Selected completed WUs not being counted on donor stats
TuxSam
Post by TuxSam »
Hi. I'm relatively new to folding (just completed 30+ WUs to date).
I noticed past few days that selected completed WUs are not being reflected on my stats, despite the log files claiming successful completion and upload to the Folding server. When it first happened, I thought it was just a glitch, especially since subsequent completed WUs were once again being counted.
However, this happened again to another completed WU, so I'm beginning to wonder if there's something I'm doing at my end that's causing this.
Here are some details regarding the first uncounted WU:
03:38:51:WU00:FS00:0xa7:************************************ Build ***************>
03:38:51:WU00:FS00:0xa7:       SIMD: avx_256
03:38:51:WU00:FS00:0xa7:**********************************************************>
03:38:51:WU00:FS00:0xa7:Project: 16508 (Run 0, Clone 712, Gen 81)
03:38:51:WU00:FS00:0xa7:Unit: 0x000000608f59f36f5eae50a3efd14831
Portion of log file showing completed upload:
09:19:57:WU00:FS00:Upload 24.02%
09:20:03:WU00:FS00:Upload 44.48%
09:20:09:WU00:FS00:Upload 65.83%
09:20:15:WU00:FS00:Upload 83.63%
09:20:21:WU00:FS00:Upload complete
09:20:21:WU00:FS00:Server responded WORK_ACK (400)
09:20:21:WU00:FS00:Final credit estimate, 7530.00 points
09:20:21:WU00:FS00:Cleaning up
Donor details:
03:26:21:  <!-- User Information -->
03:26:21:  <passkey v='*****'/>
03:26:21:  <team v='45032'/>
03:26:21:  <user v='TuxSam'/>
Server details:
09:19:50:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:19:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:19:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:1>
09:19:51:WU00:FS00:Uploading 7.03MiB to 143.89.243.111
09:19:51:WU00:FS00:Connecting to 143.89.243.111:8080
Re: Selected completed WUs not being counted on donor stats
Post by Neil-B »
This happens occasionally when a communications "glitch" happens between WS/CS and stats server ... as long as you see the three lines "WORK-ACK (400)", "Final credit estimate," and ""Cleaning up" the WU return has been successful and at some point the Wu will appear in the stats ... a post such as this one or viewtopic.php?f=18&t=35864 helps alert the team to an issue - but one has to be patient as stats issues are low priority compared to keeping the science infrastructure working and can take days, weeks or even on the very rare occasion months - but in my experience they do always get resolved.
Sometimes a single server will have a glitch. We don't always know about it until somebody reports it.
Generally speaking when you make a report like the one above, we can track down and fix the proble if you report the PRCG numbers of the missing credit's WU and the server to which the WU itself was uploaded alnong with the time/data of the upload. Some of your log clips would be more useful if you included a little more information from before/after the parts you pasted.
Florian_Berlin
Post by Florian_Berlin »
I have also WUs of a new device of mine which don't appear in my stats yet, even though my passkeys and Name and Team number match. Here are the parts that might be interesting for you to find an delay / error. (I just deleted the progress of the WU)
*********************** Log Started 2020-08-14T22:24:26Z ***********************
22:24:26:Trying to access database...
22:24:27:Successfully acquired database lock
22:24:27:Read GPUs.txt
22:24:27:Enabled folding slot 00: READY cpu:4
22:24:27:****************************** FAHClient ******************************
22:24:27:        Version: 7.6.13
22:24:27:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:24:27:      Copyright: 2020 foldingathome.org
22:24:27:       Homepage: https://foldingathome.org/
22:24:27:           Date: Apr 27 2020
22:24:27:           Time: 21:21:01
22:24:27:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
22:24:27:         Branch: master
22:24:27:       Compiler: Visual C++ 2008
22:24:27:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:24:27:       Platform: win32 10
22:24:27:           Bits: 32
22:24:27:           Mode: Release
22:24:27:         Config: C:\Users\super\AppData\Roaming\FAHClient\config.xml
22:24:27:******************************** CBang ********************************
22:24:27:           Date: Apr 24 2020
22:24:27:           Time: 17:07:55
22:24:27:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
22:24:27:           Bits: 32
22:24:27:******************************* System ********************************
22:24:27:            CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:24:27:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:24:27:           CPUs: 4
22:24:27:         Memory: 7.88GiB
22:24:27:    Free Memory: 5.86GiB
22:24:27:        Threads: WINDOWS_THREADS
22:24:27:     OS Version: 6.2
22:24:27:    Has Battery: true
22:24:27:     On Battery: false
22:24:27:     UTC Offset: 2
22:24:27:            PID: 9536
22:24:27:            CWD: C:\Users\super\AppData\Roaming\FAHClient
22:24:27:  Win32 Service: false
22:24:27:             OS: Windows 10 Enterprise
22:24:27:        OS Arch: AMD64
22:24:27:           GPUs: 0
22:24:27:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
22:24:27:                 angegebene Modul wurde nicht gefunden.
