[2020-09-30] No WUs available for this configuration [macOS]
belloq
Post by belloq »
Hello,
One of my Catalina systems finished previous WU and now has been unable to get a new WU for hours.
3 GHz Dual-Core Intel Core i7
MacOS 10.15.7 (19H2)
Cause preference Any
*********************** Log Started 2020-09-30T16:49:13Z ***********************
16:49:13:Trying to access database...
16:49:13:Successfully acquired database lock
16:49:13:Read GPUs.txt
16:49:13:Enabled folding slot 00: READY cpu:4
16:49:13:****************************** FAHClient ******************************
16:49:13:    Version: 7.6.13
16:49:13:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:49:13:  Copyright: 2020 foldingathome.org
16:49:13:   Homepage: https://foldingathome.org/
16:49:13:       Date: Apr 27 2020
16:49:13:       Time: 21:20:45
16:49:13:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:49:13:     Branch: master
16:49:13:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:49:13:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:49:13:             -Wno-unused-local-typedefs -stdlib=libc++
16:49:13:   Platform: darwin 19.2.0
16:49:13:       Bits: 64
16:49:13:       Mode: Release
16:49:13:     Config: /Library/Application Support/FAHClient/config.xml
16:49:13:******************************** CBang ********************************
16:49:13:       Date: Apr 24 2020
16:49:13:       Time: 17:07:50
16:49:13:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:49:13:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:49:13:       Bits: 64
16:49:13:******************************* System ********************************
16:49:13:        CPU: Intel(R) Core(TM) i7-4578U CPU @ 3.00GHz
16:49:13:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
16:49:13:       CPUs: 4
16:49:13:     Memory: 16.00GiB
16:49:13:Free Memory: 4.75GiB
16:49:13:    Threads: POSIX_THREADS
16:49:13: OS Version: 10.15
16:49:13:Has Battery: false
16:49:13: On Battery: false
16:49:13: UTC Offset: -7
16:49:13:        PID: 19679
16:49:13:        CWD: /Library/Application Support/FAHClient
16:49:13:         OS: Darwin 19.6.0 x86_64
16:49:13:    OS Arch: AMD64
16:49:13:       GPUs: 0
16:49:13:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
16:49:13:             dlopen(libcuda.dylib, 1): image not found
16:49:13:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
16:49:13:             dlopen(libOpenCL.dylib, 1): image not found
16:49:13:******************************* libFAH ********************************
16:49:13:       Date: Apr 15 2020
16:49:13:       Time: 14:43:28
16:49:13:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:49:13:       Bits: 64
16:49:13:***********************************************************************
16:49:13:<config>
16:49:13:  <!-- HTTP Server -->
16:49:13:  <allow v='127.0.0.1,10.10.10.130'/>
16:49:13:
16:49:13:  <!-- Network -->
16:49:13:  <proxy v=':8080'/>
16:49:13:
16:49:13:  <!-- Remote Command Server -->
16:49:13:  <command-allow-no-pass v='127.0.0.1,10.10.10.130'/>
16:49:13:
16:49:13:  <!-- Slot Control -->
16:49:13:  <power v='full'/>
16:49:13:
16:49:13:  <!-- User Information -->
16:49:13:  <team v='259998'/>
16:49:13:  <user v='belloq'/>
16:49:13:
16:49:13:  <!-- Folding Slots -->
16:49:13:  <slot id='0' type='CPU'/>
16:49:13:</config>
16:49:13:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:49:14:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:49:14:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:49:15:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:49:15:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:49:16:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:49:16:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:49:18:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:49:18:ERROR:WU00:FS00:Exception: Could not get an assignment
16:49:18:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:49:20:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:49:20:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:49:20:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:49:20:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:49:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:49:21:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:49:23:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:49:23:ERROR:WU00:FS00:Exception: Could not get an assignment
16:50:19:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:50:19:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:50:19:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:50:19:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:50:19:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:50:19:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:50:19:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:50:20:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:50:20:ERROR:WU00:FS00:Exception: Could not get an assignment
16:50:29:18:127.0.0.1:New Web session
16:51:56:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:51:56:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:51:56:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:51:56:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:51:56:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:51:57:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:51:57:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:51:57:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:51:57:ERROR:WU00:FS00:Exception: Could not get an assignment
16:54:33:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:54:34:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:54:34:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:54:35:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:54:35:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:54:35:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:54:35:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:54:35:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:54:35:ERROR:WU00:FS00:Exception: Could not get an assignment
Is anyone else stuck waiting?
belloq
Re: [2020-09-30] No WUs available for this configuration
Post by belloq »
Just had another client get stuck waiting too.
