No WU for my 2 x R9 390
Quad2000
Post by Quad2000 »
Good Morning together,
my Folding PC (2 x R9 390) does not work in the last 2 days. Restart does not help. Can somebody help me?
06:28:44:WU00:FS01:Connecting to assign1.foldingathome.org:80
06:28:44:WU01:FS02:Connecting to assign1.foldingathome.org:80
06:28:45:WU01:FS02:Assigned to work server 192.0.2.1
06:28:45:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:28:45:WU01:FS02:Connecting to 192.0.2.1:8080
06:28:45:WU00:FS01:Assigned to work server 192.0.2.1
06:28:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:28:45:WU00:FS01:Connecting to 192.0.2.1:8080
06:29:06:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
06:29:06:WU01:FS02:Connecting to 192.0.2.1:80
06:29:06:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
06:29:06:WU00:FS01:Connecting to 192.0.2.1:80
06:29:27:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
06:29:28:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
06:30:21:WU00:FS01:Connecting to assign1.foldingathome.org:80
06:30:21:WU01:FS02:Connecting to assign1.foldingathome.org:80
06:30:22:WU00:FS01:Assigned to work server 192.0.2.1
06:30:22:WU01:FS02:Assigned to work server 192.0.2.1
06:30:22:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:30:22:WU01:FS02:Connecting to 192.0.2.1:8080
06:30:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:30:23:WU00:FS01:Connecting to 192.0.2.1:8080
06:30:43:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
06:30:43:WU01:FS02:Connecting to 192.0.2.1:80
06:30:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
06:30:44:WU00:FS01:Connecting to 192.0.2.1:80
06:31:04:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
06:31:05:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
06:32:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
06:32:59:WU01:FS02:Connecting to assign1.foldingathome.org:80
06:32:59:WU00:FS01:Assigned to work server 192.0.2.1
06:32:59:WU01:FS02:Assigned to work server 192.0.2.1
06:32:59:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:32:59:WU01:FS02:Connecting to 192.0.2.1:8080
06:33:00:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Hawaii [Radeon R9 200/300 Series] from 192.0.2.1
06:33:00:WU00:FS01:Connecting to 192.0.2.1:8080
06:33:20:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
06:33:20:WU01:FS02:Connecting to 192.0.2.1:80
06:33:21:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
06:33:21:WU00:FS01:Connecting to 192.0.2.1:80
06:33:41:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
06:33:42:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
Re: No WU for my 2 x R9 390
It looks like your system is running into the same problem as discussed in this topic - viewtopic.php?f=18&t=35859. Will pass on the information, it should be fixed within the next day or two.
