Can't get WU's for days
uclajd
Hardware configuration: Nvidia RTX-2080 with Max-Q (990Mhz)
Post by uclajd »
I was churning out a million points a day, but I keep getting this message:
"19:43:15:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:43:15:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:43:16:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:43:16:ERROR:WU00:FS01:Exception: Could not get an assignment"
WTH?
*********************** Log Started 2020-08-02T19:37:56Z ***********************
19:37:56:Trying to access database...
19:37:56:Successfully acquired database lock
19:37:56:Read GPUs.txt
19:37:57:Enabled folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
19:37:57:****************************** FAHClient ******************************
19:37:57:        Version: 7.6.13
19:37:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:37:57:      Copyright: 2020 foldingathome.org
19:37:57:       Homepage: https://foldingathome.org/
19:37:57:           Date: Apr 27 2020
19:37:57:           Time: 21:21:01
19:37:57:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:37:57:         Branch: master
19:37:57:       Compiler: Visual C++ 2008
19:37:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:37:57:       Platform: win32 10
19:37:57:           Bits: 32
19:37:57:           Mode: Release
19:37:57:         Config: C:\Users\JD\AppData\Roaming\FAHClient\config.xml
19:37:57:******************************** CBang ********************************
19:37:57:           Date: Apr 24 2020
19:37:57:           Time: 17:07:55
19:37:57:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:37:57:           Bits: 32
19:37:57:******************************* System ********************************
19:37:57:            CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
19:37:57:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:37:57:           CPUs: 16
19:37:57:         Memory: 15.80GiB
19:37:57:    Free Memory: 12.73GiB
19:37:57:        Threads: WINDOWS_THREADS
19:37:57:     OS Version: 6.2
19:37:57:    Has Battery: true
19:37:57:     On Battery: false
19:37:57:     UTC Offset: -7
19:37:57:            PID: 10716
19:37:57:            CWD: C:\Users\JD\AppData\Roaming\FAHClient
19:37:57:  Win32 Service: false
19:37:57:             OS: Windows 10 Enterprise
19:37:57:        OS Arch: AMD64
19:37:57:           GPUs: 2
19:37:57:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
19:37:57:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU104M [GeForce RTX 2080 Mobile]
19:37:57:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
19:37:57:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.23
19:37:57:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
19:37:57:******************************* libFAH ********************************
19:37:57:           Date: Apr 15 2020
19:37:57:           Time: 14:53:14
19:37:57:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:37:57:           Bits: 32
19:37:57:***********************************************************************
19:37:57:<config>
19:37:57:  <!-- Folding Core -->
19:37:57:  <checkpoint v='30'/>
19:37:57:  <core-priority v='low'/>
19:37:57:
19:37:57:  <!-- Network -->
19:37:57:  <proxy v=':8080'/>
19:37:57:
19:37:57:  <!-- Slot Control -->
19:37:57:  <power v='MEDIUM'/>
19:37:57:
19:37:57:  <!-- User Information -->
19:37:57:  <passkey v='*****'/>
19:37:57:  <team v='40965'/>
19:37:57:  <user v='UCLAJD'/>
19:37:57:
19:37:57:  <!-- Folding Slots -->
19:37:57:  <slot id='1' type='GPU'/>
19:37:57:</config>
19:37:57:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:37:58:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': Failed to connect to assign1.foldingathome.org:80: An attempt was made to access a socket in a way forbidden by its access permissions.
19:37:58:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:37:58:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': Failed to connect to assign2.foldingathome.org:80: An attempt was made to access a socket in a way forbidden by its access permissions.
19:37:58:WU00:FS01:Connecting to assign3.foldingathome.org:80
19:37:59:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': Failed to connect to assign3.foldingathome.org:80: An attempt was made to access a socket in a way forbidden by its access permissions.
19:37:59:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:37:59:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': Failed to connect to assign4.foldingathome.org:80: An attempt was made to access a socket in a way forbidden by its access permissions.
