disable logging?
jarruza
disable logging?
Post by jarruza »
Is it possible to disable logging? I want to run start and stop FAH on Windows through the command line but stopping is impossible due to the log file always being locked, e.g.:
22:25:38:ERROR:Exception: Failed to rename 'log.txt' to 'logs\log-20200918-222538.txt': The process cannot access the file because it is being used by another process.
I always end up having to kill the process instead.
Thanks
jarruza
config.xml overwritten
Post by jarruza »
It seems that the config.xml being overwritten is a common problem. Is there a fix or workaround for this issue?
Thanks
Mod note - Merged topic with other first post, related problem (J)
Re: disable logging?
Welcome to the F@H Forum jarruza,
Can you please post more of the log file around that error message? AFAIK, you can manually start and stop FAHClient assuming you know what you're doing since this is an expert feature. Our recommendation is to use the default settings and use the provided shortcuts to start/exit the client.
Re: config.xml overwritten
Can you please provide more context?
config.xml is always overwritten when there are changes to the client configuration, i.e. when you start/pause a Slot or add advanced features. By default, the last 16 versions of config.xml is stored.
jarruza
Post by jarruza »
Below is my latest log. I'm currently in the exploration process but the goal is to install this on a few thousand computers. Hence, I need to script this so I can start the process every night and stop in the mornings.
*********************** Log Started 2020-09-18T22:09:55Z ***********************
22:09:55:Trying to access database...
22:09:55:Successfully acquired database lock
22:09:55:Read GPUs.txt
22:09:55:Enabled folding slot 00: READY cpu:3
22:09:55:ERROR:Exception: Failed to register systray icon: Unspecified error
22:09:55:****************************** FAHClient ******************************
22:09:55:        Version: 7.6.13
22:09:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:55:      Copyright: 2020 foldingathome.org
22:09:55:       Homepage: https://foldingathome.org/
22:09:55:           Date: Apr 27 2020
22:09:55:           Time: 21:21:01
22:09:55:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
22:09:55:         Branch: master
22:09:55:       Compiler: Visual C++ 2008
22:09:55:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:09:55:       Platform: win32 10
22:09:55:           Bits: 32
22:09:55:           Mode: Release
22:09:55:         Config: C:\Users\Jose\Downloads\FAH\config.xml
22:09:55:******************************** CBang ********************************
22:09:55:           Date: Apr 24 2020
22:09:55:           Time: 17:07:55
22:09:55:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
22:09:55:           Bits: 32
22:09:55:******************************* System ********************************
22:09:55:            CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:09:55:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:09:55:           CPUs: 4
22:09:55:         Memory: 15.88GiB
22:09:55:    Free Memory: 7.93GiB
22:09:55:        Threads: WINDOWS_THREADS
22:09:55:     OS Version: 6.2
22:09:55:    Has Battery: false
22:09:55:     On Battery: false
22:09:55:     UTC Offset: -5
22:09:55:            PID: 13452
22:09:55:            CWD: C:\Users\Jose\Downloads\FAH
22:09:55:  Win32 Service: false
22:09:55:             OS: Windows 10 Enterprise
22:09:55:        OS Arch: AMD64
22:09:55:           GPUs: 0
22:09:55:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:09:55:                 specified module could not be found.
