GPU problem
simonvilleneuve
GPU problem
Post by simonvilleneuve »
Hi,
My Dell Latitude 7390 under Windows 10 can't load a GPU slot. I have followed the steps described in the FAQ, but nothing work.
Re: GPU problem
Please post the top segment of your log (see below)
Have you installed the drivers from the manufacturer of you GPU chip? The ones installed by Windows are incomplete. Then remove the setting GPU - FALSE.
simonvilleneuve
Re: GPU problem log 1/2
*********************** Log Started 2020-10-20T19:32:37Z ***********************
19:32:37:Trying to access database...
19:32:37:Successfully acquired database lock
19:32:37:Read GPUs.txt
19:32:37:Enabled folding slot 00: PAUSED cpu:8 (by user)
19:32:38:****************************** FAHClient ******************************
19:32:38:        Version: 7.6.13
19:32:38:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:32:38:      Copyright: 2020 foldingathome.org
19:32:38:       Homepage: https://foldingathome.org/
19:32:38:           Date: Apr 27 2020
19:32:38:           Time: 21:21:01
19:32:38:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:32:38:         Branch: master
19:32:38:       Compiler: Visual C++ 2008
19:32:38:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:32:38:       Platform: win32 10
19:32:38:           Bits: 32
19:32:38:           Mode: Release
19:32:38:         Config: C:\Users\svilleneuve\AppData\Roaming\FAHClient\config.xml
19:32:38:******************************** CBang ********************************
19:32:38:           Date: Apr 24 2020
19:32:38:           Time: 17:07:55
19:32:38:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:32:38:           Bits: 32
19:32:38:******************************* System ********************************
19:32:38:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
19:32:38:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
19:32:38:           CPUs: 8
19:32:38:         Memory: 15.86GiB
19:32:38:    Free Memory: 13.01GiB
19:32:38:        Threads: WINDOWS_THREADS
19:32:38:     OS Version: 6.2
19:32:38:    Has Battery: true
19:32:38:     On Battery: false
19:32:38:     UTC Offset: -4
19:32:38:            PID: 14040
19:32:38:            CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient
19:32:38:  Win32 Service: false
19:32:38:             OS: Windows 10 Enterprise
19:32:38:        OS Arch: AMD64
19:32:38:           GPUs: 0
19:32:38:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Le
19:32:38:                 module spcifi est introuvable.
19:32:38:
19:32:38:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:24.20
19:32:38:******************************* libFAH ********************************
19:32:38:           Date: Apr 15 2020
19:32:38:           Time: 14:53:14
19:32:38:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:32:38:           Bits: 32
19:32:38:***********************************************************************
19:32:38:<config>
19:32:38:  <!-- Folding Slot Configuration -->
19:32:38:  <cause v='COVID_19'/>
19:32:38:
19:32:38:  <!-- Network -->
19:32:38:  <proxy v=':8080'/>
19:32:38:
19:32:38:  <!-- Slot Control -->
19:32:38:  <power v='full'/>
19:32:38:
19:32:38:  <!-- User Information -->
19:32:38:  <team v='240085'/>
19:32:38:  <user v='Khayman_qc'/>
19:32:38:
19:32:38:  <!-- Folding Slots -->
19:32:38:  <slot id='0' type='CPU'>
19:32:38:    <paused v='true'/>
19:32:38:  </slot>
19:32:38:</config>
20:57:29:FS00:Unpaused
20:57:29:WU01:FS00:Starting
20:57:29:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
20:57:29:WU01:FS00:Started FahCore on PID 12056
20:57:29:WU01:FS00:Core PID:13536
20:57:29:WU01:FS00:FahCore 0xa8 started
20:57:29:WU01:FS00:0xa8:*********************** Log Started 2020-10-20T20:57:29Z ***********************
20:57:29:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:57:29:WU01:FS00:0xa8:       Core: Gromacs
20:57:29:WU01:FS00:0xa8:       Type: 0xa8
20:57:29:WU01:FS00:0xa8:    Version: 0.0.8
20:57:29:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:57:29:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
20:57:29:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
20:57:29:WU01:FS00:0xa8:       Date: Sep 25 2020
20:57:29:WU01:FS00:0xa8:       Time: 08:28:00
20:57:29:WU01:FS00:0xa8:   Revision: d4f41a5b7a748fdb0ff538746b195ca3a8075aae
20:57:29:WU01:FS00:0xa8:     Branch: master
20:57:29:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:57:29:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Ob3
20:57:29:WU01:FS00:0xa8:             /Zc:throwingNew /MT
20:57:29:WU01:FS00:0xa8:   Platform: win32 10
20:57:29:WU01:FS00:0xa8:       Bits: 64
20:57:29:WU01:FS00:0xa8:       Mode: Release
20:57:29:WU01:FS00:0xa8:       SIMD: avx2_256
20:57:29:WU01:FS00:0xa8:     OpenMP: ON
20:57:29:WU01:FS00:0xa8:       CUDA: OFF
20:57:29:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12056 -checkpoint 15 -np
20:57:29:WU01:FS00:0xa8:             8
20:57:29:WU01:FS00:0xa8:************************************ libFAH ************************************
20:57:29:WU01:FS00:0xa8:       Time: 07:23:00
20:57:29:WU01:FS00:0xa8:************************************ CBang *************************************
20:57:29:WU01:FS00:0xa8:       Time: 07:22:40
20:57:29:WU01:FS00:0xa8:************************************ System ************************************
20:57:29:WU01:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:57:29:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:57:29:WU01:FS00:0xa8:       CPUs: 8
20:57:29:WU01:FS00:0xa8:     Memory: 15.86GiB
20:57:29:WU01:FS00:0xa8:Free Memory: 9.22GiB
20:57:29:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
20:57:29:WU01:FS00:0xa8: OS Version: 6.2
20:57:29:WU01:FS00:0xa8:Has Battery: true
20:57:29:WU01:FS00:0xa8: On Battery: false
20:57:29:WU01:FS00:0xa8: UTC Offset: -4
20:57:29:WU01:FS00:0xa8:        PID: 13536
20:57:29:WU01:FS00:0xa8:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
20:57:29:WU01:FS00:0xa8:********************************************************************************
20:57:29:WU01:FS00:0xa8:Project: 16812 (Run 7, Clone 1019, Gen 2)
20:57:29:WU01:FS00:0xa8:Unit: 0x00000002b2aec48a5f8ddf258b16deb4
20:57:29:WU01:FS00:0xa8:Digital signatures verified
20:57:29:WU01:FS00:0xa8:Calling: mdrun -c frame2.gro -s frame2.tpr -x frame2.xtc -cpi state.cpt -cpt 15 -nt 8 -ntmpi 1
20:57:29:WU01:FS00:0xa8:Steps: first=1000000 total=1500000
20:57:31:WU01:FS00:0xa8:Completed 468322 out of 500000 steps (93%)
20:58:09:Removing old file 'configs/config-20201012-022917.xml'
20:58:09:Saving configuration to config.xml
20:58:09:<config>
20:58:09:  <!-- Folding Slot Configuration -->
20:58:09:  <cause v='COVID_19'/>
20:58:09:
20:58:09:  <!-- Network -->
20:58:09:  <proxy v=':8080'/>
20:58:09:
20:58:09:  <!-- Slot Control -->
20:58:09:  <power v='full'/>
20:58:09:
20:58:09:  <!-- User Information -->
20:58:09:  <team v='240085'/>
20:58:09:  <user v='Khayman_qc'/>
20:58:09:
20:58:09:  <!-- Folding Slots -->
20:58:09:  <slot id='0' type='CPU'/>
20:58:09:</config>
20:58:36:WU01:FS00:0xa8:Completed 470000 out of 500000 steps (94%)
21:01:58:WU01:FS00:0xa8:Completed 475000 out of 500000 steps (95%)
21:05:46:WU01:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
21:10:02:WU01:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
21:13:58:WU01:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
21:18:01:WU01:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
21:18:02:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:18:02:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:18:02:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:18:02:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:18:03:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:18:03:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:18:03:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:18:03:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:18:03:ERROR:WU00:FS00:Exception: Could not get an assignment
21:18:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:18:03:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:18:04:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:18:04:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:18:04:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:18:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:18:04:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:18:04:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:18:04:ERROR:WU00:FS00:Exception: Could not get an assignment
