I seem to have received a bad _a8 core update [OS X]
ShootThePicture
Post by ShootThePicture »
A couple of hours ago my client downloaded an updated version of the _a8 core and promptly started giving the INTERRUPTED (102 = 0x66) error message over and over again. I followed the advice on another post to get the WU to be dumped. I removed the CPU slot, added a GPU slot, the work unit was dumped, and I remade the CPU slot to get a new WU. It simply downloaded another WU from the same project and has continued giving me the same error. They are both 16810 WUs. I've included my logs from since the problem began. This is my first post so I hope I am doing this right.
03:16:30:WU00:FS00:Connecting to assign1.foldingathome.org:80
03:16:31:WU00:FS00:Assigned to work server 143.89.243.111
03:16:31:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 143.89.243.111
03:16:31:WU00:FS00:Connecting to 143.89.243.111:8080
03:16:31:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:18:08:WU00:FS00:Connecting to assign1.foldingathome.org:80
03:18:08:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
03:18:08:WU00:FS00:Connecting to assign2.foldingathome.org:80
03:18:08:WU00:FS00:Assigned to work server 178.174.196.138
03:18:08:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 178.174.196.138
03:18:08:WU00:FS00:Connecting to 178.174.196.138:8080
03:18:09:WU00:FS00:Downloading 1.88MiB
03:18:10:WU00:FS00:Download complete
03:18:11:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16810 run:59 clone:584 gen:39 core:0xa8 unit:0x0000002ab2aec48a5eff24dd618f98de
03:18:11:WU00:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah
03:18:11:WU00:FS00:Connecting to cores.foldingathome.org:80
03:18:11:WU00:FS00:FahCore a8: Downloading 6.22MiB
03:18:12:WU00:FS00:FahCore a8: Download complete
03:18:12:WU00:FS00:Valid core signature
03:18:13:WU00:FS00:Unpacked 15.63MiB to cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8
03:18:17:WU01:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
03:18:19:WU01:FS00:0xa8:Saving result file ../logfile_01.txt
03:18:19:WU01:FS00:0xa8:Saving result file ener.edr
03:18:19:WU01:FS00:0xa8:Saving result file frame43.gro
03:18:19:WU01:FS00:0xa8:Saving result file frame43.xtc
03:18:19:WU01:FS00:0xa8:Saving result file md.log
03:18:19:WU01:FS00:0xa8:Saving result file science.log
03:18:19:WU01:FS00:0xa8:Saving result file state.cpt
03:18:20:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
03:18:20:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:18:20:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16810 run:97 clone:369 gen:43 core:0xa8 unit:0x0000002fb2aec48a5eff1f814f025f57
03:18:20:WU01:FS00:Uploading 8.00MiB to 178.174.196.138
03:18:20:WU00:FS00:Starting
03:18:20:WU01:FS00:Connecting to 178.174.196.138:8080
03:18:20:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:18:20:WU00:FS00:Started FahCore on PID 46160
03:18:20:WU00:FS00:Core PID:46161
03:18:20:WU00:FS00:FahCore 0xa8 started
03:18:21:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:18:21:WU00:FS00:Starting
03:18:21:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:18:21:WU00:FS00:Started FahCore on PID 46164
03:18:21:WU00:FS00:Core PID:46165
03:18:21:WU00:FS00:FahCore 0xa8 started
03:18:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:18:26:WU01:FS00:Upload 20.30%
03:18:32:WU01:FS00:Upload 45.28%
03:18:38:WU01:FS00:Upload 70.27%
03:18:44:WU01:FS00:Upload 94.47%
03:18:45:WU01:FS00:Upload complete
03:18:45:WU01:FS00:Server responded WORK_ACK (400)
03:18:45:WU01:FS00:Final credit estimate, 10155.00 points
03:18:45:WU01:FS00:Cleaning up
03:19:21:WU00:FS00:Starting
03:19:21:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:19:21:WU00:FS00:Started FahCore on PID 46191
03:19:21:WU00:FS00:Core PID:46192
03:19:21:WU00:FS00:FahCore 0xa8 started
03:19:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:20:21:WU00:FS00:Starting
03:20:21:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:20:21:WU00:FS00:Started FahCore on PID 46203
03:20:21:WU00:FS00:Core PID:46204
03:20:21:WU00:FS00:FahCore 0xa8 started
03:20:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:21:21:WU00:FS00:Starting
03:21:21:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:21:21:WU00:FS00:Started FahCore on PID 46228
03:21:21:WU00:FS00:Core PID:46229
03:21:21:WU00:FS00:FahCore 0xa8 started
03:21:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:22:21:WU00:FS00:Starting
03:22:21:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:22:21:WU00:FS00:Started FahCore on PID 46295
03:22:21:WU00:FS00:Core PID:46296
03:22:21:WU00:FS00:FahCore 0xa8 started
03:22:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:23:22:WU00:FS00:Starting
03:23:22:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:23:22:WU00:FS00:Started FahCore on PID 46303
03:23:22:WU00:FS00:Core PID:46304
03:23:22:WU00:FS00:FahCore 0xa8 started
03:23:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:24:22:WU00:FS00:Starting
03:24:22:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:24:22:WU00:FS00:Started FahCore on PID 46312
03:24:22:WU00:FS00:Core PID:46313
03:24:22:WU00:FS00:FahCore 0xa8 started
03:24:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:25:22:WU00:FS00:Starting
03:25:22:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:25:22:WU00:FS00:Started FahCore on PID 46331
03:25:22:WU00:FS00:Core PID:46332
03:25:22:WU00:FS00:FahCore 0xa8 started
03:25:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:26:22:WU00:FS00:Starting
03:26:22:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:26:22:WU00:FS00:Started FahCore on PID 46335
