Can't Access Stats Report
Hi there
For the last couple of days, I have been unable to load the stats page. Is this a known problem? On the first attempt it doesn't load, on subsequent attempts, it displays the message "Bad Gateway". All other functions, including folding and team, OS and other donor stats display fine.
All the best
Julian
All the best
Julian
Re: Can't Access Stats Report
Welcome to the F@H Forum JulianM,
Thanks for pointing that out. I can confirm that I too can't load the individual Stats report. I will notify the correct people for this
MantisMan13
I've been seeing this come and go frequently over the last few weeks. Happening again now where I can't get to the team page and get the bad gateway error or the page will take a very long time to load. Same with Donner. This reminds me of how pages might act if the database query is having issues with handle requests and connection threads timing out. If they are using MYSQL, a check to the slow query log and some table maintenance may be in order to get indexes working correctly again.
It is now working fine for me. I got an update and there's no issue from F@H side. It might be a routing or a network issue which means that there's very little (if anything) that can be done to fix it.
I saw a message saying that a problem with the stats sever was resolved. It didn't specify what problem, but the event's time corresponds to when you started getting stats reports again. Coincidence? Perhaps; perhaps not.
Brian_S_Wilson
I added a new workstation to my team today and suddenly I can't see the team stats any more. Anyone else seeing this issue?
Just checked again. After 15 minutes, I'm now seeing the stats now.
SandyG
- Hardware configuration: 2 Shuttle i9's with RTX3060, Old server mobo, Mint Linux with 2 RTX3090's and 2 RTX 4090. Dell 7920 RTX3060, RTX4070
[img]https://folding.extremeoverclocking.com/sigs/sigimage.php?u=1172112[/img] - Contact:
Same here, 'Bad Gateway' or page just hangs. This seems to be only on the individual stats check. If I look on the stats pages under different categories they call come up. If I do a donor specific search or click the link on the local processing status page it hosed with the bad gateway message.
I'm going to make a guess.
The "bad gateway" message is often a sign that the connection to the server is overloaded. If we accept that explanation as applying to you, and the fact that FAH strongly discourages gathering too much detail from the database rather than choosing to download the flat files, we quickly arrive at the fact that too many people are trying to extract too many details.
This might or might not apply.
I've been having the problem for the last couple of days. I'm including a copy of my log in case it helps:
*********************** Log Started 2021-03-30T19:53:03Z ***********************
19:53:03:******************************* libFAH ********************************
19:53:03: Date: Oct 20 2020
19:53:03: Time: 13:36:55
19:53:03: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:53:03: Branch: master
19:53:03: Compiler: Visual C++ 2015
19:53:03: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:53:03: Platform: win32 10
19:53:03: Bits: 32
19:53:03: Mode: Release
19:53:03:****************************** FAHClient ******************************
19:53:03: Version: 7.6.21
19:53:03: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:53:03: Copyright: 2020 foldingathome.org
19:53:03: Homepage: https://foldingathome.org/
19:53:03: Time: 13:41:04
19:53:03: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:53:03: Bits: 32
19:53:03: Args: --open-web-control
19:53:03: Config: C:\Users\waltj\AppData\Roaming\FAHClient\config.xml
19:53:03:******************************** CBang ********************************
19:53:03: Time: 11:36:18
19:53:03: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:53:03: Bits: 32
19:53:03:******************************* System ********************************
19:53:03: CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
19:53:03: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:53:03: CPUs: 12
19:53:03: Memory: 15.88GiB
19:53:03: Free Memory: 11.23GiB
19:53:03: Threads: WINDOWS_THREADS
19:53:03: OS Version: 6.2
19:53:03: Has Battery: true
19:53:03: On Battery: false
19:53:03: UTC Offset: -4
19:53:03: PID: 1472
19:53:03: CWD: C:\Users\waltj\AppData\Roaming\FAHClient
19:53:03: Win32 Service: false
19:53:03: OS: Windows 10 Home
19:53:03: OS Arch: AMD64
19:53:03: GPUs: 1
19:53:03: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116M [GeForce GTX 1660 Mobile]
19:53:03: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.1
19:53:03:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.63
19:53:03:***********************************************************************
19:53:03:<config>
19:53:03: <!-- Folding Slot Configuration -->
19:53:03: <cause v='COVID_19'/>
19:53:03:
19:53:03: <!-- Slot Control -->
19:53:03: <power v='FULL'/>
19:53:03:
19:53:03: <!-- User Information -->
19:53:03: <passkey v='*****'/>
19:53:03: <team v='1'/>
19:53:03: <user v='wjones40'/>
19:53:03:
19:53:03: <!-- Folding Slots -->
19:53:03: <slot id='0' type='CPU'/>
19:53:03: <slot id='1' type='GPU'/>
19:53:03:</config>
19:53:03:Trying to access database...
