5700xt and 2060 KO Ultra <400k PPD
catwell
Post by catwell »
I've been reading the forum for some time, and I tried to follow all the setting people use.
But, my video cards are getting about 1/2 the PPD others seem to get. But why?
I have a 5700XT and a 2060 KO Ultra.
The 5700XT is my video out card. The other is just there for folding.
I sometimes get 400k PPD on each card, or a total of 800k.
I removed the CPU folding slot, but I didn't see a bump in PPD.
Any guidance would be greatly appreciated!
*********************** Log Started 2020-08-14T07:20:20Z ***********************
07:20:20:Trying to access database...
07:20:20:Successfully acquired database lock
07:20:20:Read GPUs.txt
07:20:21:Enabled folding slot 01: PAUSED gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] (by user)
07:20:21:Enabled folding slot 02: PAUSED gpu:1:TU104 [GeForce RTX 2060] (by user)
07:20:21:****************************** FAHClient ******************************
07:20:21:        Version: 7.6.13
07:20:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:20:21:      Copyright: 2020 foldingathome.org
07:20:21:       Homepage: https://foldingathome.org/
07:20:21:           Date: Apr 27 2020
07:20:21:           Time: 21:21:01
07:20:21:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:20:21:         Branch: master
07:20:21:       Compiler: Visual C++ 2008
07:20:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:20:21:       Platform: win32 10
07:20:21:           Bits: 32
07:20:21:           Mode: Release
07:20:21:           Args: --open-web-control
07:20:21:         Config: C:\Users\1\AppData\Roaming\FAHClient\config.xml
07:20:21:******************************** CBang ********************************
07:20:21:           Date: Apr 24 2020
07:20:21:           Time: 17:07:55
07:20:21:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:20:21:           Bits: 32
07:20:21:******************************* System ********************************
07:20:21:            CPU: AMD Ryzen 7 3800X 8-Core Processor
07:20:21:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:20:21:           CPUs: 16
07:20:21:         Memory: 31.92GiB
07:20:21:    Free Memory: 17.80GiB
07:20:21:        Threads: WINDOWS_THREADS
07:20:21:     OS Version: 6.2
07:20:21:    Has Battery: false
07:20:21:     On Battery: false
07:20:21:     UTC Offset: -5
07:20:21:            PID: 8488
07:20:21:            CWD: C:\Users\1\AppData\Roaming\FAHClient
07:20:21:  Win32 Service: false
07:20:21:             OS: Windows 10 Enterprise
07:20:21:        OS Arch: AMD64
07:20:21:           GPUs: 2
07:20:21:          GPU 0: Bus:11 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
07:20:21:                 / 5700/5700 XT]
07:20:21:          GPU 1: Bus:3 Slot:0 Func:0 NVIDIA:7 TU104 [GeForce RTX 2060]
07:20:21:  CUDA Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:7.5 Driver:11.0
07:20:21:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:1.2 Driver:3004.7
07:20:21:OpenCL Device 1: Platform:1 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:451.67
07:20:21:******************************* libFAH ********************************
07:20:21:           Date: Apr 15 2020
07:20:21:           Time: 14:53:14
07:20:21:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:20:21:           Bits: 32
07:20:21:***********************************************************************
07:20:21:<config>
07:20:21:  <!-- Folding Core -->
07:20:21:  <checkpoint v='30'/>
07:20:21:  <core-priority v='low'/>
07:20:21:
07:20:21:  <!-- Folding Slot Configuration -->
07:20:21:  <cause v='HIGH_PRIORITY'/>
07:20:21:
07:20:21:  <!-- Network -->
07:20:21:  <proxy v=':8080'/>
07:20:21:
07:20:21:  <!-- Slot Control -->
07:20:21:  <power v='full'/>
07:20:21:
07:20:21:  <!-- User Information -->
07:20:21:
07:20:21:
07:20:21:  <!-- Folding Slots -->
07:20:21:  <slot id='1' type='GPU'>
07:20:21:    <gpu-index v='0'/>
07:20:21:    <paused v='true'/>
07:20:21:  </slot>
07:20:21:  <slot id='2' type='GPU'>
07:20:21:  </slot>
07:20:21:</config>
07:20:22:5:127.0.0.1:New Web session
07:20:22:6:127.0.0.1:New Web session
07:20:25:17:127.0.0.1:New Web session
07:20:37:FS01:Unpaused
07:20:37:FS02:Unpaused
07:20:38:WU01:FS01:Starting
07:20:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:20:38:WU01:FS01:Started FahCore on PID 23072
07:20:38:WU01:FS01:Core PID:17644
07:20:38:WU01:FS01:FahCore 0x22 started
07:20:38:WU00:FS02:Starting
07:20:38:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
07:20:38:WU00:FS02:Started FahCore on PID 18760
07:20:38:WU00:FS02:Core PID:25336
07:20:38:WU00:FS02:FahCore 0x22 started
07:20:38:WU01:FS01:0x22:*********************** Log Started 2020-08-14T07:20:38Z ***********************
07:20:38:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:20:38:WU01:FS01:0x22:       Core: Core22
07:20:38:WU01:FS01:0x22:       Type: 0x22
07:20:38:WU01:FS01:0x22:    Version: 0.0.11
07:20:38:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:20:38:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:20:38:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:20:38:WU01:FS01:0x22:       Date: Jun 26 2020
07:20:38:WU01:FS01:0x22:       Time: 19:49:16
07:20:38:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:20:38:WU01:FS01:0x22:     Branch: core22-0.0.11
07:20:38:WU01:FS01:0x22:   Compiler: Visual C++ 2015
07:20:38:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:20:38:WU01:FS01:0x22:   Platform: win32 10
07:20:38:WU01:FS01:0x22:       Bits: 64
