192.0.2.1
rickoic
Hardware configuration: eVga x299 DARK 2070 Super, eVGA 2080, eVga 1070, eVga 2080 Super
MSI x399 eVga 2080, eVga 1070, eVga 1070, GT970
192.0.2.1
Post by rickoic »
14:44:36:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:44:37:WU04:FS03:Assigned to work server 192.0.2.1
14:44:37:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:44:37:WU04:FS03:Connecting to 192.0.2.1:8080
*********************** Log Started 2020-10-22T14:44:22Z ***********************
14:44:58:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:44:58:WU04:FS03:Connecting to 192.0.2.1:80
14:45:19:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:45:20:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:45:20:WU04:FS03:Assigned to work server 192.0.2.1
14:45:20:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:45:20:WU04:FS03:Connecting to 192.0.2.1:8080
14:45:42:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:45:42:WU04:FS03:Connecting to 192.0.2.1:80
14:46:03:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:46:20:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:46:20:WU04:FS03:Assigned to work server 192.0.2.1
14:46:20:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:46:20:WU04:FS03:Connecting to 192.0.2.1:8080
14:46:41:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:46:41:WU04:FS03:Connecting to 192.0.2.1:80
14:47:02:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:47:57:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:47:57:WU04:FS03:Assigned to work server 192.0.2.1
14:47:57:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:47:57:WU04:FS03:Connecting to 192.0.2.1:8080
14:48:18:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:48:18:WU04:FS03:Connecting to 192.0.2.1:80
14:48:39:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:50:34:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:50:35:WU04:FS03:Assigned to work server 192.0.2.1
14:50:35:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:50:35:WU04:FS03:Connecting to 192.0.2.1:8080
14:50:56:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:50:56:WU04:FS03:Connecting to 192.0.2.1:80
14:51:17:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:54:49:WU04:FS03:Connecting to assign1.foldingathome.org:80
14:54:49:WU04:FS03:Assigned to work server 192.0.2.1
14:54:49:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
14:54:49:WU04:FS03:Connecting to 192.0.2.1:8080
14:55:10:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
14:55:10:WU04:FS03:Connecting to 192.0.2.1:80
14:55:31:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:01:40:WU04:FS03:Connecting to assign1.foldingathome.org:80
15:01:40:WU04:FS03:Assigned to work server 192.0.2.1
15:01:40:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
15:01:40:WU04:FS03:Connecting to 192.0.2.1:8080
15:02:01:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
15:02:01:WU04:FS03:Connecting to 192.0.2.1:80
15:02:22:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:02:46:WU04:FS03:Slot ID 3 no longer exists and not yet downloaded, dumping
15:02:46:WU04:FS03:Cleaning up
15:04:12:WU04:FS03:Connecting to assign1.foldingathome.org:80
15:04:12:WU04:FS03:Assigned to work server 192.0.2.1
15:04:12:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
15:04:12:WU04:FS03:Connecting to 192.0.2.1:8080
15:04:33:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
15:04:33:WU04:FS03:Connecting to 192.0.2.1:80
15:04:55:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:04:55:WU04:FS03:Connecting to assign1.foldingathome.org:80
15:04:55:WU04:FS03:Assigned to work server 192.0.2.1
15:04:55:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
15:04:55:WU04:FS03:Connecting to 192.0.2.1:8080
15:05:16:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
15:05:16:WU04:FS03:Connecting to 192.0.2.1:80
15:05:38:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:05:55:WU04:FS03:Connecting to assign1.foldingathome.org:80
15:05:55:WU04:FS03:Assigned to work server 192.0.2.1
15:05:55:WU04:FS03:Requesting new work unit for slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463 from 192.0.2.1
15:05:55:WU04:FS03:Connecting to 192.0.2.1:8080
15:06:16:WARNING:WU04:FS03:WorkServer connection failed on port 8080 trying 80
15:06:16:WU04:FS03:Connecting to 192.0.2.1:80
15:06:38:ERROR:WU04:FS03:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
I'm folding because Dec 2005 I had radical prostate surgery.
Lost brother to spinal cancer, brother-in-law to prostate cancer.
Several 1st cousins lost and a few who have survived.
