1cho
Posts: 4 Joined: Tue Jul 07, 2020 10:53 am
Post
by 1cho » Wed Aug 26, 2020 2:43 pm
Hi,
I've been contributing to the folding cause since April with little to no problems.
But as of late August, I've been getting Memory Management Issues with my MSI RX5500 XT MECH OC,
Could this be a Driver issue or is my card running into a hardware problem?
I've installed
Adrenalin 2020 edition 20.8.2 as of late.
or should I revert back to a stable AMD Driver Build?
I'm running on Windows 10 Pro 64--bit
May 2020 Update
*********************** Log Started 2020-08-28T06:10:50Z ***********************
06:10:50:Trying to access database...
06:10:50:Successfully acquired database lock
06:10:50:Read GPUs.txt
06:10:51:Enabled folding slot 00: READY cpu:14
06:10:52:Enabled folding slot 01: READY gpu:0:Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
06:10:52:****************************** FAHClient ******************************
06:10:52: Version: 7.6.13
06:10:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:10:52: Copyright: 2020 foldingathome.org
06:10:52: Homepage: https://foldingathome.org/
06:10:52: Date: Apr 27 2020
06:10:52: Time: 21:21:01
06:10:52: Revision: 5a652817f46116b6e135503af97f18e094414e3b
06:10:52: Branch: master
06:10:52: Compiler: Visual C++ 2008
06:10:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:10:52: Platform: win32 10
06:10:52: Bits: 32
06:10:52: Mode: Release
06:10:52: Args: --open-web-control
06:10:52: Config: C:\Users\lopez\AppData\Roaming\FAHClient\config.xml
06:10:52:******************************** CBang ********************************
06:10:52: Date: Apr 24 2020
06:10:52: Time: 17:07:55
06:10:52: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
06:10:52: Bits: 32
06:10:52:******************************* System ********************************
06:10:52: CPU: AMD Ryzen 7 2700 Eight-Core Processor
06:10:52: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
06:10:52: CPUs: 16
06:10:52: Memory: 31.95GiB
06:10:52: Free Memory: 27.45GiB
06:10:52: Threads: WINDOWS_THREADS
06:10:52: OS Version: 6.2
06:10:52: Has Battery: false
06:10:52: On Battery: false
06:10:52: UTC Offset: 8
06:10:52: PID: 5304
06:10:52: CWD: C:\Users\lopez\AppData\Roaming\FAHClient
06:10:52: Win32 Service: false
06:10:52: OS: Windows 10 Enterprise
06:10:52: OS Arch: AMD64
06:10:52: GPUs: 1
06:10:52: GPU 0: Bus:43 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
06:10:52: 5500M]
06:10:52: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:10:52: specified module could not be found.
06:10:52:
06:10:52:OpenCL Device 0: Platform:0 Device:0 Bus:43 Slot:0 Compute:1.2 Driver:3110.7
06:10:52:******************************* libFAH ********************************
06:10:52: Date: Apr 15 2020
06:10:52: Time: 14:53:14
06:10:52: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:10:52: Bits: 32
06:10:52:***********************************************************************
06:10:52:<config>
06:10:52: <!-- User Information -->
06:10:52: <passkey v='*****'/>
06:10:52: <team v='254500'/>
06:10:52: <user v='1cho'/>
06:10:52:
06:10:52: <!-- Folding Slots -->
06:10:52: <slot id='0' type='CPU'/>
06:10:52: <slot id='1' type='GPU'/>
06:10:52:</config>
06:10:52:WU02:FS00:Starting
06:10:52:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5304 -checkpoint 15 -np 14
06:10:52:WU02:FS00:Started FahCore on PID 6340
06:10:52:WU02:FS00:Core PID:7272
06:10:52:WU02:FS00:FahCore 0xa7 started
06:10:52:WARNING:WU01:FS01:Past final deadline 2020-08-28T04:18:00Z, dumping
06:10:52:WU01:FS01:Cleaning up
06:10:53:WU02:FS00:0xa7:*********************** Log Started 2020-08-28T06:10:52Z ***********************
06:10:53:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:10:53:WU02:FS00:0xa7: Type: 0xa7
06:10:53:WU02:FS00:0xa7: Core: Gromacs
06:10:53:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 6340 -checkpoint 15 -np
06:10:53:WU02:FS00:0xa7: 14
06:10:53:WU02:FS00:0xa7:************************************ CBang *************************************
06:10:53:WU02:FS00:0xa7: Date: Nov 27 2019
06:10:53:WU02:FS00:0xa7: Time: 03:40:09