19:53:03:Successfully acquired database lock
19:53:03:FS00:Initialized folding slot 00: cpu:11
19:53:03:FS01:Initialized folding slot 01: gpu:1:0 TU116M [GeForce GTX 1660 Mobile]
19:53:03:WU02:FS00:Starting
19:53:03:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\waltj\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 1472 -checkpoint 15 -np 11
19:53:03:WU02:FS00:Started FahCore on PID 10568
19:53:03:WU02:FS00:Core PID:15272
19:53:03:WU02:FS00:FahCore 0xa7 started
19:53:04:WU01:FS01:Starting
19:53:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\waltj\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1472 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:53:04:WU01:FS01:Started FahCore on PID 13488
19:53:04:WU01:FS01:Core PID:17440
19:53:04:WU01:FS01:FahCore 0x22 started
19:53:04:WU02:FS00:0xa7:*********************** Log Started 2021-03-30T19:53:03Z ***********************
19:53:04:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:53:04:WU02:FS00:0xa7: Type: 0xa7
19:53:04:WU02:FS00:0xa7: Core: Gromacs
19:53:04:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 10568 -checkpoint 15 -np
19:53:04:WU02:FS00:0xa7: 11
19:53:04:WU02:FS00:0xa7:************************************ CBang *************************************
19:53:04:WU02:FS00:0xa7: Date: Nov 27 2019
19:53:04:WU02:FS00:0xa7: Time: 03:40:09
19:53:04:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
19:53:04:WU02:FS00:0xa7: Branch: master
19:53:04:WU02:FS00:0xa7: Compiler: Visual C++ 2008
19:53:04:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:53:04:WU02:FS00:0xa7: Platform: win32 10
19:53:04:WU02:FS00:0xa7: Bits: 64
19:53:04:WU02:FS00:0xa7: Mode: Release
19:53:04:WU02:FS00:0xa7:************************************ System ************************************
19:53:04:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
19:53:04:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:53:04:WU02:FS00:0xa7: CPUs: 12
19:53:04:WU02:FS00:0xa7: Memory: 15.88GiB
19:53:04:WU02:FS00:0xa7:Free Memory: 11.23GiB
19:53:04:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
19:53:04:WU02:FS00:0xa7: OS Version: 6.2
19:53:04:WU02:FS00:0xa7:Has Battery: true
19:53:04:WU02:FS00:0xa7: On Battery: false
19:53:04:WU02:FS00:0xa7: UTC Offset: -4
19:53:04:WU02:FS00:0xa7: PID: 15272
19:53:04:WU01:FS01:0x22:*********************** Log Started 2021-03-30T19:53:04Z ***********************
19:53:04:WU02:FS00:0xa7: CWD: C:\Users\waltj\AppData\Roaming\FAHClient\work
19:53:04:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:53:04:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
19:53:04:WU01:FS01:0x22: Core: Core22
19:53:04:WU02:FS00:0xa7: Version: 0.0.19
19:53:04:WU01:FS01:0x22: Type: 0x22
19:53:04:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:53:04:WU01:FS01:0x22: Version: 0.0.13
19:53:04:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
19:53:04:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:53:04:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
19:53:04:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
19:53:04:WU02:FS00:0xa7: Date: Nov 25 2019
19:53:04:WU01:FS01:0x22: Homepage: https://foldingathome.org/
19:53:04:WU02:FS00:0xa7: Time: 17:12:41
19:53:04:WU01:FS01:0x22: Date: Sep 19 2020
19:53:04:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
19:53:04:WU01:FS01:0x22: Time: 02:35:58
19:53:04:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:53:04:WU01:FS01:0x22: Branch: core22-0.0.13
19:53:04:WU01:FS01:0x22: Compiler: Visual C++ 2015
19:53:04:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:53:04:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
19:53:04:WU01:FS01:0x22: Platform: win32 10
19:53:04:WU02:FS00:0xa7:************************************ Build *************************************
19:53:04:WU01:FS01:0x22: Bits: 64
19:53:04:WU02:FS00:0xa7: SIMD: avx_256
19:53:04:WU01:FS01:0x22: Mode: Release
19:53:04:WU02:FS00:0xa7:********************************************************************************
19:53:04:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:53:04:WU02:FS00:0xa7:Project: 16927 (Run 21, Clone 318, Gen 115)
