It said bad work unit but i thought it would just return that and get another. I tried to refresh it by removing the slot, but this morning I have the same problem.
I noticed on the log for yesterday it unpacked new stuff to the cores folder, and it's since then I've had a problem. I can't seem to fix it. What should I do? Thanks for your help.
*********************** Log Started 2020-09-28T09:01:55Z ***********************
09:01:55:************************* Folding@home Client *************************
09:01:55: Website: https://foldingathome.org/
09:01:55: Copyright: (c) 2009-2018 foldingathome.org
09:01:55: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:01:55: Args:
09:01:55: Config: D:\Folding\data\config.xml
09:01:55:******************************** Build ********************************
09:01:55: Version: 7.5.1
09:01:55: Date: May 11 2018
09:01:55: Time: 13:06:32
09:01:55: Repository: Git
09:01:55: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:01:55: Branch: master
09:01:55: Compiler: Visual C++ 2008
09:01:55: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:01:55: Platform: win32 10
09:01:55: Bits: 32
09:01:55: Mode: Release
09:01:55:******************************* System ********************************
09:01:55: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
09:01:55: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:01:55: CPUs: 12
09:01:55: Memory: 15.94GiB
09:01:55: Free Memory: 13.06GiB
09:01:55: Threads: WINDOWS_THREADS
09:01:55: OS Version: 6.2
09:01:55: Has Battery: false
09:01:55: On Battery: false
09:01:55: UTC Offset: 1
09:01:55: PID: 9400
09:01:55: CWD: D:\Folding\data
09:01:55: OS: Windows 10 Enterprise
09:01:55: OS Arch: AMD64
09:01:55: GPUs: 1
09:01:55: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 SUPER]
09:01:55: 8218
09:01:55: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
09:01:55:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:451.67
09:01:55: Win32 Service: false
09:01:55:***********************************************************************
09:01:55:<config>
09:01:55: <!-- Network -->
09:01:55: <proxy v=':8080'/>
09:01:55:
09:01:55: <!-- User Information -->
09:01:55: <passkey v='********************************'/>
09:01:55: <team v='#######'/>
09:01:55: <user v='########/>
09:01:55:
09:01:55: <!-- Folding Slots -->
09:01:55: <slot id='1' type='GPU'>
09:01:55: <paused v='true'/>
09:01:55: </slot>
09:01:55:</config>
09:01:55:Trying to access database...
09:01:55:Successfully acquired database lock
09:01:55:Enabled folding slot 01: PAUSED gpu:0:TU104 [GeForce RTX 2070 SUPER] 8218 (by user)
09:02:12:FS01:Unpaused
09:02:12:WU00:FS01:Connecting to 65.254.110.245:8080
09:02:13:WU00:FS01:Assigned to work server 155.247.166.220
09:02:13:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 SUPER] 8218 from 155.247.166.220
09:02:13:WU00:FS01:Connecting to 155.247.166.220:8080
09:02:15:WU00:FS01:Downloading 28.18MiB
09:02:21:WU00:FS01:Download 30.61%
09:02:27:WU00:FS01:Download 59.45%
09:02:33:WU00:FS01:Download 84.29%
09:02:36:WU00:FS01:Download complete
09:02:36:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16918 run:92 clone:24 gen:89 core:0x22 unit:0x000000800002894c5f1761955d2f624d
09:02:36:WU00:FS01:Starting
09:02:36:WU00:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\data\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:02:36:WU00:FS01:Started FahCore on PID 10124
09:02:36:WU00:FS01:Core PID:1496
09:02:36:WU00:FS01:FahCore 0x22 started
09:02:37:WU00:FS01:0x22:*********************** Log Started 2020-09-28T09:02:37Z ***********************
09:02:37:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:02:37:WU00:FS01:0x22: Core: Core22
09:02:37:WU00:FS01:0x22: Type: 0x22
09:02:37:WU00:FS01:0x22: Version: 0.0.11
09:02:37:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:37:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
09:02:37:WU00:FS01:0x22: Homepage: https://foldingathome.org/
09:02:37:WU00:FS01:0x22: Date: Jun 26 2020
