missing credit server 206.223.170.146
goodyca
Post by goodyca »
The following WU's were successfully uploaded to the subject server, but no credit was issued. I have checked the WU Status of each at https://apps.foldingathome.org/wu, and they are all show as "Not found."
Completion Time Project Description
07/24/20 04:52 PM Project: 14257 (Run 0, Clone 1717, Gen 59)
07/24/20 07:52 PM Project: 14256 (Run 0, Clone 561, Gen 310)
07/25/20 05:15 AM Project: 14259 (Run 0, Clone 1330, Gen 42)
Here is an example log file for one of the WU's
03:54:18:WU01:FS01:Connecting to 65.254.110.245:80
03:54:19:WU01:FS01:Assigned to work server 206.223.170.146
03:54:19:WU01:FS01:Requesting new work unit for slot 01: READY cpu:7 from 206.223.170.146
03:54:19:WU01:FS01:Connecting to 206.223.170.146:8080
03:54:19:WU01:FS01:Downloading 3.40MiB
03:54:20:WU01:FS01:Download complete
03:54:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14259 run:0 clone:1330 gen:42 core:0xa7 unit:0x00000035cedfaa925eac9dbffaaad5cb
03:54:20:WU01:FS01:Starting
03:54:20:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1765 -checkpoint 15 -np 7
03:54:20:WU01:FS01:Started FahCore on PID 551954
03:54:20:WU01:FS01:Core PID:551958
03:54:20:WU01:FS01:FahCore 0xa7 started
03:54:20:WU01:FS01:0xa7:*********************** Log Started 2020-07-25T03:54:20Z ***********************
03:54:20:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
03:54:20:WU01:FS01:0xa7:       Type: 0xa7
03:54:20:WU01:FS01:0xa7:       Core: Gromacs
03:54:20:WU01:FS01:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 551954 -checkpoint 15 -np
03:54:20:WU01:FS01:0xa7:             7
03:54:20:WU01:FS01:0xa7:************************************ CBang *************************************
03:54:20:WU01:FS01:0xa7:       Date: Nov 27 2019
03:54:20:WU01:FS01:0xa7:       Time: 11:26:54
03:54:20:WU01:FS01:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:54:20:WU01:FS01:0xa7:     Branch: master
03:54:20:WU01:FS01:0xa7:   Compiler: GNU 8.3.0
03:54:20:WU01:FS01:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
03:54:20:WU01:FS01:0xa7:             -fno-pie -fPIC
03:54:20:WU01:FS01:0xa7:   Platform: linux2 4.19.0-5-amd64
03:54:20:WU01:FS01:0xa7:       Bits: 64
03:54:20:WU01:FS01:0xa7:       Mode: Release
03:54:20:WU01:FS01:0xa7:************************************ System ************************************
03:54:20:WU01:FS01:0xa7:        CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
03:54:20:WU01:FS01:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
03:54:20:WU01:FS01:0xa7:       CPUs: 8
03:54:20:WU01:FS01:0xa7:     Memory: 15.55GiB
03:54:20:WU01:FS01:0xa7:Free Memory: 2.90GiB
03:54:20:WU01:FS01:0xa7:    Threads: POSIX_THREADS
03:54:20:WU01:FS01:0xa7: OS Version: 5.7
03:54:20:WU01:FS01:0xa7:Has Battery: false
03:54:20:WU01:FS01:0xa7: On Battery: false
03:54:20:WU01:FS01:0xa7: UTC Offset: -5
03:54:20:WU01:FS01:0xa7:        PID: 551958
03:54:20:WU01:FS01:0xa7:        CWD: /var/lib/fahclient/work
03:54:20:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
03:54:20:WU01:FS01:0xa7:    Version: 0.0.19
03:54:20:WU01:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:54:20:WU01:FS01:0xa7:  Copyright: 2019 foldingathome.org
03:54:20:WU01:FS01:0xa7:   Homepage: https://foldingathome.org/
03:54:20:WU01:FS01:0xa7:       Date: Nov 26 2019
03:54:20:WU01:FS01:0xa7:       Time: 00:41:42
03:54:20:WU01:FS01:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:54:20:WU01:FS01:0xa7:************************************ Build *************************************
03:54:20:WU01:FS01:0xa7:       SIMD: avx_256
03:54:20:WU01:FS01:0xa7:********************************************************************************