06:10:53:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:10:53:WU02:FS00:0xa7: Branch: master
06:10:53:WU02:FS00:0xa7: Compiler: Visual C++ 2008
06:10:53:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:10:53:WU02:FS00:0xa7: Platform: win32 10
06:10:53:WU02:FS00:0xa7: Bits: 64
06:10:53:WU02:FS00:0xa7: Mode: Release
06:10:53:WU02:FS00:0xa7:************************************ System ************************************
06:10:53:WU02:FS00:0xa7: CPU: AMD Ryzen 7 2700 Eight-Core Processor
06:10:53:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
06:10:53:WU02:FS00:0xa7: CPUs: 16
06:10:53:WU02:FS00:0xa7: Memory: 31.95GiB
06:10:53:WU02:FS00:0xa7:Free Memory: 27.43GiB
06:10:53:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
06:10:53:WU02:FS00:0xa7: OS Version: 6.2
06:10:53:WU02:FS00:0xa7:Has Battery: false
06:10:53:WU02:FS00:0xa7: On Battery: false
06:10:53:WU02:FS00:0xa7: UTC Offset: 8
06:10:53:WU02:FS00:0xa7: PID: 7272
06:10:53:WU02:FS00:0xa7: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
06:10:53:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
06:10:53:WU02:FS00:0xa7: Version: 0.0.19
06:10:53:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:10:53:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
06:10:53:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
06:10:53:WU02:FS00:0xa7: Date: Nov 25 2019
06:10:53:WU02:FS00:0xa7: Time: 17:12:41
06:10:53:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:10:53:WU02:FS00:0xa7:************************************ Build *************************************
06:10:53:WU02:FS00:0xa7: SIMD: avx_256
06:10:53:WU02:FS00:0xa7:********************************************************************************
06:10:53:WU02:FS00:0xa7:Project: 14379 (Run 2035, Clone 4, Gen 344)
06:10:53:WU02:FS00:0xa7:Unit: 0x0000018f455e42075e932fb02cc2d8ef
06:10:53:WU02:FS00:0xa7:Digital signatures verified
06:10:53:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
06:10:53:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
06:10:53:WU02:FS00:0xa7:Calling: mdrun -s frame344.tpr -o frame344.trr -cpi state.cpt -cpt 15 -nt 12
06:10:53:WU02:FS00:0xa7:ERROR:Guru Meditation #735264368603e141.b64a8be765ddad46 (1310688.2621376) '02/01/frame344.trr'
06:10:55:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:10:55:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:10:55:WU00:FS01:Connecting to assign1.foldingathome.org:80
06:10:55:WU02:FS00:Starting
06:10:55:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5304 -checkpoint 15 -np 14
06:10:55:WU02:FS00:Started FahCore on PID 11032
06:10:55:WU02:FS00:Core PID:11056
06:10:55:WU02:FS00:FahCore 0xa7 started
06:10:55:WU02:FS00:0xa7:*********************** Log Started 2020-08-28T06:10:55Z ***********************
06:10:55:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:10:55:WU02:FS00:0xa7: Type: 0xa7
06:10:55:WU02:FS00:0xa7: Core: Gromacs
06:10:55:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 11032 -checkpoint 15 -np
06:10:55:WU02:FS00:0xa7: 14
06:10:55:WU02:FS00:0xa7:************************************ CBang *************************************
06:10:55:WU02:FS00:0xa7: Date: Nov 27 2019
06:10:55:WU02:FS00:0xa7: Time: 03:40:09
06:10:55:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:10:55:WU02:FS00:0xa7: Branch: master
06:10:55:WU02:FS00:0xa7: Compiler: Visual C++ 2008
06:10:55:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:10:55:WU02:FS00:0xa7: Platform: win32 10
06:10:55:WU02:FS00:0xa7: Bits: 64
06:10:55:WU02:FS00:0xa7: Mode: Release
06:10:55:WU02:FS00:0xa7:************************************ System ************************************
06:10:55:WU02:FS00:0xa7: CPU: AMD Ryzen 7 2700 Eight-Core Processor
06:10:55:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
06:10:55:WU02:FS00:0xa7: CPUs: 16
06:10:55:WU02:FS00:0xa7: Memory: 31.95GiB
06:10:55:WU02:FS00:0xa7:Free Memory: 27.10GiB
06:10:55:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
06:10:55:WU02:FS00:0xa7: OS Version: 6.2
06:10:55:WU02:FS00:0xa7:Has Battery: false
06:10:55:WU02:FS00:0xa7: On Battery: false