Re: 192.0.2.1
Normally a GTX 1070 would be a supported GPU. (192.0.2.1 tends to indicate yours is unsupported)
You did not post the first 200 lines of your Log where it tells us what your PC is configured as. (OS, CPU, RAM, GPU, Driver, etc)
One hint is that this is GPU 2, so F@H may be confused about which driver support which GPU
Beyond that, I await the configuration portion of the log.
Re: 192.0.2.1
Either the servers are out of WUs suitable for assigning to the GTX 1070, you are running a version of OS X, or an unusable installation of OpenCL support has been detected. Not enough information to determine which of these conditions apply.
rickoic
Re: 192.0.2.1
Post by rickoic »
Had another 1070 installed, but lost fans on it so replaced it with another 1070.
14:44:22:Trying to access database...
14:44:22:Successfully acquired database lock
14:44:22:Read GPUs.txt
14:44:23:Enabled folding slot 00: READY cpu:12
14:44:23:Enabled folding slot 01: READY gpu:0:TU104 [GeForce RTX 2070 SUPER]
14:44:23:Enabled folding slot 02: READY gpu:1:TU104 [GeForce RTX 2080 Rev. A] 10068
14:44:23:Enabled folding slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463
14:44:23:Enabled folding slot 04: READY gpu:3:TU104 [GeForce RTX 2080 SUPER]
14:44:23:ERROR:No compute devices matched GPU #2 {
14:44:23:ERROR:  "vendor": 4318,
14:44:23:ERROR:  "device": 7041,
14:44:23:ERROR:  "type": 2,
14:44:23:ERROR:  "species": 7,
14:44:23:ERROR:  "description": "GP104 [GeForce GTX 1070] 6463"
14:44:23:ERROR:}.  You may need to update your graphics drivers.
14:44:23:WARNING:WU05:No longer matches Slot 2's configuration, migrating to FS03
14:44:23:ERROR:Exception: Unit not found
14:44:23:WARNING:WU02:No longer matches Slot 3's configuration, migrating to FS02
14:44:23:****************************** FAHClient ******************************
14:44:23:        Version: 7.6.13
14:44:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:44:23:      Copyright: 2020 foldingathome.org
14:44:23:       Homepage: https://foldingathome.org/
14:44:23:           Date: Apr 27 2020
14:44:23:           Time: 21:21:01
14:44:23:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
14:44:23:         Branch: master
14:44:23:       Compiler: Visual C++ 2008
14:44:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:44:23:       Platform: win32 10
14:44:23:           Bits: 32
14:44:23:           Mode: Release
14:44:23:         Config: C:\Users\ricko\AppData\Roaming\FAHClient\config.xml
14:44:23:******************************** CBang ********************************
14:44:23:           Date: Apr 24 2020
14:44:23:           Time: 17:07:55
14:44:23:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
14:44:23:           Bits: 32
14:44:23:******************************* System ********************************
14:44:23:            CPU: Intel(R) Core(TM) i9-9820X CPU @ 3.30GHz
14:44:23:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
14:44:23:           CPUs: 20
14:44:23:         Memory: 15.69GiB
14:44:23:    Free Memory: 13.22GiB
14:44:23:        Threads: WINDOWS_THREADS
14:44:23:     OS Version: 6.2
14:44:23:    Has Battery: false
14:44:23:     On Battery: false
14:44:23:     UTC Offset: -5
14:44:23:            PID: 9348
14:44:23:            CWD: C:\Users\ricko\AppData\Roaming\FAHClient
14:44:23:  Win32 Service: false
14:44:23:             OS: Windows 10 Home
14:44:23:        OS Arch: AMD64
14:44:23:           GPUs: 4
14:44:23:          GPU 0: Bus:23 Slot:0 Func:0 NVIDIA:7 TU104 [GeForce RTX 2070 SUPER]
14:44:23:          GPU 1: Bus:101 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080 Rev. A]
14:44:23:                 10068
14:44:23:          GPU 2: Bus:24 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
14:44:23:          GPU 3: Bus:179 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080 SUPER]
14:44:23:  CUDA Device 0: Platform:0 Device:0 Bus:179 Slot:0 Compute:7.5 Driver:11.0
14:44:23:  CUDA Device 1: Platform:0 Device:1 Bus:101 Slot:0 Compute:7.5 Driver:11.0
14:44:23:  CUDA Device 2: Platform:0 Device:2 Bus:23 Slot:0 Compute:7.5 Driver:11.0
14:44:23:OpenCL Device 0: Platform:0 Device:0 Bus:179 Slot:0 Compute:1.2 Driver:451.48