22:09:55:
22:09:55:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
22:09:55:******************************* libFAH ********************************
22:09:55:           Date: Apr 15 2020
22:09:55:           Time: 14:53:14
22:09:55:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
22:09:55:           Bits: 32
22:09:55:***********************************************************************
22:09:55:<config>
22:09:55:  <!-- User Information -->
22:09:55:  <team v='267484'/>
22:09:55:
22:09:55:  <!-- Folding Slots -->
22:09:55:  <slot id='0' type='CPU'/>
22:09:55:</config>
22:09:55:WU01:FS00:Starting
22:09:55:WARNING:WU01:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
22:09:55:WU01:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:09:55:WU01:FS00:Started FahCore on PID 15892
22:09:55:WU01:FS00:Core PID:9756
22:09:55:WU01:FS00:FahCore 0xa7 started
22:09:56:WU01:FS00:0xa7:*********************** Log Started 2020-09-18T22:09:55Z ***********************
22:09:56:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:09:56:WU01:FS00:0xa7:       Type: 0xa7
22:09:56:WU01:FS00:0xa7:       Core: Gromacs
22:09:56:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15892 -checkpoint 15 -np
22:09:56:WU01:FS00:0xa7:             3
22:09:56:WU01:FS00:0xa7:************************************ CBang *************************************
22:09:56:WU01:FS00:0xa7:       Date: Nov 27 2019
22:09:56:WU01:FS00:0xa7:       Time: 03:40:09
22:09:56:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:09:56:WU01:FS00:0xa7:     Branch: master
22:09:56:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:09:56:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:09:56:WU01:FS00:0xa7:   Platform: win32 10
22:09:56:WU01:FS00:0xa7:       Bits: 64
22:09:56:WU01:FS00:0xa7:       Mode: Release
22:09:56:WU01:FS00:0xa7:************************************ System ************************************
22:09:56:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:09:56:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:09:56:WU01:FS00:0xa7:       CPUs: 4
22:09:56:WU01:FS00:0xa7:     Memory: 15.88GiB
22:09:56:WU01:FS00:0xa7:Free Memory: 7.89GiB
22:09:56:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:09:56:WU01:FS00:0xa7: OS Version: 6.2
22:09:56:WU01:FS00:0xa7:Has Battery: false
22:09:56:WU01:FS00:0xa7: On Battery: false
22:09:56:WU01:FS00:0xa7: UTC Offset: -5
22:09:56:WU01:FS00:0xa7:        PID: 9756
22:09:56:WU01:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:09:56:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:09:56:WU01:FS00:0xa7:    Version: 0.0.19
22:09:56:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:56:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:09:56:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:09:56:WU01:FS00:0xa7:       Date: Nov 25 2019
22:09:56:WU01:FS00:0xa7:       Time: 17:12:41
22:09:56:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:09:56:WU01:FS00:0xa7:************************************ Build *************************************
22:09:56:WU01:FS00:0xa7:       SIMD: avx_256
22:09:56:WU01:FS00:0xa7:********************************************************************************
22:09:56:WU01:FS00:0xa7:Project: 16440 (Run 0, Clone 593, Gen 196)
22:09:56:WU01:FS00:0xa7:Unit: 0x000000dd80fccb015ea8ebe7b76f477b
22:09:56:WU01:FS00:0xa7:Digital signatures verified
22:09:56:WU01:FS00:0xa7:Calling: mdrun -s frame196.tpr -o frame196.trr -x frame196.xtc -cpi state.cpt -cpt 15 -nt 3
22:09:56:WU01:FS00:0xa7:ERROR:Guru Meditation #0.12a727a5c4fcc210 (0.2907336) '01/01/frame196.trr'
22:09:57:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:09:57:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:09:57:WU01:FS00:Starting
22:09:57:WU01:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:09:57:WU01:FS00:Started FahCore on PID 11260
22:09:57:WU01:FS00:Core PID:328
22:09:57:WU01:FS00:FahCore 0xa7 started
22:09:58:WU01:FS00:0xa7:*********************** Log Started 2020-09-18T22:09:57Z ***********************
22:09:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:09:58:WU01:FS00:0xa7:       Type: 0xa7
22:09:58:WU01:FS00:0xa7:       Core: Gromacs
22:09:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11260 -checkpoint 15 -np
