bobhairgrove
Posts: 8 Joined: Sat May 30, 2020 9:38 am
Post
by bobhairgrove » Sun Jul 26, 2020 8:28 pm
After a few days of successful (???) folding, I am now getting this error. Here is my configuration and a sample of the log:
20:07:27:WU01:FS01:0x22:*********************** Log Started 2020-07-26T20:07:27Z ***********************
20:07:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:07:27:WU01:FS01:0x22: Core: Core22
20:07:27:WU01:FS01:0x22: Type: 0x22
20:07:27:WU01:FS01:0x22: Version: 0.0.11
20:07:27:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:07:27:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
20:07:27:WU01:FS01:0x22: Homepage: https://foldingathome.org/
20:07:27:WU01:FS01:0x22: Date: Jun 27 2020
20:07:27:WU01:FS01:0x22: Time: 22:50:00
20:07:27:WU01:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
20:07:27:WU01:FS01:0x22: Branch: core22-0.0.11
20:07:27:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
20:07:27:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
20:07:27:WU01:FS01:0x22: -funroll-loops
20:07:27:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
20:07:27:WU01:FS01:0x22: Bits: 64
20:07:27:WU01:FS01:0x22: Mode: Release
20:07:27:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:07:27:WU01:FS01:0x22: <peastman@stanford.edu>
20:07:27:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 15457 -checkpoint 15
20:07:27:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:07:27:WU01:FS01:0x22: 0 -gpu 0
20:07:27:WU01:FS01:0x22:************************************ libFAH ************************************
20:07:27:WU01:FS01:0x22: Time: 22:11:04
20:07:27:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
20:07:27:WU01:FS01:0x22: Branch: HEAD
20:07:27:WU01:FS01:0x22:************************************ CBang *************************************
20:07:27:WU01:FS01:0x22: Time: 22:10:11
20:07:27:WU01:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
20:07:27:WU01:FS01:0x22: -funroll-loops -fPIC
20:07:27:WU01:FS01:0x22:************************************ System ************************************
20:07:27:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
20:07:27:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:07:27:WU01:FS01:0x22: CPUs: 8
20:07:27:WU01:FS01:0x22: Memory: 15.53GiB
20:07:27:WU01:FS01:0x22:Free Memory: 11.87GiB
20:07:27:WU01:FS01:0x22: Threads: POSIX_THREADS
20:07:27:WU01:FS01:0x22: OS Version: 5.4
20:07:27:WU01:FS01:0x22:Has Battery: true
20:07:27:WU01:FS01:0x22: On Battery: false
20:07:27:WU01:FS01:0x22: UTC Offset: 2
20:07:27:WU01:FS01:0x22: PID: 15461
20:07:27:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
20:07:27:WU01:FS01:0x22:********************************************************************************
20:07:27:WU01:FS01:0x22:Project: 11744 (Run 0, Clone 9497, Gen 109)
20:07:27:WU01:FS01:0x22:Unit: 0x0000009a8ca304f15e6bc3eb0274ec48
20:07:27:WU01:FS01:0x22:Reading tar file core.xml
20:07:27:WU01:FS01:0x22:Reading tar file integrator.xml
20:07:27:WU01:FS01:0x22:Reading tar file state.xml
20:07:29:WU01:FS01:0x22:Reading tar file system.xml
20:07:30:WU01:FS01:0x22:Digital signatures verified
20:07:30:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:07:30:WU01:FS01:0x22:Version 0.0.11
20:07:30:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
20:07:30:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:07:30:WU01:FS01:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
20:07:30:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
20:07:30:WU01:FS01:0x22:OpenCL platform is not available.
20:07:30:WU01:FS01:0x22:There is no registered Platform called "OpenCL"
20:07:30:WU01:FS01:0x22:Platform plugin load failures:
20:07:30:WU01:FS01:0x22:ERROR:126: OpenCL platform is not available.
20:07:30:WU01:FS01:0x22:ERROR:There is no registered Platform called "OpenCL"
20:07:30:WU01:FS01:0x22:ERROR:Platform plugin load failures:
20:07:30:WU01:FS01:0x22:Saving result file ../logfile_01.txt
20:07:30:WU01:FS01:0x22:Saving result file science.log
20:07:30:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:07:30:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:07:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11744 run:0 clone:9497 gen:109 core:0x22 unit:0x0000009a8ca304f15e6bc3eb0274ec48
20:07:30:WU01:FS01:Uploading 2.48KiB to 140.163.4.241
20:07:30:WU01:FS01:Connecting to 140.163.4.241:8080
20:07:30:WU02:FS01:Connecting to assign1.foldingathome.org:80
20:07:30:WU01:FS01:Upload complete
20:07:30:WU01:FS01:Server responded WORK_ACK (400)
20:07:30:WU01:FS01:Cleaning up
FAHClient seems to recognize my GPU all right. And it was working OK until just this evening. Now it is crashing over and over again with the GPU WorkUnits.
Posts: 8290 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Sun Jul 26, 2020 8:37 pm
Please post the first 100-200 lines of your log. That shows hardware, software and client information that is useful for seeing what the client has detected and set up for. If copying from the log window of FAHControl, click Refresh to reload the log from the beginning. Unchecking Follow will make it easier to scroll back.
bobhairgrove
Post
by bobhairgrove » Sun Jul 26, 2020 9:11 pm
OK, this is probably way too much ... but you should be able to see what you need.
*********************** Log Started 2020-07-26T08:19:20Z ***********************
08:19:20:Trying to access database...
