My overclock timing are for
RX570 4GB (Saphire pulse mini ITX)
GPU clock (Mhz): 300:588:95211601209:1400
GPU volt (mV)----:750:765:918:98710201060
Frecuency memory :1750Mhz atomatic voltaje with software raedon adrenalin version 20.4....
RX570 8GB(Shaphire pulse)
Frecuency memory : 2000Mhz at 950mV
The RX570 of 4GB and the RX570 of 8GB in the same motherboard B450 msi ,make around 800.000 PPD
RX5700XT (power color) GPU: 2150MHz
Voltaje---------:1135mV
The memory is 1750Mhz default , voltage is automatic.
This is the theory when you put the values, but, in the pratice, the system equilibrate this values to
2075Mhz at 1137mV
Temperatures with fans of 120mm of diammeter at 3500rpm, of delta electronics company are 70 - 75ºC Temperature of the junction, at the gpu only 65ºC.
This graphic make 1.100.000 PPD in the motherboard B450M msi
In all graphic cards i aplied overclock and undervoltaje, are stable work of more than 10 days at 24h per day. PLEASE Not for domestic use, the fans are a lot powerfull, the sound are unsoportable
Overclock experience with RX570 and RX5700XT
Re: Overclock experience with RX570 and RX5700XT
Is your 800 000 PPD consistent with your RX570 8GB? Got the same GPU, but stock in a eGPU and I usually get around 300-400 000 PPD. And how much where you getting before OC?
2 x RTX570 is consistent 800.000PPDNilem wrote:Is your 800 000 PPD consistent with your RX570 8GB? Got the same GPU, but stock in a eGPU and I usually get around 300-400 000 PPD. And how much where you getting before OC?