03:48:33:WU01:FS00:0xa7:*********************** Log Started 2020-09-30T03:48:32Z ***********************
03:48:33:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:48:33:WU01:FS00:0xa7:       Type: 0xa7
03:48:33:WU01:FS00:0xa7:       Core: Gromacs
03:48:33:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 564 -checkpoint 15 -np 2
03:48:33:WU01:FS00:0xa7:************************************ CBang *************************************
03:48:33:WU01:FS00:0xa7:       Date: Nov 27 2019
03:48:33:WU01:FS00:0xa7:       Time: 03:26:57
03:48:33:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:48:33:WU01:FS00:0xa7:     Branch: master
03:48:33:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
03:48:33:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
03:48:33:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
03:48:33:WU01:FS00:0xa7:   Platform: darwin 19.0.0
03:48:33:WU01:FS00:0xa7:       Bits: 64
03:48:33:WU01:FS00:0xa7:       Mode: Release
03:48:33:WU01:FS00:0xa7:************************************ System ************************************
03:48:33:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM)2 Duo CPU E8435 @ 3.06GHz
03:48:33:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
03:48:33:WU01:FS00:0xa7:       CPUs: 2
03:48:33:WU01:FS00:0xa7:     Memory: 4.00GiB
03:48:33:WU01:FS00:0xa7:Free Memory: 2.01GiB
03:48:33:WU01:FS00:0xa7:    Threads: POSIX_THREADS
03:48:33:WU01:FS00:0xa7: OS Version: 10.11
03:48:33:WU01:FS00:0xa7:Has Battery: false
03:48:33:WU01:FS00:0xa7: On Battery: false
03:48:33:WU01:FS00:0xa7: UTC Offset: -7
03:48:33:WU01:FS00:0xa7:        PID: 565
03:48:33:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
03:48:33:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:48:33:WU01:FS00:0xa7:    Version: 0.0.19
03:48:33:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:48:33:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:48:33:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:48:33:WU01:FS00:0xa7:       Date: Nov 25 2019
03:48:33:WU01:FS00:0xa7:       Time: 16:45:06
03:48:33:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:48:33:WU01:FS00:0xa7:************************************ Build *************************************
03:48:33:WU01:FS00:0xa7:       SIMD: sse2
03:48:33:WU01:FS00:0xa7:********************************************************************************
03:48:33:WU01:FS00:0xa7:Project: 13824 (Run 123, Clone 3, Gen 162)
03:48:33:WU01:FS00:0xa7:Unit: 0x000000b780fccb095c9249cfd9e2d2b5
03:48:33:WU01:FS00:0xa7:Reading tar file core.xml
03:48:33:WU01:FS00:0xa7:Reading tar file frame162.tpr
03:48:33:WU01:FS00:0xa7:Digital signatures verified
03:48:33:WU01:FS00:0xa7:Calling: mdrun -s frame162.tpr -o frame162.trr -x frame162.xtc -cpt 15 -nt 2
03:48:33:WU01:FS00:0xa7:Steps: first=20250000 total=125000
03:48:38:WU00:FS00:Upload 8.58%
03:48:43:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
03:48:44:WU00:FS00:Upload 14.05%
03:48:50:WU00:FS00:Upload 19.51%
03:48:56:WU00:FS00:Upload 32.78%
03:49:02:WU00:FS00:Upload 36.68%
03:49:08:WU00:FS00:Upload 41.36%
03:49:14:WU00:FS00:Upload 46.05%
03:49:21:WU00:FS00:Upload 53.07%
03:49:27:WU00:FS00:Upload 59.31%
03:49:33:WU00:FS00:Upload 66.34%
03:49:39:WU00:FS00:Upload 71.80%
03:49:46:WU00:FS00:Upload 81.17%
03:49:52:WU00:FS00:Upload 86.63%
03:49:58:WU00:FS00:Upload 92.87%
03:50:01:WU00:FS00:Upload complete
03:50:01:WU00:FS00:Server responded WORK_ACK (400)
03:50:01:WU00:FS00:Final credit estimate, 5256.00 points
03:50:01:WU00:FS00:Cleaning up
03:56:28:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
04:04:22:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
04:12:08:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
04:20:01:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
******************************* Date: 2020-09-30 *******************************
04:27:47:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
04:35:40:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
04:43:26:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
04:51:18:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
04:59:04:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
05:06:57:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
05:14:52:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
05:22:45:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
05:30:30:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
05:38:24:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
05:46:10:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
05:54:03:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
06:01:49:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
06:09:42:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
06:17:27:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
06:25:21:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
06:33:06:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
06:40:59:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
06:48:52:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
06:56:38:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
07:04:30:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
07:12:16:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
07:20:14:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
07:27:59:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
07:35:53:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
07:43:38:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
07:51:32:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
07:59:18:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
08:07:11:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
08:14:56:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
08:22:49:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
08:30:35:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
08:38:28:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
08:46:13:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
08:54:06:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
09:01:52:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
09:09:44:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
09:17:31:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
09:25:23:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
09:33:09:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
09:41:03:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
09:48:55:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
09:56:41:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
10:04:34:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
10:12:20:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
10:20:13:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
10:27:58:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
10:35:51:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
10:43:36:WU01:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
10:51:29:WU01:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
10:59:14:WU01:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
11:07:07:WU01:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
11:15:01:WU01:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
11:22:54:WU01:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
11:30:40:WU01:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
11:38:32:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
11:46:18:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
11:54:11:WU01:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
12:01:56:WU01:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
