Ellesmere XT Cards Directed to Work Server 192.0.2.1
RX 580s not folding
I've got 2 systems with RX 580s that just stopped folding, they're getting "WorkServer connection failed on port 8080 trying 80
23:13:03:WU01:FS01:Connecting to 192.0.2.1:80" like they're not able to fold. Did something happen?
192.0.2.1 Work Server
The Assignment Server is sending out Work Server requests for 192.0.2.1, which is for obvious reasons going to be an issue.
23:19:08:WU02:FS01:Connecting to assign1.foldingathome.org:80
23:19:08:WU02:FS01:Assigned to work server 192.0.2.1
23:19:08:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:19:08:WU02:FS01:Connecting to 192.0.2.1:8080
23:19:29:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
23:19:29:WU02:FS01:Connecting to 192.0.2.1:80
23:19:51:ERROR:WU02:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Re: 192.0.2.1 Work Server
192.0.2.1 indicates an un supported GPU setup.
You don't give us the configuration portion of your log, so we can't see what you have configured, so our ability to guess is very limited.
https://www.techpowerup.com/gpu-specs/r ... -470.c2861
The hardware supports OpenCL 1.2 and 64 bit (Double Precision) floating point math, so it can fold. It is possible you do not have a driver that supports OpenCL, we can't know.
If giving us enough clues to help is out of the question,you could install a new driver directly from AMD. (I would link the right driver if I knew what OS you are running)
I am inquiring about changes at the server.
Re: RX 580s not folding
Welcome to Folding@Home!
It will be fastest if you post the first 200 lines of your log so we can see your PC setup and configuration.
viewtopic.php?f=24&t=26036
That link should have instructions for what ever OS you use.
*********************** Log Started 2020-07-24T23:02:29Z ***********************
23:02:29:Trying to access database...
23:02:29:Successfully acquired database lock
23:02:29:Downloading GPUs.txt from assign1.foldingathome.org:80
23:02:29:Connecting to assign1.foldingathome.org:80
23:02:30:Read GPUs.txt
23:02:30:Enabled folding slot 00: READY cpu:10
23:02:30:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:02:30:****************************** FAHClient ******************************
23:02:30: Version: 7.6.13
23:02:30: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:02:30: Copyright: 2020 foldingathome.org
23:02:30: Homepage: https://foldingathome.org/
23:02:30: Date: Apr 27 2020
23:02:30: Time: 21:21:01
23:02:30: Revision: 5a652817f46116b6e135503af97f18e094414e3b
23:02:30: Branch: master
23:02:30: Compiler: Visual C++ 2008
23:02:30: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:02:30: Platform: win32 10
23:02:30: Bits: 32
23:02:30: Mode: Release
23:02:30: Args: --open-web-control
23:02:30: Config: C:\Users\raffy\AppData\Roaming\FAHClient\config.xml
23:02:30:******************************** CBang ********************************
23:02:30: Date: Apr 24 2020
23:02:30: Time: 17:07:55
23:02:30: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
23:02:30: Bits: 32
23:02:30:******************************* System ********************************
23:02:30: CPU: AMD Ryzen 5 1600 Six-Core Processor
23:02:30: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:02:30: CPUs: 12
23:02:30: Memory: 15.95GiB
23:02:30: Free Memory: 11.35GiB
23:02:30: Threads: WINDOWS_THREADS
23:02:30: OS Version: 6.2
23:02:30: Has Battery: false
23:02:30: On Battery: false
23:02:30: UTC Offset: -4
23:02:30: PID: 32
23:02:30: CWD: C:\Users\raffy\AppData\Roaming\FAHClient
23:02:30: Win32 Service: false
23:02:30: OS: Windows 10 Enterprise
23:02:30: OS Arch: AMD64
23:02:30: GPUs: 1
23:02:30: GPU 0: Bus:9 Slot:0 Func:0 AMD:4 Ellesmere XT [Radeon RX
23:02:30: 470/480/570/580/590]
23:02:30: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:02:30: specified module could not be found.