21:19:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:19:04:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:19:04:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:19:04:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:19:04:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:19:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:19:04:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:19:04:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:19:04:ERROR:WU00:FS00:Exception: Could not get an assignment
21:20:41:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:20:41:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:20:41:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:20:41:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:20:41:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:20:41:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:20:41:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:20:41:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:20:41:ERROR:WU00:FS00:Exception: Could not get an assignment
21:22:15:WU01:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
21:22:16:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
21:22:16:WU01:FS00:0xa8:Saving result file frame2.gro
21:22:16:WU01:FS00:0xa8:Saving result file frame2.xtc
21:22:16:WU01:FS00:0xa8:Saving result file md.log
21:22:16:WU01:FS00:0xa8:Saving result file science.log
21:22:16:WU01:FS00:0xa8:Saving result file state.cpt
21:22:16:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
21:22:17:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:22:17:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16812 run:7 clone:1019 gen:2 core:0xa8 unit:0x00000002b2aec48a5f8ddf258b16deb4
21:22:17:WU01:FS00:Uploading 8.37MiB to 178.174.196.138
21:22:17:WU01:FS00:Connecting to 178.174.196.138:8080
21:22:23:WU01:FS00:Upload 28.37%
21:22:29:WU01:FS00:Upload 51.52%
21:22:35:WU01:FS00:Upload 72.43%
21:22:41:WU01:FS00:Upload 94.08%
21:22:42:WU01:FS00:Upload complete
21:22:43:WU01:FS00:Server responded WORK_ACK (400)
21:22:43:WU01:FS00:Final credit estimate, 6803.00 points
21:22:43:WU01:FS00:Cleaning up
21:23:18:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:23:18:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:23:18:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:23:18:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:23:18:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:23:18:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:23:18:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:23:19:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:23:19:ERROR:WU00:FS00:Exception: Could not get an assignment
21:27:32:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:27:32:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:27:32:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:27:33:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:27:33:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:27:33:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:27:33:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:27:33:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:27:33:ERROR:WU00:FS00:Exception: Could not get an assignment
21:34:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:34:24:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:34:24:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:34:24:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:34:24:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:34:24:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:34:24:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:34:25:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:34:25:ERROR:WU00:FS00:Exception: Could not get an assignment
21:45:29:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:45:30:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:45:30:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:45:30:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:45:30:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:45:30:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:45:30:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:45:30:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:45:30:ERROR:WU00:FS00:Exception: Could not get an assignment
22:03:26:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:03:26:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
22:03:26:WU00:FS00:Connecting to assign2.foldingathome.org:80
22:03:26:WU00:FS00:Assigned to work server 206.223.170.146
22:03:27:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 206.223.170.146
22:03:27:WU00:FS00:Connecting to 206.223.170.146:8080
22:03:27:ERROR:WU00:FS00:Exception: Server did not assign work unit
22:32:28:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:32:28:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
22:32:29:WU00:FS00:Connecting to assign2.foldingathome.org:80
22:32:29:WU00:FS00:Assigned to work server 178.174.196.138
22:32:29:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 178.174.196.138
22:32:29:WU00:FS00:Connecting to 178.174.196.138:8080
22:32:30:WU00:FS00:Downloading 2.05MiB
22:32:32:WU00:FS00:Download complete
22:32:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16812 run:10 clone:1216 gen:3 core:0xa8 unit:0x00000003b2aec48a5f8ddf2675b87f64
22:32:32:WU00:FS00:Starting
22:32:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
22:32:32:WU00:FS00:Started FahCore on PID 2764
22:32:32:WU00:FS00:Core PID:12316
22:32:32:WU00:FS00:FahCore 0xa8 started
22:32:32:WU00:FS00:0xa8:*********************** Log Started 2020-10-20T22:32:32Z ***********************
22:32:33:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:32:33:WU00:FS00:0xa8:       Core: Gromacs
22:32:33:WU00:FS00:0xa8:       Type: 0xa8
22:32:33:WU00:FS00:0xa8:    Version: 0.0.8
22:32:33:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:32:33:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
22:32:33:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
22:32:33:WU00:FS00:0xa8:       Date: Sep 25 2020
22:32:33:WU00:FS00:0xa8:       Time: 08:28:00
22:32:33:WU00:FS00:0xa8:   Revision: d4f41a5b7a748fdb0ff538746b195ca3a8075aae
22:32:33:WU00:FS00:0xa8:     Branch: master
22:32:33:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
22:32:33:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Ob3
22:32:33:WU00:FS00:0xa8:             /Zc:throwingNew /MT
22:32:33:WU00:FS00:0xa8:   Platform: win32 10
22:32:33:WU00:FS00:0xa8:       Bits: 64
22:32:33:WU00:FS00:0xa8:       Mode: Release
22:32:33:WU00:FS00:0xa8:       SIMD: avx2_256
22:32:33:WU00:FS00:0xa8:     OpenMP: ON
22:32:33:WU00:FS00:0xa8:       CUDA: OFF
22:32:33:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2764 -checkpoint 15 -np 8
22:32:33:WU00:FS00:0xa8:************************************ libFAH ************************************
22:32:33:WU00:FS00:0xa8:       Time: 07:23:00
22:32:33:WU00:FS00:0xa8:************************************ CBang *************************************
22:32:33:WU00:FS00:0xa8:       Time: 07:22:40
22:32:33:WU00:FS00:0xa8:************************************ System ************************************
22:32:33:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
22:32:33:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
22:32:33:WU00:FS00:0xa8:       CPUs: 8
22:32:33:WU00:FS00:0xa8:     Memory: 15.86GiB
22:32:33:WU00:FS00:0xa8:Free Memory: 9.10GiB
22:32:33:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
22:32:33:WU00:FS00:0xa8: OS Version: 6.2
22:32:33:WU00:FS00:0xa8:Has Battery: true
22:32:33:WU00:FS00:0xa8: On Battery: false
22:32:33:WU00:FS00:0xa8: UTC Offset: -4
22:32:33:WU00:FS00:0xa8:        PID: 12316
22:32:33:WU00:FS00:0xa8:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
22:32:33:WU00:FS00:0xa8:********************************************************************************
22:32:33:WU00:FS00:0xa8:Project: 16812 (Run 10, Clone 1216, Gen 3)
22:32:33:WU00:FS00:0xa8:Unit: 0x00000003b2aec48a5f8ddf2675b87f64
22:32:33:WU00:FS00:0xa8:Reading tar file core.xml
22:32:33:WU00:FS00:0xa8:Reading tar file frame3.tpr
22:32:33:WU00:FS00:0xa8:Digital signatures verified
22:32:33:WU00:FS00:0xa8:Calling: mdrun -c frame3.gro -s frame3.tpr -x frame3.xtc -cpt 15 -nt 8 -ntmpi 1
22:32:33:WU00:FS00:0xa8:Steps: first=1500000 total=2000000