08:19:20:Successfully acquired database lock
08:19:20:Read GPUs.txt
08:19:20:Enabled folding slot 00: PAUSED cpu:6 (by user)
08:19:20:Enabled folding slot 01: PAUSED gpu:0:GP107M [GeForce GTX 1050 Mobile] (by user)
08:19:20:****************************** FAHClient ******************************
08:19:20: Version: 7.6.13
08:19:20: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:19:20: Copyright: 2020 foldingathome.org
08:19:20: Homepage: https://foldingathome.org/
08:19:20: Date: Apr 28 2020
08:19:20: Time: 04:20:16
08:19:20: Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:19:20: Branch: master
08:19:20: Compiler: GNU 8.3.0
08:19:20: Options: -std=c++11 -ffunction-sections -fdata-sections -O3
08:19:20: -funroll-loops -fno-pie
08:19:20: Platform: linux2 4.19.0-5-amd64
08:19:20: Bits: 64
08:19:20: Mode: Release
08:19:20: Args: --child /etc/fahclient/config.xml --run-as fahclient
08:19:20: --pid-file=/var/run/fahclient.pid --daemon
08:19:20: Config: /etc/fahclient/config.xml
08:19:20:******************************** CBang ********************************
08:19:20: Date: Apr 25 2020
08:19:20: Time: 00:07:53
08:19:20: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:19:20: -funroll-loops -fno-pie -fPIC
08:19:20: Bits: 64
08:19:20:******************************* System ********************************
08:19:20: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
08:19:20: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:19:20: CPUs: 8
08:19:20: Memory: 15.53GiB
08:19:20: Free Memory: 14.51GiB
08:19:20: Threads: POSIX_THREADS
08:19:20: OS Version: 5.4
08:19:20: Has Battery: true
08:19:20: On Battery: false
08:19:20: UTC Offset: 2
08:19:20: PID: 1515
08:19:20: CWD: /var/lib/fahclient
08:19:20: OS: Linux 5.4.0-42-generic x86_64
08:19:20: OS Arch: AMD64
08:19:20: GPUs: 1
08:19:20: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Mobile]
08:19:20: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
08:19:20:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.100
08:19:20:******************************* libFAH ********************************
08:19:20: Date: Apr 15 2020
08:19:20: Time: 21:43:24
08:19:20: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:19:20: Bits: 64
08:19:20:***********************************************************************
08:19:20:<config>
08:19:20: <!-- Client Control -->
08:19:20: <fold-anon v='true'/>
08:19:20:
08:19:20: <!-- Folding Slot Configuration -->
08:19:20: <gpu v='false'/>
08:19:20:
08:19:20: <!-- Network -->
08:19:20: <proxy v=':8080'/>
08:19:20:
08:19:20: <!-- Slot Control -->
08:19:20: <power v='medium'/>
08:19:20:
08:19:20: <!-- User Information -->
08:19:20: <passkey v='*****'/>
08:19:20: <user v='bobhairgrove'/>
08:19:20:
08:19:20: <!-- Folding Slots -->
08:19:20: <slot id='0' type='CPU'>
08:19:20: <paused v='true'/>
08:19:20: </slot>
08:19:20: <slot id='1' type='GPU'>
08:19:20: </slot>
08:19:20:</config>
08:20:18:FS00:Unpaused
08:20:18:FS01:Unpaused
08:20:18:WU01:FS01:Starting
08:20:18:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:20:18:WU01:FS01:Started FahCore on PID 2233
08:20:18:WU01:FS01:Core PID:2237
08:20:18:WU01:FS01:FahCore 0x22 started
08:20:18:WU02:FS00:Starting
08:20:18:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -np 6
08:20:18:WU02:FS00:Started FahCore on PID 2240
08:20:18:WU02:FS00:Core PID:2244
08:20:18:WU02:FS00:FahCore 0xa7 started
08:20:18:WU01:FS01:0x22:*********************** Log Started 2020-07-26T08:20:18Z ***********************
08:20:18:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:20:18:WU01:FS01:0x22: Core: Core22
08:20:18:WU01:FS01:0x22: Type: 0x22
08:20:18:WU01:FS01:0x22: Version: 0.0.11
08:20:18:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:20:18:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
08:20:18:WU01:FS01:0x22: Homepage: https://foldingathome.org/
08:20:18:WU01:FS01:0x22: Date: Jun 27 2020
08:20:18:WU01:FS01:0x22: Time: 22:50:00
08:20:18:WU01:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
08:20:18:WU01:FS01:0x22: Branch: core22-0.0.11
08:20:18:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:20:18:WU01:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:20:18:WU01:FS01:0x22: -funroll-loops
08:20:18:WU01:FS01:0x22: Platform: linux2 4.19.76-linuxkit
08:20:18:WU01:FS01:0x22: Bits: 64
08:20:18:WU01:FS01:0x22: Mode: Release
08:20:18:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:20:18:WU01:FS01:0x22: <peastman@stanford.edu>
08:20:18:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 2233 -checkpoint 15
08:20:18:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:20:18:WU01:FS01:0x22: 0 -gpu 0
08:20:18:WU01:FS01:0x22:************************************ libFAH ************************************
08:20:18:WU01:FS01:0x22: Time: 22:11:04
08:20:18:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
08:20:18:WU01:FS01:0x22: Branch: HEAD
08:20:18:WU01:FS01:0x22:************************************ CBang *************************************
08:20:18:WU01:FS01:0x22: Time: 22:10:11
08:20:18:WU01:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
08:20:18:WU01:FS01:0x22: -funroll-loops -fPIC
08:20:18:WU01:FS01:0x22:************************************ System ************************************
08:20:18:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
08:20:18:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:20:18:WU01:FS01:0x22: CPUs: 8
08:20:18:WU01:FS01:0x22: Memory: 15.53GiB
08:20:18:WU01:FS01:0x22:Free Memory: 13.66GiB
08:20:18:WU01:FS01:0x22: Threads: POSIX_THREADS
08:20:18:WU01:FS01:0x22: OS Version: 5.4
08:20:18:WU01:FS01:0x22:Has Battery: true
08:20:18:WU01:FS01:0x22: On Battery: false
08:20:18:WU01:FS01:0x22: UTC Offset: 2
08:20:18:WU01:FS01:0x22: PID: 2237
08:20:18:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
08:20:18:WU01:FS01:0x22:********************************************************************************
08:20:18:WU01:FS01:0x22:Project: 13416 (Run 637, Clone 4, Gen 4)
08:20:18:WU01:FS01:0x22:Unit: 0x0000000b12bc7d9a5f02afa47007eea5
08:20:18:WU01:FS01:0x22:Digital signatures verified
08:20:18:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:20:18:WU01:FS01:0x22:Version 0.0.11
08:20:18:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
08:20:18:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
08:20:18:WU01:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
08:20:18:WU01:FS01:0x22: Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
08:20:18:WU02:FS00:0xa7:*********************** Log Started 2020-07-26T08:20:18Z ***********************
08:20:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:20:18:WU02:FS00:0xa7: Type: 0xa7
08:20:18:WU02:FS00:0xa7: Core: Gromacs
08:20:18:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 2240 -checkpoint 15 -np 6
08:20:18:WU02:FS00:0xa7:************************************ CBang *************************************
08:20:18:WU02:FS00:0xa7: Date: Nov 27 2019
08:20:18:WU02:FS00:0xa7: Time: 11:26:54
08:20:18:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:20:18:WU02:FS00:0xa7: Branch: master
08:20:18:WU02:FS00:0xa7: Compiler: GNU 8.3.0
08:20:18:WU02:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
08:20:18:WU02:FS00:0xa7: -fno-pie -fPIC
08:20:18:WU02:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
08:20:18:WU02:FS00:0xa7: Bits: 64
08:20:18:WU02:FS00:0xa7: Mode: Release
08:20:18:WU02:FS00:0xa7:************************************ System ************************************
08:20:18:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
08:20:18:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:20:18:WU02:FS00:0xa7: CPUs: 8
08:20:18:WU02:FS00:0xa7: Memory: 15.53GiB
08:20:18:WU02:FS00:0xa7:Free Memory: 13.64GiB
08:20:18:WU02:FS00:0xa7: Threads: POSIX_THREADS
