AMD GPU running but stops at ETA 4 secs
Quad2000
Post by Quad2000 »
Hello together,
I have 2 folding Rigs:
1: 2 x R9 390
2: GTX 1080 + RX480
Both have sometimes a problem but only at the AMD Cards. The Job is running and at ETA 4secs it stops. No progress.
To solve this I have to delete the GPU Slot and add it again.
Can somebody help me with this?
Thank you very much for your help.
*********************** Log Started 2020-08-07T04:13:05Z ***********************
04:40:12:FS01:Unpaused
04:40:12:WU02:FS01:Starting
04:40:12:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\HJG-RX480\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 6848 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
04:40:12:WU02:FS01:Started FahCore on PID 4968
04:40:12:WU02:FS01:Core PID:5572
04:40:12:WU02:FS01:FahCore 0x22 started
04:40:13:WU02:FS01:0x22:*********************** Log Started 2020-08-07T04:40:12Z ***********************
04:40:13:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:40:13:WU02:FS01:0x22:       Core: Core22
04:40:13:WU02:FS01:0x22:       Type: 0x22
04:40:13:WU02:FS01:0x22:    Version: 0.0.11
04:40:13:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:40:13:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
04:40:13:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
04:40:13:WU02:FS01:0x22:       Date: Jun 26 2020
04:40:13:WU02:FS01:0x22:       Time: 19:49:16
04:40:13:WU02:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
04:40:13:WU02:FS01:0x22:     Branch: core22-0.0.11
04:40:13:WU02:FS01:0x22:   Compiler: Visual C++ 2015
04:40:13:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
04:40:13:WU02:FS01:0x22:   Platform: win32 10
04:40:13:WU02:FS01:0x22:       Bits: 64
04:40:13:WU02:FS01:0x22:       Mode: Release
04:40:13:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:40:13:WU02:FS01:0x22:             <peastman@stanford.edu>
04:40:13:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4968 -checkpoint 30
04:40:13:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
04:40:13:WU02:FS01:0x22:************************************ libFAH ************************************
04:40:13:WU02:FS01:0x22:       Time: 19:47:12
04:40:13:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:40:13:WU02:FS01:0x22:     Branch: HEAD
04:40:13:WU02:FS01:0x22:************************************ CBang *************************************
04:40:13:WU02:FS01:0x22:       Time: 19:46:11
04:40:13:WU02:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
04:40:13:WU02:FS01:0x22:     Branch: master
04:40:13:WU02:FS01:0x22:************************************ System ************************************
04:40:13:WU02:FS01:0x22:        CPU: Intel(R) Celeron(R) CPU G3900 @ 2.80GHz
04:40:13:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
04:40:13:WU02:FS01:0x22:       CPUs: 2
04:40:13:WU02:FS01:0x22:     Memory: 15.96GiB
04:40:13:WU02:FS01:0x22:Free Memory: 12.06GiB
04:40:13:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
04:40:13:WU02:FS01:0x22: OS Version: 6.2
04:40:13:WU02:FS01:0x22:Has Battery: false
04:40:13:WU02:FS01:0x22: On Battery: false
04:40:13:WU02:FS01:0x22: UTC Offset: 2
04:40:13:WU02:FS01:0x22:        PID: 5572
04:40:13:WU02:FS01:0x22:        CWD: C:\Users\HJG-RX480\AppData\Roaming\FAHClient\work
04:40:13:WU02:FS01:0x22:********************************************************************************
04:40:13:WU02:FS01:0x22:Project: 16917 (Run 0, Clone 91, Gen 16)
04:40:13:WU02:FS01:0x22:Unit: 0x000000170002894c5f0e45dec6c48356
04:40:13:WU02:FS01:0x22:Digital signatures verified
04:40:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:40:13:WU02:FS01:0x22:Version 0.0.11
04:40:13:WU02:FS01:0x22:  Checkpoint write interval: 500000 steps (2%) [50 total]
04:40:13:WU02:FS01:0x22:  JSON viewer frame write interval: 250000 steps (1%) [100 total]
04:40:13:WU02:FS01:0x22:  XTC frame write interval: 5000000 steps (20%) [5 total]
04:40:13:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
******************************* Date: 2020-08-07 *******************************
******************************* Date: 2020-08-08 *******************************
Re: AMD GPU running but stops at ETA 4 secs
Post by muziqaz »
Does this happen with all the projects or just 16917? What driver version AMD has? It is possible that driver crashes, thus WU stalls. Does this happen if you are folding on just one card with single fah slot created? Are GPU slots created manually with manual GPU Index/OpenCL Index values added?
FAH Omega tester
Is your AMD oveclocked?
