Getting bad work unit (Unreleased driver issue)
silverpulser
Post by silverpulser »
My last two attempts at running FAH resulted in a Bad Work Unit. In fact it keeps trying new WU's for a while with similar result. I have upgraded to lates client and restarted my computer. Still responds the same. Here is my log:
*********************** Log Started 2020-09-16T13:14:38Z ***********************
13:15:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
13:15:28:WU01:FS01:Connecting to 18.188.125.154:8080
13:15:29:WU01:FS01:Downloading 343.32KiB
13:15:29:WU01:FS01:Download complete
13:15:29:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13427 run:2573 clone:10 gen:0 core:0x22 unit:0x0000000212bc7d9a5f586ced496893bf
13:15:29:WU01:FS01:Starting
13:15:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:15:29:WU01:FS01:Started FahCore on PID 11608
UPDATE
Installed latest Client and restarted computer with the same result. It keeps downloading and starting to run new WU's but throws up the "Error initializing context: clCreateContext (222)Error initializing context: clCreateContext (222)" Bad Work Unit (114 = 0x72).
What can I do to overcome this?
13:15:29:WU01:FS01:Core PID:7024
13:15:29:WU01:FS01:FahCore 0x22 started
13:15:30:WU01:FS01:0x22:*********************** Log Started 2020-09-16T13:15:29Z ***********************
13:15:30:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:15:30:WU01:FS01:0x22:       Core: Core22
13:15:30:WU01:FS01:0x22:       Type: 0x22
13:15:30:WU01:FS01:0x22:    Version: 0.0.11
13:15:30:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:15:30:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
13:15:30:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
13:15:30:WU01:FS01:0x22:       Date: Jun 26 2020
13:15:30:WU01:FS01:0x22:       Time: 19:49:16
13:15:30:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:15:30:WU01:FS01:0x22:     Branch: core22-0.0.11
13:15:30:WU01:FS01:0x22:   Compiler: Visual C++ 2015
13:15:30:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:15:30:WU01:FS01:0x22:   Platform: win32 10
13:15:30:WU01:FS01:0x22:       Bits: 64
13:15:30:WU01:FS01:0x22:       Mode: Release
13:15:30:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:15:30:WU01:FS01:0x22:             <peastman@stanford.edu>
13:15:30:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11608 -checkpoint 15
13:15:30:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:15:30:WU01:FS01:0x22:             0 -gpu 0
13:15:30:WU01:FS01:0x22:************************************ libFAH ************************************
13:15:30:WU01:FS01:0x22:       Time: 19:47:12
13:15:30:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:15:30:WU01:FS01:0x22:     Branch: HEAD
13:15:30:WU01:FS01:0x22:************************************ CBang *************************************
13:15:30:WU01:FS01:0x22:       Time: 19:46:11
13:15:30:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:15:30:WU01:FS01:0x22:     Branch: master
13:15:30:WU01:FS01:0x22:************************************ System ************************************
13:15:30:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:15:30:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:15:30:WU01:FS01:0x22:       CPUs: 2
13:15:30:WU01:FS01:0x22:     Memory: 3.98GiB
13:15:30:WU01:FS01:0x22:Free Memory: 1.27GiB
13:15:30:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:15:30:WU01:FS01:0x22: OS Version: 6.2
13:15:30:WU01:FS01:0x22:Has Battery: false
13:15:30:WU01:FS01:0x22: On Battery: false
13:15:30:WU01:FS01:0x22: UTC Offset: 1
13:15:30:WU01:FS01:0x22:        PID: 7024
13:15:30:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:15:30:WU01:FS01:0x22:********************************************************************************
13:15:30:WU01:FS01:0x22:Project: 13427 (Run 2573, Clone 10, Gen 0)
13:15:30:WU01:FS01:0x22:Unit: 0x0000000212bc7d9a5f586ced496893bf
13:15:30:WU01:FS01:0x22:Reading tar file core.xml
13:15:30:WU01:FS01:0x22:Reading tar file integrator.xml
13:15:30:WU01:FS01:0x22:Reading tar file state.xml.bz2
13:15:30:WU01:FS01:0x22:Reading tar file system.xml.bz2
13:15:30:WU01:FS01:0x22:Digital signatures verified
13:15:30:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:15:30:WU01:FS01:0x22:Version 0.0.11
13:15:30:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:15:30:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:15:30:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:15:30:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:15:31:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:15:31:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:15:31:WU01:FS01:0x22:Saving result file science.log
13:15:31:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:15:31:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:15:31:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13427 run:2573 clone:10 gen:0 core:0x22 unit:0x0000000212bc7d9a5f586ced496893bf
13:15:31:WU01:FS01:Uploading 2.43KiB to 18.188.125.154
13:15:31:WU01:FS01:Connecting to 18.188.125.154:8080
13:15:31:WU00:FS01:Connecting to 65.254.110.245:80
13:15:32:WU01:FS01:Upload complete
13:15:32:WU01:FS01:Server responded WORK_ACK (400)
13:15:32:WU01:FS01:Cleaning up
13:15:33:WU00:FS01:Assigned to work server 155.247.166.220
13:15:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 155.247.166.220
13:15:33:WU00:FS01:Connecting to 155.247.166.220:8080
13:15:34:WU00:FS01:Downloading 9.01MiB
13:15:40:WU00:FS01:Download 43.00%
13:15:44:WU00:FS01:Download complete
13:15:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16920 run:41 clone:14 gen:98 core:0x22 unit:0x000000830002894c5f2a13c73cf64d65
13:15:44:WU00:FS01:Starting
13:15:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:15:44:WU00:FS01:Started FahCore on PID 8808
13:15:44:WU00:FS01:Core PID:10776
13:15:44:WU00:FS01:FahCore 0x22 started
13:15:44:WU00:FS01:0x22:*********************** Log Started 2020-09-16T13:15:44Z ***********************
13:15:44:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:15:44:WU00:FS01:0x22:       Core: Core22
13:15:44:WU00:FS01:0x22:       Type: 0x22
13:15:44:WU00:FS01:0x22:    Version: 0.0.11
13:15:44:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:15:44:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
13:15:44:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
13:15:44:WU00:FS01:0x22:       Date: Jun 26 2020
13:15:44:WU00:FS01:0x22:       Time: 19:49:16
13:15:44:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:15:44:WU00:FS01:0x22:     Branch: core22-0.0.11
13:15:44:WU00:FS01:0x22:   Compiler: Visual C++ 2015
13:15:44:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:15:44:WU00:FS01:0x22:   Platform: win32 10
13:15:44:WU00:FS01:0x22:       Bits: 64
13:15:44:WU00:FS01:0x22:       Mode: Release
13:15:44:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:15:44:WU00:FS01:0x22:             <peastman@stanford.edu>
13:15:44:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8808 -checkpoint 15
13:15:44:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:15:44:WU00:FS01:0x22:             0 -gpu 0
13:15:44:WU00:FS01:0x22:************************************ libFAH ************************************
13:15:44:WU00:FS01:0x22:       Time: 19:47:12
13:15:44:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:15:44:WU00:FS01:0x22:     Branch: HEAD
13:15:44:WU00:FS01:0x22:************************************ CBang *************************************
13:15:44:WU00:FS01:0x22:       Time: 19:46:11
13:15:44:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:15:44:WU00:FS01:0x22:     Branch: master
13:15:44:WU00:FS01:0x22:************************************ System ************************************
13:15:44:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:15:44:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:15:44:WU00:FS01:0x22:       CPUs: 2
13:15:44:WU00:FS01:0x22:     Memory: 3.98GiB
13:15:44:WU00:FS01:0x22:Free Memory: 1.25GiB
13:15:44:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
13:15:44:WU00:FS01:0x22: OS Version: 6.2
13:15:44:WU00:FS01:0x22:Has Battery: false
13:15:44:WU00:FS01:0x22: On Battery: false
13:15:44:WU00:FS01:0x22: UTC Offset: 1
13:15:44:WU00:FS01:0x22:        PID: 10776
13:15:44:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:15:44:WU00:FS01:0x22:********************************************************************************
13:15:44:WU00:FS01:0x22:Project: 16920 (Run 41, Clone 14, Gen 98)
13:15:44:WU00:FS01:0x22:Unit: 0x000000830002894c5f2a13c73cf64d65
13:15:44:WU00:FS01:0x22:Reading tar file core.xml
13:15:44:WU00:FS01:0x22:Reading tar file integrator.xml
13:15:44:WU00:FS01:0x22:Reading tar file state.xml
13:15:44:WU00:FS01:0x22:Reading tar file system.xml
13:15:44:WU00:FS01:0x22:Digital signatures verified
13:15:44:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:15:44:WU00:FS01:0x22:Version 0.0.11
13:15:44:WU00:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
13:15:44:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
13:15:44:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
13:15:44:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
13:15:46:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:15:46:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
13:15:46:WU00:FS01:0x22:Saving result file science.log
13:15:46:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:15:47:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:15:47:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:16920 run:41 clone:14 gen:98 core:0x22 unit:0x000000830002894c5f2a13c73cf64d65
