BAD_WORK_UNIT (114 = 0x72)
Forcinghavok
Post by Forcinghavok »
Just curious whats going on with all these bad work units? Does anybody have any idea whats up with the bad work units?
22:27:11:WU02:FS00:0xa7:*********************** Log Started 2020-09-15T22:27:11Z ***********************
22:27:11:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:27:11:WU02:FS00:0xa7:       Type: 0xa7
22:27:11:WU02:FS00:0xa7:       Core: Gromacs
22:27:11:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4184 -checkpoint 3 -np 4
22:27:11:WU02:FS00:0xa7:************************************ CBang *************************************
22:27:11:WU02:FS00:0xa7:       Date: Nov 27 2019
22:27:11:WU02:FS00:0xa7:       Time: 03:40:09
22:27:11:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:27:12:WU02:FS00:0xa7:     Branch: master
22:27:12:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
22:27:12:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:27:12:WU02:FS00:0xa7:   Platform: win32 10
22:27:12:WU02:FS00:0xa7:       Bits: 64
22:27:12:WU02:FS00:0xa7:       Mode: Release
22:27:12:WU02:FS00:0xa7:************************************ System ************************************
22:27:12:WU02:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:27:12:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:27:12:WU02:FS00:0xa7:       CPUs: 8
22:27:12:WU02:FS00:0xa7:     Memory: 15.90GiB
22:27:12:WU02:FS00:0xa7:Free Memory: 12.95GiB
22:27:12:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
22:27:12:WU02:FS00:0xa7: OS Version: 6.2
22:27:12:WU02:FS00:0xa7:Has Battery: false
22:27:12:WU02:FS00:0xa7: On Battery: false
22:27:12:WU02:FS00:0xa7: UTC Offset: -4
22:27:12:WU02:FS00:0xa7:        PID: 8220
22:27:12:WU02:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
22:27:12:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
22:27:12:WU02:FS00:0xa7:    Version: 0.0.19
22:27:12:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:27:12:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:27:12:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
22:27:12:WU02:FS00:0xa7:       Date: Nov 25 2019
22:27:12:WU02:FS00:0xa7:       Time: 17:12:41
22:27:12:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:27:12:WU02:FS00:0xa7:************************************ Build *************************************
22:27:12:WU02:FS00:0xa7:       SIMD: avx_256
22:27:12:WU02:FS00:0xa7:********************************************************************************
22:27:12:WU02:FS00:0xa7:Project: 14833 (Run 135, Clone 2, Gen 303)
22:27:12:WU02:FS00:0xa7:Unit: 0x00000139455e42075ef0d5a007bd7ba3
22:27:12:WU02:FS00:0xa7:Digital signatures verified
22:27:12:WU02:FS00:0xa7:Calling: mdrun -s frame303.tpr -o frame303.trr -cpi state.cpt -cpt 3 -nt 4
22:27:12:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:27:12:WARNING:WU01:FS01:Too many errors, failing
22:27:12:WU02:FS00:0xa7:Steps: first=0 total=250000
22:27:12:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:14906 run:340 clone:2 gen:5 core:0x22 unit:0x0000000a81d59d695f4ec9d449a177fd
22:27:12:WU01:FS01:Connecting to 129.213.157.105:8080
22:27:13:WU02:FS00:0xa7:Completed 9240 out of 250000 steps (3%)
22:27:13:WU00:FS01:Connecting to assign1.foldingathome.org:80
22:27:13:WU01:FS01:Server responded WORK_ACK (400)
22:27:13:WU01:FS01:Cleaning up
22:27:14:WU00:FS01:Assigned to work server 155.247.166.220
22:27:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 155.247.166.220
22:27:14:WU00:FS01:Connecting to 155.247.166.220:8080
22:27:15:WU00:FS01:Downloading 9.00MiB
22:27:18:WU00:FS01:Download complete
22:27:19:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16920 run:65 clone:21 gen:162 core:0x22 unit:0x000000c70002894c5f2a13c66c3f1e1c
Re: BAD_WORK_UNIT (114 = 0x72)
No part of the configuration portion of the log is displayed, typically the first 200 lines, so we know nothing about your PC
No part of the WU before the error is displayed, so we have no idea what details of the WU may be in error.
Please help us help you.
AFAIK, there's nothing in the WU Database. It might appear in the next few hours: https://apps.foldingathome.org/wu#proje ... =2&gen=303
Forcinghavok
Are the logs in another folder? Below is where they used to be.
C:\Users\erikb\AppData\Roaming\FAHClient\logs
I don't have an entry for that date the 15th!
Forcinghavok
I found something in the FAHclient folder. It was just called log. I believe this is the full log from that day. The bad work unit is below. Thank you.
*********************** Log Started 2020-09-14T19:43:13Z ***********************
19:43:13:Trying to access database...
