I have managed to get Proxmox to properly pass through my extra physical GPU (Nvidia K620) as slot 2. Slot 1 is the virtio display driver that Proxmox uses for console connections. On my system Slot 0 is the CPU. This is all working, but FAHClient is confused by the arrangement and when FAHClient boots it tries to assign the Nvidia drivers to the virtual display virtio. As a result I get the usual cryptic "ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out" that actually means it wants to use that GPU but can't.
Is there any way to prevent FAHClient from using Slot 1 virtio? When I try removing it, the FAHClient just slides the slot 2 stuff to slot 1 and then no GPU works. What I am looking for is a way to get FAHClient to ignore one video "card".
Thoughts?
Block one GPU -- virtio
Re: Block one GPU -- virtio
Welcome to Folding@Home!
If you set an option on that slot
pause-on-start to true
it will not fold
I hope that helps!
it will not fold
I hope that helps!
Welcome to the F@H Forum ronsparks,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
Here is the log file of the most recent runs. Note that Slot 1 is the virtual display, but it shows to be the GM107GL Quadro K620. Slot 2 is actually that physical GPU and you can see it is actually processing work units successfully. As I mentioned in my original post, all seems to be working fine except that error messages that are coming from the false GPU. I am just too much of a consistency nerd to ignore that I guess.
BTW, the same K620 is working in my desktop and they are both folding at about the same rate. So, I trust that the card is properly recognized and is compatible.
12:41:26:WU03:FS00:Starting
12:41:26:WU03:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/ron/cores/cores.foldingathome.org/lin/64bit-sse2/a8-0.0.6/Core_a8.fah/FahCore_a8 -dir 03 -suffix 01 -version 706 -lifeline 12756 -checkpoint 15 -np 3
12:41:26:WU03:FS00:Started FahCore on PID 13193
12:41:26:WU03:FS00:Core PID:13197
12:41:26:WU03:FS00:FahCore 0xa8 started
12:41:27:WU03:FS00:0xa8:*********************** Log Started 2020-09-15T12:41:26Z ***********************
12:41:27:WU03:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
12:41:27:WU03:FS00:0xa8: Core: Gromacs
12:41:27:WU03:FS00:0xa8: Type: 0xa8
12:41:27:WU03:FS00:0xa8: Version: 0.0.6
12:41:27:WU03:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:41:27:WU03:FS00:0xa8: Copyright: 2020 foldingathome.org
12:41:27:WU03:FS00:0xa8: Homepage: https://foldingathome.org/
12:41:27:WU03:FS00:0xa8: Date: Jul 25 2020
12:41:27:WU03:FS00:0xa8: Time: 14:01:39
12:41:27:WU03:FS00:0xa8: Compiler: GNU 8.3.0
12:41:27:WU03:FS00:0xa8: Options: -std=c++14 -fsigned-char -ffunction-sections -fdata-sections -O3
12:41:27:WU03:FS00:0xa8: -funroll-loops -fno-pie
12:41:27:WU03:FS00:0xa8: Platform: linux2 4.15.0-108-generic
12:41:27:WU03:FS00:0xa8: Bits: 64
12:41:27:WU03:FS00:0xa8: Mode: Release
12:41:27:WU03:FS00:0xa8: SIMD: sse2
12:41:27:WU03:FS00:0xa8: OpenMP: ON
12:41:27:WU03:FS00:0xa8: CUDA: OFF
12:41:27:WU03:FS00:0xa8: Args: -dir 03 -suffix 01 -version 706 -lifeline 13193 -checkpoint 15 -np
12:41:27:WU03:FS00:0xa8: 3
12:41:27:WU03:FS00:0xa8:************************************ libFAH ************************************
12:41:27:WU03:FS00:0xa8: Date: Jul 12 2020
12:41:27:WU03:FS00:0xa8: Time: 18:25:05
12:41:27:WU03:FS00:0xa8:************************************ CBang *************************************
12:41:27:WU03:FS00:0xa8: Time: 18:24:52
12:41:27:WU03:FS00:0xa8: -funroll-loops -fno-pie -fPIC
12:41:27:WU03:FS00:0xa8:************************************ System ************************************
12:41:27:WU03:FS00:0xa8: CPU: Common KVM processor
12:41:27:WU03:FS00:0xa8: CPU ID: GenuineIntel Family 15 Model 6 Stepping 1