22:09:58:WU01:FS00:0xa7:             3
22:09:58:WU01:FS00:0xa7:************************************ CBang *************************************
22:09:58:WU01:FS00:0xa7:       Date: Nov 27 2019
22:09:58:WU01:FS00:0xa7:       Time: 03:40:09
22:09:58:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:09:58:WU01:FS00:0xa7:     Branch: master
22:09:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:09:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:09:58:WU01:FS00:0xa7:   Platform: win32 10
22:09:58:WU01:FS00:0xa7:       Bits: 64
22:09:58:WU01:FS00:0xa7:       Mode: Release
22:09:58:WU01:FS00:0xa7:************************************ System ************************************
22:09:58:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:09:58:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:09:58:WU01:FS00:0xa7:       CPUs: 4
22:09:58:WU01:FS00:0xa7:     Memory: 15.88GiB
22:09:58:WU01:FS00:0xa7:Free Memory: 7.89GiB
22:09:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:09:58:WU01:FS00:0xa7: OS Version: 6.2
22:09:58:WU01:FS00:0xa7:Has Battery: false
22:09:58:WU01:FS00:0xa7: On Battery: false
22:09:58:WU01:FS00:0xa7: UTC Offset: -5
22:09:58:WU01:FS00:0xa7:        PID: 328
22:09:58:WU01:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:09:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:09:58:WU01:FS00:0xa7:    Version: 0.0.19
22:09:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:58:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:09:58:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:09:58:WU01:FS00:0xa7:       Date: Nov 25 2019
22:09:58:WU01:FS00:0xa7:       Time: 17:12:41
22:09:58:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:09:58:WU01:FS00:0xa7:************************************ Build *************************************
22:09:58:WU01:FS00:0xa7:       SIMD: avx_256
22:09:58:WU01:FS00:0xa7:********************************************************************************
22:09:58:WU01:FS00:0xa7:Project: 16440 (Run 0, Clone 593, Gen 196)
22:09:58:WU01:FS00:0xa7:Unit: 0x000000dd80fccb015ea8ebe7b76f477b
22:09:58:WU01:FS00:0xa7:Digital signatures verified
22:09:58:WU01:FS00:0xa7:Calling: mdrun -s frame196.tpr -o frame196.trr -x frame196.xtc -cpi state.cpt -cpt 15 -nt 3
22:09:58:WU01:FS00:0xa7:ERROR:Guru Meditation #0.12a727a5c4fcc210 (0.2907336) '01/01/frame196.trr'
22:09:59:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:09:59:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:10:56:Saving configuration to config.xml
22:10:56:<config>
22:10:56:  <!-- User Information -->
22:10:56:  <team v='267484'/>
22:10:56:
22:10:56:  <!-- Folding Slots -->
22:10:56:  <slot id='0' type='CPU'/>
22:10:56:</config>
22:10:57:WU01:FS00:Starting
22:10:57:WU01:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:10:57:WU01:FS00:Started FahCore on PID 11068
22:10:57:WU01:FS00:Core PID:5304
22:10:57:WU01:FS00:FahCore 0xa7 started
22:10:58:WU01:FS00:0xa7:*********************** Log Started 2020-09-18T22:10:57Z ***********************
22:10:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:10:58:WU01:FS00:0xa7:       Type: 0xa7
22:10:58:WU01:FS00:0xa7:       Core: Gromacs
22:10:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11068 -checkpoint 15 -np
22:10:58:WU01:FS00:0xa7:             3
22:10:58:WU01:FS00:0xa7:************************************ CBang *************************************
22:10:58:WU01:FS00:0xa7:       Date: Nov 27 2019
22:10:58:WU01:FS00:0xa7:       Time: 03:40:09
22:10:58:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:10:58:WU01:FS00:0xa7:     Branch: master
22:10:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:10:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:10:58:WU01:FS00:0xa7:   Platform: win32 10
22:10:58:WU01:FS00:0xa7:       Bits: 64
22:10:58:WU01:FS00:0xa7:       Mode: Release
22:10:58:WU01:FS00:0xa7:************************************ System ************************************
22:10:58:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:10:58:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:10:58:WU01:FS00:0xa7:       CPUs: 4
22:10:58:WU01:FS00:0xa7:     Memory: 15.88GiB
22:10:58:WU01:FS00:0xa7:Free Memory: 7.68GiB