19:43:13:Successfully acquired database lock
19:43:13:Read GPUs.txt
19:43:14:Enabled folding slot 00: READY cpu:4
19:43:15:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
19:43:15:****************************** FAHClient ******************************
19:43:15:        Version: 7.6.13
19:43:15:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:43:15:      Copyright: 2020 foldingathome.org
19:43:15:       Homepage: https://foldingathome.org/
19:43:15:           Date: Apr 27 2020
19:43:15:           Time: 21:21:01
19:43:15:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:43:15:         Branch: master
19:43:15:       Compiler: Visual C++ 2008
19:43:15:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:15:       Platform: win32 10
19:43:15:           Bits: 32
19:43:15:           Mode: Release
19:43:15:         Config: C:\Users\erikb\AppData\Roaming\FAHClient\config.xml
19:43:15:******************************** CBang ********************************
19:43:15:           Date: Apr 24 2020
19:43:15:           Time: 17:07:55
19:43:15:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:43:15:           Bits: 32
19:43:15:******************************* System ********************************
19:43:15:            CPU: AMD FX(tm)-8350 Eight-Core Processor
19:43:15:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:43:15:           CPUs: 8
19:43:15:         Memory: 15.90GiB
19:43:15:    Free Memory: 13.36GiB
19:43:15:        Threads: WINDOWS_THREADS
19:43:15:     OS Version: 6.2
19:43:15:    Has Battery: false
19:43:15:     On Battery: false
19:43:15:     UTC Offset: -4
19:43:15:            PID: 8440
19:43:15:            CWD: C:\Users\erikb\AppData\Roaming\FAHClient
19:43:15:  Win32 Service: false
19:43:15:             OS: Windows 10 Home
19:43:15:        OS Arch: AMD64
19:43:15:           GPUs: 1
19:43:15:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
19:43:15:                 470/480/570/580/590]
19:43:15:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:43:15:                 specified module could not be found.
19:43:15:
19:43:15:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3110.7
19:43:15:******************************* libFAH ********************************
19:43:15:           Date: Apr 15 2020
19:43:15:           Time: 14:53:14
19:43:15:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:43:15:           Bits: 32
19:43:15:***********************************************************************
19:43:16:<config>
19:43:16:  <!-- Folding Core -->
19:43:16:  <checkpoint v='3'/>
19:43:16:
19:43:16:  <!-- Network -->
19:43:16:  <proxy v=':8080'/>
19:43:16:
19:43:16:  <!-- Slot Control -->
19:43:16:  <pause-on-battery v='false'/>
19:43:16:  <power v='full'/>
19:43:16:
19:43:16:  <!-- User Information -->
19:43:16:  <team v='2092'/>
19:43:16:  <user v='ForcingHavok'/>
19:43:16:
19:43:16:  <!-- Folding Slots -->
19:43:16:  <slot id='0' type='CPU'>
19:43:16:    <cpus v='4'/>
19:43:16:  </slot>
19:43:16:  <slot id='1' type='GPU'/>
19:43:16:</config>
19:43:16:WU01:FS01:Starting
19:43:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:43:16:WU01:FS01:Started FahCore on PID 8972
19:43:16:WU01:FS01:Core PID:8996
19:43:16:WU01:FS01:FahCore 0x22 started
19:43:17:WU02:FS00:Starting
19:43:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -np 4
19:43:17:WU02:FS00:Started FahCore on PID 9120
19:43:19:WU02:FS00:Core PID:9200
19:43:19:WU02:FS00:FahCore 0xa7 started
19:43:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:43:21:WU02:FS00:0xa7:*********************** Log Started 2020-09-14T19:43:20Z ***********************
19:43:21:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:43:21:WU02:FS00:0xa7:       Type: 0xa7
19:43:21:WU02:FS00:0xa7:       Core: Gromacs
19:43:21:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9120 -checkpoint 3 -np 4
19:43:21:WU02:FS00:0xa7:************************************ CBang *************************************
19:43:21:WU02:FS00:0xa7:       Date: Nov 27 2019
19:43:21:WU02:FS00:0xa7:       Time: 03:40:09
19:43:21:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
19:43:21:WU02:FS00:0xa7:     Branch: master
19:43:21:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
19:43:21:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:21:WU02:FS00:0xa7:   Platform: win32 10
19:43:21:WU02:FS00:0xa7:       Bits: 64
19:43:21:WU02:FS00:0xa7:       Mode: Release
19:43:21:WU02:FS00:0xa7:************************************ System ************************************
19:43:21:WU02:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:43:21:WU01:FS01:Starting
19:43:21:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:43:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:43:21:WU02:FS00:0xa7:       CPUs: 8
19:43:21:WU02:FS00:0xa7:     Memory: 15.90GiB
19:43:21:WU01:FS01:Started FahCore on PID 8312
19:43:21:WU02:FS00:0xa7:Free Memory: 13.38GiB
19:43:21:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
19:43:21:WU02:FS00:0xa7: OS Version: 6.2
19:43:21:WU02:FS00:0xa7:Has Battery: false
19:43:21:WU02:FS00:0xa7: On Battery: false
19:43:21:WU02:FS00:0xa7: UTC Offset: -4
19:43:21:WU02:FS00:0xa7:        PID: 9200
19:43:21:WU01:FS01:Core PID:8392
19:43:21:WU02:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
19:43:21:WU01:FS01:FahCore 0x22 started
19:43:21:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
19:43:21:WU02:FS00:0xa7:    Version: 0.0.19
19:43:21:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:43:21:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:43:21:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
19:43:21:WU02:FS00:0xa7:       Date: Nov 25 2019
19:43:21:WU02:FS00:0xa7:       Time: 17:12:41
19:43:21:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
19:43:21:WU02:FS00:0xa7:************************************ Build *************************************
19:43:21:WU02:FS00:0xa7:       SIMD: avx_256
