OpenCL not present, or is configured incorrectly
CrimsonFKR
Post by CrimsonFKR »
I am trying to run two p106-90 cards using an i5 6600k IGPU as the primary output. I am having an issue using the repurposed mining cards with this program, as i get the following error when trying to run 'auto' (set to -1)
ERROR:WU00:FS03:Failed to start core: Option 'opencl-index' has no default and is not set.
In GPU-Z it doesnt appear to support OpenCL, but i know the tech is more than capable, as CUDA is automatically detected.
I've tried to set the OpenCL index manually to no avail. It then hard fails and does not retry. In auto, it endlessly retries WU's. Please help :)
Re: OpenCL not present, or is configured incorrectly
Welcome to the F@H Forum CrimsonFKR,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
CrimsonFKR
*********************** Log Started 2020-08-17T23:01:05Z ***********************
23:01:05:Trying to access database...
23:01:05:Successfully acquired database lock
23:01:05:Read GPUs.txt
23:01:05:Enabled folding slot 00: READY cpu:2
23:01:05:Enabled folding slot 01: READY gpu:0:GP106 [P106-090]
23:01:05:Enabled folding slot 03: READY gpu:1:Gen9/GT2 [HD Graphics 530]
23:01:05:WARNING:WU03:No longer matches Slot 3's configuration, migrating to FS01
23:01:05:ERROR:Exception: Unit not found
23:01:05:****************************** FAHClient ******************************
23:01:05:        Version: 7.6.13
23:01:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:01:05:      Copyright: 2020 foldingathome.org
23:01:05:       Homepage: https://foldingathome.org/
23:01:05:           Date: Apr 27 2020
23:01:05:           Time: 21:21:01
23:01:05:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
23:01:05:         Branch: master
23:01:05:       Compiler: Visual C++ 2008
23:01:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:01:05:       Platform: win32 10
23:01:05:           Bits: 32
23:01:05:           Mode: Release
23:01:05:           Args: --open-web-control
23:01:05:         Config: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\config.xml
23:01:05:******************************** CBang ********************************
23:01:05:           Date: Apr 24 2020
23:01:05:           Time: 17:07:55
23:01:05:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
23:01:05:           Bits: 32
23:01:05:******************************* System ********************************
23:01:05:            CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
23:01:05:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:01:05:           CPUs: 4
23:01:05:         Memory: 14.95GiB
23:01:05:    Free Memory: 12.52GiB
23:01:05:        Threads: WINDOWS_THREADS
23:01:05:     OS Version: 6.2
23:01:05:    Has Battery: false
23:01:05:     On Battery: false
23:01:05:     UTC Offset: -7
23:01:05:            PID: 1100
23:01:05:            CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient
23:01:05:  Win32 Service: false
23:01:05:             OS: Windows 10 Home
23:01:05:        OS Arch: AMD64
23:01:05:           GPUs: 3
23:01:05:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
23:01:05:          GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 Gen9/GT2 [HD Graphics 530]
23:01:05:          GPU 2: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
23:01:05:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
23:01:05:  CUDA Device 1: Platform:0 Device:1 Bus:4 Slot:0 Compute:6.1 Driver:11.0
23:01:05:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
23:01:05:******************************* libFAH ********************************
23:01:05:           Date: Apr 15 2020
23:01:05:           Time: 14:53:14
23:01:05:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:01:05:           Bits: 32
23:01:05:***********************************************************************
23:01:05:<config>
23:01:05:  <!-- Folding Core -->
23:01:05:  <core-priority v='low'/>
23:01:05:
23:01:05:  <!-- Network -->
23:01:05:  <proxy v=':8080'/>
23:01:05:
23:01:05:  <!-- Slot Control -->
23:01:05:  <power v='full'/>
23:01:05:
23:01:05:  <!-- User Information -->
23:01:05:  <passkey v='*****'/>
23:01:05:  <team v='223518'/>
23:01:05:  <user v='CrimsonFKR'/>
23:01:05:
23:01:05:  <!-- Folding Slots -->
23:01:05:  <slot id='0' type='CPU'/>
23:01:05:  <slot id='1' type='GPU'/>
23:01:05:  <slot id='3' type='GPU'/>
23:01:05:</config>
23:01:05:WU01:FS01:Starting
23:01:05:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
23:01:05:WU00:FS00:Starting
23:01:05:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 1100 -checkpoint 15 -np 2
23:01:05:WU00:FS00:Started FahCore on PID 2996
23:01:05:WU00:FS00:Core PID:1944
23:01:05:WU00:FS00:FahCore 0xa7 started
23:01:06:WU00:FS00:0xa7:*********************** Log Started 2020-08-17T23:01:05Z ***********************
23:01:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:01:06:WU00:FS00:0xa7:       Type: 0xa7
