Nvidia RTX 3080 stuck on OpenCL, won't use CUDA
COCOViper
Post by COCOViper »
See log below.
Performed a full DDU of all Nvidia items from my old 2080S in safe mode, shut down, installed 3080 and latest driver (456.55 Game Ready) but folding client keeps giving the error of:
07:16:15:WU00:FS01:0x22:  cuda-device 0 specified
07:16:21:WU00:FS01:0x22:Attempting to create CUDA context:
07:16:21:WU00:FS01:0x22:  Configuring platform CUDA
07:16:21:WU00:FS01:0x22:Failed to create CUDA context:
07:16:21:WU00:FS01:0x22:Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)
07:16:21:WU00:FS01:0x22:Attempting to create OpenCL context:
07:16:21:WU00:FS01:0x22:  Configuring platform OpenCL
07:16:27:WU00:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
Any suggestions?
Log:
*********************** Log Started 2020-10-01T07:14:04Z ***********************
07:14:04:Trying to access database...
07:14:04:Successfully acquired database lock
07:14:04:Read GPUs.txt
07:14:05:Enabled folding slot 01: PAUSED gpu:0:GA102 [GeForce RTX 3080] (by user)
07:14:05:****************************** FAHClient ******************************
07:14:05:        Version: 7.6.13
07:14:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:14:05:      Copyright: 2020 foldingathome.org
07:14:05:       Homepage: https://foldingathome.org/
07:14:05:           Date: Apr 27 2020
07:14:05:           Time: 21:21:01
07:14:05:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:14:05:         Branch: master
07:14:05:       Compiler: Visual C++ 2008
07:14:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:14:05:       Platform: win32 10
07:14:05:           Bits: 32
07:14:05:           Mode: Release
07:14:05:         Config: C:\Users\cocov\AppData\Roaming\FAHClient\config.xml
07:14:05:******************************** CBang ********************************
07:14:05:           Date: Apr 24 2020
07:14:05:           Time: 17:07:55
07:14:05:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:14:05:           Bits: 32
07:14:05:******************************* System ********************************
07:14:05:            CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz
07:14:05:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
07:14:05:           CPUs: 16
07:14:05:         Memory: 63.94GiB
07:14:05:    Free Memory: 58.12GiB
07:14:05:        Threads: WINDOWS_THREADS
07:14:05:     OS Version: 6.2
07:14:05:    Has Battery: false
07:14:05:     On Battery: false
07:14:05:     UTC Offset: -7
07:14:05:            PID: 19556
07:14:05:            CWD: C:\Users\cocov\AppData\Roaming\FAHClient
07:14:05:  Win32 Service: false
07:14:05:             OS: Windows 10 Enterprise
07:14:05:        OS Arch: AMD64
07:14:05:           GPUs: 1
07:14:05:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]
07:14:05:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.1
07:14:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:456.55
07:14:05:******************************* libFAH ********************************
07:14:05:           Date: Apr 15 2020
07:14:05:           Time: 14:53:14
07:14:05:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:14:05:           Bits: 32
07:14:05:***********************************************************************
07:14:05:<config>
07:14:05:  <!-- Folding Core -->
07:14:05:  <checkpoint v='30'/>
07:14:05:  <core-priority v='low'/>
07:14:05:
07:14:05:  <!-- Folding Slot Configuration -->
07:14:05:  <cause v='COVID_19'/>
07:14:05:
07:14:05:  <!-- Network -->
07:14:05:  <proxy v=':8080'/>
07:14:05:
07:14:05:  <!-- Slot Control -->
07:14:05:  <power v='FULL'/>
07:14:05:
07:14:05:  <!-- User Information -->
07:14:05:  <passkey v='*****'/>
07:14:05:  <team v='33'/>
07:14:05:  <user v='COCOViper'/>
07:14:05:
07:14:05:  <!-- Folding Slots -->
07:14:05:  <slot id='1' type='GPU'>
07:14:05:    <client-type v='advanced'/>
07:14:05:    <max-packet-size v='big'/>
07:14:05:    <next-unit-percentage v='100'/>
07:14:05:    <pause-on-start v='True'/>
07:14:05:  </slot>
07:14:05:</config>
07:16:10:FS01:Unpaused
07:16:11:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:16:11:WU00:FS01:Assigned to work server 18.188.125.154
07:16:11:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GA102 [GeForce RTX 3080] from 18.188.125.154
07:16:11:WU00:FS01:Connecting to 18.188.125.154:8080
07:16:12:WU00:FS01:Downloading 6.90MiB
07:16:14:WU00:FS01:Download complete
07:16:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13426 run:5709 clone:11 gen:5 core:0x22 unit:0x0000000912bc7d9a5f597ce22ab10d9e