03:54:20:WU01:FS01:0xa7:Project: 14259 (Run 0, Clone 1330, Gen 42)
03:54:20:WU01:FS01:0xa7:Unit: 0x00000035cedfaa925eac9dbffaaad5cb
03:54:20:WU01:FS01:0xa7:Reading tar file core.xml
03:54:20:WU01:FS01:0xa7:Reading tar file frame42.tpr
03:54:20:WU01:FS01:0xa7:Digital signatures verified
03:54:20:WU01:FS01:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
03:54:20:WU01:FS01:0xa7:Calling: mdrun -s frame42.tpr -o frame42.trr -x frame42.xtc -cpt 15 -nt 6
03:54:20:WU01:FS01:0xa7:Steps: first=10500000 total=250000
03:54:21:WU01:FS01:0xa7:Completed 1 out of 250000 steps (0%)
03:55:09:WU01:FS01:0xa7:Completed 2500 out of 250000 steps (1%)
03:55:58:WU01:FS01:0xa7:Completed 5000 out of 250000 steps (2%)
03:56:48:WU01:FS01:0xa7:Completed 7500 out of 250000 steps (3%)
05:13:23:WU01:FS01:0xa7:Completed 242500 out of 250000 steps (97%)
05:14:12:WU01:FS01:0xa7:Completed 245000 out of 250000 steps (98%)
05:15:01:WU01:FS01:0xa7:Completed 247500 out of 250000 steps (99%)
05:15:49:WU01:FS01:0xa7:Completed 250000 out of 250000 steps (100%)
05:15:50:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:15:50:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14259 run:0 clone:1330 gen:42 core:0xa7 unit:0x00000035cedfaa925eac9dbffaaad5cb
05:15:50:WU01:FS01:Uploading 2.84MiB to 206.223.170.146
05:15:50:WU01:FS01:Connecting to 206.223.170.146:8080
05:15:56:WU01:FS01:Upload 76.98%
05:15:58:WU01:FS01:Upload complete
05:15:58:WU01:FS01:Server responded WORK_ACK (400)
05:15:58:WU01:FS01:Final credit estimate, 5215.00 points
05:15:58:WU01:FS01:Cleaning up
comixgoddess
Re: missing credit server 206.223.170.146
Post by comixgoddess »
I have the exact same issue with the following -
07/18/2020 project:14255 run:0 clone:494 gen:230
07/23/2020 project:14255 run:0 clone:528 gen:279
In both instances, I received the "WORK_ACK" response and a final credit estimate, but no points and the work units couldn't be found on the WU Status page.
Post by Neil-B »
Delays can occur sometimes (these can be days, weeks or even months) which can be due a number of issues but at some point someone will kick the server and the stats will catch up ... Given it is just a stats "glitch" this kind of issue tends to take lower priority that issues such as servers being down ... Reporting it is good as it lets the team know that there is a sort out to do.
comixgoddess
Received credit for all three of my work units earlier today. Thanks for giving the server a nudge! :ewink:
SetiCrew486
Post by SetiCrew486 »
Maybe someone should have a look at the server again ...
These WUs of mine still seem to be stuck:
07/28/2020 project:14256 run:0 clone:1650 gen:187
07/29/2020 project:14236 run:545 clone:4 gen:2
I guess I'll just wait a little longer ...
“Knowledge is knowing that a tomato is a fruit; wisdom is not putting it in a fruit salad.” ― Miles Kington
Post by Neil-B »
Sorting out these issues (stats are of less immediate urgency than say assignment issues) can sometimes take time (weeks not days) to sort ... but they do get sorted - just need to be patient
SetiCrew486
No problem.
But as you said
Neil-B wrote:Reporting it is good as it lets the team know that there is a sort out to do.
I just wanted to mention that there is still not everything in order (assumed that someone looked at the server already, as comixgoddess' post indicates).
Of course I 'm aware that stats issues have a very low priority ... science first :biggrin:
comixgoddess
Just letting you know the server may need another nudge. Starting August 1, I now have six WUs that have made it back to the server without points being credited.