23:01:06:WU00:FS00:0xa7:       Core: Gromacs
23:01:06:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2996 -checkpoint 15 -np 2
23:01:06:WU00:FS00:0xa7:************************************ CBang *************************************
23:01:06:WU00:FS00:0xa7:       Date: Nov 27 2019
23:01:06:WU00:FS00:0xa7:       Time: 03:40:09
23:01:06:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
23:01:06:WU00:FS00:0xa7:     Branch: master
23:01:06:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:01:06:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:01:06:WU00:FS00:0xa7:   Platform: win32 10
23:01:06:WU00:FS00:0xa7:       Bits: 64
23:01:06:WU00:FS00:0xa7:       Mode: Release
23:01:06:WU00:FS00:0xa7:************************************ System ************************************
23:01:06:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
23:01:06:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:01:06:WU00:FS00:0xa7:       CPUs: 4
23:01:06:WU00:FS00:0xa7:     Memory: 14.95GiB
23:01:06:WU00:FS00:0xa7:Free Memory: 12.45GiB
23:01:06:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:01:06:WU00:FS00:0xa7: OS Version: 6.2
23:01:06:WU00:FS00:0xa7:Has Battery: false
23:01:06:WU00:FS00:0xa7: On Battery: false
23:01:06:WU00:FS00:0xa7: UTC Offset: -7
23:01:06:WU00:FS00:0xa7:        PID: 1944
23:01:06:WU00:FS00:0xa7:        CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\work
23:01:06:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:01:06:WU00:FS00:0xa7:    Version: 0.0.19
23:01:06:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:01:06:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:01:06:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:01:06:WU00:FS00:0xa7:       Date: Nov 25 2019
23:01:06:WU00:FS00:0xa7:       Time: 17:12:41
23:01:06:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
23:01:06:WU00:FS00:0xa7:************************************ Build *************************************
23:01:06:WU00:FS00:0xa7:       SIMD: avx_256
23:01:06:WU00:FS00:0xa7:********************************************************************************
23:01:06:WU00:FS00:0xa7:Project: 14816 (Run 2431, Clone 2, Gen 17)
23:01:06:WU00:FS00:0xa7:Unit: 0x00000014455e42065ec7cdd1048bc5d1
23:01:06:WU00:FS00:0xa7:Digital signatures verified
23:01:06:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpi state.cpt -cpt 15 -nt 2
23:01:06:WU00:FS00:0xa7:Steps: first=0 total=250000
23:01:06:WU01:FS01:Starting
23:01:06:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
23:01:06:WU02:FS03:Connecting to assign1.foldingathome.org:80
23:01:07:WU00:FS00:0xa7:Completed 93862 out of 250000 steps (37%)
23:01:07:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:01:07:WU02:FS03:Connecting to assign2.foldingathome.org:80
23:01:07:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:01:07:WU02:FS03:Connecting to assign3.foldingathome.org:80
23:01:08:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:01:08:WU02:FS03:Connecting to assign4.foldingathome.org:80
23:01:08:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:01:08:ERROR:WU02:FS03:Exception: Could not get an assignment
23:01:08:WU02:FS03:Connecting to assign1.foldingathome.org:80
23:01:08:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:01:08:WU02:FS03:Connecting to assign2.foldingathome.org:80
23:01:08:17:127.0.0.1:New Web session
23:01:09:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:01:09:WU02:FS03:Connecting to assign3.foldingathome.org:80
23:01:09:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:01:09:WU02:FS03:Connecting to assign4.foldingathome.org:80
23:01:09:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:01:09:ERROR:WU02:FS03:Exception: Could not get an assignment
23:02:07:WU01:FS01:Starting
23:02:07:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
23:02:08:WU02:FS03:Connecting to assign1.foldingathome.org:80
23:02:08:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:02:08:WU02:FS03:Connecting to assign2.foldingathome.org:80
23:02:09:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:02:09:WU02:FS03:Connecting to assign3.foldingathome.org:80
23:02:09:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:02:09:WU02:FS03:Connecting to assign4.foldingathome.org:80
23:02:09:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:02:09:ERROR:WU02:FS03:Exception: Could not get an assignment
23:02:14:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
Knish
Post by Knish »
CrimsonFKR wrote:I
you can't set something that's not there, as indicated by GPU-Z. Install Nvidia drivers from nvidia's site
CrimsonFKR
i have done that. tried the drivers from nvidia, as well as ones off of the gigabyte and aorus sites. Could not find a Zotac specific driver. so for some reason the driver install does not include what i need, or perhaps there is some special configuration i have to do?
