It seems that FAH is using the wrong GPU card. This is on Windows 10, a Dell Precision 7740 laptop.
This has two graphics boards. In Task Manager, they are labeled as
GPU 0: Intel UHD Graphics 630
GPU 1: AMD Radeon Pro WX 7130
Until a couple of days ago, FAH used the Radeon card exclusively; the "Compute 1" subset, (or engine?) of the Radeon card, was always 100% busy during these calculations.
But now: the FAH Control program shows:
a) slot 01 is "ready" to use the UHD card, and
b) the task in slot 02 is running on the Radeon.
However, Task Manager shows that the opposite: UHD (/3d subset) is 100% busy, while the Radeon is idle.
Also, (until a couple of days ago), the GPU task would complete in about 6 hours. But now, the FAH Control shows that this GPU task will take two days and is worth only 25100 credits.
Is something wrong with the software, or on my end, or what?
FAH using the wrong GPU card?
Re: FAH using the wrong GPU card?
Welcome to the F@H Forum RBaillie,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
I believe that a new Intel Driver version might have caused this to happen: viewtopic.php?f=108&t=36178
Drivers:
Intel UHD 630 driver: version 27.20.100.8280, 5/19/2020
AMD Radeon driver: version 26.20.13028.3001, 1/13/2020
Don't know if this is related or not, but a couple of days ago, I noticed that the desktop icons looked weird (shadows below the icons) so I rebooted. (Graphics driver crashed?) This happens every month or two. Rebooting returns the desktop to a normal appearance. I have since un-installed and re-installed FAH, but FAH is still using the wrong GPU.
Also, simultaneously with starting to use the wrong GPU (at least the opposite one from what Task Manager claims), the CPU calculations have started up again. Previously, there was a period of several weeks when the CPU was idle and only the Radeon CPU was doing anything.
Here's the current log file
01:56:08:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
02:25:29:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
02:25:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:25:52:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
02:25:52:WU01:FS01:Connecting to assign2.foldingathome.org:80
02:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
02:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
02:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
02:25:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
02:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
02:25:53:ERROR:WU01:FS01:Exception: Could not get an assignment
02:27:04:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
02:28:45:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
02:30:23:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
02:32:01:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
02:33:40:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
02:35:16:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
02:36:56:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
02:38:32:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
02:39:17:WU02:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
02:40:09:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
02:40:39:24:127.0.0.1:New Web session
02:41:49:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
02:42:43:FS00:Shutting core down
02:42:43:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 516
02:42:43:WU00:FS00:0xa7:Exiting, please wait. . .
02:42:46:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:42:46:WU00:FS00:Starting
02:42:46:WARNING:WU00:FS00:Changed SMP threads from 9 to 10 this can cause some work units to fail
02:42:46:WARNING:WU00:FS00:AS lowered CPUs from 10 to 9
02:42:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 9
02:42:46:WU00:FS00:Started FahCore on PID 2916
02:42:52:WU00:FS00:Core PID:1668
02:42:52:WU00:FS00:FahCore 0xa7 started
02:42:53:WU00:FS00:0xa7:*********************** Log Started 2020-10-01T02:42:52Z ***********************
02:42:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:42:53:WU00:FS00:0xa7: Type: 0xa7
02:42:53:WU00:FS00:0xa7: Core: Gromacs
02:42:53:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 2916 -checkpoint 15 -np 9
02:42:53:WU00:FS00:0xa7:************************************ CBang *************************************
02:42:53:WU00:FS00:0xa7: Date: Nov 27 2019
02:42:53:WU00:FS00:0xa7: Time: 03:40:09
02:42:53:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
02:42:53:WU00:FS00:0xa7: Branch: master
02:42:53:WU00:FS00:0xa7: Compiler: Visual C++ 2008
02:42:53:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:42:53:WU00:FS00:0xa7: Platform: win32 10
02:42:53:WU00:FS00:0xa7: Bits: 64
02:42:53:WU00:FS00:0xa7: Mode: Release
02:42:53:WU00:FS00:0xa7:************************************ System ************************************
02:42:53:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
02:42:53:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:42:53:WU00:FS00:0xa7: CPUs: 12
02:42:53:WU00:FS00:0xa7: Memory: 63.76GiB
02:42:53:WU00:FS00:0xa7:Free Memory: 56.47GiB
02:42:53:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
02:42:53:WU00:FS00:0xa7: OS Version: 6.2
02:42:53:WU00:FS00:0xa7:Has Battery: true
02:42:53:WU00:FS00:0xa7: On Battery: false
02:42:53:WU00:FS00:0xa7: UTC Offset: -4
02:42:53:WU00:FS00:0xa7: PID: 1668
02:42:53:WU00:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
02:42:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:42:53:WU00:FS00:0xa7: Version: 0.0.19
02:42:53:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:42:53:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
02:42:53:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
02:42:53:WU00:FS00:0xa7: Date: Nov 25 2019
02:42:53:WU00:FS00:0xa7: Time: 17:12:41
02:42:53:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
02:42:53:WU00:FS00:0xa7:************************************ Build *************************************
02:42:53:WU00:FS00:0xa7: SIMD: avx_256
02:42:53:WU00:FS00:0xa7:********************************************************************************
02:42:53:WU00:FS00:0xa7:Project: 17407 (Run 0, Clone 817, Gen 36)
02:42:53:WU00:FS00:0xa7:Unit: 0x0000002842aa6f325f61846f8c9c910c
02:42:53:WU00:FS00:0xa7:Digital signatures verified
02:42:53:WU00:FS00:0xa7:Calling: mdrun -s frame36.tpr -o frame36.trr -x frame36.xtc -cpi state.cpt -cpt 15 -nt 9
02:42:53:WU00:FS00:0xa7:Steps: first=4500000 total=125000
02:42:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:55:WU00:FS00:0xa7:Completed 116972 out of 125000 steps (93%)
02:43:05:Saving configuration to config.xml
02:43:05:<config>
02:43:05: <!-- Slot Control -->
02:43:05: <power v='full'/>
02:43:05:
02:43:05: <!-- User Information -->
02:43:05: <passkey v='*****'/>
02:43:05: <team v='182116'/>
02:43:05: <user v='RBaillie'/>
02:43:05:
02:43:05: <!-- Folding Slots -->
02:43:05: <slot id='0' type='CPU'/>
02:43:05: <slot id='1' type='GPU'/>
02:43:05: <slot id='2' type='GPU'/>
02:43:05:</config>
02:43:36:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
02:45:11:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
02:46:49:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
02:48:25:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
02:50:00:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
02:51:35:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
02:51:36:WU03:FS00:Connecting to assign1.foldingathome.org:80
02:51:36:WU03:FS00:Assigned to work server 143.89.243.111
02:51:36:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 143.89.243.111
02:51:36:WU03:FS00:Connecting to 143.89.243.111:8080
02:51:37:ERROR:WU03:FS00:Exception: Server did not assign work unit
02:51:37:WU03:FS00:Connecting to assign1.foldingathome.org:80
02:51:38:WU03:FS00:Assigned to work server 69.94.66.7
02:51:38:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 69.94.66.7
02:51:38:WU03:FS00:Connecting to 69.94.66.7:8080
02:51:38:WU03:FS00:Downloading 2.79MiB
02:51:41:WU03:FS00:Download complete
02:51:41:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14379 run:2701 clone:4 gen:501 core:0xa7 unit:0x00000238455e42075e932f2170106327
02:53:09:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
02:53:13:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
02:53:13:WU00:FS00:0xa7:Saving result file frame36.trr
02:53:13:WU00:FS00:0xa7:Saving result file frame36.xtc
02:53:13:WU00:FS00:0xa7:Saving result file md.log
02:53:13:WU00:FS00:0xa7:Saving result file science.log
02:53:13:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:53:14:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:53:14:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17407 run:0 clone:817 gen:36 core:0xa7 unit:0x0000002842aa6f325f61846f8c9c910c
02:53:14:WU00:FS00:Uploading 9.94MiB to 66.170.111.50
02:53:14:WU00:FS00:Connecting to 66.170.111.50:8080
02:53:14:WU03:FS00:Starting
02:53:14:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 10
02:53:14:WU03:FS00:Started FahCore on PID 4900
02:53:14:WU03:FS00:Core PID:20044
02:53:14:WU03:FS00:FahCore 0xa7 started
02:53:14:WU03:FS00:0xa7:*********************** Log Started 2020-10-01T02:53:14Z ***********************
02:53:14:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:53:14:WU03:FS00:0xa7: Type: 0xa7
02:53:14:WU03:FS00:0xa7: Core: Gromacs
02:53:14:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 4900 -checkpoint 15 -np
02:53:14:WU03:FS00:0xa7: 10
02:53:14:WU03:FS00:0xa7:************************************ CBang *************************************
02:53:14:WU03:FS00:0xa7: Date: Nov 27 2019
02:53:14:WU03:FS00:0xa7: Time: 03:40:09
02:53:14:WU03:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
02:53:14:WU03:FS00:0xa7: Branch: master
02:53:14:WU03:FS00:0xa7: Compiler: Visual C++ 2008
02:53:14:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:53:14:WU03:FS00:0xa7: Platform: win32 10
02:53:14:WU03:FS00:0xa7: Bits: 64
02:53:14:WU03:FS00:0xa7: Mode: Release
02:53:14:WU03:FS00:0xa7:************************************ System ************************************