22:24:27:
22:24:27:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
22:24:27:******************************* libFAH ********************************
22:24:27:           Date: Apr 15 2020
22:24:27:           Time: 14:53:14
22:24:27:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
22:24:27:           Bits: 32
22:24:27:***********************************************************************
22:24:28:<config>
22:24:28:  <!-- Folding Slot Configuration -->
22:24:28:  <cause v='COVID_19'/>
22:24:28:
22:24:28:  <!-- Slot Control -->
22:24:28:  <power v='FULL'/>
22:24:28:
22:24:28:  <!-- User Information -->
22:24:28:  <passkey v='*****'/>
22:24:28:  <team v='45700'/>
22:24:28:  <user v='Florian_Berlin'/>
22:24:28:
22:24:28:  <!-- Folding Slots -->
22:24:28:  <slot id='0' type='CPU'/>
22:24:28:</config>
22:24:28:WU00:FS00:Starting
22:24:28:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
22:24:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 1
22:24:28:WU00:FS00:Started FahCore on PID 10128
22:24:28:WU00:FS00:Core PID:10160
22:24:28:WU00:FS00:FahCore 0xa7 started
22:24:28:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:24:28Z ***********************
22:24:28:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:24:28:WU00:FS00:0xa7:       Type: 0xa7
22:24:28:WU00:FS00:0xa7:       Core: Gromacs
22:24:28:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10128 -checkpoint 15 -np
22:24:28:WU00:FS00:0xa7:             1
22:24:28:WU00:FS00:0xa7:************************************ CBang *************************************
22:24:28:WU00:FS00:0xa7:       Date: Nov 27 2019
22:24:28:WU00:FS00:0xa7:       Time: 03:40:09
22:24:28:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:24:28:WU00:FS00:0xa7:     Branch: master
22:24:28:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:24:28:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:24:28:WU00:FS00:0xa7:   Platform: win32 10
22:24:28:WU00:FS00:0xa7:       Bits: 64
22:24:28:WU00:FS00:0xa7:       Mode: Release
22:24:28:WU00:FS00:0xa7:************************************ System ************************************
22:24:28:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:24:28:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:24:28:WU00:FS00:0xa7:       CPUs: 4
22:24:28:WU00:FS00:0xa7:     Memory: 7.88GiB
22:24:28:WU00:FS00:0xa7:Free Memory: 5.81GiB
22:24:28:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:24:28:WU00:FS00:0xa7: OS Version: 6.2
22:24:28:WU00:FS00:0xa7:Has Battery: true
22:24:28:WU00:FS00:0xa7: On Battery: false
22:24:28:WU00:FS00:0xa7: UTC Offset: 2
22:24:28:WU00:FS00:0xa7:        PID: 10160
22:24:28:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:24:28:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:24:28:WU00:FS00:0xa7:    Version: 0.0.19
22:24:28:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:24:28:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:24:28:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:24:28:WU00:FS00:0xa7:       Date: Nov 25 2019
22:24:28:WU00:FS00:0xa7:       Time: 17:12:41
22:24:28:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:24:28:WU00:FS00:0xa7:************************************ Build *************************************
22:24:28:WU00:FS00:0xa7:       SIMD: avx_256
22:24:28:WU00:FS00:0xa7:********************************************************************************
22:24:28:WU00:FS00:0xa7:Project: 14379 (Run 1508, Clone 0, Gen 398)
22:24:28:WU00:FS00:0xa7:Unit: 0x000001be455e42075e93306f34cbe813
22:24:28:WU00:FS00:0xa7:Digital signatures verified
22:24:28:WU00:FS00:0xa7:Calling: mdrun -s frame398.tpr -o frame398.trr -cpi state.cpt -cpt 15 -nt 1
22:24:28:WU00:FS00:0xa7:ERROR:Guru Meditation #c1ccd56e649b6951.9ac4db01bd631264 (1332312.2664624) '00/01/frame398.trr'
22:24:30:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:24:30:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:24:30:WU00:FS00:Starting
22:24:30:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
22:24:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 1
22:24:30:WU00:FS00:Started FahCore on PID 9760
22:24:30:WU00:FS00:Core PID:9692
22:24:30:WU00:FS00:FahCore 0xa7 started
22:24:31:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:24:30Z ***********************
22:24:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:24:31:WU00:FS00:0xa7:       Type: 0xa7
22:24:31:WU00:FS00:0xa7:       Core: Gromacs
22:24:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9760 -checkpoint 15 -np 1
22:24:31:WU00:FS00:0xa7:************************************ CBang *************************************
22:24:31:WU00:FS00:0xa7:       Date: Nov 27 2019
22:24:31:WU00:FS00:0xa7:       Time: 03:40:09
22:24:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:24:31:WU00:FS00:0xa7:     Branch: master
22:24:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:24:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:24:31:WU00:FS00:0xa7:   Platform: win32 10