CrimsonFKR wrote:...In GPU-Z it doesnt appear to support OpenCL,..
The screenshot you posted shows that OpenGL is detected but not OpenCL
I noticed that your driver version is 27.20 but mine is 451.48 thus you might need a more recent version of the driver?
I am aware that other donors here have successfully setup that GPGPU for folding.
[everyone is entitled to my opinion]
23:01:05: GPUs: 3
This shows two Nvidia GPUs and an Intel GPU (we are again 'blessed' by completely unsupported Intel GPUs in Production, because F@H is unaware of the idea of a Test system)
Next we have two CUDA software packages, attached to the Nvidia GPUs, 1 and 4.
Next we have an Intel version of OpenCL that is not correctly attached to GPU 2.
One 'voodoo' idea would be to clear all drivers and reinstall just the Nvidia driver.
This is a well regarded uninstaller I have never used.
https://www.guru3d.com/files-details/di ... nload.html
I hope this helps!
(if you try this, repost the configuration portion of the log, so we can see if it changed anything)
CrimsonFKR
*********************** Log Started 2020-08-18T06:21:08Z ***********************
06:21:08:Trying to access database...
06:21:08:Successfully acquired database lock
06:21:08:Read GPUs.txt
06:21:08:Enabled folding slot 00: READY cpu:2
06:21:11:Enabled folding slot 01: READY gpu:0:GP106 [P106-090]
06:21:11:Enabled folding slot 03: READY gpu:1:Gen9/GT2 [HD Graphics 530]
06:21:11:WARNING:WU03:No longer matches Slot 3's configuration, migrating to FS01
06:21:11:ERROR:Exception: Unit not found
06:21:11:****************************** FAHClient ******************************
06:21:11:        Version: 7.6.13
06:21:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:21:11:      Copyright: 2020 foldingathome.org
06:21:11:       Homepage: https://foldingathome.org/
06:21:11:           Date: Apr 27 2020
06:21:11:           Time: 21:21:01
06:21:11:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
06:21:11:         Branch: master
06:21:11:       Compiler: Visual C++ 2008
06:21:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:21:11:       Platform: win32 10
06:21:11:           Bits: 32
06:21:11:           Mode: Release
06:21:11:         Config: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\config.xml
06:21:11:******************************** CBang ********************************
06:21:11:           Date: Apr 24 2020
06:21:11:           Time: 17:07:55
06:21:11:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
06:21:11:           Bits: 32
06:21:11:******************************* System ********************************
06:21:11:            CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
06:21:11:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
06:21:11:           CPUs: 4
06:21:11:         Memory: 14.95GiB
06:21:11:    Free Memory: 13.16GiB
06:21:11:        Threads: WINDOWS_THREADS
06:21:11:     OS Version: 6.2
06:21:11:    Has Battery: false
06:21:11:     On Battery: false
06:21:11:     UTC Offset: -7
06:21:11:            PID: 8204
06:21:11:            CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient
06:21:11:  Win32 Service: false
06:21:11:             OS: Windows 10 Home
06:21:11:        OS Arch: AMD64
06:21:11:           GPUs: 3
06:21:11:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
06:21:11:          GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 Gen9/GT2 [HD Graphics 530]
06:21:11:          GPU 2: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
06:21:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
06:21:11:  CUDA Device 1: Platform:0 Device:1 Bus:4 Slot:0 Compute:6.1 Driver:11.0
06:21:11:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
06:21:11:******************************* libFAH ********************************
06:21:11:           Date: Apr 15 2020
06:21:11:           Time: 14:53:14
06:21:11:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:21:11:           Bits: 32
06:21:11:***********************************************************************
06:21:11:<config>
06:21:11:  <!-- Folding Core -->
06:21:11:  <core-priority v='low'/>
06:21:11:
06:21:11:  <!-- Network -->
06:21:11:  <proxy v=':8080'/>
06:21:11:
06:21:11:  <!-- Slot Control -->
06:21:11:  <power v='full'/>
06:21:11:
06:21:11:  <!-- User Information -->
06:21:11:  <passkey v='*****'/>
06:21:11:  <team v='223518'/>