12:41:27:WU03:FS00:0xa8: CPUs: 6
12:41:27:WU03:FS00:0xa8: Memory: 1.94GiB
12:41:27:WU03:FS00:0xa8:Free Memory: 184.58MiB
12:41:27:WU03:FS00:0xa8: Threads: POSIX_THREADS
12:41:27:WU03:FS00:0xa8: OS Version: 5.4
12:41:27:WU03:FS00:0xa8:Has Battery: false
12:41:27:WU03:FS00:0xa8: On Battery: false
12:41:27:WU03:FS00:0xa8: UTC Offset: 0
12:41:27:WU03:FS00:0xa8: PID: 13197
12:41:27:WU03:FS00:0xa8: CWD: /home/ron/work
12:41:27:WU03:FS00:0xa8:********************************************************************************
12:41:27:WU03:FS00:0xa8:Project: 16810 (Run 30, Clone 493, Gen 18)
12:41:27:WU03:FS00:0xa8:Unit: 0x00000013b2aec48a5eff27a343eaadaa
12:41:27:WU03:FS00:0xa8:Reading tar file core.xml
12:41:27:WU03:FS00:0xa8:Reading tar file frame18.tpr
12:41:27:WU03:FS00:0xa8:Digital signatures verified
12:41:27:WU03:FS00:0xa8:Calling: mdrun -c frame18.gro -s frame18.tpr -x frame18.xtc -cpt 15 -nt 3 -ntmpi 1
12:41:27:WU03:FS00:0xa8:Steps: first=9000000 total=9500000
12:41:28:WU03:FS00:0xa8:Completed 1 out of 500000 steps (0%)
12:41:32:WU01:FS00:Upload 47.10%
12:41:38:WU01:FS00:Upload 80.74%
12:41:42:WU01:FS00:Upload complete
12:41:42:WU01:FS00:Server responded WORK_ACK (400)
12:41:42:WU01:FS00:Final credit estimate, 2073.00 points
12:41:42:WU01:FS00:Cleaning up
******************************* Date: 2020-09-15 *******************************
12:45:14:WU02:FS02:0xa8:Completed 230000 out of 500000 steps (46%)
12:47:11:WU03:FS00:0xa8:Completed 5000 out of 500000 steps (1%)
12:52:54:WU03:FS00:0xa8:Completed 10000 out of 500000 steps (2%)
12:55:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:55:18:WU00:FS01:Assigned to work server 192.0.2.1
12:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
12:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
12:58:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:58:33:WU00:FS01:Connecting to 192.0.2.1:80
12:58:36:WU03:FS00:0xa8:Completed 15000 out of 500000 steps (3%)
13:00:44:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
13:01:38:WU02:FS02:0xa8:Completed 235000 out of 500000 steps (47%)
13:04:17:WU03:FS00:0xa8:Completed 20000 out of 500000 steps (4%)
13:09:57:WU03:FS00:0xa8:Completed 25000 out of 500000 steps (5%)
13:15:39:WU03:FS00:0xa8:Completed 30000 out of 500000 steps (6%)
13:17:58:WU02:FS02:0xa8:Completed 240000 out of 500000 steps (48%)
13:21:21:WU03:FS00:0xa8:Completed 35000 out of 500000 steps (7%)
13:27:03:WU03:FS00:0xa8:Completed 40000 out of 500000 steps (8%)
13:32:45:WU03:FS00:0xa8:Completed 45000 out of 500000 steps (9%)
13:34:25:WU02:FS02:0xa8:Completed 245000 out of 500000 steps (49%)
13:38:25:WU03:FS00:0xa8:Completed 50000 out of 500000 steps (10%)
13:44:07:WU03:FS00:0xa8:Completed 55000 out of 500000 steps (11%)
13:49:46:WU03:FS00:0xa8:Completed 60000 out of 500000 steps (12%)
13:50:58:WU02:FS02:0xa8:Completed 250000 out of 500000 steps (50%)
13:55:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:55:19:WU00:FS01:Assigned to work server 192.0.2.1
13:55:26:WU03:FS00:0xa8:Completed 65000 out of 500000 steps (13%)
13:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
13:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
13:58:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:58:33:WU00:FS01:Connecting to 192.0.2.1:80
14:00:44:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
14:01:08:WU03:FS00:0xa8:Completed 70000 out of 500000 steps (14%)
14:06:48:WU03:FS00:0xa8:Completed 75000 out of 500000 steps (15%)
14:07:23:WU02:FS02:0xa8:Completed 255000 out of 500000 steps (51%)
14:12:30:WU03:FS00:0xa8:Completed 80000 out of 500000 steps (16%)
14:18:12:WU03:FS00:0xa8:Completed 85000 out of 500000 steps (17%)
14:23:52:WU02:FS02:0xa8:Completed 260000 out of 500000 steps (52%)