07:16:14:WU00:FS01:Starting
07:16:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cocov\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 19556 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:16:14:WU00:FS01:Started FahCore on PID 19508
07:16:14:WU00:FS01:Core PID:19896
07:16:14:WU00:FS01:FahCore 0x22 started
07:16:15:WU00:FS01:0x22:*********************** Log Started 2020-10-01T07:16:14Z ***********************
07:16:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:16:15:WU00:FS01:0x22:       Core: Core22
07:16:15:WU00:FS01:0x22:       Type: 0x22
07:16:15:WU00:FS01:0x22:    Version: 0.0.13
07:16:15:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:16:15:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
07:16:15:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
07:16:15:WU00:FS01:0x22:       Date: Sep 19 2020
07:16:15:WU00:FS01:0x22:       Time: 02:35:58
07:16:15:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
07:16:15:WU00:FS01:0x22:     Branch: core22-0.0.13
07:16:15:WU00:FS01:0x22:   Compiler: Visual C++ 2015
07:16:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:16:15:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
07:16:15:WU00:FS01:0x22:   Platform: win32 10
07:16:15:WU00:FS01:0x22:       Bits: 64
07:16:15:WU00:FS01:0x22:       Mode: Release
07:16:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:16:15:WU00:FS01:0x22:             <peastman@stanford.edu>
07:16:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 19508 -checkpoint 30
07:16:15:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:16:15:WU00:FS01:0x22:             0 -gpu 0
07:16:15:WU00:FS01:0x22:************************************ libFAH ************************************
07:16:15:WU00:FS01:0x22:       Date: Sep 7 2020
07:16:15:WU00:FS01:0x22:       Time: 19:09:56
07:16:15:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
07:16:15:WU00:FS01:0x22:     Branch: HEAD
07:16:15:WU00:FS01:0x22:************************************ CBang *************************************
07:16:15:WU00:FS01:0x22:       Time: 19:08:30
07:16:15:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
07:16:15:WU00:FS01:0x22:************************************ System ************************************
07:16:15:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz
07:16:15:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
07:16:15:WU00:FS01:0x22:       CPUs: 16
07:16:15:WU00:FS01:0x22:     Memory: 63.94GiB
07:16:15:WU00:FS01:0x22:Free Memory: 58.78GiB
07:16:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:16:15:WU00:FS01:0x22: OS Version: 6.2
07:16:15:WU00:FS01:0x22:Has Battery: false
07:16:15:WU00:FS01:0x22: On Battery: false
07:16:15:WU00:FS01:0x22: UTC Offset: -7
07:16:15:WU00:FS01:0x22:        PID: 19896
07:16:15:WU00:FS01:0x22:        CWD: C:\Users\cocov\AppData\Roaming\FAHClient\work
07:16:15:WU00:FS01:0x22:************************************ OpenMM ************************************
07:16:15:WU00:FS01:0x22:   Revision: 189320d0
07:16:15:WU00:FS01:0x22:********************************************************************************
07:16:15:WU00:FS01:0x22:Project: 13426 (Run 5709, Clone 11, Gen 5)
07:16:15:WU00:FS01:0x22:Unit: 0x0000000912bc7d9a5f597ce22ab10d9e
07:16:15:WU00:FS01:0x22:Reading tar file core.xml
07:16:15:WU00:FS01:0x22:Reading tar file integrator.xml
07:16:15:WU00:FS01:0x22:Reading tar file state.xml.bz2
07:16:15:WU00:FS01:0x22:Reading tar file system.xml.bz2
07:16:15:WU00:FS01:0x22:Digital signatures verified
07:16:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:16:15:WU00:FS01:0x22:Version 0.0.13
07:16:15:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:16:15:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:16:15:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:16:15:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:16:15:WU00:FS01:0x22:There are 4 platforms available.
07:16:15:WU00:FS01:0x22:Platform 0: Reference
07:16:15:WU00:FS01:0x22:Platform 1: CPU
07:16:15:WU00:FS01:0x22:Platform 2: OpenCL
07:16:15:WU00:FS01:0x22:  opencl-device 0 specified
07:16:15:WU00:FS01:0x22:Platform 3: CUDA
07:16:27:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
07:16:27:WU00:FS01:0x22:Checkpoint completed at step 0
Re: Nvidia RTX 3080 stuck on OpenCL, won't use CUDA
Welcome to the F@H Forum COCOViper,
Can you please confirm that you do not have CUDA toolkit installed on your system? Also, can you confirm via GPU-Z that you have CUDA ticked?
ajm
Post by ajm »
Maybe reinstall FAH (incl. data)?