03:26:22:WU00:FS00:Core PID:46336
03:26:22:WU00:FS00:FahCore 0xa8 started
03:26:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:27:22:WU00:FS00:Starting
03:27:22:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:27:22:WU00:FS00:Started FahCore on PID 46338
03:27:22:WU00:FS00:Core PID:46339
03:27:22:WU00:FS00:FahCore 0xa8 started
03:27:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:28:23:WU00:FS00:Starting
03:28:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:28:23:WU00:FS00:Started FahCore on PID 46341
03:28:23:WU00:FS00:Core PID:46342
03:28:23:WU00:FS00:FahCore 0xa8 started
03:28:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:29:23:WU00:FS00:Starting
03:29:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:29:23:WU00:FS00:Started FahCore on PID 46344
03:29:23:WU00:FS00:Core PID:46345
03:29:23:WU00:FS00:FahCore 0xa8 started
03:29:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:30:23:WU00:FS00:Starting
03:30:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:30:23:WU00:FS00:Started FahCore on PID 46348
03:30:23:WU00:FS00:Core PID:46349
03:30:23:WU00:FS00:FahCore 0xa8 started
03:30:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:31:23:WU00:FS00:Starting
03:31:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:31:23:WU00:FS00:Started FahCore on PID 46353
03:31:23:WU00:FS00:Core PID:46354
03:31:23:WU00:FS00:FahCore 0xa8 started
03:31:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:32:23:WU00:FS00:Starting
03:32:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:32:23:WU00:FS00:Started FahCore on PID 46356
03:32:23:WU00:FS00:Core PID:46357
03:32:23:WU00:FS00:FahCore 0xa8 started
03:32:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:33:23:WU00:FS00:Starting
03:33:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:33:23:WU00:FS00:Started FahCore on PID 46359
03:33:23:WU00:FS00:Core PID:46360
03:33:23:WU00:FS00:FahCore 0xa8 started
03:33:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:34:23:WU00:FS00:Starting
03:34:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:34:23:WU00:FS00:Started FahCore on PID 46371
03:34:23:WU00:FS00:Core PID:46372
03:34:23:WU00:FS00:FahCore 0xa8 started
03:34:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:35:23:WU00:FS00:Starting
03:35:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:35:23:WU00:FS00:Started FahCore on PID 46377
03:35:23:WU00:FS00:Core PID:46378
03:35:23:WU00:FS00:FahCore 0xa8 started
03:35:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:36:23:WU00:FS00:Starting
03:36:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:36:23:WU00:FS00:Started FahCore on PID 46381
03:36:23:WU00:FS00:Core PID:46382
03:36:23:WU00:FS00:FahCore 0xa8 started
03:36:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:37:24:WU00:FS00:Starting
03:37:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:37:24:WU00:FS00:Started FahCore on PID 46384
03:37:24:WU00:FS00:Core PID:46385
03:37:24:WU00:FS00:FahCore 0xa8 started
03:37:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:38:24:WU00:FS00:Starting
03:38:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:38:24:WU00:FS00:Started FahCore on PID 46387
03:38:24:WU00:FS00:Core PID:46388
03:38:24:WU00:FS00:FahCore 0xa8 started
03:38:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:39:24:WU00:FS00:Starting
03:39:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:39:24:WU00:FS00:Started FahCore on PID 46390
03:39:24:WU00:FS00:Core PID:46391
03:39:24:WU00:FS00:FahCore 0xa8 started
03:39:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:40:24:WU00:FS00:Starting
03:40:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:40:24:WU00:FS00:Started FahCore on PID 46393
03:40:24:WU00:FS00:Core PID:46394
03:40:24:WU00:FS00:FahCore 0xa8 started
03:40:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:41:24:WU00:FS00:Starting
03:41:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:41:24:WU00:FS00:Started FahCore on PID 46398
03:41:24:WU00:FS00:Core PID:46399
03:41:24:WU00:FS00:FahCore 0xa8 started
03:41:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:42:25:WU00:FS00:Starting
03:42:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:42:25:WU00:FS00:Started FahCore on PID 46401
03:42:25:WU00:FS00:Core PID:46402
03:42:25:WU00:FS00:FahCore 0xa8 started
03:42:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:43:25:WU00:FS00:Starting
03:43:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:43:25:WU00:FS00:Started FahCore on PID 46404
03:43:25:WU00:FS00:Core PID:46405
03:43:25:WU00:FS00:FahCore 0xa8 started
03:43:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:44:25:WU00:FS00:Starting
03:44:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:44:25:WU00:FS00:Started FahCore on PID 46407
03:44:25:WU00:FS00:Core PID:46408
03:44:25:WU00:FS00:FahCore 0xa8 started
03:44:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:45:25:WU00:FS00:Starting
03:45:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:45:25:WU00:FS00:Started FahCore on PID 46409
03:45:25:WU00:FS00:Core PID:46410
03:45:25:WU00:FS00:FahCore 0xa8 started
03:45:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:46:25:WU00:FS00:Starting
03:46:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:46:25:WU00:FS00:Started FahCore on PID 46416
03:46:25:WU00:FS00:Core PID:46417
03:46:25:WU00:FS00:FahCore 0xa8 started
03:46:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:47:25:WU00:FS00:Starting
03:47:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:47:25:WU00:FS00:Started FahCore on PID 46419
03:47:25:WU00:FS00:Core PID:46420
