GPU keeps restarting to 0%
AlphaOmega888
Hardware configuration: CPU: AMD Ryzen 5 1600 Six-Core Processor
GPU: GeForce GTX 1050 Ti
Post by AlphaOmega888 »
After getting to 0.5% or so, folding at home restarts the gpu work unit from 0%.
I noticed the message "Is your system overclocked" in the log file, does folding@home not work with overclocking?
What can I do to stop this from happening again?
Here's the log file:
*********************** Log Started 2020-07-28T19:38:47Z ***********************
19:38:47:Trying to access database...
19:38:47:Successfully acquired database lock
19:38:47:Read GPUs.txt
19:38:47:Enabled folding slot 00: READY cpu:6
19:38:47:Enabled folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138
19:38:47:****************************** FAHClient ******************************
19:38:47:        Version: 7.6.13
19:38:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:38:47:      Copyright: 2020 foldingathome.org
19:38:47:       Homepage: https://foldingathome.org/
19:38:47:           Date: Apr 27 2020
19:38:47:           Time: 21:21:01
19:38:47:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:38:47:         Branch: master
19:38:47:       Compiler: Visual C++ 2008
19:38:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:38:47:       Platform: win32 10
19:38:47:           Bits: 32
19:38:47:           Mode: Release
19:38:47:         Config: C:\Users\User\AppData\Roaming\FAHClient\config.xml
19:38:47:******************************** CBang ********************************
19:38:47:           Date: Apr 24 2020
19:38:47:           Time: 17:07:55
19:38:47:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:38:47:           Bits: 32
19:38:47:******************************* System ********************************
19:38:47:            CPU: AMD Ryzen 5 1600 Six-Core Processor
19:38:47:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
19:38:47:           CPUs: 12
19:38:47:         Memory: 15.93GiB
19:38:47:    Free Memory: 12.61GiB
19:38:47:        Threads: WINDOWS_THREADS
19:38:47:     OS Version: 6.2
19:38:47:    Has Battery: false
19:38:47:     On Battery: false
19:38:47:     UTC Offset: -4
19:38:47:            PID: 11584
19:38:47:            CWD: C:\Users\User\AppData\Roaming\FAHClient
19:38:47:  Win32 Service: false
19:38:47:             OS: Windows 10 Home
19:38:47:        OS Arch: AMD64
19:38:47:           GPUs: 1
19:38:47:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
19:38:47:  CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:11.0
19:38:47:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:451.67
19:38:47:******************************* libFAH ********************************
19:38:47:           Date: Apr 15 2020
19:38:47:           Time: 14:53:14
19:38:47:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:38:47:           Bits: 32
19:38:47:***********************************************************************
19:38:47:<config>
19:38:47:  <!-- Folding Core -->
19:38:47:  <checkpoint v='8'/>
19:38:47:  <core-priority v='low'/>
19:38:47:
19:38:47:  <!-- Folding Slot Configuration -->
19:38:47:  <cause v='COVID_19'/>
19:38:47:
19:38:47:  <!-- HTTP Server -->
19:38:47:  <allow v='127.0.0.1 192.168.1.0/24'/>
19:38:47:
19:38:47:  <!-- Network -->
19:38:47:  <proxy v=':8080'/>
19:38:47:
19:38:47:  <!-- Remote Command Server -->
19:38:47:  <password v='*****'/>
19:38:47:
19:38:47:  <!-- Slot Control -->
19:38:47:  <pause-on-battery v='false'/>
19:38:47:
19:38:47:  <!-- User Information -->
19:38:47:  <passkey v='*****'/>
19:38:47:  <team v='223518'/>
19:38:47:  <user v='AlphaOmega888'/>
19:38:47:
19:38:47:  <!-- Folding Slots -->
19:38:47:  <slot id='0' type='CPU'>
19:38:47:    <cpus v='6'/>
19:38:47:  </slot>
19:38:47:  <slot id='1' type='GPU'>
19:38:47:    <gpu-index v='0'/>
19:38:47:  </slot>
19:38:47:</config>
19:38:47:WU02:FS01:Starting
19:38:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-nvidia/21-0.0.20/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:38:47:WU02:FS01:Started FahCore on PID 13376
19:38:47:WU02:FS01:Core PID:13492
19:38:47:WU02:FS01:FahCore 0x21 started
19:38:47:WU00:FS00:Starting
19:38:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -np 6
19:38:47:WU00:FS00:Started FahCore on PID 13836
19:38:47:WU00:FS00:Core PID:13872
19:38:47:WU00:FS00:FahCore 0xa7 started
19:38:48:WU00:FS00:0xa7:*********************** Log Started 2020-07-28T19:38:48Z ***********************
19:38:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:38:48:WU00:FS00:0xa7:       Type: 0xa7
19:38:48:WU00:FS00:0xa7:       Core: Gromacs
19:38:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13836 -checkpoint 8 -np 6
19:38:48:WU00:FS00:0xa7:************************************ CBang *************************************
19:38:48:WU00:FS00:0xa7:       Date: Nov 27 2019
19:38:48:WU00:FS00:0xa7:       Time: 03:40:09
19:38:48:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
19:38:48:WU00:FS00:0xa7:     Branch: master
19:38:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:38:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:38:48:WU00:FS00:0xa7:   Platform: win32 10
19:38:48:WU00:FS00:0xa7:       Bits: 64
19:38:48:WU00:FS00:0xa7:       Mode: Release
19:38:48:WU00:FS00:0xa7:************************************ System ************************************
19:38:48:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
19:38:48:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
19:38:48:WU00:FS00:0xa7:       CPUs: 12
19:38:48:WU00:FS00:0xa7:     Memory: 15.93GiB
19:38:48:WU00:FS00:0xa7:Free Memory: 12.54GiB
19:38:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:38:48:WU00:FS00:0xa7: OS Version: 6.2
19:38:48:WU00:FS00:0xa7:Has Battery: false
19:38:48:WU00:FS00:0xa7: On Battery: false
19:38:48:WU00:FS00:0xa7: UTC Offset: -4
19:38:48:WU00:FS00:0xa7:        PID: 13872
19:38:48:WU00:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
19:38:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:38:48:WU00:FS00:0xa7:    Version: 0.0.19
19:38:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:38:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:38:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:38:48:WU00:FS00:0xa7:       Date: Nov 25 2019
19:38:48:WU00:FS00:0xa7:       Time: 17:12:41
19:38:48:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
19:38:48:WU02:FS01:0x21:*********************** Log Started 2020-07-28T19:38:48Z ***********************
19:38:48:WU02:FS01:0x21:Project: 16900 (Run 22, Clone 38, Gen 35)
19:38:48:WU02:FS01:0x21:Unit: 0x0000004d0002894c5ecb32b5c84c993c
19:38:48:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:38:48:WU00:FS00:0xa7:************************************ Build *************************************
19:38:48:WU02:FS01:0x21:Machine: 1
19:38:48:WU00:FS00:0xa7:       SIMD: avx_256
19:38:48:WU02:FS01:0x21:Digital signatures verified
19:38:48:WU00:FS00:0xa7:********************************************************************************
19:38:48:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:38:48:WU00:FS00:0xa7:Project: 14379 (Run 1380, Clone 1, Gen 295)
19:38:48:WU02:FS01:0x21:Version 0.0.20
19:38:48:WU00:FS00:0xa7:Unit: 0x00000152455e42075e933059e9f9e6fc
19:38:48:WU02:FS01:0x21:  Found a checkpoint file
19:38:48:WU00:FS00:0xa7:Digital signatures verified
19:38:48:WU00:FS00:0xa7:Calling: mdrun -s frame295.tpr -o frame295.trr -cpi state.cpt -cpt 8 -nt 6
19:38:48:WU00:FS00:0xa7:Steps: first=0 total=250000
19:38:49:WU00:FS00:0xa7:Completed 228073 out of 250000 steps (91%)
19:38:49:WU02:FS01:0x21:Completed 7750000 out of 25000000 steps (31%)
19:38:49:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:40:06:FS00:Paused
19:40:06:FS01:Paused
19:40:06:FS00:Shutting core down
19:40:06:FS01:Shutting core down
19:40:06:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 13872
19:40:06:WU00:FS00:0xa7:Exiting, please wait. . .
19:40:06:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 13492
19:40:06:WU02:FS01:0x21:Exiting, please wait. . .
