I don't know how else to describe it.
It's always been like this on this PC as far as I remember.
It's a big loss to me because I routinely use the "finish" button in advanced control.
Advanced control keeps reloading in a loop
Re: Advanced control keeps reloading in a loop
I need more information.
This usually means a bad config.xml file. But more details would be helpful.
What details do you want?
I just installed 7.6.13 with all the recommended settings. Here is the end of log.txt with many progress lines removed (both done for character limit reasons). The final 2 lines appear when advanced control is open and the final line then repeats until I exit advanced control
23:51:09:WU02:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
23:51:10:WU02:FS00:0xa8:Saving result file ..\logfile_01.txt
23:51:10:WU02:FS00:0xa8:Saving result file ener.edr
23:51:10:WU02:FS00:0xa8:Saving result file frame7.gro
23:51:10:WU02:FS00:0xa8:Saving result file frame7.xtc
23:51:10:WU02:FS00:0xa8:Saving result file md.log
23:51:10:WU02:FS00:0xa8:Saving result file science.log
23:51:10:WU02:FS00:0xa8:Saving result file state.cpt
23:51:10:WU02:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
23:51:10:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:51:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16810 run:30 clone:847 gen:7 core:0xa8 unit:0x00000007b2aec48a5eff2788f1b55ab0
23:51:10:WU02:FS00:Uploading 8.00MiB to 178.174.196.138
23:51:10:WU02:FS00:Connecting to 178.174.196.138:8080
23:51:16:WU02:FS00:Upload 20.30%
23:51:22:WU02:FS00:Upload 44.51%
23:51:28:WU02:FS00:Upload 69.50%
23:51:34:WU02:FS00:Upload 93.70%
23:51:35:WU02:FS00:Upload complete
23:51:35:WU02:FS00:Server responded WORK_ACK (400)
23:51:35:WU02:FS00:Final credit estimate, 23050.00 points
23:51:35:WU02:FS00:Cleaning up
23:51:38:WU01:FS00:Connecting to assign1.foldingathome.org:80
23:51:39:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:51:39:WU01:FS00:Connecting to assign2.foldingathome.org:80
23:51:39:WU01:FS00:Assigned to work server 178.174.196.138
23:51:39:WU01:FS00:Requesting new work unit for slot 00: READY cpu:31 from 178.174.196.138
23:51:39:WU01:FS00:Connecting to 178.174.196.138:8080
23:51:39:WU01:FS00:Downloading 1.88MiB
23:51:41:WU01:FS00:Download complete
23:51:41:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16810 run:40 clone:357 gen:46 core:0xa8 unit:0x00000034b2aec48a5eff2798aa7add1e
23:51:41:WU01:FS00:Starting
23:51:41:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phili\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.6/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 15956 -checkpoint 15 -np 31
23:51:41:WU01:FS00:Started FahCore on PID 16076
23:51:41:WU01:FS00:Core PID:5676
23:51:41:WU01:FS00:FahCore 0xa8 started
23:51:42:WU01:FS00:0xa8:*********************** Log Started 2020-09-23T23:51:41Z ***********************
23:51:42:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:51:42:WU01:FS00:0xa8: Core: Gromacs
23:51:42:WU01:FS00:0xa8: Type: 0xa8
23:51:42:WU01:FS00:0xa8: Version: 0.0.6
23:51:42:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:51:42:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
23:51:42:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
23:51:42:WU01:FS00:0xa8: Date: Jul 25 2020
23:51:42:WU01:FS00:0xa8: Time: 07:00:04
23:51:42:WU01:FS00:0xa8: Revision: bb73a0bb4b90096d0c4f404ba28d26418056a589
23:51:42:WU01:FS00:0xa8: Branch: master
23:51:42:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.6
23:51:42:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Ob3
23:51:42:WU01:FS00:0xa8: /Zc:throwingNew /MT
23:51:42:WU01:FS00:0xa8: Platform: win32 10
23:51:42:WU01:FS00:0xa8: Bits: 64
23:51:42:WU01:FS00:0xa8: Mode: Release
23:51:42:WU01:FS00:0xa8: SIMD: avx2_256
23:51:42:WU01:FS00:0xa8: OpenMP: ON
23:51:42:WU01:FS00:0xa8: CUDA: OFF
23:51:42:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 16076 -checkpoint 15 -np
23:51:42:WU01:FS00:0xa8: 31
23:51:42:WU01:FS00:0xa8:************************************ libFAH ************************************
23:51:42:WU01:FS00:0xa8: Time: 06:58:32
23:51:42:WU01:FS00:0xa8:************************************ CBang *************************************
23:51:42:WU01:FS00:0xa8: Time: 06:58:21
23:51:42:WU01:FS00:0xa8:************************************ System ************************************
23:51:42:WU01:FS00:0xa8: CPU: AMD Ryzen Threadripper 3960X 24-Core Processor
23:51:42:WU01:FS00:0xa8: CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
23:51:42:WU01:FS00:0xa8: CPUs: 48
23:51:42:WU01:FS00:0xa8: Memory: 63.87GiB
23:51:42:WU01:FS00:0xa8:Free Memory: 56.03GiB
23:51:42:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
23:51:42:WU01:FS00:0xa8: OS Version: 6.2
23:51:42:WU01:FS00:0xa8:Has Battery: false
23:51:42:WU01:FS00:0xa8: On Battery: false
23:51:42:WU01:FS00:0xa8: UTC Offset: -7
23:51:42:WU01:FS00:0xa8: PID: 5676
23:51:42:WU01:FS00:0xa8: CWD: C:\Users\phili\AppData\Roaming\FAHClient\work
23:51:42:WU01:FS00:0xa8:********************************************************************************
23:51:42:WU01:FS00:0xa8:Project: 16810 (Run 40, Clone 357, Gen 46)
23:51:42:WU01:FS00:0xa8:Unit: 0x00000034b2aec48a5eff2798aa7add1e
23:51:42:WU01:FS00:0xa8:Reading tar file core.xml
23:51:42:WU01:FS00:0xa8:Reading tar file frame46.tpr
23:51:42:WU01:FS00:0xa8:Digital signatures verified
23:51:42:WU01:FS00:0xa8:Calling: mdrun -c frame46.gro -s frame46.tpr -x frame46.xtc -cpt 15 -nt 31 -ntmpi 1
23:51:42:WU01:FS00:0xa8:Steps: first=23000000 total=23500000
23:51:42:WU01:FS00:0xa8:Completed 1 out of 500000 steps (0%)
23:55:38:30:127.0.0.1:New Web session
23:55:39:WU01:FS00:0xa8:Completed 35000 out of 500000 steps (7%)
23:56:12:WU01:FS00:0xa8:Completed 40000 out of 500000 steps (8%)
23:59:09:ERROR:unknown exception: In thread 23
23:59:15:ERROR:Receive error: 997: Overlapped I/O operation is in progress.-
What we did not know: Operating System, CPU, RAM, Bittness, Driver version,GPU, version of F@H, and your configuration. it is almost certain that some of that would help.WillerZ wrote:What details do you want?
Your log helps a great deal!
We also need the beginning of the log file where it enumerates the cpu and GPU information. The text of your config.xml will also help.
You have an AMD Threadripper and you didn't use our search function.
See this topic: viewtopic.php?f=108&t=34942
