FahCore Returned: INTERRUPTED [OS X]
pattanner92
Post by pattanner92 »
This is a work machine, so I only have so much control. However this unit usually work flawlessly throughout the night, but sometime last night my client kept returning the error "FahCore Returned: INTERRUPTED". I happened for about 12 hours before I could get to it, I restarted my computer to no avail. It seems to be stuck in this loop. Any help to get out of this would be greatly appreciated!
My Machine Stats:
iMac 27" 5K Retina
OS - macOS Mojave (10.14.6)
CPU - Intel 3.6 GHz Core i9
F@H Stats:
Client Version - 7.6.13
WU Assigned: 16810
Here are the logs (since my reboot today):
*********************** Log Started 2020-09-24T16:07:31Z ***********************
16:07:31:Trying to access database...
16:07:31:Successfully acquired database lock
16:07:32:Downloading GPUs.txt from assign1.foldingathome.org:80
16:07:32:Connecting to assign1.foldingathome.org:80
16:07:35:Read GPUs.txt
16:07:35:Enabled folding slot 00: READY cpu:16
16:07:35:****************************** FAHClient ******************************
16:07:35:    Version: 7.6.13
16:07:35:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:07:35:  Copyright: 2020 foldingathome.org
16:07:35:   Homepage: https://foldingathome.org/
16:07:35:       Date: Apr 27 2020
16:07:35:       Time: 21:20:45
16:07:35:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:07:35:     Branch: master
16:07:35:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:07:35:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:07:35:             -Wno-unused-local-typedefs -stdlib=libc++
16:07:35:   Platform: darwin 19.2.0
16:07:35:       Bits: 64
16:07:35:       Mode: Release
16:07:35:     Config: /Library/Application Support/FAHClient/config.xml
16:07:35:******************************** CBang ********************************
16:07:35:       Date: Apr 24 2020
16:07:35:       Time: 17:07:50
16:07:35:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:07:35:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:07:35:       Bits: 64
16:07:35:******************************* System ********************************
16:07:35:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
16:07:35:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
16:07:35:       CPUs: 16
16:07:35:     Memory: 8.00GiB
16:07:35:Free Memory: 4.84GiB
16:07:35:    Threads: POSIX_THREADS
16:07:35: OS Version: 10.14
16:07:35:Has Battery: false
16:07:35: On Battery: false
16:07:35: UTC Offset: -4
16:07:35:        PID: 51
16:07:35:        CWD: /Library/Application Support/FAHClient
16:07:35:         OS: Darwin 18.7.0 x86_64
16:07:35:    OS Arch: AMD64
16:07:35:       GPUs: 2
16:07:35:      GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
16:07:35:      GPU 1: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
16:07:35:             470/480/570/580/590]
16:07:35:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
16:07:35:             dlopen(libcuda.dylib, 1): image not found
16:07:35:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
16:07:35:             dlopen(libOpenCL.dylib, 1): image not found
16:07:35:******************************* libFAH ********************************
16:07:35:       Date: Apr 15 2020
16:07:35:       Time: 14:43:28
16:07:35:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:07:35:       Bits: 64
16:07:35:***********************************************************************
16:07:35:<config>
16:07:35:  <!-- Slot Control -->
16:07:35:  <power v='full'/>
16:07:35:
16:07:35:  <!-- User Information -->
16:07:35:  <passkey v='*****'/>
16:07:35:  <team v='removed for privacy'/>
16:07:35:  <user v='removed for privacy'/>
16:07:35:
16:07:35:  <!-- Folding Slots -->
16:07:35:  <slot id='0' type='CPU'/>
16:07:35:</config>
16:07:39:WU01:FS00:Starting
16:07:39:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:07:39:WU01:FS00:Started FahCore on PID 589
16:07:54:WU01:FS00:Core PID:781
16:07:54:WU01:FS00:FahCore 0xa8 started
16:07:57:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:08:01:WU01:FS00:Starting
16:08:01:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:08:01:WU01:FS00:Started FahCore on PID 817
16:08:01:WU01:FS00:Core PID:820
16:08:01:WU01:FS00:FahCore 0xa8 started
16:08:03:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:09:01:WU01:FS00:Starting
16:09:03:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:09:03:WU01:FS00:Started FahCore on PID 1690
16:09:58:WU01:FS00:Core PID:1742
16:09:58:WU01:FS00:FahCore 0xa8 started
16:10:08:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:10:14:WU01:FS00:Starting
16:10:14:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:10:14:WU01:FS00:Started FahCore on PID 1746
16:10:15:WU01:FS00:Core PID:1747