14:23:53:WU03:FS00:0xa8:Completed 90000 out of 500000 steps (18%)
14:29:35:WU03:FS00:0xa8:Completed 95000 out of 500000 steps (19%)
14:35:17:WU03:FS00:0xa8:Completed 100000 out of 500000 steps (20%)
14:40:21:WU02:FS02:0xa8:Completed 265000 out of 500000 steps (53%)
14:40:59:WU03:FS00:0xa8:Completed 105000 out of 500000 steps (21%)
14:46:40:WU03:FS00:0xa8:Completed 110000 out of 500000 steps (22%)
14:52:21:WU03:FS00:0xa8:Completed 115000 out of 500000 steps (23%)
14:55:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:55:19:WU00:FS01:Assigned to work server 192.0.2.1
14:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
14:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
14:56:48:WU02:FS02:0xa8:Completed 270000 out of 500000 steps (54%)
14:58:04:WU03:FS00:0xa8:Completed 120000 out of 500000 steps (24%)
14:58:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:58:33:WU00:FS01:Connecting to 192.0.2.1:80
15:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
15:03:45:WU03:FS00:0xa8:Completed 125000 out of 500000 steps (25%)
15:09:25:WU03:FS00:0xa8:Completed 130000 out of 500000 steps (26%)
15:13:20:WU02:FS02:0xa8:Completed 275000 out of 500000 steps (55%)
15:15:05:WU03:FS00:0xa8:Completed 135000 out of 500000 steps (27%)
15:20:45:WU03:FS00:0xa8:Completed 140000 out of 500000 steps (28%)
15:26:25:WU03:FS00:0xa8:Completed 145000 out of 500000 steps (29%)
15:29:48:WU02:FS02:0xa8:Completed 280000 out of 500000 steps (56%)
15:32:08:WU03:FS00:0xa8:Completed 150000 out of 500000 steps (30%)
15:37:47:WU03:FS00:0xa8:Completed 155000 out of 500000 steps (31%)
15:43:30:WU03:FS00:0xa8:Completed 160000 out of 500000 steps (32%)
15:46:14:WU02:FS02:0xa8:Completed 285000 out of 500000 steps (57%)
15:49:11:WU03:FS00:0xa8:Completed 165000 out of 500000 steps (33%)
15:54:50:WU03:FS00:0xa8:Completed 170000 out of 500000 steps (34%)
15:55:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:55:19:WU00:FS01:Assigned to work server 192.0.2.1
15:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
15:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
15:58:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:58:34:WU00:FS01:Connecting to 192.0.2.1:80
16:00:30:WU03:FS00:0xa8:Completed 175000 out of 500000 steps (35%)
16:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
16:02:34:WU02:FS02:0xa8:Completed 290000 out of 500000 steps (58%)
16:06:09:WU03:FS00:0xa8:Completed 180000 out of 500000 steps (36%)
16
:11:51:WU03:FS00:0xa8:Completed 185000 out of 500000 steps (37%)
16:17:32:WU03:FS00:0xa8:Completed 190000 out of 500000 steps (38%)
16:18:59:WU02:FS02:0xa8:Completed 295000 out of 500000 steps (59%)
16:23:13:WU03:FS00:0xa8:Completed 195000 out of 500000 steps (39%)
16:28:55:WU03:FS00:0xa8:Completed 200000 out of 500000 steps (40%)
16:34:36:WU03:FS00:0xa8:Completed 205000 out of 500000 steps (41%)
16:35:22:WU02:FS02:0xa8:Completed 300000 out of 500000 steps (60%)
16:40:16:WU03:FS00:0xa8:Completed 210000 out of 500000 steps (42%)
16:45:54:WU03:FS00:0xa8:Completed 215000 out of 500000 steps (43%)
16:51:30:WU03:FS00:0xa8:Completed 220000 out of 500000 steps (44%)
16:51:44:WU02:FS02:0xa8:Completed 305000 out of 500000 steps (61%)
16:55:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
16:55:19:WU00:FS01:Assigned to work server 192.0.2.1
16:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
16:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
16:57:10:WU03:FS00:0xa8:Completed 225000 out of 500000 steps (45%)
16:58:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
16:58:34:WU00:FS01:Connecting to 192.0.2.1:80
17:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
17:02:49:WU03:FS00:0xa8:Completed 230000 out of 500000 steps (46%)
17:08:04:WU02:FS02:0xa8:Completed 310000 out of 500000 steps (62%)