13:15:47:WU00:FS01:Uploading 10.00KiB to 155.247.166.220
13:15:47:WU00:FS01:Connecting to 155.247.166.220:8080
13:15:47:WU00:FS01:Upload complete
13:15:47:WU00:FS01:Server responded WORK_ACK (400)
13:15:47:WU01:FS01:Connecting to 65.254.110.245:80
13:15:47:WU00:FS01:Cleaning up
13:15:48:WU01:FS01:Assigned to work server 66.170.111.50
13:15:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 66.170.111.50
13:15:48:WU01:FS01:Connecting to 66.170.111.50:8080
13:15:49:WU01:FS01:Downloading 11.16MiB
13:15:55:WU01:FS01:Download 6.16%
13:16:01:WU01:FS01:Download 74.45%
13:16:03:WU01:FS01:Download complete
13:16:03:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14485 run:0 clone:1774 gen:22 core:0x22 unit:0x0000001d42aa6f325f45dea97188675b
13:16:03:WU01:FS01:Starting
13:16:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:16:03:WU01:FS01:Started FahCore on PID 5332
13:16:03:WU01:FS01:Core PID:9084
13:16:03:WU01:FS01:FahCore 0x22 started
13:16:04:WU01:FS01:0x22:*********************** Log Started 2020-09-16T13:16:03Z ***********************
13:16:04:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:16:04:WU01:FS01:0x22:       Core: Core22
13:16:04:WU01:FS01:0x22:       Type: 0x22
13:16:04:WU01:FS01:0x22:    Version: 0.0.11
13:16:04:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:04:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
13:16:04:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
13:16:04:WU01:FS01:0x22:       Date: Jun 26 2020
13:16:04:WU01:FS01:0x22:       Time: 19:49:16
13:16:04:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:16:04:WU01:FS01:0x22:     Branch: core22-0.0.11
13:16:04:WU01:FS01:0x22:   Compiler: Visual C++ 2015
13:16:04:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:16:04:WU01:FS01:0x22:   Platform: win32 10
13:16:04:WU01:FS01:0x22:       Bits: 64
13:16:04:WU01:FS01:0x22:       Mode: Release
13:16:04:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:16:04:WU01:FS01:0x22:             <peastman@stanford.edu>
13:16:04:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5332 -checkpoint 15
13:16:04:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:16:04:WU01:FS01:0x22:             0 -gpu 0
13:16:04:WU01:FS01:0x22:************************************ libFAH ************************************
13:16:04:WU01:FS01:0x22:       Time: 19:47:12
13:16:04:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:16:04:WU01:FS01:0x22:     Branch: HEAD
13:16:04:WU01:FS01:0x22:************************************ CBang *************************************
13:16:04:WU01:FS01:0x22:       Time: 19:46:11
13:16:04:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:16:04:WU01:FS01:0x22:     Branch: master
13:16:04:WU01:FS01:0x22:************************************ System ************************************
13:16:04:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:16:04:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:16:04:WU01:FS01:0x22:       CPUs: 2
13:16:04:WU01:FS01:0x22:     Memory: 3.98GiB
13:16:04:WU01:FS01:0x22:Free Memory: 1.25GiB
13:16:04:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:16:04:WU01:FS01:0x22: OS Version: 6.2
13:16:04:WU01:FS01:0x22:Has Battery: false
13:16:04:WU01:FS01:0x22: On Battery: false
13:16:04:WU01:FS01:0x22: UTC Offset: 1
13:16:04:WU01:FS01:0x22:        PID: 9084
13:16:04:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:16:04:WU01:FS01:0x22:********************************************************************************
13:16:04:WU01:FS01:0x22:Project: 14485 (Run 0, Clone 1774, Gen 22)
13:16:04:WU01:FS01:0x22:Unit: 0x0000001d42aa6f325f45dea97188675b
13:16:04:WU01:FS01:0x22:Reading tar file core.xml
13:16:04:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
13:16:04:WU01:FS01:0x22:Reading tar file state.xml.bz2
13:16:04:WU01:FS01:0x22:Reading tar file system.xml.bz2
13:16:04:WU01:FS01:0x22:Digital signatures verified
13:16:04:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:16:04:WU01:FS01:0x22:Version 0.0.11
13:16:04:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
13:16:04:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
13:16:04:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
13:16:04:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
13:16:23:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:16:23:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:16:23:WU01:FS01:0x22:Saving result file science.log
13:16:23:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:16:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:16:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14485 run:0 clone:1774 gen:22 core:0x22 unit:0x0000001d42aa6f325f45dea97188675b
13:16:24:WU01:FS01:Uploading 10.00KiB to 66.170.111.50
13:16:24:WU01:FS01:Connecting to 66.170.111.50:8080
13:16:24:WU00:FS01:Connecting to 65.254.110.245:80
13:16:24:WU01:FS01:Upload complete
13:16:24:WU01:FS01:Server responded WORK_ACK (400)
13:16:24:WU01:FS01:Cleaning up
13:16:25:WU00:FS01:Assigned to work server 18.188.125.154
13:16:25:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
13:16:25:WU00:FS01:Connecting to 18.188.125.154:8080
13:16:26:WU00:FS01:Downloading 338.43KiB
13:16:26:WU00:FS01:Download complete
13:16:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2356 clone:28 gen:1 core:0x22 unit:0x0000000212bc7d9a5f586ceec40f1d81
13:16:26:WU00:FS01:Starting
13:16:26:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:16:26:WU00:FS01:Started FahCore on PID 8492
13:16:26:WU00:FS01:Core PID:4616
13:16:26:WU00:FS01:FahCore 0x22 started
13:16:27:WU00:FS01:0x22:*********************** Log Started 2020-09-16T13:16:26Z ***********************
13:16:27:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:16:27:WU00:FS01:0x22:       Core: Core22
13:16:27:WU00:FS01:0x22:       Type: 0x22
13:16:27:WU00:FS01:0x22:    Version: 0.0.11
13:16:27:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:27:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
13:16:27:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
13:16:27:WU00:FS01:0x22:       Date: Jun 26 2020
13:16:27:WU00:FS01:0x22:       Time: 19:49:16
13:16:27:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:16:27:WU00:FS01:0x22:     Branch: core22-0.0.11
13:16:27:WU00:FS01:0x22:   Compiler: Visual C++ 2015
13:16:27:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:16:27:WU00:FS01:0x22:   Platform: win32 10
13:16:27:WU00:FS01:0x22:       Bits: 64
13:16:27:WU00:FS01:0x22:       Mode: Release
13:16:27:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:16:27:WU00:FS01:0x22:             <peastman@stanford.edu>
13:16:27:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8492 -checkpoint 15
13:16:27:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:16:27:WU00:FS01:0x22:             0 -gpu 0
13:16:27:WU00:FS01:0x22:************************************ libFAH ************************************
13:16:27:WU00:FS01:0x22:       Time: 19:47:12
13:16:27:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:16:27:WU00:FS01:0x22:     Branch: HEAD
13:16:27:WU00:FS01:0x22:************************************ CBang *************************************
13:16:27:WU00:FS01:0x22:       Time: 19:46:11
13:16:27:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:16:27:WU00:FS01:0x22:     Branch: master
13:16:27:WU00:FS01:0x22:************************************ System ************************************
13:16:27:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:16:27:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:16:27:WU00:FS01:0x22:       CPUs: 2
13:16:27:WU00:FS01:0x22:     Memory: 3.98GiB
13:16:27:WU00:FS01:0x22:Free Memory: 1.28GiB
13:16:27:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
13:16:27:WU00:FS01:0x22: OS Version: 6.2
13:16:27:WU00:FS01:0x22:Has Battery: false
13:16:27:WU00:FS01:0x22: On Battery: false
13:16:27:WU00:FS01:0x22: UTC Offset: 1
13:16:27:WU00:FS01:0x22:        PID: 4616
13:16:27:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:16:27:WU00:FS01:0x22:********************************************************************************
13:16:27:WU00:FS01:0x22:Project: 13427 (Run 2356, Clone 28, Gen 1)
13:16:27:WU00:FS01:0x22:Unit: 0x0000000212bc7d9a5f586ceec40f1d81
13:16:27:WU00:FS01:0x22:Reading tar file core.xml
13:16:27:WU00:FS01:0x22:Reading tar file integrator.xml
13:16:27:WU00:FS01:0x22:Reading tar file state.xml.bz2
13:16:27:WU00:FS01:0x22:Reading tar file system.xml.bz2
13:16:27:WU00:FS01:0x22:Digital signatures verified
13:16:27:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:16:27:WU00:FS01:0x22:Version 0.0.11
13:16:27:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:16:27:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:16:27:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:16:27:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:16:27:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:16:27:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
13:16:27:WU00:FS01:0x22:Saving result file science.log
13:16:27:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:16:28:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:16:28:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2356 clone:28 gen:1 core:0x22 unit:0x0000000212bc7d9a5f586ceec40f1d81
13:16:28:WU00:FS01:Uploading 2.43KiB to 18.188.125.154
13:16:28:WU00:FS01:Connecting to 18.188.125.154:8080
13:16:28:WU01:FS01:Connecting to 65.254.110.245:80
13:16:28:WU00:FS01:Upload complete
13:16:29:WU00:FS01:Server responded WORK_ACK (400)
13:16:29:WU00:FS01:Cleaning up
13:16:29:WU01:FS01:Assigned to work server 18.188.125.154
13:16:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
