206.223.170.146
Maddog
206.223.170.146
Post by Maddog »
Client has been trying and retrying, for more than 4 hours, to upload finished WU to this server.
Server response is, please wait (464). Can somebody take a look, server status shows online and assign.
Foxter
Re: 206.223.170.146
Post by Foxter »
I can confirm, my team has the same issue:
11:52:35:WU02:FS01:Upload complete
11:52:35:WU02:FS01erver responded PLEASE_WAIT (464)
11:52:35:WARNING:WU02:FS01:Failed to send results, will try again later
We had 4 WU with this issue and soon to have 5.
HaloJones
Re: 206.223.170.146
Post by HaloJones »
I'm also struggling to get assigned work from this server but no issue with work from 128.252.203.9
single 1070
JimF
Re: 206.223.170.146
Post by JimF »
I can't get GPU work assigned from 206.223.170.146 also.
HaloJones
Re: 206.223.170.146
Post by HaloJones »
13:24:00:WU02:FS00:Connecting to 65.254.110.245:8080
13:24:00:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:24:00:WU02:FS00:Connecting to 18.218.241.186:80
13:24:00:WU02:FS00:Assigned to work server 206.223.170.146
13:24:00:WU02:FS00:Requesting new work unit for slot 00: READY cpu:11 from 206.223.170.146
13:24:00:WU02:FS00:Connecting to 206.223.170.146:8080
13:25:12:ERROR:WU02:FS00:Exception: Server did not assign work unit
13:30:51:WU02:FS00:Connecting to 65.254.110.245:8080
13:30:52:WU02:FS00:Assigned to work server 206.223.170.146
13:30:52:WU02:FS00:Requesting new work unit for slot 00: READY cpu:11 from 206.223.170.146
13:30:52:WU02:FS00:Connecting to 206.223.170.146:8080
13:33:03:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:41:57:WU02:FS00:Connecting to 65.254.110.245:8080
13:41:57:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:41:57:WU02:FS00:Connecting to 18.218.241.186:80
13:41:57:WU02:FS00:Assigned to work server 206.223.170.146
13:41:57:WU02:FS00:Requesting new work unit for slot 00: READY cpu:11 from 206.223.170.146
13:41:57:WU02:FS00:Connecting to 206.223.170.146:8080
13:44:08:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:59:54:WU02:FS00:Connecting to 65.254.110.245:8080
13:59:54:WU02:FS00:Assigned to work server 206.223.170.146
13:59:54:WU02:FS00:Requesting new work unit for slot 00: READY cpu:11 from 206.223.170.146
13:59:54:WU02:FS00:Connecting to 206.223.170.146:8080
14:00:08:ERROR:WU02:FS00:Exception: Server did not assign work unit
this is for a cpu so it's all types of units.
single 1070
gs60
Re: 206.223.170.146
Post by gs60 »
Hello,
Earlier I was having problems also and a browser connection to the server would return ERR_CONNECTION_RESET. I tried again just now and got the standard work server home page so they may have been having some network issues earlier. I'm on the at&t network.
Hikyuuri
Re: 206.223.170.146
Post by Hikyuuri »
I also have multiple clients, on multiple Internet connections (likely not a Internet issue) that are "failing" to upload completed work units. The reason for the quotes around "failing" is it seems to upload the work unit, but then gets a "Please Wait" status message.