17:08:29:WU03:FS00:0xa8:Completed 235000 out of 500000 steps (47%)
17:14:13:WU03:FS00:0xa8:Completed 240000 out of 500000 steps (48%)
17:19:54:WU03:FS00:0xa8:Completed 245000 out of 500000 steps (49%)
17:24:36:WU02:FS02:0xa8:Completed 315000 out of 500000 steps (63%)
17:25:34:WU03:FS00:0xa8:Completed 250000 out of 500000 steps (50%)
17:31:15:WU03:FS00:0xa8:Completed 255000 out of 500000 steps (51%)
17:36:56:WU03:FS00:0xa8:Completed 260000 out of 500000 steps (52%)
17:41:07:WU02:FS02:0xa8:Completed 320000 out of 500000 steps (64%)
17:42:37:WU03:FS00:0xa8:Completed 265000 out of 500000 steps (53%)
17:48:18:WU03:FS00:0xa8:Completed 270000 out of 500000 steps (54%)
17:53:59:WU03:FS00:0xa8:Completed 275000 out of 500000 steps (55%)
17:55:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:55:19:WU00:FS01:Assigned to work server 192.0.2.1
17:56:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
17:56:24:WU00:FS01:Connecting to 192.0.2.1:8080
17:57:36:WU02:FS02:0xa8:Completed 325000 out of 500000 steps (65%)
17:58:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:58:35:WU00:FS01:Connecting to 192.0.2.1:80
17:59:41:WU03:FS00:0xa8:Completed 280000 out of 500000 steps (56%)
18:00:46:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
18:05:21:WU03:FS00:0xa8:Completed 285000 out of 500000 steps (57%)
18:11:02:WU03:FS00:0xa8:Completed 290000 out of 500000 steps (58%)
18:14:01:WU02:FS02:0xa8:Completed 330000 out of 500000 steps (66%)
18:16:45:WU03:FS00:0xa8:Completed 295000 out of 500000 steps (59%)
18:22:26:WU03:FS00:0xa8:Completed 300000 out of 500000 steps (60%)
18:28:09:WU03:FS00:0xa8:Completed 305000 out of 500000 steps (61%)
18:30:29:WU02:FS02:0xa8:Completed 335000 out of 500000 steps (67%)
18:33:49:WU03:FS00:0xa8:Completed 310000 out of 500000 steps (62%)
18:39:30:WU03:FS00:0xa8:Completed 315000 out of 500000 steps (63%)
18:45:11:WU03:FS00:0xa8:Completed 320000 out of 500000 steps (64%)
18:47:01:WU02:FS02:0xa8:Completed 340000 out of 500000 steps (68%)
18:50:50:WU03:FS00:0xa8:Completed 325000 out of 500000 steps (65%)
18:55:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:55:19:WU00:FS01:Assigned to work server 192.0.2.1
18:56:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
18:56:24:WU00:FS01:Connecting to 192.0.2.1:8080
18:56:30:WU03:FS00:0xa8:Completed 330000 out of 500000 steps (66%)
18:58:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
18:58:35:WU00:FS01:Connecting to 192.0.2.1:80
19:00:46:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
19:02:13:WU03:FS00:0xa8:Completed 335000 out of 500000 steps (67%)
19:03:28:WU02:FS02:0xa8:Completed 345000 out of 500000 steps (69%)
19:07:53:WU03:FS00:0xa8:Completed 340000 out of 500000 steps (68%)
19:13:33:WU03:FS00:0xa8:Completed 345000 out of 500000 steps (69%)
19:19:14:WU03:FS00:0xa8:Completed 350000 out of 500000 steps (70%)
19:19:50:WU02:FS02:0xa8:Completed 350000 out of 500000 steps (70%)
19:24:56:WU03:FS00:0xa8:Completed 355000 out of 500000 steps (71%)
19:30:38:WU03:FS00:0xa8:Completed 360000 out of 500000 steps (72%)
19:36:18:WU02:FS02:0xa8:Completed 355000 out of 500000 steps (71%)
19:36:20:WU03:FS00:0xa8:Completed 365000 out of 500000 steps (73%)
19:42:04:WU03:FS00:0xa8:Completed 370000 out of 500000 steps (74%)
19:47:45:WU03:FS00:0xa8:Completed 375000 out of 500000 steps (75%)
19:52:48:WU02:FS02:0xa8:Completed 360000 out of 500000 steps (72%)
19:53:26:WU03:FS00:0xa8:Completed 380000 out of 500000 steps (76%)
19:55:19:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:55:20:WU00:FS01:Assigned to work server 192.0.2.1
19:56:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
19:56:24:WU00:FS01:Connecting to 192.0.2.1:8080
19:58:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:58:33:WU00:FS01:Connecting to 192.0.2.1:80
