168.245.198.125 struggling
Juggy
Hardware configuration: Intel i9 9900KF @4.9GHZ
MSI Z390M Gaming OC
64GB G-Skill Ripjaw 3200
Gigabyte RTX2060 Super Gaming OC
NZXT Kraken X63 AIO
Corsair RM850
Samsung 1TB Evo Pro NVMe
Post by Juggy »
That server is struggling to accept work. 9 minutes for a 4.7mb file to get to 87% then fails.
13:07:48:WU00:FS01:Uploading 4.74MiB to 168.245.198.125
13:07:48:WU00:FS01:Connecting to 168.245.198.125:8080
13:07:48:WU02:FS01:0xa7:Completed 23750 out of 62500 steps (38%)
13:07:54:WU00:FS01:Upload 6.59%
13:08:16:WU02:FS01:0xa7:Completed 24375 out of 62500 steps (39%)
13:08:43:WU00:FS01:Upload 19.76%
13:08:44:WU02:FS01:0xa7:Completed 25000 out of 62500 steps (40%)
13:08:53:WU04:FS00:0x22:Completed 120000 out of 1000000 steps (12%)
13:09:12:WU02:FS01:0xa7:Completed 25625 out of 62500 steps (41%)
13:09:36:WU00:FS01:Upload 30.30%
13:09:40:WU02:FS01:0xa7:Completed 26250 out of 62500 steps (42%)
13:10:08:WU02:FS01:0xa7:Completed 26875 out of 62500 steps (43%)
13:10:11:WU04:FS00:0x22:Completed 130000 out of 1000000 steps (13%)
13:10:22:WU00:FS01:Upload 35.57%
13:10:28:WU00:FS01:Upload 43.47%
13:10:36:WU02:FS01:0xa7:Completed 27500 out of 62500 steps (44%)
13:11:04:WU02:FS01:0xa7:Completed 28125 out of 62500 steps (45%)
13:11:06:WU00:FS01:Upload 47.42%
13:11:12:WU00:FS01:Upload 51.37%
13:11:29:WU04:FS00:0x22:Completed 140000 out of 1000000 steps (14%)
13:11:32:WU02:FS01:0xa7:Completed 28750 out of 62500 steps (46%)
13:11:57:WU00:FS01:Upload 52.69%
13:12:00:WU02:FS01:0xa7:Completed 29375 out of 62500 steps (47%)
13:12:28:WU02:FS01:0xa7:Completed 30000 out of 62500 steps (48%)
13:12:46:WU04:FS00:0x22:Completed 150000 out of 1000000 steps (15%)
13:12:50:WU00:FS01:Upload 57.96%
13:12:57:WU02:FS01:0xa7:Completed 30625 out of 62500 steps (49%)
13:13:25:WU02:FS01:0xa7:Completed 31250 out of 62500 steps (50%)
13:13:33:WU00:FS01:Upload 63.23%
13:13:53:WU02:FS01:0xa7:Completed 31875 out of 62500 steps (51%)
13:14:05:WU04:FS00:0x22:Completed 160000 out of 1000000 steps (16%)
13:14:20:WU00:FS01:Upload 71.13%
13:14:20:WU02:FS01:0xa7:Completed 32500 out of 62500 steps (52%)
13:14:48:WU02:FS01:0xa7:Completed 33125 out of 62500 steps (53%)
13:15:01:WU00:FS01:Upload 80.35%
13:15:07:WU00:FS01:Upload 84.31%
13:15:16:WU02:FS01:0xa7:Completed 33750 out of 62500 steps (54%)
13:15:22:WU04:FS00:0x22:Completed 170000 out of 1000000 steps (17%)
13:15:44:WU02:FS01:0xa7:Completed 34375 out of 62500 steps (55%)
13:16:01:WU00:FS01:Upload 86.94%
13:16:01:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
Re: 168.245.198.125 struggling
I see a high assign rate on this server ... it might be a bit overloaded ...
comixgoddess
Hardware configuration: MacBook Pro 2017
Post by comixgoddess »
Similar issue here, but with a twist. My work unit (project:16411 run:1476 clone:4 gen:18) uploaded to the collection server but the log only shows that the base points being awarded (rather than the QRB points for completing the WU in under three hours). And when I search on the WU status page, I get "Not found".
16:01:26:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16411 run:1476 clone:4 gen:18 core:0xa7 unit:0x00000019a8f5c67d5e8772bc7ca46fd7
16:01:26:WU01:FS00:Uploading 2.40MiB to 168.245.198.125
16:01:26:WU01:FS00:Connecting to 168.245.198.125:8080
16:01:38:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:01:38:WU01:FS00:Connecting to 168.245.198.125:80
16:01:49:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 168.245.198.125:80: Operation timed out
16:01:49:WU01:FS00:Trying to send results to collection server
16:01:49:WU01:FS00:Uploading 2.40MiB to 146.94.192.82
16:01:49:WU01:FS00:Connecting to 146.94.192.82:8080
16:01:53:WU01:FS00:Upload complete
16:01:54:WU01:FS00:Server responded WORK_ACK (400)
16:01:54:WU01:FS00:Final credit estimate, 501.00 points
points that appear in the log are based on how long your computer thinks you had the WU. (They're not the actual points awarded.) Search the various log files on your compuuter and find the first time/date the WU was downloaded (if it was downloaded more than once, which is rare) and the time/date it was eventually uploaded to either the WS or the CS. Those times are used to compute the points shown in your log.
The same two times based on the server's clocks are used to calculate the ACTUAL points awarded.
A backlog of points recprds has accumulated on various servers that have not been posted to the stats database. They'll get there eventually. The record will contain the correct calculation, no matter when it gets there because the time that the results arrived at either the WS or the CS is recorded when they're uploaded.
comixgoddess
bruce wrote:points that appear in the log are based on how long your computer thinks you had the WU. (They're not the actual points awarded.) Search the various log files on your compuuter and find the first time/date the WU was downloaded (if it was downloaded more than once, which is rare) and the time/date it was eventually uploaded to either the WS or the CS. Those times are used to compute the points shown in your log.
Hi Bruce ~
I checked my logs and the WU was downloaded on 7/31 as follows --
13:43:51:WU01:FS00:Connecting to 168.245.198.125:8080
13:43:57:WU01:FS00:Downloading 2.85MiB
13:43:59:WU01:FS00:Download complete
13:43:59:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16411 run:1476 clone:4 gen:18 core:0xa7 unit:0x00000019a8f5c67d5e8772bc7ca46fd7
Uploaded the same day at 16:01:53 to collection server 146.94.192.82:8080. Just noticed that while the download was 2.85MiB, the upload is shown as 2.40MiB. :?:
