No server update when fah installed
MrWaffelXD
Post by MrWaffelXD »
For a couple of months I fold.
Everytime I try to update my server (CentOS7) using the yum update command I get errors like
Running transaction check
FEHLER bei Transaktionsprüfung gegenüber Depsolve:
python(abi) = 2.6 is needed by (installed) fahcontrol-7.4.4-1.noarch
** 3 bereits bestehende(s) rpmdb Problem(e) gefunden, »yum check« gibt Folgendes aus:
fahcontrol-7.4.4-1.noarch hat fehlende Abhängigkeiten zu python(abi) = ('0', '2.6', None)
fahviewer-7.4.4-1.x86_64 hat fehlende Abhängigkeiten zu libGLU.so.1()(64bit)
fahviewer-7.4.4-1.x86_64 hat fehlende Abhängigkeiten zu libglut.so.3()(64bit)
Which is saying that I have missing dependencies for a couple of packages.
I tried to exclude them from the update but it wont work corrrectly.
Does somebody know this kind of issues?
Thanks for your help.
Re: No server update when fah installed
Post by Neil-B »
If you search the forums for "python" you should find a few threads where this issue is discussed ... Ubuntu 20 folders have these issues .. there may be instructions/guides in one of those threads - but you may have to work out CentOS variants as I can't recall anyone mentioning that as their OS
You may also run into fewer dependency issues if you use a more recent version of the client software. The version show in your post is 7.4.4, that release is from nearly 6 years ago. The current version is 7.6.13, and there is still a fair bit of knowledge present on the forum for the prior release 7.5.1. If I recall correctly, 7.5.1 uses Python 2.7.