22:24:31:WU00:FS00:0xa7:       Bits: 64
22:24:31:WU00:FS00:0xa7:       Mode: Release
22:24:31:WU00:FS00:0xa7:************************************ System ************************************
22:24:31:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:24:31:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:24:31:WU00:FS00:0xa7:       CPUs: 4
22:24:31:WU00:FS00:0xa7:     Memory: 7.88GiB
22:24:31:WU00:FS00:0xa7:Free Memory: 5.78GiB
22:24:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:24:31:WU00:FS00:0xa7: OS Version: 6.2
22:24:31:WU00:FS00:0xa7:Has Battery: true
22:24:31:WU00:FS00:0xa7: On Battery: false
22:24:31:WU00:FS00:0xa7: UTC Offset: 2
22:24:31:WU00:FS00:0xa7:        PID: 9692
22:24:31:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:24:31:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:24:31:WU00:FS00:0xa7:    Version: 0.0.19
22:24:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:24:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:24:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:24:31:WU00:FS00:0xa7:       Date: Nov 25 2019
22:24:31:WU00:FS00:0xa7:       Time: 17:12:41
22:24:31:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:24:31:WU00:FS00:0xa7:************************************ Build *************************************
22:24:31:WU00:FS00:0xa7:       SIMD: avx_256
22:24:31:WU00:FS00:0xa7:********************************************************************************
22:24:31:WU00:FS00:0xa7:Project: 14379 (Run 1508, Clone 0, Gen 398)
22:24:31:WU00:FS00:0xa7:Unit: 0x000001be455e42075e93306f34cbe813
22:24:31:WU00:FS00:0xa7:Digital signatures verified
22:24:31:WU00:FS00:0xa7:Calling: mdrun -s frame398.tpr -o frame398.trr -cpi state.cpt -cpt 15 -nt 1
22:24:31:WU00:FS00:0xa7:ERROR:Guru Meditation #c1ccd56e649b6951.9ac4db01bd631264 (1332312.2664624) '00/01/frame398.trr'
22:24:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:24:33:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:25:30:WU00:FS00:Starting
22:25:30:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
22:25:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 1
22:25:30:WU00:FS00:Started FahCore on PID 3336
22:25:30:WU00:FS00:Core PID:2236
22:25:30:WU00:FS00:FahCore 0xa7 started
22:25:31:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:25:31Z ***********************
22:25:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:25:31:WU00:FS00:0xa7:       Type: 0xa7
22:25:31:WU00:FS00:0xa7:       Core: Gromacs
22:25:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3336 -checkpoint 15 -np 1
22:25:31:WU00:FS00:0xa7:************************************ CBang *************************************
22:25:31:WU00:FS00:0xa7:       Date: Nov 27 2019
22:25:31:WU00:FS00:0xa7:       Time: 03:40:09
22:25:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:25:31:WU00:FS00:0xa7:     Branch: master
22:25:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:25:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:25:31:WU00:FS00:0xa7:   Platform: win32 10
22:25:31:WU00:FS00:0xa7:       Bits: 64
22:25:31:WU00:FS00:0xa7:       Mode: Release
22:25:31:WU00:FS00:0xa7:************************************ System ************************************
22:25:31:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:25:31:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:25:31:WU00:FS00:0xa7:       CPUs: 4
22:25:31:WU00:FS00:0xa7:     Memory: 7.88GiB
22:25:31:WU00:FS00:0xa7:Free Memory: 5.69GiB
22:25:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:25:31:WU00:FS00:0xa7: OS Version: 6.2
22:25:31:WU00:FS00:0xa7:Has Battery: true
22:25:31:WU00:FS00:0xa7: On Battery: false
22:25:31:WU00:FS00:0xa7: UTC Offset: 2
22:25:31:WU00:FS00:0xa7:        PID: 2236
22:25:31:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:25:31:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:25:31:WU00:FS00:0xa7:    Version: 0.0.19
22:25:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:25:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:25:31:WU00:FS00:0xa7:       Date: Nov 25 2019
22:25:31:WU00:FS00:0xa7:       Time: 17:12:41
22:25:31:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:25:31:WU00:FS00:0xa7:************************************ Build *************************************
22:25:31:WU00:FS00:0xa7:       SIMD: avx_256
22:25:31:WU00:FS00:0xa7:********************************************************************************
22:25:31:WU00:FS00:0xa7:Project: 14379 (Run 1508, Clone 0, Gen 398)
22:25:31:WU00:FS00:0xa7:Unit: 0x000001be455e42075e93306f34cbe813
22:25:31:WU00:FS00:0xa7:Digital signatures verified
22:25:31:WU00:FS00:0xa7:Calling: mdrun -s frame398.tpr -o frame398.trr -cpi state.cpt -cpt 15 -nt 1
22:25:31:WU00:FS00:0xa7:ERROR:Guru Meditation #c1ccd56e649b6951.9ac4db01bd631264 (1332312.2664624) '00/01/frame398.trr'
22:25:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:25:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:25:38:FS00:Finishing
22:25:38:FS00:Paused
22:25:43:FS00:Unpaused
22:25:43:FS00:Finishing
22:25:59:4:127.0.0.1:New Web session
22:26:10:FS00:Paused
22:26:12:FS00:Unpaused
22:26:31:WU00:FS00:Starting
22:26:31:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
22:26:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 1
22:26:31:WU00:FS00:Started FahCore on PID 8756
22:26:31:WU00:FS00:Core PID:1924
22:26:31:WU00:FS00:FahCore 0xa7 started
22:26:31:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:26:31Z ***********************
22:26:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:26:31:WU00:FS00:0xa7:       Type: 0xa7
22:26:31:WU00:FS00:0xa7:       Core: Gromacs
22:26:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8756 -checkpoint 15 -np 1
22:26:31:WU00:FS00:0xa7:************************************ CBang *************************************
22:26:31:WU00:FS00:0xa7:       Date: Nov 27 2019
22:26:31:WU00:FS00:0xa7:       Time: 03:40:09
22:26:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:26:31:WU00:FS00:0xa7:     Branch: master
22:26:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:26:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:26:31:WU00:FS00:0xa7:   Platform: win32 10
22:26:31:WU00:FS00:0xa7:       Bits: 64
22:26:31:WU00:FS00:0xa7:       Mode: Release
22:26:31:WU00:FS00:0xa7:************************************ System ************************************
22:26:31:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:26:31:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:26:31:WU00:FS00:0xa7:       CPUs: 4
22:26:31:WU00:FS00:0xa7:     Memory: 7.88GiB
22:26:31:WU00:FS00:0xa7:Free Memory: 5.38GiB
22:26:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:26:31:WU00:FS00:0xa7: OS Version: 6.2
22:26:31:WU00:FS00:0xa7:Has Battery: true
22:26:31:WU00:FS00:0xa7: On Battery: false
22:26:31:WU00:FS00:0xa7: UTC Offset: 2
22:26:31:WU00:FS00:0xa7:        PID: 1924
22:26:31:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:26:31:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:26:31:WU00:FS00:0xa7:    Version: 0.0.19
22:26:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:26:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:26:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:26:31:WU00:FS00:0xa7:       Date: Nov 25 2019
22:26:31:WU00:FS00:0xa7:       Time: 17:12:41
22:26:31:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:26:31:WU00:FS00:0xa7:************************************ Build *************************************
22:26:31:WU00:FS00:0xa7:       SIMD: avx_256
22:26:31:WU00:FS00:0xa7:********************************************************************************
22:26:31:WU00:FS00:0xa7:Project: 14379 (Run 1508, Clone 0, Gen 398)
22:26:31:WU00:FS00:0xa7:Unit: 0x000001be455e42075e93306f34cbe813
22:26:31:WU00:FS00:0xa7:Digital signatures verified
22:26:31:WU00:FS00:0xa7:Calling: mdrun -s frame398.tpr -o frame398.trr -cpi state.cpt -cpt 15 -nt 1
22:26:31:WU00:FS00:0xa7:ERROR:Guru Meditation #c1ccd56e649b6951.9ac4db01bd631264 (1332312.2664624) '00/01/frame398.trr'
22:26:33:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:26:33:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:27:31:WU00:FS00:Starting
22:27:31:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
22:27:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 1
22:27:31:WU00:FS00:Started FahCore on PID 5092
22:27:31:WU00:FS00:Core PID:6036
22:27:31:WU00:FS00:FahCore 0xa7 started
22:27:31:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:27:31Z ***********************
22:27:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:27:31:WU00:FS00:0xa7:       Type: 0xa7
22:27:31:WU00:FS00:0xa7:       Core: Gromacs
22:27:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5092 -checkpoint 15 -np 1
22:27:31:WU00:FS00:0xa7:************************************ CBang *************************************
22:27:31:WU00:FS00:0xa7:       Date: Nov 27 2019
22:27:31:WU00:FS00:0xa7:       Time: 03:40:09
22:27:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:27:31:WU00:FS00:0xa7:     Branch: master
22:27:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:27:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:27:31:WU00:FS00:0xa7:   Platform: win32 10
22:27:31:WU00:FS00:0xa7:       Bits: 64
22:27:31:WU00:FS00:0xa7:       Mode: Release
22:27:31:WU00:FS00:0xa7:************************************ System ************************************
22:27:31:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:27:31:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:27:31:WU00:FS00:0xa7:       CPUs: 4
22:27:31:WU00:FS00:0xa7:     Memory: 7.88GiB
22:27:31:WU00:FS00:0xa7:Free Memory: 5.33GiB
22:27:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:27:31:WU00:FS00:0xa7: OS Version: 6.2
22:27:31:WU00:FS00:0xa7:Has Battery: true
22:27:31:WU00:FS00:0xa7: On Battery: false
22:27:31:WU00:FS00:0xa7: UTC Offset: 2
22:27:31:WU00:FS00:0xa7:        PID: 6036
22:27:31:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:27:31:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:27:31:WU00:FS00:0xa7:    Version: 0.0.19
22:27:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:27:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:27:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:27:31:WU00:FS00:0xa7:       Date: Nov 25 2019
22:27:31:WU00:FS00:0xa7:       Time: 17:12:41
22:27:31:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:27:31:WU00:FS00:0xa7:************************************ Build *************************************
22:27:31:WU00:FS00:0xa7:       SIMD: avx_256
22:27:31:WU00:FS00:0xa7:********************************************************************************
22:27:31:WU00:FS00:0xa7:Project: 14379 (Run 1508, Clone 0, Gen 398)
22:27:31:WU00:FS00:0xa7:Unit: 0x000001be455e42075e93306f34cbe813
22:27:31:WU00:FS00:0xa7:Digital signatures verified
22:27:31:WU00:FS00:0xa7:Calling: mdrun -s frame398.tpr -o frame398.trr -cpi state.cpt -cpt 15 -nt 1
22:27:31:WU00:FS00:0xa7:ERROR:Guru Meditation #c1ccd56e649b6951.9ac4db01bd631264 (1332312.2664624) '00/01/frame398.trr'
22:27:33:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:27:33:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:27:33:WARNING:WU00:FS00:Too many errors, failing
22:27:33:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14379 run:1508 clone:0 gen:398 core:0xa7 unit:0x000001be455e42075e93306f34cbe813
22:27:33:WU00:FS00:Connecting to 69.94.66.7:8080
22:27:33:WU00:FS00:Server responded WORK_ACK (400)
22:27:33:WU00:FS00:Cleaning up
22:27:33:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:27:33:WU00:FS00:Assigned to work server 206.223.170.146
22:27:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 206.223.170.146
22:27:33:WU00:FS00:Connecting to 206.223.170.146:8080
22:27:34:WU00:FS00:Downloading 3.42MiB
22:27:36:WU00:FS00:Download complete
22:27:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14258 run:0 clone:574 gen:312 core:0xa7 unit:0x0000016bcedfaa925eac9fe11797aabc
22:27:36:WU00:FS00:Starting
22:27:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 4
22:27:36:WU00:FS00:Started FahCore on PID 3532
22:27:36:WU00:FS00:Core PID:3484
22:27:36:WU00:FS00:FahCore 0xa7 started
22:27:36:WU00:FS00:0xa7:*********************** Log Started 2020-08-14T22:27:36Z ***********************
22:27:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:27:36:WU00:FS00:0xa7:       Type: 0xa7
22:27:36:WU00:FS00:0xa7:       Core: Gromacs
22:27:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3532 -checkpoint 15 -np 4
22:27:36:WU00:FS00:0xa7:************************************ CBang *************************************
22:27:36:WU00:FS00:0xa7:       Date: Nov 27 2019
22:27:36:WU00:FS00:0xa7:       Time: 03:40:09
22:27:36:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:27:36:WU00:FS00:0xa7:     Branch: master
22:27:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:27:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:27:36:WU00:FS00:0xa7:   Platform: win32 10
22:27:36:WU00:FS00:0xa7:       Bits: 64
22:27:36:WU00:FS00:0xa7:       Mode: Release
22:27:36:WU00:FS00:0xa7:************************************ System ************************************
22:27:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
22:27:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:27:36:WU00:FS00:0xa7:       CPUs: 4
22:27:36:WU00:FS00:0xa7:     Memory: 7.88GiB
22:27:36:WU00:FS00:0xa7:Free Memory: 5.31GiB
22:27:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:27:36:WU00:FS00:0xa7: OS Version: 6.2
22:27:36:WU00:FS00:0xa7:Has Battery: true
22:27:36:WU00:FS00:0xa7: On Battery: false
22:27:36:WU00:FS00:0xa7: UTC Offset: 2
22:27:36:WU00:FS00:0xa7:        PID: 3484
22:27:36:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
22:27:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:27:36:WU00:FS00:0xa7:    Version: 0.0.19
22:27:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:27:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:27:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:27:36:WU00:FS00:0xa7:       Date: Nov 25 2019
22:27:36:WU00:FS00:0xa7:       Time: 17:12:41
22:27:36:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:27:36:WU00:FS00:0xa7:************************************ Build *************************************
22:27:36:WU00:FS00:0xa7:       SIMD: avx_256
22:27:36:WU00:FS00:0xa7:********************************************************************************
22:27:36:WU00:FS00:0xa7:Project: 14258 (Run 0, Clone 574, Gen 312)
22:27:36:WU00:FS00:0xa7:Unit: 0x0000016bcedfaa925eac9fe11797aabc
22:27:36:WU00:FS00:0xa7:Reading tar file core.xml
22:27:36:WU00:FS00:0xa7:Reading tar file frame312.tpr
22:27:36:WU00:FS00:0xa7:Digital signatures verified
22:27:36:WU00:FS00:0xa7:Calling: mdrun -s frame312.tpr -o frame312.trr -x frame312.xtc -cpt 15 -nt 4