06:10:55:WU02:FS00:0xa7: UTC Offset: 8
06:10:55:WU02:FS00:0xa7: PID: 11056
06:10:55:WU02:FS00:0xa7: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
06:10:55:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
06:10:55:WU02:FS00:0xa7: Version: 0.0.19
06:10:55:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:10:55:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
06:10:55:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
06:10:55:WU02:FS00:0xa7: Date: Nov 25 2019
06:10:55:WU02:FS00:0xa7: Time: 17:12:41
06:10:55:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:10:55:WU02:FS00:0xa7:************************************ Build *************************************
06:10:55:WU02:FS00:0xa7: SIMD: avx_256
06:10:55:WU02:FS00:0xa7:********************************************************************************
06:10:55:WU02:FS00:0xa7:Project: 14379 (Run 2035, Clone 4, Gen 344)
06:10:55:WU02:FS00:0xa7:Unit: 0x0000018f455e42075e932fb02cc2d8ef
06:10:55:WU02:FS00:0xa7:Digital signatures verified
06:10:55:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
06:10:55:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
06:10:55:WU02:FS00:0xa7:Calling: mdrun -s frame344.tpr -o frame344.trr -cpi state.cpt -cpt 15 -nt 12
06:10:55:WU02:FS00:0xa7:ERROR:Guru Meditation #735264368603e141.b64a8be765ddad46 (1310688.2621376) '02/01/frame344.trr'
06:10:56:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:10:56:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:10:56:WU00:FS01:Assigned to work server 18.188.125.154
06:10:56:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 14 [Radeon RX 5500/5500M / Pro 5500M] from 18.188.125.154
06:10:56:WU00:FS01:Connecting to 18.188.125.154:8080
06:10:58:17:127.0.0.1:New Web session
06:11:00:WU00:FS01:Downloading 6.16MiB
06:11:04:FS00:Paused
06:11:04:FS01:Paused
06:11:06:WU00:FS01:Download 2.03%
06:11:13:WU00:FS01:Download 3.05%
06:11:20:WU00:FS01:Download 4.06%
06:11:26:WU00:FS01:Download 6.09%
06:11:34:WU00:FS01:Download 8.12%
06:11:40:WU00:FS01:Download 9.14%
06:11:47:WU00:FS01:Download 12.18%
06:11:51:Saving configuration to config.xml
06:11:51:<config>
06:11:51: <!-- User Information -->
06:11:51: <passkey v='*****'/>
06:11:51: <team v='254500'/>
06:11:51: <user v='1cho'/>
06:11:51:
06:11:51: <!-- Folding Slots -->
06:11:51: <slot id='0' type='CPU'>
06:11:51: <paused v='true'/>
06:11:51: </slot>
06:11:51: <slot id='1' type='GPU'>
06:11:51: </slot>
06:11:51:</config>
06:11:53:WU00:FS01:Download 18.28%
06:11:59:WU00:FS01:Download 59.91%
06:12:02:WU00:FS01:Download complete
06:12:02:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13422 run:5672 clone:42 gen:0 core:0x22 unit:0x0000000012bc7d9a5f3a174dd8325b79
1cho on Fri Aug 28, 2020 6:16 am, edited 1 time in total.
Posts: 6986 Joined: Wed Dec 23, 2009 9:33 am
Hardware configuration: V7.6.21 -> Multi-purpose 24/7 Windows 10 64-bit CPU:2/3/4/6 -> Intel i7-6700K GPU:1 -> Nvidia GTX 1080 Ti § Retired: 2x Nvidia GTX 1070 Nvidia GTX 675M Nvidia GTX 660 Ti Nvidia GTX 650 SC Nvidia GTX 260 896 MB SOC Nvidia 9600GT 1 GB OC Nvidia 9500M GS Nvidia 8800GTS 320 MB Intel Core i7-860 Intel Core i7-3840QM Intel i3-3240 Intel Core 2 Duo E8200 Intel Core 2 Duo E6550 Intel Core 2 Duo T8300 Intel Pentium E5500 Intel Pentium E5400
Post
by PantherX » Thu Aug 27, 2020 8:18 am
Welcome to the F@H Forum 1cho,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
Posts: 1996 Joined: Sun Mar 22, 2020 5:52 pm
Hardware configuration: 1: 2x Xeon E5-2697v3@2.60GHz, 512GB DDR4 LRDIMM, SSD Raid, Win10 Ent 20H2, Quadro K420 1GB, FAH 7.6.21 2: Xeon E3-1505Mv5@2.80GHz, 32GB DDR4, NVME, Win10 Pro 20H2, Quadro M1000M 2GB, FAH 7.6.21 (actually have two of these) 3: i7-960@3.20GHz, 12GB DDR3, SSD, Win10 Pro 20H2, GTX 750Ti 2GB, GTX 1080Ti 11GB, FAH 7.6.21
Post
by Neil-B » Thu Aug 27, 2020 8:26 am
It might be worth while reverting your driver to known stable in the first instance to discount that ... don't know how many issues these drivers usually have but the current list
https://www.amd.com/en/support/kb/relea ... win-20-8-2 does show a few issues - yours might be another?