07:20:38:WU01:FS01:0x22:       Mode: Release
07:20:38:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:20:38:WU01:FS01:0x22:             <peastman@stanford.edu>
07:20:38:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 23072 -checkpoint 30
07:20:38:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:20:38:WU01:FS01:0x22:************************************ libFAH ************************************
07:20:38:WU01:FS01:0x22:       Time: 19:47:12
07:20:38:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:20:38:WU01:FS01:0x22:     Branch: HEAD
07:20:38:WU01:FS01:0x22:************************************ CBang *************************************
07:20:38:WU01:FS01:0x22:       Time: 19:46:11
07:20:38:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:20:38:WU01:FS01:0x22:     Branch: master
07:20:38:WU01:FS01:0x22:************************************ System ************************************
07:20:38:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:20:38:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:20:38:WU01:FS01:0x22:       CPUs: 16
07:20:38:WU01:FS01:0x22:     Memory: 31.92GiB
07:20:38:WU01:FS01:0x22:Free Memory: 17.69GiB
07:20:38:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:20:38:WU01:FS01:0x22: OS Version: 6.2
07:20:38:WU01:FS01:0x22:Has Battery: false
07:20:38:WU01:FS01:0x22: On Battery: false
07:20:38:WU01:FS01:0x22: UTC Offset: -5
07:20:38:WU01:FS01:0x22:        PID: 17644
07:20:38:WU01:FS01:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:20:38:WU01:FS01:0x22:********************************************************************************
07:20:38:WU01:FS01:0x22:Project: 13420 (Run 7111, Clone 41, Gen 2)
07:20:38:WU01:FS01:0x22:Unit: 0x0000000612bc7d9a5f2249a9bebe8a88
07:20:38:WU01:FS01:0x22:Digital signatures verified
07:20:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:20:38:WU01:FS01:0x22:Version 0.0.11
07:20:38:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:20:38:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:20:38:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:20:38:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:20:38:WU00:FS02:0x22:*********************** Log Started 2020-08-14T07:20:38Z ***********************
07:20:38:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:20:38:WU00:FS02:0x22:       Core: Core22
07:20:38:WU00:FS02:0x22:       Type: 0x22
07:20:38:WU00:FS02:0x22:    Version: 0.0.11
07:20:38:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:20:38:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
07:20:38:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
07:20:38:WU00:FS02:0x22:       Date: Jun 26 2020
07:20:38:WU00:FS02:0x22:       Time: 19:49:16
07:20:38:WU00:FS02:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:20:38:WU00:FS02:0x22:     Branch: core22-0.0.11
07:20:38:WU00:FS02:0x22:   Compiler: Visual C++ 2015
07:20:38:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:20:38:WU00:FS02:0x22:   Platform: win32 10
07:20:38:WU00:FS02:0x22:       Bits: 64
07:20:38:WU00:FS02:0x22:       Mode: Release
07:20:38:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:20:38:WU00:FS02:0x22:             <peastman@stanford.edu>
07:20:38:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 18760 -checkpoint 30
07:20:38:WU00:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
07:20:38:WU00:FS02:0x22:             0 -gpu 0
07:20:38:WU00:FS02:0x22:************************************ libFAH ************************************
07:20:38:WU00:FS02:0x22:       Time: 19:47:12
07:20:38:WU00:FS02:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:20:38:WU00:FS02:0x22:     Branch: HEAD
07:20:38:WU00:FS02:0x22:************************************ CBang *************************************
07:20:38:WU00:FS02:0x22:       Time: 19:46:11
07:20:38:WU00:FS02:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:20:38:WU00:FS02:0x22:     Branch: master
07:20:38:WU00:FS02:0x22:************************************ System ************************************
07:20:38:WU00:FS02:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:20:38:WU00:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:20:38:WU00:FS02:0x22:       CPUs: 16
07:20:38:WU00:FS02:0x22:     Memory: 31.92GiB
07:20:38:WU00:FS02:0x22:Free Memory: 17.69GiB
07:20:38:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
07:20:38:WU00:FS02:0x22: OS Version: 6.2
07:20:38:WU00:FS02:0x22:Has Battery: false
07:20:38:WU00:FS02:0x22: On Battery: false
07:20:38:WU00:FS02:0x22: UTC Offset: -5
07:20:38:WU00:FS02:0x22:        PID: 25336
07:20:38:WU00:FS02:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:20:38:WU00:FS02:0x22:********************************************************************************
07:20:38:WU00:FS02:0x22:Project: 13420 (Run 6196, Clone 31, Gen 1)
07:20:38:WU00:FS02:0x22:Unit: 0x0000000412bc7d9a5f224978a30cc9a4
07:20:38:WU00:FS02:0x22:Digital signatures verified
07:20:38:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:20:38:WU00:FS02:0x22:Version 0.0.11
07:20:38:WU00:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:20:38:WU00:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:20:38:WU00:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:20:38:WU00:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:20:42:FS01:Paused
07:20:42:FS02:Paused
07:20:43:FS01:Shutting core down
07:20:43:FS02:Shutting core down
07:20:43:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 17644
07:20:43:WU01:FS01:0x22:Exiting, please wait. . .
07:20:43:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 25336
07:20:43:WU00:FS02:0x22:Exiting, please wait. . .
07:20:50:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
07:20:50:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
07:20:50:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
07:21:02:FS01:Unpaused
07:21:02:FS01:Finishing
07:21:02:FS02:Unpaused
07:21:02:FS02:Finishing
07:21:02:WU00:FS02:Starting
07:21:02:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
07:21:02:WU00:FS02:Started FahCore on PID 6336
07:21:02:WU00:FS02:Core PID:19396
07:21:02:WU00:FS02:FahCore 0x22 started
07:21:02:WU00:FS02:0x22:*********************** Log Started 2020-08-14T07:21:02Z ***********************
07:21:03:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:21:03:WU00:FS02:0x22:       Core: Core22
07:21:03:WU00:FS02:0x22:       Type: 0x22
07:21:03:WU00:FS02:0x22:    Version: 0.0.11
07:21:03:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:21:03:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
07:21:03:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
07:21:03:WU00:FS02:0x22:       Date: Jun 26 2020
07:21:03:WU00:FS02:0x22:       Time: 19:49:16
07:21:03:WU00:FS02:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:21:03:WU00:FS02:0x22:     Branch: core22-0.0.11
07:21:03:WU00:FS02:0x22:   Compiler: Visual C++ 2015
07:21:03:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:21:03:WU00:FS02:0x22:   Platform: win32 10
07:21:03:WU00:FS02:0x22:       Bits: 64
07:21:03:WU00:FS02:0x22:       Mode: Release
07:21:03:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:21:03:WU00:FS02:0x22:             <peastman@stanford.edu>
07:21:03:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6336 -checkpoint 30
07:21:03:WU00:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
07:21:03:WU00:FS02:0x22:             0 -gpu 0
07:21:03:WU00:FS02:0x22:************************************ libFAH ************************************
07:21:03:WU00:FS02:0x22:       Time: 19:47:12
07:21:03:WU00:FS02:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:21:03:WU00:FS02:0x22:     Branch: HEAD
07:21:03:WU00:FS02:0x22:************************************ CBang *************************************
07:21:03:WU00:FS02:0x22:       Time: 19:46:11
07:21:03:WU00:FS02:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:21:03:WU00:FS02:0x22:     Branch: master
07:21:03:WU00:FS02:0x22:************************************ System ************************************
07:21:03:WU00:FS02:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:21:03:WU00:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:21:03:WU00:FS02:0x22:       CPUs: 16
07:21:03:WU00:FS02:0x22:     Memory: 31.92GiB
07:21:03:WU00:FS02:0x22:Free Memory: 17.57GiB
07:21:03:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
07:21:03:WU00:FS02:0x22: OS Version: 6.2
07:21:03:WU00:FS02:0x22:Has Battery: false
07:21:03:WU00:FS02:0x22: On Battery: false
07:21:03:WU00:FS02:0x22: UTC Offset: -5
07:21:03:WU00:FS02:0x22:        PID: 19396
07:21:03:WU00:FS02:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:21:03:WU00:FS02:0x22:********************************************************************************
07:21:03:WU00:FS02:0x22:Project: 13420 (Run 6196, Clone 31, Gen 1)
07:21:03:WU00:FS02:0x22:Unit: 0x0000000412bc7d9a5f224978a30cc9a4
07:21:03:WU00:FS02:0x22:Digital signatures verified
07:21:03:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:21:03:WU00:FS02:0x22:Version 0.0.11
07:21:03:WU00:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:21:03:WU00:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:21:03:WU00:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:21:03:WU00:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:21:14:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
07:21:15:FS01:Paused
07:21:15:FS02:Paused
07:21:15:FS01:Shutting core down
07:21:15:FS02:Shutting core down
07:21:16:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 19396
07:21:16:WU00:FS02:0x22:Exiting, please wait. . .
07:21:16:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
07:21:16:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
07:21:40:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:21:53:FS01:Unpaused
07:21:53:FS02:Unpaused
07:21:53:WU01:FS01:Starting
07:21:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:21:53:WU01:FS01:Started FahCore on PID 14868
07:21:53:WU01:FS01:Core PID:20544
07:21:53:WU01:FS01:FahCore 0x22 started
07:21:54:WU01:FS01:0x22:*********************** Log Started 2020-08-14T07:21:53Z ***********************
07:21:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:21:54:WU01:FS01:0x22:       Core: Core22
07:21:54:WU01:FS01:0x22:       Type: 0x22
07:21:54:WU01:FS01:0x22:    Version: 0.0.11
07:21:54:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:21:54:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:21:54:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:21:54:WU01:FS01:0x22:       Date: Jun 26 2020
07:21:54:WU01:FS01:0x22:       Time: 19:49:16
07:21:54:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:21:54:WU01:FS01:0x22:     Branch: core22-0.0.11
07:21:54:WU01:FS01:0x22:   Compiler: Visual C++ 2015
07:21:54:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:21:54:WU01:FS01:0x22:   Platform: win32 10
07:21:54:WU01:FS01:0x22:       Bits: 64
07:21:54:WU01:FS01:0x22:       Mode: Release
07:21:54:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:21:54:WU01:FS01:0x22:             <peastman@stanford.edu>
07:21:54:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14868 -checkpoint 30
07:21:54:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:21:54:WU01:FS01:0x22:************************************ libFAH ************************************
07:21:54:WU01:FS01:0x22:       Time: 19:47:12
07:21:54:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:21:54:WU01:FS01:0x22:     Branch: HEAD
07:21:54:WU01:FS01:0x22:************************************ CBang *************************************
07:21:54:WU01:FS01:0x22:       Time: 19:46:11
07:21:54:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:21:54:WU01:FS01:0x22:     Branch: master
07:21:54:WU01:FS01:0x22:************************************ System ************************************
07:21:54:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:21:54:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:21:54:WU01:FS01:0x22:       CPUs: 16
07:21:54:WU01:FS01:0x22:     Memory: 31.92GiB
07:21:54:WU01:FS01:0x22:Free Memory: 17.68GiB
07:21:54:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:21:54:WU01:FS01:0x22: OS Version: 6.2
07:21:54:WU01:FS01:0x22:Has Battery: false
07:21:54:WU01:FS01:0x22: On Battery: false
07:21:54:WU01:FS01:0x22: UTC Offset: -5
07:21:54:WU01:FS01:0x22:        PID: 20544
07:21:54:WU01:FS01:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:21:54:WU01:FS01:0x22:********************************************************************************
07:21:54:WU01:FS01:0x22:Project: 13420 (Run 7111, Clone 41, Gen 2)
07:21:54:WU01:FS01:0x22:Unit: 0x0000000612bc7d9a5f2249a9bebe8a88
07:21:54:WU01:FS01:0x22:Digital signatures verified
07:21:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:21:54:WU01:FS01:0x22:Version 0.0.11
07:21:54:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:21:54:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:21:54:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:21:54:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:22:02:WU00:FS02:Starting
07:22:02:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
07:22:02:WU00:FS02:Started FahCore on PID 15268
07:22:02:WU00:FS02:Core PID:25176
07:22:02:WU00:FS02:FahCore 0x22 started
07:22:03:WU00:FS02:0x22:*********************** Log Started 2020-08-14T07:22:02Z ***********************
07:22:03:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:22:03:WU00:FS02:0x22:       Core: Core22
07:22:03:WU00:FS02:0x22:       Type: 0x22
07:22:03:WU00:FS02:0x22:    Version: 0.0.11
07:22:03:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:22:03:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
07:22:03:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
07:22:03:WU00:FS02:0x22:       Date: Jun 26 2020
07:22:03:WU00:FS02:0x22:       Time: 19:49:16
07:22:03:WU00:FS02:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:22:03:WU00:FS02:0x22:     Branch: core22-0.0.11
07:22:03:WU00:FS02:0x22:   Compiler: Visual C++ 2015
07:22:03:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:22:03:WU00:FS02:0x22:   Platform: win32 10
07:22:03:WU00:FS02:0x22:       Bits: 64
07:22:03:WU00:FS02:0x22:       Mode: Release
07:22:03:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:22:03:WU00:FS02:0x22:             <peastman@stanford.edu>
07:22:03:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15268 -checkpoint 30
07:22:03:WU00:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
07:22:03:WU00:FS02:0x22:             0 -gpu 0
07:22:03:WU00:FS02:0x22:************************************ libFAH ************************************
07:22:03:WU00:FS02:0x22:       Time: 19:47:12
07:22:03:WU00:FS02:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:22:03:WU00:FS02:0x22:     Branch: HEAD
07:22:03:WU00:FS02:0x22:************************************ CBang *************************************
07:22:03:WU00:FS02:0x22:       Time: 19:46:11
07:22:03:WU00:FS02:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:22:03:WU00:FS02:0x22:     Branch: master
07:22:03:WU00:FS02:0x22:************************************ System ************************************
07:22:03:WU00:FS02:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:22:03:WU00:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:22:03:WU00:FS02:0x22:       CPUs: 16
07:22:03:WU00:FS02:0x22:     Memory: 31.92GiB
07:22:03:WU00:FS02:0x22:Free Memory: 17.59GiB
07:22:03:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
07:22:03:WU00:FS02:0x22: OS Version: 6.2
07:22:03:WU00:FS02:0x22:Has Battery: false
07:22:03:WU00:FS02:0x22: On Battery: false
07:22:03:WU00:FS02:0x22: UTC Offset: -5
07:22:03:WU00:FS02:0x22:        PID: 25176
07:22:03:WU00:FS02:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:22:03:WU00:FS02:0x22:********************************************************************************
07:22:03:WU00:FS02:0x22:Project: 13420 (Run 6196, Clone 31, Gen 1)
07:22:03:WU00:FS02:0x22:Unit: 0x0000000412bc7d9a5f224978a30cc9a4
07:22:03:WU00:FS02:0x22:Digital signatures verified
07:22:03:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:22:03:WU00:FS02:0x22:Version 0.0.11
07:22:03:WU00:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:22:03:WU00:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:22:03:WU00:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:22:03:WU00:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:22:14:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
07:22:22:Removing old file 'configs/config-20200813-050503.xml'
07:22:22:Saving configuration to config.xml
07:22:22:<config>
07:22:22:  <!-- Folding Core -->
07:22:22:  <checkpoint v='30'/>
07:22:22:  <core-priority v='low'/>
07:22:22:
07:22:22:  <!-- Folding Slot Configuration -->
07:22:22:  <cause v='COVID_19'/>
07:22:22:
07:22:22:  <!-- Network -->
07:22:22:  <proxy v=':8080'/>
07:22:22:
07:22:22:  <!-- Slot Control -->
07:22:22:  <power v='full'/>
07:22:22:
07:22:22:  <!-- User Information -->
07:22:22:
07:22:22:  <!-- Folding Slots -->
07:22:22:  <slot id='1' type='GPU'>
07:22:22:    <gpu-index v='0'/>
07:22:22:  </slot>
07:22:22:  <slot id='2' type='GPU'/>
07:22:22:</config>
07:22:56:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
07:24:09:FS01:Paused
07:24:09:FS02:Paused
07:24:10:FS01:Shutting core down
07:24:10:FS02:Shutting core down
07:24:10:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 20544
07:24:10:WU01:FS01:0x22:Exiting, please wait. . .