22:32:34:WU00:FS00:0xa8:Completed 1 out of 500000 steps (0%)
22:35:55:WU00:FS00:0xa8:Completed 5000 out of 500000 steps (1%)
22:39:39:WU00:FS00:0xa8:Completed 10000 out of 500000 steps (2%)
22:43:35:WU00:FS00:0xa8:Completed 15000 out of 500000 steps (3%)
22:47:34:WU00:FS00:0xa8:Completed 20000 out of 500000 steps (4%)
22:51:35:WU00:FS00:0xa8:Completed 25000 out of 500000 steps (5%)
22:55:34:WU00:FS00:0xa8:Completed 30000 out of 500000 steps (6%)
22:59:34:WU00:FS00:0xa8:Completed 35000 out of 500000 steps (7%)
23:03:37:WU00:FS00:0xa8:Completed 40000 out of 500000 steps (8%)
23:07:34:WU00:FS00:0xa8:Completed 45000 out of 500000 steps (9%)
23:11:33:WU00:FS00:0xa8:Completed 50000 out of 500000 steps (10%)
23:16:06:WU00:FS00:0xa8:Completed 55000 out of 500000 steps (11%)
23:20:41:WU00:FS00:0xa8:Completed 60000 out of 500000 steps (12%)
23:24:38:WU00:FS00:0xa8:Completed 65000 out of 500000 steps (13%)
23:28:36:WU00:FS00:0xa8:Completed 70000 out of 500000 steps (14%)
23:32:43:WU00:FS00:0xa8:Completed 75000 out of 500000 steps (15%)
23:36:47:WU00:FS00:0xa8:Completed 80000 out of 500000 steps (16%)
23:40:45:WU00:FS00:0xa8:Completed 85000 out of 500000 steps (17%)
23:44:47:WU00:FS00:0xa8:Completed 90000 out of 500000 steps (18%)
23:48:53:WU00:FS00:0xa8:Completed 95000 out of 500000 steps (19%)
23:52:52:WU00:FS00:0xa8:Completed 100000 out of 500000 steps (20%)
23:56:52:WU00:FS00:0xa8:Completed 105000 out of 500000 steps (21%)
00:00:51:WU00:FS00:0xa8:Completed 110000 out of 500000 steps (22%)
00:04:50:WU00:FS00:0xa8:Completed 115000 out of 500000 steps (23%)
00:08:49:WU00:FS00:0xa8:Completed 120000 out of 500000 steps (24%)
00:12:48:WU00:FS00:0xa8:Completed 125000 out of 500000 steps (25%)
00:16:44:WU00:FS00:0xa8:Completed 130000 out of 500000 steps (26%)
00:20:42:WU00:FS00:0xa8:Completed 135000 out of 500000 steps (27%)
00:24:39:WU00:FS00:0xa8:Completed 140000 out of 500000 steps (28%)
00:28:43:WU00:FS00:0xa8:Completed 145000 out of 500000 steps (29%)
00:32:39:WU00:FS00:0xa8:Completed 150000 out of 500000 steps (30%)
00:36:43:WU00:FS00:0xa8:Completed 155000 out of 500000 steps (31%)
00:40:40:WU00:FS00:0xa8:Completed 160000 out of 500000 steps (32%)
00:44:37:WU00:FS00:0xa8:Completed 165000 out of 500000 steps (33%)
00:48:36:WU00:FS00:0xa8:Completed 170000 out of 500000 steps (34%)
00:52:32:WU00:FS00:0xa8:Completed 175000 out of 500000 steps (35%)
00:56:31:WU00:FS00:0xa8:Completed 180000 out of 500000 steps (36%)
01:00:30:WU00:FS00:0xa8:Completed 185000 out of 500000 steps (37%)
01:02:00:FS00:Paused
01:02:00:FS00:Shutting core down
01:02:01:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 12316
01:02:01:WU00:FS00:0xa8:Exiting, please wait. . .
01:02:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:02:09:Removing old file 'configs/config-20201013-003400.xml'
01:02:09:Saving configuration to config.xml
01:02:09:<config>
01:02:09:  <!-- Folding Slot Configuration -->
01:02:09:  <cause v='COVID_19'/>
01:02:09:
01:02:09:  <!-- Network -->
01:02:09:  <proxy v=':8080'/>
01:02:09:
01:02:09:  <!-- Slot Control -->
01:02:09:  <power v='full'/>
01:02:09:
01:02:09:  <!-- User Information -->
01:02:09:  <team v='240085'/>
01:02:09:  <user v='Khayman_qc'/>
01:02:09:
01:02:09:  <!-- Folding Slots -->
01:02:09:  <slot id='0' type='CPU'>
01:02:09:    <paused v='true'/>
01:02:09:  </slot>
01:02:09:</config>
******************************* Date: 2020-10-21 *******************************
03:11:14:FS00:Unpaused
03:11:14:WU00:FS00:Starting
03:11:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
03:11:14:WU00:FS00:Started FahCore on PID 9080
03:11:14:WU00:FS00:Core PID:8228
03:11:14:WU00:FS00:FahCore 0xa8 started
03:11:14:WU00:FS00:0xa8:*********************** Log Started 2020-10-21T03:11:14Z ***********************
03:11:14:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
03:11:14:WU00:FS00:0xa8:       Core: Gromacs
03:11:14:WU00:FS00:0xa8:       Type: 0xa8
03:11:14:WU00:FS00:0xa8:    Version: 0.0.8
03:11:14:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:11:14:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
03:11:14:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
03:11:14:WU00:FS00:0xa8:       Date: Sep 25 2020
03:11:14:WU00:FS00:0xa8:       Time: 08:28:00
03:11:14:WU00:FS00:0xa8:   Revision: d4f41a5b7a748fdb0ff538746b195ca3a8075aae
03:11:14:WU00:FS00:0xa8:     Branch: master
03:11:14:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
03:11:14:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Ob3
03:11:14:WU00:FS00:0xa8:             /Zc:throwingNew /MT
03:11:14:WU00:FS00:0xa8:   Platform: win32 10
03:11:14:WU00:FS00:0xa8:       Bits: 64
03:11:14:WU00:FS00:0xa8:       Mode: Release
03:11:14:WU00:FS00:0xa8:       SIMD: avx2_256
03:11:14:WU00:FS00:0xa8:     OpenMP: ON
03:11:14:WU00:FS00:0xa8:       CUDA: OFF
03:11:14:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9080 -checkpoint 15 -np 8
03:11:14:WU00:FS00:0xa8:************************************ libFAH ************************************
03:11:14:WU00:FS00:0xa8:       Time: 07:23:00
03:11:14:WU00:FS00:0xa8:************************************ CBang *************************************
03:11:14:WU00:FS00:0xa8:       Time: 07:22:40
03:11:14:WU00:FS00:0xa8:************************************ System ************************************
03:11:14:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
03:11:14:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
03:11:14:WU00:FS00:0xa8:       CPUs: 8
03:11:14:WU00:FS00:0xa8:     Memory: 15.86GiB
03:11:14:WU00:FS00:0xa8:Free Memory: 9.52GiB
03:11:14:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
03:11:14:WU00:FS00:0xa8: OS Version: 6.2
03:11:14:WU00:FS00:0xa8:Has Battery: true
03:11:14:WU00:FS00:0xa8: On Battery: false
03:11:14:WU00:FS00:0xa8: UTC Offset: -4
03:11:14:WU00:FS00:0xa8:        PID: 8228
03:11:14:WU00:FS00:0xa8:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
03:11:14:WU00:FS00:0xa8:********************************************************************************
03:11:14:WU00:FS00:0xa8:Project: 16812 (Run 10, Clone 1216, Gen 3)
03:11:14:WU00:FS00:0xa8:Unit: 0x00000003b2aec48a5f8ddf2675b87f64
03:11:14:WU00:FS00:0xa8:Digital signatures verified
03:11:14:WU00:FS00:0xa8:Calling: mdrun -c frame3.gro -s frame3.tpr -x frame3.xtc -cpi state.cpt -cpt 15 -nt 8 -ntmpi 1
03:11:14:WU00:FS00:0xa8:Steps: first=1500000 total=2000000
03:11:16:WU00:FS00:0xa8:Completed 186862 out of 500000 steps (37%)
03:11:17:Removing old file 'configs/config-20201013-030226.xml'
03:11:17:Saving configuration to config.xml
03:11:17:<config>
03:11:17:  <!-- Folding Slot Configuration -->
03:11:17:  <cause v='COVID_19'/>
03:11:17:
03:11:17:  <!-- Network -->
03:11:17:  <proxy v=':8080'/>
03:11:17:
03:11:17:  <!-- Slot Control -->
03:11:17:  <power v='full'/>
03:11:17:
03:11:17:  <!-- User Information -->
03:11:17:  <team v='240085'/>
03:11:17:  <user v='Khayman_qc'/>
03:11:17:
03:11:17:  <!-- Folding Slots -->
03:11:17:  <slot id='0' type='CPU'/>
03:11:17:</config>
03:14:32:WU00:FS00:0xa8:Completed 190000 out of 500000 steps (38%)
03:18:36:WU00:FS00:0xa8:Completed 195000 out of 500000 steps (39%)
03:22:40:WU00:FS00:0xa8:Completed 200000 out of 500000 steps (40%)
03:26:37:WU00:FS00:0xa8:Completed 205000 out of 500000 steps (41%)
03:30:28:WU00:FS00:0xa8:Completed 210000 out of 500000 steps (42%)
03:34:24:WU00:FS00:0xa8:Completed 215000 out of 500000 steps (43%)
03:38:14:WU00:FS00:0xa8:Completed 220000 out of 500000 steps (44%)
03:42:05:WU00:FS00:0xa8:Completed 225000 out of 500000 steps (45%)
03:45:52:WU00:FS00:0xa8:Completed 230000 out of 500000 steps (46%)
03:49:41:WU00:FS00:0xa8:Completed 235000 out of 500000 steps (47%)
03:53:52:WU00:FS00:0xa8:Completed 240000 out of 500000 steps (48%)
03:57:42:WU00:FS00:0xa8:Completed 245000 out of 500000 steps (49%)
04:01:30:WU00:FS00:0xa8:Completed 250000 out of 500000 steps (50%)
04:05:19:WU00:FS00:0xa8:Completed 255000 out of 500000 steps (51%)
04:09:09:WU00:FS00:0xa8:Completed 260000 out of 500000 steps (52%)
04:12:59:WU00:FS00:0xa8:Completed 265000 out of 500000 steps (53%)
04:16:47:WU00:FS00:0xa8:Completed 270000 out of 500000 steps (54%)
04:20:34:WU00:FS00:0xa8:Completed 275000 out of 500000 steps (55%)
04:24:21:WU00:FS00:0xa8:Completed 280000 out of 500000 steps (56%)
04:28:09:WU00:FS00:0xa8:Completed 285000 out of 500000 steps (57%)
04:31:55:WU00:FS00:0xa8:Completed 290000 out of 500000 steps (58%)
04:35:47:WU00:FS00:0xa8:Completed 295000 out of 500000 steps (59%)