06:21:11:  <user v='CrimsonFKR'/>
06:21:11:
06:21:11:  <!-- Folding Slots -->
06:21:11:  <slot id='0' type='CPU'/>
06:21:11:  <slot id='1' type='GPU'/>
06:21:11:  <slot id='3' type='GPU'/>
06:21:11:</config>
06:21:11:WU00:FS01:Starting
06:21:11:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:21:11:WU01:FS00:Starting
06:21:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8204 -checkpoint 15 -np 2
06:21:11:WU01:FS00:Started FahCore on PID 8236
06:21:11:WU01:FS00:Core PID:8668
06:21:11:WU01:FS00:FahCore 0xa7 started
06:21:12:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:21:12:WU01:FS00:0xa7:*********************** Log Started 2020-08-18T06:21:11Z ***********************
06:21:12:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:21:12:WU01:FS00:0xa7:       Type: 0xa7
06:21:12:WU01:FS00:0xa7:       Core: Gromacs
06:21:12:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8236 -checkpoint 15 -np 2
06:21:12:WU01:FS00:0xa7:************************************ CBang *************************************
06:21:12:WU01:FS00:0xa7:       Date: Nov 27 2019
06:21:12:WU01:FS00:0xa7:       Time: 03:40:09
06:21:12:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:21:12:WU01:FS00:0xa7:     Branch: master
06:21:12:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
06:21:12:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:21:12:WU01:FS00:0xa7:   Platform: win32 10
06:21:12:WU01:FS00:0xa7:       Bits: 64
06:21:12:WU01:FS00:0xa7:       Mode: Release
06:21:12:WU01:FS00:0xa7:************************************ System ************************************
06:21:12:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
06:21:12:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
06:21:12:WU01:FS00:0xa7:       CPUs: 4
06:21:12:WU01:FS00:0xa7:     Memory: 14.95GiB
06:21:12:WU01:FS00:0xa7:Free Memory: 12.83GiB
06:21:12:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
06:21:12:WU01:FS00:0xa7: OS Version: 6.2
06:21:12:WU01:FS00:0xa7:Has Battery: false
06:21:12:WU01:FS00:0xa7: On Battery: false
06:21:12:WU01:FS00:0xa7: UTC Offset: -7
06:21:12:WU01:FS00:0xa7:        PID: 8668
06:21:12:WU01:FS00:0xa7:        CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\work
06:21:12:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
06:21:12:WU01:FS00:0xa7:    Version: 0.0.19
06:21:12:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:21:12:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:21:12:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
06:21:12:WU01:FS00:0xa7:       Date: Nov 25 2019
06:21:12:WU01:FS00:0xa7:       Time: 17:12:41
06:21:12:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:21:12:WU01:FS00:0xa7:************************************ Build *************************************
06:21:12:WU01:FS00:0xa7:       SIMD: avx_256
06:21:12:WU01:FS00:0xa7:********************************************************************************
06:21:12:WU01:FS00:0xa7:Project: 14823 (Run 2753, Clone 1, Gen 125)
06:21:12:WU01:FS00:0xa7:Unit: 0x000000949bf7a4d55ea30b702d2a286d
06:21:12:WU01:FS00:0xa7:Digital signatures verified
06:21:12:WU01:FS00:0xa7:Calling: mdrun -s frame125.tpr -o frame125.trr -cpi state.cpt -cpt 15 -nt 2
06:21:12:WU01:FS00:0xa7:ERROR:Guru Meditation #5923ea52d4c2e70e.436ad8f752710404 (1354152.2708304) '01/01/frame125.trr'
06:21:13:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:21:13:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:21:15:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:21:15:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:21:16:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:21:16:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:21:16:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:21:16:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:21:16:WU01:FS00:Starting
06:21:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8204 -checkpoint 15 -np 2
06:21:16:WU01:FS00:Started FahCore on PID 10096
06:21:17:WU01:FS00:Core PID:10120
06:21:17:WU01:FS00:FahCore 0xa7 started
06:21:17:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:21:17:ERROR:WU02:FS03:Exception: Could not get an assignment
06:21:17:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:21:17:WU01:FS00:0xa7:*********************** Log Started 2020-08-18T06:21:17Z ***********************
06:21:17:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:21:17:WU01:FS00:0xa7:       Type: 0xa7
