:WU00:FS00:0xa7:Completed 187442 out of 250000 steps (74%)
18:16:30:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
18:16:37:WU01:FS01:0x22:Attempting to create OpenCL context:
18:16:37:WU01:FS01:0x22:  Configuring platform OpenCL
18:16:39:Removing old file 'configs/config-20201023-023212.xml'
18:16:39:Saving configuration to config.xml
18:16:39:<config>
18:16:39:  <!-- Folding Slot Configuration -->
18:16:39:  <cause v='COVID_19'/>
18:16:39:
18:16:39:  <!-- Network -->
18:16:39:  <proxy v=':8080'/>
18:16:39:
18:16:39:  <!-- Slot Control -->
18:16:39:  <power v='FULL'/>
18:16:39:
18:16:39:  <!-- User Information -->
18:16:39:  <passkey v='*****'/>
18:16:39:  <team v='40051'/>
18:16:39:  <user v='Darryl'/>
18:16:39:
18:16:39:  <!-- Folding Slots -->
18:16:39:  <slot id='0' type='CPU'/>
18:16:39:  <slot id='1' type='GPU'>
18:16:39:    <pci-bus v='14'/>
18:16:39:    <pci-slot v='0'/>
18:16:39:  </slot>
18:16:39:</config>
18:16:45:WU01:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
18:16:45:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
18:17:28:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
18:18:27:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
18:19:25:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
18:20:26:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
18:21:26:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
18:22:25:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
18:23:25:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
18:24:26:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
18:25:25:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
18:26:23:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
18:27:22:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
18:28:24:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
18:29:24:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
18:30:23:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
18:31:22:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
18:32:17:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
18:32:22:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
18:33:21:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
18:34:20:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
18:35:18:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
18:36:17:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
18:37:16:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
18:38:14:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
18:39:14:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
18:40:13:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
18:40:14:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:40:15:WU02:FS00:Assigned to work server 178.174.196.138
18:40:15:WU02:FS00:Requesting new work unit for slot 00: cpu:11 from 178.174.196.138
18:40:15:WU02:FS00:Connecting to 178.174.196.138:8080
18:40:36:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
18:40:36:WU02:FS00:Connecting to 178.174.196.138:80
18:40:57:ERROR:WU02:FS00:Exception: Failed to connect to 178.174.196.138:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:40:58:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:40:58:WU02:FS00:Assigned to work server 178.174.196.138
18:40:58:WU02:FS00:Requesting new work unit for slot 00: cpu:11 from 178.174.196.138
18:40:58:WU02:FS00:Connecting to 178.174.196.138:8080
18:41:13:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:41:14:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:41:14:WU00:FS00:0xa7:Saving result file frame70.trr
18:41:14:WU00:FS00:0xa7:Saving result file frame70.xtc
18:41:14:WU00:FS00:0xa7:Saving result file md.log
18:41:14:WU00:FS00:0xa7:Saving result file science.log
18:41:14:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:41:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:41:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14258 run:0 clone:3323 gen:70 core:0xa7 unit:0x00000050cedfaa925f6a38b326a769de
18:41:15:WU00:FS00:Uploading 2.88MiB to 206.223.170.146
18:41:15:WU00:FS00:Connecting to 206.223.170.146:8080
18:41:19:WU00:FS00:Upload complete
18:41:19:WU00:FS00:Server responded WORK_ACK (400)
18:41:19:WU00:FS00:Final credit estimate, 4649.00 points
18:41:19:WU00:FS00:Cleaning up
18:41:19:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
18:41:19:WU02:FS00:Connecting to 178.174.196.138:80
18:41:40:ERROR:WU02:FS00:Exception: Failed to connect to 178.174.196.138:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:41:58:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:41:59:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:41:59:WU02:FS00:Connecting to assign2.foldingathome.org:80
18:41:59:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:41:59:WU02:FS00:Connecting to assign3.foldingathome.org:80
18:42:00:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:42:00:WU02:FS00:Connecting to assign4.foldingathome.org:80
18:42:00:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:42:00:ERROR:WU02:FS00:Exception: Could not get an assignment
18:43:36:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:43:36:WU02:FS00:Assigned to work server 178.174.196.138
18:43:36:WU02:FS00:Requesting new work unit for slot 00: cpu:11 from 178.174.196.138
18:43:36:WU02:FS00:Connecting to 178.174.196.138:8080
18:43:49:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
18:46:12:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:46:13:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
18:46:13:WU02:FS00:Assigned to work server 66.170.111.50
18:46:13:WU02:FS00:Requesting new work unit for slot 00: cpu:11 from 66.170.111.50
18:46:13:WU02:FS00:Connecting to 66.170.111.50:8080
18:46:13:ERROR:WU02:FS00:Exception: Server did not assign work unit
18:50:27:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:50:27:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:50:27:WU02:FS00:Connecting to assign2.foldingathome.org:80