07:24:10:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 25176
07:24:10:WU00:FS02:0x22:Exiting, please wait. . .
07:24:10:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
07:24:10:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:24:10:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
07:24:24:Removing old file 'configs/config-20200813-060214.xml'
07:24:24:Saving configuration to config.xml
07:24:24:<config>
07:24:24:  <!-- Folding Core -->
07:24:24:  <checkpoint v='30'/>
07:24:24:  <core-priority v='low'/>
07:24:24:
07:24:24:  <!-- Folding Slot Configuration -->
07:24:24:  <cause v='COVID_19'/>
07:24:24:
07:24:24:  <!-- Network -->
07:24:24:  <proxy v=':8080'/>
07:24:24:
07:24:24:  <!-- Slot Control -->
07:24:24:  <power v='full'/>
07:24:24:
07:24:24:  <!-- User Information -->
07:24:24:
07:24:24:  <!-- Folding Slots -->
07:24:24:  <slot id='1' type='GPU'>
07:24:24:    <gpu-index v='0'/>
07:24:24:    <paused v='true'/>
07:24:24:  </slot>
07:24:24:  <slot id='2' type='GPU'>
07:24:24:  </slot>
07:24:24:</config>
07:28:13:FS01:Unpaused
07:28:13:FS02:Unpaused
07:28:14:WU01:FS01:Starting
07:28:14:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:28:14:WU01:FS01:Started FahCore on PID 15808
07:28:14:WU01:FS01:Core PID:19676
07:28:14:WU01:FS01:FahCore 0x22 started
07:28:14:WU00:FS02:Starting
07:28:14:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
07:28:14:WU00:FS02:Started FahCore on PID 6712
07:28:14:WU00:FS02:Core PID:24376
07:28:14:WU00:FS02:FahCore 0x22 started
07:28:14:WU01:FS01:0x22:*********************** Log Started 2020-08-14T07:28:14Z ***********************
07:28:14:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:28:14:WU01:FS01:0x22:       Core: Core22
07:28:14:WU01:FS01:0x22:       Type: 0x22
07:28:14:WU01:FS01:0x22:    Version: 0.0.11
07:28:14:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:28:14:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:28:14:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:28:14:WU01:FS01:0x22:       Date: Jun 26 2020
07:28:14:WU01:FS01:0x22:       Time: 19:49:16
07:28:14:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:28:14:WU01:FS01:0x22:     Branch: core22-0.0.11
07:28:14:WU01:FS01:0x22:   Compiler: Visual C++ 2015
07:28:14:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:28:14:WU01:FS01:0x22:   Platform: win32 10
07:28:14:WU01:FS01:0x22:       Bits: 64
07:28:14:WU01:FS01:0x22:       Mode: Release
07:28:14:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:28:14:WU01:FS01:0x22:             <peastman@stanford.edu>
07:28:14:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15808 -checkpoint 30
07:28:14:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:28:14:WU01:FS01:0x22:************************************ libFAH ************************************
07:28:14:WU01:FS01:0x22:       Time: 19:47:12
07:28:14:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:28:14:WU01:FS01:0x22:     Branch: HEAD
07:28:14:WU01:FS01:0x22:************************************ CBang *************************************
07:28:14:WU01:FS01:0x22:       Time: 19:46:11
07:28:14:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:28:14:WU01:FS01:0x22:     Branch: master
07:28:14:WU01:FS01:0x22:************************************ System ************************************
07:28:14:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:28:14:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:28:14:WU01:FS01:0x22:       CPUs: 16
07:28:14:WU01:FS01:0x22:     Memory: 31.92GiB
07:28:14:WU01:FS01:0x22:Free Memory: 17.53GiB
07:28:14:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:28:14:WU01:FS01:0x22: OS Version: 6.2
07:28:14:WU01:FS01:0x22:Has Battery: false
07:28:14:WU01:FS01:0x22: On Battery: false
07:28:14:WU01:FS01:0x22: UTC Offset: -5
07:28:14:WU01:FS01:0x22:        PID: 19676
07:28:14:WU01:FS01:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:28:14:WU01:FS01:0x22:********************************************************************************
07:28:14:WU01:FS01:0x22:Project: 13420 (Run 7111, Clone 41, Gen 2)
07:28:14:WU01:FS01:0x22:Unit: 0x0000000612bc7d9a5f2249a9bebe8a88
07:28:14:WU01:FS01:0x22:Digital signatures verified
07:28:14:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:28:14:WU01:FS01:0x22:Version 0.0.11
07:28:14:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:28:14:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:28:14:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:28:14:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:28:14:WU00:FS02:0x22:*********************** Log Started 2020-08-14T07:28:14Z ***********************
07:28:14:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:28:14:WU00:FS02:0x22:       Core: Core22
07:28:14:WU00:FS02:0x22:       Type: 0x22
07:28:14:WU00:FS02:0x22:    Version: 0.0.11
07:28:14:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:28:14:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
07:28:14:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
07:28:14:WU00:FS02:0x22:       Date: Jun 26 2020
07:28:14:WU00:FS02:0x22:       Time: 19:49:16
07:28:14:WU00:FS02:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
07:28:14:WU00:FS02:0x22:     Branch: core22-0.0.11
07:28:14:WU00:FS02:0x22:   Compiler: Visual C++ 2015
07:28:14:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:28:14:WU00:FS02:0x22:   Platform: win32 10
07:28:14:WU00:FS02:0x22:       Bits: 64
07:28:14:WU00:FS02:0x22:       Mode: Release
07:28:14:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:28:14:WU00:FS02:0x22:             <peastman@stanford.edu>
07:28:14:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6712 -checkpoint 30
07:28:14:WU00:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
07:28:14:WU00:FS02:0x22:             0 -gpu 0
07:28:14:WU00:FS02:0x22:************************************ libFAH ************************************
07:28:14:WU00:FS02:0x22:       Time: 19:47:12
07:28:14:WU00:FS02:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:28:14:WU00:FS02:0x22:     Branch: HEAD
07:28:14:WU00:FS02:0x22:************************************ CBang *************************************
07:28:14:WU00:FS02:0x22:       Time: 19:46:11
07:28:14:WU00:FS02:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
07:28:14:WU00:FS02:0x22:     Branch: master
07:28:14:WU00:FS02:0x22:************************************ System ************************************
07:28:14:WU00:FS02:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
07:28:14:WU00:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:28:14:WU00:FS02:0x22:       CPUs: 16
