I hope it will be useful to some.To enable or disable AVX instructions you can use this commands:
Enable AVX: bcdedit /set xsavedisable 0
Disable AVX: bcdedit /set xsavedisable 1
Open your command prompt and type it, then hit the enter button.
From: https://superuser.com/questions/244213/ ... y-computer
