FahClient v7.6.14 beta now supports ARM Linux / Raspberry Pi
https://foldingathome.org/beta/
Future steps: Android mobile devices
https://neocortix.com/coronablog
Mod edit : client 7.6.14 is broken, do not use it. Please wait for official announcements.
Re: FahClient v7.6.14 beta now supports ARM Linux / Raspberr
Is this client the one that there was a message from Anton yesterday evening on discord not to use due to bugs?
I am not sure if there may be issues with with the current arm client or with something neocortix server side but for some their user there is an issue that they are aware of and are working on - not sure if this will impact others as I have no clue how the the arm client works and where the issue lies with the neocortix user.
The do not use message was v *.13 and this is v*.14 that contains a proposed fix to the bugs he was talking about. Apparently it is also bug ridden.
Dr. Merkwürdigliebe
- Hardware configuration: Xeon 1230v3 + Geforce RTX 2080
I installed the new beta version on my computer (Ubuntu 20.04) and was subsequently unable to fold because there was no GPU slot and neither was I able to configure one.
I click Save and my configuration is being discarded.
*********************** Log Started 2020-08-14T18:59:25Z ***********************
18:59:25:******************************* libFAH ********************************
18:59:25: Date: Aug 6 2020
18:59:25: Time: 18:59:35
18:59:25: Revision: c8afa4a61c11532766fdd22f839ce8ab12abd88e
18:59:25: Branch: master
18:59:25: Compiler: GNU 8.3.0
18:59:25: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
18:59:25: -O3 -funroll-loops -fno-pie
18:59:25: Platform: linux2 4.19.0-5-amd64
18:59:25: Bits: 64
18:59:25: Mode: Release
18:59:25:****************************** FAHClient ******************************
18:59:25: Version: 7.6.14
18:59:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:25: Copyright: 2020 foldingathome.org
18:59:25: Homepage: https://foldingathome.org/
18:59:25: Time: 19:30:18
18:59:25: Revision: 1f756e6055fbb2d146db661bf8585363d29011ee
18:59:25: Bits: 64
18:59:25: Args: --child /etc/fahclient/config.xml --run-as fahclient
18:59:25: --pid-file=/var/run/fahclient.pid --daemon
18:59:25: Config: /etc/fahclient/config.xml
18:59:25:******************************** CBang ********************************
18:59:25: Date: Aug 9 2020
18:59:25: Time: 20:16:33
18:59:25: Revision: eadd6f4368f7828f0e0a8433795546f2b1642c88
18:59:25: -O3 -funroll-loops -fno-pie -fPIC
18:59:25: Bits: 64
18:59:25:******************************* System ********************************
18:59:25: CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
18:59:25: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:59:25: CPUs: 8
18:59:25: Memory: 15.56GiB
18:59:25: Free Memory: 3.01GiB
18:59:25: Threads: POSIX_THREADS
18:59:25: OS Version: 5.7
18:59:25: Has Battery: false
18:59:25: On Battery: false
18:59:25: UTC Offset: 2
18:59:25: PID: 41409
18:59:25: CWD: /var/lib/fahclient
18:59:25: OS: Linux 5.7.13-050713-generic x86_64
18:59:25: OS Arch: AMD64
18:59:25: GPUs: 1
18:59:25: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080 Rev. A]
18:59:25: 10068
18:59:25: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
18:59:25:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:450.57
18:59:25:***********************************************************************
18:59:25:<config>
18:59:25: <!-- Client Control -->
18:59:25: <fold-anon v='true'/>
18:59:25:
18:59:25: <!-- Folding Slot Configuration -->
18:59:25: <gpu v='false'/>
18:59:25:
18:59:25: <!-- Slot Control -->
18:59:25: <power v='full'/>
18:59:25:
18:59:25: <!-- User Information -->
18:59:25: <passkey v='*****'/>
18:59:25: <team v='38412'/>
18:59:25: <user v='Blarg'/>
18:59:25:
18:59:25: <!-- Folding Slots -->
18:59:25:</config>
18:59:25:Trying to access database...
