WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66) [OS X]
synthesizerwriter
Post by synthesizerwriter »
Hi,
I installed FAH a few days ago, and it worked through a few WUs with no problems. Then it stopped. I looked at the log and it does this every minute or so:
16:54:24:WU00:FS00:Started FahCore on PID 4619
16:54:24:WU00:FS00:Core PID:4620
16:54:24:WU00:FS00:FahCore 0xa8 started
16:54:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:55:24:WU00:FS00:Starting
16:55:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
16:55:24:WU00:FS00:Started FahCore on PID 4627
16:55:24:WU00:FS00:Core PID:4628
16:55:24:WU00:FS00:FahCore 0xa8 started
16:55:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
I searched for 'WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)' on Google and it pointed to a post on this forum which said to: {pause/delete the 00 folder/un-pause]. I did this, but still get the same 'WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)' every minute or so.
How do I fix this, please?
Thanks,
Martin
Oh, the start of the log looks like this:
*********************** Log Started 2020-09-27T09:45:50Z ***********************
09:45:50:Trying to access database...
09:45:52:Successfully acquired database lock
09:45:52:Read GPUs.txt
09:45:52:Enabled folding slot 00: READY cpu:16
09:45:52:****************************** FAHClient ******************************
09:45:52:    Version: 7.6.13
09:45:52:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:45:52:  Copyright: 2020 foldingathome.org
09:45:52:   Homepage: https://foldingathome.org/
09:45:52:       Date: Apr 27 2020
09:45:52:       Time: 21:20:45
09:45:52:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
09:45:52:     Branch: master
09:45:52:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
09:45:52:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
09:45:52:             -Wno-unused-local-typedefs -stdlib=libc++
09:45:52:   Platform: darwin 19.2.0
09:45:52:       Bits: 64
09:45:52:       Mode: Release
09:45:52:     Config: /Library/Application Support/FAHClient/config.xml
09:45:52:******************************** CBang ********************************
09:45:52:       Date: Apr 24 2020
09:45:52:       Time: 17:07:50
09:45:52:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
09:45:52:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
09:45:52:       Bits: 64
09:45:52:******************************* System ********************************
09:45:52:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
09:45:52:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
09:45:52:       CPUs: 16
09:45:52:     Memory: 40.00GiB
09:45:52:Free Memory: 35.91GiB
09:45:52:    Threads: POSIX_THREADS
09:45:52: OS Version: 10.14
09:45:52:Has Battery: false
09:45:52: On Battery: false
09:45:52: UTC Offset: 1
09:45:52:        PID: 49
09:45:52:        CWD: /Library/Application Support/FAHClient
09:45:52:         OS: Darwin 18.7.0 x86_64
09:45:52:    OS Arch: AMD64
09:45:52:       GPUs: 2
09:45:52:      GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
09:45:52:      GPU 1: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
09:45:52:             470/480/570/580/590]
09:45:52:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
09:45:52:             dlopen(libcuda.dylib, 1): image not found
09:45:52:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
09:45:52:             dlopen(libOpenCL.dylib, 1): image not found
09:45:52:******************************* libFAH ********************************
09:45:52:       Date: Apr 15 2020
09:45:52:       Time: 14:43:28
09:45:52:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:45:52:       Bits: 64
09:45:52:***********************************************************************
09:45:52:<config>
09:45:52:  <!-- Slot Control -->
09:45:52:  <power v='FULL'/>
09:45:52:
09:45:52:  <!-- User Information -->
09:45:52:  <team v='240881'/>
09:45:52:  <user v='Synthesizerwriter'/>
09:45:52:
09:45:52:  <!-- Folding Slots -->
09:45:52:  <slot id='0' type='CPU'/>
09:45:52:</config>
09:45:52:WU00:FS00:Starting
09:45:52:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
09:45:52:WU00:FS00:Started FahCore on PID 246
09:45:52:WU00:FS00:Core PID:247
09:45:52:WU00:FS00:FahCore 0xa8 started
09:45:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:45:56:WU00:FS00:Starting
09:45:56:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
09:45:56:WU00:FS00:Started FahCore on PID 307
09:45:56:WU00:FS00:Core PID:308
09:45:56:WU00:FS00:FahCore 0xa8 started
09:45:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:46:28:2:127.0.0.1:New Web session
09:46:30:7:127.0.0.1:New Web session
09:46:56:WU00:FS00:Starting
09:46:56:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
Re: WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66) [OS
See this topic - viewtopic.php?f=105&t=36147. Basically a bad version of the A8 folding core for OS X made it out, it has been replaced on the servers with a version that should work. You will not need to delete the work files, just the folding core.