It looks like you have made quite a few changes in the config.xml and maybe some of them don't agree with the new GPU.
COCOViper
Post by COCOViper »
Thanks for the quick replies all!
GPU-Z shows CUDA checked.
I do actually have a CUDA tool kit installed. What should I do to resolve if this is an issue?
Post by Neil-B »
A number of folders have found that removing the CUDA toolkit resolves the problem ... I may have also seen a topic wherea folder removed the cuda toolkit, reinstalled drivers then reinstalled toolkit and it worked but need to track down the thread
COCOViper
Post by COCOViper »
Is it this one maybe?
viewtopic.php?f=80&t=36167
COCOViper
Post by COCOViper »
Uninstalling everything Nvidia from Add/Remove Programs that wasn't Drivers or GeForce expereince and then rebooting seems to have fixed it! 5M PPD!
*********************** Log Started 2020-10-01T19:29:31Z ***********************
19:29:31:Trying to access database...
19:29:31:Successfully acquired database lock
19:29:31:Read GPUs.txt
19:29:31:Enabled folding slot 01: PAUSED gpu:0:GA102 [GeForce RTX 3080] (by user)
19:29:31:****************************** FAHClient ******************************
19:29:31:        Version: 7.6.13
19:29:31:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:29:31:      Copyright: 2020 foldingathome.org
19:29:31:       Homepage: https://foldingathome.org/
19:29:31:           Date: Apr 27 2020
19:29:31:           Time: 21:21:01
19:29:31:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:29:31:         Branch: master
19:29:31:       Compiler: Visual C++ 2008
19:29:31:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:29:31:       Platform: win32 10
19:29:31:           Bits: 32
19:29:31:           Mode: Release
19:29:31:         Config: C:\Users\cocov\AppData\Roaming\FAHClient\config.xml
19:29:31:******************************** CBang ********************************
19:29:31:           Date: Apr 24 2020
19:29:31:           Time: 17:07:55
19:29:31:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:29:31:           Bits: 32
19:29:31:******************************* System ********************************
19:29:31:            CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz
19:29:31:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:29:31:           CPUs: 16
19:29:31:         Memory: 63.94GiB
19:29:31:    Free Memory: 57.99GiB
19:29:31:        Threads: WINDOWS_THREADS
19:29:31:     OS Version: 6.2
19:29:31:    Has Battery: false
19:29:31:     On Battery: false
19:29:31:     UTC Offset: -7
19:29:31:            PID: 18964
19:29:31:            CWD: C:\Users\cocov\AppData\Roaming\FAHClient
19:29:31:  Win32 Service: false
19:29:31:             OS: Windows 10 Enterprise
19:29:31:        OS Arch: AMD64
19:29:31:           GPUs: 1
19:29:31:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]
19:29:31:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.1
19:29:31:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:456.55
19:29:31:******************************* libFAH ********************************
19:29:31:           Date: Apr 15 2020
19:29:31:           Time: 14:53:14
19:29:31:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:29:31:           Bits: 32
19:29:31:***********************************************************************
19:29:31:<config>
19:29:31:  <!-- Folding Core -->
19:29:31:  <checkpoint v='30'/>
19:29:31:  <core-priority v='low'/>
19:29:31:
19:29:31:  <!-- Folding Slot Configuration -->
19:29:31:  <cause v='COVID_19'/>
19:29:31:
19:29:31:  <!-- Network -->
19:29:31:  <proxy v=':8080'/>
19:29:31:
19:29:31:  <!-- Slot Control -->
19:29:31:  <power v='FULL'/>
19:29:31:
19:29:31:  <!-- User Information -->
19:29:31:  <passkey v='*****'/>
19:29:31:  <team v='33'/>
19:29:31:  <user v='COCOViper'/>
19:29:31:
19:29:31:  <!-- Folding Slots -->
19:29:31:  <slot id='1' type='GPU'>
19:29:31:    <client-type v='advanced'/>
19:29:31:    <max-packet-size v='big'/>
19:29:31:    <next-unit-percentage v='100'/>
19:29:31:    <pause-on-start v='True'/>
19:29:31:  </slot>
19:29:31:</config>
19:29:57:FS01:Unpaused
19:29:57:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:29:58:WU00:FS01:Assigned to work server 129.213.157.105
19:29:58:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GA102 [GeForce RTX 3080] from 129.213.157.105
19:29:58:WU00:FS01:Connecting to 129.213.157.105:8080
19:30:04:WU00:FS01:Downloading 21.64MiB
19:30:09:WU00:FS01:Download complete
19:30:09:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14908 run:307 clone:0 gen:22 core:0x22 unit:0x0000001b81d59d695f5260277b3d712d