1cho
Post
by 1cho » Fri Aug 28, 2020 6:17 am
PantherX wrote: Welcome to the F@H Forum 1cho,
Thanks PantherX, I've Edited the Post with a Code attached
1cho on Fri Aug 28, 2020 7:34 am, edited 1 time in total.
1cho
Post
by 1cho » Fri Aug 28, 2020 6:26 am
Neil-B wrote: It might be worth while reverting your driver to known stable in the first instance to discount that ... don't know how many issues these drivers usually have but the current list
I'll try with the
20.8.3 update first,
Otherwise I might have to revert back to
20.4.2
Post
by PantherX » Fri Aug 28, 2020 7:45 am
The log provided indicates that you have an issue with the CPU Slot:
May I suggest that you change the value to 8 to ensure that WU can fold? You can do that by:
Opening up Advanced Control (AKA FAHControl)
Clicking on Configure
Click on Slots tab
Selecting the cpu slot
Clicking on Edit
Changing the CPUs value to 8
Clicking on OK
Clicking on Save
I can't see any error message for the GPU, the last entry seems to show that everything looks fine:
May I suggest that you reboot your system after you have saved all work and then post a fresh copy of the log file after your system has been folding for about 15 minutes to 30 minutes?
1cho
Post
by 1cho » Fri Aug 28, 2020 10:03 am
PantherX wrote: The log provided indicates that you have an issue with the CPU Slot:
Click on Slots tab
Clicking on Edit
Clicking on OK
Clicking on Save
Awesome, thanks for the assist PantherX, it's been Folding for about an hour now, everything seems normal now.
Please see the attached Code for your reference
*********************** Log Started 2020-08-28T09:02:22Z ***********************
09:02:22:Trying to access database...
09:02:22:Successfully acquired database lock
09:02:22:Read GPUs.txt
09:02:22:Enabled folding slot 00: PAUSED cpu:14 (by user)
09:02:22:Enabled folding slot 01: PAUSED gpu:0:Navi 14 [Radeon RX 5500/5500M / Pro 5500M] (by user)
09:02:22:****************************** FAHClient ******************************
09:02:22: Version: 7.6.13
09:02:22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:22: Copyright: 2020 foldingathome.org
09:02:22: Homepage: https://foldingathome.org/
09:02:22: Date: Apr 27 2020
09:02:22: Time: 21:21:01
09:02:22: Revision: 5a652817f46116b6e135503af97f18e094414e3b
09:02:22: Branch: master
09:02:22: Compiler: Visual C++ 2008
09:02:22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:02:22: Platform: win32 10
09:02:22: Bits: 32
09:02:22: Mode: Release
09:02:22: Args: --open-web-control
09:02:22: Config: C:\Users\lopez\AppData\Roaming\FAHClient\config.xml
09:02:22:******************************** CBang ********************************
09:02:22: Date: Apr 24 2020
09:02:22: Time: 17:07:55
09:02:22: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
09:02:22: Bits: 32
09:02:22:******************************* System ********************************
09:02:22: CPU: AMD Ryzen 7 2700 Eight-Core Processor
09:02:22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:02:22: CPUs: 16
09:02:22: Memory: 31.95GiB
09:02:22: Free Memory: 29.44GiB
09:02:22: Threads: WINDOWS_THREADS
09:02:22: OS Version: 6.2
09:02:22: Has Battery: false
09:02:22: On Battery: false
09:02:22: UTC Offset: 8
09:02:22: PID: 11072
09:02:22: CWD: C:\Users\lopez\AppData\Roaming\FAHClient
09:02:22: Win32 Service: false
09:02:22: OS: Windows 10 Enterprise
09:02:22: OS Arch: AMD64
09:02:22: GPUs: 1
09:02:22: GPU 0: Bus:43 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
09:02:22: 5500M]
09:02:22: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
09:02:22: specified module could not be found.