19:40:06:WU02:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
19:40:06:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
19:40:06:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:40:06:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:40:49:Removing old file 'configs/config-20200727-221346.xml'
19:40:49:Saving configuration to config.xml
19:40:49:<config>
19:40:49:  <!-- Folding Core -->
19:40:49:  <checkpoint v='8'/>
19:40:49:  <core-priority v='low'/>
19:40:49:
19:40:49:  <!-- Folding Slot Configuration -->
19:40:49:  <cause v='COVID_19'/>
19:40:49:
19:40:49:  <!-- HTTP Server -->
19:40:49:  <allow v='127.0.0.1 192.168.1.0/24'/>
19:40:49:
19:40:49:  <!-- Network -->
19:40:49:  <proxy v=':8080'/>
19:40:49:
19:40:49:  <!-- Remote Command Server -->
19:40:49:  <password v='*****'/>
19:40:49:
19:40:49:  <!-- Slot Control -->
19:40:49:  <pause-on-battery v='false'/>
19:40:49:
19:40:49:  <!-- User Information -->
19:40:49:  <passkey v='*****'/>
19:40:49:  <team v='223518'/>
19:40:49:  <user v='AlphaOmega888'/>
19:40:49:
19:40:49:  <!-- Folding Slots -->
19:40:49:  <slot id='0' type='CPU'>
19:40:49:    <cpus v='6'/>
19:40:49:    <paused v='true'/>
19:40:49:  </slot>
19:40:49:  <slot id='1' type='GPU'>
19:40:49:    <gpu-index v='0'/>
19:40:49:  </slot>
19:40:49:</config>
20:07:31:FS00:Unpaused
20:07:31:FS01:Unpaused
20:07:31:WU02:FS01:Starting
20:07:31:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-nvidia/21-0.0.20/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:07:31:WU02:FS01:Started FahCore on PID 15316
20:07:31:WU02:FS01:Core PID:13500
20:07:31:WU02:FS01:FahCore 0x21 started
20:07:31:WU00:FS00:Starting
20:07:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -np 6
20:07:31:WU00:FS00:Started FahCore on PID 16876
20:07:31:WU00:FS00:Core PID:14924
20:07:31:WU00:FS00:FahCore 0xa7 started
20:07:31:WU02:FS01:0x21:*********************** Log Started 2020-07-28T20:07:31Z ***********************
20:07:31:WU02:FS01:0x21:Project: 16900 (Run 22, Clone 38, Gen 35)
20:07:31:WU02:FS01:0x21:Unit: 0x0000004d0002894c5ecb32b5c84c993c
20:07:31:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:07:31:WU02:FS01:0x21:Machine: 1
20:07:31:WU02:FS01:0x21:Digital signatures verified
20:07:31:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:07:31:WU02:FS01:0x21:Version 0.0.20
20:07:31:WU02:FS01:0x21:  Found a checkpoint file
20:07:31:WU00:FS00:0xa7:*********************** Log Started 2020-07-28T20:07:31Z ***********************
20:07:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:07:31:WU00:FS00:0xa7:       Type: 0xa7
20:07:31:WU00:FS00:0xa7:       Core: Gromacs
20:07:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16876 -checkpoint 8 -np 6
20:07:31:WU00:FS00:0xa7:************************************ CBang *************************************
20:07:31:WU00:FS00:0xa7:       Date: Nov 27 2019
20:07:31:WU00:FS00:0xa7:       Time: 03:40:09
20:07:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:07:31:WU00:FS00:0xa7:     Branch: master
20:07:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:07:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:07:31:WU00:FS00:0xa7:   Platform: win32 10
20:07:31:WU00:FS00:0xa7:       Bits: 64
20:07:31:WU00:FS00:0xa7:       Mode: Release
20:07:31:WU00:FS00:0xa7:************************************ System ************************************
20:07:31:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
20:07:31:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:07:31:WU00:FS00:0xa7:       CPUs: 12
20:07:31:WU00:FS00:0xa7:     Memory: 15.93GiB
20:07:31:WU00:FS00:0xa7:Free Memory: 13.31GiB
20:07:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:07:32:WU00:FS00:0xa7: OS Version: 6.2
20:07:32:WU00:FS00:0xa7:Has Battery: false
20:07:32:WU00:FS00:0xa7: On Battery: false
20:07:32:WU00:FS00:0xa7: UTC Offset: -4
20:07:32:WU00:FS00:0xa7:        PID: 14924
20:07:32:WU00:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:07:32:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:07:32:WU00:FS00:0xa7:    Version: 0.0.19
20:07:32:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:07:32:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:07:32:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:07:32:WU00:FS00:0xa7:       Date: Nov 25 2019
20:07:32:WU00:FS00:0xa7:       Time: 17:12:41
20:07:32:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:07:32:WU00:FS00:0xa7:     Branch: master
20:07:32:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:07:32:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:07:32:WU00:FS00:0xa7:   Platform: win32 10
20:07:32:WU00:FS00:0xa7:       Bits: 64
20:07:32:WU00:FS00:0xa7:       Mode: Release
20:07:32:WU00:FS00:0xa7:************************************ Build *************************************
20:07:32:WU00:FS00:0xa7:       SIMD: avx_256
20:07:32:WU00:FS00:0xa7:********************************************************************************
20:07:32:WU00:FS00:0xa7:Project: 14379 (Run 1380, Clone 1, Gen 295)
20:07:32:WU00:FS00:0xa7:Unit: 0x00000152455e42075e933059e9f9e6fc
20:07:32:WU00:FS00:0xa7:Digital signatures verified
20:07:32:WU00:FS00:0xa7:Calling: mdrun -s frame295.tpr -o frame295.trr -cpi state.cpt -cpt 8 -nt 6
20:07:32:WU00:FS00:0xa7:Steps: first=0 total=250000
20:07:32:WU00:FS00:0xa7:Completed 229704 out of 250000 steps (91%)
20:07:33:WU02:FS01:0x21:Completed 7750000 out of 25000000 steps (31%)
20:07:33:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:07:45:Removing old file 'configs/config-20200727-221404.xml'
20:07:45:Saving configuration to config.xml
20:07:45:<config>
20:07:45:  <!-- Folding Core -->
20:07:45:  <checkpoint v='8'/>
20:07:45:  <core-priority v='low'/>
20:07:45:
20:07:45:  <!-- Folding Slot Configuration -->
20:07:45:  <cause v='COVID_19'/>
20:07:45:
20:07:45:  <!-- HTTP Server -->
20:07:45:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:07:45:
20:07:45:  <!-- Network -->
20:07:45:  <proxy v=':8080'/>
20:07:45:
20:07:45:  <!-- Remote Command Server -->
20:07:45:  <password v='*****'/>
20:07:45:
20:07:45:  <!-- Slot Control -->
20:07:45:  <pause-on-battery v='false'/>
20:07:45:  <power v='full'/>
20:07:45:
20:07:45:  <!-- User Information -->
20:07:45:  <passkey v='*****'/>
20:07:45:  <team v='223518'/>
20:07:45:  <user v='AlphaOmega888'/>
20:07:45:
20:07:45:  <!-- Folding Slots -->
20:07:45:  <slot id='0' type='CPU'>
20:07:45:    <cpus v='12'/>
20:07:45:    <paused v='True'/>
20:07:45:  </slot>
20:07:45:  <slot id='1' type='GPU'>
20:07:45:    <gpu-index v='0'/>
20:07:45:  </slot>
20:07:45:</config>
20:07:45:FS00:Shutting core down
20:07:45:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 14924
20:07:45:WU00:FS00:0xa7:Exiting, please wait. . .