19:37:59:ERROR:WU00:FS01:Exception: Could not get an assignment
19:38:00:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:38:00:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:38:00:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:38:01:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:38:01:WU00:FS01:Connecting to assign3.foldingathome.org:80
19:38:01:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:38:01:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:38:03:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:38:03:ERROR:WU00:FS01:Exception: Could not get an assignment
19:39:00:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:39:00:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:39:00:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:39:00:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:39:00:WU00:FS01:Connecting to assign3.foldingathome.org:80
19:39:01:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:39:01:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:39:02:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:39:02:ERROR:WU00:FS01:Exception: Could not get an assignment
19:40:03:17:127.0.0.1:New Web session
19:40:37:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:40:37:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:40:37:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:40:38:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:40:38:WU00:FS01:Connecting to assign3.foldingathome.org:80
19:40:38:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:40:38:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:40:38:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:40:38:ERROR:WU00:FS01:Exception: Could not get an assignment
19:43:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:43:15:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:43:15:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:43:15:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:43:15:WU00:FS01:Connecting to assign3.foldingathome.org:80
Reason: added Code tags to log
Nvidia RTX-2080 with Max-Q (990Mhz) on Alienware 17 i9-9980HK @2.40 GHz 8-core.
Re: Can't get WU's for days
Your client has run into a bug in how it handles updates in the GPUs.txt file that it downloads about once a month to get the changes. In this specific case, some Intel iGPUs have been enabled for the researchers to test and check out possibly supporting them in the future. The Intel GPU has taken over the GPU folding and there are no public WUs.
This can be fixed up.
First pause folding. Then using FAHControl's Configure select the Slots tab. Click on the GPU slot and then Edit. Add the Extra Slot Option 'pause-on-start-true' and set it to 'true'. OK and Save these changes.
Next to add back in your RTX 2080, go back into Configure.and click Add under the Slots tab. On the window for adding and modifying slots click the radio button in the GPU area at the left side. It defaults to CPU, and in some themes is not too visible. OK and Save this. You should now have a working GPU folding slot.
For now do not remove the GPU slot for the disabled Intel GPU. The client will just add it back and mess things up again. You can pause folding using the pause all slots, but when resuming you will want to select just the slot for the 2080. To do this Right-click on the GPU slot for the 2080 in FAHControl, a small menu will pop up.
uclajd
Post by uclajd »
Joe_H wrote:Your client has run into a bug in how it handles updates in the GPUs.txt file that it downloads about once a month to get the changes. In this specific case, some Intel iGPUs have been enabled for the researchers to test and check out possibly supporting them in the future. The Intel GPU has taken over the GPU folding and there are no public WUs.
For now do not remove the GPU slot for the unable Intel GPU. The client will just add it back and mess things up again. You can pause folding using the pause all slots, but when resuming you will want to select just the slot for the 2080. To do this Right-click on the GPU slot for the 2080 in FAHControl, a small menu will pop up.
Thanks man, started a download immediately!
It's still showing the other GPU in folding slots and work queue. Anyway to get rid of that? TIA.
uclajd wrote:It's still showing the other GPU in folding slots and work queue. Anyway to get rid of that? TIA.
Unfortunately not for now. There were some changes in how the client detects GPU hardware and creates folding slots in recent versions of the client, so it may have to wait for the next version to be fixed. The bug shows up for two different types of changes in the GPUs.txt file. One is if a GPU changes from supported to unsupported, the other is this case where an unsupported GPU becomes "supported". I wrote "supported" as the setting at this time is only for internal testers, needed because they get work through the same servers. Not supported for general assignments.
uyaem
Post by uyaem »
uclajd wrote:
Joe_H wrote:It's still showing the other GPU in folding slots and work queue. Anyway to get rid of that? TIA.
You can't/shouldn't remove the slot, but to ease load on the servers and your log file, you can simply pause the slot.
Additionally, you can set the pause-on-start option for that slot to true so it won't try again after reboot, make sure you select the correct GPU ofc ;)
uclajd
Post by uclajd »
Done. Thanks guys, I'm folding away, over a million PPD back on track! :D