13:16:29:WU01:FS01:Connecting to 18.188.125.154:8080
13:16:30:WU01:FS01:Downloading 344.44KiB
13:16:30:WU01:FS01:Download complete
13:16:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13427 run:2320 clone:2 gen:4 core:0x22 unit:0x0000000a12bc7d9a5f586ce6ab273745
13:16:31:WU01:FS01:Starting
13:16:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:16:31:WU01:FS01:Started FahCore on PID 9272
13:16:31:WU01:FS01:Core PID:6744
13:16:31:WU01:FS01:FahCore 0x22 started
13:16:31:WU01:FS01:0x22:*********************** Log Started 2020-09-16T13:16:31Z ***********************
13:16:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:16:31:WU01:FS01:0x22:       Core: Core22
13:16:31:WU01:FS01:0x22:       Type: 0x22
13:16:31:WU01:FS01:0x22:    Version: 0.0.11
13:16:31:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:31:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
13:16:31:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
13:16:31:WU01:FS01:0x22:       Date: Jun 26 2020
13:16:31:WU01:FS01:0x22:       Time: 19:49:16
13:16:31:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:16:31:WU01:FS01:0x22:     Branch: core22-0.0.11
13:16:31:WU01:FS01:0x22:   Compiler: Visual C++ 2015
13:16:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:16:31:WU01:FS01:0x22:   Platform: win32 10
13:16:31:WU01:FS01:0x22:       Bits: 64
13:16:31:WU01:FS01:0x22:       Mode: Release
13:16:31:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:16:31:WU01:FS01:0x22:             <peastman@stanford.edu>
13:16:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9272 -checkpoint 15
13:16:31:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:16:31:WU01:FS01:0x22:             0 -gpu 0
13:16:31:WU01:FS01:0x22:************************************ libFAH ************************************
13:16:31:WU01:FS01:0x22:       Time: 19:47:12
13:16:31:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:16:31:WU01:FS01:0x22:     Branch: HEAD
13:16:31:WU01:FS01:0x22:************************************ CBang *************************************
13:16:31:WU01:FS01:0x22:       Time: 19:46:11
13:16:31:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:16:31:WU01:FS01:0x22:     Branch: master
13:16:31:WU01:FS01:0x22:************************************ System ************************************
13:16:31:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:16:31:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:16:31:WU01:FS01:0x22:       CPUs: 2
13:16:31:WU01:FS01:0x22:     Memory: 3.98GiB
13:16:31:WU01:FS01:0x22:Free Memory: 1.28GiB
13:16:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:16:31:WU01:FS01:0x22: OS Version: 6.2
13:16:31:WU01:FS01:0x22:Has Battery: false
13:16:31:WU01:FS01:0x22: On Battery: false
13:16:31:WU01:FS01:0x22: UTC Offset: 1
13:16:31:WU01:FS01:0x22:        PID: 6744
13:16:31:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:16:31:WU01:FS01:0x22:********************************************************************************
13:16:31:WU01:FS01:0x22:Project: 13427 (Run 2320, Clone 2, Gen 4)
13:16:31:WU01:FS01:0x22:Unit: 0x0000000a12bc7d9a5f586ce6ab273745
13:16:31:WU01:FS01:0x22:Reading tar file core.xml
13:16:31:WU01:FS01:0x22:Reading tar file integrator.xml
13:16:31:WU01:FS01:0x22:Reading tar file state.xml.bz2
13:16:31:WU01:FS01:0x22:Reading tar file system.xml.bz2
13:16:31:WU01:FS01:0x22:Digital signatures verified
13:16:31:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:16:31:WU01:FS01:0x22:Version 0.0.11
13:16:31:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:16:31:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:16:31:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:16:31:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:16:32:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:16:32:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:16:32:WU01:FS01:0x22:Saving result file science.log
13:16:32:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:16:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:16:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13427 run:2320 clone:2 gen:4 core:0x22 unit:0x0000000a12bc7d9a5f586ce6ab273745
13:16:32:WU01:FS01:Uploading 2.43KiB to 18.188.125.154
13:16:32:WU01:FS01:Connecting to 18.188.125.154:8080
13:16:33:WU00:FS01:Connecting to 65.254.110.245:80
13:16:33:WU01:FS01:Upload complete
13:16:33:WU01:FS01:Server responded WORK_ACK (400)
13:16:33:WU01:FS01:Cleaning up
13:16:34:WU00:FS01:Assigned to work server 18.188.125.154
13:16:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
13:16:34:WU00:FS01:Connecting to 18.188.125.154:8080
13:16:35:WU00:FS01:Downloading 339.89KiB
13:16:35:WU00:FS01:Download complete
13:16:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2547 clone:13 gen:3 core:0x22 unit:0x0000000612bc7d9a5f586ceb92d0d7d5
13:16:35:WU00:FS01:Starting
13:16:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:16:35:WU00:FS01:Started FahCore on PID 1768
13:16:35:WU00:FS01:Core PID:6448
13:16:35:WU00:FS01:FahCore 0x22 started
13:16:36:WU00:FS01:0x22:*********************** Log Started 2020-09-16T13:16:36Z ***********************
13:16:36:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:16:36:WU00:FS01:0x22:       Core: Core22
13:16:36:WU00:FS01:0x22:       Type: 0x22
13:16:36:WU00:FS01:0x22:    Version: 0.0.11
13:16:36:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:36:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
13:16:36:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
13:16:36:WU00:FS01:0x22:       Date: Jun 26 2020
13:16:36:WU00:FS01:0x22:       Time: 19:49:16
13:16:36:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:16:36:WU00:FS01:0x22:     Branch: core22-0.0.11
13:16:36:WU00:FS01:0x22:   Compiler: Visual C++ 2015
13:16:36:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:16:36:WU00:FS01:0x22:   Platform: win32 10
13:16:36:WU00:FS01:0x22:       Bits: 64
13:16:36:WU00:FS01:0x22:       Mode: Release
13:16:36:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:16:36:WU00:FS01:0x22:             <peastman@stanford.edu>
13:16:36:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1768 -checkpoint 15
13:16:36:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:16:36:WU00:FS01:0x22:             0 -gpu 0
13:16:36:WU00:FS01:0x22:************************************ libFAH ************************************
13:16:36:WU00:FS01:0x22:       Time: 19:47:12
13:16:36:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:16:36:WU00:FS01:0x22:     Branch: HEAD
13:16:36:WU00:FS01:0x22:************************************ CBang *************************************
13:16:36:WU00:FS01:0x22:       Time: 19:46:11
13:16:36:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:16:36:WU00:FS01:0x22:     Branch: master
13:16:36:WU00:FS01:0x22:************************************ System ************************************
13:16:36:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:16:36:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:16:36:WU00:FS01:0x22:       CPUs: 2
13:16:36:WU00:FS01:0x22:     Memory: 3.98GiB
13:16:36:WU00:FS01:0x22:Free Memory: 1.28GiB
13:16:36:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
13:16:36:WU00:FS01:0x22: OS Version: 6.2
13:16:36:WU00:FS01:0x22:Has Battery: false
13:16:36:WU00:FS01:0x22: On Battery: false
13:16:36:WU00:FS01:0x22: UTC Offset: 1
13:16:36:WU00:FS01:0x22:        PID: 6448
13:16:36:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:16:36:WU00:FS01:0x22:********************************************************************************
13:16:36:WU00:FS01:0x22:Project: 13427 (Run 2547, Clone 13, Gen 3)
13:16:36:WU00:FS01:0x22:Unit: 0x0000000612bc7d9a5f586ceb92d0d7d5
13:16:36:WU00:FS01:0x22:Reading tar file core.xml
13:16:36:WU00:FS01:0x22:Reading tar file integrator.xml
13:16:36:WU00:FS01:0x22:Reading tar file state.xml.bz2
13:16:36:WU00:FS01:0x22:Reading tar file system.xml.bz2
13:16:36:WU00:FS01:0x22:Digital signatures verified
13:16:36:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:16:36:WU00:FS01:0x22:Version 0.0.11
13:16:36:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:16:36:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:16:36:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:16:36:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:16:37:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:16:37:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
13:16:37:WU00:FS01:0x22:Saving result file science.log
13:16:37:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:16:37:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:16:37:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2547 clone:13 gen:3 core:0x22 unit:0x0000000612bc7d9a5f586ceb92d0d7d5
13:16:37:WU00:FS01:Uploading 2.43KiB to 18.188.125.154
13:16:37:WU00:FS01:Connecting to 18.188.125.154:8080
13:16:38:WU01:FS01:Connecting to 65.254.110.245:80
13:16:38:WU00:FS01:Upload complete
13:16:38:WU00:FS01:Server responded WORK_ACK (400)
13:16:38:WU00:FS01:Cleaning up
13:16:39:WU01:FS01:Assigned to work server 18.188.125.154
13:16:39:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
13:16:39:WU01:FS01:Connecting to 18.188.125.154:8080
13:16:40:WU01:FS01:Downloading 347.01KiB
13:16:40:WU01:FS01:Download complete
13:16:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13427 run:2484 clone:10 gen:4 core:0x22 unit:0x0000000912bc7d9a5f586cf0d24e3e38
13:16:41:WU01:FS01:Starting
13:16:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:16:41:WU01:FS01:Started FahCore on PID 3128
13:16:41:WU01:FS01:Core PID:5960
13:16:41:WU01:FS01:FahCore 0x22 started