19:43:21:WU02:FS00:0xa7:********************************************************************************
19:43:21:WU02:FS00:0xa7:Project: 14833 (Run 135, Clone 2, Gen 303)
19:43:21:WU02:FS00:0xa7:Unit: 0x00000139455e42075ef0d5a007bd7ba3
19:43:21:WU02:FS00:0xa7:Digital signatures verified
19:43:21:WU02:FS00:0xa7:Calling: mdrun -s frame303.tpr -o frame303.trr -cpi state.cpt -cpt 3 -nt 4
19:43:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:43:23:WU02:FS00:0xa7:Steps: first=0 total=250000
19:43:23:WU02:FS00:0xa7:Completed 9171 out of 250000 steps (3%)
19:43:30:FS00:Shutting core down
19:43:30:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 9200
19:43:30:WU02:FS00:0xa7:Exiting, please wait. . .
19:43:32:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:43:34:FS00:Paused
19:43:34:FS01:Paused
19:44:14:Removing old file 'configs/config-20200910-201647.xml'
19:44:14:Saving configuration to config.xml
19:44:14:<config>
19:44:14:  <!-- Folding Core -->
19:44:14:  <checkpoint v='3'/>
19:44:14:
19:44:14:  <!-- Network -->
19:44:14:  <proxy v=':8080'/>
19:44:14:
19:44:14:  <!-- Slot Control -->
19:44:14:  <pause-on-battery v='false'/>
19:44:14:  <power v='full'/>
19:44:14:
19:44:14:  <!-- User Information -->
19:44:14:  <team v='2092'/>
19:44:14:  <user v='ForcingHavok'/>
19:44:14:
19:44:14:  <!-- Folding Slots -->
19:44:14:  <slot id='0' type='CPU'>
19:44:14:    <cpus v='4'/>
19:44:14:    <idle v='true'/>
19:44:14:    <paused v='true'/>
19:44:14:  </slot>
19:44:14:  <slot id='1' type='GPU'>
19:44:14:  </slot>
19:44:14:</config>
19:46:25:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
******************************* Date: 2020-09-15 *******************************
22:27:10:FS00:Unpaused
22:27:10:FS01:Unpaused
22:27:10:WU01:FS01:Starting
22:27:10:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:27:10:WU01:FS01:Started FahCore on PID 7956
22:27:10:WU01:FS01:Core PID:4584
22:27:10:WU01:FS01:FahCore 0x22 started
22:27:11:WU02:FS00:Starting
22:27:11:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -np 4
22:27:11:WU02:FS00:Started FahCore on PID 4184
22:27:11:WU02:FS00:Core PID:8220
22:27:11:WU02:FS00:FahCore 0xa7 started
22:27:19:WU00:FS01:Starting
22:27:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:27:19:WU00:FS01:Started FahCore on PID 9084
22:27:19:WU00:FS01:Core PID:1264
22:27:19:WU00:FS01:FahCore 0x22 started
22:27:19:WU00:FS01:0x22:*********************** Log Started 2020-09-15T22:27:19Z ***********************
22:27:19:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:27:19:WU00:FS01:0x22:       Core: Core22
22:27:19:WU00:FS01:0x22:       Type: 0x22
22:27:19:WU00:FS01:0x22:    Version: 0.0.11
22:27:19:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:27:19:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
22:27:19:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
22:27:19:WU00:FS01:0x22:       Date: Jun 26 2020
22:27:19:WU00:FS01:0x22:       Time: 19:49:16
22:27:19:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
22:27:19:WU00:FS01:0x22:     Branch: core22-0.0.11
22:27:19:WU00:FS01:0x22:   Compiler: Visual C++ 2015
22:27:19:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:27:19:WU00:FS01:0x22:   Platform: win32 10
22:27:19:WU00:FS01:0x22:       Bits: 64
22:27:19:WU00:FS01:0x22:       Mode: Release
22:27:19:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:27:19:WU00:FS01:0x22:             <peastman@stanford.edu>
22:27:19:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9084 -checkpoint 3
22:27:19:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:27:19:WU00:FS01:0x22:************************************ libFAH ************************************
22:27:19:WU00:FS01:0x22:       Time: 19:47:12
22:27:19:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
22:27:19:WU00:FS01:0x22:     Branch: HEAD
22:27:19:WU00:FS01:0x22:************************************ CBang *************************************
22:27:19:WU00:FS01:0x22:       Time: 19:46:11
22:27:19:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
22:27:19:WU00:FS01:0x22:     Branch: master
22:27:19:WU00:FS01:0x22:************************************ System ************************************
22:27:19:WU00:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:27:19:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:27:19:WU00:FS01:0x22:       CPUs: 8
22:27:19:WU00:FS01:0x22:     Memory: 15.90GiB
22:27:19:WU00:FS01:0x22:Free Memory: 12.86GiB
22:27:19:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
22:27:19:WU00:FS01:0x22: OS Version: 6.2
22:27:19:WU00:FS01:0x22:Has Battery: false
22:27:19:WU00:FS01:0x22: On Battery: false
22:27:19:WU00:FS01:0x22: UTC Offset: -4
22:27:19:WU00:FS01:0x22:        PID: 1264
22:27:19:WU00:FS01:0x22:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
22:27:19:WU00:FS01:0x22:********************************************************************************
22:27:19:WU00:FS01:0x22:Project: 16920 (Run 65, Clone 21, Gen 162)
22:27:19:WU00:FS01:0x22:Unit: 0x000000c70002894c5f2a13c66c3f1e1c
22:27:19:WU00:FS01:0x22:Reading tar file core.xml
22:27:19:WU00:FS01:0x22:Reading tar file integrator.xml
22:27:19:WU00:FS01:0x22:Reading tar file state.xml
22:27:19:WU00:FS01:0x22:Reading tar file system.xml
22:27:19:WU00:FS01:0x22:Digital signatures verified
22:27:19:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:27:19:WU00:FS01:0x22:Version 0.0.11
22:27:19:WU00:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
22:27:19:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
22:27:19:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
22:27:19:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
22:27:28:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
22:27:58:Removing old file 'configs/config-20200910-235926.xml'
22:27:58:Saving configuration to config.xml
22:27:58:<config>
22:27:58:  <!-- Folding Core -->
22:27:58:  <checkpoint v='3'/>
22:27:58:
22:27:58:  <!-- Network -->
22:27:58:  <proxy v=':8080'/>