07:28:14:WU00:FS02:0x22:     Memory: 31.92GiB
07:28:14:WU00:FS02:0x22:Free Memory: 17.53GiB
07:28:14:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
07:28:14:WU00:FS02:0x22: OS Version: 6.2
07:28:14:WU00:FS02:0x22:Has Battery: false
07:28:14:WU00:FS02:0x22: On Battery: false
07:28:14:WU00:FS02:0x22: UTC Offset: -5
07:28:14:WU00:FS02:0x22:        PID: 24376
07:28:14:WU00:FS02:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
07:28:14:WU00:FS02:0x22:********************************************************************************
07:28:14:WU00:FS02:0x22:Project: 13420 (Run 6196, Clone 31, Gen 1)
07:28:14:WU00:FS02:0x22:Unit: 0x0000000412bc7d9a5f224978a30cc9a4
07:28:14:WU00:FS02:0x22:Digital signatures verified
07:28:14:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:28:14:WU00:FS02:0x22:Version 0.0.11
07:28:14:WU00:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:28:14:WU00:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:28:14:WU00:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
07:28:14:WU00:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
07:28:26:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
07:28:28:Removing old file 'configs/config-20200813-060517.xml'
07:28:28:Saving configuration to config.xml
07:28:28:<config>
07:28:28:  <!-- Folding Core -->
07:28:28:  <checkpoint v='30'/>
07:28:28:  <core-priority v='low'/>
07:28:28:
07:28:28:  <!-- Folding Slot Configuration -->
07:28:28:  <cause v='COVID_19'/>
07:28:28:
07:28:28:  <!-- Network -->
07:28:28:  <proxy v=':8080'/>
07:28:28:
07:28:28:  <!-- Slot Control -->
07:28:28:  <power v='full'/>
07:28:28:
07:28:28:  <!-- User Information -->
07:28:28:
07:28:28:  <!-- Folding Slots -->
07:28:28:  <slot id='1' type='GPU'>
07:28:28:    <gpu-index v='0'/>
07:28:28:  </slot>
07:28:28:  <slot id='2' type='GPU'/>
07:28:28:</config>
07:29:16:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
07:30:22:WU00:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
07:31:07:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
07:32:18:WU00:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
07:32:56:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
07:34:14:WU00:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
07:34:45:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
07:36:11:WU00:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
07:36:34:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
07:38:08:WU00:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
07:38:25:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
07:40:06:WU00:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
07:40:15:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
07:42:03:WU00:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
07:42:04:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
07:43:53:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
07:44:00:WU00:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
07:45:43:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
07:45:56:WU00:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
07:47:30:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
07:47:53:WU00:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
07:49:19:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
07:49:50:WU00:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
07:51:09:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
07:51:47:WU00:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
07:52:59:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
07:53:44:WU00:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
07:54:48:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
07:55:41:WU00:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
07:56:38:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
07:57:38:WU00:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
07:58:28:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
07:59:36:WU00:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
08:00:17:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
08:01:32:WU00:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
08:02:07:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
08:03:29:WU00:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
08:03:56:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
08:05:26:WU00:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
08:05:44:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
08:07:23:WU00:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
08:07:34:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
08:09:21:WU00:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
08:09:22:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
08:11:10:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
08:11:17:WU00:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
08:12:59:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
08:13:14:WU00:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
08:14:47:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
08:15:10:WU00:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
08:16:36:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
08:17:07:WU00:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
08:18:25:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
08:19:09:WU00:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
08:20:13:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
08:21:11:WU00:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
08:22:05:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
08:23:12:WU00:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
08:23:54:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
08:25:13:WU00:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
08:25:43:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
08:27:15:WU00:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
08:27:32:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
08:29:16:WU00:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
08:29:21:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
08:31:09:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
08:31:17:WU00:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
08:32:57:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
08:33:18:WU00:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
08:34:45:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
08:35:20:WU00:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
08:36:32:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
08:37:20:WU00:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