14:04:22:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17403 run:0 clone:1853 gen:30 core:0x22 unit:0x0000002ccedfaa925f7d60dafd6c5f60
14:04:22:WU00:FS01:Uploading 22.82MiB to 206.223.170.146
14:04:22:WU00:FS01:Connecting to 206.223.170.146:8080
14:04:37:WU00:FS01:Upload 0.27%
14:04:43:WU00:FS01:Upload 5.20%
14:04:49:WU00:FS01:Upload 10.68%
14:04:55:WU00:FS01:Upload 16.16%
14:05:01:WU00:FS01:Upload 23.01%
14:05:07:WU00:FS01:Upload 29.03%
14:05:13:WU00:FS01:Upload 34.78%
14:05:19:WU00:FS01:Upload 39.99%
14:05:25:WU00:FS01:Upload 45.46%
14:05:31:WU00:FS01:Upload 50.67%
14:05:37:WU00:FS01:Upload 55.60%
14:05:43:WU00:FS01:Upload 61.35%
14:05:49:WU00:FS01:Upload 66.83%
14:05:55:WU00:FS01:Upload 72.31%
14:06:01:WU00:FS01:Upload 77.24%
14:06:07:WU00:FS01:Upload 82.71%
14:06:13:WU00:FS01:Upload 87.64%
14:06:19:WU00:FS01:Upload 93.12%
14:06:25:WU00:FS01:Upload 98.60%
14:06:27:WU00:FS01:Upload complete
14:06:27:WU00:FS01:Server responded PLEASE_WAIT (464)
14:06:27:WARNING:WU00:FS01:Failed to send results, will try again later
This is the same on all my clients trying to upload finished WUs to this server. They all send, but then get told to wait. One client has attempted to upload 22 times now, so not sure how long it has been trying.
JimF
Re: 206.223.170.146
Post by JimF »
After a reboot, I was eventually able to get work assigned from assign1.foldingathome.org (from work server 128.252.203.9).
14:03:48:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:03:49:WU00:FS00:Assigned to work server 206.223.170.146
14:03:49:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:TU106 [Geforce RTX 2060] from 206.223.170.146
14:03:49:WU00:FS00:Connecting to 206.223.170.146:8080
\x1b[91m14:04:59:ERROR:WU00:FS00:Exception: Server did not assign work unit\x1b[0m
14:04:59:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:05:00:WU00:FS00:Assigned to work server 206.223.170.146
14:05:00:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:TU106 [Geforce RTX 2060] from 206.223.170.146
14:05:00:WU00:FS00:Connecting to 206.223.170.146:8080
\x1b[93m14:07:09:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80\x1b[0m
14:07:09:WU00:FS00:Connecting to 206.223.170.146:80
\x1b[91m14:09:20:ERROR:WU00:FS00:Exception: Failed to connect to 206.223.170.146:80: Connection timed out\x1b[0m
14:09:20:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:09:21:WU00:FS00:Assigned to work server 206.223.170.146
14:09:21:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:TU106 [Geforce RTX 2060] from 206.223.170.146
14:09:21:WU00:FS00:Connecting to 206.223.170.146:8080
\x1b[91m14:09:26:ERROR:WU00:FS00:Exception: Server did not assign work unit\x1b[0m
14:10:58:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:10:58:WU00:FS00:Assigned to work server 128.252.203.9
14:10:58:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:TU106 [Geforce RTX 2060] from 128.252.203.9
14:10:58:WU00:FS00:Connecting to 128.252.203.9:8080
14:10:58:WU00:FS00:Downloading 12.99MiB
14:11:01:WU00:FS00:Download complete
14:11:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17418 run:0 clone:1643 gen:55 core:0x22 unit:0x0000004480fccb095f6ac18b6324765d
Maddog
Re: 206.223.170.146
Post by Maddog »
Still not uploaded. Probably does not help that assign rate is set at over 70,000 an hour and no CS.
My other machine was also stalled by being constantly assigned to this server. After a reboot finally got WU from another server.
NormalDiffusion
Re: 206.223.170.146
Post by NormalDiffusion »
Same here, can't upload to the server (well actually I can reach 100% but it's being dropped directly), nor is it assigning WUs...
JimF
Re: 206.223.170.146
Post by JimF »
I am out of luck again, for almost an hour.
I will find something else for my GTX 1660 Ti to do.