22:27:58:
22:27:58:  <!-- Slot Control -->
22:27:58:  <pause-on-battery v='false'/>
22:27:58:  <power v='full'/>
22:27:58:
22:27:58:  <!-- User Information -->
22:27:58:  <team v='2092'/>
22:27:58:  <user v='ForcingHavok'/>
22:27:58:
22:27:58:  <!-- Folding Slots -->
22:27:58:  <slot id='0' type='CPU'>
22:27:58:    <cpus v='4'/>
22:27:58:  </slot>
22:27:58:  <slot id='1' type='GPU'/>
22:27:58:</config>
22:28:34:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
22:29:05:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
22:30:41:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
22:32:18:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
22:32:57:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
22:33:54:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
22:35:31:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
22:37:07:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
22:37:20:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
22:38:43:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
22:40:19:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
22:41:41:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
22:41:56:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
22:43:32:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
22:45:09:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
22:46:04:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
22:46:45:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
22:48:21:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
22:49:57:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
22:50:25:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
22:51:33:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
22:53:11:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
22:54:47:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
22:54:48:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
22:56:26:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
22:58:03:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
22:59:09:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
22:59:40:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
23:01:17:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
23:02:53:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
23:03:32:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
23:04:29:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
23:06:05:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
23:07:41:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
23:07:55:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
23:09:18:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
23:10:56:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
23:12:18:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
23:12:33:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
23:14:10:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
23:15:50:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
23:16:46:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
23:17:29:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
23:19:05:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
23:20:41:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
23:21:08:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
23:22:18:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
23:23:54:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
23:25:31:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
23:25:31:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
23:27:07:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
23:28:43:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
23:29:54:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
23:30:19:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
23:31:56:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
23:33:34:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
23:34:18:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
23:35:10:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
23:36:46:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
23:38:22:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
23:38:40:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:39:58:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
23:41:35:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
23:43:03:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:43:11:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
23:44:47:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
23:46:23:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
23:47:25:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
23:48:00:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
23:49:36:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
23:51:13:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
23:51:47:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
23:52:49:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
23:54:25:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
23:56:01:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
23:56:09:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
23:57:38:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
23:59:14:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
00:00:32:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
00:00:50:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
00:02:26:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
00:04:03:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
00:04:53:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
00:05:39:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
00:07:15:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
00:07:30:FS00:Shutting core down
00:07:30:FS01:Shutting core down
00:07:30:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 1264
00:07:30:WU00:FS01:0x22:Exiting, please wait. . .