06:21:17:WU01:FS00:0xa7:       Core: Gromacs
06:21:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10096 -checkpoint 15 -np
06:21:17:WU01:FS00:0xa7:             2
06:21:17:WU01:FS00:0xa7:************************************ CBang *************************************
06:21:17:WU01:FS00:0xa7:       Date: Nov 27 2019
06:21:17:WU01:FS00:0xa7:       Time: 03:40:09
06:21:17:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:21:17:WU01:FS00:0xa7:     Branch: master
06:21:17:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
06:21:17:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:21:17:WU01:FS00:0xa7:   Platform: win32 10
06:21:17:WU01:FS00:0xa7:       Bits: 64
06:21:17:WU01:FS00:0xa7:       Mode: Release
06:21:17:WU01:FS00:0xa7:************************************ System ************************************
06:21:17:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
06:21:17:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
06:21:17:WU01:FS00:0xa7:       CPUs: 4
06:21:17:WU01:FS00:0xa7:     Memory: 14.95GiB
06:21:17:WU01:FS00:0xa7:Free Memory: 12.61GiB
06:21:17:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
06:21:17:WU01:FS00:0xa7: OS Version: 6.2
06:21:17:WU01:FS00:0xa7:Has Battery: false
06:21:17:WU01:FS00:0xa7: On Battery: false
06:21:17:WU01:FS00:0xa7: UTC Offset: -7
06:21:17:WU01:FS00:0xa7:        PID: 10120
06:21:17:WU01:FS00:0xa7:        CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\work
06:21:17:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
06:21:17:WU01:FS00:0xa7:    Version: 0.0.19
06:21:17:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:21:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:21:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
06:21:17:WU01:FS00:0xa7:       Date: Nov 25 2019
06:21:17:WU01:FS00:0xa7:       Time: 17:12:41
06:21:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:21:17:WU01:FS00:0xa7:************************************ Build *************************************
06:21:17:WU01:FS00:0xa7:       SIMD: avx_256
06:21:17:WU01:FS00:0xa7:********************************************************************************
06:21:17:WU01:FS00:0xa7:Project: 14823 (Run 2753, Clone 1, Gen 125)
06:21:17:WU01:FS00:0xa7:Unit: 0x000000949bf7a4d55ea30b702d2a286d
06:21:17:WU01:FS00:0xa7:Digital signatures verified
06:21:17:WU01:FS00:0xa7:Calling: mdrun -s frame125.tpr -o frame125.trr -cpi state.cpt -cpt 15 -nt 2
06:21:17:WU01:FS00:0xa7:ERROR:Guru Meditation #5923ea52d4c2e70e.436ad8f752710404 (1354152.2708304) '01/01/frame125.trr'
06:21:18:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:21:18:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:21:18:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:21:18:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:21:18:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:21:18:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:21:19:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:21:19:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:21:19:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:21:19:ERROR:WU02:FS03:Exception: Could not get an assignment
06:22:12:WU00:FS01:Starting
06:22:12:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:22:17:WU01:FS00:Starting
06:22:17:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8204 -checkpoint 15 -np 2
06:22:17:WU01:FS00:Started FahCore on PID 2912
06:22:17:WU01:FS00:Core PID:2996
06:22:17:WU01:FS00:FahCore 0xa7 started
06:22:17:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:22:17:WU01:FS00:0xa7:*********************** Log Started 2020-08-18T06:22:17Z ***********************
06:22:17:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:22:17:WU01:FS00:0xa7:       Type: 0xa7
06:22:17:WU01:FS00:0xa7:       Core: Gromacs
06:22:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2912 -checkpoint 15 -np 2
06:22:17:WU01:FS00:0xa7:************************************ CBang *************************************
06:22:17:WU01:FS00:0xa7:       Date: Nov 27 2019
06:22:17:WU01:FS00:0xa7:       Time: 03:40:09
06:22:17:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:22:17:WU01:FS00:0xa7:     Branch: master
06:22:17:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
06:22:17:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:22:17:WU01:FS00:0xa7:   Platform: win32 10