19:59:06:WU03:FS00:0xa8:Completed 385000 out of 500000 steps (77%)
20:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
20:04:44:WU03:FS00:0xa8:Completed 390000 out of 500000 steps (78%)
20:09:09:WU02:FS02:0xa8:Completed 365000 out of 500000 steps (73%)
20:10:22:WU03:FS00:0xa8:Completed 395000 out of 500000 steps (79%)
20:16:02:WU03:FS00:0xa8:Completed 400000 out of 500000 steps (80%)
20:21:39:WU03:FS00:0xa8:Completed 405000 out of 500000 steps (81%)
20:25:28:WU02:FS02:0xa8:Completed 370000 out of 500000 steps (74%)
20:27:17:WU03:FS00:0xa8:Completed 410000 out of 500000 steps (82%)
20:32:56:WU03:FS00:0xa8:Completed 415000 out of 500000 steps (83%)
20:38:33:WU03:FS00:0xa8:Completed 420000 out of 500000 steps (84%)
20:41:51:WU02:FS02:0xa8:Completed 375000 out of 500000 steps (75%)
20:44:12:WU03:FS00:0xa8:Completed 425000 out of 500000 steps (85%)
20:49:50:WU03:FS00:0xa8:Completed 430000 out of 500000 steps (86%)
20:55:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
20:55:20:WU00:FS01:Assigned to work server 192.0.2.1
20:55:29:WU03:FS00:0xa8:Completed 435000 out of 500000 steps (87%)
20:56:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
20:56:24:WU00:FS01:Connecting to 192.0.2.1:8080
20:58:16:WU02:FS02:0xa8:Completed 380000 out of 500000 steps (76%)
20:58:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
20:58:34:WU00:FS01:Connecting to 192.0.2.1:80
21:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
21:01:07:WU03:FS00:0xa8:Completed 440000 out of 500000 steps (88%)
21:06:44:WU03:FS00:0xa8:Completed 445000 out of 500000 steps (89%)
21:12:24:WU03:FS00:0xa8:Completed 450000 out of 500000 steps (90%)
21:14:42:WU02:FS02:0xa8:Completed 385000 out of 500000 steps (77%)
21:18:01:WU03:FS00:0xa8:Completed 455000 out of 500000 steps (91%)
21:23:38:WU03:FS00:0xa8:Completed 460000 out of 500000 steps (92%)
21:29:16:WU03:FS00:0xa8:Completed 465000 out of 500000 steps (93%)
21:31:04:WU02:FS02:0xa8:Completed 390000 out of 500000 steps (78%)
21:34:53:WU03:FS00:0xa8:Completed 470000 out of 500000 steps (94%)
21:40:31:WU03:FS00:0xa8:Completed 475000 out of 500000 steps (95%)
21:46:09:WU03:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
21:47:36:WU02:FS02:0xa8:Completed 395000 out of 500000 steps (79%)
21:51:46:WU03:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
21:55:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:55:20:WU00:FS01:Assigned to work server 192.0.2.1
21:56:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107GL [Quadro K620] from 192.0.2.1
21:56:24:WU00:FS01:Connecting to 192.0.2.1:8080
21:57:25:WU03:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
21:58:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:58:34:WU00:FS01:Connecting to 192.0.2.1:80
22:00:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
22:03:06:WU03:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
22:03:07:WU01:FS00:Connecting to assign1.foldingathome.org:80
22:03:07:WU01:FS00:Assigned to work server 150.136.14.110
22:03:07:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 150.136.14.110
22:03:07:WU01:FS00:Connecting to 150.136.14.110:8080
22:03:08:WU01:FS00:Downloading 3.11MiB
22:03:10:WU01:FS00:Download complete
22:03:11:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16422 run:821 clone:4 gen:50 core:0xa7 unit:0x0000003896880e6e5e8bde5d35ed7052
22:04:07:WU02:FS02:0xa8:Completed 400000 out of 500000 steps (80%)
22:08:47:WU03:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
22:08:50:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:08:50:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16810 run:30 clone:493 gen:18 core:0xa8 unit:0x00000013b2aec48a5eff27a343eaadaa
22:08:50:WU03:FS00:Uploading 8.00MiB to 178.174.196.138