08:20:18:WU02:FS00:0xa7: OS Version: 5.4
08:20:18:WU02:FS00:0xa7:Has Battery: true
08:20:18:WU02:FS00:0xa7: On Battery: false
08:20:18:WU02:FS00:0xa7: UTC Offset: 2
08:20:18:WU02:FS00:0xa7: PID: 2244
08:20:18:WU02:FS00:0xa7: CWD: /var/lib/fahclient/work
08:20:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:20:18:WU02:FS00:0xa7: Version: 0.0.19
08:20:18:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:20:18:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
08:20:18:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
08:20:18:WU02:FS00:0xa7: Date: Nov 26 2019
08:20:18:WU02:FS00:0xa7: Time: 00:41:42
08:20:18:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:20:18:WU02:FS00:0xa7:************************************ Build *************************************
08:20:18:WU02:FS00:0xa7: SIMD: avx_256
08:20:18:WU02:FS00:0xa7:********************************************************************************
08:20:18:WU02:FS00:0xa7:Project: 14820 (Run 321, Clone 4, Gen 207)
08:20:18:WU02:FS00:0xa7:Unit: 0x000000ee2879986c5eaa287a59db3869
08:20:18:WU02:FS00:0xa7:Digital signatures verified
08:20:18:WU02:FS00:0xa7:Calling: mdrun -s frame207.tpr -o frame207.trr -cpi state.cpt -cpt 15 -nt 6
08:20:18:WU02:FS00:0xa7:Steps: first=0 total=250000
08:20:19:WU02:FS00:0xa7:Completed 158273 out of 250000 steps (63%)
08:20:21:Saving configuration to /etc/fahclient/config.xml
08:20:21:<config>
08:20:21: <!-- Client Control -->
08:20:21: <fold-anon v='true'/>
08:20:21:
08:20:21: <!-- Folding Slot Configuration -->
08:20:21: <gpu v='false'/>
08:20:21:
08:20:21: <!-- Network -->
08:20:21: <proxy v=':8080'/>
08:20:21:
08:20:21: <!-- Slot Control -->
08:20:21: <power v='medium'/>
08:20:21:
08:20:21: <!-- User Information -->
08:20:21: <passkey v='*****'/>
08:20:21: <user v='bobhairgrove'/>
08:20:21:
08:20:21: <!-- Folding Slots -->
08:20:21: <slot id='0' type='CPU'/>
08:20:21: <slot id='1' type='GPU'/>
08:20:21:</config>
08:20:38:WU01:FS01:0x22:ERROR:NaNs detected in forces. 4658 0
08:20:38:WU01:FS01:0x22:Saving result file ../logfile_01.txt
08:20:38:WU01:FS01:0x22:Saving result file science.log
08:20:38:WU01:FS01:0x22:Saving result file state.xml.bz2
08:20:38:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
08:20:38:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:20:38:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13416 run:637 clone:4 gen:4 core:0x22 unit:0x0000000b12bc7d9a5f02afa47007eea5
08:20:38:WU01:FS01:Uploading 5.64MiB to 18.188.125.154
08:20:38:WU01:FS01:Connecting to 18.188.125.154:8080
08:20:39:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:20:39:WU00:FS01:Assigned to work server 18.188.125.154
08:20:39:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 18.188.125.154
08:20:39:WU00:FS01:Connecting to 18.188.125.154:8080
08:20:40:WU00:FS01:Downloading 7.03MiB
08:20:43:WU00:FS01:Download complete
08:20:43:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13420 run:980 clone:13 gen:0 core:0x22 unit:0x0000000012bc7d9a5f1d0f8dd42bdba2
08:20:43:WU00:FS01:Starting
08:20:43:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:20:43:WU00:FS01:Started FahCore on PID 2322
08:20:43:WU00:FS01:Core PID:2326
08:20:43:WU00:FS01:FahCore 0x22 started
08:20:43:WU00:FS01:0x22:*********************** Log Started 2020-07-26T08:20:43Z ***********************
08:20:43:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:20:43:WU00:FS01:0x22: Core: Core22
08:20:43:WU00:FS01:0x22: Type: 0x22
08:20:43:WU00:FS01:0x22: Version: 0.0.11
08:20:43:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:20:43:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
08:20:43:WU00:FS01:0x22: Homepage: https://foldingathome.org/
08:20:43:WU00:FS01:0x22: Date: Jun 27 2020
08:20:43:WU00:FS01:0x22: Time: 22:50:00
08:20:43:WU00:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
08:20:43:WU00:FS01:0x22: Branch: core22-0.0.11
08:20:43:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:20:43:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:20:43:WU00:FS01:0x22: -funroll-loops
08:20:43:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
08:20:43:WU00:FS01:0x22: Bits: 64
08:20:43:WU00:FS01:0x22: Mode: Release
08:20:43:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:20:43:WU00:FS01:0x22: <peastman@stanford.edu>
08:20:43:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2322 -checkpoint 15
08:20:43:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:20:43:WU00:FS01:0x22: 0 -gpu 0
08:20:43:WU00:FS01:0x22:************************************ libFAH ************************************
08:20:43:WU00:FS01:0x22: Time: 22:11:04
08:20:43:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
08:20:43:WU00:FS01:0x22: Branch: HEAD
08:20:43:WU00:FS01:0x22:************************************ CBang *************************************
08:20:43:WU00:FS01:0x22: Time: 22:10:11
08:20:43:WU00:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
08:20:43:WU00:FS01:0x22: -funroll-loops -fPIC
08:20:43:WU00:FS01:0x22:************************************ System ************************************
08:20:43:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
08:20:43:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:20:43:WU00:FS01:0x22: CPUs: 8
08:20:43:WU00:FS01:0x22: Memory: 15.53GiB
08:20:43:WU00:FS01:0x22:Free Memory: 13.46GiB
08:20:43:WU00:FS01:0x22: Threads: POSIX_THREADS
08:20:43:WU00:FS01:0x22: OS Version: 5.4
08:20:43:WU00:FS01:0x22:Has Battery: true
08:20:43:WU00:FS01:0x22: On Battery: false
08:20:43:WU00:FS01:0x22: UTC Offset: 2
08:20:43:WU00:FS01:0x22: PID: 2326
08:20:43:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
08:20:43:WU00:FS01:0x22:********************************************************************************
08:20:43:WU00:FS01:0x22:Project: 13420 (Run 980, Clone 13, Gen 0)
08:20:43:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5f1d0f8dd42bdba2
08:20:43:WU00:FS01:0x22:Reading tar file core.xml
08:20:43:WU00:FS01:0x22:Reading tar file integrator.xml
08:20:43:WU00:FS01:0x22:Reading tar file state.xml.bz2
08:20:43:WU00:FS01:0x22:Reading tar file system.xml.bz2
08:20:43:WU00:FS01:0x22:Digital signatures verified
08:20:43:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:20:43:WU00:FS01:0x22:Version 0.0.11
08:20:43:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
08:20:43:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
08:20:43:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
08:20:43:WU00:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
08:20:44:WU01:FS01:Upload 45.45%
08:20:50:WU01:FS01:Upload 92.01%
08:20:52:WU01:FS01:Upload complete
08:20:52:WU01:FS01:Server responded WORK_ACK (400)
08:20:52:WU01:FS01:Cleaning up
08:20:59:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
08:21:21:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
08:23:01:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
08:24:53:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
08:26:53:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
08:28:43:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
08:29:01:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
08:31:13:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
08:33:32:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
08:35:58:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
08:36:29:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
08:38:28:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
08:41:02:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
08:41:35:FS00:Paused
08:41:35:FS01:Paused
08:41:35:FS00:Shutting core down
08:41:35:FS01:Shutting core down
08:41:36:WU00:FS01:0x22:Caught signal SIGINT(2) on PID 2326
08:41:36:WU00:FS01:0x22:Exiting, please wait. . .