06:22:17:WU01:FS00:0xa7:       Bits: 64
06:22:17:WU01:FS00:0xa7:       Mode: Release
06:22:17:WU01:FS00:0xa7:************************************ System ************************************
06:22:17:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
06:22:17:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
06:22:17:WU01:FS00:0xa7:       CPUs: 4
06:22:17:WU01:FS00:0xa7:     Memory: 14.95GiB
06:22:17:WU01:FS00:0xa7:Free Memory: 12.60GiB
06:22:17:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
06:22:17:WU01:FS00:0xa7: OS Version: 6.2
06:22:17:WU01:FS00:0xa7:Has Battery: false
06:22:17:WU01:FS00:0xa7: On Battery: false
06:22:17:WU01:FS00:0xa7: UTC Offset: -7
06:22:17:WU01:FS00:0xa7:        PID: 2996
06:22:17:WU01:FS00:0xa7:        CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\work
06:22:17:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
06:22:17:WU01:FS00:0xa7:    Version: 0.0.19
06:22:17:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:22:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:22:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
06:22:17:WU01:FS00:0xa7:       Date: Nov 25 2019
06:22:17:WU01:FS00:0xa7:       Time: 17:12:41
06:22:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:22:17:WU01:FS00:0xa7:************************************ Build *************************************
06:22:17:WU01:FS00:0xa7:       SIMD: avx_256
06:22:17:WU01:FS00:0xa7:********************************************************************************
06:22:17:WU01:FS00:0xa7:Project: 14823 (Run 2753, Clone 1, Gen 125)
06:22:17:WU01:FS00:0xa7:Unit: 0x000000949bf7a4d55ea30b702d2a286d
06:22:17:WU01:FS00:0xa7:Digital signatures verified
06:22:17:WU01:FS00:0xa7:Calling: mdrun -s frame125.tpr -o frame125.trr -cpi state.cpt -cpt 15 -nt 2
06:22:17:WU01:FS00:0xa7:ERROR:Guru Meditation #5923ea52d4c2e70e.436ad8f752710404 (1354152.2708304) '01/01/frame125.trr'
06:22:18:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:22:18:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:22:18:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:22:18:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:22:18:WARNING:WU01:FS00:Too many errors, failing
06:22:18:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14823 run:2753 clone:1 gen:125 core:0xa7 unit:0x000000949bf7a4d55ea30b702d2a286d
06:22:18:WU01:FS00:Connecting to 155.247.164.213:8080
06:22:18:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:22:18:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:22:18:WU03:FS00:Connecting to assign1.foldingathome.org:80
06:22:18:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:22:18:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:22:18:WU01:FS00:Server responded WORK_ACK (400)
06:22:18:WU01:FS00:Cleaning up
06:22:18:WU03:FS00:Assigned to work server 69.94.66.7
06:22:18:WU03:FS00:Requesting new work unit for slot 00: READY cpu:2 from 69.94.66.7
06:22:18:WU03:FS00:Connecting to 69.94.66.7:8080
06:22:19:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:22:19:ERROR:WU02:FS03:Exception: Could not get an assignment
06:22:19:WU03:FS00:Downloading 2.82MiB
06:22:25:WU03:FS00:Download 17.74%
06:22:31:WU03:FS00:Download 39.92%
06:22:37:WU03:FS00:Download 62.09%
06:22:43:WU03:FS00:Download 90.92%
06:22:45:WU03:FS00:Download complete
06:22:45:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14379 run:1387 clone:4 gen:372 core:0xa7 unit:0x000001a4455e42075e933002549e38e6
06:22:45:WU03:FS00:Starting
06:22:45:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 8204 -checkpoint 15 -np 2
06:22:45:WU03:FS00:Started FahCore on PID 5040
06:22:45:WU03:FS00:Core PID:5200
06:22:45:WU03:FS00:FahCore 0xa7 started
06:22:46:WU03:FS00:0xa7:*********************** Log Started 2020-08-18T06:22:45Z ***********************
06:22:46:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:22:46:WU03:FS00:0xa7:       Type: 0xa7
06:22:46:WU03:FS00:0xa7:       Core: Gromacs
06:22:46:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 5040 -checkpoint 15 -np 2
06:22:46:WU03:FS00:0xa7:************************************ CBang *************************************
06:22:46:WU03:FS00:0xa7:       Date: Nov 27 2019
06:22:46:WU03:FS00:0xa7:       Time: 03:40:09
06:22:46:WU03:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:22:46:WU03:FS00:0xa7:     Branch: master