02:53:14:WU03:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
02:53:14:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:53:14:WU03:FS00:0xa7: CPUs: 12
02:53:14:WU03:FS00:0xa7: Memory: 63.76GiB
02:53:14:WU03:FS00:0xa7:Free Memory: 57.21GiB
02:53:14:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
02:53:14:WU03:FS00:0xa7: OS Version: 6.2
02:53:14:WU03:FS00:0xa7:Has Battery: true
02:53:14:WU03:FS00:0xa7: On Battery: false
02:53:14:WU03:FS00:0xa7: UTC Offset: -4
02:53:14:WU03:FS00:0xa7: PID: 20044
02:53:14:WU03:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
02:53:14:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
02:53:14:WU03:FS00:0xa7: Version: 0.0.19
02:53:14:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:53:14:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
02:53:14:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
02:53:14:WU03:FS00:0xa7: Date: Nov 25 2019
02:53:14:WU03:FS00:0xa7: Time: 17:12:41
02:53:14:WU03:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
02:53:14:WU03:FS00:0xa7:************************************ Build *************************************
02:53:14:WU03:FS00:0xa7: SIMD: avx_256
02:53:14:WU03:FS00:0xa7:********************************************************************************
02:53:14:WU03:FS00:0xa7:Project: 14379 (Run 2701, Clone 4, Gen 501)
02:53:14:WU03:FS00:0xa7:Unit: 0x00000238455e42075e932f2170106327
02:53:14:WU03:FS00:0xa7:Reading tar file core.xml
02:53:14:WU03:FS00:0xa7:Reading tar file frame501.tpr
02:53:14:WU03:FS00:0xa7:Digital signatures verified
02:53:14:WU03:FS00:0xa7:Calling: mdrun -s frame501.tpr -o frame501.trr -cpt 15 -nt 10
02:53:14:WU03:FS00:0xa7:Steps: first=0 total=250000
02:53:16:WU03:FS00:0xa7:Completed 1 out of 250000 steps (0%)
02:53:20:WU00:FS00:Upload 13.20%
02:53:26:WU00:FS00:Upload 44.01%
02:53:32:WU00:FS00:Upload 76.70%
02:53:36:WU00:FS00:Upload complete
02:53:36:WU00:FS00:Server responded WORK_ACK (400)
02:53:36:WU00:FS00:Final credit estimate, 4498.00 points
02:53:36:WU00:FS00:Cleaning up
02:54:45:WU03:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
03:24:36:WU03:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
03:25:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:25:52:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
03:25:52:WU01:FS01:Connecting to assign2.foldingathome.org:80
03:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
03:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
03:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
03:25:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
03:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
03:25:53:ERROR:WU01:FS01:Exception: Could not get an assignment
03:26:06:WU03:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
04:25:45:WU03:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
04:25:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
04:25:52:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:25:52:WU01:FS01:Connecting to assign2.foldingathome.org:80
04:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
04:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:25:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
04:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:25:53:ERROR:WU01:FS01:Exception: Could not get an assignment
04:27:14:WU03:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
05:19:15:WU03:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
05:20:44:WU03:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
05:20:45:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:20:45:WU00:FS00:Assigned to work server 178.174.196.138
05:20:45:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 178.174.196.138
05:20:45:WU00:FS00:Connecting to 178.174.196.138:8080
05:20:46:WU00:FS00:Downloading 1.88MiB
05:20:48:WU00:FS00:Download complete
05:20:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16810 run:70 clone:67 gen:47 core:0xa8 unit:0x00000039b2aec48a5eff242a7b505e53
05:20:48:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah
05:20:48:WU00:FS00:Connecting to cores.foldingathome.org:80
05:20:48:WU00:FS00:FahCore a8: Downloading 7.83MiB
05:20:50:WU00:FS00:FahCore a8: Download complete
05:20:50:WU00:FS00:Valid core signature
05:20:50:WU00:FS00:Unpacked 21.33MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe
05:20:50:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/libfftw3f-3.dll
05:20:50:WU00:FS00:Unpacked 180.29KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/vcomp140.dll
05:22:14:WU03:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
05:22:16:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
05:22:16:WU03:FS00:0xa7:Saving result file dhdl.xvg
05:22:16:WU03:FS00:0xa7:Saving result file frame501.trr
05:22:16:WU03:FS00:0xa7:Saving result file md.log
05:22:16:WU03:FS00:0xa7:Saving result file pullf.xvg
05:22:16:WU03:FS00:0xa7:Saving result file pullx.xvg
05:22:16:WU03:FS00:0xa7:Saving result file science.log
05:22:16:WU03:FS00:0xa7:Saving result file traj_comp.xtc
05:22:16:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
05:22:16:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:22:16:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14379 run:2701 clone:4 gen:501 core:0xa7 unit:0x00000238455e42075e932f2170106327
05:22:16:WU03:FS00:Uploading 6.40MiB to 69.94.66.7
05:22:16:WU03:FS00:Connecting to 69.94.66.7:8080
05:22:16:WU00:FS00:Starting
05:22:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.8/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 10
05:22:16:WU00:FS00:Started FahCore on PID 8744
05:22:19:WU00:FS00:Core PID:1916
05:22:19:WU00:FS00:FahCore 0xa8 started
05:22:20:WU00:FS00:0xa8:*********************** Log Started 2020-10-01T05:22:19Z ***********************
05:22:20:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
05:22:20:WU00:FS00:0xa8: Core: Gromacs
05:22:20:WU00:FS00:0xa8: Type: 0xa8
05:22:20:WU00:FS00:0xa8: Version: 0.0.8
05:22:20:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:22:20:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
05:22:20:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
05:22:20:WU00:FS00:0xa8: Date: Sep 25 2020
05:22:20:WU00:FS00:0xa8: Time: 08:28:00
05:22:20:WU00:FS00:0xa8: Revision: d4f41a5b7a748fdb0ff538746b195ca3a8075aae
05:22:20:WU00:FS00:0xa8: Branch: master
05:22:20:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
05:22:20:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Ob3
05:22:20:WU00:FS00:0xa8: /Zc:throwingNew /MT
05:22:20:WU00:FS00:0xa8: Platform: win32 10
05:22:20:WU00:FS00:0xa8: Bits: 64
05:22:20:WU00:FS00:0xa8: Mode: Release
05:22:20:WU00:FS00:0xa8: SIMD: avx2_256
05:22:20:WU00:FS00:0xa8: OpenMP: ON
05:22:20:WU00:FS00:0xa8: CUDA: OFF
05:22:20:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 8744 -checkpoint 15 -np
05:22:20:WU00:FS00:0xa8: 10
05:22:20:WU00:FS00:0xa8:************************************ libFAH ************************************
05:22:20:WU00:FS00:0xa8: Time: 07:23:00
05:22:20:WU00:FS00:0xa8:************************************ CBang *************************************
05:22:20:WU00:FS00:0xa8: Time: 07:22:40
05:22:20:WU00:FS00:0xa8:************************************ System ************************************
05:22:20:WU00:FS00:0xa8: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
05:22:20:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
05:22:20:WU00:FS00:0xa8: CPUs: 12
05:22:20:WU00:FS00:0xa8: Memory: 63.76GiB
05:22:20:WU00:FS00:0xa8:Free Memory: 56.76GiB
05:22:20:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
05:22:20:WU00:FS00:0xa8: OS Version: 6.2
05:22:20:WU00:FS00:0xa8:Has Battery: true
05:22:20:WU00:FS00:0xa8: On Battery: false
05:22:20:WU00:FS00:0xa8: UTC Offset: -4
05:22:20:WU00:FS00:0xa8: PID: 1916
05:22:20:WU00:FS00:0xa8: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
05:22:20:WU00:FS00:0xa8:********************************************************************************
05:22:20:WU00:FS00:0xa8:Project: 16810 (Run 70, Clone 67, Gen 47)
05:22:20:WU00:FS00:0xa8:Unit: 0x00000039b2aec48a5eff242a7b505e53
05:22:20:WU00:FS00:0xa8:Reading tar file core.xml
05:22:20:WU00:FS00:0xa8:Reading tar file frame47.tpr
05:22:20:WU00:FS00:0xa8:Digital signatures verified
05:22:20:WU00:FS00:0xa8:Calling: mdrun -c frame47.gro -s frame47.tpr -x frame47.xtc -cpt 15 -nt 10 -ntmpi 1
05:22:20:WU00:FS00:0xa8:Steps: first=23500000 total=24000000
05:22:21:WU00:FS00:0xa8:Completed 1 out of 500000 steps (0%)
05:22:22:WU03:FS00:Upload 33.21%
05:22:28:WU03:FS00:Upload 71.31%
05:22:32:WU03:FS00:Upload complete
05:22:32:WU03:FS00:Server responded WORK_ACK (400)
05:22:32:WU03:FS00:Final credit estimate, 4056.00 points
05:22:32:WU03:FS00:Cleaning up
05:24:44:WU00:FS00:0xa8:Completed 5000 out of 500000 steps (1%)
05:25:29:WU02:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
05:25:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
05:25:52:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
05:25:52:WU01:FS01:Connecting to assign2.foldingathome.org:80
05:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
05:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
05:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
05:25:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
05:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
05:25:53:ERROR:WU01:FS01:Exception: Could not get an assignment
05:27:07:WU00:FS00:0xa8:Completed 10000 out of 500000 steps (2%)
06:24:33:WU00:FS00:0xa8:Completed 130000 out of 500000 steps (26%)
06:25:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
06:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:25:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
06:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
06:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:25:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
06:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:25:54:ERROR:WU01:FS01:Exception: Could not get an assignment