15:01:02:WU01:FS00:Assigned to work server 206.223.170.146
15:01:02:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 206.223.170.146
15:01:02:WU01:FS00:Connecting to 206.223.170.146:8080
\x1b[91m15:01:02:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
15:03:39:WU01:FS00:Connecting to 65.254.110.245:80
\x1b[93m15:03:39:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration\x1b[0m
15:03:39:WU01:FS00:Connecting to 18.218.241.186:80
15:03:39:WU01:FS00:Assigned to work server 128.252.203.9
15:03:39:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 128.252.203.9
15:03:39:WU01:FS00:Connecting to 128.252.203.9:8080
\x1b[91m15:03:40:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
15:07:53:WU01:FS00:Connecting to 65.254.110.245:80
\x1b[93m15:07:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration\x1b[0m
15:07:53:WU01:FS00:Connecting to 18.218.241.186:80
15:07:54:WU01:FS00:Assigned to work server 206.223.170.146
15:07:54:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 206.223.170.146
15:07:54:WU01:FS00:Connecting to 206.223.170.146:8080
\x1b[91m15:07:54:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
15:14:45:WU01:FS00:Connecting to 65.254.110.245:80
15:14:45:WU01:FS00:Assigned to work server 206.223.170.146
15:14:45:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 206.223.170.146
15:14:45:WU01:FS00:Connecting to 206.223.170.146:8080
\x1b[91m15:14:45:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
15:25:50:WU01:FS00:Connecting to 65.254.110.245:80
15:25:50:WU01:FS00:Assigned to work server 140.163.4.231
15:25:50:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 140.163.4.231
15:25:50:WU01:FS00:Connecting to 140.163.4.231:8080
\x1b[91m15:26:46:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
15:43:47:WU01:FS00:Connecting to 65.254.110.245:80
\x1b[93m15:43:47:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration\x1b[0m
15:43:47:WU01:FS00:Connecting to 18.218.241.186:80
\x1b[93m15:43:47:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration\x1b[0m
\x1b[93m15:43:48:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration\x1b[0m
15:43:48:WU01:FS00:Connecting to 18.218.241.186:80
15:43:48:WU01:FS00:Assigned to work server 206.223.170.146
15:43:48:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 206.223.170.146
15:43:48:WU01:FS00:Connecting to 206.223.170.146:8080
\x1b[91m15:43:48:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
Hikyuuri
Re: 206.223.170.146
Post by Hikyuuri »
The 206.223.170.146 server is finally showing as Down on the Server Stats page (https://apps.foldingathome.org/serverstats). So, hopefully this means they are aware of the issue and are looking into it.
Re: 206.223.170.146
FYI, the researchers have already been informed and work is underway to ensure that sufficient CPU WUs are available to all donors ASAP :)
Hikyuuri
Re: 206.223.170.146
Post by Hikyuuri »
PantherX wrote:FYI, the researchers have already been informed and work is underway to ensure that sufficient CPU WUs are available to all donors ASAP :)
PantherX, this is not a assignment issue, but a collection issue.
I have work units that are 100% complete, but are not successfully uploading to 206.223.170.146.
It started working again yesterday, but now I have failures to upload again. Slightly different this time though:
14:02:37:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14255 run:0 clone:2084 gen:40 core:0xa7 unit:0x00000030cedfaa925f6a38d7f1c83803
14:02:37:WU02:FS00:Uploading 2.87MiB to 206.223.170.146
14:02:37:WU02:FS00:Connecting to 206.223.170.146:8080
14:02:58:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
14:02:58:WU02:FS00:Connecting to 206.223.170.146:80
14:03:05:WU02:FS00:Upload 2.18%
14:03:35:WU02:FS00:Upload 4.35%
14:03:35:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
Yesterday, it would get to 100%, but then fail with the error code "Please wait". It successfully was working late last night (I'm in CDT, so about 12 hours ago), but this morning it is not working again. At the time of this reply, it has failed 10 times to upload to the server, and the log show the same attempt was made every time, but the "transfer failed".
Knish
Re: 206.223.170.146
Post by Knish »
maybe the completed WUs are practicing social distancing so they're spreading out for the return home