06:22:46:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
06:22:46:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:22:46:WU03:FS00:0xa7:   Platform: win32 10
06:22:46:WU03:FS00:0xa7:       Bits: 64
06:22:46:WU03:FS00:0xa7:       Mode: Release
06:22:46:WU03:FS00:0xa7:************************************ System ************************************
06:22:46:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
06:22:46:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
06:22:46:WU03:FS00:0xa7:       CPUs: 4
06:22:46:WU03:FS00:0xa7:     Memory: 14.95GiB
06:22:46:WU03:FS00:0xa7:Free Memory: 12.61GiB
06:22:46:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
06:22:46:WU03:FS00:0xa7: OS Version: 6.2
06:22:46:WU03:FS00:0xa7:Has Battery: false
06:22:46:WU03:FS00:0xa7: On Battery: false
06:22:46:WU03:FS00:0xa7: UTC Offset: -7
06:22:46:WU03:FS00:0xa7:        PID: 5200
06:22:46:WU03:FS00:0xa7:        CWD: C:\Users\CrimsonFKR\AppData\Roaming\FAHClient\work
06:22:46:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
06:22:46:WU03:FS00:0xa7:    Version: 0.0.19
06:22:46:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:22:46:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:22:46:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
06:22:46:WU03:FS00:0xa7:       Date: Nov 25 2019
06:22:46:WU03:FS00:0xa7:       Time: 17:12:41
06:22:46:WU03:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:22:46:WU03:FS00:0xa7:************************************ Build *************************************
06:22:46:WU03:FS00:0xa7:       SIMD: avx_256
06:22:46:WU03:FS00:0xa7:********************************************************************************
06:22:46:WU03:FS00:0xa7:Project: 14379 (Run 1387, Clone 4, Gen 372)
06:22:46:WU03:FS00:0xa7:Unit: 0x000001a4455e42075e933002549e38e6
06:22:46:WU03:FS00:0xa7:Reading tar file core.xml
06:22:46:WU03:FS00:0xa7:Reading tar file frame372.tpr
06:22:46:WU03:FS00:0xa7:Digital signatures verified
06:22:46:WU03:FS00:0xa7:Calling: mdrun -s frame372.tpr -o frame372.trr -cpt 15 -nt 2
06:22:46:WU03:FS00:0xa7:Steps: first=0 total=250000
06:22:47:WU03:FS00:0xa7:Completed 1 out of 250000 steps (0%)
06:23:49:WU00:FS01:Starting
06:23:49:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:23:54:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:23:55:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:23:55:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:23:55:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:23:55:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:23:55:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:23:55:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:23:56:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:23:56:ERROR:WU02:FS03:Exception: Could not get an assignment
06:25:09:WU03:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
06:26:26:WU00:FS01:Starting
06:26:26:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:26:32:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:26:32:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:26:32:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:26:33:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:26:33:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:26:33:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:26:33:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:26:34:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:26:34:ERROR:WU02:FS03:Exception: Could not get an assignment
06:27:32:WU03:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
06:29:53:WU03:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
06:30:40:WU00:FS01:Starting
06:30:40:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:30:40:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:13422 run:9 clone:21 gen:2 core:0x22 unit:0x0000000512bc7d9a5f3881eb4d221fb6
06:30:40:WU00:FS01:Connecting to 18.188.125.154:8080
06:30:41:WU00:FS01:Server responded WORK_ACK (400)
06:30:41:WU00:FS01:Cleaning up
06:30:41:WU01:FS01:Connecting to assign1.foldingathome.org:80
06:30:41:WU01:FS01:Assigned to work server 18.188.125.154
06:30:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [P106-090] from 18.188.125.154
06:30:41:WU01:FS01:Connecting to 18.188.125.154:8080
06:30:42:WU01:FS01:Downloading 7.04MiB
06:30:46:WU02:FS03:Connecting to assign1.foldingathome.org:80