09:02:22:
09:02:22:OpenCL Device 0: Platform:0 Device:0 Bus:43 Slot:0 Compute:1.2 Driver:3110.7
09:02:22:******************************* libFAH ********************************
09:02:22: Date: Apr 15 2020
09:02:22: Time: 14:53:14
09:02:22: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:02:22: Bits: 32
09:02:22:***********************************************************************
09:02:22:<config>
09:02:22: <!-- Network -->
09:02:22: <proxy v=':8080'/>
09:02:22:
09:02:22: <!-- User Information -->
09:02:22: <passkey v='*****'/>
09:02:22: <team v='254500'/>
09:02:22: <user v='1cho'/>
09:02:22:
09:02:22: <!-- Folding Slots -->
09:02:22: <slot id='0' type='CPU'>
09:02:22: <paused v='true'/>
09:02:22: </slot>
09:02:22: <slot id='1' type='GPU'>
09:02:22: </slot>
09:02:22:</config>
09:02:26:3:127.0.0.1:New Web session
09:02:42:FS00:Unpaused
09:02:42:FS01:Unpaused
09:02:42:WU02:FS00:Starting
09:02:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11072 -checkpoint 15 -np 14
09:02:42:WU02:FS00:Started FahCore on PID 4148
09:02:42:WU02:FS00:Core PID:4588
09:02:42:WU02:FS00:FahCore 0xa7 started
09:02:42:WU00:FS01:Starting
09:02:42:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11072 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:02:42:WU00:FS01:Started FahCore on PID 4888
09:02:42:WU00:FS01:Core PID:5680
09:02:42:WU00:FS01:FahCore 0x22 started
09:02:43:WU02:FS00:0xa7:*********************** Log Started 2020-08-28T09:02:42Z ***********************
09:02:43:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:02:43:WU02:FS00:0xa7: Type: 0xa7
09:02:43:WU02:FS00:0xa7: Core: Gromacs
09:02:43:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 4148 -checkpoint 15 -np
09:02:43:WU02:FS00:0xa7: 14
09:02:43:WU02:FS00:0xa7:************************************ CBang *************************************
09:02:43:WU02:FS00:0xa7: Date: Nov 27 2019
09:02:43:WU02:FS00:0xa7: Time: 03:40:09
09:02:43:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:02:43:WU02:FS00:0xa7: Branch: master
09:02:43:WU02:FS00:0xa7: Compiler: Visual C++ 2008
09:02:43:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:02:43:WU02:FS00:0xa7: Platform: win32 10
09:02:43:WU02:FS00:0xa7: Bits: 64
09:02:43:WU02:FS00:0xa7: Mode: Release
09:02:43:WU02:FS00:0xa7:************************************ System ************************************
09:02:43:WU02:FS00:0xa7: CPU: AMD Ryzen 7 2700 Eight-Core Processor
09:02:43:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:02:43:WU02:FS00:0xa7: CPUs: 16
09:02:43:WU02:FS00:0xa7: Memory: 31.95GiB
09:02:43:WU02:FS00:0xa7:Free Memory: 28.91GiB
09:02:43:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
09:02:43:WU02:FS00:0xa7: OS Version: 6.2
09:02:43:WU02:FS00:0xa7:Has Battery: false
09:02:43:WU02:FS00:0xa7: On Battery: false
09:02:43:WU02:FS00:0xa7: UTC Offset: 8
09:02:43:WU02:FS00:0xa7: PID: 4588
09:02:43:WU02:FS00:0xa7: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
09:02:43:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
09:02:43:WU02:FS00:0xa7: Version: 0.0.19
09:02:43:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:43:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
09:02:43:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
09:02:43:WU02:FS00:0xa7: Date: Nov 25 2019
09:02:43:WU02:FS00:0xa7: Time: 17:12:41
09:02:43:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:02:43:WU02:FS00:0xa7:************************************ Build *************************************
09:02:43:WU02:FS00:0xa7: SIMD: avx_256
09:02:43:WU02:FS00:0xa7:********************************************************************************
09:02:43:WU02:FS00:0xa7:Project: 14379 (Run 2035, Clone 4, Gen 344)
09:02:43:WU02:FS00:0xa7:Unit: 0x0000018f455e42075e932fb02cc2d8ef
09:02:43:WU02:FS00:0xa7:Digital signatures verified
09:02:43:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
09:02:43:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
09:02:43:WU02:FS00:0xa7:Calling: mdrun -s frame344.tpr -o frame344.trr -cpi state.cpt -cpt 15 -nt 12
09:02:43:WU02:FS00:0xa7:ERROR:Guru Meditation #735264368603e141.b64a8be765ddad46 (1310688.2621376) '02/01/frame344.trr'
09:02:43:WU00:FS01:0x22:*********************** Log Started 2020-08-28T09:02:42Z ***********************
09:02:43:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:02:43:WU00:FS01:0x22: Core: Core22
09:02:43:WU00:FS01:0x22: Type: 0x22
09:02:43:WU00:FS01:0x22: Version: 0.0.11
09:02:43:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:43:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
09:02:43:WU00:FS01:0x22: Homepage: https://foldingathome.org/
09:02:43:WU00:FS01:0x22: Date: Jun 26 2020
09:02:43:WU00:FS01:0x22: Time: 19:49:16
09:02:43:WU00:FS01:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
09:02:43:WU00:FS01:0x22: Branch: core22-0.0.11
09:02:43:WU00:FS01:0x22: Compiler: Visual C++ 2015
09:02:43:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:02:43:WU00:FS01:0x22: Platform: win32 10
09:02:43:WU00:FS01:0x22: Bits: 64
09:02:43:WU00:FS01:0x22: Mode: Release
09:02:43:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:02:43:WU00:FS01:0x22: <peastman@stanford.edu>