19:30:09:WU00:FS01:Starting
19:30:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cocov\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 18964 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:30:09:WU00:FS01:Started FahCore on PID 23312
19:30:10:WU00:FS01:Core PID:23344
19:30:10:WU00:FS01:FahCore 0x22 started
19:30:10:WU00:FS01:0x22:*********************** Log Started 2020-10-01T19:30:10Z ***********************
19:30:10:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:30:10:WU00:FS01:0x22:       Core: Core22
19:30:10:WU00:FS01:0x22:       Type: 0x22
19:30:10:WU00:FS01:0x22:    Version: 0.0.13
19:30:10:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:30:10:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
19:30:10:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
19:30:10:WU00:FS01:0x22:       Date: Sep 19 2020
19:30:10:WU00:FS01:0x22:       Time: 02:35:58
19:30:10:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:30:10:WU00:FS01:0x22:     Branch: core22-0.0.13
19:30:10:WU00:FS01:0x22:   Compiler: Visual C++ 2015
19:30:10:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:30:10:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:30:10:WU00:FS01:0x22:   Platform: win32 10
19:30:10:WU00:FS01:0x22:       Bits: 64
19:30:10:WU00:FS01:0x22:       Mode: Release
19:30:10:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:30:10:WU00:FS01:0x22:             <peastman@stanford.edu>
19:30:10:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 23312 -checkpoint 30
19:30:10:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:30:10:WU00:FS01:0x22:             0 -gpu 0
19:30:10:WU00:FS01:0x22:************************************ libFAH ************************************
19:30:10:WU00:FS01:0x22:       Date: Sep 7 2020
19:30:10:WU00:FS01:0x22:       Time: 19:09:56
19:30:10:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:30:10:WU00:FS01:0x22:     Branch: HEAD
19:30:10:WU00:FS01:0x22:************************************ CBang *************************************
19:30:10:WU00:FS01:0x22:       Time: 19:08:30
19:30:10:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:30:10:WU00:FS01:0x22:************************************ System ************************************
19:30:10:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz
19:30:10:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:30:10:WU00:FS01:0x22:       CPUs: 16
19:30:10:WU00:FS01:0x22:     Memory: 63.94GiB
19:30:10:WU00:FS01:0x22:Free Memory: 58.94GiB
19:30:10:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
19:30:10:WU00:FS01:0x22: OS Version: 6.2
19:30:10:WU00:FS01:0x22:Has Battery: false
19:30:10:WU00:FS01:0x22: On Battery: false
19:30:10:WU00:FS01:0x22: UTC Offset: -7
19:30:10:WU00:FS01:0x22:        PID: 23344
19:30:10:WU00:FS01:0x22:        CWD: C:\Users\cocov\AppData\Roaming\FAHClient\work
19:30:10:WU00:FS01:0x22:************************************ OpenMM ************************************
19:30:10:WU00:FS01:0x22:   Revision: 189320d0
19:30:10:WU00:FS01:0x22:********************************************************************************
19:30:10:WU00:FS01:0x22:Project: 14908 (Run 307, Clone 0, Gen 22)
19:30:10:WU00:FS01:0x22:Unit: 0x0000001b81d59d695f5260277b3d712d
19:30:10:WU00:FS01:0x22:Reading tar file core.xml
19:30:10:WU00:FS01:0x22:Reading tar file integrator.xml
19:30:10:WU00:FS01:0x22:Reading tar file state.xml
19:30:11:WU00:FS01:0x22:Reading tar file system.xml
19:30:12:WU00:FS01:0x22:Digital signatures verified
19:30:12:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:30:12:WU00:FS01:0x22:Version 0.0.13
19:30:12:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
19:30:12:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:30:12:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (5%) [20 total]
19:30:12:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
19:30:12:WU00:FS01:0x22:There are 4 platforms available.
19:30:12:WU00:FS01:0x22:Platform 0: Reference
19:30:12:WU00:FS01:0x22:Platform 1: CPU
19:30:12:WU00:FS01:0x22:Platform 2: OpenCL
19:30:12:WU00:FS01:0x22:  opencl-device 0 specified
19:30:12:WU00:FS01:0x22:Platform 3: CUDA
19:30:12:WU00:FS01:0x22:  cuda-device 0 specified
19:30:20:WU00:FS01:0x22:Attempting to create CUDA context:
19:30:20:WU00:FS01:0x22:  Configuring platform CUDA
19:31:19:WU00:FS01:0x22:  Using CUDA and gpu 0
19:31:19:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
19:31:20:WU00:FS01:0x22:Checkpoint completed at step 0
19:32:01:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