13:16:41:WU01:FS01:0x22:*********************** Log Started 2020-09-16T13:16:41Z ***********************
13:16:41:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:16:41:WU01:FS01:0x22:       Core: Core22
13:16:41:WU01:FS01:0x22:       Type: 0x22
13:16:41:WU01:FS01:0x22:    Version: 0.0.11
13:16:41:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:16:41:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
13:16:41:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
13:16:41:WU01:FS01:0x22:       Date: Jun 26 2020
13:16:41:WU01:FS01:0x22:       Time: 19:49:16
13:16:41:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
13:16:41:WU01:FS01:0x22:     Branch: core22-0.0.11
13:16:41:WU01:FS01:0x22:   Compiler: Visual C++ 2015
13:16:41:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:16:41:WU01:FS01:0x22:   Platform: win32 10
13:16:41:WU01:FS01:0x22:       Bits: 64
13:16:41:WU01:FS01:0x22:       Mode: Release
13:16:41:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:16:41:WU01:FS01:0x22:             <peastman@stanford.edu>
13:16:41:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3128 -checkpoint 15
13:16:41:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:16:41:WU01:FS01:0x22:             0 -gpu 0
13:16:41:WU01:FS01:0x22:************************************ libFAH ************************************
13:16:41:WU01:FS01:0x22:       Time: 19:47:12
13:16:41:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:16:41:WU01:FS01:0x22:     Branch: HEAD
13:16:41:WU01:FS01:0x22:************************************ CBang *************************************
13:16:41:WU01:FS01:0x22:       Time: 19:46:11
13:16:41:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
13:16:41:WU01:FS01:0x22:     Branch: master
13:16:41:WU01:FS01:0x22:************************************ System ************************************
13:16:41:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
13:16:41:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:16:41:WU01:FS01:0x22:       CPUs: 2
13:16:41:WU01:FS01:0x22:     Memory: 3.98GiB
13:16:41:WU01:FS01:0x22:Free Memory: 1.29GiB
13:16:41:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:16:41:WU01:FS01:0x22: OS Version: 6.2
13:16:41:WU01:FS01:0x22:Has Battery: false
13:16:41:WU01:FS01:0x22: On Battery: false
13:16:41:WU01:FS01:0x22: UTC Offset: 1
13:16:41:WU01:FS01:0x22:        PID: 5960
13:16:41:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:16:41:WU01:FS01:0x22:********************************************************************************
13:16:41:WU01:FS01:0x22:Project: 13427 (Run 2484, Clone 10, Gen 4)
13:16:41:WU01:FS01:0x22:Unit: 0x0000000912bc7d9a5f586cf0d24e3e38
13:16:41:WU01:FS01:0x22:Reading tar file core.xml
13:16:41:WU01:FS01:0x22:Reading tar file integrator.xml
13:16:41:WU01:FS01:0x22:Reading tar file state.xml.bz2
13:16:41:WU01:FS01:0x22:Reading tar file system.xml.bz2
13:16:41:WU01:FS01:0x22:Digital signatures verified
13:16:41:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:16:41:WU01:FS01:0x22:Version 0.0.11
13:16:41:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:16:41:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:16:41:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:16:41:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:16:42:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
13:16:42:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:16:42:WU01:FS01:0x22:Saving result file science.log
13:16:42:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:16:42:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:16:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13427 run:2484 clone:10 gen:4 core:0x22 unit:0x0000000912bc7d9a5f586cf0d24e3e38
13:16:43:WU01:FS01:Uploading 2.43KiB to 18.188.125.154
13:16:43:WU01:FS01:Connecting to 18.188.125.154:8080
13:16:43:WU01:FS01:Upload complete
13:16:43:WU01:FS01:Server responded WORK_ACK (400)
13:16:43:WU01:FS01:Cleaning up
Mod Edit: Fixed Code Tags - PantherX
Re: Getting bad work unit
If you post the first 200 lines of your log, it should have the configuration information for your PC.
That may help, and can't hurt.
silverpulser
OK, here is the log you requested:
14:26:18:        Version: 7.6.13
14:26:18:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:18:      Copyright: 2020 foldingathome.org
14:26:18:       Homepage: https://foldingathome.org/
14:26:18:           Date: Apr 27 2020
14:26:18:           Time: 21:21:01
14:26:18:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
14:26:18:         Branch: master
14:26:18:       Compiler: Visual C++ 2008
14:26:18:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:26:18:       Platform: win32 10
14:26:18:           Bits: 32
14:26:18:           Mode: Release
14:26:18:           Args: --open-web-control
14:26:18:         Config: C:\Users\User\AppData\Roaming\FAHClient\config.xml
14:26:18:******************************** CBang ********************************
14:26:18:           Date: Apr 24 2020
14:26:18:           Time: 17:07:55
14:26:18:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
14:26:18:           Bits: 32
14:26:18:******************************* System ********************************
14:26:18:            CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:26:18:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:26:18:           CPUs: 2
14:26:18:         Memory: 3.98GiB
14:26:18:    Free Memory: 1.89GiB
14:26:18:        Threads: WINDOWS_THREADS
14:26:18:     OS Version: 6.2
14:26:18:    Has Battery: false
14:26:18:     On Battery: false
14:26:18:     UTC Offset: 1
14:26:18:            PID: 12116
14:26:18:            CWD: C:\Users\User\AppData\Roaming\FAHClient
14:26:18:  Win32 Service: false
14:26:18:             OS: Windows 10 Enterprise
14:26:18:        OS Arch: AMD64
14:26:18:           GPUs: 1
14:26:18:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM107 [GeForce GTX 750 Ti] 1389
14:26:18:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:11.1
14:26:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.15
14:26:18:******************************* libFAH ********************************
14:26:18:           Date: Apr 15 2020
14:26:18:           Time: 14:53:14
14:26:18:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:26:18:           Bits: 32
14:26:18:***********************************************************************
14:26:18:<config>
14:26:18:  <!-- Network -->
14:26:18:  <proxy v=':8080'/>
14:26:18:
14:26:18:  <!-- Slot Control -->
14:26:18:  <power v='full'/>
14:26:18:
14:26:18:  <!-- User Information -->
14:26:18:  <passkey v='*****'/>
14:26:18:  <team v='142900'/>
14:26:18:  <user v='Silverpulser'/>
14:26:18:
14:26:18:  <!-- Folding Slots -->
14:26:18:  <slot id='1' type='GPU'/>
14:26:18:</config>
14:26:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:26:20:WU00:FS01:Assigned to work server 18.188.125.154
14:26:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:26:20:WU00:FS01:Connecting to 18.188.125.154:8080
14:26:22:WU00:FS01:Downloading 345.40KiB
14:26:22:WU00:FS01:Download complete
14:26:23:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2317 clone:8 gen:4 core:0x22 unit:0x0000000712bc7d9a5f586cec3dcb79cc
14:26:23:WU00:FS01:Starting
14:26:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:26:23:WU00:FS01:Started FahCore on PID 10044
14:26:23:WU00:FS01:Core PID:11712
14:26:23:WU00:FS01:FahCore 0x22 started
14:26:24:WU00:FS01:0x22:*********************** Log Started 2020-09-16T14:26:23Z ***********************
14:26:24:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:26:24:WU00:FS01:0x22:       Core: Core22
14:26:24:WU00:FS01:0x22:       Type: 0x22
14:26:24:WU00:FS01:0x22:    Version: 0.0.11
14:26:24:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:24:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:26:24:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:26:24:WU00:FS01:0x22:       Date: Jun 26 2020
14:26:24:WU00:FS01:0x22:       Time: 19:49:16
14:26:24:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:26:24:WU00:FS01:0x22:     Branch: core22-0.0.11
14:26:24:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:26:24:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:26:24:WU00:FS01:0x22:   Platform: win32 10
14:26:24:WU00:FS01:0x22:       Bits: 64
14:26:24:WU00:FS01:0x22:       Mode: Release
14:26:24:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:26:24:WU00:FS01:0x22:             <peastman@stanford.edu>
14:26:24:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10044 -checkpoint 15
14:26:24:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:26:24:WU00:FS01:0x22:             0 -gpu 0
14:26:24:WU00:FS01:0x22:************************************ libFAH ************************************
14:26:24:WU00:FS01:0x22:       Time: 19:47:12
14:26:24:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:26:24:WU00:FS01:0x22:     Branch: HEAD
14:26:24:WU00:FS01:0x22:************************************ CBang *************************************
14:26:24:WU00:FS01:0x22:       Time: 19:46:11
14:26:24:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:26:24:WU00:FS01:0x22:     Branch: master
14:26:24:WU00:FS01:0x22:************************************ System ************************************
14:26:24:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:26:24:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:26:24:WU00:FS01:0x22:       CPUs: 2
14:26:24:WU00:FS01:0x22:     Memory: 3.98GiB
14:26:24:WU00:FS01:0x22:Free Memory: 1.73GiB
14:26:24:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:26:24:WU00:FS01:0x22: OS Version: 6.2