04:39:33:WU00:FS00:0xa8:Completed 300000 out of 500000 steps (60%)
04:43:25:WU00:FS00:0xa8:Completed 305000 out of 500000 steps (61%)
04:47:12:WU00:FS00:0xa8:Completed 310000 out of 500000 steps (62%)
04:50:59:WU00:FS00:0xa8:Completed 315000 out of 500000 steps (63%)
04:54:45:WU00:FS00:0xa8:Completed 320000 out of 500000 steps (64%)
04:58:32:WU00:FS00:0xa8:Completed 325000 out of 500000 steps (65%)
05:02:18:WU00:FS00:0xa8:Completed 330000 out of 500000 steps (66%)
05:06:05:WU00:FS00:0xa8:Completed 335000 out of 500000 steps (67%)
05:09:51:WU00:FS00:0xa8:Completed 340000 out of 500000 steps (68%)
05:13:36:WU00:FS00:0xa8:Completed 345000 out of 500000 steps (69%)
05:17:22:WU00:FS00:0xa8:Completed 350000 out of 500000 steps (70%)
05:21:09:WU00:FS00:0xa8:Completed 355000 out of 500000 steps (71%)
05:24:54:WU00:FS00:0xa8:Completed 360000 out of 500000 steps (72%)
05:28:41:WU00:FS00:0xa8:Completed 365000 out of 500000 steps (73%)
05:32:28:WU00:FS00:0xa8:Completed 370000 out of 500000 steps (74%)
05:36:25:WU00:FS00:0xa8:Completed 375000 out of 500000 steps (75%)
05:40:11:WU00:FS00:0xa8:Completed 380000 out of 500000 steps (76%)
05:43:57:WU00:FS00:0xa8:Completed 385000 out of 500000 steps (77%)
05:47:47:WU00:FS00:0xa8:Completed 390000 out of 500000 steps (78%)
05:51:32:WU00:FS00:0xa8:Completed 395000 out of 500000 steps (79%)
05:55:15:WU00:FS00:0xa8:Completed 400000 out of 500000 steps (80%)
05:59:01:WU00:FS00:0xa8:Completed 405000 out of 500000 steps (81%)
06:02:45:WU00:FS00:0xa8:Completed 410000 out of 500000 steps (82%)
06:06:30:WU00:FS00:0xa8:Completed 415000 out of 500000 steps (83%)
06:10:14:WU00:FS00:0xa8:Completed 420000 out of 500000 steps (84%)
06:14:00:WU00:FS00:0xa8:Completed 425000 out of 500000 steps (85%)
06:17:45:WU00:FS00:0xa8:Completed 430000 out of 500000 steps (86%)
06:21:30:WU00:FS00:0xa8:Completed 435000 out of 500000 steps (87%)
06:25:14:WU00:FS00:0xa8:Completed 440000 out of 500000 steps (88%)
06:28:59:WU00:FS00:0xa8:Completed 445000 out of 500000 steps (89%)
06:32:43:WU00:FS00:0xa8:Completed 450000 out of 500000 steps (90%)
06:36:35:WU00:FS00:0xa8:Completed 455000 out of 500000 steps (91%)
06:40:53:WU00:FS00:0xa8:Completed 460000 out of 500000 steps (92%)
06:44:44:WU00:FS00:0xa8:Completed 465000 out of 500000 steps (93%)
06:48:39:WU00:FS00:0xa8:Completed 470000 out of 500000 steps (94%)
06:52:23:WU00:FS00:0xa8:Completed 475000 out of 500000 steps (95%)
06:56:07:WU00:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
06:59:52:WU00:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
07:03:38:WU00:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
07:07:22:WU00:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
07:07:23:WU01:FS00:Connecting to assign1.foldingathome.org:80
07:07:23:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
07:07:23:WU01:FS00:Connecting to assign2.foldingathome.org:80
07:07:24:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
07:07:24:WU01:FS00:Connecting to assign3.foldingathome.org:80
07:07:24:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
07:07:24:WU01:FS00:Connecting to assign4.foldingathome.org:80
07:07:24:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
07:07:24:ERROR:WU01:FS00:Exception: Could not get an assignment
07:07:24:WU01:FS00:Connecting to assign1.foldingathome.org:80
07:07:25:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
07:07:25:WU01:FS00:Connecting to assign2.foldingathome.org:80
07:07:25:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
07:07:25:WU01:FS00:Connecting to assign3.foldingathome.org:80
07:07:25:WU01:FS00:Assigned to work server 69.94.66.7
07:07:25:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 69.94.66.7
07:07:25:WU01:FS00:Connecting to 69.94.66.7:8080
07:07:27:WU01:FS00:Downloading 2.82MiB
07:07:27:WU01:FS00:Download complete
07:07:27:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14379 run:2594 clone:1 gen:528 core:0xa7 unit:0x00000258455e42075e932f365eee3fee
07:11:06:WU00:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
07:11:07:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
07:11:07:WU00:FS00:0xa8:Saving result file frame3.gro
07:11:07:WU00:FS00:0xa8:Saving result file frame3.xtc
07:11:07:WU00:FS00:0xa8:Saving result file md.log
07:11:07:WU00:FS00:0xa8:Saving result file science.log
07:11:07:WU00:FS00:0xa8:Saving result file state.cpt
07:11:07:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
07:11:07:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:11:07:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:10 clone:1216 gen:3 core:0xa8 unit:0x00000003b2aec48a5f8ddf2675b87f64
07:11:07:WU00:FS00:Uploading 8.35MiB to 178.174.196.138
07:11:07:WU00:FS00:Connecting to 178.174.196.138:8080
07:11:07:WU01:FS00:Starting
07:11:07:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
07:11:08:WU01:FS00:Started FahCore on PID 13244
07:11:08:WU01:FS00:Core PID:12780
07:11:08:WU01:FS00:FahCore 0xa7 started
07:11:08:WU01:FS00:0xa7:*********************** Log Started 2020-10-21T07:11:08Z ***********************
07:11:08:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:11:08:WU01:FS00:0xa7:       Type: 0xa7
07:11:08:WU01:FS00:0xa7:       Core: Gromacs
07:11:08:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13244 -checkpoint 15 -np
07:11:08:WU01:FS00:0xa7:             8
07:11:08:WU01:FS00:0xa7:************************************ CBang *************************************
07:11:08:WU01:FS00:0xa7:       Date: Nov 27 2019
07:11:08:WU01:FS00:0xa7:       Time: 03:40:09
07:11:08:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:11:08:WU01:FS00:0xa7:     Branch: master
07:11:08:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:11:08:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:11:08:WU01:FS00:0xa7:   Platform: win32 10
07:11:08:WU01:FS00:0xa7:       Bits: 64
07:11:08:WU01:FS00:0xa7:       Mode: Release
07:11:08:WU01:FS00:0xa7:************************************ System ************************************
07:11:08:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
07:11:08:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
07:11:08:WU01:FS00:0xa7:       CPUs: 8
07:11:08:WU01:FS00:0xa7:     Memory: 15.86GiB
07:11:08:WU01:FS00:0xa7:Free Memory: 9.82GiB
07:11:08:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
07:11:08:WU01:FS00:0xa7: OS Version: 6.2
07:11:08:WU01:FS00:0xa7:Has Battery: true
07:11:08:WU01:FS00:0xa7: On Battery: false
07:11:08:WU01:FS00:0xa7: UTC Offset: -4
07:11:08:WU01:FS00:0xa7:        PID: 12780
07:11:08:WU01:FS00:0xa7:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
07:11:08:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:11:08:WU01:FS00:0xa7:    Version: 0.0.19
07:11:08:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:11:08:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
simonvilleneuve
Re: GPU problem log 2/2
07:11:08:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:11:08:WU01:FS00:0xa7:       Date: Nov 25 2019
07:11:08:WU01:FS00:0xa7:       Time: 17:12:41
07:11:08:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:11:08:WU01:FS00:0xa7:************************************ Build *************************************
07:11:08:WU01:FS00:0xa7:       SIMD: avx_256
07:11:08:WU01:FS00:0xa7:********************************************************************************
07:11:08:WU01:FS00:0xa7:Project: 14379 (Run 2594, Clone 1, Gen 528)
07:11:08:WU01:FS00:0xa7:Unit: 0x00000258455e42075e932f365eee3fee
07:11:08:WU01:FS00:0xa7:Reading tar file core.xml
07:11:08:WU01:FS00:0xa7:Reading tar file frame528.tpr
07:11:08:WU01:FS00:0xa7:Digital signatures verified
07:11:08:WU01:FS00:0xa7:Calling: mdrun -s frame528.tpr -o frame528.trr -cpt 15 -nt 8
07:11:08:WU01:FS00:0xa7:Steps: first=0 total=250000
07:11:10:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
07:11:13:WU00:FS00:Upload 31.45%
07:11:19:WU00:FS00:Upload 68.88%
07:11:24:WU00:FS00:Upload complete
07:11:24:WU00:FS00:Server responded WORK_ACK (400)
07:11:24:WU00:FS00:Final credit estimate, 7864.00 points
07:11:24:WU00:FS00:Cleaning up
07:13:19:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
07:15:31:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
07:17:43:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
07:19:54:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
07:22:05:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
07:24:17:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
07:26:29:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