06:26:56:WU00:FS00:0xa8:Completed 135000 out of 500000 steps (27%)
07:21:58:WU00:FS00:0xa8:Completed 250000 out of 500000 steps (50%)
******************************* Date: 2020-10-01 *******************************
07:24:22:WU00:FS00:0xa8:Completed 255000 out of 500000 steps (51%)
07:25:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
07:25:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
07:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
07:25:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
07:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
07:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
07:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
07:25:54:ERROR:WU01:FS01:Exception: Could not get an assignment
07:26:45:WU00:FS00:0xa8:Completed 260000 out of 500000 steps (52%)
08:21:45:WU00:FS00:0xa8:Completed 375000 out of 500000 steps (75%)
08:24:09:WU00:FS00:0xa8:Completed 380000 out of 500000 steps (76%)
08:25:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
08:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
08:25:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
08:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
08:25:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
08:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
08:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
08:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
08:25:54:ERROR:WU01:FS01:Exception: Could not get an assignment
08:26:33:WU00:FS00:0xa8:Completed 385000 out of 500000 steps (77%)
08:28:56:WU00:FS00:0xa8:Completed 390000 out of 500000 steps (78%)
08:31:19:WU00:FS00:0xa8:Completed 395000 out of 500000 steps (79%)
08:33:43:WU00:FS00:0xa8:Completed 400000 out of 500000 steps (80%)
08:36:07:WU00:FS00:0xa8:Completed 405000 out of 500000 steps (81%)
08:38:31:WU00:FS00:0xa8:Completed 410000 out of 500000 steps (82%)
08:40:54:WU00:FS00:0xa8:Completed 415000 out of 500000 steps (83%)
08:43:26:WU00:FS00:0xa8:Completed 420000 out of 500000 steps (84%)
08:44:11:WU02:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
08:44:14:WU02:FS02:0x22:Checkpoint completed at step 350000
08:45:49:WU00:FS00:0xa8:Completed 425000 out of 500000 steps (85%)
08:48:13:WU00:FS00:0xa8:Completed 430000 out of 500000 steps (86%)
08:50:36:WU00:FS00:0xa8:Completed 435000 out of 500000 steps (87%)
08:53:00:WU00:FS00:0xa8:Completed 440000 out of 500000 steps (88%)
08:55:23:WU00:FS00:0xa8:Completed 445000 out of 500000 steps (89%)
08:57:46:WU00:FS00:0xa8:Completed 450000 out of 500000 steps (90%)
09:00:11:WU00:FS00:0xa8:Completed 455000 out of 500000 steps (91%)
09:02:35:WU00:FS00:0xa8:Completed 460000 out of 500000 steps (92%)
09:04:58:WU00:FS00:0xa8:Completed 465000 out of 500000 steps (93%)
09:07:22:WU00:FS00:0xa8:Completed 470000 out of 500000 steps (94%)
09:09:46:WU00:FS00:0xa8:Completed 475000 out of 500000 steps (95%)
09:12:09:WU00:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
09:14:32:WU00:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
09:16:56:WU00:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
09:17:24:WU02:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
09:19:19:WU00:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
09:19:20:WU03:FS00:Connecting to assign1.foldingathome.org:80
09:19:20:WU03:FS00:Assigned to work server 143.89.243.111
09:19:20:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 143.89.243.111
09:19:20:WU03:FS00:Connecting to 143.89.243.111:8080
09:19:21:ERROR:WU03:FS00:Exception: Server did not assign work unit
09:19:21:WU03:FS00:Connecting to assign1.foldingathome.org:80
09:19:21:WU03:FS00:Assigned to work server 155.247.164.214
09:19:21:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 155.247.164.214
09:19:21:WU03:FS00:Connecting to 155.247.164.214:8080
09:19:22:WU03:FS00:Downloading 2.82MiB
09:19:23:WU03:FS00:Download complete
09:19:23:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14827 run:1000 clone:2 gen:22 core:0xa7 unit:0x0000001a9bf7a4d65ea66457c67b8e71
09:21:42:WU00:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
09:21:43:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
09:21:43:WU00:FS00:0xa8:Saving result file ener.edr
09:21:43:WU00:FS00:0xa8:Saving result file frame47.gro
09:21:43:WU00:FS00:0xa8:Saving result file frame47.xtc
09:21:43:WU00:FS00:0xa8:Saving result file md.log
09:21:43:WU00:FS00:0xa8:Saving result file science.log
09:21:43:WU00:FS00:0xa8:Saving result file state.cpt
09:21:43:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
09:21:44:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:21:44:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16810 run:70 clone:67 gen:47 core:0xa8 unit:0x00000039b2aec48a5eff242a7b505e53
09:21:44:WU00:FS00:Uploading 8.00MiB to 178.174.196.138
09:21:44:WU00:FS00:Connecting to 178.174.196.138:8080
09:21:44:WU03:FS00:Starting
09:21:44:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 10
09:21:44:WU03:FS00:Started FahCore on PID 14288
09:21:44:WU03:FS00:Core PID:11956
09:21:44:WU03:FS00:FahCore 0xa7 started
09:21:44:WU03:FS00:0xa7:*********************** Log Started 2020-10-01T09:21:44Z ***********************
09:21:44:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:21:44:WU03:FS00:0xa7: Type: 0xa7
09:21:44:WU03:FS00:0xa7: Core: Gromacs
09:21:44:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 14288 -checkpoint 15 -np
09:21:44:WU03:FS00:0xa7: 10
09:21:44:WU03:FS00:0xa7:************************************ CBang *************************************
09:21:44:WU03:FS00:0xa7: Date: Nov 27 2019
09:21:44:WU03:FS00:0xa7: Time: 03:40:09
09:21:44:WU03:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:21:44:WU03:FS00:0xa7: Branch: master
09:21:44:WU03:FS00:0xa7: Compiler: Visual C++ 2008
09:21:44:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:21:44:WU03:FS00:0xa7: Platform: win32 10
09:21:44:WU03:FS00:0xa7: Bits: 64
09:21:44:WU03:FS00:0xa7: Mode: Release
09:21:44:WU03:FS00:0xa7:************************************ System ************************************
09:21:44:WU03:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
09:21:44:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
09:21:44:WU03:FS00:0xa7: CPUs: 12
09:21:44:WU03:FS00:0xa7: Memory: 63.76GiB
09:21:44:WU03:FS00:0xa7:Free Memory: 56.92GiB
09:21:44:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
09:21:44:WU03:FS00:0xa7: OS Version: 6.2
09:21:44:WU03:FS00:0xa7:Has Battery: true
09:21:44:WU03:FS00:0xa7: On Battery: false
09:21:44:WU03:FS00:0xa7: UTC Offset: -4
09:21:44:WU03:FS00:0xa7: PID: 11956
09:21:44:WU03:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
09:21:44:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:21:44:WU03:FS00:0xa7: Version: 0.0.19
09:21:44:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:21:44:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
09:21:44:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
09:21:44:WU03:FS00:0xa7: Date: Nov 25 2019
09:21:44:WU03:FS00:0xa7: Time: 17:12:41
09:21:44:WU03:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:21:44:WU03:FS00:0xa7:************************************ Build *************************************
09:21:44:WU03:FS00:0xa7: SIMD: avx_256
09:21:44:WU03:FS00:0xa7:********************************************************************************
09:21:44:WU03:FS00:0xa7:Project: 14827 (Run 1000, Clone 2, Gen 22)
09:21:44:WU03:FS00:0xa7:Unit: 0x0000001a9bf7a4d65ea66457c67b8e71
09:21:44:WU03:FS00:0xa7:Reading tar file core.xml
09:21:44:WU03:FS00:0xa7:Reading tar file frame22.tpr
09:21:44:WU03:FS00:0xa7:Digital signatures verified
09:21:44:WU03:FS00:0xa7:Calling: mdrun -s frame22.tpr -o frame22.trr -cpt 15 -nt 10
09:21:44:WU03:FS00:0xa7:Steps: first=0 total=250000
09:21:46:WU03:FS00:0xa7:Completed 1 out of 250000 steps (0%)
09:21:50:WU00:FS00:Upload 11.71%
09:21:56:WU00:FS00:Upload 39.82%
09:22:02:WU00:FS00:Upload 69.49%
09:22:08:WU00:FS00:Upload 99.16%
09:22:08:WU00:FS00:Upload complete
09:22:08:WU00:FS00:Server responded WORK_ACK (400)
09:22:08:WU00:FS00:Final credit estimate, 11041.00 points
09:22:08:WU00:FS00:Cleaning up
09:23:15:WU03:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:24:43:WU03:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
09:25:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:25:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
09:25:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
09:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
09:25:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
09:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
09:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
09:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
09:25:54:ERROR:WU01:FS01:Exception: Could not get an assignment
09:26:12:WU03:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:27:40:WU03:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
10:24:12:WU02:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
10:25:29:WU03:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
10:25:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:25:54:WU01:FS01:Connecting to assign2.foldingathome.org:80
10:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:25:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
10:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
10:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:25:54:ERROR:WU01:FS01:Exception: Could not get an assignment
10:26:58:WU03:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
10:28:26:WU03:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
11:22:49:WU03:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
11:24:18:WU03:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
11:25:47:WU03:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
11:25:54:WU01:FS01:Connecting to assign1.foldingathome.org:80
11:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:25:54:WU01:FS01:Connecting to assign2.foldingathome.org:80
11:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:25:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
11:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
11:25:55:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:25:55:ERROR:WU01:FS01:Exception: Could not get an assignment
11:27:16:WU03:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
11:28:44:WU03:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
11:48:14:WU03:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
11:49:44:WU03:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
11:49:44:WU00:FS00:Connecting to assign1.foldingathome.org:80
11:49:44:WU00:FS00:Assigned to work server 143.89.243.111
11:49:44:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 143.89.243.111
11:49:44:WU00:FS00:Connecting to 143.89.243.111:8080
11:49:45:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:49:45:WU00:FS00:Connecting to assign1.foldingathome.org:80
11:49:46:WU00:FS00:Assigned to work server 128.252.203.9
11:49:46:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 128.252.203.9
11:49:46:WU00:FS00:Connecting to 128.252.203.9:8080
11:49:46:WU00:FS00:Downloading 8.14MiB
11:49:48:WU00:FS00:Download complete
11:49:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13828 run:51 clone:3 gen:147 core:0xa7 unit:0x000000b180fccb095e6d0b5e15b50e90
11:51:13:WU03:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
11:51:15:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
11:51:15:WU03:FS00:0xa7:Saving result file dhdl.xvg
11:51:15:WU03:FS00:0xa7:Saving result file frame22.trr
11:51:15:WU03:FS00:0xa7:Saving result file md.log
11:51:15:WU03:FS00:0xa7:Saving result file pullf.xvg
11:51:15:WU03:FS00:0xa7:Saving result file pullx.xvg
11:51:15:WU03:FS00:0xa7:Saving result file science.log
11:51:15:WU03:FS00:0xa7:Saving result file traj_comp.xtc
11:51:15:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:51:16:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:51:16:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14827 run:1000 clone:2 gen:22 core:0xa7 unit:0x0000001a9bf7a4d65ea66457c67b8e71
11:51:16:WU03:FS00:Uploading 6.79MiB to 155.247.164.214
11:51:16:WU03:FS00:Connecting to 155.247.164.214:8080
11:51:16:WU00:FS00:Starting
11:51:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 10
11:51:16:WU00:FS00:Started FahCore on PID 11248
11:51:16:WU00:FS00:Core PID:10032
11:51:16:WU00:FS00:FahCore 0xa7 started
11:51:16:WU00:FS00:0xa7:*********************** Log Started 2020-10-01T11:51:16Z ***********************
11:51:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:51:16:WU00:FS00:0xa7: Type: 0xa7
11:51:16:WU00:FS00:0xa7: Core: Gromacs
11:51:16:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 11248 -checkpoint 15 -np
11:51:16:WU00:FS00:0xa7: 10
11:51:16:WU00:FS00:0xa7:************************************ CBang *************************************
11:51:16:WU00:FS00:0xa7: Date: Nov 27 2019
11:51:16:WU00:FS00:0xa7: Time: 03:40:09
11:51:16:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:51:16:WU00:FS00:0xa7: Branch: master
11:51:16:WU00:FS00:0xa7: Compiler: Visual C++ 2008
11:51:16:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:51:16:WU00:FS00:0xa7: Platform: win32 10
11:51:16:WU00:FS00:0xa7: Bits: 64
11:51:16:WU00:FS00:0xa7: Mode: Release
11:51:16:WU00:FS00:0xa7:************************************ System ************************************
11:51:16:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
11:51:16:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:51:16:WU00:FS00:0xa7: CPUs: 12
11:51:16:WU00:FS00:0xa7: Memory: 63.76GiB
11:51:16:WU00:FS00:0xa7:Free Memory: 56.92GiB
11:51:16:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
11:51:16:WU00:FS00:0xa7: OS Version: 6.2
11:51:16:WU00:FS00:0xa7:Has Battery: true
11:51:16:WU00:FS00:0xa7: On Battery: false
11:51:16:WU00:FS00:0xa7: UTC Offset: -4
11:51:16:WU00:FS00:0xa7: PID: 10032
11:51:16:WU00:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
11:51:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:51:16:WU00:FS00:0xa7: Version: 0.0.19
11:51:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:51:16:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:51:16:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:51:16:WU00:FS00:0xa7: Date: Nov 25 2019
11:51:16:WU00:FS00:0xa7: Time: 17:12:41
11:51:16:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:51:16:WU00:FS00:0xa7:************************************ Build *************************************
11:51:16:WU00:FS00:0xa7: SIMD: avx_256
11:51:16:WU00:FS00:0xa7:********************************************************************************
11:51:16:WU00:FS00:0xa7:Project: 13828 (Run 51, Clone 3, Gen 147)
11:51:16:WU00:FS00:0xa7:Unit: 0x000000b180fccb095e6d0b5e15b50e90
11:51:16:WU00:FS00:0xa7:Reading tar file core.xml
11:51:16:WU00:FS00:0xa7:Reading tar file frame147.tpr
11:51:16:WU00:FS00:0xa7:Digital signatures verified
11:51:16:WU00:FS00:0xa7:Calling: mdrun -s frame147.tpr -o frame147.trr -x frame147.xtc -cpt 15 -nt 10
11:51:16:WU00:FS00:0xa7:Steps: first=18375000 total=125000
11:51:20:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
11:51:22:WU03:FS00:Upload 59.86%
11:51:26:WU03:FS00:Upload complete
11:51:26:WU03:FS00:Server responded WORK_ACK (400)
11:51:26:WU03:FS00:Final credit estimate, 4276.00 points
11:51:26:WU03:FS00:Cleaning up
11:53:06:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
11:54:51:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
11:56:37:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
11:58:23:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
12:00:08:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
12:01:54:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
12:03:39:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
12:05:06:WU02:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
12:05:25:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
12:07:12:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
12:08:57:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
12:10:42:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
12:12:28:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
12:14:13:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
12:15:59:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
12:17:44:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
12:19:30:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
12:21:16:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
12:23:02:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
12:24:48:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
12:25:54:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:25:54:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:25:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:25:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:25:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:25:55:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:25:55:ERROR:WU01:FS01:Exception: Could not get an assignment
12:26:33:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
12:28:19:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
12:30:04:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
12:31:49:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
12:33:34:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
12:35:19:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
12:37:06:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
12:38:36:WU02:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
12:38:52:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
12:40:38:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
12:42:24:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
12:44:10:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
12:45:56:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
12:47:42:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
12:49:27:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
12:51:13:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
12:53:00:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
12:54:46:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
12:56:31:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
12:58:17:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
13:00:03:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
13:01:48:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
13:03:34:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
13:05:19:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
13:07:07:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
13:08:52:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
13:10:45:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
13:12:11:WU02:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
13:12:37:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
13:14:25:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
We need the very top of the log file. When you view it in FAHControl, you have refresh it because it only shows you the last part of the log if it's long. You'll find something like this:
02:47:04: GPUs: 0
02:47:04: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
02:47:04: specified module could not be found.
02:47:04:
02:47:04:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
plus other interesting things. See below.
You can probably create a second GPU slot. Technically the Intel device isn't supported yet but you can leave it paused once the current WU is finished and use only the second slot or (one of these days) you may be able to use both of them (on 2 different WUs) if your system can manage the extra heat.
02:47:04: GPUs: 0
02:47:04:
Reason: changed color yellow on white
(Thanks for your patience!) I did a refresh, then copied the non-junk from the log file. I do occasionally pause everything to make the fan go quiet when I'm on the phone.
*********************** Log Started 2020-09-30T13:21:54Z ***********************
13:21:54:Trying to access database...