08:41:36:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
08:41:36:WU02:FS00:0xa7:Caught signal SIGINT(2) on PID 2244
08:41:36:WU02:FS00:0xa7:Exiting, please wait. . .
08:41:36:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
08:41:37:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
08:41:37:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:41:42:Saving configuration to /etc/fahclient/config.xml
08:41:42:<config>
08:41:42: <!-- Client Control -->
08:41:42: <fold-anon v='true'/>
08:41:42:
08:41:42: <!-- Folding Slot Configuration -->
08:41:42: <gpu v='false'/>
08:41:42:
08:41:42: <!-- Network -->
08:41:42: <proxy v=':8080'/>
08:41:42:
08:41:42: <!-- Slot Control -->
08:41:42: <power v='medium'/>
08:41:42:
08:41:42: <!-- User Information -->
08:41:42: <passkey v='*****'/>
08:41:42: <user v='bobhairgrove'/>
08:41:42:
08:41:42: <!-- Folding Slots -->
08:41:42: <slot id='0' type='CPU'>
08:41:42: <paused v='true'/>
08:41:42: </slot>
08:41:42: <slot id='1' type='GPU'>
08:41:42: </slot>
08:41:42:</config>
09:53:30:FS00:Unpaused
09:53:30:FS01:Unpaused
09:53:30:WU02:FS00:Starting
09:53:30:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -np 6
09:53:30:WU02:FS00:Started FahCore on PID 5629
09:53:30:WU02:FS00:Core PID:5633
09:53:30:WU02:FS00:FahCore 0xa7 started
09:53:31:WU00:FS01:Starting
09:53:31:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:53:31:WU00:FS01:Started FahCore on PID 5637
09:53:31:WU00:FS01:Core PID:5641
09:53:31:WU00:FS01:FahCore 0x22 started
09:53:31:WU02:FS00:0xa7:*********************** Log Started 2020-07-26T09:53:30Z ***********************
09:53:31:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:53:31:WU02:FS00:0xa7: Type: 0xa7
09:53:31:WU02:FS00:0xa7: Core: Gromacs
09:53:31:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 5629 -checkpoint 15 -np 6
09:53:31:WU02:FS00:0xa7:************************************ CBang *************************************
09:53:31:WU02:FS00:0xa7: Date: Nov 27 2019
09:53:31:WU02:FS00:0xa7: Time: 11:26:54
09:53:31:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:53:31:WU02:FS00:0xa7: Branch: master
09:53:31:WU02:FS00:0xa7: Compiler: GNU 8.3.0
09:53:31:WU02:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
09:53:31:WU02:FS00:0xa7: -fno-pie -fPIC
09:53:31:WU02:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
09:53:31:WU02:FS00:0xa7: Bits: 64
09:53:31:WU02:FS00:0xa7: Mode: Release
09:53:31:WU02:FS00:0xa7:************************************ System ************************************
09:53:31:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
09:53:31:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:53:31:WU02:FS00:0xa7: CPUs: 8
09:53:31:WU02:FS00:0xa7: Memory: 15.53GiB
09:53:31:WU02:FS00:0xa7:Free Memory: 12.60GiB
09:53:31:WU02:FS00:0xa7: Threads: POSIX_THREADS
09:53:31:WU02:FS00:0xa7: OS Version: 5.4
09:53:31:WU02:FS00:0xa7:Has Battery: true
09:53:31:WU02:FS00:0xa7: On Battery: false
09:53:31:WU02:FS00:0xa7: UTC Offset: 2
09:53:31:WU02:FS00:0xa7: PID: 5633
09:53:31:WU02:FS00:0xa7: CWD: /var/lib/fahclient/work
09:53:31:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
09:53:31:WU02:FS00:0xa7: Version: 0.0.19
09:53:31:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:53:31:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
09:53:31:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
09:53:31:WU02:FS00:0xa7: Date: Nov 26 2019
09:53:31:WU02:FS00:0xa7: Time: 00:41:42
09:53:31:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:53:31:WU02:FS00:0xa7:************************************ Build *************************************
09:53:31:WU02:FS00:0xa7: SIMD: avx_256
09:53:31:WU02:FS00:0xa7:********************************************************************************
09:53:31:WU02:FS00:0xa7:Project: 14820 (Run 321, Clone 4, Gen 207)
09:53:31:WU02:FS00:0xa7:Unit: 0x000000ee2879986c5eaa287a59db3869
09:53:31:WU02:FS00:0xa7:Digital signatures verified
09:53:31:WU02:FS00:0xa7:Calling: mdrun -s frame207.tpr -o frame207.trr -cpi state.cpt -cpt 15 -nt 6
09:53:31:WU02:FS00:0xa7:Steps: first=0 total=250000
09:53:31:WU00:FS01:0x22:*********************** Log Started 2020-07-26T09:53:31Z ***********************
09:53:31:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:53:31:WU00:FS01:0x22: Core: Core22
09:53:31:WU00:FS01:0x22: Type: 0x22
09:53:31:WU00:FS01:0x22: Version: 0.0.11
09:53:31:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:53:31:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
09:53:31:WU00:FS01:0x22: Homepage: https://foldingathome.org/
09:53:31:WU00:FS01:0x22: Date: Jun 27 2020
09:53:31:WU00:FS01:0x22: Time: 22:50:00
09:53:31:WU00:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
09:53:31:WU00:FS01:0x22: Branch: core22-0.0.11
09:53:31:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
09:53:31:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
09:53:31:WU00:FS01:0x22: -funroll-loops
09:53:31:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
09:53:31:WU00:FS01:0x22: Bits: 64
09:53:31:WU00:FS01:0x22: Mode: Release
09:53:31:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:53:31:WU00:FS01:0x22: <peastman@stanford.edu>
09:53:31:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 5637 -checkpoint 15
09:53:31:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:53:31:WU00:FS01:0x22: 0 -gpu 0
09:53:31:WU00:FS01:0x22:************************************ libFAH ************************************
09:53:31:WU00:FS01:0x22: Time: 22:11:04
09:53:31:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
09:53:31:WU00:FS01:0x22: Branch: HEAD
09:53:31:WU00:FS01:0x22:************************************ CBang *************************************
09:53:31:WU00:FS01:0x22: Time: 22:10:11
09:53:31:WU00:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
09:53:31:WU00:FS01:0x22: -funroll-loops -fPIC
09:53:31:WU00:FS01:0x22:************************************ System ************************************
09:53:31:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
09:53:31:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:53:31:WU00:FS01:0x22: CPUs: 8
09:53:31:WU00:FS01:0x22: Memory: 15.53GiB
09:53:31:WU00:FS01:0x22:Free Memory: 12.60GiB
09:53:31:WU00:FS01:0x22: Threads: POSIX_THREADS
09:53:31:WU00:FS01:0x22: OS Version: 5.4
09:53:31:WU00:FS01:0x22:Has Battery: true
09:53:31:WU00:FS01:0x22: On Battery: false
09:53:31:WU00:FS01:0x22: UTC Offset: 2
09:53:31:WU00:FS01:0x22: PID: 5641
09:53:31:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
09:53:31:WU00:FS01:0x22:********************************************************************************
09:53:31:WU00:FS01:0x22:Project: 13420 (Run 980, Clone 13, Gen 0)
09:53:31:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5f1d0f8dd42bdba2
09:53:31:WU00:FS01:0x22:Digital signatures verified
09:53:31:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:53:31:WU00:FS01:0x22:Version 0.0.11
09:53:31:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
09:53:31:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
09:53:31:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
09:53:31:WU00:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
09:53:31:WU02:FS00:0xa7:Completed 183043 out of 250000 steps (73%)
09:53:43:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
09:53:53:Saving configuration to /etc/fahclient/config.xml
09:53:53:<config>
09:53:53: <!-- Client Control -->
09:53:53: <fold-anon v='true'/>
09:53:53:
09:53:53: <!-- Folding Slot Configuration -->
09:53:53: <gpu v='false'/>
09:53:53:
09:53:53: <!-- Network -->
09:53:53: <proxy v=':8080'/>
09:53:53:
09:53:53: <!-- Slot Control -->
09:53:53: <power v='medium'/>
09:53:53:
09:53:53: <!-- User Information -->
09:53:53: <passkey v='*****'/>
09:53:53: <user v='bobhairgrove'/>
09:53:53:
09:53:53: <!-- Folding Slots -->
09:53:53: <slot id='0' type='CPU'/>
09:53:53: <slot id='1' type='GPU'/>
09:53:53:</config>
09:54:54:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
09:56:58:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
09:59:18:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
10:01:29:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
10:01:50:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
10:04:26:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
10:07:07:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
10:09:15:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
10:09:51:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
10:12:36:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
10:15:20:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
10:17:01:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
10:18:06:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
10:20:50:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
10:23:35:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
10:24:48:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
10:26:22:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
10:29:11:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
10:31:51:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
10:32:35:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
10:34:34:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
10:37:18:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
10:40:02:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
10:40:24:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
10:42:45:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
10:45:28:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
10:48:11:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
10:48:11:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
10:50:54:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
10:53:41:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
10:55:58:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
10:56:29:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
10:59:15:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
11:01:59:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
11:02:00:WU01:FS00:Connecting to assign1.foldingathome.org:80
11:02:01:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:02:01:WU01:FS00:Connecting to assign2.foldingathome.org:80
11:02:01:WU01:FS00:Assigned to work server 150.136.14.110
11:02:01:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 150.136.14.110
11:02:01:WU01:FS00:Connecting to 150.136.14.110:8080
11:02:02:WU01:FS00:Downloading 3.11MiB
11:02:03:WU01:FS00:Download complete
11:02:03:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16422 run:164 clone:0 gen:158 core:0xa7 unit:0x000000af96880e6e5e8bdf1ef81603b7
11:03:45:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
11:04:43:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
11:04:47:WU02:FS00:0xa7:Saving result file ../logfile_01.txt
11:04:47:WU02:FS00:0xa7:Saving result file dhdl.xvg
11:04:47:WU02:FS00:0xa7:Saving result file frame207.trr
11:04:47:WU02:FS00:0xa7:Saving result file md.log
11:04:47:WU02:FS00:0xa7:Saving result file pullf.xvg
11:04:47:WU02:FS00:0xa7:Saving result file pullx.xvg
11:04:47:WU02:FS00:0xa7:Saving result file science.log
11:04:47:WU02:FS00:0xa7:Saving result file traj_comp.xtc
11:04:47:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:04:47:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:04:47:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14820 run:321 clone:4 gen:207 core:0xa7 unit:0x000000ee2879986c5eaa287a59db3869
11:04:47:WU02:FS00:Uploading 6.87MiB to 40.121.152.108
11:04:47:WU02:FS00:Connecting to 40.121.152.108:8080
11:04:47:WU01:FS00:Starting
11:04:47:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -np 6
11:04:47:WU01:FS00:Started FahCore on PID 5786
11:04:47:WU01:FS00:Core PID:5790
11:04:47:WU01:FS00:FahCore 0xa7 started
11:04:47:WU01:FS00:0xa7:*********************** Log Started 2020-07-26T11:04:47Z ***********************
11:04:47:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:04:47:WU01:FS00:0xa7: Type: 0xa7
11:04:47:WU01:FS00:0xa7: Core: Gromacs
11:04:47:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 5786 -checkpoint 15 -np 6
11:04:47:WU01:FS00:0xa7:************************************ CBang *************************************
11:04:47:WU01:FS00:0xa7: Date: Nov 27 2019
11:04:47:WU01:FS00:0xa7: Time: 11:26:54
11:04:47:WU01:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:04:47:WU01:FS00:0xa7: Branch: master
11:04:47:WU01:FS00:0xa7: Compiler: GNU 8.3.0
11:04:47:WU01:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
11:04:47:WU01:FS00:0xa7: -fno-pie -fPIC
11:04:47:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
11:04:47:WU01:FS00:0xa7: Bits: 64
11:04:47:WU01:FS00:0xa7: Mode: Release
11:04:47:WU01:FS00:0xa7:************************************ System ************************************
11:04:47:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
11:04:47:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:04:47:WU01:FS00:0xa7: CPUs: 8
11:04:47:WU01:FS00:0xa7: Memory: 15.53GiB
11:04:47:WU01:FS00:0xa7:Free Memory: 11.90GiB
11:04:47:WU01:FS00:0xa7: Threads: POSIX_THREADS
11:04:47:WU01:FS00:0xa7: OS Version: 5.4
11:04:47:WU01:FS00:0xa7:Has Battery: true
11:04:47:WU01:FS00:0xa7: On Battery: false
11:04:47:WU01:FS00:0xa7: UTC Offset: 2
11:04:47:WU01:FS00:0xa7: PID: 5790
11:04:47:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
11:04:47:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:04:47:WU01:FS00:0xa7: Version: 0.0.19
11:04:47:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:04:47:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
11:04:47:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
11:04:47:WU01:FS00:0xa7: Date: Nov 26 2019
11:04:47:WU01:FS00:0xa7: Time: 00:41:42
11:04:47:WU01:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:04:47:WU01:FS00:0xa7:************************************ Build *************************************
11:04:47:WU01:FS00:0xa7: SIMD: avx_256
11:04:47:WU01:FS00:0xa7:********************************************************************************
11:04:47:WU01:FS00:0xa7:Project: 16422 (Run 164, Clone 0, Gen 158)
11:04:47:WU01:FS00:0xa7:Unit: 0x000000af96880e6e5e8bdf1ef81603b7
11:04:47:WU01:FS00:0xa7:Reading tar file core.xml
11:04:47:WU01:FS00:0xa7:Reading tar file frame158.tpr
11:04:47:WU01:FS00:0xa7:Digital signatures verified
11:04:47:WU01:FS00:0xa7:Calling: mdrun -s frame158.tpr -o frame158.trr -x frame158.xtc -cpt 15 -nt 6
11:04:47:WU01:FS00:0xa7:Steps: first=39500000 total=250000
11:04:48:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
11:04:53:WU02:FS00:Upload 54.62%
11:04:59:WU02:FS00:Upload complete
11:04:59:WU02:FS00:Server responded WORK_ACK (400)
11:04:59:WU02:FS00:Final credit estimate, 1756.00 points
11:04:59:WU02:FS00:Cleaning up
11:07:19:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
11:07:26:FS00:Paused
11:07:26:FS01:Paused
11:07:27:FS00:Shutting core down
11:07:27:FS01:Shutting core down
11:07:27:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 5790
11:07:27:WU01:FS00:0xa7:Exiting, please wait. . .