20:07:46:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:07:46:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:08:16:Removing old file 'configs/config-20200727-221422.xml'
20:08:16:Saving configuration to config.xml
20:08:16:<config>
20:08:16:  <!-- Folding Core -->
20:08:16:  <checkpoint v='8'/>
20:08:16:  <core-priority v='low'/>
20:08:16:
20:08:16:  <!-- Folding Slot Configuration -->
20:08:16:  <cause v='COVID_19'/>
20:08:16:
20:08:16:  <!-- HTTP Server -->
20:08:16:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:08:16:
20:08:16:  <!-- Network -->
20:08:16:  <proxy v=':8080'/>
20:08:16:
20:08:16:  <!-- Remote Command Server -->
20:08:16:  <password v='*****'/>
20:08:16:
20:08:16:  <!-- Slot Control -->
20:08:16:  <pause-on-battery v='false'/>
20:08:16:  <power v='full'/>
20:08:16:
20:08:16:  <!-- User Information -->
20:08:16:  <passkey v='*****'/>
20:08:16:  <team v='223518'/>
20:08:16:  <user v='AlphaOmega888'/>
20:08:16:
20:08:16:  <!-- Folding Slots -->
20:08:16:  <slot id='0' type='CPU'>
20:08:16:    <cpus v='12'/>
20:08:16:    <paused v='True'/>
20:08:16:  </slot>
20:08:16:  <slot id='1' type='GPU'>
20:08:16:    <gpu-index v='0'/>
20:08:16:  </slot>
20:08:16:</config>
20:08:30:Removing old file 'configs/config-20200727-221523.xml'
20:08:30:Saving configuration to config.xml
20:08:30:<config>
20:08:30:  <!-- Folding Core -->
20:08:30:  <checkpoint v='8'/>
20:08:30:  <core-priority v='low'/>
20:08:30:
20:08:30:  <!-- Folding Slot Configuration -->
20:08:30:  <cause v='COVID_19'/>
20:08:30:
20:08:30:  <!-- HTTP Server -->
20:08:30:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:08:30:
20:08:30:  <!-- Network -->
20:08:30:  <proxy v=':8080'/>
20:08:30:
20:08:30:  <!-- Remote Command Server -->
20:08:30:  <password v='*****'/>
20:08:30:
20:08:30:  <!-- Slot Control -->
20:08:30:  <pause-on-battery v='false'/>
20:08:30:  <power v='full'/>
20:08:30:
20:08:30:  <!-- User Information -->
20:08:30:  <passkey v='*****'/>
20:08:30:  <team v='223518'/>
20:08:30:  <user v='AlphaOmega888'/>
20:08:30:
20:08:30:  <!-- Folding Slots -->
20:08:30:  <slot id='0' type='CPU'>
20:08:30:    <paused v='True'/>
20:08:30:  </slot>
20:08:30:  <slot id='1' type='GPU'>
20:08:30:    <gpu-index v='0'/>
20:08:30:  </slot>
20:08:30:</config>
20:08:31:WU00:FS00:Starting
20:08:31:WARNING:WU00:FS00:Changed SMP threads from 6 to 11 this can cause some work units to fail
20:08:31:WARNING:WU00:FS00:AS lowered CPUs from 11 to 6
20:08:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -np 6
20:08:31:WU00:FS00:Started FahCore on PID 16248
20:08:31:WU00:FS00:Core PID:3952
20:08:31:WU00:FS00:FahCore 0xa7 started
20:08:32:WU00:FS00:0xa7:*********************** Log Started 2020-07-28T20:08:31Z ***********************
20:08:32:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:08:32:WU00:FS00:0xa7:       Type: 0xa7
20:08:32:WU00:FS00:0xa7:       Core: Gromacs
20:08:32:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16248 -checkpoint 8 -np 6
20:08:32:WU00:FS00:0xa7:************************************ CBang *************************************
20:08:32:WU00:FS00:0xa7:       Date: Nov 27 2019
20:08:32:WU00:FS00:0xa7:       Time: 03:40:09
20:08:32:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:08:32:WU00:FS00:0xa7:     Branch: master
20:08:32:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:08:32:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:08:32:WU00:FS00:0xa7:   Platform: win32 10
20:08:32:WU00:FS00:0xa7:       Bits: 64
20:08:32:WU00:FS00:0xa7:       Mode: Release
20:08:32:WU00:FS00:0xa7:************************************ System ************************************
20:08:32:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
20:08:32:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:08:32:WU00:FS00:0xa7:       CPUs: 12
20:08:32:WU00:FS00:0xa7:     Memory: 15.93GiB
20:08:32:WU00:FS00:0xa7:Free Memory: 13.15GiB
20:08:32:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:08:32:WU00:FS00:0xa7: OS Version: 6.2
20:08:32:WU00:FS00:0xa7:Has Battery: false
20:08:32:WU00:FS00:0xa7: On Battery: false
20:08:32:WU00:FS00:0xa7: UTC Offset: -4
20:08:32:WU00:FS00:0xa7:        PID: 3952
20:08:32:WU00:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:08:32:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:08:32:WU00:FS00:0xa7:    Version: 0.0.19
20:08:32:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:08:32:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:08:32:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:08:32:WU00:FS00:0xa7:       Date: Nov 25 2019
20:08:32:WU00:FS00:0xa7:       Time: 17:12:41
20:08:32:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:08:32:WU00:FS00:0xa7:************************************ Build *************************************
20:08:32:WU00:FS00:0xa7:       SIMD: avx_256
20:08:32:WU00:FS00:0xa7:********************************************************************************
20:08:32:WU00:FS00:0xa7:Project: 14379 (Run 1380, Clone 1, Gen 295)
20:08:32:WU00:FS00:0xa7:Unit: 0x00000152455e42075e933059e9f9e6fc
20:08:32:WU00:FS00:0xa7:Digital signatures verified
20:08:32:WU00:FS00:0xa7:Calling: mdrun -s frame295.tpr -o frame295.trr -cpi state.cpt -cpt 8 -nt 6
20:08:32:WU00:FS00:0xa7:Steps: first=0 total=250000
20:08:32:WU00:FS00:0xa7:Completed 229982 out of 250000 steps (91%)
20:08:33:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
20:09:17:Removing old file 'configs/config-20200727-223240.xml'
20:09:17:Saving configuration to config.xml
20:09:17:<config>
20:09:17:  <!-- Folding Core -->
20:09:17:  <checkpoint v='8'/>
20:09:17:  <core-priority v='low'/>
20:09:17:
20:09:17:  <!-- Folding Slot Configuration -->
20:09:17:  <cause v='COVID_19'/>
20:09:17:
20:09:17:  <!-- HTTP Server -->
20:09:17:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:09:17:
20:09:17:  <!-- Network -->
20:09:17:  <proxy v=':8080'/>
20:09:17:
20:09:17:  <!-- Remote Command Server -->
20:09:17:  <password v='*****'/>
20:09:17:
20:09:17:  <!-- Slot Control -->
20:09:17:  <pause-on-battery v='false'/>
20:09:17:  <power v='full'/>
20:09:17:
20:09:17:  <!-- User Information -->
20:09:17:  <passkey v='*****'/>
20:09:17:  <team v='223518'/>
20:09:17:  <user v='AlphaOmega888'/>
20:09:17:
20:09:17:  <!-- Folding Slots -->
20:09:17:  <slot id='0' type='CPU'>
20:09:17:    <paused v='True'/>
20:09:17:  </slot>
20:09:17:  <slot id='1' type='GPU'>
20:09:17:    <gpu-index v='0'/>
20:09:17:  </slot>
20:09:17:</config>
20:10:25:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
20:11:20:Removing old file 'configs/config-20200727-224021.xml'
20:11:20:Saving configuration to config.xml
20:11:20:<config>
20:11:20:  <!-- Folding Core -->
20:11:20:  <checkpoint v='8'/>
20:11:20:  <core-priority v='low'/>
20:11:20:
20:11:20:  <!-- Folding Slot Configuration -->
20:11:20:  <cause v='COVID_19'/>
20:11:20:
20:11:20:  <!-- HTTP Server -->
20:11:20:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:11:20:
20:11:20:  <!-- Network -->
20:11:20:  <proxy v=':8080'/>
20:11:20:
20:11:20:  <!-- Remote Command Server -->
20:11:20:  <password v='*****'/>
20:11:20:
20:11:20:  <!-- Slot Control -->
20:11:20:  <pause-on-battery v='false'/>
20:11:20:  <power v='full'/>
20:11:20:
20:11:20:  <!-- User Information -->
20:11:20:  <passkey v='*****'/>
20:11:20:  <team v='223518'/>
20:11:20:  <user v='AlphaOmega888'/>
20:11:20:
20:11:20:  <!-- Folding Slots -->
20:11:20:  <slot id='0' type='CPU'>
20:11:20:    <cpus v='10'/>
20:11:20:    <paused v='True'/>
20:11:20:  </slot>
20:11:20:  <slot id='1' type='GPU'>
20:11:20:    <gpu-index v='0'/>
20:11:20:  </slot>
20:11:20:</config>
20:11:20:FS00:Shutting core down
20:11:20:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 3952
20:11:20:WU00:FS00:0xa7:Exiting, please wait. . .
20:11:21:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:11:21:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:11:21:WU00:FS00:Starting
20:11:21:WARNING:WU00:FS00:Changed SMP threads from 11 to 10 this can cause some work units to fail
20:11:21:WARNING:WU00:FS00:AS lowered CPUs from 10 to 6
20:11:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 8 -np 6
20:11:21:WU00:FS00:Started FahCore on PID 17012
20:11:21:WU00:FS00:Core PID:9008
20:11:21:WU00:FS00:FahCore 0xa7 started
20:11:22:WU00:FS00:0xa7:*********************** Log Started 2020-07-28T20:11:21Z ***********************
20:11:22:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:11:22:WU00:FS00:0xa7:       Type: 0xa7
20:11:22:WU00:FS00:0xa7:       Core: Gromacs
20:11:22:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17012 -checkpoint 8 -np 6
20:11:22:WU00:FS00:0xa7:************************************ CBang *************************************
20:11:22:WU00:FS00:0xa7:       Date: Nov 27 2019
20:11:22:WU00:FS00:0xa7:       Time: 03:40:09
20:11:22:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
20:11:22:WU00:FS00:0xa7:     Branch: master
20:11:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:11:22:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:11:22:WU00:FS00:0xa7:   Platform: win32 10
20:11:22:WU00:FS00:0xa7:       Bits: 64
20:11:22:WU00:FS00:0xa7:       Mode: Release
20:11:22:WU00:FS00:0xa7:************************************ System ************************************
20:11:22:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
20:11:22:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:11:22:WU00:FS00:0xa7:       CPUs: 12
20:11:22:WU00:FS00:0xa7:     Memory: 15.93GiB
20:11:22:WU00:FS00:0xa7:Free Memory: 13.21GiB
20:11:22:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:11:22:WU00:FS00:0xa7: OS Version: 6.2
20:11:22:WU00:FS00:0xa7:Has Battery: false
20:11:22:WU00:FS00:0xa7: On Battery: false
20:11:22:WU00:FS00:0xa7: UTC Offset: -4
20:11:22:WU00:FS00:0xa7:        PID: 9008
20:11:22:WU00:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:11:22:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:11:22:WU00:FS00:0xa7:    Version: 0.0.19
20:11:22:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:11:22:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:11:22:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:11:22:WU00:FS00:0xa7:       Date: Nov 25 2019
20:11:22:WU00:FS00:0xa7:       Time: 17:12:41
20:11:22:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
20:11:22:WU00:FS00:0xa7:************************************ Build *************************************
20:11:22:WU00:FS00:0xa7:       SIMD: avx_256
20:11:22:WU00:FS00:0xa7:********************************************************************************
20:11:22:WU00:FS00:0xa7:Project: 14379 (Run 1380, Clone 1, Gen 295)
20:11:22:WU00:FS00:0xa7:Unit: 0x00000152455e42075e933059e9f9e6fc
20:11:22:WU00:FS00:0xa7:Digital signatures verified
20:11:22:WU00:FS00:0xa7:Calling: mdrun -s frame295.tpr -o frame295.trr -cpi state.cpt -cpt 8 -nt 6
20:11:22:WU00:FS00:0xa7:Steps: first=0 total=250000
20:11:22:WU00:FS00:0xa7:Completed 233744 out of 250000 steps (93%)
20:12:17:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
20:12:20:Removing old file 'configs/config-20200727-224048.xml'
20:12:20:Saving configuration to config.xml
20:12:20:<config>
20:12:20:  <!-- Folding Core -->
20:12:20:  <checkpoint v='8'/>
20:12:20:  <core-priority v='low'/>
20:12:20:
20:12:20:  <!-- Folding Slot Configuration -->
20:12:20:  <cause v='COVID_19'/>
20:12:20:
20:12:20:  <!-- HTTP Server -->
20:12:20:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:12:20:
20:12:20:  <!-- Network -->
20:12:20:  <proxy v=':8080'/>
20:12:20:
20:12:20:  <!-- Remote Command Server -->
20:12:20:  <password v='*****'/>
20:12:20:
20:12:20:  <!-- Slot Control -->
20:12:20:  <pause-on-battery v='false'/>
20:12:20:  <power v='full'/>
20:12:20:
20:12:20:  <!-- User Information -->
20:12:20:  <passkey v='*****'/>
20:12:20:  <team v='223518'/>
20:12:20:  <user v='AlphaOmega888'/>
20:12:20:
20:12:20:  <!-- Folding Slots -->
20:12:20:  <slot id='0' type='CPU'>
20:12:20:    <cpus v='10'/>
20:12:20:    <paused v='True'/>
20:12:20:  </slot>
20:12:20:  <slot id='1' type='GPU'>
20:12:20:    <gpu-index v='0'/>
20:12:20:  </slot>
20:12:20:</config>
20:14:09:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
20:14:37:WU02:FS01:0x21:Completed 8000000 out of 25000000 steps (32%)
20:16:01:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
20:17:57:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
20:19:53:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
20:21:45:WU02:FS01:0x21:Completed 8250000 out of 25000000 steps (33%)
20:21:49:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
20:21:50:WU01:FS00:Connecting to assign1.foldingathome.org:80
20:21:51:WU01:FS00:Assigned to work server 168.245.198.125
20:21:51:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 168.245.198.125
20:21:51:WU01:FS00:Connecting to 168.245.198.125:8080
20:21:51:WU01:FS00:Downloading 2.85MiB
20:21:53:WU01:FS00:Download complete
20:21:53:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16411 run:2580 clone:3 gen:116 core:0xa7 unit:0x0000007ea8f5c67d5e8773a456c65da4
20:22:04:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
JohnChodera
Pande Group Member
Re: GPU keeps restarting to 0%
Post by JohnChodera »
Weird! I don't know why you are still getting core 0x21 jobs. Can you delete your work/ directory (or dump your work unit) and try again? We should be serving core 0x22 jobs for the GPU now.
~ john Chodera // MSKCC
aetch
Post by aetch »
He's running project 16900 which is for cancer and runs on core 0x21.
AlphaOmega888
JohnChodera wrote:Weird! I don't know why you are still getting core 0x21 jobs. Can you delete your work/ directory (or dump your work unit) and try again? We should be serving core 0x22 jobs for the GPU now.
I tried this and it seems to have worked so far, will update if anything new happens.
AlphaOmega888
Right after I sent that lost post, I noticed that it had failed once between my posts and I didn't notice, I’m not sure if this is related or if this is a different problem entirely.
Here's the log:
*********************** Log Started 2020-07-29T01:23:20Z ***********************
01:23:20:Trying to access database...
01:23:20:Successfully acquired database lock
01:23:20:Read GPUs.txt
01:23:21:Enabled folding slot 00: PAUSED cpu:8 (by user)
01:23:21:****************************** FAHClient ******************************
01:23:21:        Version: 7.6.13
01:23:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:23:21:      Copyright: 2020 foldingathome.org
01:23:21:       Homepage: https://foldingathome.org/
01:23:21:           Date: Apr 27 2020
01:23:21:           Time: 21:21:01
01:23:21:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
01:23:21:         Branch: master
01:23:21:       Compiler: Visual C++ 2008
01:23:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:23:21:       Platform: win32 10
01:23:21:           Bits: 32
01:23:21:           Mode: Release
01:23:21:         Config: C:\Users\User\AppData\Roaming\FAHClient\config.xml
01:23:21:******************************** CBang ********************************
01:23:21:           Date: Apr 24 2020
01:23:21:           Time: 17:07:55
01:23:21:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
01:23:21:           Bits: 32
01:23:21:******************************* System ********************************
01:23:21:            CPU: AMD Ryzen 5 1600 Six-Core Processor
01:23:21:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:23:21:           CPUs: 12
01:23:21:         Memory: 15.93GiB
01:23:21:    Free Memory: 12.39GiB
01:23:21:        Threads: WINDOWS_THREADS
01:23:21:     OS Version: 6.2
01:23:21:    Has Battery: false
01:23:21:     On Battery: false
01:23:21:     UTC Offset: -4
01:23:21:            PID: 12656
01:23:21:            CWD: C:\Users\User\AppData\Roaming\FAHClient
01:23:21:  Win32 Service: false
01:23:21:             OS: Windows 10 Home
01:23:21:        OS Arch: AMD64
01:23:21:           GPUs: 1
01:23:21:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
01:23:21:  CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:11.0
01:23:21:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:451.67
01:23:21:******************************* libFAH ********************************
01:23:21:           Date: Apr 15 2020
01:23:21:           Time: 14:53:14
01:23:21:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
01:23:21:           Bits: 32
01:23:21:***********************************************************************
01:23:21:<config>
01:23:21:  <!-- Folding Core -->
01:23:21:  <checkpoint v='8'/>
01:23:21:  <core-priority v='low'/>
01:23:21:
01:23:21:  <!-- Folding Slot Configuration -->
01:23:21:  <cause v='COVID_19'/>
01:23:21:
01:23:21:  <!-- HTTP Server -->
01:23:21:  <allow v='127.0.0.1 192.168.1.0/24'/>
01:23:21:
01:23:21:  <!-- Network -->
01:23:21:  <proxy v=':8080'/>
01:23:21:
01:23:21:  <!-- Remote Command Server -->
01:23:21:  <password v='*****'/>
01:23:21:
01:23:21:  <!-- Slot Control -->
01:23:21:  <pause-on-battery v='false'/>
01:23:21:  <power v='full'/>
01:23:21:
01:23:21:  <!-- User Information -->
01:23:21:  <passkey v='*****'/>
01:23:21:  <team v='223518'/>
01:23:21:  <user v='AlphaOmega888'/>
01:23:21:
01:23:21:  <!-- Folding Slots -->
01:23:21:  <slot id='0' type='CPU'>
01:23:21:    <cpus v='8'/>
01:23:21:    <paused v='true'/>
01:23:21:  </slot>
01:23:21:</config>
01:23:21:Set client configured
01:23:40:Adding folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138
01:23:40:Removing old file 'configs/config-20200728-200917.xml'
01:23:40:Saving configuration to config.xml
01:23:40:<config>
01:23:40:  <!-- Folding Core -->
01:23:40:  <checkpoint v='8'/>
01:23:40:  <core-priority v='low'/>
01:23:40:
01:23:40:  <!-- Folding Slot Configuration -->
01:23:40:  <cause v='COVID_19'/>
01:23:40:
01:23:40:  <!-- HTTP Server -->
01:23:40:  <allow v='127.0.0.1 192.168.1.0/24'/>
01:23:40:
01:23:40:  <!-- Network -->
01:23:40:  <proxy v=':8080'/>
01:23:40:
01:23:40:  <!-- Remote Command Server -->