09:02:43:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4888 -checkpoint 15
09:02:43:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:02:43:WU00:FS01:0x22:************************************ libFAH ************************************
09:02:43:WU00:FS01:0x22: Time: 19:47:12
09:02:43:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
09:02:43:WU00:FS01:0x22: Branch: HEAD
09:02:43:WU00:FS01:0x22:************************************ CBang *************************************
09:02:43:WU00:FS01:0x22: Time: 19:46:11
09:02:43:WU00:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
09:02:43:WU00:FS01:0x22: Branch: master
09:02:43:WU00:FS01:0x22:************************************ System ************************************
09:02:43:WU00:FS01:0x22: CPU: AMD Ryzen 7 2700 Eight-Core Processor
09:02:43:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:02:43:WU00:FS01:0x22: CPUs: 16
09:02:43:WU00:FS01:0x22: Memory: 31.95GiB
09:02:43:WU00:FS01:0x22:Free Memory: 28.89GiB
09:02:43:WU00:FS01:0x22: Threads: WINDOWS_THREADS
09:02:43:WU00:FS01:0x22: OS Version: 6.2
09:02:43:WU00:FS01:0x22:Has Battery: false
09:02:43:WU00:FS01:0x22: On Battery: false
09:02:43:WU00:FS01:0x22: UTC Offset: 8
09:02:43:WU00:FS01:0x22: PID: 5680
09:02:43:WU00:FS01:0x22: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
09:02:43:WU00:FS01:0x22:********************************************************************************
09:02:43:WU00:FS01:0x22:Project: 13422 (Run 5672, Clone 42, Gen 0)
09:02:43:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5f3a174dd8325b79
09:02:43:WU00:FS01:0x22:Reading tar file core.xml
09:02:43:WU00:FS01:0x22:Reading tar file integrator.xml
09:02:43:WU00:FS01:0x22:Reading tar file state.xml.bz2
09:02:43:WU00:FS01:0x22:Reading tar file system.xml.bz2
09:02:43:WU00:FS01:0x22:Digital signatures verified
09:02:43:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:02:43:WU00:FS01:0x22:Version 0.0.11
09:02:43:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
09:02:43:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
09:02:43:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
09:02:43:WU00:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
09:02:44:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:02:44:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:02:45:WU02:FS00:Starting
09:02:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11072 -checkpoint 15 -np 14
09:02:45:WU02:FS00:Started FahCore on PID 7548
09:02:45:WU02:FS00:Core PID:11092
09:02:45:WU02:FS00:FahCore 0xa7 started
09:02:45:WU02:FS00:0xa7:*********************** Log Started 2020-08-28T09:02:45Z ***********************
09:02:45:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:02:45:WU02:FS00:0xa7: Type: 0xa7
09:02:45:WU02:FS00:0xa7: Core: Gromacs
09:02:45:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 7548 -checkpoint 15 -np
09:02:45:WU02:FS00:0xa7: 14
09:02:45:WU02:FS00:0xa7:************************************ CBang *************************************
09:02:45:WU02:FS00:0xa7: Date: Nov 27 2019
09:02:45:WU02:FS00:0xa7: Time: 03:40:09
09:02:45:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:02:45:WU02:FS00:0xa7: Branch: master
09:02:45:WU02:FS00:0xa7: Compiler: Visual C++ 2008
09:02:45:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:02:45:WU02:FS00:0xa7: Platform: win32 10
09:02:45:WU02:FS00:0xa7: Bits: 64
09:02:45:WU02:FS00:0xa7: Mode: Release
09:02:45:WU02:FS00:0xa7:************************************ System ************************************
09:02:45:WU02:FS00:0xa7: CPU: AMD Ryzen 7 2700 Eight-Core Processor
09:02:45:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:02:45:WU02:FS00:0xa7: CPUs: 16
09:02:45:WU02:FS00:0xa7: Memory: 31.95GiB
09:02:45:WU02:FS00:0xa7:Free Memory: 28.71GiB
09:02:45:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
09:02:45:WU02:FS00:0xa7: OS Version: 6.2
09:02:45:WU02:FS00:0xa7:Has Battery: false
09:02:45:WU02:FS00:0xa7: On Battery: false
09:02:45:WU02:FS00:0xa7: UTC Offset: 8
09:02:45:WU02:FS00:0xa7: PID: 11092
09:02:45:WU02:FS00:0xa7: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
09:02:45:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
09:02:45:WU02:FS00:0xa7: Version: 0.0.19
09:02:45:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:45:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
09:02:45:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
09:02:45:WU02:FS00:0xa7: Date: Nov 25 2019
09:02:45:WU02:FS00:0xa7: Time: 17:12:41
09:02:45:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:02:45:WU02:FS00:0xa7:************************************ Build *************************************
09:02:45:WU02:FS00:0xa7: SIMD: avx_256
09:02:45:WU02:FS00:0xa7:********************************************************************************
09:02:45:WU02:FS00:0xa7:Project: 14379 (Run 2035, Clone 4, Gen 344)
09:02:45:WU02:FS00:0xa7:Unit: 0x0000018f455e42075e932fb02cc2d8ef
09:02:45:WU02:FS00:0xa7:Digital signatures verified
09:02:45:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
09:02:45:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