11:07:27:WU00:FS01:0x22:Caught signal SIGINT(2) on PID 5641
11:07:27:WU00:FS01:0x22:Exiting, please wait. . .
11:07:27:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
11:07:27:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:07:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:08:06:Removing old file 'configs/config-20200725-135604.xml'
11:08:06:Saving configuration to /etc/fahclient/config.xml
11:08:06:<config>
11:08:06: <!-- Client Control -->
11:08:06: <fold-anon v='true'/>
11:08:06:
11:08:06: <!-- Folding Slot Configuration -->
11:08:06: <gpu v='false'/>
11:08:06:
11:08:06: <!-- Network -->
11:08:06: <proxy v=':8080'/>
11:08:06:
11:08:06: <!-- Slot Control -->
11:08:06: <power v='medium'/>
11:08:06:
11:08:06: <!-- User Information -->
11:08:06: <passkey v='*****'/>
11:08:06: <user v='bobhairgrove'/>
11:08:06:
11:08:06: <!-- Folding Slots -->
11:08:06: <slot id='0' type='CPU'>
11:08:06: <paused v='true'/>
11:08:06: </slot>
11:08:06: <slot id='1' type='GPU'>
11:08:06: </slot>
11:08:06:</config>
******************************* Date: 2020-07-26 *******************************
15:21:14:FS00:Unpaused
15:21:14:FS01:Unpaused
15:21:14:WU00:FS01:Starting
15:21:14:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:21:14:WU00:FS01:Started FahCore on PID 13714
15:21:14:WU00:FS01:Core PID:13718
15:21:14:WU00:FS01:FahCore 0x22 started
15:21:14:WU01:FS00:Starting
15:21:14:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -np 6
15:21:14:WU01:FS00:Started FahCore on PID 13721
15:21:14:WU01:FS00:Core PID:13725
15:21:14:WU01:FS00:FahCore 0xa7 started
15:21:15:WU00:FS01:0x22:*********************** Log Started 2020-07-26T15:21:14Z ***********************
15:21:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:21:15:WU00:FS01:0x22: Core: Core22
15:21:15:WU00:FS01:0x22: Type: 0x22
15:21:15:WU00:FS01:0x22: Version: 0.0.11
15:21:15:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:15:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
15:21:15:WU00:FS01:0x22: Homepage: https://foldingathome.org/
15:21:15:WU00:FS01:0x22: Date: Jun 27 2020
15:21:15:WU00:FS01:0x22: Time: 22:50:00
15:21:15:WU00:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
15:21:15:WU00:FS01:0x22: Branch: core22-0.0.11
15:21:15:WU00:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:21:15:WU00:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
15:21:15:WU00:FS01:0x22: -funroll-loops
15:21:15:WU00:FS01:0x22: Platform: linux2 4.19.76-linuxkit
15:21:15:WU00:FS01:0x22: Bits: 64
15:21:15:WU00:FS01:0x22: Mode: Release
15:21:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:21:15:WU00:FS01:0x22: <peastman@stanford.edu>
15:21:15:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 13714 -checkpoint 15
15:21:15:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:21:15:WU00:FS01:0x22: 0 -gpu 0
15:21:15:WU00:FS01:0x22:************************************ libFAH ************************************
15:21:15:WU00:FS01:0x22: Time: 22:11:04
15:21:15:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
15:21:15:WU00:FS01:0x22: Branch: HEAD
15:21:15:WU00:FS01:0x22:************************************ CBang *************************************
15:21:15:WU00:FS01:0x22: Time: 22:10:11
15:21:15:WU00:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
15:21:15:WU00:FS01:0x22: -funroll-loops -fPIC
15:21:15:WU00:FS01:0x22:************************************ System ************************************
15:21:15:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
15:21:15:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:21:15:WU00:FS01:0x22: CPUs: 8
15:21:15:WU00:FS01:0x22: Memory: 15.53GiB
15:21:15:WU00:FS01:0x22:Free Memory: 11.96GiB
15:21:15:WU00:FS01:0x22: Threads: POSIX_THREADS
15:21:15:WU00:FS01:0x22: OS Version: 5.4
15:21:15:WU00:FS01:0x22:Has Battery: true
15:21:15:WU00:FS01:0x22: On Battery: false
15:21:15:WU00:FS01:0x22: UTC Offset: 2
15:21:15:WU00:FS01:0x22: PID: 13718
15:21:15:WU00:FS01:0x22: CWD: /var/lib/fahclient/work
15:21:15:WU00:FS01:0x22:********************************************************************************
15:21:15:WU00:FS01:0x22:Project: 13420 (Run 980, Clone 13, Gen 0)
15:21:15:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5f1d0f8dd42bdba2
15:21:15:WU00:FS01:0x22:Digital signatures verified
15:21:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:21:15:WU00:FS01:0x22:Version 0.0.11
15:21:15:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
15:21:15:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
15:21:15:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
15:21:15:WU00:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
15:21:15:WU01:FS00:0xa7:*********************** Log Started 2020-07-26T15:21:14Z ***********************
15:21:15:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:21:15:WU01:FS00:0xa7: Type: 0xa7
15:21:15:WU01:FS00:0xa7: Core: Gromacs
15:21:15:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 13721 -checkpoint 15 -np
15:21:15:WU01:FS00:0xa7: 6
15:21:15:WU01:FS00:0xa7:************************************ CBang *************************************
15:21:15:WU01:FS00:0xa7: Date: Nov 27 2019
15:21:15:WU01:FS00:0xa7: Time: 11:26:54
15:21:15:WU01:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:21:15:WU01:FS00:0xa7: Branch: master
15:21:15:WU01:FS00:0xa7: Compiler: GNU 8.3.0
15:21:15:WU01:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
15:21:15:WU01:FS00:0xa7: -fno-pie -fPIC
15:21:15:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
15:21:15:WU01:FS00:0xa7: Bits: 64
15:21:15:WU01:FS00:0xa7: Mode: Release
15:21:15:WU01:FS00:0xa7:************************************ System ************************************
15:21:15:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
15:21:15:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:21:15:WU01:FS00:0xa7: CPUs: 8
15:21:15:WU01:FS00:0xa7: Memory: 15.53GiB
15:21:15:WU01:FS00:0xa7:Free Memory: 11.96GiB
15:21:15:WU01:FS00:0xa7: Threads: POSIX_THREADS
15:21:15:WU01:FS00:0xa7: OS Version: 5.4
15:21:15:WU01:FS00:0xa7:Has Battery: true
15:21:15:WU01:FS00:0xa7: On Battery: false
15:21:15:WU01:FS00:0xa7: UTC Offset: 2
15:21:15:WU01:FS00:0xa7: PID: 13725
15:21:15:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
15:21:15:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:21:15:WU01:FS00:0xa7: Version: 0.0.19