08:38:20:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
08:39:21:WU00:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
08:40:07:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
08:41:22:WU00:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
08:41:54:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
08:43:23:WU00:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
08:43:42:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
08:45:23:WU00:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
08:45:30:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
08:47:17:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
08:47:24:WU00:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
08:49:04:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
08:49:26:WU00:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
08:50:52:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
08:51:27:WU00:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
08:52:39:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
08:53:28:WU00:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
08:54:26:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
08:55:29:WU00:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
08:56:13:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
08:57:30:WU00:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
08:58:01:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
08:59:31:WU00:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
08:59:48:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
09:01:32:WU00:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
09:01:35:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
09:03:22:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
09:03:33:WU00:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
09:05:09:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
09:05:34:WU00:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
09:06:56:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
09:07:35:WU00:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
09:08:43:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
09:09:33:WU00:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
09:10:30:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
09:11:29:WU00:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
09:12:17:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
09:13:26:WU00:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
09:14:04:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
09:15:22:WU00:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
09:15:51:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
09:17:19:WU00:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
09:17:38:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
09:19:16:WU00:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
09:19:27:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
09:21:12:WU00:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
09:21:15:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
09:23:03:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
09:23:09:WU00:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
09:24:50:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
09:25:06:WU00:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
09:26:38:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
09:27:02:WU00:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
09:28:27:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
09:28:59:WU00:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
09:30:15:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
09:30:56:WU00:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
09:32:03:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
09:32:53:WU00:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
09:33:51:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
09:34:49:WU00:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
09:35:38:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
09:36:46:WU00:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
09:37:27:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
09:38:43:WU00:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
09:39:15:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
09:40:40:WU00:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
09:41:03:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
09:42:36:WU00:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
09:42:51:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
09:44:33:WU00:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
09:44:39:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
09:46:28:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
09:46:29:WU00:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
09:48:17:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
09:48:27:WU00:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
09:50:05:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
09:50:23:WU00:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
09:51:53:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
09:52:20:WU00:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
09:53:41:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
09:54:17:WU00:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
09:55:30:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
09:56:13:WU00:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
09:57:18:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
09:58:15:WU00:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
09:59:06:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
10:00:15:WU00:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
10:00:54:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
10:00:55:WU02:FS01:Connecting to assign1.foldingathome.org:80
10:00:55:WU02:FS01:Assigned to work server 18.188.125.154
10:00:55:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 18.188.125.154
10:00:55:WU02:FS01:Connecting to 18.188.125.154:8080
10:00:55:WU02:FS01:Downloading 7.04MiB
10:00:56:WU02:FS01:Download complete
10:00:56:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13420 run:4984 clone:20 gen:1 core:0x22 unit:0x0000000412bc7d9a5f22494ad477b0a0
10:02:17:WU00:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
10:02:42:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
10:02:42:WU01:FS01:0x22:Average performance: 159.704 ns/day
10:02:46:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
10:02:46:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