14:26:24:WU00:FS01:0x22:Has Battery: false
14:26:24:WU00:FS01:0x22: On Battery: false
14:26:24:WU00:FS01:0x22: UTC Offset: 1
14:26:24:WU00:FS01:0x22:        PID: 11712
14:26:24:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:26:24:WU00:FS01:0x22:********************************************************************************
14:26:24:WU00:FS01:0x22:Project: 13427 (Run 2317, Clone 8, Gen 4)
14:26:24:WU00:FS01:0x22:Unit: 0x0000000712bc7d9a5f586cec3dcb79cc
14:26:24:WU00:FS01:0x22:Reading tar file core.xml
14:26:24:WU00:FS01:0x22:Reading tar file integrator.xml
14:26:24:WU00:FS01:0x22:Reading tar file state.xml.bz2
14:26:24:WU00:FS01:0x22:Reading tar file system.xml.bz2
14:26:24:WU00:FS01:0x22:Digital signatures verified
14:26:24:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:26:24:WU00:FS01:0x22:Version 0.0.11
14:26:25:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:26:25:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:26:25:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:26:25:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:26:25:4:127.0.0.1:New Web session
14:26:28:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:26:28:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:26:28:WU00:FS01:0x22:Saving result file science.log
14:26:28:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:26:29:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:26:29:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2317 clone:8 gen:4 core:0x22 unit:0x0000000712bc7d9a5f586cec3dcb79cc
14:26:29:WU00:FS01:Uploading 2.44KiB to 18.188.125.154
14:26:29:WU00:FS01:Connecting to 18.188.125.154:8080
14:26:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:26:29:WU00:FS01:Upload complete
14:26:29:WU00:FS01:Server responded WORK_ACK (400)
14:26:29:WU00:FS01:Cleaning up
14:26:30:WU01:FS01:Assigned to work server 18.188.125.154
14:26:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:26:30:WU01:FS01:Connecting to 18.188.125.154:8080
14:26:30:WU01:FS01:Downloading 346.52KiB
14:26:30:WU01:FS01:Download complete
14:26:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13427 run:2318 clone:12 gen:0 core:0x22 unit:0x0000000112bc7d9a5f586cf04ab6c100
14:26:31:WU01:FS01:Starting
14:26:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:26:31:WU01:FS01:Started FahCore on PID 7076
14:26:31:WU01:FS01:Core PID:6600
14:26:31:WU01:FS01:FahCore 0x22 started
14:26:31:WU01:FS01:0x22:*********************** Log Started 2020-09-16T14:26:31Z ***********************
14:26:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:26:31:WU01:FS01:0x22:       Core: Core22
14:26:31:WU01:FS01:0x22:       Type: 0x22
14:26:31:WU01:FS01:0x22:    Version: 0.0.11
14:26:31:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:31:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:26:31:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:26:31:WU01:FS01:0x22:       Date: Jun 26 2020
14:26:31:WU01:FS01:0x22:       Time: 19:49:16
14:26:31:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:26:31:WU01:FS01:0x22:     Branch: core22-0.0.11
14:26:31:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:26:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:26:31:WU01:FS01:0x22:   Platform: win32 10
14:26:31:WU01:FS01:0x22:       Bits: 64
14:26:31:WU01:FS01:0x22:       Mode: Release
14:26:31:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:26:31:WU01:FS01:0x22:             <peastman@stanford.edu>
14:26:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7076 -checkpoint 15
14:26:31:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:26:31:WU01:FS01:0x22:             0 -gpu 0
14:26:31:WU01:FS01:0x22:************************************ libFAH ************************************
14:26:31:WU01:FS01:0x22:       Time: 19:47:12
14:26:31:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:26:31:WU01:FS01:0x22:     Branch: HEAD
14:26:31:WU01:FS01:0x22:************************************ CBang *************************************
14:26:31:WU01:FS01:0x22:       Time: 19:46:11
14:26:31:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:26:31:WU01:FS01:0x22:     Branch: master
14:26:31:WU01:FS01:0x22:************************************ System ************************************
14:26:31:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:26:31:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:26:31:WU01:FS01:0x22:       CPUs: 2
14:26:31:WU01:FS01:0x22:     Memory: 3.98GiB
14:26:31:WU01:FS01:0x22:Free Memory: 1.69GiB
14:26:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:26:31:WU01:FS01:0x22: OS Version: 6.2
14:26:31:WU01:FS01:0x22:Has Battery: false
14:26:31:WU01:FS01:0x22: On Battery: false
14:26:31:WU01:FS01:0x22: UTC Offset: 1
14:26:31:WU01:FS01:0x22:        PID: 6600
14:26:31:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:26:31:WU01:FS01:0x22:********************************************************************************
14:26:31:WU01:FS01:0x22:Project: 13427 (Run 2318, Clone 12, Gen 0)
14:26:31:WU01:FS01:0x22:Unit: 0x0000000112bc7d9a5f586cf04ab6c100
14:26:31:WU01:FS01:0x22:Reading tar file core.xml
14:26:31:WU01:FS01:0x22:Reading tar file integrator.xml
14:26:31:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:26:31:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:26:31:WU01:FS01:0x22:Digital signatures verified
14:26:31:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:26:31:WU01:FS01:0x22:Version 0.0.11
14:26:31:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:26:31:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:26:31:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:26:31:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:26:32:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:26:32:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:26:32:WU01:FS01:0x22:Saving result file science.log
14:26:32:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:26:33:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:26:33:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13427 run:2318 clone:12 gen:0 core:0x22 unit:0x0000000112bc7d9a5f586cf04ab6c100
14:26:33:WU01:FS01:Uploading 2.43KiB to 18.188.125.154
14:26:33:WU01:FS01:Connecting to 18.188.125.154:8080
14:26:33:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:26:33:WU01:FS01:Upload complete
14:26:33:WU01:FS01:Server responded WORK_ACK (400)
14:26:33:WU01:FS01:Cleaning up
14:26:34:WU00:FS01:Assigned to work server 18.188.125.154
14:26:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:26:34:WU00:FS01:Connecting to 18.188.125.154:8080
14:26:34:WU00:FS01:Downloading 345.69KiB
14:26:35:WU00:FS01:Download complete
14:26:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2319 clone:3 gen:5 core:0x22 unit:0x0000000712bc7d9a5f586cecb060c68e
14:26:35:WU00:FS01:Starting
14:26:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:26:35:WU00:FS01:Started FahCore on PID 11944
14:26:35:WU00:FS01:Core PID:11756
14:26:35:WU00:FS01:FahCore 0x22 started
14:26:35:WU00:FS01:0x22:*********************** Log Started 2020-09-16T14:26:35Z ***********************
14:26:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:26:35:WU00:FS01:0x22:       Core: Core22
14:26:35:WU00:FS01:0x22:       Type: 0x22
14:26:35:WU00:FS01:0x22:    Version: 0.0.11
14:26:35:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:35:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:26:35:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:26:35:WU00:FS01:0x22:       Date: Jun 26 2020
14:26:35:WU00:FS01:0x22:       Time: 19:49:16
14:26:35:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:26:35:WU00:FS01:0x22:     Branch: core22-0.0.11
14:26:35:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:26:36:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:26:36:WU00:FS01:0x22:   Platform: win32 10
14:26:36:WU00:FS01:0x22:       Bits: 64
14:26:36:WU00:FS01:0x22:       Mode: Release
14:26:36:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:26:36:WU00:FS01:0x22:             <peastman@stanford.edu>
14:26:36:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11944 -checkpoint 15
14:26:36:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:26:36:WU00:FS01:0x22:             0 -gpu 0
14:26:36:WU00:FS01:0x22:************************************ libFAH ************************************
14:26:36:WU00:FS01:0x22:       Date: Jun 26 2020
14:26:36:WU00:FS01:0x22:       Time: 19:47:12
14:26:36:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:26:36:WU00:FS01:0x22:     Branch: HEAD
14:26:36:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:26:36:WU00:FS01:0x22:************************************ CBang *************************************
14:26:36:WU00:FS01:0x22:       Time: 19:46:11
14:26:36:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:26:36:WU00:FS01:0x22:     Branch: master
14:26:36:WU00:FS01:0x22:************************************ System ************************************
14:26:36:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:26:36:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:26:36:WU00:FS01:0x22:       CPUs: 2
14:26:36:WU00:FS01:0x22:     Memory: 3.98GiB
14:26:36:WU00:FS01:0x22:Free Memory: 1.69GiB
14:26:36:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:26:36:WU00:FS01:0x22: OS Version: 6.2
14:26:36:WU00:FS01:0x22:Has Battery: false
14:26:36:WU00:FS01:0x22: On Battery: false
14:26:36:WU00:FS01:0x22: UTC Offset: 1
14:26:36:WU00:FS01:0x22:        PID: 11756
14:26:36:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:26:36:WU00:FS01:0x22:********************************************************************************
