*********************** Log Started 2020-08-24T14:10:48Z ***********************
14:10:50:WU03:FS02:Starting
14:10:50:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\sabrinah\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 4492 -checkpoint 3 -np 2
14:10:51:WU03:FS02:Started FahCore on PID 30520
14:10:51:WU03:FS02:Core PID:44116
14:10:51:WU03:FS02:FahCore 0xa7 started
14:10:52:WU03:FS02:0xa7:*********************** Log Started 2020-08-24T14:10:52Z ***********************
14:10:52:WU03:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
14:10:52:WU03:FS02:0xa7: Type: 0xa7
14:10:52:WU03:FS02:0xa7: Core: Gromacs
14:10:52:WU03:FS02:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 30520 -checkpoint 3 -np 2
14:10:52:WU03:FS02:0xa7:************************************ CBang *************************************
14:10:52:WU03:FS02:0xa7: Date: Nov 27 2019
14:10:52:WU03:FS02:0xa7: Time: 03:40:09
14:10:52:WU03:FS02:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:10:52:WU03:FS02:0xa7: Branch: master
14:10:52:WU03:FS02:0xa7: Compiler: Visual C++ 2008
14:10:52:WU03:FS02:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:52:WU03:FS02:0xa7: Platform: win32 10
14:10:52:WU03:FS02:0xa7: Bits: 64
14:10:52:WU03:FS02:0xa7: Mode: Release
14:10:52:WU03:FS02:0xa7:************************************ System ************************************
14:10:52:WU03:FS02:0xa7: CPU: AMD A10-5750M APU with Radeon(tm) HD Graphics
14:10:52:WU03:FS02:0xa7: CPU ID: AuthenticAMD Family 21 Model 19 Stepping 1
14:10:52:WU03:FS02:0xa7: CPUs: 4
14:10:52:WU03:FS02:0xa7: Memory: 7.20GiB
14:10:52:WU03:FS02:0xa7:Free Memory: 3.73GiB
14:10:52:WU03:FS02:0xa7: Threads: WINDOWS_THREADS
14:10:52:WU03:FS02:0xa7: OS Version: 6.1
14:10:52:WU03:FS02:0xa7:Has Battery: true
14:10:52:WU03:FS02:0xa7: On Battery: false
14:10:52:WU03:FS02:0xa7: UTC Offset: -4
14:10:52:WU03:FS02:0xa7: PID: 44116
14:10:52:WU03:FS02:0xa7: CWD: C:\Users\sabrinah\AppData\Roaming\FAHClient\work
14:10:52:WU03:FS02:0xa7:******************************** Build - libFAH ********************************
14:10:52:WU03:FS02:0xa7: Version: 0.0.19
14:10:52:WU03:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:10:52:WU03:FS02:0xa7: Copyright: 2019 foldingathome.org
14:10:52:WU03:FS02:0xa7: Homepage: https://foldingathome.org/
14:10:52:WU03:FS02:0xa7: Date: Nov 25 2019
14:10:52:WU03:FS02:0xa7: Time: 17:12:41
14:10:52:WU03:FS02:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:10:52:WU03:FS02:0xa7:************************************ Build *************************************
14:10:52:WU03:FS02:0xa7: SIMD: avx_256
14:10:52:WU03:FS02:0xa7:********************************************************************************
14:10:52:WU03:FS02:0xa7:Project: 14254 (Run 0, Clone 760, Gen 185)
14:10:52:WU03:FS02:0xa7:Unit: 0x000000f5cedfaa925eaca0560c3680fc
14:10:52:WU03:FS02:0xa7:Digital signatures verified
14:10:52:WU03:FS02:0xa7:Calling: mdrun -s frame185.tpr -o frame185.trr -x frame185.xtc -cpi state.cpt -cpt 3 -nt 2
14:10:52:WU03:FS02:0xa7:ERROR:Guru Meditation #0.d6e91a83f60d52ef (0.1673616) '03/01/frame185.trr'
14:17:33:WARNING:WU03:FS02:FahCore returned: FAILED_3 (255 = 0xff)
14:17:33:WARNING:WU03:FS02:Too many errors, failing
14:17:33:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:17:33:WU03:FS02:Connecting to 206.223.170.146:8080
14:17:54:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:17:54:WU03:FS02:Connecting to 206.223.170.146:80
14:18:15:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:18:15:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:18:15:WU03:FS02:Connecting to 206.223.170.146:8080
14:18:36:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:18:36:WU03:FS02:Connecting to 206.223.170.146:80
14:18:57:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:19:15:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:19:15:WU03:FS02:Connecting to 206.223.170.146:8080
14:19:36:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:19:36:WU03:FS02:Connecting to 206.223.170.146:80
14:19:57:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:20:52:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:20:52:WU03:FS02:Connecting to 206.223.170.146:8080
14:21:13:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:21:13:WU03:FS02:Connecting to 206.223.170.146:80
14:21:34:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:23:29:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:23:29:WU03:FS02:Connecting to 206.223.170.146:8080
14:23:50:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:23:50:WU03:FS02:Connecting to 206.223.170.146:80
14:24:12:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:27:44:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:27:44:WU03:FS02:Connecting to 206.223.170.146:8080
14:28:05:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:28:05:WU03:FS02:Connecting to 206.223.170.146:80
14:28:26:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:34:35:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:34:35:WU03:FS02:Connecting to 206.223.170.146:8080
14:34:56:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:34:56:WU03:FS02:Connecting to 206.223.170.146:80
14:35:17:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:45:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
14:45:40:WU03:FS02:Connecting to 206.223.170.146:8080
14:46:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
14:46:01:WU03:FS02:Connecting to 206.223.170.146:80
14:46:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:03:37:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
15:03:37:WU03:FS02:Connecting to 206.223.170.146:8080
15:03:58:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
15:03:58:WU03:FS02:Connecting to 206.223.170.146:80
15:04:19:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:32:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
15:32:39:WU03:FS02:Connecting to 206.223.170.146:8080