01:23:40:  <password v='*****'/>
01:23:40:
01:23:40:  <!-- Slot Control -->
01:23:40:  <pause-on-battery v='false'/>
01:23:40:  <power v='full'/>
01:23:40:
01:23:40:  <!-- User Information -->
01:23:40:  <passkey v='*****'/>
01:23:40:  <team v='223518'/>
01:23:40:  <user v='AlphaOmega888'/>
01:23:40:
01:23:40:  <!-- Folding Slots -->
01:23:40:  <slot id='0' type='CPU'>
01:23:40:    <cpus v='8'/>
01:23:40:    <paused v='true'/>
01:23:40:  </slot>
01:23:40:  <slot id='1' type='GPU'/>
01:23:40:</config>
01:23:40:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:23:41:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:23:41:WU00:FS01:Assigned to work server 128.252.203.10
01:23:41:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 from 128.252.203.10
01:23:41:WU00:FS01:Connecting to 128.252.203.10:8080
01:23:42:FS00:Unpaused
01:23:42:WU01:FS00:Connecting to assign1.foldingathome.org:80
01:23:42:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:23:42:WU01:FS00:Connecting to assign2.foldingathome.org:80
01:23:43:WU01:FS00:Assigned to work server 168.245.198.125
01:23:43:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 168.245.198.125
01:23:43:WU01:FS00:Connecting to 168.245.198.125:8080
01:23:43:ERROR:WU01:FS00:Exception: Server did not assign work unit
01:23:43:WU01:FS00:Connecting to assign1.foldingathome.org:80
01:23:43:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:23:43:WU01:FS00:Connecting to assign2.foldingathome.org:80
01:23:43:WU00:FS01:Downloading 5.80MiB
01:23:44:WU01:FS00:Assigned to work server 168.245.198.125
01:23:44:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 168.245.198.125
01:23:44:WU01:FS00:Connecting to 168.245.198.125:8080
01:23:44:WU01:FS00:Downloading 7.75MiB
01:23:46:WU00:FS01:Download complete
01:23:46:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11761 run:0 clone:13351 gen:24 core:0x22 unit:0x0000003480fccb0a5e7114037c44d3d8
01:23:46:WU00:FS01:Starting
01:23:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:23:46:WU00:FS01:Started FahCore on PID 6904
01:23:46:WU00:FS01:Core PID:9988
01:23:46:WU00:FS01:FahCore 0x22 started
01:23:46:WU00:FS01:0x22:*********************** Log Started 2020-07-29T01:23:46Z ***********************
01:23:46:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:23:46:WU00:FS01:0x22:       Core: Core22
01:23:46:WU00:FS01:0x22:       Type: 0x22
01:23:46:WU00:FS01:0x22:    Version: 0.0.11
01:23:46:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:23:46:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
01:23:46:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
01:23:46:WU00:FS01:0x22:       Date: Jun 26 2020
01:23:46:WU00:FS01:0x22:       Time: 19:49:16
01:23:46:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:23:46:WU00:FS01:0x22:     Branch: core22-0.0.11
01:23:46:WU00:FS01:0x22:   Compiler: Visual C++ 2015
01:23:46:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:23:46:WU00:FS01:0x22:   Platform: win32 10
01:23:46:WU00:FS01:0x22:       Bits: 64
01:23:46:WU00:FS01:0x22:       Mode: Release
01:23:46:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:23:46:WU00:FS01:0x22:             <peastman@stanford.edu>
01:23:46:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6904 -checkpoint 8
01:23:46:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:23:46:WU00:FS01:0x22:             0 -gpu 0
01:23:46:WU00:FS01:0x22:************************************ libFAH ************************************
01:23:46:WU00:FS01:0x22:       Time: 19:47:12
01:23:46:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:23:46:WU00:FS01:0x22:     Branch: HEAD
01:23:46:WU00:FS01:0x22:************************************ CBang *************************************
01:23:46:WU00:FS01:0x22:       Time: 19:46:11
01:23:46:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:23:46:WU00:FS01:0x22:     Branch: master
01:23:46:WU00:FS01:0x22:************************************ System ************************************
01:23:46:WU00:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:23:46:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:23:46:WU00:FS01:0x22:       CPUs: 12
01:23:46:WU00:FS01:0x22:     Memory: 15.93GiB
01:23:46:WU00:FS01:0x22:Free Memory: 12.26GiB
01:23:46:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
01:23:46:WU00:FS01:0x22: OS Version: 6.2
01:23:46:WU00:FS01:0x22:Has Battery: false
01:23:46:WU00:FS01:0x22: On Battery: false
01:23:46:WU00:FS01:0x22: UTC Offset: -4
01:23:46:WU00:FS01:0x22:        PID: 9988
01:23:46:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:23:46:WU00:FS01:0x22:********************************************************************************
01:23:46:WU00:FS01:0x22:Project: 11761 (Run 0, Clone 13351, Gen 24)
01:23:46:WU00:FS01:0x22:Unit: 0x0000003480fccb0a5e7114037c44d3d8
01:23:46:WU00:FS01:0x22:Reading tar file core.xml
01:23:46:WU00:FS01:0x22:Reading tar file integrator.xml
01:23:46:WU00:FS01:0x22:Reading tar file state.xml
01:23:46:WU00:FS01:0x22:Reading tar file system.xml
01:23:47:WU00:FS01:0x22:Digital signatures verified
01:23:47:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:23:47:WU00:FS01:0x22:Version 0.0.11
01:23:47:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
01:23:47:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
01:23:47:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
01:23:47:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
01:23:50:WU01:FS00:Download 97.57%
01:23:50:WU01:FS00:Download complete
01:23:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16412 run:0 clone:712 gen:117 core:0xa7 unit:0x00000090a8f5c67d5e8231613da0692d
01:23:50:WU01:FS00:Starting
01:23:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -np 8
01:23:50:WU01:FS00:Started FahCore on PID 15532
01:23:50:WU01:FS00:Core PID:15556
01:23:50:WU01:FS00:FahCore 0xa7 started
01:23:50:WU01:FS00:0xa7:*********************** Log Started 2020-07-29T01:23:50Z ***********************
01:23:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:23:50:WU01:FS00:0xa7:       Type: 0xa7
01:23:50:WU01:FS00:0xa7:       Core: Gromacs
01:23:50:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15532 -checkpoint 8 -np 8
01:23:50:WU01:FS00:0xa7:************************************ CBang *************************************
01:23:50:WU01:FS00:0xa7:       Date: Nov 27 2019
01:23:50:WU01:FS00:0xa7:       Time: 03:40:09
01:23:50:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
01:23:50:WU01:FS00:0xa7:     Branch: master
01:23:50:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
01:23:50:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:23:50:WU01:FS00:0xa7:   Platform: win32 10
01:23:50:WU01:FS00:0xa7:       Bits: 64
01:23:50:WU01:FS00:0xa7:       Mode: Release
01:23:50:WU01:FS00:0xa7:************************************ System ************************************
01:23:50:WU01:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:23:50:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:23:50:WU01:FS00:0xa7:       CPUs: 12
01:23:50:WU01:FS00:0xa7:     Memory: 15.93GiB
01:23:50:WU01:FS00:0xa7:Free Memory: 12.08GiB
01:23:50:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
01:23:50:WU01:FS00:0xa7: OS Version: 6.2
01:23:50:WU01:FS00:0xa7:Has Battery: false
01:23:50:WU01:FS00:0xa7: On Battery: false
01:23:50:WU01:FS00:0xa7: UTC Offset: -4
01:23:50:WU01:FS00:0xa7:        PID: 15556
01:23:50:WU01:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:23:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:23:50:WU01:FS00:0xa7:    Version: 0.0.19
01:23:50:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:23:50:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:23:50:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
01:23:50:WU01:FS00:0xa7:       Date: Nov 25 2019
01:23:50:WU01:FS00:0xa7:       Time: 17:12:41
01:23:50:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
01:23:50:WU01:FS00:0xa7:************************************ Build *************************************
01:23:50:WU01:FS00:0xa7:       SIMD: avx_256
01:23:50:WU01:FS00:0xa7:********************************************************************************
01:23:50:WU01:FS00:0xa7:Project: 16412 (Run 0, Clone 712, Gen 117)
01:23:50:WU01:FS00:0xa7:Unit: 0x00000090a8f5c67d5e8231613da0692d
01:23:50:WU01:FS00:0xa7:Reading tar file core.xml
01:23:50:WU01:FS00:0xa7:Reading tar file frame117.tpr
01:23:50:WU01:FS00:0xa7:Digital signatures verified
01:23:50:WU01:FS00:0xa7:Calling: mdrun -s frame117.tpr -o frame117.trr -x frame117.xtc -cpt 8 -nt 8
01:23:50:WU01:FS00:0xa7:Steps: first=29250000 total=250000
01:23:52:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
01:23:53:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
01:24:20:FS00:Paused
01:24:20:FS01:Paused
01:24:20:FS00:Shutting core down
01:24:20:FS01:Shutting core down
01:24:20:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 9988
01:24:20:WU00:FS01:0x22:Exiting, please wait. . .
01:24:20:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
01:24:21:Removing old file 'configs/config-20200728-201120.xml'
01:24:21:Saving configuration to config.xml
01:24:21:<config>
01:24:21:  <!-- Folding Core -->
01:24:21:  <checkpoint v='8'/>
01:24:21:  <core-priority v='low'/>
01:24:21:
01:24:21:  <!-- Folding Slot Configuration -->
01:24:21:  <cause v='COVID_19'/>
01:24:21:
01:24:21:  <!-- HTTP Server -->
01:24:21:  <allow v='127.0.0.1 192.168.1.0/24'/>
01:24:21:
01:24:21:  <!-- Network -->
01:24:21:  <proxy v=':8080'/>
01:24:21:
01:24:21:  <!-- Remote Command Server -->
01:24:21:  <password v='*****'/>
01:24:21:
01:24:21:  <!-- Slot Control -->
01:24:21:  <pause-on-battery v='false'/>
01:24:21:  <power v='full'/>
01:24:21:
01:24:21:  <!-- User Information -->
01:24:21:  <passkey v='*****'/>
01:24:21:  <team v='223518'/>
01:24:21:  <user v='AlphaOmega888'/>
01:24:21:
01:24:21:  <!-- Folding Slots -->
01:24:21:  <slot id='0' type='CPU'>
01:24:21:    <cpus v='8'/>
01:24:21:    <paused v='true'/>
01:24:21:  </slot>
01:24:21:  <slot id='1' type='GPU'>
01:24:21:  </slot>
01:24:21:</config>
01:24:21:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 15556
01:24:21:WU01:FS00:0xa7:Exiting, please wait. . .