08/01/20 03:41 project:14236 run:290 clone:0 gen:157
08/01/20 22:22 project:14217 run:843 clone:2 gen:20
08/02/20 20:33 project:14217 run:223 clone:3 gen:16
08/03/20 06:39 project:14259 run:0 clone:1137 gen:122
08/04/20 02:21 project:14216 run:318 clone:0 gen:202
08/04/20 16:40 project:14217 run:887 clone:0 gen:201
Hopfgeist
Hardware configuration: Dell T420, 2x Xeon E5-2470 v2, NetBSD 10, SunFire X2270 M2, 2x Xeon X5675, NetBSD 9; various other Linux/NetBSD PCs, Macs and virtual servers.
WU P:14256,R:0,C:405,G:325 on 206.223.170.146 not credited
Post by Hopfgeist »
Hi,
it seems that the above work unit was not credited in the stats. I know this is low-priority, and I'm not complaining, just letting you know. See the log excerpt below for details.
Assignment Server: 18.218.241.186:80 (after failure from 65.254.110.245:8080)
Work Server: 206.223.170.146
WU: project:14256 run:0 clone:405 gen:325
Date/Time of Download completion: 2020-08-03T19:55:17Z
Date/Time of Upload acknowledgment: 2020-08-04T18:59:53Z
Results are not shown under https://apps.foldingathome.org/wu?p=142 ... 05&gen=325 as of now (2020-08-05T09:47:00Z)
Here are the gory details (omissions are from "WU00", handling previous and following work units and not relevant to this case):
******************************* Date: 2020-08-03 *******************************
19:55:14:WU01:FS00:Connecting to 65.254.110.245:8080
19:55:14:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Empty work server assignment
19:55:14:WU01:FS00:Connecting to 18.218.241.186:80
19:55:15:WU01:FS00:Assigned to work server 206.223.170.146
19:55:15:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:1 from 206.223.170.146
19:55:15:WU01:FS00:Connecting to 206.223.170.146:8080
19:55:17:WU01:FS00:Download complete
19:55:17:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14256 run:0 clone:405 gen:325 core:0xa7 unit:0x00000180cedfaa925eac9f54d60cb3a8
19:55:17:WU01:FS00:Starting
19:55:17:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/bernd/FAH/cores/cores.foldingathome.org/lin/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 1006 -checkpoint 15
19:55:17:WU01:FS00:Started FahCore on PID 20880
19:55:17:WU01:FS00:Core PID:20884
19:55:17:WU01:FS00:FahCore 0xa7 started
19:55:17:WU01:FS00:0xa7:*********************** Log Started 2020-08-03T19:55:17Z ***********************
19:55:17:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:55:17:WU01:FS00:0xa7:       Type: 0xa7
19:55:17:WU01:FS00:0xa7:       Core: Gromacs
19:55:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 20880 -checkpoint 15
19:55:17:WU01:FS00:0xa7:************************************ CBang *************************************
19:55:17:WU01:FS00:0xa7:       Date: Nov 27 2019
19:55:17:WU01:FS00:0xa7:       Time: 11:26:54
19:55:17:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
19:55:17:WU01:FS00:0xa7:     Branch: master
19:55:17:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
19:55:17:WU01:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
19:55:17:WU01:FS00:0xa7:             -fno-pie -fPIC
19:55:17:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
19:55:17:WU01:FS00:0xa7:       Bits: 64
19:55:17:WU01:FS00:0xa7:       Mode: Release
19:55:17:WU01:FS00:0xa7:************************************ System ************************************
19:55:17:WU01:FS00:0xa7:        CPU: QEMU Virtual CPU version 2.5+
19:55:17:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 6 Stepping 3
19:55:17:WU01:FS00:0xa7:       CPUs: 1
19:55:17:WU01:FS00:0xa7:     Memory: 1.95GiB
19:55:17:WU01:FS00:0xa7:Free Memory: 225.54MiB
19:55:17:WU01:FS00:0xa7:    Threads: POSIX_THREADS
19:55:17:WU01:FS00:0xa7: OS Version: 4.15
19:55:17:WU01:FS00:0xa7:Has Battery: false
19:55:17:WU01:FS00:0xa7: On Battery: false
19:55:17:WU01:FS00:0xa7: UTC Offset: 2
19:55:17:WU01:FS00:0xa7:        PID: 20884
19:55:17:WU01:FS00:0xa7:        CWD: /home/bernd/FAH/work
19:55:17:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
19:55:17:WU01:FS00:0xa7:    Version: 0.0.19
19:55:17:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:55:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
19:55:17:WU01:FS00:0xa7:       Date: Nov 26 2019
19:55:17:WU01:FS00:0xa7:       Time: 00:41:43
19:55:17:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
19:55:17:WU01:FS00:0xa7:************************************ Build *************************************
19:55:17:WU01:FS00:0xa7:       SIMD: sse2
19:55:17:WU01:FS00:0xa7:********************************************************************************
19:55:17:WU01:FS00:0xa7:Project: 14256 (Run 0, Clone 405, Gen 325)
19:55:17:WU01:FS00:0xa7:Unit: 0x00000180cedfaa925eac9f54d60cb3a8
19:55:17:WU01:FS00:0xa7:Reading tar file core.xml
19:55:17:WU01:FS00:0xa7:Reading tar file frame325.tpr
19:55:17:WU01:FS00:0xa7:Digital signatures verified
19:55:17:WU01:FS00:0xa7:Calling: mdrun -s frame325.tpr -o frame325.trr -x frame325.xtc -cpt 15 -nt 1
19:55:17:WU01:FS00:0xa7:Steps: first=81250000 total=250000
19:55:19:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:08:33:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
******************************* Date: 2020-08-04 *******************************
18:59:44:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:59:47:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
18:59:47:WU01:FS00:0xa7:Saving result file frame325.trr