09:02:45:WU02:FS00:0xa7:Calling: mdrun -s frame344.tpr -o frame344.trr -cpi state.cpt -cpt 15 -nt 12
09:02:45:WU02:FS00:0xa7:ERROR:Guru Meditation #735264368603e141.b64a8be765ddad46 (1310688.2621376) '02/01/frame344.trr'
09:02:45:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:02:45:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:02:45:WARNING:WU02:FS00:Too many errors, failing
09:02:45:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14379 run:2035 clone:4 gen:344 core:0xa7 unit:0x0000018f455e42075e932fb02cc2d8ef
09:02:45:WU02:FS00:Connecting to 69.94.66.7:8080
09:02:46:WU01:FS00:Connecting to assign1.foldingathome.org:80
09:02:46:WU02:FS00:Server responded WORK_ACK (400)
09:02:46:WU02:FS00:Cleaning up
09:02:47:WU01:FS00:Assigned to work server 155.247.164.214
09:02:47:WU01:FS00:Requesting new work unit for slot 00: READY cpu:14 from 155.247.164.214
09:02:47:WU01:FS00:Connecting to 155.247.164.214:8080
09:02:48:WU01:FS00:Downloading 2.83MiB
09:02:54:WU01:FS00:Download 17.69%
09:03:01:WU01:FS00:Download 22.11%
09:03:08:WU01:FS00:Download 26.54%
09:03:14:WU01:FS00:Download 30.96%
09:03:15:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
09:03:23:Saving configuration to config.xml
09:03:23:<config>
09:03:23: <!-- Network -->
09:03:23: <proxy v=':8080'/>
09:03:23:
09:03:23: <!-- User Information -->
09:03:23: <passkey v='*****'/>
09:03:23: <team v='254500'/>
09:03:23: <user v='1cho'/>
09:03:23:
09:03:23: <!-- Folding Slots -->
09:03:23: <slot id='0' type='CPU'/>
09:03:23: <slot id='1' type='GPU'/>
09:03:23:</config>
09:03:25:WU01:FS00:Download 35.38%
09:03:31:WU01:FS00:Download 39.81%
09:03:37:WU01:FS00:Download 44.23%
09:03:45:WU01:FS00:Download 50.86%
09:03:52:WU01:FS00:Download 55.29%
09:04:01:WU01:FS00:Download 61.92%
09:04:09:WU01:FS00:Download 66.34%
09:04:16:WU01:FS00:Download 70.77%
09:04:22:WU01:FS00:Download 77.40%
09:04:29:WU01:FS00:Download 81.82%
09:04:38:WU01:FS00:Download 86.25%
09:04:44:WU01:FS00:Download 90.67%
09:04:52:WU01:FS00:Download 95.09%
09:05:01:WU01:FS00:Download 99.52%
09:05:02:WU01:FS00:Download complete
09:05:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14822 run:338 clone:2 gen:203 core:0xa7 unit:0x000000f09bf7a4d65ea0a7e2736b6cd7
09:05:02:WU01:FS00:Starting
09:05:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lopez\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11072 -checkpoint 15 -np 14
09:05:02:WU01:FS00:Started FahCore on PID 6780
09:05:02:WU01:FS00:Core PID:3996
09:05:02:WU01:FS00:FahCore 0xa7 started
09:05:02:WU01:FS00:0xa7:*********************** Log Started 2020-08-28T09:05:02Z ***********************
09:05:02:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:05:02:WU01:FS00:0xa7: Type: 0xa7
09:05:02:WU01:FS00:0xa7: Core: Gromacs
09:05:02:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 6780 -checkpoint 15 -np
09:05:02:WU01:FS00:0xa7: 14
09:05:02:WU01:FS00:0xa7:************************************ CBang *************************************
09:05:02:WU01:FS00:0xa7: Date: Nov 27 2019
09:05:02:WU01:FS00:0xa7: Time: 03:40:09
09:05:02:WU01:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:05:02:WU01:FS00:0xa7: Branch: master
09:05:02:WU01:FS00:0xa7: Compiler: Visual C++ 2008
09:05:02:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:05:02:WU01:FS00:0xa7: Platform: win32 10
09:05:02:WU01:FS00:0xa7: Bits: 64
09:05:02:WU01:FS00:0xa7: Mode: Release
09:05:02:WU01:FS00:0xa7:************************************ System ************************************
09:05:02:WU01:FS00:0xa7: CPU: AMD Ryzen 7 2700 Eight-Core Processor
09:05:02:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:05:02:WU01:FS00:0xa7: CPUs: 16
09:05:02:WU01:FS00:0xa7: Memory: 31.95GiB
09:05:02:WU01:FS00:0xa7:Free Memory: 28.44GiB
09:05:02:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
09:05:02:WU01:FS00:0xa7: OS Version: 6.2
09:05:02:WU01:FS00:0xa7:Has Battery: false
09:05:02:WU01:FS00:0xa7: On Battery: false
09:05:02:WU01:FS00:0xa7: UTC Offset: 8
09:05:02:WU01:FS00:0xa7: PID: 3996
09:05:02:WU01:FS00:0xa7: CWD: C:\Users\lopez\AppData\Roaming\FAHClient\work
09:05:02:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:05:02:WU01:FS00:0xa7: Version: 0.0.19
09:05:02:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:05:02:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
09:05:02:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
09:05:02:WU01:FS00:0xa7: Date: Nov 25 2019
09:05:02:WU01:FS00:0xa7: Time: 17:12:41
09:05:02:WU01:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:05:03:WU01:FS00:0xa7: Branch: master
09:05:03:WU01:FS00:0xa7: Compiler: Visual C++ 2008
09:05:03:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:05:03:WU01:FS00:0xa7: Platform: win32 10
09:05:03:WU01:FS00:0xa7: Bits: 64
09:05:03:WU01:FS00:0xa7: Mode: Release
09:05:03:WU01:FS00:0xa7:************************************ Build *************************************
09:05:03:WU01:FS00:0xa7: SIMD: avx_256
09:05:03:WU01:FS00:0xa7:********************************************************************************
09:05:03:WU01:FS00:0xa7:Project: 14822 (Run 338, Clone 2, Gen 203)