16:10:15:WU01:FS00:FahCore 0xa8 started
16:10:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:11:14:WU01:FS00:Starting
16:11:14:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:11:14:WU01:FS00:Started FahCore on PID 1782
16:11:15:WU01:FS00:Core PID:1783
16:11:15:WU01:FS00:FahCore 0xa8 started
16:11:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:12:14:WU01:FS00:Starting
16:12:14:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:12:14:WU01:FS00:Started FahCore on PID 1785
16:12:15:WU01:FS00:Core PID:1786
16:12:15:WU01:FS00:FahCore 0xa8 started
16:12:15:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:13:15:WU01:FS00:Starting
16:13:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:13:15:WU01:FS00:Started FahCore on PID 1804
16:13:15:WU01:FS00:Core PID:1805
16:13:15:WU01:FS00:FahCore 0xa8 started
16:13:15:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:14:15:WU01:FS00:Starting
16:14:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:14:15:WU01:FS00:Started FahCore on PID 1834
16:14:16:WU01:FS00:Core PID:1835
16:14:16:WU01:FS00:FahCore 0xa8 started
16:14:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:15:15:WU01:FS00:Starting
16:15:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:15:15:WU01:FS00:Started FahCore on PID 1842
16:15:15:WU01:FS00:Core PID:1843
16:15:15:WU01:FS00:FahCore 0xa8 started
16:15:15:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:16:15:WU01:FS00:Starting
16:16:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:16:15:WU01:FS00:Started FahCore on PID 1853
16:16:15:WU01:FS00:Core PID:1854
16:16:15:WU01:FS00:FahCore 0xa8 started
16:16:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:17:15:WU01:FS00:Starting
16:17:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:17:15:WU01:FS00:Started FahCore on PID 1859
16:17:15:WU01:FS00:Core PID:1860
16:17:15:WU01:FS00:FahCore 0xa8 started
16:17:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:18:15:WU01:FS00:Starting
16:18:15:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:18:15:WU01:FS00:Started FahCore on PID 1863
16:18:15:WU01:FS00:Core PID:1864
16:18:15:WU01:FS00:FahCore 0xa8 started
16:18:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:19:14:Saving configuration to config.xml
16:19:14:<config>
16:19:14:  <!-- Slot Control -->
16:19:14:  <power v='full'/>
16:19:14:
16:19:14:  <!-- User Information -->
16:19:14:  <passkey v='*****'/>
16:19:14:  <team v='234762'/>
16:19:14:  <user v='Pattanner92'/>
16:19:14:
16:19:14:  <!-- Folding Slots -->
16:19:14:  <slot id='0' type='CPU'>
16:19:14:    <idle v='true'/>
16:19:14:  </slot>
16:19:14:</config>
16:19:27:WU01:FS00:Starting
16:19:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:19:27:WU01:FS00:Started FahCore on PID 1869
16:19:27:WU01:FS00:Core PID:1870
16:19:27:WU01:FS00:FahCore 0xa8 started
16:19:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:20:15:Saving configuration to config.xml
16:20:15:<config>
16:20:15:  <!-- Slot Control -->
16:20:15:  <power v='full'/>
16:20:15:
16:20:15:  <!-- User Information -->
16:20:15:  <passkey v='*****'/>
16:20:15:  <team v='234762'/>
16:20:15:  <user v='Pattanner92'/>
16:20:15:
16:20:15:  <!-- Folding Slots -->
16:20:15:  <slot id='0' type='CPU'/>
16:20:15:</config>
16:20:27:WU01:FS00:Starting
16:20:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:20:27:WU01:FS00:Started FahCore on PID 1881
16:20:27:WU01:FS00:Core PID:1882
16:20:27:WU01:FS00:FahCore 0xa8 started
16:20:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:21:27:WU01:FS00:Starting
16:21:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:21:27:WU01:FS00:Started FahCore on PID 1885
16:21:27:WU01:FS00:Core PID:1886
16:21:27:WU01:FS00:FahCore 0xa8 started
16:21:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:22:27:WU01:FS00:Starting
16:22:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:22:27:WU01:FS00:Started FahCore on PID 1896
16:22:27:WU01:FS00:Core PID:1897
16:22:27:WU01:FS00:FahCore 0xa8 started
16:22:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:23:27:WU01:FS00:Starting
16:23:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:23:27:WU01:FS00:Started FahCore on PID 1917
16:23:27:WU01:FS00:Core PID:1918
16:23:27:WU01:FS00:FahCore 0xa8 started
16:23:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:24:28:WU01:FS00:Starting
16:24:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:24:28:WU01:FS00:Started FahCore on PID 1921
16:24:28:WU01:FS00:Core PID:1922
16:24:28:WU01:FS00:FahCore 0xa8 started
16:24:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:25:28:WU01:FS00:Starting
16:25:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:25:28:WU01:FS00:Started FahCore on PID 1930
16:25:28:WU01:FS00:Core PID:1931
16:25:28:WU01:FS00:FahCore 0xa8 started