00:07:30:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
00:07:30:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 8220
00:07:30:WU02:FS00:0xa7:Exiting, please wait. . .
00:07:31:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:07:32:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:07:34:FS00:Paused
00:07:34:FS01:Paused
00:07:36:Removing old file 'configs/config-20200911-020025.xml'
00:07:36:Saving configuration to config.xml
00:07:36:<config>
00:07:36:  <!-- Folding Core -->
00:07:36:  <checkpoint v='3'/>
00:07:36:
00:07:36:  <!-- Network -->
00:07:36:  <proxy v=':8080'/>
00:07:36:
00:07:36:  <!-- Slot Control -->
00:07:36:  <pause-on-battery v='false'/>
00:07:36:  <power v='full'/>
00:07:36:
00:07:36:  <!-- User Information -->
00:07:36:  <team v='2092'/>
00:07:36:  <user v='ForcingHavok'/>
00:07:36:
00:07:36:  <!-- Folding Slots -->
00:07:36:  <slot id='0' type='CPU'>
00:07:36:    <cpus v='4'/>
00:07:36:    <idle v='true'/>
00:07:36:    <paused v='true'/>
00:07:36:  </slot>
00:07:36:  <slot id='1' type='GPU'>
00:07:36:  </slot>
00:07:36:</config>
******************************* Date: 2020-09-16 *******************************
11:11:35:Removing old file 'configs/config-20200911-030630.xml'
11:11:35:Saving configuration to config.xml
11:11:35:<config>
11:11:35:  <!-- Folding Core -->
11:11:35:  <checkpoint v='3'/>
11:11:35:
11:11:35:  <!-- Network -->
11:11:35:  <proxy v=':8080'/>
11:11:35:
11:11:35:  <!-- Slot Control -->
11:11:35:  <pause-on-battery v='false'/>
11:11:35:  <power v='full'/>
11:11:35:
11:11:35:  <!-- User Information -->
11:11:35:  <team v='2092'/>
11:11:35:  <user v='ForcingHavok'/>
11:11:35:
11:11:35:  <!-- Folding Slots -->
11:11:35:  <slot id='0' type='CPU'>
11:11:35:    <cpus v='4'/>
11:11:35:    <paused v='true'/>
11:11:35:  </slot>
11:11:35:  <slot id='1' type='GPU'>
11:11:35:  </slot>
11:11:35:</config>
11:11:42:FS00:Unpaused
11:11:42:FS01:Unpaused
11:11:43:WU02:FS00:Starting
11:11:43:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -np 4
11:11:43:WU02:FS00:Started FahCore on PID 1828
11:11:43:WU02:FS00:Core PID:2628
11:11:43:WU02:FS00:FahCore 0xa7 started
11:11:43:WU00:FS01:Starting
11:11:43:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:11:43:WU00:FS01:Started FahCore on PID 6104
11:11:43:WU00:FS01:Core PID:9224
11:11:43:WU00:FS01:FahCore 0x22 started
11:11:44:WU02:FS00:0xa7:*********************** Log Started 2020-09-16T11:11:43Z ***********************
11:11:44:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:11:44:WU02:FS00:0xa7:       Type: 0xa7
11:11:44:WU02:FS00:0xa7:       Core: Gromacs
11:11:44:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 1828 -checkpoint 3 -np 4
11:11:44:WU02:FS00:0xa7:************************************ CBang *************************************
11:11:44:WU02:FS00:0xa7:       Date: Nov 27 2019
11:11:44:WU02:FS00:0xa7:       Time: 03:40:09
11:11:44:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:11:44:WU02:FS00:0xa7:     Branch: master
11:11:44:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
11:11:44:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:11:44:WU02:FS00:0xa7:   Platform: win32 10
11:11:44:WU02:FS00:0xa7:       Bits: 64
11:11:44:WU02:FS00:0xa7:       Mode: Release
11:11:44:WU02:FS00:0xa7:************************************ System ************************************
11:11:44:WU02:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
11:11:44:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
11:11:44:WU02:FS00:0xa7:       CPUs: 8
11:11:44:WU02:FS00:0xa7:     Memory: 15.90GiB
11:11:44:WU02:FS00:0xa7:Free Memory: 12.99GiB
11:11:44:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
11:11:44:WU02:FS00:0xa7: OS Version: 6.2
11:11:44:WU02:FS00:0xa7:Has Battery: false
11:11:44:WU02:FS00:0xa7: On Battery: false
11:11:44:WU02:FS00:0xa7: UTC Offset: -4
11:11:44:WU02:FS00:0xa7:        PID: 2628
11:11:44:WU02:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
11:11:44:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
11:11:44:WU02:FS00:0xa7:    Version: 0.0.19
11:11:44:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:11:44:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:11:44:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
11:11:44:WU02:FS00:0xa7:       Date: Nov 25 2019
11:11:44:WU02:FS00:0xa7:       Time: 17:12:41
11:11:44:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:11:44:WU02:FS00:0xa7:************************************ Build *************************************
11:11:44:WU02:FS00:0xa7:       SIMD: avx_256
11:11:44:WU02:FS00:0xa7:********************************************************************************
11:11:44:WU02:FS00:0xa7:Project: 14833 (Run 135, Clone 2, Gen 303)
11:11:44:WU02:FS00:0xa7:Unit: 0x00000139455e42075ef0d5a007bd7ba3
11:11:44:WU02:FS00:0xa7:Digital signatures verified
11:11:44:WU02:FS00:0xa7:Calling: mdrun -s frame303.tpr -o frame303.trr -cpi state.cpt -cpt 3 -nt 4
11:11:44:WU00:FS01:0x22:*********************** Log Started 2020-09-16T11:11:44Z ***********************
11:11:44:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:11:44:WU00:FS01:0x22:       Core: Core22
11:11:44:WU00:FS01:0x22:       Type: 0x22
11:11:44:WU00:FS01:0x22:    Version: 0.0.11
11:11:44:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:11:44:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
11:11:44:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
11:11:44:WU00:FS01:0x22:       Date: Jun 26 2020
11:11:44:WU00:FS01:0x22:       Time: 19:49:16
11:11:44:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
11:11:44:WU00:FS01:0x22:     Branch: core22-0.0.11
11:11:44:WU00:FS01:0x22:   Compiler: Visual C++ 2015
11:11:44:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
11:11:44:WU00:FS01:0x22:   Platform: win32 10
11:11:44:WU00:FS01:0x22:       Bits: 64
11:11:44:WU00:FS01:0x22:       Mode: Release