03:47:25:WU00:FS00:FahCore 0xa8 started
03:47:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:48:25:WU00:FS00:Starting
03:48:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:48:25:WU00:FS00:Started FahCore on PID 46422
03:48:25:WU00:FS00:Core PID:46423
03:48:25:WU00:FS00:FahCore 0xa8 started
03:48:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:49:25:WU00:FS00:Starting
03:49:25:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:49:25:WU00:FS00:Started FahCore on PID 46429
03:49:25:WU00:FS00:Core PID:46430
03:49:25:WU00:FS00:FahCore 0xa8 started
03:49:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:50:26:WU00:FS00:Starting
03:50:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:50:26:WU00:FS00:Started FahCore on PID 46432
03:50:26:WU00:FS00:Core PID:46433
03:50:26:WU00:FS00:FahCore 0xa8 started
03:50:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:51:26:WU00:FS00:Starting
03:51:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:51:26:WU00:FS00:Started FahCore on PID 46460
03:51:26:WU00:FS00:Core PID:46461
03:51:26:WU00:FS00:FahCore 0xa8 started
03:51:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:52:26:WU00:FS00:Starting
03:52:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:52:26:WU00:FS00:Started FahCore on PID 46495
03:52:26:WU00:FS00:Core PID:46496
03:52:26:WU00:FS00:FahCore 0xa8 started
03:52:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:53:26:WU00:FS00:Starting
03:53:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:53:26:WU00:FS00:Started FahCore on PID 46499
03:53:26:WU00:FS00:Core PID:46500
03:53:26:WU00:FS00:FahCore 0xa8 started
03:53:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:54:26:WU00:FS00:Starting
03:54:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:54:26:WU00:FS00:Started FahCore on PID 46503
03:54:26:WU00:FS00:Core PID:46504
03:54:26:WU00:FS00:FahCore 0xa8 started
03:54:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:55:26:WU00:FS00:Starting
03:55:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:55:26:WU00:FS00:Started FahCore on PID 46506
03:55:26:WU00:FS00:Core PID:46507
03:55:26:WU00:FS00:FahCore 0xa8 started
03:55:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:56:26:WU00:FS00:Starting
03:56:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:56:26:WU00:FS00:Started FahCore on PID 46510
03:56:27:WU00:FS00:Core PID:46511
03:56:27:WU00:FS00:FahCore 0xa8 started
03:56:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:57:26:WU00:FS00:Starting
03:57:26:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:57:26:WU00:FS00:Started FahCore on PID 46513
03:57:26:WU00:FS00:Core PID:46514
03:57:26:WU00:FS00:FahCore 0xa8 started
03:57:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:58:27:WU00:FS00:Starting
03:58:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:58:27:WU00:FS00:Started FahCore on PID 46516
03:58:27:WU00:FS00:Core PID:46517
03:58:27:WU00:FS00:FahCore 0xa8 started
03:58:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:59:27:WU00:FS00:Starting
03:59:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
03:59:27:WU00:FS00:Started FahCore on PID 46521
03:59:27:WU00:FS00:Core PID:46522
03:59:27:WU00:FS00:FahCore 0xa8 started
03:59:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:00:27:WU00:FS00:Starting
04:00:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:00:27:WU00:FS00:Started FahCore on PID 46526
04:00:27:WU00:FS00:Core PID:46527
04:00:27:WU00:FS00:FahCore 0xa8 started
04:00:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:01:27:WU00:FS00:Starting
04:01:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:01:27:WU00:FS00:Started FahCore on PID 46530
04:01:27:WU00:FS00:Core PID:46531
04:01:27:WU00:FS00:FahCore 0xa8 started
04:01:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:02:27:WU00:FS00:Starting
04:02:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:02:27:WU00:FS00:Started FahCore on PID 46534
04:02:27:WU00:FS00:Core PID:46535
04:02:27:WU00:FS00:FahCore 0xa8 started
04:02:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:03:27:WU00:FS00:Starting
04:03:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:03:27:WU00:FS00:Started FahCore on PID 46538
04:03:27:WU00:FS00:Core PID:46539
04:03:27:WU00:FS00:FahCore 0xa8 started
04:03:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:04:27:WU00:FS00:Starting
04:04:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:04:27:WU00:FS00:Started FahCore on PID 46545
04:04:27:WU00:FS00:Core PID:46546
04:04:27:WU00:FS00:FahCore 0xa8 started
04:04:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:05:27:WU00:FS00:Starting
04:05:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:05:27:WU00:FS00:Started FahCore on PID 46549
04:05:27:WU00:FS00:Core PID:46550
04:05:27:WU00:FS00:FahCore 0xa8 started
04:05:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:06:28:WU00:FS00:Starting
04:06:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:06:28:WU00:FS00:Started FahCore on PID 46558
04:06:28:WU00:FS00:Core PID:46559
04:06:28:WU00:FS00:FahCore 0xa8 started
04:06:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:07:28:WU00:FS00:Starting
04:07:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:07:28:WU00:FS00:Started FahCore on PID 46571
04:07:28:WU00:FS00:Core PID:46572
04:07:28:WU00:FS00:FahCore 0xa8 started
04:07:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:08:28:WU00:FS00:Starting
04:08:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:08:28:WU00:FS00:Started FahCore on PID 46575
04:08:28:WU00:FS00:Core PID:46576
04:08:28:WU00:FS00:FahCore 0xa8 started