Pause folding using FAHControl or Web Control
Delete /Library/Application Support/FAHClient/cores, you will be prompted for an admin account password.
Resume folding, a new copy of the folding core should be downloaded and installed. The WU should run okay now.
synthesizerwriter
Thanks for this!
Unfortunately I then got this:
18:12:55:FS00:Paused
18:13:12:Removing old file 'configs/config-20200923-164711.xml'
18:13:12:Saving configuration to config.xml
18:13:12:<config>
18:13:12:  <!-- Slot Control -->
18:13:12:  <power v='FULL'/>
18:13:12:
18:13:12:  <!-- User Information -->
18:13:12:  <team v='240881'/>
18:13:12:  <user v='Synthesizerwriter'/>
18:13:12:
18:13:12:  <!-- Folding Slots -->
18:13:12:  <slot id='0' type='CPU'>
18:13:12:    <paused v='true'/>
18:13:12:  </slot>
18:13:12:</config>
18:13:57:FS00:Unpaused
18:13:57:WU00:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah
18:13:57:WU00:FS00:Connecting to cores.foldingathome.org:80
18:13:57:WU00:FS00:FahCore a8: Downloading 6.22MiB
18:14:00:WU00:FS00:FahCore a8: Download complete
18:14:00:WU00:FS00:Valid core signature
18:14:00:WU00:FS00:Unpacked 15.63MiB to cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8
18:14:00:WU00:FS00:Starting
18:14:00:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
18:14:00:WU00:FS00:Started FahCore on PID 5256
18:14:00:WU00:FS00:Core PID:5257
18:14:00:WU00:FS00:FahCore 0xa8 started
18:14:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:14:13:Removing old file 'configs/config-20200923-165620.xml'
18:14:13:Saving configuration to config.xml
18:14:13:<config>
18:14:13:  <!-- Slot Control -->
18:14:13:  <power v='FULL'/>
18:14:13:
18:14:13:  <!-- User Information -->
18:14:13:  <team v='240881'/>
18:14:13:  <user v='Synthesizerwriter'/>
18:14:13:
18:14:13:  <!-- Folding Slots -->
18:14:13:  <slot id='0' type='CPU'/>
18:14:13:</config>
18:15:00:WU00:FS00:Starting
18:15:00:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
18:15:00:WU00:FS00:Started FahCore on PID 5267
18:15:00:WU00:FS00:Core PID:5268
18:15:00:WU00:FS00:FahCore 0xa8 started
18:15:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:16:00:WU00:FS00:Starting
18:16:00:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 49 -checkpoint 15 -np 16
18:16:00:WU00:FS00:Started FahCore on PID 5273
18:16:00:WU00:FS00:Core PID:5274
18:16:00:WU00:FS00:FahCore 0xa8 started
18:16:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
...and now I seem to be back with the same problem...
Martin
I will check with the people who manage the project and folding cores. The OS X 0.0.7 A8 core should have been removed from the server and not be available to get downloaded again. Project 16810 should have been getting either version 0.0.6 or 0.0.8.
synthesizerwriter
@Joe_H,
Many thanks again for your efforts and explanation. Much appreciated.
Cheers and stay safe,
Martin
synthesizerwriter
@Joe_H,
Folding again! Thank you.
Martin