14:26:36:WU00:FS01:0x22:Project: 13427 (Run 2319, Clone 3, Gen 5)
14:26:36:WU00:FS01:0x22:Unit: 0x0000000712bc7d9a5f586cecb060c68e
14:26:36:WU00:FS01:0x22:Reading tar file core.xml
14:26:36:WU00:FS01:0x22:Reading tar file integrator.xml
14:26:36:WU00:FS01:0x22:Reading tar file state.xml.bz2
14:26:36:WU00:FS01:0x22:Reading tar file system.xml.bz2
14:26:36:WU00:FS01:0x22:Digital signatures verified
14:26:36:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:26:36:WU00:FS01:0x22:Version 0.0.11
14:26:36:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:26:36:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:26:36:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:26:36:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:26:36:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:26:36:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:26:36:WU00:FS01:0x22:Saving result file science.log
14:26:36:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:26:37:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:26:37:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2319 clone:3 gen:5 core:0x22 unit:0x0000000712bc7d9a5f586cecb060c68e
14:26:37:WU00:FS01:Uploading 2.43KiB to 18.188.125.154
14:26:37:WU00:FS01:Connecting to 18.188.125.154:8080
14:26:37:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:26:37:WU00:FS01:Upload complete
14:26:37:WU00:FS01:Server responded WORK_ACK (400)
14:26:37:WU00:FS01:Cleaning up
14:26:37:WU01:FS01:Assigned to work server 66.170.111.50
14:26:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 66.170.111.50
14:26:37:WU01:FS01:Connecting to 66.170.111.50:8080
14:26:38:WU01:FS01:Downloading 11.16MiB
14:26:44:WU01:FS01:Download 52.64%
14:26:48:WU01:FS01:Download complete
14:26:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14485 run:0 clone:174 gen:27 core:0x22 unit:0x0000002442aa6f325f45dea95f49630a
14:26:48:WU01:FS01:Starting
14:26:48:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:26:48:WU01:FS01:Started FahCore on PID 10288
14:26:48:WU01:FS01:Core PID:11388
14:26:48:WU01:FS01:FahCore 0x22 started
14:26:48:WU01:FS01:0x22:*********************** Log Started 2020-09-16T14:26:48Z ***********************
14:26:48:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:26:48:WU01:FS01:0x22:       Core: Core22
14:26:48:WU01:FS01:0x22:       Type: 0x22
14:26:48:WU01:FS01:0x22:    Version: 0.0.11
14:26:48:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:48:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:26:48:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:26:48:WU01:FS01:0x22:       Date: Jun 26 2020
14:26:48:WU01:FS01:0x22:       Time: 19:49:16
14:26:48:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:26:48:WU01:FS01:0x22:     Branch: core22-0.0.11
14:26:48:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:26:48:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:26:48:WU01:FS01:0x22:   Platform: win32 10
14:26:48:WU01:FS01:0x22:       Bits: 64
14:26:48:WU01:FS01:0x22:       Mode: Release
14:26:48:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:26:48:WU01:FS01:0x22:             <peastman@stanford.edu>
14:26:48:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10288 -checkpoint 15
14:26:48:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:26:48:WU01:FS01:0x22:             0 -gpu 0
14:26:48:WU01:FS01:0x22:************************************ libFAH ************************************
14:26:48:WU01:FS01:0x22:       Time: 19:47:12
14:26:48:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:26:48:WU01:FS01:0x22:     Branch: HEAD
14:26:48:WU01:FS01:0x22:************************************ CBang *************************************
14:26:48:WU01:FS01:0x22:       Time: 19:46:11
14:26:48:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:26:48:WU01:FS01:0x22:     Branch: master
14:26:48:WU01:FS01:0x22:************************************ System ************************************
14:26:48:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:26:48:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:26:48:WU01:FS01:0x22:       CPUs: 2
14:26:48:WU01:FS01:0x22:     Memory: 3.98GiB
14:26:48:WU01:FS01:0x22:Free Memory: 1.70GiB
14:26:48:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:26:48:WU01:FS01:0x22: OS Version: 6.2
14:26:48:WU01:FS01:0x22:Has Battery: false
14:26:48:WU01:FS01:0x22: On Battery: false
14:26:48:WU01:FS01:0x22: UTC Offset: 1
14:26:48:WU01:FS01:0x22:        PID: 11388
14:26:48:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:26:48:WU01:FS01:0x22:********************************************************************************
14:26:48:WU01:FS01:0x22:Project: 14485 (Run 0, Clone 174, Gen 27)
14:26:48:WU01:FS01:0x22:Unit: 0x0000002442aa6f325f45dea95f49630a
14:26:48:WU01:FS01:0x22:Reading tar file core.xml
14:26:48:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
14:26:48:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:26:48:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:26:48:WU01:FS01:0x22:Digital signatures verified
14:26:48:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:26:48:WU01:FS01:0x22:Version 0.0.11
14:26:48:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
14:26:48:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
14:26:48:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
14:26:48:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
14:27:08:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:27:08:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:27:08:WU01:FS01:0x22:Saving result file science.log
14:27:08:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:27:08:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:27:09:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14485 run:0 clone:174 gen:27 core:0x22 unit:0x0000002442aa6f325f45dea95f49630a
14:27:09:WU01:FS01:Uploading 10.00KiB to 66.170.111.50
14:27:09:WU01:FS01:Connecting to 66.170.111.50:8080
14:27:09:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:27:09:WU01:FS01:Upload complete
14:27:09:WU01:FS01:Server responded WORK_ACK (400)
14:27:09:WU01:FS01:Cleaning up
14:27:09:WU00:FS01:Assigned to work server 18.188.125.154
14:27:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:27:09:WU00:FS01:Connecting to 18.188.125.154:8080
14:27:10:WU00:FS01:Downloading 345.00KiB
14:27:10:WU00:FS01:Download complete
14:27:10:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2321 clone:0 gen:5 core:0x22 unit:0x0000000b12bc7d9a5f586cebc89f6a5c
14:27:11:WU00:FS01:Starting
14:27:11:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:27:11:WU00:FS01:Started FahCore on PID 10296
14:27:11:WU00:FS01:Core PID:12060
14:27:11:WU00:FS01:FahCore 0x22 started
14:27:11:WU00:FS01:0x22:*********************** Log Started 2020-09-16T14:27:11Z ***********************
14:27:11:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:27:11:WU00:FS01:0x22:       Core: Core22
14:27:11:WU00:FS01:0x22:       Type: 0x22
14:27:11:WU00:FS01:0x22:    Version: 0.0.11
14:27:11:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:11:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:27:11:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:27:11:WU00:FS01:0x22:       Date: Jun 26 2020
14:27:11:WU00:FS01:0x22:       Time: 19:49:16
14:27:11:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:27:11:WU00:FS01:0x22:     Branch: core22-0.0.11
14:27:11:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:27:11:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:27:11:WU00:FS01:0x22:   Platform: win32 10
14:27:11:WU00:FS01:0x22:       Bits: 64
14:27:11:WU00:FS01:0x22:       Mode: Release
14:27:11:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:27:11:WU00:FS01:0x22:             <peastman@stanford.edu>
14:27:11:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15
14:27:11:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:27:11:WU00:FS01:0x22:             0 -gpu 0
14:27:11:WU00:FS01:0x22:************************************ libFAH ************************************
14:27:11:WU00:FS01:0x22:       Time: 19:47:12
14:27:11:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:27:11:WU00:FS01:0x22:     Branch: HEAD
14:27:11:WU00:FS01:0x22:************************************ CBang *************************************
14:27:11:WU00:FS01:0x22:       Time: 19:46:11
14:27:11:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:27:11:WU00:FS01:0x22:     Branch: master
14:27:11:WU00:FS01:0x22:************************************ System ************************************
14:27:11:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:27:11:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:27:11:WU00:FS01:0x22:       CPUs: 2
14:27:11:WU00:FS01:0x22:     Memory: 3.98GiB
14:27:11:WU00:FS01:0x22:Free Memory: 1.76GiB
14:27:11:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:27:11:WU00:FS01:0x22: OS Version: 6.2
14:27:11:WU00:FS01:0x22:Has Battery: false
14:27:11:WU00:FS01:0x22: On Battery: false
14:27:11:WU00:FS01:0x22: UTC Offset: 1
14:27:11:WU00:FS01:0x22:        PID: 12060
14:27:11:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:27:11:WU00:FS01:0x22:********************************************************************************
14:27:11:WU00:FS01:0x22:Project: 13427 (Run 2321, Clone 0, Gen 5)
14:27:11:WU00:FS01:0x22:Unit: 0x0000000b12bc7d9a5f586cebc89f6a5c
14:27:11:WU00:FS01:0x22:Reading tar file core.xml
14:27:11:WU00:FS01:0x22:Reading tar file integrator.xml
14:27:11:WU00:FS01:0x22:Reading tar file state.xml.bz2
14:27:11:WU00:FS01:0x22:Reading tar file system.xml.bz2
14:27:11:WU00:FS01:0x22:Digital signatures verified