13:21:54:Successfully acquired database lock
13:21:54:Downloading GPUs.txt from assign1.foldingathome.org:80
13:21:54:Connecting to assign1.foldingathome.org:80
13:21:54:Read GPUs.txt
13:21:54:Enabled folding slot 00: PAUSED cpu:4 (not configured)
13:21:54:Enabled folding slot 01: PAUSED gpu:0:Gen9p5/GT2 [UHD Graphics 630] (not configured)
13:21:54:Enabled folding slot 02: PAUSED gpu:1:Ellesmere PRO [Radeon RX 470] (not configured)
13:21:55:****************************** FAHClient ******************************
13:21:55: Version: 7.6.13
13:21:55: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:21:55: Copyright: 2020 foldingathome.org
13:21:55: Homepage: https://foldingathome.org/
13:21:55: Date: Apr 27 2020
13:21:55: Time: 21:21:01
13:21:55: Revision: 5a652817f46116b6e135503af97f18e094414e3b
13:21:55: Branch: master
13:21:55: Compiler: Visual C++ 2008
13:21:55: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:21:55: Platform: win32 10
13:21:55: Bits: 32
13:21:55: Mode: Release
13:21:55: Args: --open-web-control
13:21:55:******************************** CBang ********************************
13:21:55: Date: Apr 24 2020
13:21:55: Time: 17:07:55
13:21:55: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
13:21:55: Bits: 32
13:21:55:******************************* System ********************************
13:21:55: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
13:21:55: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:21:55: CPUs: 12
13:21:55: Memory: 63.76GiB
13:21:55: Free Memory: 58.88GiB
13:21:55: Threads: WINDOWS_THREADS
13:21:55: OS Version: 6.2
13:21:55: Has Battery: true
13:21:55: On Battery: false
13:21:55: UTC Offset: -4
13:21:55: PID: 18232
13:21:55: CWD: C:\Users\bobba\AppData\Roaming\FAHClient
13:21:55: Win32 Service: false
13:21:55: OS: Windows 10 Enterprise
13:21:55: OS Arch: AMD64
13:21:55: GPUs: 2
13:21:55: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
13:21:55: GPU 1: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere PRO [Radeon RX 470]
13:21:55: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:21:55: specified module could not be found.
13:21:55:
13:21:55:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
13:21:55:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2906.10
13:21:55:******************************* libFAH ********************************
13:21:55: Date: Apr 15 2020
13:21:55: Time: 14:53:14
13:21:55: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:21:55: Bits: 32
13:21:55:***********************************************************************
13:21:55:<config>
13:21:55: <!-- Folding Slots -->
13:21:55: <slot id='0' type='CPU'/>
13:21:55: <slot id='1' type='GPU'/>
13:21:55: <slot id='2' type='GPU'/>
13:21:55:</config>
13:21:56:6:127.0.0.1:New Web session
13:22:55:Saving configuration to config.xml
13:22:55:<config>
13:22:55: <!-- Folding Slots -->
13:22:55: <slot id='0' type='CPU'/>
13:22:55: <slot id='1' type='GPU'/>
13:22:55: <slot id='2' type='GPU'/>
13:22:55:</config>
13:22:55:Set client configured
13:22:55:WU00:FS00:Connecting to assign1.foldingathome.org:80
13:22:55:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:22:55:WU00:FS00:Connecting to assign2.foldingathome.org:80
13:22:56:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:22:56:WU00:FS00:Connecting to assign3.foldingathome.org:80
13:22:56:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:22:56:WU00:FS00:Connecting to assign4.foldingathome.org:80
13:22:56:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:22:56:ERROR:WU00:FS00:Exception: Could not get an assignment
13:22:56:WU00:FS00:Connecting to assign1.foldingathome.org:80
13:22:56:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:22:56:WU00:FS00:Connecting to assign2.foldingathome.org:80
13:22:57:WU00:FS00:Assigned to work server 69.94.66.7
13:22:57:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 69.94.66.7
13:22:57:WU00:FS00:Connecting to 69.94.66.7:8080
13:22:57:WU00:FS00:Downloading 2.83MiB
13:23:01:WU00:FS00:Download complete
13:23:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14379 run:387 clone:1 gen:508 core:0xa7 unit:0x0000023c455e42075e9330d139f598f0
13:23:01:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
13:23:01:WU00:FS00:Connecting to cores.foldingathome.org:80
13:23:01:WU00:FS00:FahCore a7: Downloading 6.71MiB
13:23:04:WU00:FS00:FahCore a7: Download complete
13:23:04:WU00:FS00:Valid core signature
13:23:04:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
13:23:04:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
13:23:04:WU00:FS00:Starting
13:23:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 4
13:23:04:WU00:FS00:Started FahCore on PID 18324
13:23:07:WU00:FS00:Core PID:12060
13:23:07:WU00:FS00:FahCore 0xa7 started
13:23:07:WU00:FS00:0xa7:*********************** Log Started 2020-09-30T13:23:07Z ***********************
13:23:07:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:23:07:WU00:FS00:0xa7: Type: 0xa7
13:23:07:WU00:FS00:0xa7: Core: Gromacs
13:23:07:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 18324 -checkpoint 15 -np
13:23:07:WU00:FS00:0xa7: 4
13:23:07:WU00:FS00:0xa7:************************************ CBang *************************************
13:23:07:WU00:FS00:0xa7: Date: Nov 27 2019
13:23:07:WU00:FS00:0xa7: Time: 03:40:09
13:23:07:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:23:07:WU00:FS00:0xa7: Branch: master
13:23:07:WU00:FS00:0xa7: Compiler: Visual C++ 2008
13:23:07:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:23:07:WU00:FS00:0xa7: Platform: win32 10
13:23:07:WU00:FS00:0xa7: Bits: 64
13:23:07:WU00:FS00:0xa7: Mode: Release
13:23:07:WU00:FS00:0xa7:************************************ System ************************************
13:23:07:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
13:23:07:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:23:07:WU00:FS00:0xa7: CPUs: 12
13:23:07:WU00:FS00:0xa7: Memory: 63.76GiB
13:23:07:WU00:FS00:0xa7:Free Memory: 58.03GiB
13:23:07:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
13:23:07:WU00:FS00:0xa7: OS Version: 6.2
13:23:07:WU00:FS00:0xa7:Has Battery: true
13:23:07:WU00:FS00:0xa7: On Battery: false
13:23:07:WU00:FS00:0xa7: UTC Offset: -4
13:23:07:WU00:FS00:0xa7: PID: 12060
13:23:07:WU00:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
13:23:07:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:23:07:WU00:FS00:0xa7: Version: 0.0.19
13:23:07:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:23:07:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
13:23:07:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
13:23:07:WU00:FS00:0xa7: Date: Nov 25 2019
13:23:07:WU00:FS00:0xa7: Time: 17:12:41
13:23:07:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:23:07:WU00:FS00:0xa7:************************************ Build *************************************
13:23:07:WU00:FS00:0xa7: SIMD: avx_256
13:23:07:WU00:FS00:0xa7:********************************************************************************
13:23:07:WU00:FS00:0xa7:Project: 14379 (Run 387, Clone 1, Gen 508)
13:23:07:WU00:FS00:0xa7:Unit: 0x0000023c455e42075e9330d139f598f0
13:23:07:WU00:FS00:0xa7:Reading tar file core.xml
13:23:07:WU00:FS00:0xa7:Reading tar file frame508.tpr
13:23:07:WU00:FS00:0xa7:Digital signatures verified
13:23:07:WU00:FS00:0xa7:Calling: mdrun -s frame508.tpr -o frame508.trr -cpt 15 -nt 4
13:23:07:WU00:FS00:0xa7:Steps: first=0 total=250000
13:23:08:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
13:23:56:Saving configuration to config.xml
13:23:56:<config>
13:23:56: <!-- User Information -->
13:23:56: <passkey v='*****'/>
13:23:56: <team v='182116'/>
13:23:56: <user v='RBaillie'/>
13:23:56:
13:23:56: <!-- Folding Slots -->
13:23:56: <slot id='0' type='CPU'/>
13:23:56: <slot id='1' type='GPU'/>
13:23:56: <slot id='2' type='GPU'/>
13:23:56:</config>
13:24:25:FS00:Shutting core down
13:24:26:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 12060
13:24:26:WU00:FS00:0xa7:Exiting, please wait. . .