04:08:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:09:28:WU00:FS00:Starting
04:09:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:09:28:WU00:FS00:Started FahCore on PID 46578
04:09:28:WU00:FS00:Core PID:46579
04:09:28:WU00:FS00:FahCore 0xa8 started
04:09:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:10:28:WU00:FS00:Starting
04:10:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:10:28:WU00:FS00:Started FahCore on PID 46581
04:10:28:WU00:FS00:Core PID:46582
04:10:28:WU00:FS00:FahCore 0xa8 started
04:10:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:11:28:WU00:FS00:Starting
04:11:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:11:28:WU00:FS00:Started FahCore on PID 46585
04:11:28:WU00:FS00:Core PID:46586
04:11:28:WU00:FS00:FahCore 0xa8 started
04:11:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:12:28:WU00:FS00:Starting
04:12:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:12:28:WU00:FS00:Started FahCore on PID 46592
04:12:28:WU00:FS00:Core PID:46593
04:12:28:WU00:FS00:FahCore 0xa8 started
04:12:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:13:28:WU00:FS00:Starting
04:13:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:13:28:WU00:FS00:Started FahCore on PID 46595
04:13:28:WU00:FS00:Core PID:46596
04:13:28:WU00:FS00:FahCore 0xa8 started
04:13:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:14:28:WU00:FS00:Starting
04:14:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:14:28:WU00:FS00:Started FahCore on PID 46600
04:14:28:WU00:FS00:Core PID:46601
04:14:28:WU00:FS00:FahCore 0xa8 started
04:14:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:14:47:WARNING:WU00:FS00:Slot ID 0 no longer exists and there are no other matching slots, dumping
04:14:47:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:16810 run:59 clone:584 gen:39 core:0xa8 unit:0x0000002ab2aec48a5eff24dd618f98de
04:14:47:WU00:FS00:Connecting to 178.174.196.138:8080
04:14:48:WU00:FS00:Server responded WORK_ACK (400)
04:14:48:WU00:FS00:Cleaning up
04:15:41:Adding folding slot 00: READY cpu:7
04:15:42:Saving configuration to config.xml
04:15:42:<config>
04:15:42:  <!-- Network -->
04:15:42:  <proxy v=':8080'/>
04:15:42:
04:15:42:  <!-- User Information -->
04:15:42:  <user v='JumpRaven'/>
04:15:42:
04:15:42:  <!-- Folding Slots -->
04:15:42:  <slot id='0' type='CPU'/>
04:15:42:</config>
04:15:43:WU00:FS00:Connecting to assign1.foldingathome.org:80
04:15:45:WU00:FS00:Assigned to work server 143.89.243.111
04:15:45:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 143.89.243.111
04:15:45:WU00:FS00:Connecting to 143.89.243.111:8080
04:15:47:ERROR:WU00:FS00:Exception: Server did not assign work unit
04:15:47:WU00:FS00:Connecting to assign1.foldingathome.org:80
04:15:47:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:15:47:WU00:FS00:Connecting to assign2.foldingathome.org:80
04:15:48:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:15:48:WU00:FS00:Connecting to assign3.foldingathome.org:80
04:15:48:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:15:48:WU00:FS00:Connecting to assign4.foldingathome.org:80
04:15:48:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:15:48:ERROR:WU00:FS00:Exception: Could not get an assignment
04:16:47:WU00:FS00:Connecting to assign1.foldingathome.org:80
04:16:47:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:16:47:WU00:FS00:Connecting to assign2.foldingathome.org:80
04:16:48:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:16:48:WU00:FS00:Connecting to assign3.foldingathome.org:80
04:16:49:WU00:FS00:Assigned to work server 143.89.243.111
04:16:49:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 143.89.243.111
04:16:49:WU00:FS00:Connecting to 143.89.243.111:8080
04:16:49:ERROR:WU00:FS00:Exception: Server did not assign work unit
04:18:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
04:18:25:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:18:25:WU00:FS00:Connecting to assign2.foldingathome.org:80
04:18:26:WU00:FS00:Assigned to work server 178.174.196.138
04:18:26:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 178.174.196.138
04:18:26:WU00:FS00:Connecting to 178.174.196.138:8080
04:18:26:WU00:FS00:Downloading 1.88MiB
04:18:28:WU00:FS00:Download complete
04:18:29:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16810 run:13 clone:727 gen:21 core:0xa8 unit:0x00000018b2aec48a5eff2a81a9d49a87
04:18:32:WU00:FS00:Starting
04:18:32:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:18:32:WU00:FS00:Started FahCore on PID 46621
04:18:48:WU00:FS00:Core PID:46622
04:18:48:WU00:FS00:FahCore 0xa8 started
04:18:49:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:18:49:WU00:FS00:Starting
04:18:49:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:18:49:WU00:FS00:Started FahCore on PID 46623
04:18:49:WU00:FS00:Core PID:46624
04:18:49:WU00:FS00:FahCore 0xa8 started
04:19:49:WU00:FS00:Starting
04:19:49:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:19:49:WU00:FS00:Started FahCore on PID 46637
04:19:49:WU00:FS00:Core PID:46638
04:19:49:WU00:FS00:FahCore 0xa8 started
04:19:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:20:49:WU00:FS00:Starting
04:20:49:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:20:49:WU00:FS00:Started FahCore on PID 46643
04:20:49:WU00:FS00:Core PID:46644
04:20:49:WU00:FS00:FahCore 0xa8 started
04:20:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:21:49:WU00:FS00:Starting
04:21:49:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:21:49:WU00:FS00:Started FahCore on PID 46647
04:21:49:WU00:FS00:Core PID:46648
04:21:49:WU00:FS00:FahCore 0xa8 started
