AMD Cayman [FirePro V5900 (FireGL V)]
bt99
Post by bt99 »
Not sure this is the right place for this.
Trying to get an AMD FirePro V5900 (FireGL V) to fold, but I keep getting:
20:05:16:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cayman [FirePro V5900 (FireGL V)] from 192.0.2.1
20:05:16:WU00:FS01:Connecting to 192.0.2.1:8080
20:05:37:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
It seems to be supported and in the GPUS.txt:
0x1002:0x6707:1:5:Cayman [FirePro V5900 (FireGL V)]
system info:
20:05:02:******************************* System ********************************
20:05:02:            CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
20:05:02:         CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
20:05:02:           CPUs: 12
20:05:02:         Memory: 32.00GiB
20:05:02:    Free Memory: 29.85GiB
20:05:02:        Threads: WINDOWS_THREADS
20:05:02:     OS Version: 6.2
20:05:02:    Has Battery: false
20:05:02:     On Battery: false
20:05:02:     UTC Offset: -6
20:05:02:            PID: 9080
20:05:02:            CWD: C:\Users\christopher\AppData\Roaming\FAHClient
20:05:02:  Win32 Service: false
20:05:02:             OS: Windows 10 Enterprise
20:05:02:        OS Arch: AMD64
20:05:02:           GPUs: 1
20:05:02:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1 Cayman [FirePro V5900 (FireGL V)]
20:05:02:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:05:02:                 specified module could not be found.
20:05:02:
20:05:02:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:1800.12
Re: AMD Cayman [FirePro V5900 (FireGL V)]
The current version of the GPUs.txt file has this entry:
0x1002:0x6707:1:1:Cayman [FirePro V5900 (FireGL V)]
They are part way through redoing the species numbering for AMD GPUs to make them more performance based than generational. Some issues have arisen, will pass on your report.
Welcome to Folding@home!
https://www.techpowerup.com/gpu-specs/f ... v5900.c577
This should (very slowly) fold. It does 64 bit (Double Precision) floating point math and supports OpenCL 1.2, the minimum requirements for F@H GPU folding.
It is 9 years old and (depending on how you count) three AMD generations back. With only 512 cores it would not be fast even if new. (80% as fast as a GT 1030?)
The newest driver I can find is from 2017 https://www.amd.com/en/support/professi ... epro-v5900
I hope they get the GPUs.txt worked out.
Folding slowly should be acceptable for some projects, but not all. I don't mind leaving that up to the project owner. The question is whether Joseph has blocked species 3 (->192.2.0.1)