11:11:44:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:11:44:WU00:FS01:0x22:             <peastman@stanford.edu>
11:11:44:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6104 -checkpoint 3
11:11:44:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:11:44:WU00:FS01:0x22:************************************ libFAH ************************************
11:11:44:WU00:FS01:0x22:       Time: 19:47:12
11:11:44:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
11:11:44:WU00:FS01:0x22:     Branch: HEAD
11:11:44:WU00:FS01:0x22:************************************ CBang *************************************
11:11:44:WU00:FS01:0x22:       Time: 19:46:11
11:11:44:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
11:11:44:WU00:FS01:0x22:     Branch: master
11:11:44:WU00:FS01:0x22:************************************ System ************************************
11:11:44:WU00:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
11:11:44:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
11:11:44:WU00:FS01:0x22:       CPUs: 8
11:11:44:WU00:FS01:0x22:     Memory: 15.90GiB
11:11:44:WU00:FS01:0x22:Free Memory: 12.99GiB
11:11:44:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:11:44:WU00:FS01:0x22: OS Version: 6.2
11:11:44:WU00:FS01:0x22:Has Battery: false
11:11:44:WU00:FS01:0x22: On Battery: false
11:11:44:WU00:FS01:0x22: UTC Offset: -4
11:11:44:WU00:FS01:0x22:        PID: 9224
11:11:44:WU00:FS01:0x22:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
11:11:44:WU00:FS01:0x22:********************************************************************************
11:11:44:WU00:FS01:0x22:Project: 16920 (Run 65, Clone 21, Gen 162)
11:11:44:WU00:FS01:0x22:Unit: 0x000000c70002894c5f2a13c66c3f1e1c
11:11:44:WU00:FS01:0x22:Digital signatures verified
11:11:44:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:11:44:WU00:FS01:0x22:Version 0.0.11
11:11:45:WU00:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
11:11:45:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
11:11:45:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
11:11:45:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
11:11:45:WU02:FS00:0xa7:Steps: first=0 total=250000
11:11:46:WU02:FS00:0xa7:Completed 66502 out of 250000 steps (26%)
11:11:59:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
11:12:31:Removing old file 'configs/config-20200911-152415.xml'
11:12:31:Saving configuration to config.xml
11:12:31:<config>
11:12:31:  <!-- Folding Core -->
11:12:31:  <checkpoint v='3'/>
11:12:31:
11:12:31:  <!-- Network -->
11:12:31:  <proxy v=':8080'/>
11:12:31:
11:12:31:  <!-- Slot Control -->
11:12:31:  <pause-on-battery v='false'/>
11:12:31:  <power v='full'/>
11:12:31:
11:12:31:  <!-- User Information -->
11:12:31:  <team v='2092'/>
11:12:31:  <user v='ForcingHavok'/>
11:12:31:
11:12:31:  <!-- Folding Slots -->
11:12:31:  <slot id='0' type='CPU'>
11:12:31:    <cpus v='4'/>
11:12:31:  </slot>
11:12:31:  <slot id='1' type='GPU'/>
11:12:31:</config>
11:13:33:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
11:13:39:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
11:15:18:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
11:16:55:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
11:17:59:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
11:18:31:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
11:20:06:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
11:21:43:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
11:22:21:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
11:23:20:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
11:24:57:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
11:26:33:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
11:26:43:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
11:28:10:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
11:29:46:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
11:31:05:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
11:31:22:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
11:32:58:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
11:34:33:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
11:35:26:WU02:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
11:36:09:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
11:37:46:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
11:39:23:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
11:39:48:WU02:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
11:40:59:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
11:42:36:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
11:44:09:WU02:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
11:44:13:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
11:45:48:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
11:47:24:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
11:48:31:WU02:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
11:49:00:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
11:50:36:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
11:52:11:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
11:52:51:WU02:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
11:53:47:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
11:55:23:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
11:56:58:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
11:57:13:WU02:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
11:58:34:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
12:00:10:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
12:01:34:WU02:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
12:01:46:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
12:03:22:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
12:04:57:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
12:05:57:WU02:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
