Two clients call same name and same passkey
GTX56O
Hardware configuration: rx570 itx 4gb no oc
Post by GTX56O »
Is posible ? make two clients, with the same name and the same passkey in different computers?
In the second computer have problems with the port 8080
gs60
Re: Two clients call same name and same passkey
Post by gs60 »
You can have two computers (or more) that use the same username and passkey. I did that for a while with 3 laptops in the house. Not sure what you mean by an issue with port 8080? If you could paste a few lines of the logfile that contain the error, that would give us a better idea. My guess is the error is a normal error you get with project servers from time to time, but the log will tell us more.
Are any of the computers behind a business's router/firewall. That commonly modifies how the client's uses port 8080.
GTX56O
Post by GTX56O »
My problem is Open CL: Not detected: clGetDeviceIDs() returned -1
I have a RX5700XT, i have got a software controller Adrenalin 20.8.3, you think i need the last, the 20.9.1?