09:02:37:WU00:FS01:0x22: Time: 19:49:16
09:02:37:WU00:FS01:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
09:02:37:WU00:FS01:0x22: Branch: core22-0.0.11
09:02:37:WU00:FS01:0x22: Compiler: Visual C++ 2015
09:02:37:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:02:37:WU00:FS01:0x22: Platform: win32 10
09:02:37:WU00:FS01:0x22: Bits: 64
09:02:37:WU00:FS01:0x22: Mode: Release
09:02:37:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:02:37:WU00:FS01:0x22: <peastman@stanford.edu>
09:02:37:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 10124 -checkpoint 15
09:02:37:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:02:37:WU00:FS01:0x22: 0 -gpu 0
09:02:37:WU00:FS01:0x22:************************************ libFAH ************************************
09:02:37:WU00:FS01:0x22: Time: 19:47:12
09:02:37:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
09:02:37:WU00:FS01:0x22: Branch: HEAD
09:02:37:WU00:FS01:0x22:************************************ CBang *************************************
09:02:37:WU00:FS01:0x22: Time: 19:46:11
09:02:37:WU00:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
09:02:37:WU00:FS01:0x22: Branch: master
09:02:37:WU00:FS01:0x22:************************************ System ************************************
09:02:37:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
09:02:37:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:02:37:WU00:FS01:0x22: CPUs: 12
09:02:37:WU00:FS01:0x22: Memory: 15.94GiB
09:02:37:WU00:FS01:0x22:Free Memory: 12.47GiB
09:02:37:WU00:FS01:0x22: Threads: WINDOWS_THREADS
09:02:37:WU00:FS01:0x22: OS Version: 6.2
09:02:37:WU00:FS01:0x22:Has Battery: false
09:02:37:WU00:FS01:0x22: On Battery: false
09:02:37:WU00:FS01:0x22: UTC Offset: 1
09:02:37:WU00:FS01:0x22: PID: 1496
09:02:37:WU00:FS01:0x22: CWD: D:\Folding\data\work
09:02:37:WU00:FS01:0x22:********************************************************************************
09:02:37:WU00:FS01:0x22:Project: 16918 (Run 92, Clone 24, Gen 89)
09:02:37:WU00:FS01:0x22:Unit: 0x000000800002894c5f1761955d2f624d
09:02:37:WU00:FS01:0x22:Reading tar file core.xml
09:02:37:WU00:FS01:0x22:Reading tar file integrator.xml
09:02:37:WU00:FS01:0x22:Reading tar file state.xml
09:02:37:WU00:FS01:0x22:Reading tar file system.xml
09:02:37:WU00:FS01:0x22:Digital signatures verified
09:02:37:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:02:37:WU00:FS01:0x22:Version 0.0.11
09:02:38:WU00:FS01:0x22: Checkpoint write interval: 100000 steps (2%) [50 total]
09:02:38:WU00:FS01:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
09:02:38:WU00:FS01:0x22: XTC frame write interval: 250000 steps (5%) [20 total]
09:02:38:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
09:02:43:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
09:02:56:Removing old file 'configs/config-20200915-091925.xml'
09:02:56:Saving configuration to config.xml
09:02:56:<config>
09:02:56: <!-- Network -->
09:02:56: <proxy v=':8080'/>
09:02:56:
09:02:56: <!-- User Information -->
09:02:56: <passkey v='********************************'/>
09:02:56: <team v='######'/>
09:02:56: <user v='######'/>
09:02:56:
09:02:56: <!-- Folding Slots -->
09:02:56: <slot id='1' type='GPU'/>
09:02:56:</config>
09:04:15:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
TRIMMED
11:42:28:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
11:42:28:WU01:FS01:Connecting to 65.254.110.245:8080
11:42:28:WU01:FS01:Assigned to work server 128.252.203.9
11:42:28:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104 [GeForce RTX 2070 SUPER] 8218 from 128.252.203.9
11:42:28:WU01:FS01:Connecting to 128.252.203.9:8080
11:42:30:WU01:FS01:Downloading 23.09MiB
11:42:36:WU01:FS01:Download 38.97%
11:42:42:WU01:FS01:Download 79.57%
11:42:45:WU01:FS01:Download complete
11:42:45:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14484 run:0 clone:1871 gen:79 core:0x22 unit:0x0000007280fccb095f171a3906246faf
11:42:45:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