07:28:40:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
07:30:51:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
07:33:03:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
07:35:18:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
07:37:35:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
07:39:45:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
07:41:57:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
07:44:07:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
07:46:19:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
07:48:31:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
07:50:39:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
07:52:51:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
07:55:02:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
07:57:14:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
07:59:25:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
08:01:37:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
08:03:50:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
08:06:02:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
08:08:15:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
08:10:27:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
08:12:39:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
08:14:50:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
08:17:01:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
08:19:12:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
08:21:22:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
08:23:31:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
08:25:40:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
08:27:51:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
08:30:00:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
08:32:10:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
08:34:27:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
08:36:37:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
08:38:46:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
08:40:56:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
08:43:06:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
08:45:16:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
08:47:26:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
08:49:37:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
08:51:46:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
08:53:58:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
08:56:14:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
08:58:24:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
09:00:32:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
09:02:42:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
09:04:52:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
09:07:02:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
09:09:12:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
09:11:25:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
09:13:34:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
09:15:43:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
09:17:54:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
09:20:04:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
09:22:14:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
09:24:25:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
09:26:38:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
09:28:49:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
09:31:00:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
09:33:13:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
09:35:27:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
09:37:47:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
09:40:04:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
09:42:27:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
09:44:59:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
09:47:15:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
09:49:27:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
09:51:38:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
09:53:50:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
09:56:01:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
09:58:13:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
10:00:22:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
10:02:33:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
10:04:43:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
10:06:53:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
10:09:02:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
10:11:13:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
10:13:22:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
10:15:32:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
10:17:41:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
10:19:53:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
10:22:03:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
10:24:13:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
10:26:23:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
10:28:32:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
10:30:41:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
10:32:52:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
10:35:04:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
10:37:14:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
10:39:24:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
10:41:34:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
10:43:44:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
10:45:54:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
10:48:05:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
10:48:06:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:48:06:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:48:06:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:48:06:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:48:06:WU00:FS00:Connecting to assign3.foldingathome.org:80
10:48:07:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:48:07:WU00:FS00:Connecting to assign4.foldingathome.org:80
10:48:07:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:48:07:ERROR:WU00:FS00:Exception: Could not get an assignment
10:48:07:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:48:07:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:48:07:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:48:08:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:48:08:WU00:FS00:Connecting to assign3.foldingathome.org:80
10:48:08:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:48:08:WU00:FS00:Connecting to assign4.foldingathome.org:80
10:48:08:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:48:08:ERROR:WU00:FS00:Exception: Could not get an assignment
10:49:07:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:49:07:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:49:07:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:49:08:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:49:08:WU00:FS00:Connecting to assign3.foldingathome.org:80
10:49:08:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:49:08:WU00:FS00:Connecting to assign4.foldingathome.org:80
10:49:08:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:49:08:ERROR:WU00:FS00:Exception: Could not get an assignment
10:50:15:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
10:50:17:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
10:50:17:WU01:FS00:0xa7:Saving result file dhdl.xvg
10:50:17:WU01:FS00:0xa7:Saving result file frame528.trr
10:50:17:WU01:FS00:0xa7:Saving result file md.log
10:50:17:WU01:FS00:0xa7:Saving result file pullf.xvg
10:50:17:WU01:FS00:0xa7:Saving result file pullx.xvg
10:50:17:WU01:FS00:0xa7:Saving result file science.log
10:50:17:WU01:FS00:0xa7:Saving result file traj_comp.xtc
10:50:17:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
10:50:18:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:50:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14379 run:2594 clone:1 gen:528 core:0xa7 unit:0x00000258455e42075e932f365eee3fee
10:50:18:WU01:FS00:Uploading 6.45MiB to 69.94.66.7
10:50:18:WU01:FS00:Connecting to 69.94.66.7:8080
10:50:24:WU01:FS00:Upload 40.68%
10:50:30:WU01:FS00:Upload 85.23%
10:50:32:WU01:FS00:Upload complete
10:50:32:WU01:FS00:Server responded WORK_ACK (400)