12:06:33:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
12:08:09:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
12:09:44:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
12:10:18:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
12:11:20:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
12:12:56:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
12:14:31:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
12:14:32:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:14:32:WU01:FS01:Assigned to work server 18.188.125.154
12:14:32:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
12:14:32:WU01:FS01:Connecting to 18.188.125.154:8080
12:14:33:WU01:FS01:Downloading 6.13MiB
12:14:34:WU01:FS01:Download complete
12:14:34:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13426 run:3697 clone:24 gen:2 core:0x22 unit:0x0000000312bc7d9a5f597cbd21ac0f9e
12:14:39:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
12:16:07:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
12:16:07:WU00:FS01:0x22:Average performance: 90.1879 ns/day
12:16:08:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
12:16:08:WU00:FS01:0x22:Saving result file checkpointState.xml
12:16:08:WU00:FS01:0x22:Saving result file positions.xtc
12:16:08:WU00:FS01:0x22:Saving result file science.log
12:16:08:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:16:08:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:16:08:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16920 run:65 clone:21 gen:162 core:0x22 unit:0x000000c70002894c5f2a13c66c3f1e1c
12:16:08:WU00:FS01:Uploading 6.71MiB to 155.247.166.220
12:16:08:WU00:FS01:Connecting to 155.247.166.220:8080
12:16:08:WU01:FS01:Starting
12:16:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8440 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:16:08:WU01:FS01:Started FahCore on PID 3172
12:16:08:WU01:FS01:Core PID:5516
12:16:08:WU01:FS01:FahCore 0x22 started
12:16:09:WU01:FS01:0x22:*********************** Log Started 2020-09-16T12:16:08Z ***********************
12:16:09:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:16:09:WU01:FS01:0x22:       Core: Core22
12:16:09:WU01:FS01:0x22:       Type: 0x22
12:16:09:WU01:FS01:0x22:    Version: 0.0.11
12:16:09:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:16:09:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
12:16:09:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
12:16:09:WU01:FS01:0x22:       Date: Jun 26 2020
12:16:09:WU01:FS01:0x22:       Time: 19:49:16
12:16:09:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
12:16:09:WU01:FS01:0x22:     Branch: core22-0.0.11
12:16:09:WU01:FS01:0x22:   Compiler: Visual C++ 2015
12:16:09:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:16:09:WU01:FS01:0x22:   Platform: win32 10
12:16:09:WU01:FS01:0x22:       Bits: 64
12:16:09:WU01:FS01:0x22:       Mode: Release
12:16:09:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:16:09:WU01:FS01:0x22:             <peastman@stanford.edu>
12:16:09:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3172 -checkpoint 3
12:16:09:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:16:09:WU01:FS01:0x22:************************************ libFAH ************************************
12:16:09:WU01:FS01:0x22:       Time: 19:47:12
12:16:09:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
12:16:09:WU01:FS01:0x22:     Branch: HEAD
12:16:09:WU01:FS01:0x22:************************************ CBang *************************************
12:16:09:WU01:FS01:0x22:       Time: 19:46:11
12:16:09:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
12:16:09:WU01:FS01:0x22:     Branch: master
12:16:09:WU01:FS01:0x22:************************************ System ************************************
12:16:09:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
12:16:09:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
12:16:09:WU01:FS01:0x22:       CPUs: 8
12:16:09:WU01:FS01:0x22:     Memory: 15.90GiB
12:16:09:WU01:FS01:0x22:Free Memory: 13.32GiB
12:16:09:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
12:16:09:WU01:FS01:0x22: OS Version: 6.2
12:16:09:WU01:FS01:0x22:Has Battery: false
12:16:09:WU01:FS01:0x22: On Battery: false
12:16:09:WU01:FS01:0x22: UTC Offset: -4
12:16:09:WU01:FS01:0x22:        PID: 5516
12:16:09:WU01:FS01:0x22:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
12:16:09:WU01:FS01:0x22:********************************************************************************
12:16:09:WU01:FS01:0x22:Project: 13426 (Run 3697, Clone 24, Gen 2)
12:16:09:WU01:FS01:0x22:Unit: 0x0000000312bc7d9a5f597cbd21ac0f9e
12:16:09:WU01:FS01:0x22:Reading tar file core.xml
12:16:09:WU01:FS01:0x22:Reading tar file integrator.xml
12:16:09:WU01:FS01:0x22:Reading tar file state.xml.bz2
12:16:09:WU01:FS01:0x22:Reading tar file system.xml.bz2
12:16:09:WU01:FS01:0x22:Digital signatures verified
12:16:09:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:16:09:WU01:FS01:0x22:Version 0.0.11
12:16:09:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
12:16:09:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:16:09:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
12:16:09:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
12:16:13:WU00:FS01:Upload complete
12:16:13:WU00:FS01:Server responded WORK_ACK (400)
12:16:13:WU00:FS01:Final credit estimate, 11755.00 points
12:16:13:WU00:FS01:Cleaning up
12:16:35:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
12:18:54:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
12:20:29:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
12:23:01:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
12:24:21:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
12:27:10:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
12:28:13:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
12:31:18:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
