What is the option for always running?
There are two options one is "While I am working"
and second options is " Only when Idel"
is there any option for always running? because if I select while I am working option, after finish work I will switch off the monitor only, is it running because I haven't selected "only when ideal" option.
please guide me
Thanking you & regard s
Jagadeesh Pasumarthi
What is the option for always running ?
Re: What is the option for always running ?
The option "While I'm working" is what you are looking for. It means that FAH will run when the computer is idle AND when you are using it.
You can then switch off the monitor when you leave, or lock the computer and switch off the monitor. FAH will keep on folding.
Hi AJM.
I got a doubt logical way that's way I asked . Thank you very much for your kind reply dear AJM.
Last edited by jagadeesh_pasumarthi on Wed Sep 02, 2020 5:39 pm, edited 1 time in total.
Welcome to Folding@Home!
If you are using Windows, in the Control Panel, in the Power control panel,setf sleep when plugged in to never. This will help keep F@H folding.
Please note that if you're folding on the GPU, switching users might cause issues. If you're not sure, can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