01:24:21:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:24:24:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:41:10:FS00:Unpaused
01:41:10:FS01:Unpaused
01:41:10:WU00:FS01:Starting
01:41:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:41:10:WU00:FS01:Started FahCore on PID 11840
01:41:10:WU00:FS01:Core PID:8840
01:41:10:WU00:FS01:FahCore 0x22 started
01:41:10:WU01:FS00:Starting
01:41:10:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -np 8
01:41:10:WU01:FS00:Started FahCore on PID 8728
01:41:10:WU01:FS00:Core PID:1244
01:41:10:WU01:FS00:FahCore 0xa7 started
01:41:11:WU00:FS01:0x22:*********************** Log Started 2020-07-29T01:41:10Z ***********************
01:41:11:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:41:11:WU00:FS01:0x22:       Core: Core22
01:41:11:WU00:FS01:0x22:       Type: 0x22
01:41:11:WU00:FS01:0x22:    Version: 0.0.11
01:41:11:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:41:11:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
01:41:11:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
01:41:11:WU00:FS01:0x22:       Date: Jun 26 2020
01:41:11:WU00:FS01:0x22:       Time: 19:49:16
01:41:11:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:41:11:WU00:FS01:0x22:     Branch: core22-0.0.11
01:41:11:WU00:FS01:0x22:   Compiler: Visual C++ 2015
01:41:11:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:41:11:WU00:FS01:0x22:   Platform: win32 10
01:41:11:WU00:FS01:0x22:       Bits: 64
01:41:11:WU00:FS01:0x22:       Mode: Release
01:41:11:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:41:11:WU00:FS01:0x22:             <peastman@stanford.edu>
01:41:11:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11840 -checkpoint 8
01:41:11:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:41:11:WU00:FS01:0x22:             0 -gpu 0
01:41:11:WU00:FS01:0x22:************************************ libFAH ************************************
01:41:11:WU00:FS01:0x22:       Time: 19:47:12
01:41:11:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:41:11:WU00:FS01:0x22:     Branch: HEAD
01:41:11:WU00:FS01:0x22:************************************ CBang *************************************
01:41:11:WU00:FS01:0x22:       Time: 19:46:11
01:41:11:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:41:11:WU00:FS01:0x22:     Branch: master
01:41:11:WU00:FS01:0x22:************************************ System ************************************
01:41:11:WU00:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:41:11:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:41:11:WU00:FS01:0x22:       CPUs: 12
01:41:11:WU00:FS01:0x22:     Memory: 15.93GiB
01:41:11:WU00:FS01:0x22:Free Memory: 12.05GiB
01:41:11:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
01:41:11:WU00:FS01:0x22: OS Version: 6.2
01:41:11:WU00:FS01:0x22:Has Battery: false
01:41:11:WU00:FS01:0x22: On Battery: false
01:41:11:WU00:FS01:0x22: UTC Offset: -4
01:41:11:WU00:FS01:0x22:        PID: 8840
01:41:11:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:41:11:WU00:FS01:0x22:********************************************************************************
01:41:11:WU00:FS01:0x22:Project: 11761 (Run 0, Clone 13351, Gen 24)
01:41:11:WU00:FS01:0x22:Unit: 0x0000003480fccb0a5e7114037c44d3d8
01:41:11:WU00:FS01:0x22:Digital signatures verified
01:41:11:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:41:11:WU00:FS01:0x22:Version 0.0.11
01:41:11:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
01:41:11:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
01:41:11:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
01:41:11:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
01:41:11:WU01:FS00:0xa7:*********************** Log Started 2020-07-29T01:41:10Z ***********************
01:41:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:41:11:WU01:FS00:0xa7:       Type: 0xa7
01:41:11:WU01:FS00:0xa7:       Core: Gromacs
01:41:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8728 -checkpoint 8 -np 8
01:41:11:WU01:FS00:0xa7:************************************ CBang *************************************
01:41:11:WU01:FS00:0xa7:       Date: Nov 27 2019
01:41:11:WU01:FS00:0xa7:       Time: 03:40:09
01:41:11:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
01:41:11:WU01:FS00:0xa7:     Branch: master
01:41:11:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
01:41:11:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:41:11:WU01:FS00:0xa7:   Platform: win32 10
01:41:11:WU01:FS00:0xa7:       Bits: 64
01:41:11:WU01:FS00:0xa7:       Mode: Release
01:41:11:WU01:FS00:0xa7:************************************ System ************************************
01:41:11:WU01:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:41:11:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:41:11:WU01:FS00:0xa7:       CPUs: 12
01:41:11:WU01:FS00:0xa7:     Memory: 15.93GiB
01:41:11:WU01:FS00:0xa7:Free Memory: 12.03GiB
01:41:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
01:41:11:WU01:FS00:0xa7: OS Version: 6.2
01:41:11:WU01:FS00:0xa7:Has Battery: false
01:41:11:WU01:FS00:0xa7: On Battery: false
01:41:11:WU01:FS00:0xa7: UTC Offset: -4
01:41:11:WU01:FS00:0xa7:        PID: 1244
01:41:11:WU01:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:41:11:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:41:11:WU01:FS00:0xa7:    Version: 0.0.19
01:41:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:41:11:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:41:11:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
01:41:11:WU01:FS00:0xa7:       Date: Nov 25 2019
01:41:11:WU01:FS00:0xa7:       Time: 17:12:41
01:41:11:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
01:41:11:WU01:FS00:0xa7:************************************ Build *************************************
01:41:11:WU01:FS00:0xa7:       SIMD: avx_256
01:41:11:WU01:FS00:0xa7:********************************************************************************
01:41:11:WU01:FS00:0xa7:Project: 16412 (Run 0, Clone 712, Gen 117)
01:41:11:WU01:FS00:0xa7:Unit: 0x00000090a8f5c67d5e8231613da0692d
01:41:11:WU01:FS00:0xa7:Digital signatures verified
01:41:11:WU01:FS00:0xa7:Calling: mdrun -s frame117.tpr -o frame117.trr -x frame117.xtc -cpi state.cpt -cpt 8 -nt 8
01:41:11:WU01:FS00:0xa7:Steps: first=29250000 total=250000
01:41:12:WU01:FS00:0xa7:Completed 282 out of 250000 steps (0%)
01:41:17:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
01:41:38:Removing old file 'configs/config-20200728-201220.xml'
01:41:38:Saving configuration to config.xml
01:41:38:<config>
01:41:38:  <!-- Folding Core -->
01:41:38:  <checkpoint v='8'/>
01:41:38:  <core-priority v='low'/>
01:41:38:
01:41:38:  <!-- Folding Slot Configuration -->
01:41:38:  <cause v='COVID_19'/>
01:41:38:
01:41:38:  <!-- HTTP Server -->
01:41:38:  <allow v='127.0.0.1 192.168.1.0/24'/>
01:41:38:
01:41:38:  <!-- Network -->
01:41:38:  <proxy v=':8080'/>
01:41:38:
01:41:38:  <!-- Remote Command Server -->
01:41:38:  <password v='*****'/>
01:41:38:
01:41:38:  <!-- Slot Control -->
01:41:38:  <pause-on-battery v='false'/>
01:41:38:  <power v='full'/>
01:41:38:
01:41:38:  <!-- User Information -->
01:41:38:  <passkey v='*****'/>
01:41:38:  <team v='223518'/>
01:41:38:  <user v='AlphaOmega888'/>
01:41:38:
01:41:38:  <!-- Folding Slots -->
01:41:38:  <slot id='0' type='CPU'>
01:41:38:    <cpus v='8'/>
01:41:38:  </slot>
01:41:38:  <slot id='1' type='GPU'/>
01:41:38:</config>
01:44:03:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
01:45:11:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
01:46:50:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
01:47:14:WU00:FS01:0x22:An exception occurred at step 42669: Particle coordinate is nan
01:47:14:WU00:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
01:47:14:WU00:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
01:47:14:WARNING:WU00:FS01:FahCore returned: CORE_RESTART (98 = 0x62)
01:47:15:WU00:FS01:Starting
01:47:15:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:47:15:WU00:FS01:Started FahCore on PID 10688
01:47:15:WU00:FS01:Core PID:15256
01:47:15:WU00:FS01:FahCore 0x22 started
01:47:15:WU00:FS01:0x22:*********************** Log Started 2020-07-29T01:47:15Z ***********************
01:47:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:47:15:WU00:FS01:0x22:       Core: Core22
01:47:15:WU00:FS01:0x22:       Type: 0x22
01:47:15:WU00:FS01:0x22:    Version: 0.0.11
01:47:15:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:15:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
01:47:15:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
01:47:15:WU00:FS01:0x22:       Date: Jun 26 2020
01:47:15:WU00:FS01:0x22:       Time: 19:49:16
01:47:15:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:47:15:WU00:FS01:0x22:     Branch: core22-0.0.11
01:47:15:WU00:FS01:0x22:   Compiler: Visual C++ 2015
01:47:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:47:15:WU00:FS01:0x22:   Platform: win32 10
01:47:15:WU00:FS01:0x22:       Bits: 64
01:47:15:WU00:FS01:0x22:       Mode: Release
01:47:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:47:15:WU00:FS01:0x22:             <peastman@stanford.edu>
01:47:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10688 -checkpoint 8
01:47:15:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:47:15:WU00:FS01:0x22:             0 -gpu 0
01:47:15:WU00:FS01:0x22:************************************ libFAH ************************************