04:21:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:22:49:WU00:FS00:Starting
04:22:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:22:50:WU00:FS00:Started FahCore on PID 46667
04:22:50:WU00:FS00:Core PID:46669
04:22:50:WU00:FS00:FahCore 0xa8 started
04:22:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:23:50:WU00:FS00:Starting
04:23:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:23:50:WU00:FS00:Started FahCore on PID 46706
04:23:50:WU00:FS00:Core PID:46707
04:23:50:WU00:FS00:FahCore 0xa8 started
04:23:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:24:50:WU00:FS00:Starting
04:24:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:24:50:WU00:FS00:Started FahCore on PID 46709
04:24:50:WU00:FS00:Core PID:46710
04:24:50:WU00:FS00:FahCore 0xa8 started
04:24:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:25:50:WU00:FS00:Starting
04:25:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:25:50:WU00:FS00:Started FahCore on PID 46713
04:25:50:WU00:FS00:Core PID:46714
04:25:50:WU00:FS00:FahCore 0xa8 started
04:25:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:26:50:WU00:FS00:Starting
04:26:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:26:50:WU00:FS00:Started FahCore on PID 46720
04:26:50:WU00:FS00:Core PID:46721
04:26:50:WU00:FS00:FahCore 0xa8 started
04:26:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:27:50:WU00:FS00:Starting
04:27:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:27:50:WU00:FS00:Started FahCore on PID 46723
04:27:50:WU00:FS00:Core PID:46724
04:27:50:WU00:FS00:FahCore 0xa8 started
04:27:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:28:50:WU00:FS00:Starting
04:28:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:28:50:WU00:FS00:Started FahCore on PID 46729
04:28:50:WU00:FS00:Core PID:46730
04:28:50:WU00:FS00:FahCore 0xa8 started
04:28:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:29:50:WU00:FS00:Starting
04:29:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:29:50:WU00:FS00:Started FahCore on PID 46732
04:29:50:WU00:FS00:Core PID:46733
04:29:50:WU00:FS00:FahCore 0xa8 started
04:29:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:30:50:WU00:FS00:Starting
04:30:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:30:50:WU00:FS00:Started FahCore on PID 46750
04:30:50:WU00:FS00:Core PID:46751
04:30:50:WU00:FS00:FahCore 0xa8 started
04:30:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:31:50:WU00:FS00:Starting
04:31:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:31:50:WU00:FS00:Started FahCore on PID 46801
04:31:50:WU00:FS00:Core PID:46802
04:31:50:WU00:FS00:FahCore 0xa8 started
04:31:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:32:50:WU00:FS00:Starting
04:32:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:32:50:WU00:FS00:Started FahCore on PID 46805
04:32:50:WU00:FS00:Core PID:46806
04:32:50:WU00:FS00:FahCore 0xa8 started
04:32:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:33:50:WU00:FS00:Starting
04:33:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:33:50:WU00:FS00:Started FahCore on PID 46810
04:33:50:WU00:FS00:Core PID:46811
04:33:50:WU00:FS00:FahCore 0xa8 started
04:33:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:34:51:WU00:FS00:Starting
04:34:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:34:51:WU00:FS00:Started FahCore on PID 46814
04:34:51:WU00:FS00:Core PID:46815
04:34:51:WU00:FS00:FahCore 0xa8 started
04:34:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:35:51:WU00:FS00:Starting
04:35:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:35:51:WU00:FS00:Started FahCore on PID 46817
04:35:51:WU00:FS00:Core PID:46818
04:35:51:WU00:FS00:FahCore 0xa8 started
04:35:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:36:51:WU00:FS00:Starting
04:36:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:36:51:WU00:FS00:Started FahCore on PID 46821
04:36:51:WU00:FS00:Core PID:46822
04:36:51:WU00:FS00:FahCore 0xa8 started
04:36:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:37:51:WU00:FS00:Starting
04:37:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:37:51:WU00:FS00:Started FahCore on PID 46827
04:37:51:WU00:FS00:Core PID:46828
04:37:51:WU00:FS00:FahCore 0xa8 started
04:37:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:38:51:WU00:FS00:Starting
04:38:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:38:51:WU00:FS00:Started FahCore on PID 46832
04:38:51:WU00:FS00:Core PID:46833
04:38:51:WU00:FS00:FahCore 0xa8 started
04:38:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:39:51:WU00:FS00:Starting
04:39:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:39:51:WU00:FS00:Started FahCore on PID 46838
04:39:51:WU00:FS00:Core PID:46839
04:39:51:WU00:FS00:FahCore 0xa8 started
04:39:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:40:51:WU00:FS00:Starting
04:40:51:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
04:40:51:WU00:FS00:Started FahCore on PID 46842
04:40:51:WU00:FS00:Core PID:46843
04:40:51:WU00:FS00:FahCore 0xa8 started
04:40:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Reason: edited to show issue is with the OS X version of core
Re: I seem to have received a bad _a8 core update
Welcome to the F@H Forum ShootThePicture,
Can you please post the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
I also noticed that you seem to be using a developmental version of FahCore_a8 instead of the released version which I have notified to the correct people. In the meantime, I would suggest that you pause your CPU Slot for a day or two since dumping WUs isn't ideal.