14:44:23:OpenCL Device 1: Platform:0 Device:1 Bus:101 Slot:0 Compute:1.2 Driver:451.48
14:44:23:OpenCL Device 2: Platform:0 Device:2 Bus:23 Slot:0 Compute:1.2 Driver:451.48
14:44:23:******************************* libFAH ********************************
14:44:23:           Date: Apr 15 2020
14:44:23:           Time: 14:53:14
14:44:23:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:44:23:           Bits: 32
14:44:23:***********************************************************************
14:44:23:<config>
14:44:23:  <!-- Folding Core -->
14:44:23:  <core-priority v='low'/>
14:44:23:
14:44:23:  <!-- Folding Slot Configuration -->
14:44:23:  <cause v='COVID_19'/>
14:44:23:
14:44:23:  <!-- Network -->
14:44:23:  <proxy v=':8080'/>
14:44:23:
14:44:23:  <!-- Slot Control -->
14:44:23:  <power v='full'/>
14:44:23:
14:44:23:  <!-- User Information -->
14:44:23:  <passkey v='*****'/>
14:44:23:  <team v='15'/>
14:44:23:  <user v='rickoic'/>
14:44:23:
14:44:23:  <!-- Folding Slots -->
14:44:23:  <slot id='0' type='CPU'>
14:44:23:    <client-type v='beta'/>
14:44:23:    <cpus v='12'/>
14:44:23:    <max-packet-size v='big'/>
14:44:23:  </slot>
14:44:23:  <slot id='1' type='GPU'>
14:44:23:  </slot>
14:44:23:  <slot id='2' type='GPU'>
14:44:23:  </slot>
14:44:23:  <slot id='3' type='GPU'>
14:44:23:  </slot>
14:44:23:  <slot id='4' type='GPU'>
14:44:23:  </slot>
14:44:23:</config>
14:44:23:WU01:FS01:Starting
14:44:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ricko\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9348 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 2 -cuda-device 2 -gpu 2
14:44:23:WU01:FS01:Started FahCore on PID 5008
14:44:23:WU01:FS01:Core PID:12268
14:44:23:WU01:FS01:FahCore 0x22 started
14:44:23:WU03:FS04:Starting
14:44:23:WU03:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ricko\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9348 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:44:23:WU03:FS04:Started FahCore on PID 11472
14:44:23:WU03:FS04:Core PID:11684
14:44:23:WU03:FS04:FahCore 0x22 started
14:44:23:WU00:FS00:Starting
14:44:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ricko\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 9348 -checkpoint 15 -np 12
14:44:24:WU01:FS01:0x22:*********************** Log Started 2020-10-22T14:44:23Z ***********************
14:44:24:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:44:24:WU01:FS01:0x22:       Core: Core22
14:44:24:WU01:FS01:0x22:       Type: 0x22
14:44:24:WU01:FS01:0x22:    Version: 0.0.13
14:44:24:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:44:24:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:44:24:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:44:24:WU01:FS01:0x22:       Date: Sep 19 2020
14:44:24:WU01:FS01:0x22:       Time: 02:35:58
14:44:24:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:44:24:WU01:FS01:0x22:     Branch: core22-0.0.13
14:44:24:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:44:24:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:44:24:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
14:44:24:WU01:FS01:0x22:   Platform: win32 10
14:44:24:WU01:FS01:0x22:       Bits: 64
14:44:24:WU01:FS01:0x22:       Mode: Release
14:44:24:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:44:24:WU01:FS01:0x22:             <peastman@stanford.edu>
14:44:24:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5008 -checkpoint 15
14:44:24:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 2 -cuda-device
14:44:24:WU01:FS01:0x22:             2 -gpu 2
14:44:24:WU01:FS01:0x22:************************************ libFAH ************************************
14:44:24:WU01:FS01:0x22:       Date: Sep 7 2020
14:44:24:WU01:FS01:0x22:       Time: 19:09:56
14:44:24:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:44:24:WU01:FS01:0x22:     Branch: HEAD
14:44:24:WU01:FS01:0x22:************************************ CBang *************************************
14:44:24:WU01:FS01:0x22:       Time: 19:08:30
14:44:24:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:44:24:WU01:FS01:0x22:************************************ System ************************************
