Error on Docker version FAILED_3 (255 = 0xff)
VelvetLounger
Hardware configuration: I run on Win, Mac, and OMV
Post by VelvetLounger »
I have FAH running on my PC fine. However im having trouble getting it going using Docker on OMV5. Below is a clip from my log showing the error I get on the last line. The cycle keeps repeating. Can anyone help with this
This is being run on Ryzen 3 1200.
01:36:07:WU01:FS00:Connecting to assign1.foldingathome.org:80
01:36:07:WU01:FS00:Assigned to work server 150.136.14.110
01:36:07:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 150.136.14.110
01:36:07:WU01:FS00:Connecting to 150.136.14.110:8080
01:36:08:WU01:FS00:Downloading 2.34MiB
01:36:08:WU01:FS00:Download complete
01:36:09:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16417 run:2997 clone:4 gen:164 core:0xa7 unit:0x000000b896880e6e5e8a5f86649422ca
01:36:09:WU01:FS00:Starting
01:36:09:WU01:FS00:Running FahCore: /app/usr/bin/FAHCoreWrapper /config/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 266 -checkpoint 15 -np 4
01:36:09:WU01:FS00:Started FahCore on PID 315
01:36:09:WU01:FS00:Core PID:319
01:36:09:WU01:FS00:FahCore 0xa7 started
01:36:09:WARNING:WU01:FS00:FahCore returned: FAILED_3 (255 = 0xff)
Thanks
Velvet
Win 10 on Ryzen 7 2700 with Vega 56
Mac Mini 2012 Quad core with Intel graphics
rMBP 13" OSX with intel graphics
OMV5 on Ryzen 3 1200 with Radeon 7970
Re: Error on Docker version FAILED_3 (255 = 0xff)
Welcome to the F@H Forum VelvetLounger,
While I don't have much experience with Docker, do you:
1) Have correct permissions within docker to start folding
2) I believe that OMV5 is still a beta product (https://www.openmediavault.org/?p=2554) which means you might have found a bug? Can you try it with a stable release instead to see what happens?
Just wondering, what's your use case for using docker instead of the native system?