19:53:04:WU01:FS01:0x22: <peastman@stanford.edu>
19:53:04:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
19:53:04:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 13488 -checkpoint 15
19:53:04:WU02:FS00:0xa7:Digital signatures verified
19:53:04:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:53:04:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
19:53:04:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
19:53:04:WU02:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -cpi state.cpt -cpt 15 -nt 10
19:53:04:WU01:FS01:0x22:************************************ libFAH ************************************
19:53:04:WU01:FS01:0x22: Date: Sep 7 2020
19:53:04:WU01:FS01:0x22: Time: 19:09:56
19:53:04:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:53:04:WU01:FS01:0x22: Branch: HEAD
19:53:04:WU01:FS01:0x22:************************************ CBang *************************************
19:53:04:WU01:FS01:0x22: Time: 19:08:30
19:53:04:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:53:04:WU01:FS01:0x22:************************************ System ************************************
19:53:04:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
19:53:04:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:53:04:WU01:FS01:0x22: CPUs: 12
19:53:04:WU01:FS01:0x22: Memory: 15.88GiB
19:53:04:WU01:FS01:0x22:Free Memory: 11.20GiB
19:53:04:WU01:FS01:0x22: Threads: WINDOWS_THREADS
19:53:04:WU01:FS01:0x22: OS Version: 6.2
19:53:04:WU01:FS01:0x22:Has Battery: true
19:53:04:WU01:FS01:0x22: On Battery: false
19:53:04:WU01:FS01:0x22: UTC Offset: -4
19:53:04:WU01:FS01:0x22: PID: 17440
19:53:04:WU01:FS01:0x22: CWD: C:\Users\waltj\AppData\Roaming\FAHClient\work
19:53:04:WU01:FS01:0x22:************************************ OpenMM ************************************
19:53:04:WU01:FS01:0x22: Revision: 189320d0
19:53:04:WU01:FS01:0x22:********************************************************************************
19:53:04:WU01:FS01:0x22:Project: 17339 (Run 14, Clone 103, Gen 30)
19:53:04:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:53:04:WU01:FS01:0x22:Digital signatures verified
19:53:04:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:53:04:WU01:FS01:0x22:Version 0.0.13
19:53:04:WU01:FS01:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
19:53:04:WU01:FS01:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
19:53:04:WU01:FS01:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
19:53:04:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
19:53:04:WU01:FS01:0x22:There are 4 platforms available.
19:53:04:WU01:FS01:0x22:Platform 0: Reference
19:53:04:WU01:FS01:0x22:Platform 1: CPU
19:53:04:WU01:FS01:0x22:Platform 2: OpenCL
19:53:04:WU01:FS01:0x22: opencl-device 0 specified
19:53:04:WU01:FS01:0x22:Platform 3: CUDA
19:53:04:WU01:FS01:0x22: cuda-device 0 specified
19:53:05:WU02:FS00:0xa7:Steps: first=57500000 total=500000
19:53:08:WU02:FS00:0xa7:Completed 429702 out of 500000 steps (85%)
19:53:18:5:127.0.0.1:New Web session
19:53:20:13:127.0.0.1:New Web session
19:53:26:WU02:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
19:53:36:WU01:FS01:0x22:Attempting to create CUDA context:
19:53:36:WU01:FS01:0x22: Configuring platform CUDA
19:53:45:WU01:FS01:0x22: Using CUDA and gpu 0
19:53:46:WU01:FS01:0x22:Completed 450000 out of 750000 steps (60%)
19:54:04:Saving configuration to config.xml
19:54:04:<config>
19:54:04: <!-- Folding Slot Configuration -->
19:54:04: <cause v='COVID_19'/>
19:54:04:
19:54:04: <!-- Slot Control -->
19:54:04: <power v='FULL'/>
19:54:04:
19:54:04: <!-- User Information -->
19:54:04: <passkey v='*****'/>
19:54:04: <team v='1'/>
19:54:04: <user v='wjones40'/>
19:54:04:
19:54:04: <!-- Folding Slots -->
19:54:04: <slot id='0' type='CPU'/>
19:54:04: <slot id='1' type='GPU'>
19:54:04: <pci-bus v='1'/>
19:54:04: <pci-slot v='0'/>
19:54:04: </slot>
19:54:04:</config>
19:55:44:WU01:FS01:0x22:Completed 457500 out of 750000 steps (61%)
19:56:56:WU02:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
19:57:43:WU01:FS01:0x22:Completed 465000 out of 750000 steps (62%)
19:57:46:WU01:FS01:0x22:Checkpoint completed at step 465000