12:09:49:WU01:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
12:17:34:WU01:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
12:25:27:WU01:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
12:33:12:WU01:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
12:41:05:WU01:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
12:48:58:WU01:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
12:56:42:WU01:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
13:04:35:WU01:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
13:12:21:WU01:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
13:20:14:WU01:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
13:28:00:WU01:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
13:35:52:WU01:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
13:43:37:WU01:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
13:51:30:WU01:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
13:59:15:WU01:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
14:07:08:WU01:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
14:14:53:WU01:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
14:22:47:WU01:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
14:30:32:WU01:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
14:38:25:WU01:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
14:46:10:WU01:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
14:54:02:WU01:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
15:01:48:WU01:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
15:09:40:WU01:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
15:17:25:WU01:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
15:25:18:WU01:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
15:33:03:WU01:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
15:40:56:WU01:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
15:48:49:WU01:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
15:56:34:WU01:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
16:04:27:WU01:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
16:12:12:WU01:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
16:20:05:WU01:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
16:27:51:WU01:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
16:35:44:WU01:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
16:43:29:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
16:43:30:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:43:32:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:43:32:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:43:32:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:43:32:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:43:33:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:43:33:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:43:34:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:43:34:ERROR:WU00:FS00:Exception: Could not get an assignment
16:43:34:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:43:35:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:43:35:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:43:37:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:43:37:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:43:39:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:43:39:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:43:41:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:43:41:ERROR:WU00:FS00:Exception: Could not get an assignment
16:44:34:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:44:38:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:44:38:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:44:39:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:44:39:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:44:40:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:44:40:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:44:45:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:44:45:ERROR:WU00:FS00:Exception: Could not get an assignment
16:46:12:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:46:15:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:46:15:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:46:15:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:46:15:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:46:16:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:46:16:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:46:16:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:46:16:ERROR:WU00:FS00:Exception: Could not get an assignment
16:48:49:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:48:50:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:48:50:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:48:50:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:48:50:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:48:51:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:48:51:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:48:51:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:48:51:ERROR:WU00:FS00:Exception: Could not get an assignment
16:51:22:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
16:51:41:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
16:51:41:WU01:FS00:0xa7:Saving result file frame162.trr
16:51:41:WU01:FS00:0xa7:Saving result file frame162.xtc
16:51:41:WU01:FS00:0xa7:Saving result file md.log
16:51:41:WU01:FS00:0xa7:Saving result file science.log
16:51:41:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
16:51:42:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:51:42:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13824 run:123 clone:3 gen:162 core:0xa7 unit:0x000000b780fccb095c9249cfd9e2d2b5
16:51:42:WU01:FS00:Uploading 11.29MiB to 128.252.203.9
16:51:42:WU01:FS00:Connecting to 128.252.203.9:8080
16:51:48:WU01:FS00:Upload 2.77%
16:51:55:WU01:FS00:Upload 10.52%
16:52:01:WU01:FS00:Upload 14.39%
16:52:07:WU01:FS00:Upload 27.68%
16:52:13:WU01:FS00:Upload 33.76%
16:52:19:WU01:FS00:Upload 42.62%
16:52:25:WU01:FS00:Upload 44.28%
16:52:31:WU01:FS00:Upload 48.71%
16:52:37:WU01:FS00:Upload 56.46%
16:52:43:WU01:FS00:Upload 63.10%
16:52:50:WU01:FS00:Upload 66.42%
16:52:56:WU01:FS00:Upload 70.85%
16:53:02:WU01:FS00:Upload 78.60%
16:53:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:53:05:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:53:05:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:53:06:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:53:06:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:53:07:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:53:07:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:53:07:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:53:07:ERROR:WU00:FS00:Exception: Could not get an assignment
16:53:08:WU01:FS00:Upload 85.79%
16:53:16:WU01:FS00:Upload 97.97%
16:53:24:WU01:FS00:Upload 100.00%
16:53:27:WU01:FS00:Upload complete
16:53:28:WU01:FS00:Server responded WORK_ACK (400)
16:53:28:WU01:FS00:Final credit estimate, 2774.00 points
16:53:28:WU01:FS00:Cleaning up
Every so often I will have a system have to wait for a WU. The CPU projects are available, but either a server is too busy to take another download connection, or the type of WU is not a match for the system requesting.
This should improve over the next couple of weeks. There are a number of new servers in the process of being integrated into the network and setup to assign work. They are replacing older machines and donated servers that are returning to their original usages.