22:10:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:10:58:WU01:FS00:0xa7: OS Version: 6.2
22:10:58:WU01:FS00:0xa7:Has Battery: false
22:10:58:WU01:FS00:0xa7: On Battery: false
22:10:58:WU01:FS00:0xa7: UTC Offset: -5
22:10:58:WU01:FS00:0xa7:        PID: 5304
22:10:58:WU01:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:10:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:10:58:WU01:FS00:0xa7:    Version: 0.0.19
22:10:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:10:58:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:10:58:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:10:58:WU01:FS00:0xa7:       Date: Nov 25 2019
22:10:58:WU01:FS00:0xa7:       Time: 17:12:41
22:10:58:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:10:58:WU01:FS00:0xa7:************************************ Build *************************************
22:10:58:WU01:FS00:0xa7:       SIMD: avx_256
22:10:58:WU01:FS00:0xa7:********************************************************************************
22:10:58:WU01:FS00:0xa7:Project: 16440 (Run 0, Clone 593, Gen 196)
22:10:58:WU01:FS00:0xa7:Unit: 0x000000dd80fccb015ea8ebe7b76f477b
22:10:58:WU01:FS00:0xa7:Digital signatures verified
22:10:58:WU01:FS00:0xa7:Calling: mdrun -s frame196.tpr -o frame196.trr -x frame196.xtc -cpi state.cpt -cpt 15 -nt 3
22:10:58:WU01:FS00:0xa7:ERROR:Guru Meditation #0.12a727a5c4fcc210 (0.2907336) '01/01/frame196.trr'
22:10:59:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:10:59:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:11:57:WU01:FS00:Starting
22:11:57:WU01:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:11:57:WU01:FS00:Started FahCore on PID 128
22:11:57:WU01:FS00:Core PID:4912
22:11:57:WU01:FS00:FahCore 0xa7 started
22:11:58:WU01:FS00:0xa7:*********************** Log Started 2020-09-18T22:11:57Z ***********************
22:11:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:11:58:WU01:FS00:0xa7:       Type: 0xa7
22:11:58:WU01:FS00:0xa7:       Core: Gromacs
22:11:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 128 -checkpoint 15 -np 3
22:11:58:WU01:FS00:0xa7:************************************ CBang *************************************
22:11:58:WU01:FS00:0xa7:       Date: Nov 27 2019
22:11:58:WU01:FS00:0xa7:       Time: 03:40:09
22:11:58:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:11:58:WU01:FS00:0xa7:     Branch: master
22:11:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:11:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:11:58:WU01:FS00:0xa7:   Platform: win32 10
22:11:58:WU01:FS00:0xa7:       Bits: 64
22:11:58:WU01:FS00:0xa7:       Mode: Release
22:11:58:WU01:FS00:0xa7:************************************ System ************************************
22:11:58:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:11:58:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:11:58:WU01:FS00:0xa7:       CPUs: 4
22:11:58:WU01:FS00:0xa7:     Memory: 15.88GiB
22:11:58:WU01:FS00:0xa7:Free Memory: 7.86GiB
22:11:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:11:58:WU01:FS00:0xa7: OS Version: 6.2
22:11:58:WU01:FS00:0xa7:Has Battery: false
22:11:58:WU01:FS00:0xa7: On Battery: false
22:11:58:WU01:FS00:0xa7: UTC Offset: -5
22:11:58:WU01:FS00:0xa7:        PID: 4912
22:11:58:WU01:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:11:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:11:58:WU01:FS00:0xa7:    Version: 0.0.19
22:11:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:11:58:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:11:58:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:11:58:WU01:FS00:0xa7:       Date: Nov 25 2019
22:11:58:WU01:FS00:0xa7:       Time: 17:12:41
22:11:58:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:11:58:WU01:FS00:0xa7:************************************ Build *************************************
22:11:58:WU01:FS00:0xa7:       SIMD: avx_256
22:11:58:WU01:FS00:0xa7:********************************************************************************
22:11:58:WU01:FS00:0xa7:Project: 16440 (Run 0, Clone 593, Gen 196)
22:11:58:WU01:FS00:0xa7:Unit: 0x000000dd80fccb015ea8ebe7b76f477b
22:11:58:WU01:FS00:0xa7:Digital signatures verified