15:32:39:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
15:32:39:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable host.
16:19:38:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
16:19:38:WU03:FS02:Connecting to 206.223.170.146:8080
16:19:38:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
16:19:38:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable host.
17:19:38:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
17:19:38:WU03:FS02:Connecting to 206.223.170.146:8080
17:19:59:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
17:19:59:WU03:FS02:Connecting to 206.223.170.146:80
17:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:19:38:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
18:19:38:WU03:FS02:Connecting to 206.223.170.146:8080
18:19:59:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
18:19:59:WU03:FS02:Connecting to 206.223.170.146:80
18:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
19:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
19:20:00:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
19:20:00:WU03:FS02:Connecting to 206.223.170.146:80
19:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2020-08-24 *******************************
20:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
20:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
20:20:00:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
20:20:00:WU03:FS02:Connecting to 206.223.170.146:80
20:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
21:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
21:20:00:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
21:20:00:WU03:FS02:Connecting to 206.223.170.146:80
21:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
22:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
22:20:00:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
22:20:00:WU03:FS02:Connecting to 206.223.170.146:80
22:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
23:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
23:20:00:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
23:20:00:WU03:FS02:Connecting to 206.223.170.146:80
23:20:21:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
00:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
00:19:39:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
00:19:39:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable host.
01:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
01:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
01:19:39:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
01:19:39:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable host.
******************************* Date: 2020-08-25 *******************************
02:19:39:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
02:19:39:WU03:FS02:Connecting to 206.223.170.146:8080
02:19:39:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
02:19:39:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable network.
03:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
03:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
03:19:40:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
03:19:40:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable network.
04:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
04:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
04:19:40:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
04:19:40:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A socket operation was attempted to an unreachable network.
05:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
05:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
05:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
05:20:01:WU03:FS02:Connecting to 206.223.170.146:80
05:20:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
06:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
06:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
06:20:01:WU03:FS02:Connecting to 206.223.170.146:80
06:20:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
07:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
07:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
07:20:01:WU03:FS02:Connecting to 206.223.170.146:80
07:20:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
08:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
08:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
08:20:01:WU03:FS02:Connecting to 206.223.170.146:80
08:20:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
09:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
09:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
09:20:01:WU03:FS02:Connecting to 206.223.170.146:80
09:20:23:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
10:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
10:20:01:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
10:20:01:WU03:FS02:Connecting to 206.223.170.146:80
10:20:22:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:19:40:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
11:19:40:WU03:FS02:Connecting to 206.223.170.146:8080
11:20:02:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
11:20:02:WU03:FS02:Connecting to 206.223.170.146:80
11:20:23:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:19:41:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
12:19:41:WU03:FS02:Connecting to 206.223.170.146:8080
12:20:02:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
12:20:02:WU03:FS02:Connecting to 206.223.170.146:80
12:20:23:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:19:41:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:14254 run:0 clone:760 gen:185 core:0xa7 unit:0x000000f5cedfaa925eaca0560c3680fc
13:19:41:WU03:FS02:Connecting to 206.223.170.146:8080
13:20:02:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
13:20:02:WU03:FS02:Connecting to 206.223.170.146:80
13:20:23:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