10:50:32:WU01:FS00:Final credit estimate, 3336.00 points
10:50:32:WU01:FS00:Cleaning up
10:50:44:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:50:44:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:50:45:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:50:45:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:50:45:WU00:FS00:Connecting to assign3.foldingathome.org:80
10:50:45:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:50:45:WU00:FS00:Connecting to assign4.foldingathome.org:80
10:50:45:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:50:45:ERROR:WU00:FS00:Exception: Could not get an assignment
10:53:21:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:53:22:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:53:22:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:53:22:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:53:22:WU00:FS00:Connecting to assign3.foldingathome.org:80
10:53:22:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:53:22:WU00:FS00:Connecting to assign4.foldingathome.org:80
10:53:22:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:53:22:ERROR:WU00:FS00:Exception: Could not get an assignment
10:57:36:WU00:FS00:Connecting to assign1.foldingathome.org:80
10:57:36:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:57:36:WU00:FS00:Connecting to assign2.foldingathome.org:80
10:57:36:WU00:FS00:Assigned to work server 69.94.66.7
10:57:36:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 69.94.66.7
10:57:36:WU00:FS00:Connecting to 69.94.66.7:8080
10:57:38:WU00:FS00:Downloading 2.82MiB
10:57:38:WU00:FS00:Download complete
10:57:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14379 run:948 clone:2 gen:548 core:0xa7 unit:0x00000269455e42075e9330325bceff52
10:57:38:WU00:FS00:Starting
10:57:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
10:57:38:WU00:FS00:Started FahCore on PID 15888
10:57:38:WU00:FS00:Core PID:7672
10:57:38:WU00:FS00:FahCore 0xa7 started
10:57:39:WU00:FS00:0xa7:*********************** Log Started 2020-10-21T10:57:38Z ***********************
10:57:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:57:39:WU00:FS00:0xa7:       Type: 0xa7
10:57:39:WU00:FS00:0xa7:       Core: Gromacs
10:57:39:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15888 -checkpoint 15 -np
10:57:39:WU00:FS00:0xa7:             8
10:57:39:WU00:FS00:0xa7:************************************ CBang *************************************
10:57:39:WU00:FS00:0xa7:       Date: Nov 27 2019
10:57:39:WU00:FS00:0xa7:       Time: 03:40:09
10:57:39:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:57:39:WU00:FS00:0xa7:     Branch: master
10:57:39:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:57:39:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:57:39:WU00:FS00:0xa7:   Platform: win32 10
10:57:39:WU00:FS00:0xa7:       Bits: 64
10:57:39:WU00:FS00:0xa7:       Mode: Release
10:57:39:WU00:FS00:0xa7:************************************ System ************************************
10:57:39:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
10:57:39:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
10:57:39:WU00:FS00:0xa7:       CPUs: 8
10:57:39:WU00:FS00:0xa7:     Memory: 15.86GiB
10:57:39:WU00:FS00:0xa7:Free Memory: 9.16GiB
10:57:39:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:57:39:WU00:FS00:0xa7: OS Version: 6.2
10:57:39:WU00:FS00:0xa7:Has Battery: true
10:57:39:WU00:FS00:0xa7: On Battery: false
10:57:39:WU00:FS00:0xa7: UTC Offset: -4
10:57:39:WU00:FS00:0xa7:        PID: 7672
10:57:39:WU00:FS00:0xa7:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
10:57:39:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:57:39:WU00:FS00:0xa7:    Version: 0.0.19
10:57:39:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:57:39:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:57:39:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:57:39:WU00:FS00:0xa7:       Date: Nov 25 2019
10:57:39:WU00:FS00:0xa7:       Time: 17:12:41
10:57:39:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:57:39:WU00:FS00:0xa7:************************************ Build *************************************
10:57:39:WU00:FS00:0xa7:       SIMD: avx_256
10:57:39:WU00:FS00:0xa7:********************************************************************************
10:57:39:WU00:FS00:0xa7:Project: 14379 (Run 948, Clone 2, Gen 548)
10:57:39:WU00:FS00:0xa7:Unit: 0x00000269455e42075e9330325bceff52
10:57:39:WU00:FS00:0xa7:Reading tar file core.xml
10:57:39:WU00:FS00:0xa7:Reading tar file frame548.tpr
10:57:39:WU00:FS00:0xa7:Digital signatures verified
10:57:39:WU00:FS00:0xa7:Calling: mdrun -s frame548.tpr -o frame548.trr -cpt 15 -nt 8
10:57:39:WU00:FS00:0xa7:Steps: first=0 total=250000
10:57:41:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
10:59:38:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
11:01:38:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
11:03:46:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
11:05:55:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
11:08:05:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11:10:15:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
11:12:25:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
11:14:36:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
11:16:46:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
11:18:58:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
11:21:09:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
11:23:20:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
11:25:31:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
11:27:44:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
11:29:54:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
11:32:05:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
11:34:24:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
11:36:35:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
11:38:50:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
11:41:01:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
11:43:13:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
11:45:23:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
11:47:36:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
11:49:49:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
11:52:01:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
11:54:13:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
11:56:26:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
11:58:39:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
12:00:52:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
12:03:07:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
12:05:23:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
12:07:34:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
12:09:47:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
12:11:59:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
12:14:11:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
12:16:23:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
12:18:36:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
12:20:47:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
12:22:59:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
12:25:11:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
12:27:26:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
12:29:40:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
12:31:52:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
12:34:10:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
12:36:23:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
12:38:37:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
12:40:52:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
12:44:21:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
12:47:27:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
12:50:40:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
12:54:54:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
12:58:40:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
13:02:42:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
13:06:42:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
13:10:56:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
13:15:13:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
13:19:53:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
13:25:31:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