ShootThePicture
To my knowledge, the first 100 lines are long gone in the log file. But I have found a section from the last time it successfully ran a 16810 WU on the previous a8 core. I hope this will do.
I have paused it as you suggested. Also, I never signed up for any beta cores if that helps.
22:34:35:WU01:FS00:Starting
22:34:35:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.6/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 48 -checkpoint 15 -np 7
22:34:35:WU01:FS00:Started FahCore on PID 45466
22:34:35:WU01:FS00:Core PID:45467
22:34:35:WU01:FS00:FahCore 0xa8 started
22:34:36:WU01:FS00:0xa8:*********************** Log Started 2020-09-23T22:34:36Z ***********************
22:34:36:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:34:36:WU01:FS00:0xa8:       Core: Gromacs
22:34:36:WU01:FS00:0xa8:       Type: 0xa8
22:34:36:WU01:FS00:0xa8:    Version: 0.0.6
22:34:36:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:34:36:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
22:34:36:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
22:34:36:WU01:FS00:0xa8:       Date: Jul 25 2020
22:34:36:WU01:FS00:0xa8:       Time: 17:01:41
22:34:36:WU01:FS00:0xa8:   Revision: bb73a0bb4b90096d0c4f404ba28d26418056a589
22:34:36:WU01:FS00:0xa8:     Branch: master
22:34:36:WU01:FS00:0xa8:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.32.62)
22:34:36:WU01:FS00:0xa8:    Options: -std=c++14 -fsigned-char -stdlib=libc++ -O3 -funroll-loops -fno-pie
22:34:36:WU01:FS00:0xa8:             -mmacosx-version-min=10.9
22:34:36:WU01:FS00:0xa8:   Platform: darwin 19.5.0
22:34:36:WU01:FS00:0xa8:       Bits: 64
22:34:36:WU01:FS00:0xa8:       Mode: Release
22:34:36:WU01:FS00:0xa8:       SIMD: avx2_256
22:34:36:WU01:FS00:0xa8:     OpenMP: ON
22:34:36:WU01:FS00:0xa8:       CUDA: OFF
22:34:36:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 45466 -checkpoint 15 -np
22:34:36:WU01:FS00:0xa8:             7
22:34:36:WU01:FS00:0xa8:************************************ libFAH ************************************
22:34:36:WU01:FS00:0xa8:       Time: 16:58:36
22:34:36:WU01:FS00:0xa8:************************************ CBang *************************************
22:34:36:WU01:FS00:0xa8:       Time: 16:58:19
22:34:36:WU01:FS00:0xa8:             -mmacosx-version-min=10.9 -fPIC
22:34:36:WU01:FS00:0xa8:************************************ System ************************************
22:34:36:WU01:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
22:34:36:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:34:36:WU01:FS00:0xa8:       CPUs: 8
22:34:36:WU01:FS00:0xa8:     Memory: 32.00GiB
22:34:36:WU01:FS00:0xa8:Free Memory: 976.79MiB
22:34:36:WU01:FS00:0xa8:    Threads: POSIX_THREADS
22:34:36:WU01:FS00:0xa8: OS Version: 10.14
22:34:36:WU01:FS00:0xa8:Has Battery: false
22:34:36:WU01:FS00:0xa8: On Battery: false
22:34:36:WU01:FS00:0xa8: UTC Offset: -7
22:34:36:WU01:FS00:0xa8:        PID: 45467
22:34:36:WU01:FS00:0xa8:        CWD: /Library/Application Support/FAHClient/work
22:34:36:WU01:FS00:0xa8:********************************************************************************
22:34:36:WU01:FS00:0xa8:Project: 16810 (Run 97, Clone 369, Gen 43)
22:34:36:WU01:FS00:0xa8:Unit: 0x0000002fb2aec48a5eff1f814f025f57
22:34:36:WU01:FS00:0xa8:Reading tar file core.xml
22:34:36:WU01:FS00:0xa8:Reading tar file frame43.tpr
22:34:36:WU01:FS00:0xa8:Digital signatures verified
22:34:36:WU01:FS00:0xa8:Calling: mdrun -c frame43.gro -s frame43.tpr -x frame43.xtc -cpt 15 -nt 7 -ntmpi 1
22:34:36:WU01:FS00:0xa8:Steps: first=21500000 total=22000000
Post by Neil-B »
The linked instructions should help you get the top of the log file ... it has the client configuration part of the log rather than just the core configuration which might help troubleshoot this issue.
The current log can always be refreshed in the log window of FAHControl, uncheck Follow to make it easier to scroll back to the beginning. Or it can be opened read-only in the data directory shown in the log file as CWD: minus the "work" folder.
fixablecar
Post by fixablecar »
*********************** Log Started 2020-09-24T07:09:16Z ***********************
07:09:16:Trying to access database...