22:11:58:WU01:FS00:0xa7:Calling: mdrun -s frame196.tpr -o frame196.trr -x frame196.xtc -cpi state.cpt -cpt 15 -nt 3
22:11:58:WU01:FS00:0xa7:ERROR:Guru Meditation #0.12a727a5c4fcc210 (0.2907336) '01/01/frame196.trr'
22:11:59:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:11:59:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:12:57:WU01:FS00:Starting
22:12:57:WU01:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:12:58:WU01:FS00:Started FahCore on PID 10596
22:12:58:WU01:FS00:Core PID:15476
22:12:58:WU01:FS00:FahCore 0xa7 started
22:12:58:WU01:FS00:0xa7:*********************** Log Started 2020-09-18T22:12:58Z ***********************
22:12:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:12:58:WU01:FS00:0xa7:       Type: 0xa7
22:12:58:WU01:FS00:0xa7:       Core: Gromacs
22:12:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10596 -checkpoint 15 -np
22:12:58:WU01:FS00:0xa7:             3
22:12:58:WU01:FS00:0xa7:************************************ CBang *************************************
22:12:58:WU01:FS00:0xa7:       Date: Nov 27 2019
22:12:58:WU01:FS00:0xa7:       Time: 03:40:09
22:12:58:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:12:58:WU01:FS00:0xa7:     Branch: master
22:12:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:12:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:12:58:WU01:FS00:0xa7:   Platform: win32 10
22:12:58:WU01:FS00:0xa7:       Bits: 64
22:12:58:WU01:FS00:0xa7:       Mode: Release
22:12:58:WU01:FS00:0xa7:************************************ System ************************************
22:12:58:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:12:58:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:12:58:WU01:FS00:0xa7:       CPUs: 4
22:12:58:WU01:FS00:0xa7:     Memory: 15.88GiB
22:12:58:WU01:FS00:0xa7:Free Memory: 7.88GiB
22:12:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:12:58:WU01:FS00:0xa7: OS Version: 6.2
22:12:58:WU01:FS00:0xa7:Has Battery: false
22:12:58:WU01:FS00:0xa7: On Battery: false
22:12:58:WU01:FS00:0xa7: UTC Offset: -5
22:12:58:WU01:FS00:0xa7:        PID: 15476
22:12:58:WU01:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:12:58:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:12:58:WU01:FS00:0xa7:    Version: 0.0.19
22:12:58:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:12:58:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:12:58:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:12:58:WU01:FS00:0xa7:       Date: Nov 25 2019
22:12:58:WU01:FS00:0xa7:       Time: 17:12:41
22:12:58:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:12:58:WU01:FS00:0xa7:************************************ Build *************************************
22:12:58:WU01:FS00:0xa7:       SIMD: avx_256
22:12:58:WU01:FS00:0xa7:********************************************************************************
22:12:58:WU01:FS00:0xa7:Project: 16440 (Run 0, Clone 593, Gen 196)
22:12:58:WU01:FS00:0xa7:Unit: 0x000000dd80fccb015ea8ebe7b76f477b
22:12:58:WU01:FS00:0xa7:Digital signatures verified
22:12:58:WU01:FS00:0xa7:Calling: mdrun -s frame196.tpr -o frame196.trr -x frame196.xtc -cpi state.cpt -cpt 15 -nt 3
22:12:58:WU01:FS00:0xa7:ERROR:Guru Meditation #0.12a727a5c4fcc210 (0.2907336) '01/01/frame196.trr'
22:12:59:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:12:59:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:12:59:WARNING:WU01:FS00:Too many errors, failing
22:12:59:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:16440 run:0 clone:593 gen:196 core:0xa7 unit:0x000000dd80fccb015ea8ebe7b76f477b
22:12:59:WU01:FS00:Connecting to 128.252.203.1:8080
22:12:59:WU01:FS00:Server responded WORK_ACK (400)
22:12:59:WU01:FS00:Cleaning up
22:12:59:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:13:00:WU00:FS00:Assigned to work server 150.136.14.110
22:13:00:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 150.136.14.110
22:13:00:WU00:FS00:Connecting to 150.136.14.110:8080
22:13:00:WU00:FS00:Downloading 2.18MiB
22:13:00:WU00:FS00:Download complete
22:13:00:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16423 run:5456 clone:3 gen:109 core:0xa7 unit:0x0000007696880e6e5e8a8b4e74dd6b3a
22:13:00:WU00:FS00:Starting
22:13:00:WU00:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 3