22:27:36:WU00:FS00:0xa7:Steps: first=78000000 total=250000
22:27:37:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
22:30:29:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
23:13:41:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
03:30:12:WU01:FS00:Connecting to assign1.foldingathome.org:80
03:30:12:WU01:FS00:Assigned to work server 69.94.66.6
03:30:12:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 69.94.66.6
03:30:12:WU01:FS00:Connecting to 69.94.66.6:8080
03:30:13:WU01:FS00:Downloading 2.79MiB
03:30:14:WU01:FS00:Download complete
03:30:14:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14811 run:1685 clone:3 gen:18 core:0xa7 unit:0x00000014455e42065ec19bac0b36c626
03:32:59:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
03:33:05:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:33:05:WU00:FS00:0xa7:Saving result file frame312.trr
03:33:05:WU00:FS00:0xa7:Saving result file frame312.xtc
03:33:05:WU00:FS00:0xa7:Saving result file md.log
03:33:05:WU00:FS00:0xa7:Saving result file science.log
03:33:05:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:33:05:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:33:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14258 run:0 clone:574 gen:312 core:0xa7 unit:0x0000016bcedfaa925eac9fe11797aabc
03:33:05:WU00:FS00:Uploading 2.86MiB to 206.223.170.146
03:33:05:WU00:FS00:Connecting to 206.223.170.146:8080
03:33:05:WU01:FS00:Starting
03:33:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 4
03:33:05:WU01:FS00:Started FahCore on PID 10868
03:33:06:WU01:FS00:Core PID:4076
03:33:06:WU01:FS00:FahCore 0xa7 started
03:33:06:WU01:FS00:0xa7:*********************** Log Started 2020-08-15T03:33:06Z ***********************
03:33:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:33:06:WU01:FS00:0xa7:       Type: 0xa7
03:33:06:WU01:FS00:0xa7:       Core: Gromacs
03:33:06:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10868 -checkpoint 15 -np
03:33:06:WU01:FS00:0xa7:             4
03:33:06:WU01:FS00:0xa7:************************************ CBang *************************************
03:33:06:WU01:FS00:0xa7:       Date: Nov 27 2019
03:33:06:WU01:FS00:0xa7:       Time: 03:40:09
03:33:06:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:33:06:WU01:FS00:0xa7:     Branch: master
03:33:06:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:33:06:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:33:06:WU01:FS00:0xa7:   Platform: win32 10
03:33:06:WU01:FS00:0xa7:       Bits: 64
03:33:06:WU01:FS00:0xa7:       Mode: Release
03:33:06:WU01:FS00:0xa7:************************************ System ************************************
03:33:06:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
03:33:06:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
03:33:06:WU01:FS00:0xa7:       CPUs: 4
03:33:06:WU01:FS00:0xa7:     Memory: 7.88GiB
03:33:06:WU01:FS00:0xa7:Free Memory: 4.42GiB
03:33:06:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:33:06:WU01:FS00:0xa7: OS Version: 6.2
03:33:06:WU01:FS00:0xa7:Has Battery: true
03:33:06:WU01:FS00:0xa7: On Battery: false
03:33:06:WU01:FS00:0xa7: UTC Offset: 2
03:33:06:WU01:FS00:0xa7:        PID: 4076
03:33:06:WU01:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
03:33:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:33:06:WU01:FS00:0xa7:    Version: 0.0.19
03:33:06:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:33:06:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:33:06:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:33:06:WU01:FS00:0xa7:       Date: Nov 25 2019
03:33:06:WU01:FS00:0xa7:       Time: 17:12:41
03:33:06:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:33:06:WU01:FS00:0xa7:************************************ Build *************************************
03:33:06:WU01:FS00:0xa7:       SIMD: avx_256
03:33:06:WU01:FS00:0xa7:********************************************************************************
03:33:06:WU01:FS00:0xa7:Project: 14811 (Run 1685, Clone 3, Gen 18)
03:33:06:WU01:FS00:0xa7:Unit: 0x00000014455e42065ec19bac0b36c626
03:33:06:WU01:FS00:0xa7:Reading tar file core.xml
03:33:06:WU01:FS00:0xa7:Reading tar file frame18.tpr
03:33:06:WU01:FS00:0xa7:Digital signatures verified
03:33:06:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpt 15 -nt 4
03:33:06:WU01:FS00:0xa7:Steps: first=0 total=250000
03:33:09:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
03:33:11:WU00:FS00:Upload 89.63%
03:33:11:WU00:FS00:Upload complete
03:33:12:WU00:FS00:Server responded WORK_ACK (400)
03:33:12:WU00:FS00:Final credit estimate, 2695.00 points
03:33:12:WU00:FS00:Cleaning up
09:10:40:WU00:FS00:Connecting to assign1.foldingathome.org:80
09:10:41:WU00:FS00:Assigned to work server 128.252.203.10
09:10:41:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.10
09:10:41:WU00:FS00:Connecting to 128.252.203.10:8080
09:10:41:WU00:FS00:Downloading 2.22MiB
09:10:43:WU00:FS00:Download complete