07:09:16:Successfully acquired database lock
07:09:16:Read GPUs.txt
07:09:16:Enabled folding slot 00: PAUSED cpu:12 (by user)
07:09:16:****************************** FAHClient ******************************
07:09:16:    Version: 7.6.13
07:09:16:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:09:16:  Copyright: 2020 foldingathome.org
07:09:16:   Homepage: https://foldingathome.org/
07:09:16:       Date: Apr 27 2020
07:09:16:       Time: 21:20:45
07:09:16:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:09:16:     Branch: master
07:09:16:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
07:09:16:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
07:09:16:             -Wno-unused-local-typedefs -stdlib=libc++
07:09:16:   Platform: darwin 19.2.0
07:09:16:       Bits: 64
07:09:16:       Mode: Release
07:09:16:     Config: /Library/Application Support/FAHClient/config.xml
07:09:16:******************************** CBang ********************************
07:09:16:       Date: Apr 24 2020
07:09:16:       Time: 17:07:50
07:09:16:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:09:16:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
07:09:16:       Bits: 64
07:09:16:******************************* System ********************************
07:09:16:        CPU: Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz
07:09:16:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
07:09:16:       CPUs: 12
07:09:16:     Memory: 16.00GiB
07:09:16:Free Memory: 105.79MiB
07:09:16:    Threads: POSIX_THREADS
07:09:16: OS Version: 10.15
07:09:16:Has Battery: true
07:09:16: On Battery: false
07:09:16: UTC Offset: 8
07:09:16:        PID: 2569
07:09:16:        CWD: /Library/Application Support/FAHClient
07:09:16:         OS: Darwin 19.6.0 x86_64
07:09:16:    OS Arch: AMD64
07:09:16:       GPUs: 2
07:09:16:      GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
07:09:16:      GPU 1: Bus:1 Slot:0 Func:0 AMD:5 Baffin XT [Radeon RX 460]
07:09:16:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
07:09:16:             dlopen(libcuda.dylib, 1): image not found
07:09:16:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
07:09:16:             dlopen(libOpenCL.dylib, 1): image not found
07:09:16:******************************* libFAH ********************************
07:09:16:       Date: Apr 15 2020
07:09:16:       Time: 14:43:28
07:09:16:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:09:16:       Bits: 64
07:09:16:***********************************************************************
07:09:16:<config>
07:09:16:  <!-- Folding Slot Configuration -->
07:09:16:  <cause v='COVID_19'/>
07:09:16:
07:09:16:  <!-- Network -->
07:09:16:  <proxy v=':8080'/>
07:09:16:
07:09:16:  <!-- Slot Control -->
07:09:16:  <power v='FULL'/>
07:09:16:
07:09:16:  <!-- User Information -->
07:09:16:  <passkey v='*****'/>
07:09:16:  <team v='*****'/>
07:09:16:  <user v='*****'/>
07:09:16:
07:09:16:  <!-- Folding Slots -->
07:09:16:  <slot id='0' type='CPU'>
07:09:16:    <paused v='true'/>
07:09:16:  </slot>
07:09:16:</config>
07:09:29:FS00:Unpaused
07:09:30:WU01:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah
07:09:30:WU01:FS00:Connecting to cores.foldingathome.org:80
07:09:30:WU01:FS00:FahCore a8: Downloading 6.22MiB
07:09:33:WU01:FS00:FahCore a8: Download complete
07:09:33:WU01:FS00:Valid core signature
07:09:33:WU01:FS00:Unpacked 15.63MiB to cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8
07:09:33:WU01:FS00:Starting
07:09:33:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 2569 -checkpoint 15 -np 12
07:09:33:WU01:FS00:Started FahCore on PID 2576
07:09:33:WU01:FS00:Core PID:2577
07:09:33:WU01:FS00:FahCore 0xa8 started
07:09:34:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:09:34:WU01:FS00:Starting
07:09:34:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 2569 -checkpoint 15 -np 12
07:09:34:WU01:FS00:Started FahCore on PID 2578
07:09:34:WU01:FS00:Core PID:2579
07:09:34:WU01:FS00:FahCore 0xa8 started
07:09:35:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
I have the same problem with the a8 core. It is also from Project 16810.
Post by Neil-B »
Hmm ... both cases osx ... maybe a bit early to call it a pattern but? ... Joe_H have you had any of this project run through your kit recently?
Welcome to the F@H Forum fixablecar,
Apologies for the issue that you're encountering. I have notified the people and working with them to isolate this issue and fix it ASAP. In the meantime, can you temporarily pause the slot.
ShootThePicture wrote:...Also, I never signed up for any beta cores if that helps...
That does help since this wasn't meant to be provided to anyone except the dev team to test stuff out. Once again, apologies for that and people are working on to identify the issue and prevent others from ending up in this situation.
Neil-B wrote:Hmm ... both cases osx ... maybe a bit early to call it a pattern but?...
Great observation, Neil-B! That's a possibility that is being investigated too :)
fixablecar
PantherX wrote:Welcome to the F@H Forum fixablecar,
Yea, I have already pause that.
Also, I tried to delete the "core" files in the local directory, and let the FAHClient re-download the core. However, the problem persists.