22:13:01:WU00:FS00:Started FahCore on PID 6700
22:13:01:WU00:FS00:Core PID:15424
22:13:01:WU00:FS00:FahCore 0xa7 started
22:13:01:WU00:FS00:0xa7:*********************** Log Started 2020-09-18T22:13:01Z ***********************
22:13:01:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:13:01:WU00:FS00:0xa7:       Type: 0xa7
22:13:01:WU00:FS00:0xa7:       Core: Gromacs
22:13:01:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6700 -checkpoint 15 -np 3
22:13:01:WU00:FS00:0xa7:************************************ CBang *************************************
22:13:01:WU00:FS00:0xa7:       Date: Nov 27 2019
22:13:01:WU00:FS00:0xa7:       Time: 03:40:09
22:13:01:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:13:01:WU00:FS00:0xa7:     Branch: master
22:13:01:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:13:01:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:13:01:WU00:FS00:0xa7:   Platform: win32 10
22:13:01:WU00:FS00:0xa7:       Bits: 64
22:13:01:WU00:FS00:0xa7:       Mode: Release
22:13:01:WU00:FS00:0xa7:************************************ System ************************************
22:13:01:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:13:01:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:13:01:WU00:FS00:0xa7:       CPUs: 4
22:13:01:WU00:FS00:0xa7:     Memory: 15.88GiB
22:13:01:WU00:FS00:0xa7:Free Memory: 7.87GiB
22:13:01:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:13:01:WU00:FS00:0xa7: OS Version: 6.2
22:13:01:WU00:FS00:0xa7:Has Battery: false
22:13:01:WU00:FS00:0xa7: On Battery: false
22:13:01:WU00:FS00:0xa7: UTC Offset: -5
22:13:01:WU00:FS00:0xa7:        PID: 15424
22:13:01:WU00:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:13:01:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:13:01:WU00:FS00:0xa7:    Version: 0.0.19
22:13:01:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:13:01:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:13:01:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:13:01:WU00:FS00:0xa7:       Date: Nov 25 2019
22:13:01:WU00:FS00:0xa7:       Time: 17:12:41
22:13:01:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:13:01:WU00:FS00:0xa7:************************************ Build *************************************
22:13:01:WU00:FS00:0xa7:       SIMD: avx_256
22:13:01:WU00:FS00:0xa7:********************************************************************************
22:13:01:WU00:FS00:0xa7:Project: 16423 (Run 5456, Clone 3, Gen 109)
22:13:01:WU00:FS00:0xa7:Unit: 0x0000007696880e6e5e8a8b4e74dd6b3a
22:13:01:WU00:FS00:0xa7:Reading tar file core.xml
22:13:01:WU00:FS00:0xa7:Reading tar file frame109.tpr
22:13:01:WU00:FS00:0xa7:Digital signatures verified
22:13:01:WU00:FS00:0xa7:Calling: mdrun -s frame109.tpr -o frame109.trr -x frame109.xtc -cpt 15 -nt 3
22:13:01:WU00:FS00:0xa7:Steps: first=27250000 total=250000
22:13:03:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
22:14:33:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
22:16:03:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
22:17:34:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
22:19:06:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
22:20:37:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
22:22:08:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
22:23:46:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
22:25:19:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
22:26:53:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
22:28:24:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
22:29:53:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
22:31:22:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
22:31:29:FS00:Finishing
22:32:54:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
22:33:17:FS00:Shutting core down
22:33:18:Saving configuration to config.xml
22:33:18:<config>
22:33:18:  <!-- Slot Control -->
22:33:18:  <power v='light'/>
22:33:18:
22:33:18:  <!-- User Information -->
22:33:18:  <team v='267484'/>
22:33:18:
22:33:18:  <!-- Folding Slots -->
22:33:18:  <slot id='0' type='CPU'/>
22:33:18:</config>
22:33:18:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 15424
22:33:18:WU00:FS00:0xa7:Exiting, please wait. . .