13:24:26:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:24:26:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:24:26:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:24:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:24:26:WU02:FS02:Connecting to assign1.foldingathome.org:80
13:24:26:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:24:26:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:24:26:WU02:FS02:Assigned to work server 129.213.157.105
13:24:26:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Ellesmere PRO [Radeon RX 470] from 129.213.157.105
13:24:26:WU02:FS02:Connecting to 129.213.157.105:8080
13:24:26:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:24:26:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:24:26:WU00:FS00:Starting
13:24:26:WARNING:WU00:FS00:Changed SMP threads from 4 to 9 this can cause some work units to fail
13:24:26:WARNING:WU00:FS00:AS lowered CPUs from 9 to 4
13:24:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 4
13:24:26:WU00:FS00:Started FahCore on PID 14292
13:24:26:WU00:FS00:Core PID:9576
13:24:26:WU00:FS00:FahCore 0xa7 started
13:24:27:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:24:27:ERROR:WU01:FS01:Exception: Could not get an assignment
13:24:27:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:24:27:WU00:FS00:0xa7:*********************** Log Started 2020-09-30T13:24:26Z ***********************
13:24:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:24:27:WU00:FS00:0xa7: Type: 0xa7
13:24:27:WU00:FS00:0xa7: Core: Gromacs
13:24:27:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 14292 -checkpoint 15 -np
13:24:27:WU00:FS00:0xa7: 4
13:24:27:WU00:FS00:0xa7:************************************ CBang *************************************
13:24:27:WU00:FS00:0xa7: Date: Nov 27 2019
13:24:27:WU00:FS00:0xa7: Time: 03:40:09
13:24:27:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:24:27:WU00:FS00:0xa7: Branch: master
13:24:27:WU00:FS00:0xa7: Compiler: Visual C++ 2008
13:24:27:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:24:27:WU00:FS00:0xa7: Platform: win32 10
13:24:27:WU00:FS00:0xa7: Bits: 64
13:24:27:WU00:FS00:0xa7: Mode: Release
13:24:27:WU00:FS00:0xa7:************************************ System ************************************
13:24:27:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
13:24:27:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:24:27:WU00:FS00:0xa7: CPUs: 12
13:24:27:WU00:FS00:0xa7: Memory: 63.76GiB
13:24:27:WU00:FS00:0xa7:Free Memory: 58.52GiB
13:24:27:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
13:24:27:WU00:FS00:0xa7: OS Version: 6.2
13:24:27:WU00:FS00:0xa7:Has Battery: true
13:24:27:WU00:FS00:0xa7: On Battery: false
13:24:27:WU00:FS00:0xa7: UTC Offset: -4
13:24:27:WU00:FS00:0xa7: PID: 9576
13:24:27:WU00:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
13:24:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:24:27:WU00:FS00:0xa7: Version: 0.0.19
13:24:27:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:24:27:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
13:24:27:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
13:24:27:WU00:FS00:0xa7: Date: Nov 25 2019
13:24:27:WU00:FS00:0xa7: Time: 17:12:41
13:24:27:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:24:27:WU00:FS00:0xa7:************************************ Build *************************************
13:24:27:WU00:FS00:0xa7: SIMD: avx_256
13:24:27:WU00:FS00:0xa7:********************************************************************************
13:24:27:WU00:FS00:0xa7:Project: 14379 (Run 387, Clone 1, Gen 508)
13:24:27:WU00:FS00:0xa7:Unit: 0x0000023c455e42075e9330d139f598f0
13:24:27:WU00:FS00:0xa7:Digital signatures verified
13:24:27:WU00:FS00:0xa7:Calling: mdrun -s frame508.tpr -o frame508.trr -cpi state.cpt -cpt 15 -nt 4
13:24:27:WU00:FS00:0xa7:Steps: first=0 total=250000
13:24:27:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:24:27:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:24:27:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:24:27:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:24:27:WU00:FS00:0xa7:Completed 2341 out of 250000 steps (0%)
13:24:28:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:24:28:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:24:28:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:24:28:ERROR:WU01:FS01:Exception: Could not get an assignment
13:24:32:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
13:24:33:WU02:FS02:Downloading 21.64MiB
13:24:39:WU02:FS02:Download 92.99%
13:24:39:WU02:FS02:Download complete
13:24:39:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14907 run:278 clone:0 gen:44 core:0x22 unit:0x0000003181d59d695f52602f7cb219e4
13:24:39:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
13:24:39:WU02:FS02:Connecting to cores.foldingathome.org:80
13:24:39:WU02:FS02:FahCore 22: Downloading 77.67MiB
13:24:45:WU02:FS02:FahCore 22: 51.74%
13:24:49:WU02:FS02:FahCore 22: Download complete
13:24:49:WU02:FS02:Valid core signature
13:24:49:WU02:FS02:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
13:24:49:WU02:FS02:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
13:24:49:WU02:FS02:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
13:24:49:WU02:FS02:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
13:24:49:WU02:FS02:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
13:24:49:WU02:FS02:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
13:24:49:WU02:FS02:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
13:24:49:WU02:FS02:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
13:24:49:WU02:FS02:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
13:24:49:WU02:FS02:Starting
13:24:49:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
13:24:49:WU02:FS02:Started FahCore on PID 716
13:24:50:WU02:FS02:Core PID:12084
13:24:50:WU02:FS02:FahCore 0x22 started
13:24:51:WU02:FS02:0x22:*********************** Log Started 2020-09-30T13:24:50Z ***********************
13:24:51:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
13:24:51:WU02:FS02:0x22: Core: Core22
13:24:51:WU02:FS02:0x22: Type: 0x22
13:24:51:WU02:FS02:0x22: Version: 0.0.13
13:24:51:WU02:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:24:51:WU02:FS02:0x22: Copyright: 2020 foldingathome.org
13:24:51:WU02:FS02:0x22: Homepage: https://foldingathome.org/
13:24:51:WU02:FS02:0x22: Date: Sep 19 2020
13:24:51:WU02:FS02:0x22: Time: 02:35:58
13:24:51:WU02:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
13:24:51:WU02:FS02:0x22: Branch: core22-0.0.13
13:24:51:WU02:FS02:0x22: Compiler: Visual C++ 2015
13:24:51:WU02:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:24:51:WU02:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
13:24:51:WU02:FS02:0x22: Platform: win32 10
13:24:51:WU02:FS02:0x22: Bits: 64
13:24:51:WU02:FS02:0x22: Mode: Release
13:24:51:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:24:51:WU02:FS02:0x22: <peastman@stanford.edu>
13:24:51:WU02:FS02:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 716 -checkpoint 15
13:24:51:WU02:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
13:24:51:WU02:FS02:0x22:************************************ libFAH ************************************
13:24:51:WU02:FS02:0x22: Date: Sep 7 2020
13:24:51:WU02:FS02:0x22: Time: 19:09:56
13:24:51:WU02:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
13:24:51:WU02:FS02:0x22: Branch: HEAD
13:24:51:WU02:FS02:0x22:************************************ CBang *************************************
13:24:51:WU02:FS02:0x22: Time: 19:08:30
13:24:51:WU02:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
13:24:51:WU02:FS02:0x22:************************************ System ************************************
13:24:51:WU02:FS02:0x22: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
13:24:51:WU02:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:24:51:WU02:FS02:0x22: CPUs: 12
13:24:51:WU02:FS02:0x22: Memory: 63.76GiB
13:24:51:WU02:FS02:0x22:Free Memory: 58.35GiB
13:24:51:WU02:FS02:0x22: Threads: WINDOWS_THREADS
13:24:51:WU02:FS02:0x22: OS Version: 6.2
13:24:51:WU02:FS02:0x22:Has Battery: true
13:24:51:WU02:FS02:0x22: On Battery: false
13:24:51:WU02:FS02:0x22: UTC Offset: -4
13:24:51:WU02:FS02:0x22: PID: 12084
13:24:51:WU02:FS02:0x22: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
13:24:51:WU02:FS02:0x22:************************************ OpenMM ************************************
13:24:51:WU02:FS02:0x22: Revision: 189320d0
13:24:51:WU02:FS02:0x22:********************************************************************************
13:24:51:WU02:FS02:0x22:Project: 14907 (Run 278, Clone 0, Gen 44)
13:24:51:WU02:FS02:0x22:Unit: 0x0000003181d59d695f52602f7cb219e4
13:24:51:WU02:FS02:0x22:Reading tar file core.xml
13:24:51:WU02:FS02:0x22:Reading tar file integrator.xml
13:24:51:WU02:FS02:0x22:Reading tar file state.xml
13:24:51:WU02:FS02:0x22:Reading tar file system.xml
13:24:52:WU02:FS02:0x22:Digital signatures verified
13:24:52:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
13:24:52:WU02:FS02:0x22:Version 0.0.13
13:24:52:WU02:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
13:24:52:WU02:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:24:52:WU02:FS02:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
13:24:52:WU02:FS02:0x22: Global context and integrator variables write interval: disabled
13:24:52:WU02:FS02:0x22:There are 3 platforms available.