22:08:50:WU03:FS00:Connecting to 178.174.196.138:8080
22:08:50:WU01:FS00:Starting
22:08:50:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/ron/cores/cores.foldingathome.org/lin/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 12756 -checkpoint 15 -np 3
22:08:50:WU01:FS00:Started FahCore on PID 13932
22:08:50:WU01:FS00:Core PID:13936
22:08:50:WU01:FS00:FahCore 0xa7 started
22:08:50:WU01:FS00:0xa7:*********************** Log Started 2020-09-15T22:08:50Z ***********************
22:08:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:08:50:WU01:FS00:0xa7: Type: 0xa7
22:08:50:WU01:FS00:0xa7: Core: Gromacs
22:08:50:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 13932 -checkpoint 15 -np
22:08:50:WU01:FS00:0xa7: 3
22:08:50:WU01:FS00:0xa7:************************************ CBang *************************************
22:08:50:WU01:FS00:0xa7: Date: Nov 27 2019
22:08:50:WU01:FS00:0xa7: Time: 11:26:54
22:08:50:WU01:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:08:50:WU01:FS00:0xa7: Branch: master
22:08:50:WU01:FS00:0xa7: Compiler: GNU 8.3.0
22:08:50:WU01:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
22:08:50:WU01:FS00:0xa7: -fno-pie -fPIC
22:08:50:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
22:08:50:WU01:FS00:0xa7: Bits: 64
22:08:50:WU01:FS00:0xa7: Mode: Release
22:08:50:WU01:FS00:0xa7:************************************ System ************************************
22:08:50:WU01:FS00:0xa7: CPU: Common KVM processor
22:08:50:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 15 Model 6 Stepping 1
22:08:50:WU01:FS00:0xa7: CPUs: 6
22:08:50:WU01:FS00:0xa7: Memory: 1.94GiB
22:08:50:WU01:FS00:0xa7:Free Memory: 271.81MiB
22:08:50:WU01:FS00:0xa7: Threads: POSIX_THREADS
22:08:50:WU01:FS00:0xa7: OS Version: 5.4
22:08:50:WU01:FS00:0xa7:Has Battery: false
22:08:50:WU01:FS00:0xa7: On Battery: false
22:08:50:WU01:FS00:0xa7: UTC Offset: 0
22:08:50:WU01:FS00:0xa7: PID: 13936
22:08:50:WU01:FS00:0xa7: CWD: /home/ron/work
22:08:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:08:50:WU01:FS00:0xa7: Version: 0.0.19
22:08:50:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:08:50:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
22:08:50:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
22:08:50:WU01:FS00:0xa7: Date: Nov 26 2019
22:08:50:WU01:FS00:0xa7: Time: 00:41:43
22:08:50:WU01:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:08:50:WU01:FS00:0xa7:************************************ Build *************************************
22:08:50:WU01:FS00:0xa7: SIMD: sse2
22:08:50:WU01:FS00:0xa7:********************************************************************************
22:08:50:WU01:FS00:0xa7:Project: 16422 (Run 821, Clone 4, Gen 50)
22:08:50:WU01:FS00:0xa7:Unit: 0x0000003896880e6e5e8bde5d35ed7052
22:08:50:WU01:FS00:0xa7:Reading tar file core.xml
22:08:50:WU01:FS00:0xa7:Reading tar file frame50.tpr
22:08:50:WU01:FS00:0xa7:Digital signatures verified
22:08:50:WU01:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpt 15 -nt 3
22:08:50:WU01:FS00:0xa7:Steps: first=12500000 total=250000
Darn, that is not the part of the log that shows us your configuration.
The first 200 lines should show what OS, CPU(s), GPU(s), drivers, and options you have on your PC.
I wish you well!
I wish you well!
It seems that your FS01, the virtual display is attempting to get a WU. Pausing it would prevent that. As JimboPalmer asked, the first 200 lines would allow us to understand the system better and help you out
BTW, the reason it is attempting to connect to "192.0.2.1" is because it has found an unsupported GPU. There's an enhancement request to display a more meaningful message.
Also please post the applicable entries from lspci or from GPU-Z