06:30:46:WARNING:WU02:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:30:46:WU02:FS03:Connecting to assign2.foldingathome.org:80
06:30:46:WU01:FS01:Download complete
06:30:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13422 run:271 clone:68 gen:2 core:0x22 unit:0x0000000312bc7d9a5f388ee0b3c96b3e
06:30:47:WU01:FS01:Starting
06:30:47:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:30:47:WARNING:WU02:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:30:47:WU02:FS03:Connecting to assign3.foldingathome.org:80
06:30:48:WARNING:WU02:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:30:48:WU02:FS03:Connecting to assign4.foldingathome.org:80
06:30:48:WARNING:WU02:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:30:48:ERROR:WU02:FS03:Exception: Could not get an assignment
06:31:47:WU01:FS01:Starting
06:31:47:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:32:15:WU03:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
06:33:24:WU01:FS01:Starting
06:33:24:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:34:36:WU03:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
06:36:01:WU01:FS01:Starting
06:36:01:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
06:36:57:WU03:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
CrimsonFKR
unfortunately, that solution did not work. I found a zotac specific driver which i installed
https://www.zotac.com/us/files/download ... 235&os=981
i used the software you pointed me to, found that they were undetected in device manager after a restart, installed the above driver, restarted, and attempted to run FAH. the only change in GPU-Z was the addition of 'DCH' in the driver as shown here
There are a lot of changes being made to FAHClient and numerous beta versions have been proposed but so far they still contain bugs so I can't really recommend you try any of them. Nevertheless, somewhere along that series of changes, (between the released version you're running and the latest beta version) the use of "index" values to configure GPUs has been deprecated. AND the replacement methodology hasn't quite been perfected yet. Please be patient.
[If you try the beta version, you do so at your own risk.]
I certainly would try removing all of the drivers and then first installing the drivers downloaded from NVidia. (Personally, I've never configured a P106 so I don't know what drivers are available.)
The problem associated with the Intel iGPU has also been resolved in the latest beta version.
FYI, there are few donors who have successfully setup P106 in Linux to fold. Here's the main search that you can use to do some light reading to see if there's anything you can do: search.php?st=0&sk=t&sd=d&sr=posts&keywords=P106
gunnarre
Post by gunnarre »
In case you want to try folding on Linux: On Linux Mint/Ubuntu, I found that I had to run the "server" variant of the Nvidia drivers when running multiple Nvidia cards. The regular driver only worked for a single card. The Mint driver manager detected this on its own and recommended the update, which I just applied and rebooted - so I didn't even have to use the Nvidia website for this. Nvidia-smi works as expected, and for non-mining card the graphics also work.
For other Linux distributions, you might have to install the driver via the "run" option on the Nvidia website to get it to work.
HaloJones
Post by HaloJones »
It should support OpenCL 1.2
Until GPU-Z sees it as such, you won't be able to fold on them.
single 1070
ajm
Post by ajm »
Looking at the new log, It seems like OpenCL is there, but cannot be correctly attributed to Bus/Slots, the HD 530 GPU was mingled into the installation/structuration of devices/bus/slots and OpenCL was not correctly installed either, not even where it appears to be there. It is a terrible mess.
I would try to disable the Intel 530 before the installation. And I would first of all uninstall FAH, incl. Data.
1. Uninstall FAH incl. Data
2. Disable the Intel GPU (if necessary connect the monitor to one of the Nvidia cars)
3. DDU all present GPU drivers
4. Install the latest Nvidia drivers
5. Install FAH
Ichbin3
Hardware configuration: MSI H81M, G3240, RTX 2080Ti_Rev-A@220W, Ubuntu 18.04
Post by Ichbin3 »
CrimsonFKR wrote:unfortunately, that solution did not work. I found a zotac specific driver which i installed
It is still a 3 years old driver.
Try one of the newer ones.