18:50:28:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:50:28:WU02:FS00:Connecting to assign3.foldingathome.org:80
18:50:28:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:50:28:WU02:FS00:Connecting to assign4.foldingathome.org:80
18:50:28:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:50:28:ERROR:WU02:FS00:Exception: Could not get an assignment
18:57:18:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:57:19:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:57:19:WU02:FS00:Connecting to assign2.foldingathome.org:80
18:57:19:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:57:19:WU02:FS00:Connecting to assign3.foldingathome.org:80
18:57:19:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:57:19:WU02:FS00:Connecting to assign4.foldingathome.org:80
18:57:19:WU02:FS00:Assigned to work server 128.252.203.10
18:57:19:WU02:FS00:Requesting new work unit for slot 00: cpu:11 from 128.252.203.10
18:57:19:WU02:FS00:Connecting to 128.252.203.10:8080
18:57:20:WU02:FS00:Downloading 2.77MiB
18:57:22:WU02:FS00:Download complete
18:57:22:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:17210 run:0 clone:18 gen:248 core:0xa7 unit:0x0000010d80fccb0a5f5fe9fbd49c7322
18:57:22:WU02:FS00:Starting
18:57:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\d3055\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 1460 -checkpoint 15 -np 11
18:57:22:WU02:FS00:Started FahCore on PID 13048
18:57:22:WU02:FS00:Core PID:6192
18:57:22:WU02:FS00:FahCore 0xa7 started
18:57:22:WU02:FS00:0xa7:*********************** Log Started 2020-10-27T18:57:22Z ***********************
18:57:22:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:57:22:WU02:FS00:0xa7:       Type: 0xa7
18:57:22:WU02:FS00:0xa7:       Core: Gromacs
18:57:22:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 13048 -checkpoint 15 -np
18:57:22:WU02:FS00:0xa7:             11
18:57:22:WU02:FS00:0xa7:************************************ CBang *************************************
18:57:22:WU02:FS00:0xa7:       Date: Nov 27 2019
18:57:22:WU02:FS00:0xa7:       Time: 03:40:09
18:57:22:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:57:22:WU02:FS00:0xa7:     Branch: master
18:57:22:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
18:57:22:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:57:22:WU02:FS00:0xa7:   Platform: win32 10
18:57:22:WU02:FS00:0xa7:       Bits: 64
18:57:22:WU02:FS00:0xa7:       Mode: Release
18:57:22:WU02:FS00:0xa7:************************************ System ************************************
18:57:22:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 PRO 4650G with Radeon Graphics
18:57:22:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
18:57:22:WU02:FS00:0xa7:       CPUs: 12
18:57:22:WU02:FS00:0xa7:     Memory: 15.39GiB
18:57:22:WU02:FS00:0xa7:Free Memory: 9.76GiB
18:57:22:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
18:57:22:WU02:FS00:0xa7: OS Version: 6.2
18:57:22:WU02:FS00:0xa7:Has Battery: false
18:57:22:WU02:FS00:0xa7: On Battery: false
18:57:22:WU02:FS00:0xa7: UTC Offset: -4
18:57:22:WU02:FS00:0xa7:        PID: 6192
18:57:22:WU02:FS00:0xa7:        CWD: C:\Users\d3055\AppData\Roaming\FAHClient\work
18:57:22:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:57:22:WU02:FS00:0xa7:    Version: 0.0.19
18:57:22:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:57:22:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:57:22:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
18:57:22:WU02:FS00:0xa7:       Date: Nov 25 2019
18:57:22:WU02:FS00:0xa7:       Time: 17:12:41
18:57:22:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:57:22:WU02:FS00:0xa7:************************************ Build *************************************
18:57:22:WU02:FS00:0xa7:       SIMD: avx_256
18:57:22:WU02:FS00:0xa7:********************************************************************************
18:57:22:WU02:FS00:0xa7:Project: 17210 (Run 0, Clone 18, Gen 248)
18:57:22:WU02:FS00:0xa7:Unit: 0x0000010d80fccb0a5f5fe9fbd49c7322
18:57:22:WU02:FS00:0xa7:Reading tar file core.xml
18:57:22:WU02:FS00:0xa7:Reading tar file frame248.tpr
18:57:22:WU02:FS00:0xa7:Digital signatures verified
18:57:22:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
18:57:22:WU02:FS00:0xa7:Calling: mdrun -s frame248.tpr -o frame248.trr -x frame248.xtc -cpt 15 -nt 10
18:57:22:WU02:FS00:0xa7:Steps: first=62000000 total=250000
18:57:24:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
18:58:13:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
18:58:22:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
18:59:20:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
19:00:19:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
Hardware configuration: Mac Pro 2.8 quad 12 GB smp4
MacBook Pro 2.9 i7 8 GB smp2
Re: AMD Ryzen 5 4650 Pro iGPU issue: iGPU slot Core utilizat
If you are seeing utilization rates of 98-100% by using the Compute settings in Task Manager, then the GPU is being used as much as it can be. F@h does not use 3D graphics processing. The other thing to check is what clock speed the iGPU is running at, if throttled that will slow it down. That may take different monitoring tools than Task Manager.
Reducing the CPU thread count may speed up the GPU processing, but the completion times you are seeing are consistent with other reports of the iGPUs included in the Ryzen processors.
One thing to note, it takes the client several percent of progress for its estimates of TPF, PPD and ETA to become relatively accurate.
iMac 2.8 i7 12 GB smp8, Mac Pro 2.8 quad 12 GB smp6
MacBook Pro 2.9 i7 8 GB smp3
Darryl
Post by Darryl »
Understood. I'm not overclocking and everything is stock speeds and well cooled and nothing throttling. I just wanted to be sure I'm getting everything I can get out of it. Thank you.