15:21:15:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:15:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
15:21:15:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
15:21:15:WU01:FS00:0xa7: Date: Nov 26 2019
15:21:15:WU01:FS00:0xa7: Time: 00:41:42
15:21:15:WU01:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:21:15:WU01:FS00:0xa7:************************************ Build *************************************
15:21:15:WU01:FS00:0xa7: SIMD: avx_256
15:21:15:WU01:FS00:0xa7:********************************************************************************
15:21:15:WU01:FS00:0xa7:Project: 16422 (Run 164, Clone 0, Gen 158)
15:21:15:WU01:FS00:0xa7:Unit: 0x000000af96880e6e5e8bdf1ef81603b7
15:21:15:WU01:FS00:0xa7:Digital signatures verified
15:21:15:WU01:FS00:0xa7:Calling: mdrun -s frame158.tpr -o frame158.trr -x frame158.xtc -cpi state.cpt -cpt 15 -nt 6
15:21:15:WU01:FS00:0xa7:Steps: first=39500000 total=250000
15:21:15:WU01:FS00:0xa7:Completed 2632 out of 250000 steps (1%)
15:21:22:WU00:FS01:0x22:ERROR:exception: Error initializing context: clCreateContext (-5)
15:21:22:WU00:FS01:0x22:Saving result file ../logfile_01.txt
15:21:22:WU00:FS01:0x22:Saving result file science.log
15:21:22:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:21:22:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:21:22:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13420 run:980 clone:13 gen:0 core:0x22 unit:0x0000000012bc7d9a5f1d0f8dd42bdba2
15:21:22:WU00:FS01:Uploading 22.00KiB to 18.188.125.154
15:21:22:WU00:FS01:Connecting to 18.188.125.154:8080
15:21:22:WU00:FS01:Upload complete
15:21:22:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:21:22:WU00:FS01:Server responded WORK_ACK (400)
15:21:22:WU00:FS01:Cleaning up
15:21:23:WU02:FS01:Assigned to work server 140.163.4.241
15:21:23:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 140.163.4.241
15:21:23:WU02:FS01:Connecting to 140.163.4.241:8080
15:21:39:WU02:FS01:Downloading 13.15MiB
15:21:45:WU02:FS01:Download 49.41%
15:21:46:Removing old file 'configs/config-20200725-144149.xml'
15:21:46:Saving configuration to /etc/fahclient/config.xml
15:21:46:<config>
15:21:46: <!-- Client Control -->
15:21:46: <fold-anon v='true'/>
15:21:46:
15:21:46: <!-- Folding Slot Configuration -->
15:21:46: <gpu v='false'/>
15:21:46:
15:21:46: <!-- Network -->
15:21:46: <proxy v=':8080'/>
15:21:46:
15:21:46: <!-- Slot Control -->
15:21:46: <power v='medium'/>
15:21:46:
15:21:46: <!-- User Information -->
15:21:46: <passkey v='*****'/>
15:21:46: <user v='bobhairgrove'/>
15:21:46:
15:21:46: <!-- Folding Slots -->
15:21:46: <slot id='0' type='CPU'/>
15:21:46: <slot id='1' type='GPU'/>
15:21:46:</config>
15:21:48:WU02:FS01:Download complete
15:21:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11746 run:0 clone:6015 gen:202 core:0x22 unit:0x0000014a8ca304f15e6bc357c42a05e1
15:21:49:WU02:FS01:Starting
15:21:49:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:21:49:WU02:FS01:Started FahCore on PID 13743
15:21:49:WU02:FS01:Core PID:13747
15:21:49:WU02:FS01:FahCore 0x22 started
15:21:49:WU02:FS01:0x22:*********************** Log Started 2020-07-26T15:21:49Z ***********************
15:21:49:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:21:49:WU02:FS01:0x22: Core: Core22
15:21:49:WU02:FS01:0x22: Type: 0x22
15:21:49:WU02:FS01:0x22: Version: 0.0.11
15:21:49:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:49:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
15:21:49:WU02:FS01:0x22: Homepage: https://foldingathome.org/
15:21:49:WU02:FS01:0x22: Date: Jun 27 2020
15:21:49:WU02:FS01:0x22: Time: 22:50:00
15:21:49:WU02:FS01:0x22: Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
15:21:49:WU02:FS01:0x22: Branch: core22-0.0.11
15:21:49:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:21:49:WU02:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
15:21:49:WU02:FS01:0x22: -funroll-loops
15:21:49:WU02:FS01:0x22: Platform: linux2 4.19.76-linuxkit
15:21:49:WU02:FS01:0x22: Bits: 64
15:21:49:WU02:FS01:0x22: Mode: Release
15:21:49:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:21:49:WU02:FS01:0x22: <peastman@stanford.edu>
15:21:49:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 13743 -checkpoint 15
15:21:49:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:21:49:WU02:FS01:0x22: 0 -gpu 0
15:21:49:WU02:FS01:0x22:************************************ libFAH ************************************
15:21:49:WU02:FS01:0x22: Time: 22:11:04
15:21:49:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
15:21:49:WU02:FS01:0x22: Branch: HEAD
15:21:49:WU02:FS01:0x22:************************************ CBang *************************************
15:21:49:WU02:FS01:0x22: Time: 22:10:11
15:21:49:WU02:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
15:21:49:WU02:FS01:0x22: -funroll-loops -fPIC
15:21:49:WU02:FS01:0x22:************************************ System ************************************
15:21:49:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
15:21:49:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:21:49:WU02:FS01:0x22: CPUs: 8
15:21:49:WU02:FS01:0x22: Memory: 15.53GiB
15:21:49:WU02:FS01:0x22:Free Memory: 11.88GiB
15:21:49:WU02:FS01:0x22: Threads: POSIX_THREADS
15:21:49:WU02:FS01:0x22: OS Version: 5.4
15:21:49:WU02:FS01:0x22:Has Battery: true
15:21:49:WU02:FS01:0x22: On Battery: false
15:21:49:WU02:FS01:0x22: UTC Offset: 2
15:21:49:WU02:FS01:0x22: PID: 13747
15:21:49:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
15:21:49:WU02:FS01:0x22:********************************************************************************
15:21:49:WU02:FS01:0x22:Project: 11746 (Run 0, Clone 6015, Gen 202)
15:21:49:WU02:FS01:0x22:Unit: 0x0000014a8ca304f15e6bc357c42a05e1
15:21:49:WU02:FS01:0x22:Reading tar file core.xml
15:21:49:WU02:FS01:0x22:Reading tar file integrator.xml
15:21:49:WU02:FS01:0x22:Reading tar file state.xml
15:21:52:WU02:FS01:0x22:Reading tar file system.xml
15:21:53:WU02:FS01:0x22:Digital signatures verified
15:21:53:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:21:53:WU02:FS01:0x22:Version 0.0.11
15:21:53:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
15:21:53:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
15:21:53:WU02:FS01:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
15:21:53:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
15:21:53:WU02:FS01:0x22:OpenCL platform is not available.