12:32:05:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
12:35:26:WU02:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
12:35:57:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
12:39:35:WU02:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
12:39:50:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
12:43:42:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
12:43:42:WU02:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
12:47:34:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
12:47:50:WU02:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
12:51:26:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
12:51:57:WU02:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
12:55:18:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
12:56:05:WU02:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
12:59:12:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
13:00:13:WU02:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
13:03:05:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
13:04:21:WU02:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
13:06:58:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
13:08:30:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
13:10:51:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
13:12:40:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
13:14:43:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
13:16:51:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
13:18:37:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
13:21:01:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
13:22:29:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
13:25:11:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
13:26:21:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
13:29:21:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
13:30:13:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
13:33:32:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
13:34:05:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
13:37:42:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
13:37:59:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
13:41:51:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
13:41:52:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
13:45:43:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
13:46:02:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
13:49:35:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
13:50:11:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
13:53:27:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
13:54:22:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
13:57:23:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
13:58:33:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:01:17:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
14:02:44:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:05:11:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
14:06:55:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:09:09:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
14:11:13:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:13:06:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
14:15:29:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:17:04:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
14:19:45:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
https://www.techpowerup.com/gpu-specs/a ... smere.g795
An Ellesmere XT should be a supported card.
http://www.cpu-world.com/CPUs/Bulldozer ... -8350.html
Your CPU may or may not have issues with Core_a8*, but this is Core_a7 and it should be fine.
What I think I am reading, is a Core_22 work unit that fails repeatedly, then a new unit is downloaded which works
does not appear to download a new unit either time
It gives up and gets a new WU, which works
*Core_a8 uses an enhanced mode on CPUs with AVX2 and FMA3; your CPU has FMA3 but not AVX2, so I am not sure how it will perform. Either way, it should work.
JohnChodera
Pande Group Member
Post by JohnChodera »
We have some bugfixes for AMD Cards coming in the next core release that may help here!
~ John Chodera // MSKCC
Forcinghavok
Wow finally an answer explaining that there are bug issues with AMD cards or CPU's. I have been saying there is an issue with my computer config for quite some time now and all anybody has ever said is that there is an issue with my computer. LOL. That's pretty vague. I have also run all the CPU, GPU tests and benchmark things you guys have told me which turn out fine.
However with that being said. I don't know if you have made those bugfixes yet. I have noticed that my computer can complete more work units and way less crashes. So cheers.
Forcinghavok
Oh I would like to add 1 more thing. I cannot run the CPU at 7/8 cores or -1 (setting) because its trying to use 7 of the eight cores. Stability reasons I run 4 cores. Any particular reason why I can't use -1 and use 7/8 cores?
Thanks.
Forcinghavok wrote:...I have been saying there is an issue with my computer config for quite some time now and all anybody has ever said is that there is an issue with my computer...
Assuming that you're mentioning this thread: viewtopic.php?f=16&t=35985 please note that there weren't any log files posted from your system so we couldn't troubleshoot any further since making assumptions won't be justified.
Forcinghavok wrote:...I cannot run the CPU at 7/8 cores or -1 (setting) because its trying to use 7 of the eight cores. Stability reasons I run 4 cores. Any particular reason why I can't use -1 and use 7/8 cores?...
While you can configure your CPU Slot to use 7 CPUs, only 6 will be used in FahCore_a7 WUs due to the domain decomposition issue. When running on FahCore_a8, it uses a different method so whatever number of CPUs you provide to it, it can use it without issues.