10:02:46:WU01:FS01:0x22:Saving result file globals.csv
10:02:46:WU01:FS01:0x22:Saving result file positions.xtc
10:02:46:WU01:FS01:0x22:Saving result file science.log
10:02:46:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:02:47:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:02:47:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13420 run:7111 clone:41 gen:2 core:0x22 unit:0x0000000612bc7d9a5f2249a9bebe8a88
10:02:47:WU01:FS01:Uploading 5.72MiB to 18.188.125.154
10:02:47:WU01:FS01:Connecting to 18.188.125.154:8080
10:02:47:WU02:FS01:Starting
10:02:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8488 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:02:47:WU02:FS01:Started FahCore on PID 22952
10:02:47:WU02:FS01:Core PID:14040
10:02:47:WU02:FS01:FahCore 0x22 started
10:02:47:WU02:FS01:0x22:*********************** Log Started 2020-08-14T10:02:47Z ***********************
10:02:47:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:02:47:WU02:FS01:0x22:       Core: Core22
10:02:47:WU02:FS01:0x22:       Type: 0x22
10:02:47:WU02:FS01:0x22:    Version: 0.0.11
10:02:47:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:02:47:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
10:02:47:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
10:02:47:WU02:FS01:0x22:       Date: Jun 26 2020
10:02:47:WU02:FS01:0x22:       Time: 19:49:16
10:02:47:WU02:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
10:02:47:WU02:FS01:0x22:     Branch: core22-0.0.11
10:02:47:WU02:FS01:0x22:   Compiler: Visual C++ 2015
10:02:47:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
10:02:47:WU02:FS01:0x22:   Platform: win32 10
10:02:47:WU02:FS01:0x22:       Bits: 64
10:02:47:WU02:FS01:0x22:       Mode: Release
10:02:47:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:02:47:WU02:FS01:0x22:             <peastman@stanford.edu>
10:02:47:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 22952 -checkpoint 30
10:02:47:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:02:47:WU02:FS01:0x22:************************************ libFAH ************************************
10:02:47:WU02:FS01:0x22:       Time: 19:47:12
10:02:47:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
10:02:47:WU02:FS01:0x22:     Branch: HEAD
10:02:47:WU02:FS01:0x22:************************************ CBang *************************************
10:02:47:WU02:FS01:0x22:       Time: 19:46:11
10:02:47:WU02:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
10:02:47:WU02:FS01:0x22:     Branch: master
10:02:47:WU02:FS01:0x22:************************************ System ************************************
10:02:47:WU02:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
10:02:47:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
10:02:47:WU02:FS01:0x22:       CPUs: 16
10:02:47:WU02:FS01:0x22:     Memory: 31.92GiB
10:02:47:WU02:FS01:0x22:Free Memory: 18.22GiB
10:02:47:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
10:02:47:WU02:FS01:0x22: OS Version: 6.2
10:02:47:WU02:FS01:0x22:Has Battery: false
10:02:47:WU02:FS01:0x22: On Battery: false
10:02:47:WU02:FS01:0x22: UTC Offset: -5
10:02:47:WU02:FS01:0x22:        PID: 14040
10:02:47:WU02:FS01:0x22:        CWD: C:\Users\1\AppData\Roaming\FAHClient\work
10:02:47:WU02:FS01:0x22:********************************************************************************
10:02:47:WU02:FS01:0x22:Project: 13420 (Run 4984, Clone 20, Gen 1)
10:02:47:WU02:FS01:0x22:Unit: 0x0000000412bc7d9a5f22494ad477b0a0
10:02:47:WU02:FS01:0x22:Reading tar file core.xml
10:02:47:WU02:FS01:0x22:Reading tar file integrator.xml
10:02:47:WU02:FS01:0x22:Reading tar file state.xml.bz2
10:02:47:WU02:FS01:0x22:Reading tar file system.xml.bz2
10:02:47:WU02:FS01:0x22:Digital signatures verified
10:02:47:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:02:47:WU02:FS01:0x22:Version 0.0.11
10:02:47:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
10:02:47:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
10:02:47:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
10:02:47:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
10:02:50:WU01:FS01:Upload complete
10:02:50:WU01:FS01:Server responded WORK_ACK (400)
10:02:50:WU01:FS01:Final credit estimate, 198525.00 points
10:02:50:WU01:FS01:Cleaning up
10:03:49:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
10:04:18:WU00:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
10:05:39:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
10:06:19:WU00:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
10:07:27:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
Re: 5700xt and 2060 KO Ultra <400k PPD
We need to see the first 200 lines of the log showing your client configuration : How to provide enough info to get helpful support.
Did you request a passkey and add it to you client : https://foldingathome.org/support/faq/points/passkey/ ?
catwell
Post by catwell »
Isn't that what I already put in the log section?
And I do have a passkey. I believe.
Post by Neil-B »
nope ... if you copied that from the log pane in FahControl then you need to refresh first ... should start looking something like this ...
*********************** Log Started 2020-08-12T18:52:11Z ***********************
18:52:11:Trying to access database...
18:52:11:Successfully acquired database lock
18:52:11:Downloading GPUs.txt from assign1.foldingathome.org:80
18:52:11:Connecting to assign1.foldingathome.org:80
18:52:12:Read GPUs.txt
18:52:12:Enabled folding slot 00: PAUSED cpu:2 (by user)
18:52:14:Enabled folding slot 01: PAUSED gpu:0:GM107 [GeForce GTX 750 Ti] 1389 (by user)
18:52:14:****************************** FAHClient ******************************
and you need to copy down to where it starts the first WU in the log.
catwell
Post by catwell »
Post by foldy »
Config looks good, maybe you just need to keep it running some time until the PPD bonus points kick in. And you can fold on CPU too if you like
Yes, that's the part we're looking for.
FAH correctly configures two GPUs. They each download a WU
You pause both of them and then resume folding.
Adding/Removing the CPU slot makes very little difference, either way.
Maybe you're expecting immediate results. The best suggestion I can offer is stop interrupting the client and just let it run. PPD estimates take time to stabilize. Your passkey doesn't alter the PPD until you've finished 10 WUs successfully but you do have to add it to your configuration with the "identity" tab of FAHControl.
catwell
Post by catwell »
Okay, thanks for the input.
I'll keep my eye on it then.