16:25:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:26:28:WU01:FS00:Starting
16:26:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:26:28:WU01:FS00:Started FahCore on PID 2003
16:26:28:WU01:FS00:Core PID:2004
16:26:28:WU01:FS00:FahCore 0xa8 started
16:26:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:27:28:WU01:FS00:Starting
16:27:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:27:28:WU01:FS00:Started FahCore on PID 2008
16:27:28:WU01:FS00:Core PID:2009
16:27:28:WU01:FS00:FahCore 0xa8 started
16:27:28:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:28:28:WU01:FS00:Starting
16:28:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:28:28:WU01:FS00:Started FahCore on PID 2026
16:28:29:WU01:FS00:Core PID:2027
16:28:29:WU01:FS00:FahCore 0xa8 started
16:28:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:29:28:WU01:FS00:Starting
16:29:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:29:28:WU01:FS00:Started FahCore on PID 2032
16:29:28:WU01:FS00:Core PID:2033
16:29:28:WU01:FS00:FahCore 0xa8 started
16:29:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:30:29:WU01:FS00:Starting
16:30:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:30:29:WU01:FS00:Started FahCore on PID 2047
16:30:29:WU01:FS00:Core PID:2048
16:30:29:WU01:FS00:FahCore 0xa8 started
16:30:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:31:29:WU01:FS00:Starting
16:31:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:31:29:WU01:FS00:Started FahCore on PID 2055
16:31:29:WU01:FS00:Core PID:2056
16:31:29:WU01:FS00:FahCore 0xa8 started
16:31:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:32:29:WU01:FS00:Starting
16:32:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:32:29:WU01:FS00:Started FahCore on PID 2062
16:32:29:WU01:FS00:Core PID:2063
16:32:29:WU01:FS00:FahCore 0xa8 started
16:32:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:33:29:WU01:FS00:Starting
16:33:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:33:29:WU01:FS00:Started FahCore on PID 2095
16:33:29:WU01:FS00:Core PID:2096
16:33:29:WU01:FS00:FahCore 0xa8 started
16:33:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:34:29:WU01:FS00:Starting
16:34:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:34:29:WU01:FS00:Started FahCore on PID 2099
16:34:29:WU01:FS00:Core PID:2100
16:34:29:WU01:FS00:FahCore 0xa8 started
16:34:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:35:29:WU01:FS00:Starting
16:35:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:35:29:WU01:FS00:Started FahCore on PID 2107
16:35:29:WU01:FS00:Core PID:2108
16:35:29:WU01:FS00:FahCore 0xa8 started
16:35:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:36:29:WU01:FS00:Starting
16:36:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:36:29:WU01:FS00:Started FahCore on PID 2113
16:36:29:WU01:FS00:Core PID:2114
16:36:29:WU01:FS00:FahCore 0xa8 started
16:36:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:37:29:WU01:FS00:Starting
16:37:29:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:37:29:WU01:FS00:Started FahCore on PID 2118
16:37:29:WU01:FS00:Core PID:2119
16:37:29:WU01:FS00:FahCore 0xa8 started
16:37:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:38:30:WU01:FS00:Starting
16:38:30:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:38:30:WU01:FS00:Started FahCore on PID 2141
16:38:30:WU01:FS00:Core PID:2142
16:38:30:WU01:FS00:FahCore 0xa8 started
16:38:31:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:39:30:WU01:FS00:Starting
16:39:30:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:39:30:WU01:FS00:Started FahCore on PID 2159
16:39:30:WU01:FS00:Core PID:2160
16:39:30:WU01:FS00:FahCore 0xa8 started
16:39:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:40:30:WU01:FS00:Starting
16:40:30:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 51 -checkpoint 15 -np 16
16:40:30:WU01:FS00:Started FahCore on PID 2168
16:40:30:WU01:FS00:Core PID:2169
16:40:30:WU01:FS00:FahCore 0xa8 started
16:40:30:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
MacBook Pro 15" Mid 2012 2.6GHz Intel Core i7, iMac 27" 2019 Retina 5K Intel 3.6GHz Core i9 9900K
Re: FahCore Returned: INTERRUPTED [OS X]
See this topic - viewtopic.php?f=105&t=36147. A fix is being worked on, for now just pause folding.
pattanner92
Joe_H, thank you. I missed that thread, tried to look for solutions before posting.
I have paused the slot for now.
Welcome to the F@H Forum pattanner92,
Please note that since you mentioned "work machine" you would need to have permission (usually written) from the system owners as per the EULA. In a company, that might be Internal IT, Security Team or the CTO who have the authority to decide what is allowed to run on company owned hardware.