13:29:57:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
13:32:51:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
13:35:46:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
13:38:43:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
13:41:57:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
13:44:58:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
13:48:31:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
13:51:44:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
13:55:24:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
13:58:24:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:01:15:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:03:31:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:05:51:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
14:08:07:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
14:10:27:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
14:12:43:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
14:14:59:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
14:17:16:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
14:19:33:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
14:21:56:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
14:24:13:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
14:26:29:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
14:28:47:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
14:31:02:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
14:33:22:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
14:35:43:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
14:38:27:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
14:40:57:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
14:43:14:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
14:45:30:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
14:47:47:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
14:50:04:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
14:52:21:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
14:54:37:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
14:56:55:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
14:59:12:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
15:01:27:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
15:03:47:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
15:06:03:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
15:08:18:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
15:10:33:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
15:10:34:WU01:FS00:Connecting to assign1.foldingathome.org:80
15:10:34:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:10:34:WU01:FS00:Connecting to assign2.foldingathome.org:80
15:10:35:WARNING:WU01:FS00:Failed to get assig
15:10:35:WU01:FS00:Connecting to assign3.foldingathome.org:80
15:10:35:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:10:35:WU01:FS00:Connecting to assign4.foldingathome.org:80
15:10:35:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:10:35:ERROR:WU01:FS00:Exception: Could not get an assignment
15:10:35:WU01:FS00:Connecting to assign1.foldingathome.org:80
15:10:36:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:10:36:WU01:FS00:Connecting to assign2.foldingathome.org:80
15:10:36:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:10:36:WU01:FS00:Connecting to assign3.foldingathome.org:80
15:10:36:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:10:36:WU01:FS00:Connecting to assign4.foldingathome.org:80
15:10:36:WU01:FS00:Assigned to work server 143.89.243.111
15:10:36:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 143.89.243.111
15:10:36:WU01:FS00:Connecting to 143.89.243.111:8080
15:10:39:WU01:FS00:Downloading 12.35MiB
15:10:45:WU01:FS00:Download 46.04%
15:10:51:WU01:FS00:Download 89.55%
15:10:52:WU01:FS00:Download complete
15:10:52:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16516 run:0 clone:505 gen:5 core:0xa7 unit:0x000000058f59f36f5f85b43e11046b7a
15:12:54:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
15:12:57:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
15:12:57:WU00:FS00:0xa7:Saving result file dhdl.xvg
15:12:57:WU00:FS00:0xa7:Saving result file frame548.trr
15:12:57:WU00:FS00:0xa7:Saving result file md.log
15:12:57:WU00:FS00:0xa7:Saving result file pullf.xvg
15:12:57:WU00:FS00:0xa7:Saving result file pullx.xvg
15:12:57:WU00:FS00:0xa7:Saving result file science.log
15:12:57:WU00:FS00:0xa7:Saving result file traj_comp.xtc
15:12:57:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:12:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:12:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14379 run:948 clone:2 gen:548 core:0xa7 unit:0x00000269455e42075e9330325bceff52
15:12:57:WU00:FS00:Uploading 6.47MiB to 69.94.66.7
15:12:57:WU00:FS00:Connecting to 69.94.66.7:8080
15:12:57:WU01:FS00:Starting
15:12:57:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
15:12:57:WU01:FS00:Started FahCore on PID 4500
15:12:57:WU01:FS00:Core PID:14164
15:12:57:WU01:FS00:FahCore 0xa7 started
15:12:58:WU01:FS00:0xa7:*********************** Log Started 2020-10-21T15:12:57Z ***********************
15:12:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:12:58:WU01:FS00:0xa7:       Type: 0xa7
15:12:58:WU01:FS00:0xa7:       Core: Gromacs
15:12:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4500 -checkpoint 15 -np 8
15:12:58:WU01:FS00:0xa7:************************************ CBang *************************************
15:12:58:WU01:FS00:0xa7:       Date: Nov 27 2019
15:12:58:WU01:FS00:0xa7:       Time: 03:40:09
15:12:58:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:12:58:WU01:FS00:0xa7:     Branch: master
15:12:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:12:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:12:58:WU01:FS00:0xa7:   Platform: win32 10
15:12:58:WU01:FS00:0xa7:       Bits: 64
15:12:58:WU01:FS00:0xa7:       Mode: Release
15:12:58:WU01:FS00:0xa7:************************************ System ************************************
15:12:58:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
15:12:58:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
15:12:58:WU01:FS00:0xa7:       CPUs: 8
15:12:58:WU01:FS00:0xa7:     Memory: 15.86GiB
15:12:58:WU01:FS00:0xa7:Free Memory: 8.69GiB
15:12:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
15:12:58:WU01:FS00:0xa7: OS Version: 6.2
15:12:58:WU01:FS00:0xa7:Has Battery: true
15:12:58:WU01:FS00:0xa7: On Battery: false
15:12:58:WU01:FS00:0xa7: UTC Offset: -4
15:12:58:WU01:FS00:0xa7:        PID: 14164
15:12:58:WU01:FS00:0xa7:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
15:12:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:12:58:WU01:FS00:0xa7:    Version: 0.0.19
15:12:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:12:58:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:12:58:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:12:58:WU01:FS00:0xa7:       Date: Nov 25 2019
15:12:58:WU01:FS00:0xa7:       Time: 17:12:41
15:12:58:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:12:58:WU01:FS00:0xa7:************************************ Build *************************************
15:12:58:WU01:FS00:0xa7:       SIMD: avx_256
15:12:58:WU01:FS00:0xa7:********************************************************************************
15:12:58:WU01:FS00:0xa7:Project: 16516 (Run 0, Clone 505, Gen 5)
15:12:58:WU01:FS00:0xa7:Unit: 0x000000058f59f36f5f85b43e11046b7a
15:12:58:WU01:FS00:0xa7:Reading tar file core.xml
15:12:58:WU01:FS00:0xa7:Reading tar file frame5.tpr
15:12:58:WU01:FS00:0xa7:Digital signatures verified
15:12:58:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -x frame5.xtc -cpt 15 -nt 8
15:12:58:WU01:FS00:0xa7:Steps: first=1250000 total=250000
15:13:01:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
15:13:03:WU00:FS00:Upload 39.61%
15:13:09:WU00:FS00:Upload 83.09%
15:13:11:WU00:FS00:Upload complete
15:13:11:WU00:FS00:Server responded WORK_ACK (400)
15:13:11:WU00:FS00:Final credit estimate, 3116.00 points
15:13:11:WU00:FS00:Cleaning up
15:21:31:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
15:30:05:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
15:38:43:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
15:44:44:FS00:Shutting core down
15:44:44:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 14164
15:44:44:WU01:FS00:0xa7:Exiting, please wait. . .