01:47:15:WU00:FS01:0x22:       Time: 19:47:12
01:47:15:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:47:15:WU00:FS01:0x22:     Branch: HEAD
01:47:15:WU00:FS01:0x22:************************************ CBang *************************************
01:47:15:WU00:FS01:0x22:       Time: 19:46:11
01:47:15:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:47:15:WU00:FS01:0x22:     Branch: master
01:47:15:WU00:FS01:0x22:************************************ System ************************************
01:47:15:WU00:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:47:15:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:47:15:WU00:FS01:0x22:       CPUs: 12
01:47:15:WU00:FS01:0x22:     Memory: 15.93GiB
01:47:15:WU00:FS01:0x22:Free Memory: 11.79GiB
01:47:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
01:47:15:WU00:FS01:0x22: OS Version: 6.2
01:47:15:WU00:FS01:0x22:Has Battery: false
01:47:15:WU00:FS01:0x22: On Battery: false
01:47:15:WU00:FS01:0x22: UTC Offset: -4
01:47:15:WU00:FS01:0x22:        PID: 15256
01:47:15:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:47:15:WU00:FS01:0x22:********************************************************************************
01:47:15:WU00:FS01:0x22:Project: 11761 (Run 0, Clone 13351, Gen 24)
01:47:15:WU00:FS01:0x22:Unit: 0x0000003480fccb0a5e7114037c44d3d8
01:47:15:WU00:FS01:0x22:Digital signatures verified
01:47:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:47:15:WU00:FS01:0x22:Version 0.0.11
01:47:15:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
01:47:15:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
01:47:15:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
01:47:15:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
01:47:22:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
01:49:33:WU00:FS01:0x22:An exception occurred at step 15310: Particle coordinate is nan
01:49:33:WU00:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
01:49:33:WU00:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
01:49:33:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
01:49:33:WU00:FS01:0x22:Saving result file science.log
01:49:33:WU00:FS01:0x22:Saving result file state.xml
01:49:34:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
01:49:34:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:49:34:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11761 run:0 clone:13351 gen:24 core:0x22 unit:0x0000003480fccb0a5e7114037c44d3d8
01:49:34:WU00:FS01:Uploading 4.95MiB to 128.252.203.10
01:49:34:WU00:FS01:Connecting to 128.252.203.10:8080
01:49:35:WU02:FS01:Connecting to assign1.foldingathome.org:80
01:49:35:WU02:FS01:Assigned to work server 128.252.203.10
01:49:35:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 from 128.252.203.10
01:49:35:WU02:FS01:Connecting to 128.252.203.10:8080
01:49:38:WU00:FS01:Upload complete
01:49:38:WU00:FS01:Server responded WORK_ACK (400)
01:49:38:WU00:FS01:Cleaning up
01:49:42:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
01:49:43:WU02:FS01:Downloading 15.43MiB
01:49:48:WU02:FS01:Download complete
01:49:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11759 run:0 clone:12283 gen:198 core:0x22 unit:0x0000015680fccb0a5e6ebdb27532b298
01:49:48:WU02:FS01:Starting
01:49:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:49:48:WU02:FS01:Started FahCore on PID 15236
01:49:48:WU02:FS01:Core PID:10616
01:49:48:WU02:FS01:FahCore 0x22 started
01:49:48:WU02:FS01:0x22:*********************** Log Started 2020-07-29T01:49:48Z ***********************
01:49:48:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:49:48:WU02:FS01:0x22:       Core: Core22
01:49:48:WU02:FS01:0x22:       Type: 0x22
01:49:48:WU02:FS01:0x22:    Version: 0.0.11
01:49:48:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:49:48:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
01:49:48:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
01:49:48:WU02:FS01:0x22:       Date: Jun 26 2020
01:49:48:WU02:FS01:0x22:       Time: 19:49:16
01:49:48:WU02:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:49:48:WU02:FS01:0x22:     Branch: core22-0.0.11
01:49:48:WU02:FS01:0x22:   Compiler: Visual C++ 2015
01:49:48:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:49:48:WU02:FS01:0x22:   Platform: win32 10
01:49:48:WU02:FS01:0x22:       Bits: 64
01:49:48:WU02:FS01:0x22:       Mode: Release
01:49:48:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:49:48:WU02:FS01:0x22:             <peastman@stanford.edu>
01:49:48:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 15236 -checkpoint 8
01:49:48:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:49:48:WU02:FS01:0x22:             0 -gpu 0
01:49:48:WU02:FS01:0x22:************************************ libFAH ************************************
01:49:48:WU02:FS01:0x22:       Time: 19:47:12
01:49:48:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:49:48:WU02:FS01:0x22:     Branch: HEAD
01:49:48:WU02:FS01:0x22:************************************ CBang *************************************
01:49:48:WU02:FS01:0x22:       Time: 19:46:11
01:49:48:WU02:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:49:48:WU02:FS01:0x22:     Branch: master
01:49:48:WU02:FS01:0x22:************************************ System ************************************
01:49:48:WU02:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:49:48:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:49:48:WU02:FS01:0x22:       CPUs: 12
01:49:48:WU02:FS01:0x22:     Memory: 15.93GiB
01:49:48:WU02:FS01:0x22:Free Memory: 11.82GiB
01:49:48:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
01:49:48:WU02:FS01:0x22: OS Version: 6.2
01:49:48:WU02:FS01:0x22:Has Battery: false
01:49:48:WU02:FS01:0x22: On Battery: false
01:49:48:WU02:FS01:0x22: UTC Offset: -4
01:49:48:WU02:FS01:0x22:        PID: 10616
01:49:48:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:49:48:WU02:FS01:0x22:********************************************************************************
01:49:48:WU02:FS01:0x22:Project: 11759 (Run 0, Clone 12283, Gen 198)
01:49:48:WU02:FS01:0x22:Unit: 0x0000015680fccb0a5e6ebdb27532b298
01:49:48:WU02:FS01:0x22:Reading tar file core.xml
01:49:48:WU02:FS01:0x22:Reading tar file integrator.xml
01:49:48:WU02:FS01:0x22:Reading tar file state.xml
01:49:49:WU02:FS01:0x22:Reading tar file system.xml
01:49:49:WU02:FS01:0x22:Digital signatures verified
01:49:49:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:49:49:WU02:FS01:0x22:Version 0.0.11
01:49:49:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
01:49:49:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
01:49:49:WU02:FS01:0x22:  XTC frame write interval: 50000 steps (5%) [20 total]
01:49:49:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
01:50:08:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
01:51:47:WU02:FS01:0x22:An exception occurred at step 3513: Particle coordinate is nan
01:51:47:WU02:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
01:51:47:WU02:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
01:51:47:WARNING:WU02:FS01:FahCore returned: CORE_RESTART (98 = 0x62)
01:51:47:WU02:FS01:Starting
01:51:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:51:47:WU02:FS01:Started FahCore on PID 3848
01:51:47:WU02:FS01:Core PID:388
01:51:47:WU02:FS01:FahCore 0x22 started
01:51:48:WU02:FS01:0x22:*********************** Log Started 2020-07-29T01:51:47Z ***********************
01:51:48:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:51:48:WU02:FS01:0x22:       Core: Core22
01:51:48:WU02:FS01:0x22:       Type: 0x22
01:51:48:WU02:FS01:0x22:    Version: 0.0.11
01:51:48:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:51:48:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
01:51:48:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
01:51:48:WU02:FS01:0x22:       Date: Jun 26 2020
01:51:48:WU02:FS01:0x22:       Time: 19:49:16
01:51:48:WU02:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:51:48:WU02:FS01:0x22:     Branch: core22-0.0.11
01:51:48:WU02:FS01:0x22:   Compiler: Visual C++ 2015
01:51:48:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:51:48:WU02:FS01:0x22:   Platform: win32 10
01:51:48:WU02:FS01:0x22:       Bits: 64
01:51:48:WU02:FS01:0x22:       Mode: Release
01:51:48:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:51:48:WU02:FS01:0x22:             <peastman@stanford.edu>
01:51:48:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3848 -checkpoint 8
01:51:48:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:51:48:WU02:FS01:0x22:             0 -gpu 0
01:51:48:WU02:FS01:0x22:************************************ libFAH ************************************
01:51:48:WU02:FS01:0x22:       Time: 19:47:12
01:51:48:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:51:48:WU02:FS01:0x22:     Branch: HEAD
01:51:48:WU02:FS01:0x22:************************************ CBang *************************************
01:51:48:WU02:FS01:0x22:       Time: 19:46:11
01:51:48:WU02:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:51:48:WU02:FS01:0x22:     Branch: master
01:51:48:WU02:FS01:0x22:************************************ System ************************************
01:51:48:WU02:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:51:48:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:51:48:WU02:FS01:0x22:       CPUs: 12
01:51:48:WU02:FS01:0x22:     Memory: 15.93GiB
