impossible to launch FAHControl under fedora 32
boistordu
Post by boistordu »
Hi,
  File "/usr/bin/FAHControl", line 25, in <module>
    from fah import FAHControl, load_fahcontrol_db
ModuleNotFoundError: No module named 'fah'
Last version of FAHControl 7.6.13
under fedora 32
Is it because fedora 32 has replaced python2.6 by 3.8?
thanks in advance
bikeaddict
Re: impossible to launch FAHControl under fedora 32
Post by bikeaddict »
The /usr/bin/python symlink points to python3. I had to edit /usr/bin/FAHControl and change the first line from #!/usr/bin/python to #!/usr/bin/python2 so the script loads Python 2.7 instead of 3.8.
boistordu
Post by boistordu »
thanks a lot :)
Welcome to the F@H Forum boistordu,
Apologies for the issue that you encountered :( I am glad that you managed to find a solution that worked for you :)
Please note that there is work underway to move from Python 2 to Python 3 but there's no ETA.