15:58:19:WARNING:FS00:Killing WU01
15:58:19:WARNING:WU01:FS00:Detected clock skew (13 mins 30 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
15:58:20:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:58:20:WU01:FS00:Starting
15:58:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\svilleneuve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 14040 -checkpoint 15 -np 8
15:58:21:WU01:FS00:Started FahCore on PID 17364
15:58:21:WU01:FS00:Core PID:8264
15:58:21:WU01:FS00:FahCore 0xa7 started
15:58:21:WU01:FS00:0xa7:*********************** Log Started 2020-10-21T15:58:21Z ***********************
15:58:21:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:58:21:WU01:FS00:0xa7:       Type: 0xa7
15:58:21:WU01:FS00:0xa7:       Core: Gromacs
15:58:21:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 17364 -checkpoint 15 -np
15:58:21:WU01:FS00:0xa7:             8
15:58:21:WU01:FS00:0xa7:************************************ CBang *************************************
15:58:21:WU01:FS00:0xa7:       Date: Nov 27 2019
15:58:21:WU01:FS00:0xa7:       Time: 03:40:09
15:58:21:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:58:21:WU01:FS00:0xa7:     Branch: master
15:58:21:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:58:21:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:21:WU01:FS00:0xa7:   Platform: win32 10
15:58:21:WU01:FS00:0xa7:       Bits: 64
15:58:21:WU01:FS00:0xa7:       Mode: Release
15:58:21:WU01:FS00:0xa7:************************************ System ************************************
15:58:21:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
15:58:21:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
15:58:21:WU01:FS00:0xa7:       CPUs: 8
15:58:21:WU01:FS00:0xa7:     Memory: 15.86GiB
15:58:21:WU01:FS00:0xa7:Free Memory: 7.95GiB
15:58:21:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
15:58:21:WU01:FS00:0xa7: OS Version: 6.2
15:58:21:WU01:FS00:0xa7:Has Battery: true
15:58:21:WU01:FS00:0xa7: On Battery: false
15:58:21:WU01:FS00:0xa7: UTC Offset: -4
15:58:21:WU01:FS00:0xa7:        PID: 8264
15:58:21:WU01:FS00:0xa7:        CWD: C:\Users\svilleneuve\AppData\Roaming\FAHClient\work
15:58:21:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:58:22:WU01:FS00:0xa7:    Version: 0.0.19
15:58:22:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:22:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:58:22:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:58:22:WU01:FS00:0xa7:       Date: Nov 25 2019
15:58:22:WU01:FS00:0xa7:       Time: 17:12:41
15:58:22:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:58:22:WU01:FS00:0xa7:     Branch: master
15:58:22:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:58:22:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:22:WU01:FS00:0xa7:   Platform: win32 10
15:58:22:WU01:FS00:0xa7:       Bits: 64
15:58:22:WU01:FS00:0xa7:       Mode: Release
15:58:22:WU01:FS00:0xa7:************************************ Build *************************************
15:58:22:WU01:FS00:0xa7:       SIMD: avx_256
15:58:22:WU01:FS00:0xa7:********************************************************************************
15:58:22:WU01:FS00:0xa7:Project: 16516 (Run 0, Clone 505, Gen 5)
15:58:22:WU01:FS00:0xa7:Unit: 0x000000058f59f36f5f85b43e11046b7a
15:58:22:WU01:FS00:0xa7:Digital signatures verified
15:58:22:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -x frame5.xtc -cpi state.cpt -cpt 15 -nt 8
15:58:24:WU01:FS00:0xa7:Steps: first=1250000 total=250000
15:58:29:WU01:FS00:0xa7:Completed 9252 out of 250000 steps (3%)
16:02:18:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
16:17:43:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
16:35:12:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
16:53:33:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
17:08:14:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
17:22:59:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
17:36:01:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
17:46:07:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
17:55:28:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
18:05:10:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
18:17:43:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
18:29:15:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
18:40:54:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
18:52:45:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
aetch
Re: GPU problem
Post by aetch »
Unless I'm looking at the wrong laptop you don't have an AMD/ATi or NVidia discrete graphics card which can be used for folding. You just have the Intel on-die graphics which, I believe, are being tested but haven't been approved for us plebs to fold with yet.
Generally it's gaming laptops that have the AMD/ATi or NVidia discrete graphics cards powerful enough to fold with.
Kjetil
Re: GPU problem
Post by Kjetil »
<cause v='COVID_19'/> Set this to any. Is working at my 5960X.
simonvilleneuve
Re: GPU problem
Post by simonvilleneuve »
Kjetil wrote:<cause v='COVID_19'/> Set this to any. Is working at my 5960X.
<cause v='COVID_19'/>, I don't know what this mean. If you say to priorise COVID-19, I already done that. I wanted to join the Moonshot movement, but it seems that my computer can't do it. :(
aetch
Re: GPU problem
Post by aetch »
You can leave your preferred cause as "Covid-19" if you want.
It just a preference, you'll get units for other causes if there isn't one available for Covid.
Moonshot is only one project of many projects looking at Covid and there are units which run on the CPU as well.
Don't think for a moment you can't contribute, every little helps.
Your laptop i5/i7 will crunch through units quicker than some of the decade old xeons some here are running.
You just seem to have joined us at a quiet moment when we've just finished a moonshot sprint and are low on work units.
It should pick up again soon.
Re: GPU problem
covid-19 is not the same as covid_19, but is a preference, not a mandate, so unless the servers are out of WUs, you still should get SOMETHING.
Install the drivers from https://www.nvidia.com/en-us/geforce/drivers/
Re: GPU problem
Post by foldy »
Laptop only has GPU Intel UHD Graphics 620 which is not supported yet by FAH. So no GPU folding on that laptop possible.