13:24:52:WU02:FS02:0x22:Platform 0: Reference
13:24:52:WU02:FS02:0x22:Platform 1: CPU
13:24:52:WU02:FS02:0x22:Platform 2: OpenCL
13:24:52:WU02:FS02:0x22: opencl-device 0 specified
13:24:57:Saving configuration to config.xml
13:24:57:<config>
13:24:57: <!-- Slot Control -->
13:24:57: <power v='medium'/>
13:24:57:
13:24:57: <!-- User Information -->
13:24:57: <passkey v='*****'/>
13:24:57: <team v='182116'/>
13:24:57: <user v='RBaillie'/>
13:24:57:
13:24:57: <!-- Folding Slots -->
13:24:57: <slot id='0' type='CPU'/>
13:24:57: <slot id='1' type='GPU'/>
13:24:57: <slot id='2' type='GPU'/>
13:24:57:</config>
13:25:04:WU02:FS02:0x22:Attempting to create OpenCL context:
13:25:04:WU02:FS02:0x22: Configuring platform OpenCL
13:25:23:WU02:FS02:0x22: Using OpenCL on platformId 1 and gpu 0
13:25:23:WU02:FS02:0x22:Completed 0 out of 1000000 steps (0%)
13:25:24:WU02:FS02:0x22:Checkpoint completed at step 0
13:25:27:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:25:27:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:25:27:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:25:27:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:25:27:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:25:28:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:25:28:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:25:28:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:25:28:ERROR:WU01:FS01:Exception: Could not get an assignment
13:26:18:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
13:27:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:27:04:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:27:04:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:27:05:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:27:05:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:27:05:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:27:05:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:27:05:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:27:05:ERROR:WU01:FS01:Exception: Could not get an assignment
13:28:06:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
13:28:15:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
13:29:41:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:29:42:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:29:42:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:29:42:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:29:42:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:29:42:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:29:42:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:29:42:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:29:42:ERROR:WU01:FS01:Exception: Could not get an assignment
13:30:08:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
13:32:09:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
13:33:56:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:33:56:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:33:56:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:33:56:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:33:56:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:33:56:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:33:56:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:33:57:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:33:57:ERROR:WU01:FS01:Exception: Could not get an assignment
13:34:04:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
13:35:59:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
13:38:00:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
13:40:18:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
13:40:47:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:40:47:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:40:47:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:40:47:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:40:47:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:40:48:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:40:48:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:40:48:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:40:48:ERROR:WU01:FS01:Exception: Could not get an assignment
13:42:29:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
13:44:29:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
13:46:23:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
13:48:18:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
13:50:21:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
13:51:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:51:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:51:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:51:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:51:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:51:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:51:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:51:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:51:54:ERROR:WU01:FS01:Exception: Could not get an assignment
13:52:23:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
13:54:18:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
13:56:25:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
13:57:03:WU02:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
13:58:31:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
14:00:40:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
14:02:41:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
14:04:38:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
14:06:44:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
14:08:43:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
14:09:49:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:09:49:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:09:49:WU01:FS01:Connecting to assign2.foldingathome.org:80
14:09:50:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:09:50:WU01:FS01:Connecting to assign3.foldingathome.org:80
14:09:50:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:09:50:WU01:FS01:Connecting to assign4.foldingathome.org:80
14:09:50:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:09:50:ERROR:WU01:FS01:Exception: Could not get an assignment
14:10:41:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
14:12:42:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
18:23:25:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
18:25:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:25:59:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:25:59:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:25:59:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:26:00:ERROR:WU01:FS01:Exception: Could not get an assignment
18:27:08:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
18:30:43:WU02:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
18:30:45:WU02:FS02:0x22:Checkpoint completed at step 850000
18:30:51:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
18:34:35:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
18:38:18:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
18:42:01:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
18:45:45:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
18:49:33:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
18:53:16:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
18:56:58:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
19:00:41:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
19:03:35:WU02:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
19:04:23:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
19:08:11:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
19:12:12:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
19:16:46:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
19:20:54:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
19:24:47:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
******************************* Date: 2020-10-02 *******************************
19:25:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:25:59:WU01:FS01:Connecting to assign2.foldingathome.org:80
19:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:25:59:WU01:FS01:Connecting to assign3.foldingathome.org:80
19:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:26:00:WU01:FS01:Connecting to assign4.foldingathome.org:80
19:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:26:00:ERROR:WU01:FS01:Exception: Could not get an assignment
19:28:41:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
19:32:30:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
19:36:13:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
19:37:41:WU02:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
19:39:55:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
19:40:16:FS00:Paused
19:40:16:FS00:Shutting core down
19:40:16:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 12588
19:40:16:WU00:FS00:0xa7:Exiting, please wait. . .
19:40:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:40:18:FS02:Paused
19:40:18:FS02:Shutting core down
19:40:19:WU02:FS02:0x22:WARNING:Console control signal 1 on PID 13932
19:40:19:WU02:FS02:0x22:Exiting, please wait. . .
19:40:19:WU02:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
19:40:19:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
19:40:22:Saving configuration to config.xml
19:40:22:<config>
19:40:22: <!-- Slot Control -->
19:40:22: <power v='full'/>
19:40:22:
19:40:22: <!-- User Information -->
19:40:22: <passkey v='*****'/>
19:40:22: <team v='182116'/>
19:40:22: <user v='RBaillie'/>
19:40:22:
19:40:22: <!-- Folding Slots -->
19:40:22: <slot id='0' type='CPU'>
19:40:22: <paused v='true'/>
19:40:22: </slot>
19:40:22: <slot id='1' type='GPU'/>
19:40:22: <slot id='2' type='GPU'>
19:40:22: </slot>
19:40:22:</config>
19:40:45:FS02:Unpaused
19:40:45:WU02:FS02:Starting
19:40:45:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
19:40:45:WU02:FS02:Started FahCore on PID 22716
19:40:45:WU02:FS02:Core PID:21604
19:40:45:WU02:FS02:FahCore 0x22 started
19:40:46:WU02:FS02:0x22:*********************** Log Started 2020-10-02T19:40:45Z ***********************
19:40:46:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:40:46:WU02:FS02:0x22: Core: Core22
19:40:46:WU02:FS02:0x22: Type: 0x22
19:40:46:WU02:FS02:0x22: Version: 0.0.13
19:40:46:WU02:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:40:46:WU02:FS02:0x22: Copyright: 2020 foldingathome.org
19:40:46:WU02:FS02:0x22: Homepage: https://foldingathome.org/
19:40:46:WU02:FS02:0x22: Date: Sep 19 2020
19:40:46:WU02:FS02:0x22: Time: 02:35:58
19:40:46:WU02:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:40:46:WU02:FS02:0x22: Branch: core22-0.0.13
19:40:46:WU02:FS02:0x22: Compiler: Visual C++ 2015
19:40:46:WU02:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:40:46:WU02:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
19:40:46:WU02:FS02:0x22: Platform: win32 10
19:40:46:WU02:FS02:0x22: Bits: 64
19:40:46:WU02:FS02:0x22: Mode: Release
19:40:46:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:40:46:WU02:FS02:0x22: <peastman@stanford.edu>
19:40:46:WU02:FS02:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 22716 -checkpoint 15
19:40:46:WU02:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
19:40:46:WU02:FS02:0x22:************************************ libFAH ************************************
19:40:46:WU02:FS02:0x22: Date: Sep 7 2020
19:40:46:WU02:FS02:0x22: Time: 19:09:56
19:40:46:WU02:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:40:46:WU02:FS02:0x22: Branch: HEAD
19:40:46:WU02:FS02:0x22:************************************ CBang *************************************
19:40:46:WU02:FS02:0x22: Time: 19:08:30
19:40:46:WU02:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:40:46:WU02:FS02:0x22:************************************ System ************************************
19:40:46:WU02:FS02:0x22: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
19:40:46:WU02:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:40:46:WU02:FS02:0x22: CPUs: 12
19:40:46:WU02:FS02:0x22: Memory: 63.76GiB
19:40:46:WU02:FS02:0x22:Free Memory: 56.87GiB
19:40:46:WU02:FS02:0x22: Threads: WINDOWS_THREADS
19:40:46:WU02:FS02:0x22: OS Version: 6.2
19:40:46:WU02:FS02:0x22:Has Battery: true
19:40:46:WU02:FS02:0x22: On Battery: false
19:40:46:WU02:FS02:0x22: UTC Offset: -4
19:40:46:WU02:FS02:0x22: PID: 21604
19:40:46:WU02:FS02:0x22: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
19:40:46:WU02:FS02:0x22:************************************ OpenMM ************************************
19:40:46:WU02:FS02:0x22: Revision: 189320d0
19:40:46:WU02:FS02:0x22:********************************************************************************
19:40:46:WU02:FS02:0x22:Project: 14907 (Run 278, Clone 0, Gen 44)
19:40:46:WU02:FS02:0x22:Unit: 0x0000003181d59d695f52602f7cb219e4
19:40:46:WU02:FS02:0x22:Digital signatures verified
19:40:46:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:40:46:WU02:FS02:0x22:Version 0.0.13
19:40:46:WU02:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
19:40:46:WU02:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:40:46:WU02:FS02:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
19:40:46:WU02:FS02:0x22: Global context and integrator variables write interval: disabled
19:40:46:WU02:FS02:0x22:There are 3 platforms available.
19:40:46:WU02:FS02:0x22:Platform 0: Reference
19:40:46:WU02:FS02:0x22:Platform 1: CPU
19:40:46:WU02:FS02:0x22:Platform 2: OpenCL
19:40:46:WU02:FS02:0x22: opencl-device 0 specified
19:40:55:WU02:FS02:0x22:Attempting to create OpenCL context:
19:40:55:WU02:FS02:0x22: Configuring platform OpenCL
19:41:09:WU02:FS02:0x22: Using OpenCL on platformId 1 and gpu 0
19:41:10:WU02:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
19:41:23:Saving configuration to config.xml
19:41:23:<config>
19:41:23: <!-- Slot Control -->
19:41:23: <power v='full'/>
19:41:23:
19:41:23: <!-- User Information -->
19:41:23: <passkey v='*****'/>
19:41:23: <team v='182116'/>
19:41:23: <user v='RBaillie'/>
19:41:23:
19:41:23: <!-- Folding Slots -->
19:41:23: <slot id='0' type='CPU'>
19:41:23: <paused v='true'/>
19:41:23: </slot>
19:41:23: <slot id='1' type='GPU'/>
19:41:23: <slot id='2' type='GPU'/>
19:41:23:</config>
19:41:24:FS02:Paused
19:41:24:FS02:Shutting core down
19:41:24:WU02:FS02:0x22:WARNING:Console control signal 1 on PID 21604
19:41:24:WU02:FS02:0x22:Exiting, please wait. . .