14:44:24:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9820X CPU @ 3.30GHz
14:44:24:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
14:44:24:WU01:FS01:0x22:       CPUs: 20
14:44:24:WU01:FS01:0x22:     Memory: 15.69GiB
14:44:24:WU01:FS01:0x22:Free Memory: 13.14GiB
14:44:24:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:44:24:WU01:FS01:0x22: OS Version: 6.2
14:44:24:WU01:FS01:0x22:Has Battery: false
14:44:24:WU01:FS01:0x22: On Battery: false
14:44:24:WU01:FS01:0x22: UTC Offset: -5
14:44:24:WU01:FS01:0x22:        PID: 12268
14:44:24:WU01:FS01:0x22:        CWD: C:\Users\ricko\AppData\Roaming\FAHClient\work
14:44:24:WU01:FS01:0x22:************************************ OpenMM ************************************
14:44:24:WU01:FS01:0x22:   Revision: 189320d0
14:44:24:WU01:FS01:0x22:********************************************************************************
14:44:24:WU01:FS01:0x22:Project: 17404 (Run 0, Clone 140, Gen 30)
14:44:24:WU01:FS01:0x22:Unit: 0x00000024cedfaa925f59be2ba4b93b8e
14:44:24:WU01:FS01:0x22:Digital signatures verified
14:44:24:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:44:24:WU01:FS01:0x22:Version 0.0.13
14:44:24:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
14:44:24:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
14:44:24:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
14:44:24:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
14:44:24:WU01:FS01:0x22:There are 4 platforms available.
14:44:24:WU01:FS01:0x22:Platform 0: Reference
14:44:24:WU01:FS01:0x22:Platform 1: CPU
14:44:24:WU01:FS01:0x22:Platform 2: OpenCL
14:44:24:WU01:FS01:0x22:  opencl-device 2 specified
14:44:24:WU01:FS01:0x22:Platform 3: CUDA
14:44:24:WU01:FS01:0x22:  cuda-device 2 specified
14:44:24:WU00:FS00:Started FahCore on PID 11504
14:44:24:WU00:FS00:Core PID:3168
14:44:24:WU00:FS00:FahCore 0xa8 started
rickoic
Re: 192.0.2.1
Post by rickoic »
NVIDIA GTX 1070
GPUZ numbers
GP104 Rev A1
10DE 1B81 - 3842 6170
Card that was replaced was a ASUS GTX 1070
Re: 192.0.2.1
Did you reinstall the drivers after swapping the card? You may also need to reinstall the folding client to properly detect the hardware change.
Re: 192.0.2.1
You have 4 cards and 3 drivers.
Consider writing down your User Name, Team ID and Paskey. Then uninstall including data. reboot and reinstall.
I find that install does a better job detect hardware than the client.
I hope that helps.
Knish
Re: 192.0.2.1
Post by Knish »
at some point in time all my cloud GPU instances (on debian + nvidia tesla cards) will get this error sending it to 192... I don't think they get it more than once. But I found all I would have to do is redo my sudo apt install gcc make linux-headers-$(uname -r) in order to redo the sudo ./NVIDIA* to reinstall the driver then all is well after a reboot.
I have no idea what seems to cause this. It's not an outdated driver as I just use the same one and then never have to do it again, as this only seems to happen once. Perhaps the only 'pattern' I feel is occurring is that upon starting a new gpu instance, I expect this to happen sometime in the first week or so, then it's fine for the rest of its operational lifetime.
I have looked back thru logs, which don't seem to reveal anything out of the ordinary. GCP has daily preemptions, so randomly a newly started instance will one day start up and for whatever reason need a driver reinstall (but just once and never again). Azure will stay running unless the price inflates past my threshold so tends to stay running much, much longer. Unfortunately I can't tell if a preemption was price related or something else, but on newly started instances when it comes back up, for whatever reason it will need a driver reinstall, and again just once, only once.
rickoic
Re: 192.0.2.1
Post by rickoic »
OK, tks everyone. I deleted FAH including data, rebooted, reinstalled and now all is working fine.
Still have original email giving me my key so remembering that is no problem.
Re: 192.0.2.1
Great! Thank you for the feedback! It is easier to spout off if it works!