18:59:47:WU01:FS00:0xa7:Saving result file frame325.xtc
18:59:47:WU01:FS00:0xa7:Saving result file md.log
18:59:47:WU01:FS00:0xa7:Saving result file science.log
18:59:47:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:59:47:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:59:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14256 run:0 clone:405 gen:325 core:0xa7 unit:0x00000180cedfaa925eac9f54d60cb3a8
18:59:47:WU01:FS00:Uploading 2.83MiB to 206.223.170.146
18:59:47:WU01:FS00:Connecting to 206.223.170.146:8080
18:59:53:WU01:FS00:Upload complete
18:59:53:WU01:FS00:Server responded WORK_ACK (400)
18:59:53:WU01:FS00:Final credit estimate, 1266.00 points
18:59:53:WU01:FS00:Cleaning up
Thanks for making this work so well overall!
Cheers,
HG
Dell PowerEdge T420: 2x Xeon E5-2470 v2
Severian
Post by Severian »
It seems that the server is down now.
07:25:22:WU02:FS00:Connecting to 206.223.170.146:8080
07:25:25:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
07:25:25:WU02:FS00:Connecting to 206.223.170.146:80
07:25:28:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Aucune connexion na pu tre tablie car lordinateur cible la expressment refuse.
Welcome to the F@H Forum Severian,
Thanks for your report. I have informed the person responsible.
psaam0001
Post by psaam0001 »
Actually, it would have to be the CS at TCP/IP v4.0 Address: 52.224.109.74. As I have a job waiting to go there as I write this.
Paul
psaam0001 wrote:Actually, it would have to be the CS at TCP/IP v4.0 Address: 52.224.109.74. As I have a job waiting to go there as I write this.
Paul
Is the WU trying to go to its WS first? I am assuming from the report that 206.223.170.146 is the WS.
psaam0001
Post by psaam0001 »
As I'm not near that computer at the moment, I will presume so.
Paul
Update: I just checked a different system, and it will have 2 WU's from that WS going to the CS I mentioned above within the next 17.5-19.0 hours. I'll keep an eye on them where possible to see if they get stuck too.
psaam0001
Post by psaam0001 »
Ok, so I have checked the system that I initially reported the issue from, and it looks like it was trying to connect to the CS to send the results back. A partial log with the relevant information is posted below:
06:38:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
06:38:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
06:39:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
06:39:35:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
07:25:51:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
07:26:12:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
07:26:33:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
08:25:51:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
08:26:12:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
08:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
09:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
09:26:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
09:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2020-08-07 *******************************
10:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
10:26:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
11:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
11:26:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
11:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:25:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
12:25:51:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
12:26:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
12:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:25:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
13:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
13:26:14:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
13:26:35:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:25:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
14:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
14:26:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
14:26:34:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:25:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:25:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
15:26:14:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:26:35:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:25:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
16:25:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
16:26:14:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
16:26:35:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:25:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
17:25:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
17:26:15:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
17:26:36:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:25:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
18:25:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
18:26:14:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
18:26:35:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:25:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
19:25:54:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: No connection could be made because the target machine actively refused it.
19:26:15:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
19:26:36:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Paul
Reason: added Code tags to log