14:27:11:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:27:11:WU00:FS01:0x22:Version 0.0.11
14:27:11:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:27:11:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:27:11:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:27:11:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:27:12:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:27:12:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:27:12:WU00:FS01:0x22:Saving result file science.log
14:27:12:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:27:12:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:27:12:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2321 clone:0 gen:5 core:0x22 unit:0x0000000b12bc7d9a5f586cebc89f6a5c
14:27:12:WU00:FS01:Uploading 2.43KiB to 18.188.125.154
14:27:12:WU00:FS01:Connecting to 18.188.125.154:8080
14:27:13:WU00:FS01:Upload complete
14:27:13:WU00:FS01:Server responded WORK_ACK (400)
14:27:13:WU00:FS01:Cleaning up
14:27:13:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:27:13:WU01:FS01:Assigned to work server 18.188.125.154
14:27:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:27:13:WU01:FS01:Connecting to 18.188.125.154:8080
14:27:14:WU01:FS01:Downloading 343.63KiB
14:27:14:WU01:FS01:Download complete
14:27:14:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13427 run:2511 clone:4 gen:0 core:0x22 unit:0x0000000212bc7d9a5f586ce784b9b719
14:27:15:WU01:FS01:Starting
14:27:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:27:15:WU01:FS01:Started FahCore on PID 9288
14:27:15:WU01:FS01:Core PID:12216
14:27:15:WU01:FS01:FahCore 0x22 started
14:27:15:WU01:FS01:0x22:*********************** Log Started 2020-09-16T14:27:15Z ***********************
14:27:15:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:27:15:WU01:FS01:0x22:       Core: Core22
14:27:15:WU01:FS01:0x22:       Type: 0x22
14:27:15:WU01:FS01:0x22:    Version: 0.0.11
14:27:15:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:15:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:27:15:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:27:15:WU01:FS01:0x22:       Date: Jun 26 2020
14:27:15:WU01:FS01:0x22:       Time: 19:49:16
14:27:15:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:27:15:WU01:FS01:0x22:     Branch: core22-0.0.11
14:27:15:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:27:15:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:27:15:WU01:FS01:0x22:   Platform: win32 10
14:27:15:WU01:FS01:0x22:       Bits: 64
14:27:15:WU01:FS01:0x22:       Mode: Release
14:27:15:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:27:15:WU01:FS01:0x22:             <peastman@stanford.edu>
14:27:15:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9288 -checkpoint 15
14:27:15:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:27:15:WU01:FS01:0x22:             0 -gpu 0
14:27:15:WU01:FS01:0x22:************************************ libFAH ************************************
14:27:15:WU01:FS01:0x22:       Time: 19:47:12
14:27:15:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:27:15:WU01:FS01:0x22:     Branch: HEAD
14:27:15:WU01:FS01:0x22:************************************ CBang *************************************
14:27:15:WU01:FS01:0x22:       Time: 19:46:11
14:27:15:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:27:15:WU01:FS01:0x22:     Branch: master
14:27:15:WU01:FS01:0x22:************************************ System ************************************
14:27:15:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:27:15:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:27:15:WU01:FS01:0x22:       CPUs: 2
14:27:15:WU01:FS01:0x22:     Memory: 3.98GiB
14:27:15:WU01:FS01:0x22:Free Memory: 1.76GiB
14:27:15:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:27:15:WU01:FS01:0x22: OS Version: 6.2
14:27:15:WU01:FS01:0x22:Has Battery: false
14:27:15:WU01:FS01:0x22: On Battery: false
14:27:15:WU01:FS01:0x22: UTC Offset: 1
14:27:15:WU01:FS01:0x22:        PID: 12216
14:27:15:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:27:15:WU01:FS01:0x22:********************************************************************************
14:27:15:WU01:FS01:0x22:Project: 13427 (Run 2511, Clone 4, Gen 0)
14:27:15:WU01:FS01:0x22:Unit: 0x0000000212bc7d9a5f586ce784b9b719
14:27:15:WU01:FS01:0x22:Reading tar file core.xml
14:27:15:WU01:FS01:0x22:Reading tar file integrator.xml
14:27:15:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:27:15:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:27:15:WU01:FS01:0x22:Digital signatures verified
14:27:15:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:27:15:WU01:FS01:0x22:Version 0.0.11
14:27:15:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:27:15:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:27:15:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:27:15:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:27:16:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:27:16:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:27:16:WU01:FS01:0x22:Saving result file science.log
14:27:16:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:27:16:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:27:16:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13427 run:2511 clone:4 gen:0 core:0x22 unit:0x0000000212bc7d9a5f586ce784b9b719
14:27:16:WU01:FS01:Uploading 2.43KiB to 18.188.125.154
14:27:16:WU01:FS01:Connecting to 18.188.125.154:8080
14:27:17:WU01:FS01:Upload complete
14:27:17:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:27:17:WU01:FS01:Server responded WORK_ACK (400)
14:27:17:WU01:FS01:Cleaning up
14:27:17:WU00:FS01:Assigned to work server 18.188.125.154
14:27:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 18.188.125.154
14:27:17:WU00:FS01:Connecting to 18.188.125.154:8080
14:27:18:WU00:FS01:Downloading 345.18KiB
14:27:18:WU00:FS01:Download complete
14:27:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13427 run:2195 clone:13 gen:4 core:0x22 unit:0x0000000a12bc7d9a5f586ceecc60503a
14:27:18:WU00:FS01:Starting
14:27:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:27:18:WU00:FS01:Started FahCore on PID 11552
14:27:18:WU00:FS01:Core PID:10960
14:27:18:WU00:FS01:FahCore 0x22 started
14:27:19:WU00:FS01:0x22:*********************** Log Started 2020-09-16T14:27:18Z ***********************
14:27:19:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:27:19:WU00:FS01:0x22:       Core: Core22
14:27:19:WU00:FS01:0x22:       Type: 0x22
14:27:19:WU00:FS01:0x22:    Version: 0.0.11
14:27:19:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:19:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:27:19:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:27:19:WU00:FS01:0x22:       Date: Jun 26 2020
14:27:19:WU00:FS01:0x22:       Time: 19:49:16
14:27:19:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:27:19:WU00:FS01:0x22:     Branch: core22-0.0.11
14:27:19:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:27:19:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:27:19:WU00:FS01:0x22:   Platform: win32 10
14:27:19:WU00:FS01:0x22:       Bits: 64
14:27:19:WU00:FS01:0x22:       Mode: Release
14:27:19:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:27:19:WU00:FS01:0x22:             <peastman@stanford.edu>
14:27:19:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11552 -checkpoint 15
14:27:19:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:27:19:WU00:FS01:0x22:             0 -gpu 0
14:27:19:WU00:FS01:0x22:************************************ libFAH ************************************
14:27:19:WU00:FS01:0x22:       Time: 19:47:12
14:27:19:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:27:19:WU00:FS01:0x22:     Branch: HEAD
14:27:19:WU00:FS01:0x22:************************************ CBang *************************************
14:27:19:WU00:FS01:0x22:       Time: 19:46:11
14:27:19:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:27:19:WU00:FS01:0x22:     Branch: master
14:27:19:WU00:FS01:0x22:************************************ System ************************************
14:27:19:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:27:19:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:27:19:WU00:FS01:0x22:       CPUs: 2
14:27:19:WU00:FS01:0x22:     Memory: 3.98GiB
14:27:19:WU00:FS01:0x22:Free Memory: 1.76GiB
14:27:19:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:27:19:WU00:FS01:0x22: OS Version: 6.2
14:27:19:WU00:FS01:0x22:Has Battery: false
14:27:19:WU00:FS01:0x22: On Battery: false
14:27:19:WU00:FS01:0x22: UTC Offset: 1
14:27:19:WU00:FS01:0x22:        PID: 10960
14:27:19:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:27:19:WU00:FS01:0x22:********************************************************************************
14:27:19:WU00:FS01:0x22:Project: 13427 (Run 2195, Clone 13, Gen 4)
14:27:19:WU00:FS01:0x22:Unit: 0x0000000a12bc7d9a5f586ceecc60503a
14:27:19:WU00:FS01:0x22:Reading tar file core.xml
14:27:19:WU00:FS01:0x22:Reading tar file integrator.xml
14:27:19:WU00:FS01:0x22:Reading tar file state.xml.bz2
14:27:19:WU00:FS01:0x22:Reading tar file system.xml.bz2
14:27:19:WU00:FS01:0x22:Digital signatures verified
14:27:19:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:27:19:WU00:FS01:0x22:Version 0.0.11
14:27:19:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:27:19:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:27:19:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:27:19:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:27:19:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:27:19:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:27:19:WU00:FS01:0x22:Saving result file science.log