18:59:25:Successfully acquired database lock
18:59:25:FS00:Set client configured
18:59:25:FS00:Initialized folding slot 00: cpu:8 - READY
18:59:25:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:59:26:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:59:27:WU00:FS00:Assigned to work server 155.247.164.213
18:59:27:WU00:FS00:Requesting new work unit for slot 00: cpu:8 - READY from 155.247.164.213
18:59:27:WU00:FS00:Connecting to 155.247.164.213:8080
18:59:27:WU00:FS00:Downloading 2.82MiB
18:59:29:WU00:FS00:Download complete
18:59:29:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14823 run:1226 clone:1 gen:144 core:0xa7 unit:0x000000ab9bf7a4d55ea30bd9c0c84ccb
18:59:29:WU00:FS00:Downloading core from http://cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah
18:59:29:WU00:FS00:Connecting to cores.foldingathome.org:80
18:59:29:WU00:FS00:FahCore a7: Downloading 8.17MiB
18:59:31:WU00:FS00:FahCore a7: Download complete
18:59:31:WU00:FS00:Valid core signature
18:59:31:WU00:FS00:Unpacked 18.52MiB to cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7
18:59:31:WU00:FS00:Starting
18:59:31:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 41409 -checkpoint 15 -np 8
18:59:31:WU00:FS00:Started FahCore on PID 41443
18:59:31:WU00:FS00:Core PID:41447
18:59:31:WU00:FS00:FahCore 0xa7 started
18:59:32:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T18:59:31Z ***********************
18:59:32:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:59:32:WU00:FS00:0xa7: Type: 0xa7
18:59:32:WU00:FS00:0xa7: Core: Gromacs
18:59:32:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 41443 -checkpoint 15 -np
18:59:32:WU00:FS00:0xa7: 8
18:59:32:WU00:FS00:0xa7:************************************ CBang *************************************
18:59:32:WU00:FS00:0xa7: Date: Nov 27 2019
18:59:32:WU00:FS00:0xa7: Time: 11:26:54
18:59:32:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:59:32:WU00:FS00:0xa7: Branch: master
18:59:32:WU00:FS00:0xa7: Compiler: GNU 8.3.0
18:59:32:WU00:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
18:59:32:WU00:FS00:0xa7: -fno-pie -fPIC
18:59:32:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
18:59:32:WU00:FS00:0xa7: Bits: 64
18:59:32:WU00:FS00:0xa7: Mode: Release
18:59:32:WU00:FS00:0xa7:************************************ System ************************************
18:59:32:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
18:59:32:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:59:32:WU00:FS00:0xa7: CPUs: 8
18:59:32:WU00:FS00:0xa7: Memory: 15.56GiB
18:59:32:WU00:FS00:0xa7:Free Memory: 2.97GiB
18:59:32:WU00:FS00:0xa7: Threads: POSIX_THREADS
18:59:32:WU00:FS00:0xa7: OS Version: 5.7
18:59:32:WU00:FS00:0xa7:Has Battery: false
18:59:32:WU00:FS00:0xa7: On Battery: false
18:59:32:WU00:FS00:0xa7: UTC Offset: 2
18:59:32:WU00:FS00:0xa7: PID: 41447
18:59:32:WU00:FS00:0xa7: CWD: /var/lib/fahclient/work
18:59:32:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:59:32:WU00:FS00:0xa7: Version: 0.0.19
18:59:32:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:32:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
18:59:32:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
18:59:32:WU00:FS00:0xa7: Date: Nov 26 2019
18:59:32:WU00:FS00:0xa7: Time: 00:41:42
18:59:32:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:59:32:WU00:FS00:0xa7:************************************ Build *************************************
18:59:32:WU00:FS00:0xa7: SIMD: avx_256
18:59:32:WU00:FS00:0xa7:********************************************************************************
18:59:32:WU00:FS00:0xa7:Project: 14823 (Run 1226, Clone 1, Gen 144)
18:59:32:WU00:FS00:0xa7:Unit: 0x000000ab9bf7a4d55ea30bd9c0c84ccb
18:59:32:WU00:FS00:0xa7:Reading tar file core.xml
18:59:32:WU00:FS00:0xa7:Reading tar file frame144.tpr
18:59:32:WU00:FS00:0xa7:Digital signatures verified
18:59:32:WU00:FS00:0xa7:Calling: mdrun -s frame144.tpr -o frame144.trr -cpt 15 -nt 8
18:59:32:WU00:FS00:0xa7:Steps: first=0 total=250000
18:59:33:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
19:00:26:Saving configuration to /etc/fahclient/config.xml
19:00:26:<config>
19:00:26: <!-- Client Control -->
19:00:26: <fold-anon v='true'/>
19:00:26:
19:00:26: <!-- Folding Slot Configuration -->
19:00:26: <gpu v='false'/>
19:00:26:
19:00:26: <!-- Network -->
19:00:26: <proxy v=':8080'/>
19:00:26:
19:00:26: <!-- Slot Control -->
19:00:26: <power v='full'/>
19:00:26:
19:00:26: <!-- User Information -->
19:00:26: <passkey v='*****'/>
19:00:26: <team v='38412'/>
19:00:26: <user v='Blarg'/>
19:00:26:
19:00:26: <!-- Folding Slots -->
19:00:26: <slot id='0' type='CPU'/>
19:00:26:</config>-
FahClient beta is broken on Windows too. They also pulled this beta again, so nothing to see at https://foldingathome.org/beta/
Please wait for official announcements ... 7.6.14 presented on this page is broken : it messes the slots and it could lead to a client no longer starting.