15:21:53:WU02:FS01:0x22:There is no registered Platform called "OpenCL"
15:21:53:WU02:FS01:0x22:Platform plugin load failures:
15:21:53:WU02:FS01:0x22:ERROR:126: OpenCL platform is not available.
15:21:53:WU02:FS01:0x22:ERROR:There is no registered Platform called "OpenCL"
15:21:53:WU02:FS01:0x22:ERROR:Platform plugin load failures:
15:21:53:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:21:53:WU02:FS01:0x22:Saving result file science.log
15:21:53:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:21:53:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:21:53:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11746 run:0 clone:6015 gen:202 core:0x22 unit:0x0000014a8ca304f15e6bc357c42a05e1
15:21:53:WU02:FS01:Uploading 2.49KiB to 140.163.4.241
15:21:53:WU02:FS01:Connecting to 140.163.4.241:8080
15:21:53:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:21:53:WU02:FS01:Upload complete
15:21:53:WU02:FS01:Server responded WORK_ACK (400)
15:21:53:WU02:FS01:Cleaning up
15:21:54:WU00:FS01:Assigned to work server 140.163.4.241
15:21:54:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 140.163.4.241
15:21:54:WU00:FS01:Connecting to 140.163.4.241:8080
15:22:03:WU00:FS01:Downloading 7.85MiB
15:22:09:WU00:FS01:Download 85.17%
15:22:09:WU00:FS01:Download complete
15:22:09:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:6052 gen:65 core:0x22 unit:0x000000658ca304f15e6bc439b3e37960
15:22:09:WU00:FS01:Starting
15:22:09:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1515 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:22:09:WU00:FS01:Started FahCore on PID 13760
15:22:09:WU00:FS01:Core PID:13764
15:22:09:WU00:FS01:FahCore 0x22 started
gunnarre
Posts: 560 Joined: Sun May 24, 2020 7:23 pm
Post
by gunnarre » Sun Jul 26, 2020 9:42 pm
Almost looks like your GPU disappeared between 11 and 15 UTC. The GPU slot was folding and made it to 8% on a work unit, but after it was unpaused later it couldn't initialize the folding core again.
This is a laptop? Can you force it to use the Nvidia graphics instead of the Intel graphics, at least for FoldingAtHome?
bobhairgrove
Post
by bobhairgrove » Sun Jul 26, 2020 10:19 pm
Yes, it is using the NVIDIA card, I blacklisted the Nouveau driver. You can see it in the log entries that it is using it:
Post
by Joe_H » Sun Jul 26, 2020 10:38 pm
If the laptop use nVidia;s Optimus tech, then you may also need to disable the iGPU on the Intel processor in the BIOS as well. Under Windows later versions of Optimus disabled use in the driver or had setting to use the discrete nVidia GPU for set software.
Since you are running Linux, not sure of the details of ensuring that the nVidia GPU stays active while folding. I have read of an open source control called Bumblebee, but the name is all I know about it.
bobhairgrove
Post
by bobhairgrove » Mon Jul 27, 2020 8:14 am
Hi, and thank you for looking into this. This morning (Central European time), folding is working normally again with both CPU and GPU slots. I wish I knew where the error was coming from, though.
As to Intel vs. NVIDIA, there is an Nvidia Settings app which allows one to choose which GPU to use (NVIDIA = performance, Intel = power saving mode). If the NVIDIA GPU is recognized by FAHClient, and only 1 GPU is detected in the system, I don't think that the Intel GPU would be used at all.
As to Optimus: my GPU is GeForce GTX 1050 Mobile ... I have no idea if Optimus is used here, but the laptop is already about four years old, so if Optimus is newer than that, it doesn't.
Posts: 1996 Joined: Sun Mar 22, 2020 5:52 pm
Hardware configuration: 1: 2x Xeon E5-2697v3@2.60GHz, 512GB DDR4 LRDIMM, SSD Raid, Win10 Ent 20H2, Quadro K420 1GB, FAH 7.6.21 2: Xeon E3-1505Mv5@2.80GHz, 32GB DDR4, NVME, Win10 Pro 20H2, Quadro M1000M 2GB, FAH 7.6.21 (actually have two of these) 3: i7-960@3.20GHz, 12GB DDR3, SSD, Win10 Pro 20H2, GTX 750Ti 2GB, GTX 1080Ti 11GB, FAH 7.6.21
Post
by Neil-B » Mon Jul 27, 2020 8:35 am
Your laptop will be using Optimus - and what you are describing re settings and how GPU is selected is Optimus .. It has been around for a lot longer than four years ... It is the technology that allows you Intel iGPU and the nvidia one to co-exist ...
https://en.wikipedia.org/wiki/Nvidia_Optimus ...
https://www.geforce.com/hardware/techno ... technology ... and sometimes it can be a real pain
bobhairgrove
Post
by bobhairgrove » Mon Jul 27, 2020 11:32 am
@Neil-B: Thanks very much for the detail and the links. From reading the Wikipedia page, it seems that as long as CUDA calls are being made, the NVIDIA driver will ensure that its GPU and not Intel GPU will be used.
gunnarre
Post
by gunnarre » Mon Jul 27, 2020 12:04 pm
I have experienced that on some Linux distros, GPU folding gets disrupted by hibernation/sleep mode, needing a full reboot (or perhaps just a re-initialization of the GPU?) before the graphics card folding will start again. Could that be what happened?
Post
by Neil-B » Mon Jul 27, 2020 12:10 pm
I have always wondered (and this really is unfounded speculation on my part) whether checkpointing/sanity checks on GPU WUs might play into this.
From what I "understand" (very sketchily) the cores "pause" every so often and do sanity checking/save checkpoints - and I have wondered if occasionally that "drops" the usage of the GPU low enough that an optimus based setup on automatic decides to switch the load from the nvidia to the iGPU.
Now I have absolutely no grounds to believe the above speculation to be true - but it might account for the occasional issue like yours seen especially on laptops with linux OS - as for the most part Windows Optimus issues are relatively obvious.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Wed Jul 29, 2020 5:26 pm
I share Neil-B suspicions but have no proof. When an Optimus laptop is folding, we recommend setting the BIOS to use only the NVidia device. This avoids the problem and really doesn't change the power usage pattern significantly unless you sop folding and continue to use your laptop. If you have a better idea, let us know.
bobhairgrove
Posts: 8 Joined: Sat May 30, 2020 9:38 am
Post
by bobhairgrove » Thu Jul 30, 2020 8:30 am
Thanks, Bruce. I'm sure this is a good idea, but I couldn't find any option in BIOS setup to enable/disable any graphics card. But as long as I'm folding again, I'll let it ride until the next glitch.
Post
by bruce » Thu Jul 30, 2020 5:38 pm
Optimus is essentially a power-saving option. That may help you find the setting. You'll probably need to disable GPU power savings.
bobhairgrove
Post
by bobhairgrove » Thu Jul 30, 2020 8:16 pm
Well. that setting is in the NVIDIA Settings app which is installed when I install the NVIDIA driver.
Just not in the BIOS.