19:41:25:WU02:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
19:41:25:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
19:42:24:Saving configuration to config.xml
19:42:24:<config>
19:42:24: <!-- Slot Control -->
19:42:24: <power v='full'/>
19:42:24:
19:42:24: <!-- User Information -->
19:42:24: <passkey v='*****'/>
19:42:24: <team v='182116'/>
19:42:24: <user v='RBaillie'/>
19:42:24:
19:42:24: <!-- Folding Slots -->
19:42:24: <slot id='0' type='CPU'>
19:42:24: <paused v='true'/>
19:42:24: </slot>
19:42:24: <slot id='1' type='GPU'/>
19:42:24: <slot id='2' type='GPU'>
19:42:24: </slot>
19:42:24:</config>
20:25:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:25:59:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
20:25:59:WU01:FS01:Connecting to assign2.foldingathome.org:80
20:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
20:26:00:WU01:FS01:Connecting to assign3.foldingathome.org:80
20:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
20:26:00:WU01:FS01:Connecting to assign4.foldingathome.org:80
20:26:00:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
20:26:00:ERROR:WU01:FS01:Exception: Could not get an assignment
20:57:19:FS00:Unpaused
20:57:19:WU00:FS00:Starting
20:57:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -np 10
20:57:19:WU00:FS00:Started FahCore on PID 21932
20:57:19:WU00:FS00:Core PID:18476
20:57:19:WU00:FS00:FahCore 0xa7 started
20:57:19:WU00:FS00:0xa7:*********************** Log Started 2020-10-02T20:57:19Z ***********************
20:57:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:57:19:WU00:FS00:0xa7: Type: 0xa7
20:57:19:WU00:FS00:0xa7: Core: Gromacs
20:57:19:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 21932 -checkpoint 15 -np
20:57:19:WU00:FS00:0xa7: 10
20:57:19:WU00:FS00:0xa7:************************************ CBang *************************************
20:57:19:WU00:FS00:0xa7: Date: Nov 27 2019
20:57:19:WU00:FS00:0xa7: Time: 03:40:09
20:57:19:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:57:19:WU00:FS00:0xa7: Branch: master
20:57:19:WU00:FS00:0xa7: Compiler: Visual C++ 2008
20:57:19:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:57:19:WU00:FS00:0xa7: Platform: win32 10
20:57:19:WU00:FS00:0xa7: Bits: 64
20:57:19:WU00:FS00:0xa7: Mode: Release
20:57:19:WU00:FS00:0xa7:************************************ System ************************************
20:57:19:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
20:57:19:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:57:19:WU00:FS00:0xa7: CPUs: 12
20:57:19:WU00:FS00:0xa7: Memory: 63.76GiB
20:57:19:WU00:FS00:0xa7:Free Memory: 56.13GiB
20:57:19:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
20:57:19:WU00:FS00:0xa7: OS Version: 6.2
20:57:19:WU00:FS00:0xa7:Has Battery: true
20:57:19:WU00:FS00:0xa7: On Battery: false
20:57:19:WU00:FS00:0xa7: UTC Offset: -4
20:57:19:WU00:FS00:0xa7: PID: 18476
20:57:19:WU00:FS00:0xa7: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
20:57:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:57:19:WU00:FS00:0xa7: Version: 0.0.19
20:57:19:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:57:19:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
20:57:19:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
20:57:19:WU00:FS00:0xa7: Date: Nov 25 2019
20:57:19:WU00:FS00:0xa7: Time: 17:12:41
20:57:19:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:57:19:WU00:FS00:0xa7:************************************ Build *************************************
20:57:19:WU00:FS00:0xa7: SIMD: avx_256
20:57:19:WU00:FS00:0xa7:********************************************************************************
20:57:19:WU00:FS00:0xa7:Project: 16804 (Run 6, Clone 460, Gen 38)
20:57:19:WU00:FS00:0xa7:Unit: 0x0000002f82ed0b915e9df5d67670a418
20:57:19:WU00:FS00:0xa7:Digital signatures verified
20:57:19:WU00:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
20:57:19:WU00:FS00:0xa7:Steps: first=19000000 total=500000
20:57:21:WU00:FS00:0xa7:Completed 420437 out of 500000 steps (84%)
20:57:24:FS02:Unpaused
20:57:24:WU02:FS02:Starting
20:57:24:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 18232 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
20:57:24:WU02:FS02:Started FahCore on PID 21568
20:57:24:WU02:FS02:Core PID:23348
20:57:24:WU02:FS02:FahCore 0x22 started
20:57:24:WU02:FS02:0x22:*********************** Log Started 2020-10-02T20:57:24Z ***********************
20:57:24:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
20:57:24:WU02:FS02:0x22: Core: Core22
20:57:24:WU02:FS02:0x22: Type: 0x22
20:57:24:WU02:FS02:0x22: Version: 0.0.13
20:57:24:WU02:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:57:24:WU02:FS02:0x22: Copyright: 2020 foldingathome.org
20:57:24:WU02:FS02:0x22: Homepage: https://foldingathome.org/
20:57:24:WU02:FS02:0x22: Date: Sep 19 2020
20:57:24:WU02:FS02:0x22: Time: 02:35:58
20:57:24:WU02:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:57:24:WU02:FS02:0x22: Branch: core22-0.0.13
20:57:24:WU02:FS02:0x22: Compiler: Visual C++ 2015
20:57:24:WU02:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:57:24:WU02:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
20:57:24:WU02:FS02:0x22: Platform: win32 10
20:57:24:WU02:FS02:0x22: Bits: 64
20:57:24:WU02:FS02:0x22: Mode: Release
20:57:24:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:57:24:WU02:FS02:0x22: <peastman@stanford.edu>
20:57:24:WU02:FS02:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 21568 -checkpoint 15
20:57:24:WU02:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
20:57:24:WU02:FS02:0x22:************************************ libFAH ************************************
20:57:24:WU02:FS02:0x22: Date: Sep 7 2020
20:57:24:WU02:FS02:0x22: Time: 19:09:56
20:57:24:WU02:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:57:24:WU02:FS02:0x22: Branch: HEAD
20:57:24:WU02:FS02:0x22:************************************ CBang *************************************
20:57:24:WU02:FS02:0x22: Time: 19:08:30
20:57:24:WU02:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:57:24:WU02:FS02:0x22:************************************ System ************************************
20:57:24:WU02:FS02:0x22: CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
20:57:24:WU02:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:57:24:WU02:FS02:0x22: CPUs: 12
20:57:24:WU02:FS02:0x22: Memory: 63.76GiB
20:57:24:WU02:FS02:0x22:Free Memory: 56.01GiB
20:57:24:WU02:FS02:0x22: Threads: WINDOWS_THREADS
20:57:24:WU02:FS02:0x22: OS Version: 6.2
20:57:24:WU02:FS02:0x22:Has Battery: true
20:57:24:WU02:FS02:0x22: On Battery: false
20:57:24:WU02:FS02:0x22: UTC Offset: -4
20:57:24:WU02:FS02:0x22: PID: 23348
20:57:24:WU02:FS02:0x22: CWD: C:\Users\bobba\AppData\Roaming\FAHClient\work
20:57:24:WU02:FS02:0x22:************************************ OpenMM ************************************
20:57:24:WU02:FS02:0x22: Revision: 189320d0
20:57:24:WU02:FS02:0x22:********************************************************************************
20:57:24:WU02:FS02:0x22:Project: 14907 (Run 278, Clone 0, Gen 44)
20:57:24:WU02:FS02:0x22:Unit: 0x0000003181d59d695f52602f7cb219e4
20:57:24:WU02:FS02:0x22:Digital signatures verified
20:57:24:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
20:57:24:WU02:FS02:0x22:Version 0.0.13
20:57:24:WU02:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
20:57:24:WU02:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:57:24:WU02:FS02:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
20:57:24:WU02:FS02:0x22: Global context and integrator variables write interval: disabled
20:57:24:WU02:FS02:0x22:There are 3 platforms available.
20:57:24:WU02:FS02:0x22:Platform 0: Reference
20:57:24:WU02:FS02:0x22:Platform 1: CPU
20:57:24:WU02:FS02:0x22:Platform 2: OpenCL
20:57:24:WU02:FS02:0x22: opencl-device 0 specified
20:57:38:Saving configuration to config.xml
20:57:38:<config>
20:57:38: <!-- Slot Control -->
20:57:38: <power v='full'/>
20:57:38:
20:57:38: <!-- User Information -->
20:57:38: <passkey v='*****'/>
20:57:38: <team v='182116'/>
20:57:38: <user v='RBaillie'/>
20:57:38:
20:57:38: <!-- Folding Slots -->
20:57:38: <slot id='0' type='CPU'/>
20:57:38: <slot id='1' type='GPU'/>
20:57:38: <slot id='2' type='GPU'/>
20:57:38:</config>
20:57:38:ERROR:Receive error: 10053: An established connection
was aborted by the software in your host machine.
20:57:44:WU02:FS02:0x22:Attempting to create OpenCL context:
20:57:44:WU02:FS02:0x22: Configuring platform OpenCL
20:58:12:WU02:FS02:0x22: Using OpenCL on platformId 1 and gpu 0
20:58:13:WU02:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
Re: FAH using the wrong GPU card?
Seeing your log shows that you have encountered a known configuration issue in the current client. It arises from a few Intel iGPUs being enabled for the internal testers to use and check on how well they work and fix any bugs in the folding core code. Your system will not get any WUs assigned for the Intel UHD Graphics, the slot needs to remain but paused.
Adding the parameter pause-on-start set to true for the GPU slot will keep it paused and not requesting WUs.
From your log the AMD card looks to be working just fine.
More on this issue with the Intel iGPUs was written up in this topic - viewtopic.php?f=61&t=35568, and a few others.