01:51:48:WU02:FS01:0x22:Free Memory: 11.87GiB
01:51:48:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
01:51:48:WU02:FS01:0x22: OS Version: 6.2
01:51:48:WU02:FS01:0x22:Has Battery: false
01:51:48:WU02:FS01:0x22: On Battery: false
01:51:48:WU02:FS01:0x22: UTC Offset: -4
01:51:48:WU02:FS01:0x22:        PID: 388
01:51:48:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:51:48:WU02:FS01:0x22:********************************************************************************
01:51:48:WU02:FS01:0x22:Project: 11759 (Run 0, Clone 12283, Gen 198)
01:51:48:WU02:FS01:0x22:Unit: 0x0000015680fccb0a5e6ebdb27532b298
01:51:48:WU02:FS01:0x22:Digital signatures verified
01:51:48:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:51:48:WU02:FS01:0x22:Version 0.0.11
01:51:48:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
01:51:48:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
01:51:48:WU02:FS01:0x22:  XTC frame write interval: 50000 steps (5%) [20 total]
01:51:48:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
01:52:06:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
01:53:10:WU02:FS01:0x22:An exception occurred at step 2258: Particle coordinate is nan
01:53:10:WU02:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
01:53:10:WU02:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
01:53:10:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
01:53:10:WU02:FS01:0x22:Saving result file science.log
01:53:10:WU02:FS01:0x22:Saving result file state.xml
01:53:13:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
01:53:13:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:53:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11759 run:0 clone:12283 gen:198 core:0x22 unit:0x0000015680fccb0a5e6ebdb27532b298
01:53:13:WU02:FS01:Uploading 13.19MiB to 128.252.203.10
01:53:13:WU02:FS01:Connecting to 128.252.203.10:8080
01:53:13:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:53:14:WU00:FS01:Assigned to work server 18.188.125.154
01:53:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 from 18.188.125.154
01:53:14:WU00:FS01:Connecting to 18.188.125.154:8080
01:53:14:WU00:FS01:Downloading 7.03MiB
01:53:19:WU02:FS01:Upload 39.80%
01:53:19:WU00:FS01:Download complete
01:53:19:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13420 run:4640 clone:19 gen:0 core:0x22 unit:0x0000000112bc7d9a5f20707304994a6b
01:53:19:WU00:FS01:Starting
01:53:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12656 -checkpoint 8 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:53:19:WU00:FS01:Started FahCore on PID 8436
01:53:19:WU00:FS01:Core PID:7116
01:53:19:WU00:FS01:FahCore 0x22 started
01:53:20:WU00:FS01:0x22:*********************** Log Started 2020-07-29T01:53:19Z ***********************
01:53:20:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:53:20:WU00:FS01:0x22:       Core: Core22
01:53:20:WU00:FS01:0x22:       Type: 0x22
01:53:20:WU00:FS01:0x22:    Version: 0.0.11
01:53:20:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:53:20:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
01:53:20:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
01:53:20:WU00:FS01:0x22:       Date: Jun 26 2020
01:53:20:WU00:FS01:0x22:       Time: 19:49:16
01:53:20:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
01:53:20:WU00:FS01:0x22:     Branch: core22-0.0.11
01:53:20:WU00:FS01:0x22:   Compiler: Visual C++ 2015
01:53:20:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:53:20:WU00:FS01:0x22:   Platform: win32 10
01:53:20:WU00:FS01:0x22:       Bits: 64
01:53:20:WU00:FS01:0x22:       Mode: Release
01:53:20:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:53:20:WU00:FS01:0x22:             <peastman@stanford.edu>
01:53:20:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8436 -checkpoint 8
01:53:20:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:53:20:WU00:FS01:0x22:             0 -gpu 0
01:53:20:WU00:FS01:0x22:************************************ libFAH ************************************
01:53:20:WU00:FS01:0x22:       Time: 19:47:12
01:53:20:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
01:53:20:WU00:FS01:0x22:     Branch: HEAD
01:53:20:WU00:FS01:0x22:************************************ CBang *************************************
01:53:20:WU00:FS01:0x22:       Time: 19:46:11
01:53:20:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
01:53:20:WU00:FS01:0x22:     Branch: master
01:53:20:WU00:FS01:0x22:************************************ System ************************************
01:53:20:WU00:FS01:0x22:        CPU: AMD Ryzen 5 1600 Six-Core Processor
01:53:20:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:53:20:WU00:FS01:0x22:       CPUs: 12
01:53:20:WU00:FS01:0x22:     Memory: 15.93GiB
01:53:20:WU00:FS01:0x22:Free Memory: 11.75GiB
01:53:20:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
01:53:20:WU00:FS01:0x22: OS Version: 6.2
01:53:20:WU00:FS01:0x22:Has Battery: false
01:53:20:WU00:FS01:0x22: On Battery: false
01:53:20:WU00:FS01:0x22: UTC Offset: -4
01:53:20:WU00:FS01:0x22:        PID: 7116
01:53:20:WU00:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
01:53:20:WU00:FS01:0x22:********************************************************************************
01:53:20:WU00:FS01:0x22:Project: 13420 (Run 4640, Clone 19, Gen 0)
01:53:20:WU00:FS01:0x22:Unit: 0x0000000112bc7d9a5f20707304994a6b
01:53:20:WU00:FS01:0x22:Reading tar file core.xml
01:53:20:WU00:FS01:0x22:Reading tar file integrator.xml
01:53:20:WU00:FS01:0x22:Reading tar file state.xml.bz2
01:53:20:WU00:FS01:0x22:Reading tar file system.xml.bz2
01:53:20:WU00:FS01:0x22:Digital signatures verified
01:53:20:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:53:20:WU00:FS01:0x22:Version 0.0.11
01:53:20:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
01:53:20:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
01:53:20:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
01:53:20:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
01:53:24:WU02:FS01:Upload complete
01:53:24:WU02:FS01:Server responded WORK_ACK (400)
01:53:24:WU02:FS01:Cleaning up
01:53:40:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
01:54:12:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
Al I see from the log for the Project 16900 WU after skimming through it is that you kept pausing the client. The GPU WU is going to start at the beginning or if it gets to a chcheckpoint, the last one. Checkpointing for GPU WUs is set by the researcher, and usually is between 2 and 5% of progress.
When the WU restarts it can take a bit to read the checkpoint, and then process enough to detect and report the current progress. There is just the one error at the end of the posted section of the log, no indication of the restart and what happened after.
As for overclocking, it is not officially supported. An overclock might be stable in a game, but not stable for the calculations used for F@h. This includes factory overclocks above the reference values for the GPU chipset. In practice some overclock is usually okay, but you may need to experiment a bit to find what works for your specific GPU.
gunnarre
Post by gunnarre »
It does indeed look like your system (likely the GPU) is unstable - the core is crashing at different steps in the work units which suggests some randomness to the error. Of course, some programming errors also manifest semi-randomly, like memory leaks, but this looks like a hardware error. I would look at clocking the GPU down to reference speeds.
AlphaOmega888
Hardware configuration: CPU: AMD Ryzen 5 1600 Six-Core Processor
GPU: GeForce GTX 1050 Ti
Post by AlphaOmega888 »
I changed the GPU clock back to the reference speed and it worked. It's also running 2 to 4 times faster than the 1 time it did finish while overclocked, so that's a nice bonus. It appears that folding at home really doesn't work with overclocked GPUs. Also, I noticed that my GPU is doing cancer projects instead covid-19 projects even though my cause preference is set to covid-19 in the configure menu under advanced. Is this normal or is not the right way to choose which cause I prefer to work on?
There could have been a temporary shortage of COVID-19 related WUs at the time your work request went in. The setting is a preference, so the server will first try to assign based on that and then picks the next highest priority assignment if something is not available right away. There are two main considerations at assignment time, available WUs and available network connections to the servers with those WUs.
The next WU you get does have a higher chance of being COVID-19, the current batch of COVID-19 related GPU projects were just rolled out to the servers.
There have been brief periods when there were no COVID19 assignments to distribute. FAH will assign a WU from your preferred cause if it can, but it's considered a preference, not an absolute requirement. If you happened to request a new assignment during one of those brief periods (yes, they really are very brief) FAH will assign you something else rather than make you wait.
(It's better to help cure cancer than to refuse an assignment.) There are plenty of COVID projects now so when you finish this WU it is EXTREMELY likely that you'll get a COVID assignment.
JohnChodera is responsible for many COVID projects, but he still shouldn't have suggested that you should dump a partially completed WU. Finish it an move on now that you have a stable GPU.