09:10:43:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17201 run:0 clone:1344 gen:25 core:0xa7 unit:0x0000001a80fccb0a5f32fefecb83de92
09:14:20:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
09:14:25:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
09:14:25:WU01:FS00:0xa7:Saving result file dhdl.xvg
09:14:25:WU01:FS00:0xa7:Saving result file frame18.trr
09:14:25:WU01:FS00:0xa7:Saving result file md.log
09:14:25:WU01:FS00:0xa7:Saving result file pullf.xvg
09:14:25:WU01:FS00:0xa7:Saving result file pullx.xvg
09:14:25:WU01:FS00:0xa7:Saving result file science.log
09:14:25:WU01:FS00:0xa7:Saving result file traj_comp.xtc
09:14:25:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:14:25:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:14:25:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14811 run:1685 clone:3 gen:18 core:0xa7 unit:0x00000014455e42065ec19bac0b36c626
09:14:25:WU01:FS00:Uploading 6.73MiB to 69.94.66.6
09:14:25:WU01:FS00:Connecting to 69.94.66.6:8080
09:14:25:WU00:FS00:Starting
09:14:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\super\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -np 4
09:14:25:WU00:FS00:Started FahCore on PID 5532
09:14:26:WU00:FS00:Core PID:12216
09:14:26:WU00:FS00:FahCore 0xa7 started
09:14:26:WU00:FS00:0xa7:*********************** Log Started 2020-08-15T09:14:26Z ***********************
09:14:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:14:26:WU00:FS00:0xa7:       Type: 0xa7
09:14:26:WU00:FS00:0xa7:       Core: Gromacs
09:14:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5532 -checkpoint 15 -np 4
09:14:26:WU00:FS00:0xa7:************************************ CBang *************************************
09:14:26:WU00:FS00:0xa7:       Date: Nov 27 2019
09:14:26:WU00:FS00:0xa7:       Time: 03:40:09
09:14:26:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:14:26:WU00:FS00:0xa7:     Branch: master
09:14:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:14:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:14:26:WU00:FS00:0xa7:   Platform: win32 10
09:14:26:WU00:FS00:0xa7:       Bits: 64
09:14:26:WU00:FS00:0xa7:       Mode: Release
09:14:26:WU00:FS00:0xa7:************************************ System ************************************
09:14:26:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
09:14:26:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
09:14:26:WU00:FS00:0xa7:       CPUs: 4
09:14:26:WU00:FS00:0xa7:     Memory: 7.88GiB
09:14:26:WU00:FS00:0xa7:Free Memory: 3.89GiB
09:14:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:14:26:WU00:FS00:0xa7: OS Version: 6.2
09:14:26:WU00:FS00:0xa7:Has Battery: true
09:14:26:WU00:FS00:0xa7: On Battery: false
09:14:26:WU00:FS00:0xa7: UTC Offset: 2
09:14:26:WU00:FS00:0xa7:        PID: 12216
09:14:26:WU00:FS00:0xa7:        CWD: C:\Users\super\AppData\Roaming\FAHClient\work
09:14:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:14:26:WU00:FS00:0xa7:    Version: 0.0.19
09:14:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:14:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:14:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:14:26:WU00:FS00:0xa7:       Date: Nov 25 2019
09:14:26:WU00:FS00:0xa7:       Time: 17:12:41
09:14:26:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:14:26:WU00:FS00:0xa7:************************************ Build *************************************
09:14:26:WU00:FS00:0xa7:       SIMD: avx_256
09:14:26:WU00:FS00:0xa7:********************************************************************************
09:14:26:WU00:FS00:0xa7:Project: 17201 (Run 0, Clone 1344, Gen 25)
09:14:26:WU00:FS00:0xa7:Unit: 0x0000001a80fccb0a5f32fefecb83de92
09:14:26:WU00:FS00:0xa7:Reading tar file core.xml
09:14:26:WU00:FS00:0xa7:Reading tar file frame25.tpr
09:14:26:WU00:FS00:0xa7:Digital signatures verified
09:14:26:WU00:FS00:0xa7:Calling: mdrun -s frame25.tpr -o frame25.trr -x frame25.xtc -cpt 15 -nt 4
09:14:26:WU00:FS00:0xa7:Steps: first=6250000 total=250000
09:14:27:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
09:14:31:WU01:FS00:Upload complete
09:14:31:WU01:FS00:Server responded WORK_ACK (400)
09:14:31:WU01:FS00:Final credit estimate, 2861.00 points
09:14:31:WU01:FS00:Cleaning up
parkut
Post by parkut »
Florian_Berlin: https://apps.foldingathome.org/wu?proje ... e=3&gen=18
Hi Florian_Berlin (team 45700), Your WU (P14811 R1685 C3 G18) was added to the stats database on Sat, 15 Aug 2020 13:14:30 GMT for 2861.6 points of credit.
anandhanju
Post by anandhanju »
@TuxSam, welcome to Folding@home and this forum!
The WU in your log has been credited to you -- see https://apps.foldingathome.org/wu#proje ... 712&gen=81
g_moreno
Post by g_moreno »
My credit is being computed as "Anonymous", I have already tried to change my name and Passkey. After being credited, I search in https://apps.foldingathome.org/wu#proje and the user is listed as Anonymous, and the team appears correctly. Does anyone know what it could be?
00:33:41:I1:WU2:Project: 19227 (Run 9856, Clone 5, Gen 3)
00:33:41:I1:WU2:Unit: 0x00000000000000000000000000000000
00:33:41:I1:WU2:Digital signatures verified
00:33:41:I1:WU2:Calling: mdrun -c md3.gro -s md3.tpr -x md3.xtc -cpi state.cpt -cpt 5 -nt 8 -ntmpi 1
00:33:42:I1:WU2:Steps: first=1500000 total=2000000
00:34:03:I1:WU2:Completed 396082 out of 500000 steps (79%)
00:34:53:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
00:35:08:W :CON214:DNS lookup failed for api.foldingathome.org
00:35:08:E :OUT214:Failed response: CONNECT
00:35:38:W :CON215:DNS lookup failed for api.foldingathome.org
00:35:38:E :OUT215:Failed response: CONNECT
00:36:15:W :CON216:DNS lookup failed for api.foldingathome.org
00:36:15:E :OUT216:Failed response: CONNECT
00:37:03:W :CON217:DNS lookup failed for api.foldingathome.org
00:37:03:E :OUT217:Failed response: CONNECT
00:38:08:W :CON218:DNS lookup failed for api.foldingathome.org
00:38:08:E :OUT218:Failed response: CONNECT
00:39:33:W :CON219:DNS lookup failed for api.foldingathome.org
00:39:33:E :OUT219:Failed response: CONNECT
00:41:26:I1:OUT220:> GET https://api.foldingathome.org/machine/VuJlh3uOaeCNXOGRm7pI3a5wswjBWrXbC3EJLP19Hoo HTTP/1.1
00:41:27:I1:OUT220:< HTTP/1.1 200 HTTP_OK
00:41:27:I1:OUT13:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
00:41:28:I1:OUT13:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
00:41:28:I1:Logging into node account
00:52:40:I1:WU2:Completed 400000 out of 500000 steps (80%)
01:16:52:I1:WU2:Completed 405000 out of 500000 steps (81%)
01:40:58:I1:WU2:Completed 410000 out of 500000 steps (82%)
02:05:07:I1:WU2:Completed 415000 out of 500000 steps (83%)
02:29:12:I1:WU2:Completed 420000 out of 500000 steps (84%)
02:53:20:I1:WU2:Completed 425000 out of 500000 steps (85%)
03:17:31:I1:WU2:Completed 430000 out of 500000 steps (86%)
03:41:47:I1:WU2:Completed 435000 out of 500000 steps (87%)
04:05:59:I1:WU2:Completed 440000 out of 500000 steps (88%)
04:30:11:I1:WU2:Completed 445000 out of 500000 steps (89%)
04:54:24:I1:WU2:Completed 450000 out of 500000 steps (90%)
05:18:34:I1:WU2:Completed 455000 out of 500000 steps (91%)
05:42:45:I1:WU2:Completed 460000 out of 500000 steps (92%)
06:06:55:I1:WU2:Completed 465000 out of 500000 steps (93%)
06:31:06:I1:WU2:Completed 470000 out of 500000 steps (94%)
06:55:18:I1:WU2:Completed 475000 out of 500000 steps (95%)
07:19:29:I1:WU2:Completed 480000 out of 500000 steps (96%)
07:43:39:I1:WU2:Completed 485000 out of 500000 steps (97%)
08:07:53:I1:WU2:Completed 490000 out of 500000 steps (98%)
08:32:11:I1:WU2:Completed 495000 out of 500000 steps (99%)
08:56:21:I1:WU2:Completed 500000 out of 500000 steps (100%)
08:56:24:I1:WU2:Saving result file ..\logfile_01.txt
08:56:24:I1:WU2:Saving result file dhdl.xvg
08:56:24:I1:WU2:Saving result file md.log
08:56:24:I1:WU2:Saving result file md3.gro
08:56:24:I1:WU2:Saving result file science.log
08:56:24:I1:WU2:Saving result file state.cpt
08:56:24:I1:WU2:Folding@home Core Shutdown: FINISHED_UNIT
08:56:24:I1:WU2:Core returned FINISHED_UNIT (100)
08:56:24:I1:Default:Added new work unit: cpus:8 gpus:
08:56:24:I1:WU2:Uploading WU results
08:56:25:I1:WU3:Requesting WU assignment for user Guilherme Moreno Guimarães team 3213
08:56:30:I1:OUT221:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
08:56:34:I1:OUT221:< HTTP/1.1 200 HTTP_OK
08:56:34:I1:WU2:Credited
08:56:36:I1:OUT222:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
08:56:36:I1:OUT222:< HTTP/1.1 200 HTTP_OK
08:56:36:I1:WU3:Received WU assignment eCPE8YRQKLYmIBV6UzGObHXDmCu1OaZYdferwFYxSPk
08:56:36:I1:WU3:Downloading WU
08:56:37:I1:OUT223:> POST https://ds01.scs.illinois.edu/api/assign HTTP/1.1
08:56:39:I1:OUT223:< HTTP/1.1 200 HTTP_OK
08:56:40:I1:WU3:Received WU P19227 R6841 C5 G3
08:56:40:I3:WU3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir eCPE8YRQKLYmIBV6UzGObHXDmCu1OaZYdferwFYxSPk -suffix 01 -version 8.3.18 -lifeline 15504 -np 8
08:56:40:I3:WU3:Started FahCore on PID 17180
->00:33:41:I1:WU2:Project: 19227 (Run 9856, Clone 5, Gen 3)
https://apps.foldingathome.org/wu#proje ... ne=5&gen=3
g_moreno wrote: Fri Jan 10, 2025 7:18 pm My credit is being computed as "Anonymous", I have already tried to change my name and Passkey.
You do not need to change the passkey. Once you have one it can be used with any system, username, or team. Just that when qualifying for bonus it takes 10 WUs using the same username and passkey to qualify the pair.
The WU you looked up shows as being credited to user Anonymous and Team 0 instead of Team 3213. That will happen if no entry was made at the time the WU was downloaded. The next WU processed after:
did get credited to the correct team.
From another report in the past week, usernames with characters in the extended set beyond ASCII appear to not be handled by the stats system and get credited as Anonymous. See this topic - viewtopic.php?t=42348 - where the user had used the "ž" character in their username. That character is used in by Slavic and Baltic languages in general, and for romanization for a few other languages. Your username "Guilherme Moreno Guimarães" is also using two characters that may cause issues. The developer who maintains the stats server code has been contacted, but in the meantime you should just use standard ASCII characters in your username.