14:27:20:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:27:20:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:27:20:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13427 run:2195 clone:13 gen:4 core:0x22 unit:0x0000000a12bc7d9a5f586ceecc60503a
14:27:20:WU00:FS01:Uploading 2.44KiB to 18.188.125.154
14:27:20:WU00:FS01:Connecting to 18.188.125.154:8080
14:27:20:WU00:FS01:Upload complete
14:27:20:WU00:FS01:Server responded WORK_ACK (400)
14:27:20:WU00:FS01:Cleaning up
14:27:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:27:21:WU01:FS01:Assigned to work server 66.170.111.50
14:27:21:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1389 from 66.170.111.50
14:27:21:WU01:FS01:Connecting to 66.170.111.50:8080
14:27:21:WU01:FS01:Downloading 10.20MiB
14:27:27:WU01:FS01:Download 46.58%
14:27:31:WU01:FS01:Download complete
14:27:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14487 run:0 clone:477 gen:31 core:0x22 unit:0x0000002a42aa6f325f45deaadd7d4589
14:27:31:WU01:FS01:Starting
14:27:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12116 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:27:32:WU01:FS01:Started FahCore on PID 11080
14:27:32:WU01:FS01:Core PID:11452
14:27:32:WU01:FS01:FahCore 0x22 started
14:27:32:WU01:FS01:0x22:*********************** Log Started 2020-09-16T14:27:32Z ***********************
14:27:32:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:27:32:WU01:FS01:0x22:       Core: Core22
14:27:32:WU01:FS01:0x22:       Type: 0x22
14:27:32:WU01:FS01:0x22:    Version: 0.0.11
14:27:32:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:32:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:27:32:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:27:32:WU01:FS01:0x22:       Date: Jun 26 2020
14:27:32:WU01:FS01:0x22:       Time: 19:49:16
14:27:32:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
14:27:32:WU01:FS01:0x22:     Branch: core22-0.0.11
14:27:32:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:27:32:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:27:32:WU01:FS01:0x22:   Platform: win32 10
14:27:32:WU01:FS01:0x22:       Bits: 64
14:27:32:WU01:FS01:0x22:       Mode: Release
14:27:32:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:27:32:WU01:FS01:0x22:             <peastman@stanford.edu>
14:27:32:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11080 -checkpoint 15
14:27:32:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:27:32:WU01:FS01:0x22:             0 -gpu 0
14:27:32:WU01:FS01:0x22:************************************ libFAH ************************************
14:27:32:WU01:FS01:0x22:       Time: 19:47:12
14:27:32:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:27:32:WU01:FS01:0x22:     Branch: HEAD
14:27:32:WU01:FS01:0x22:************************************ CBang *************************************
14:27:32:WU01:FS01:0x22:       Time: 19:46:11
14:27:32:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:27:32:WU01:FS01:0x22:     Branch: master
14:27:32:WU01:FS01:0x22:************************************ System ************************************
14:27:32:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
14:27:32:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:27:32:WU01:FS01:0x22:       CPUs: 2
14:27:32:WU01:FS01:0x22:     Memory: 3.98GiB
14:27:32:WU01:FS01:0x22:Free Memory: 1.72GiB
14:27:32:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:27:32:WU01:FS01:0x22: OS Version: 6.2
14:27:32:WU01:FS01:0x22:Has Battery: false
14:27:32:WU01:FS01:0x22: On Battery: false
14:27:32:WU01:FS01:0x22: UTC Offset: 1
14:27:32:WU01:FS01:0x22:        PID: 11452
14:27:32:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
14:27:32:WU01:FS01:0x22:********************************************************************************
14:27:32:WU01:FS01:0x22:Project: 14487 (Run 0, Clone 477, Gen 31)
14:27:32:WU01:FS01:0x22:Unit: 0x0000002a42aa6f325f45deaadd7d4589
14:27:32:WU01:FS01:0x22:Reading tar file core.xml
14:27:32:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
14:27:32:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:27:32:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:27:32:WU01:FS01:0x22:Digital signatures verified
14:27:32:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:27:32:WU01:FS01:0x22:Version 0.0.11
14:27:32:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
14:27:32:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
14:27:32:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
14:27:32:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
14:27:50:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (222)
14:27:50:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:27:50:WU01:FS01:0x22:Saving result file science.log
14:27:50:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:27:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:27:50:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14487 run:0 clone:477 gen:31 core:0x22 unit:0x0000002a42aa6f325f45deaadd7d4589
silverpulser
Post by silverpulser »
I have tried uninstalling FAH, restarted the computer and reinstalled FAH, It is still showing every attempted WU as Bad Work Unit.
JohnChodera
Pande Group Member
Post by JohnChodera »
I'm glad you posted! We've been seeing a few cases of this error:
This isn't a valid OpenCL error code, and likely means there is something going wrong with the NVIDIA driver. Which driver version do you have installed? Is there any chance this was updated recently? Does rebooting help?
If we can't resolve this here, we'll pull you into the developers slack if you DM me your email address.
~ John Chodera // MSKCC
silverpulser
The driver is 460.15 which has worked fine up until very recently.
H'mm, just noticed an anomaly. My other machine ( a recent new build) has a 1650 super and shows the driver as 452.06. Both machines use Geforce Experience to detect and upgrade drivers as and when they become available. So why does my older 750ti have a newer driver version than my 1650 super?
That's interesting to note that the client thinks you have this version of Nvidia's driver:
Driver:460.15
However, there's no such version on the website including any Beta's for Windows 10 64-bit (https://www.nvidia.com/Download/Find.aspx?lang=en-uk). Just wondering if you used Microsoft Windows Update to install the drivers or did you download it from somewhere other than Nvidia's site?
silverpulser
Oh, it shows the same 460.15 version in both the Nvidia control panel system information and GPU-Z. This is puzzling. Should I uninstall 460.15 and install 452.06?
Post by Neil-B »
I'm not seeing errors with 452.06 on any of my kit (which includes a gtx750ti, but that is a very small sample rate) ... might be worth a try
Out of curiosity, from where did you download the drivers?
I have read that those systems that have messed up Drivers, using DDU (https://www.guru3d.com/files-details/di ... nload.html) has helped out. I have previously used it many years ago so give that a shot and see what happens.
EDIT: The reason I am keen to find out how you got that driver version is because we need that information to help out other donors and potentially work with Nvidia if that's a driver related issue.
silverpulser
I got the driver using Geforce Experience. I wonder whether the fact that I am running Windows Insider on this machine makes any difference. I am in the Dev channel and running the latest weekly build 20215.1. The problem began whilst running the previous build and carried over to the latest build.
Just Googled Nvidia driver version 460.15 and got some results. Here is a description from a result and the list of supported Video cards includes the 750Ti:
Nvidia Geforce Graphics DEV driver 460.15 WHQL CUDA_WSL WHQL (GRD)
DriverVer = 08/28/2020, 27.21.14.6015
WHQL Cert. & Signed from August 30, 2020
Driver branch: bugfix_main-16604
Vulkan API 1.2.149
This technology preview driver is available to Microsoft Windows Insiders Program members for enabling CUDA support for Windows Subsystem for Linux (WSL 2). With WSL 2 and GPU paravirtualization technology, Microsoft enables developers to run NVIDIA GPU accelerated applications on Windows. DirectML support is included in these drivers.
Post by Neil-B »
Have found various links https://www.geeks3d.com/forums/index.php?topic=6640.0 ... looks like a nvidia development release https://developer.nvidia.com/46015-game ... ernational but I guess someone has copied/released via other routes?
... and to the Microsoft insider priogram !! :)
Humm... thanks for that information. I will pass it on shortly and see what happens :)
Officially speaking, F@H recommends to use stable OS and Driver releases. Occasionally, even WHQL driver releases have been known to cause issues in which case the Vendor was notified and a hot fix was provided with urgency. Thus, for those systems that are dedicated folding systems, updating drivers often isn't done, maybe on a quarterly basis once it is known that the release doesn't cause issues.
Since those of us who are mere mortals can't get 460.xx, the only realistic option FAH can use is to hear back from you the results of going back to 452.xx. We have to assume you're running a driver that has been released to the pubic.
silverpulser
I uninstalled 460.15 and restarted the computer which then loaded in 452.06 without any input by me!. All seems to be working normally again.
I have posted on the Windows Insider forum and will watch for any response.