22:33:19:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
22:33:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:33:20:WU00:FS00:Starting
22:33:20:WARNING:WU00:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
22:33:20:WU00:FS00:Running FahCore: C:\Users\Jose\Downloads\FAH/FAHCoreWrapper.exe C:\Users\Jose\Downloads\FAH\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13452 -checkpoint 15 -np 1
22:33:20:WU00:FS00:Started FahCore on PID 8560
22:33:20:WU00:FS00:Core PID:6828
22:33:20:WU00:FS00:FahCore 0xa7 started
22:33:20:WU00:FS00:0xa7:*********************** Log Started 2020-09-18T22:33:20Z ***********************
22:33:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:33:20:WU00:FS00:0xa7:       Type: 0xa7
22:33:20:WU00:FS00:0xa7:       Core: Gromacs
22:33:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8560 -checkpoint 15 -np 1
22:33:20:WU00:FS00:0xa7:************************************ CBang *************************************
22:33:20:WU00:FS00:0xa7:       Date: Nov 27 2019
22:33:20:WU00:FS00:0xa7:       Time: 03:40:09
22:33:20:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:33:20:WU00:FS00:0xa7:     Branch: master
22:33:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:33:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:33:20:WU00:FS00:0xa7:   Platform: win32 10
22:33:20:WU00:FS00:0xa7:       Bits: 64
22:33:20:WU00:FS00:0xa7:       Mode: Release
22:33:20:WU00:FS00:0xa7:************************************ System ************************************
22:33:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
22:33:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
22:33:20:WU00:FS00:0xa7:       CPUs: 4
22:33:20:WU00:FS00:0xa7:     Memory: 15.88GiB
22:33:20:WU00:FS00:0xa7:Free Memory: 7.69GiB
22:33:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:33:20:WU00:FS00:0xa7: OS Version: 6.2
22:33:20:WU00:FS00:0xa7:Has Battery: false
22:33:20:WU00:FS00:0xa7: On Battery: false
22:33:20:WU00:FS00:0xa7: UTC Offset: -5
22:33:20:WU00:FS00:0xa7:        PID: 6828
22:33:20:WU00:FS00:0xa7:        CWD: C:\Users\Jose\Downloads\FAH\work
22:33:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:33:20:WU00:FS00:0xa7:    Version: 0.0.19
22:33:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:33:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:33:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:33:20:WU00:FS00:0xa7:       Date: Nov 25 2019
22:33:20:WU00:FS00:0xa7:       Time: 17:12:41
22:33:20:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:33:20:WU00:FS00:0xa7:************************************ Build *************************************
22:33:20:WU00:FS00:0xa7:       SIMD: avx_256
22:33:20:WU00:FS00:0xa7:********************************************************************************
22:33:20:WU00:FS00:0xa7:Project: 16423 (Run 5456, Clone 3, Gen 109)
22:33:20:WU00:FS00:0xa7:Unit: 0x0000007696880e6e5e8a8b4e74dd6b3a
22:33:20:WU00:FS00:0xa7:Digital signatures verified
22:33:20:WU00:FS00:0xa7:Calling: mdrun -s frame109.tpr -o frame109.trr -x frame109.xtc -cpi state.cpt -cpt 15 -nt 1
22:33:20:WU00:FS00:0xa7:Steps: first=27250000 total=250000
22:33:21:WU00:FS00:0xa7:Completed 33152 out of 250000 steps (13%)
jarruza
Post by jarruza »
Re: config.xml overwritten. We're looking for a way to preserve the settings. based on the device specifications the goal is to set the power level. For example, laptops with their limited cooling abilities would be set to light, while desktop with GPUs would be set to full. However, these values seem to be overwritten every time the application starts and the values erased.
this configuration:
<config>
  <power v='light'/>
</config>
is over written with this:
<config>
</config>
Simple answer: Don't try to stop FAHClient. It's essentially a daemon which does nothing unless you tell it you want it do do something. Simply PAUSE the active WUs and all processing will cease. You can unpause it when it time to go back to work. A script can send those commands through the telnet interface on port 36330.
Be sure you have (written) permission from the owner of those computers.
Looking over your log, you have the client running in a non-default location from your "Downloads" directory. That could be part of the problem you are having with the log not being saved when going to a new one. The client needs R/W permissions and the ability to create subdirectories.
The default install will create the directory to run the client under %AppData% and setups up a shortcut that will use that as the CWD: Normally that should be used.
You mentioned wanting to install on a large group of computers There are several topics from late March through April that a number of people contributed to wanting to do the same. One that I can find fairly quickly since I posted there is this - viewtopic.php?f=106&t=33127. Perhaps between that and other similar topics you can get some useful pointers towards deploying and controlling the client on multiple systems.