09:05:03:WU01:FS00:0xa7:Unit: 0x000000f09bf7a4d65ea0a7e2736b6cd7
09:05:03:WU01:FS00:0xa7:Reading tar file core.xml
09:05:03:WU01:FS00:0xa7:Reading tar file frame203.tpr
09:05:03:WU01:FS00:0xa7:Digital signatures verified
09:05:03:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
09:05:03:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
09:05:03:WU01:FS00:0xa7:Calling: mdrun -s frame203.tpr -o frame203.trr -cpt 15 -nt 12
09:05:03:WU01:FS00:0xa7:Steps: first=0 total=250000
09:05:03:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
09:06:12:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:06:47:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
09:07:20:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
09:08:29:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:09:38:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
09:10:20:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
09:10:46:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
09:11:55:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
09:13:04:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
09:13:54:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
09:14:13:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
09:15:22:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
09:16:31:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
09:17:26:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
09:17:40:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
09:18:49:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
09:19:58:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
09:20:59:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
09:21:07:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
09:22:16:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
09:23:25:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
09:24:33:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
09:24:33:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
09:25:42:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
09:26:51:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
09:28:00:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
09:28:06:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
09:29:08:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
09:30:18:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
09:31:26:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
09:31:39:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
09:32:35:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
09:33:44:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
09:34:53:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
09:35:12:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
09:36:02:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
09:37:11:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
09:38:20:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
09:38:45:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
09:39:29:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
09:40:38:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
09:41:46:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
09:42:19:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
09:42:55:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
09:44:04:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
09:45:13:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
09:45:52:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
09:46:22:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
09:47:31:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
09:48:40:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
09:49:24:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
09:49:48:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
09:50:58:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
09:52:06:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
09:52:57:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
09:53:15:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
09:54:24:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
09:55:33:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
09:56:30:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
09:56:42:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
09:57:51:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
09:59:00:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
10:00:04:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
10:00:08:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
Post
by PantherX » Fri Aug 28, 2020 6:23 pm
Great to hear that you're folding fine now
Looking at your log file, I noticed that upon start-up, there are issues with the CPU Slot. Out of curiosity, do you pause the Slots, wait for a minute or two and then restart the system or do you simply restart the system without pausing the folding slots? Reason is that ERROR:Guru Meditation can be caused by corrupted file which can happen if the client is closed before it can save the files. Thus, it is recommended to pause the slots, wait for a couple of minutes and then reboot/shutdown your system.