11:42:45:WU01:FS01:Connecting to cores.foldingathome.org:80
11:42:46:WU01:FS01:FahCore 22: Downloading 77.67MiB
11:42:52:WU01:FS01:FahCore 22: 25.59%
11:42:58:WU01:FS01:FahCore 22: 53.43%
11:43:04:WU01:FS01:FahCore 22: 81.12%
11:43:08:WU01:FS01:FahCore 22: Download complete
11:43:08:WU01:FS01:Valid core signature
11:43:08:WU01:FS01:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
11:43:08:WU01:FS01:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
11:43:08:WU01:FS01:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
11:43:08:WU01:FS01:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
11:43:08:WU01:FS01:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
11:43:08:WU01:FS01:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
11:43:08:WU01:FS01:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
11:43:08:WU01:FS01:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
11:43:08:WU01:FS01:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
11:44:19:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
11:44:19:WU00:FS01:0x22:Average performance: 193.722 ns/day
11:44:21:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:44:21:WU00:FS01:0x22:Saving result file checkpointState.xml
11:44:21:WU00:FS01:0x22:Saving result file positions.xtc
11:44:21:WU00:FS01:0x22:Saving result file science.log
11:44:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:44:21:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16918 run:92 clone:24 gen:89 core:0x22 unit:0x000000800002894c5f1761955d2f624d
11:44:21:WU00:FS01:Uploading 15.30MiB to 155.247.166.220
11:44:21:WU00:FS01:Connecting to 155.247.166.220:8080
11:44:21:WU01:FS01:Starting
11:44:21:WU01:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\data\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:44:21:WU01:FS01:Started FahCore on PID 12672
11:44:22:WU01:FS01:Core PID:14328
11:44:22:WU01:FS01:FahCore 0x22 started
11:44:22:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:44:23:WU01:FS01:Starting
11:44:23:WU01:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\data\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:44:23:WU01:FS01:Started FahCore on PID 2448
11:44:23:WU01:FS01:Core PID:16616
11:44:23:WU01:FS01:FahCore 0x22 started
11:44:27:WU00:FS01:Upload 25.74%
11:44:33:WU00:FS01:Upload 50.66%
11:44:39:WU00:FS01:Upload 75.58%
11:44:46:WU00:FS01:Upload complete
11:44:46:WU00:FS01:Server responded WORK_ACK (400)
11:44:46:WU00:FS01:Final credit estimate, 197782.00 points
11:44:46:WU00:FS01:Cleaning up
13:19:01:FS01:Paused
13:19:01:FS01:Shutting core down
13:19:02:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:19:08:Removing old file 'configs/config-20200915-143839.xml'
13:19:08:Saving configuration to config.xml
13:19:08:<config>
13:19:08: <!-- Network -->
13:19:08: <proxy v=':8080'/>
13:19:08:
13:19:08: <!-- User Information -->
13:19:08: <passkey v='********************************'/>
13:19:08: <team v='######'/>
13:19:08: <user v='######'/>
13:19:08:
13:19:08: <!-- Folding Slots -->
13:19:08: <slot id='1' type='GPU'>
13:19:08: <paused v='true'/>
13:19:08: </slot>
13:19:08:</config>
13:19:10:FS01:Unpaused
13:19:10:WU01:FS01:Starting
13:19:10:WU01:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\data\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9400 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:19:10:WU01:FS01:Started FahCore on PID 17824
13:19:10:WU01:FS01:Core PID:16188
13:19:10:WU01:FS01:FahCore 0x22 started
13:20:09:Removing old file 'configs/config-20200916-090849.xml'
13:20:09:Saving configuration to config.xml
13:20:09:<config>
13:20:09: <!-- Network -->
13:20:09: <proxy v=':8080'/>
13:20:09:
13:20:09: <!-- User Information -->
13:20:09: <passkey v='********************************'/>
13:20:09: <team v='######'/>
13:20:09: <user v='######'/>
13:20:09:
13:20:09: <!-- Folding Slots -->
13:20:09: <slot id='1' type='GPU'/>
13:20:09:</config>
13:20:13:FS01:Shutting core down
13:20:14:Clean exit