The issue is that the WU assigned to your system is saying that it needs FahCore_a8 version 0.0.7 which is why even after you deleted the FahCore_a8, it will still download it. The solution is:
1) Ensure that the Project constraints are correctly set-up on the Server and revert any changes that were made
2) Ensure that WUs being assigned will be using FahCore_a8 version 0.0.6
3) Ensure that impacted donors have deleted the WU (by deleting the correct folder) and then start up the slot to ensure that the next WU works fine
While I don't have any ETA, I am aware that work is happening in the background to remedy this :)
comixgoddess
Hardware configuration: MacBook Pro 2017
Post by comixgoddess »
I think I have the same issue with work unit 16810 (73, 292, 32). I'm also running a Mac on OS 10.15. Here's my log file -
*********************** Log Started 2020-09-24T12:23:19Z ***********************
12:23:19:Trying to access database...
12:23:19:Successfully acquired database lock
12:23:20:Read GPUs.txt
12:23:20:Enabled folding slot 00: PAUSED cpu:3 (by user)
12:23:21:****************************** FAHClient ******************************
12:23:21:    Version: 7.6.13
12:23:21:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:23:21:  Copyright: 2020 foldingathome.org
12:23:21:   Homepage: https://foldingathome.org/
12:23:21:       Date: Apr 27 2020
12:23:21:       Time: 21:20:45
12:23:21:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
12:23:21:     Branch: master
12:23:21:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
12:23:21:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
12:23:21:             -Wno-unused-local-typedefs -stdlib=libc++
12:23:21:   Platform: darwin 19.2.0
12:23:21:       Bits: 64
12:23:21:       Mode: Release
12:23:21:     Config: /Library/Application Support/FAHClient/config.xml
12:23:21:******************************** CBang ********************************
12:23:21:       Date: Apr 24 2020
12:23:21:       Time: 17:07:50
12:23:21:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
12:23:21:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
12:23:21:       Bits: 64
12:23:21:******************************* System ********************************
12:23:21:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
12:23:21:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
12:23:21:       CPUs: 8
12:23:21:     Memory: 16.00GiB
12:23:21:Free Memory: 14.22GiB
12:23:21:    Threads: POSIX_THREADS
12:23:21: OS Version: 10.15
12:23:21:Has Battery: true
12:23:21: On Battery: false
12:23:21: UTC Offset: -7
12:23:21:        PID: 98
12:23:21:        CWD: /Library/Application Support/FAHClient
12:23:21:         OS: Darwin 19.6.0 x86_64
12:23:21:    OS Arch: AMD64
12:23:21:       GPUs: 1
12:23:21:      GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Baffin XT [Radeon RX 460]
12:23:21:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
12:23:21:             dlopen(libcuda.dylib, 1): image not found
12:23:21:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
12:23:21:             dlopen(libOpenCL.dylib, 1): image not found
12:23:21:******************************* libFAH ********************************
12:23:21:       Date: Apr 15 2020
12:23:21:       Time: 14:43:28
12:23:21:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:23:21:       Bits: 64
12:23:21:***********************************************************************
12:23:21:<config>
12:23:21:  <!-- Folding Slot Configuration -->
12:23:21:  <cause v='HIGH_PRIORITY'/>
12:23:21:
12:23:21:  <!-- Network -->
12:23:21:  <proxy v=':8080'/>
12:23:21:
12:23:21:  <!-- Slot Control -->
12:23:21:  <pause-on-battery v='false'/>
12:23:21:  <power v='full'/>
12:23:21:
12:23:21:  <!-- User Information -->
12:23:21:  <passkey v='*****'/>
12:23:21:  <team v='38188'/>
12:23:21:  <user v='comixgoddess'/>
12:23:21:
12:23:21:  <!-- Folding Slots -->
12:23:21:  <slot id='0' type='CPU'>
12:23:21:    <cpus v='3'/>
12:23:21:    <paused v='true'/>
12:23:21:  </slot>
12:23:21:</config>
12:23:48:FS00:Unpaused
12:23:48:WU00:FS00:Starting
12:23:48:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 98 -checkpoint 15 -np 3
12:23:48:WU00:FS00:Started FahCore on PID 525
12:23:49:WU00:FS00:Core PID:526
12:23:49:WU00:FS00:FahCore 0xa8 started
12:23:49:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:23:49:WU00:FS00:Starting
12:23:49:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 98 -checkpoint 15 -np 3
12:23:49:WU00:FS00:Started FahCore on PID 529
12:23:49:WU00:FS00:Core PID:530
12:23:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
The slot has been paused.
Reason: added Code tags to log
belloq
Post by belloq »
I'm glad to have found this thread. I woke up to find one of my systems doing the same thing, also on the COVID-19 project 16810. MacOS, client 7.6.13, core a8 v0.0.7. Currently at 286 attempts. I've watched it fold previous days with core a8. Top of my log isn't anything other than this:
13:07:16:WU01:FS00:Starting
13:07:16:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 01 -suffix 01 -version 706 -lifeline 62527 -checkpoint 15 -np 4
13:07:16:WU01:FS00:Started FahCore on PID 2860
13:07:16:WU01:FS00:Core PID:2861
13:07:16:WU01:FS00:FahCore 0xa8 started
13:07:17:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Will the client ever try to dump the WU? Since this is a COVID project, maybe I can manually delete the WU and put my client on a different specific project?
belloq
Post by belloq »