23:02:30:
23:02:30:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3075.12
23:02:30:******************************* libFAH ********************************
23:02:30: Date: Apr 15 2020
23:02:30: Time: 14:53:14
23:02:30: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:02:30: Bits: 32
23:02:30:***********************************************************************
23:02:30:<config>
23:02:30: <!-- Network -->
23:02:30: <proxy v=':8080'/>
23:02:30:
23:02:30: <!-- Slot Control -->
23:02:30: <power v='full'/>
23:02:30:
23:02:30: <!-- User Information -->
23:02:30: <passkey v='*****'/>
23:02:30: <team v='111065'/>
23:02:30: <user v='Braffy'/>
23:02:30:
23:02:30: <!-- Folding Slots -->
23:02:30: <slot id='0' type='CPU'>
23:02:30: <cpus v='10'/>
23:02:30: </slot>
23:02:30: <slot id='1' type='GPU'/>
23:02:30:</config>
23:02:30:WARNING:WU02:FS00:Past final deadline 2020-07-24T18:02:27Z, dumping
23:02:30:WU02:FS00:Cleaning up
23:02:30:WU00:FS00:Connecting to assign1.foldingathome.org:80
23:02:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:02:31:WU01:FS01:Assigned to work server 192.0.2.1
23:02:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:02:31:WU00:FS00:Assigned to work server 168.245.198.125
23:02:31:WU01:FS01:Connecting to 192.0.2.1:8080
23:02:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 168.245.198.125
23:02:31:WU00:FS00:Connecting to 168.245.198.125:8080
23:02:32:WU00:FS00:Downloading 8.31MiB
23:02:34:WU00:FS00:Download complete
23:02:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16424 run:497 clone:1 gen:71 core:0xa7 unit:0x00000058a8f5c67d5e8f69b3da9adcda
23:02:34:WU00:FS00:Starting
23:02:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\raffy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 32 -checkpoint 15 -np 10
23:02:34:WU00:FS00:Started FahCore on PID 964
23:02:34:WU00:FS00:Core PID:7236
23:02:34:WU00:FS00:FahCore 0xa7 started
23:02:34:18:127.0.0.1:New Web session
23:02:35:WU00:FS00:0xa7:*********************** Log Started 2020-07-24T23:02:34Z ***********************
23:02:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:02:35:WU00:FS00:0xa7: Type: 0xa7
23:02:35:WU00:FS00:0xa7: Core: Gromacs
23:02:35:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 964 -checkpoint 15 -np 10
23:02:35:WU00:FS00:0xa7:************************************ CBang *************************************
23:02:35:WU00:FS00:0xa7: Date: Nov 27 2019
23:02:35:WU00:FS00:0xa7: Time: 03:40:09
23:02:35:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
23:02:35:WU00:FS00:0xa7: Branch: master
23:02:35:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:02:35:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:02:35:WU00:FS00:0xa7: Platform: win32 10
23:02:35:WU00:FS00:0xa7: Bits: 64
23:02:35:WU00:FS00:0xa7: Mode: Release
23:02:35:WU00:FS00:0xa7:************************************ System ************************************
23:02:35:WU00:FS00:0xa7: CPU: AMD Ryzen 5 1600 Six-Core Processor
23:02:35:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:02:35:WU00:FS00:0xa7: CPUs: 12
23:02:35:WU00:FS00:0xa7: Memory: 15.95GiB
23:02:35:WU00:FS00:0xa7:Free Memory: 11.25GiB
23:02:35:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:02:35:WU00:FS00:0xa7: OS Version: 6.2
23:02:35:WU00:FS00:0xa7:Has Battery: false
23:02:35:WU00:FS00:0xa7: On Battery: false
23:02:35:WU00:FS00:0xa7: UTC Offset: -4
23:02:35:WU00:FS00:0xa7: PID: 7236
23:02:35:WU00:FS00:0xa7: CWD: C:\Users\raffy\AppData\Roaming\FAHClient\work
23:02:35:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:02:35:WU00:FS00:0xa7: Version: 0.0.19
23:02:35:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:02:35:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:02:35:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:02:35:WU00:FS00:0xa7: Date: Nov 25 2019
23:02:35:WU00:FS00:0xa7: Time: 17:12:41
23:02:35:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
23:02:35:WU00:FS00:0xa7:************************************ Build *************************************
23:02:35:WU00:FS00:0xa7: SIMD: avx_256
23:02:35:WU00:FS00:0xa7:********************************************************************************
23:02:35:WU00:FS00:0xa7:Project: 16424 (Run 497, Clone 1, Gen 71)
23:02:35:WU00:FS00:0xa7:Unit: 0x00000058a8f5c67d5e8f69b3da9adcda
23:02:35:WU00:FS00:0xa7:Reading tar file core.xml
23:02:35:WU00:FS00:0xa7:Reading tar file frame71.tpr
23:02:35:WU00:FS00:0xa7:Digital signatures verified
23:02:35:WU00:FS00:0xa7:Calling: mdrun -s frame71.tpr -o frame71.trr -x frame71.xtc -cpt 15 -nt 10
23:02:35:WU00:FS00:0xa7:Steps: first=17750000 total=250000
23:02:37:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:02:44:Removing old file 'configs/config-20200711-031944.xml'
23:02:44:Saving configuration to config.xml
23:02:44:<config>
23:02:44: <!-- Network -->
23:02:44: <proxy v=':8080'/>
23:02:44:
23:02:44: <!-- Slot Control -->
23:02:44: <power v='full'/>
23:02:44:
23:02:44: <!-- User Information -->
23:02:44: <passkey v='*****'/>
23:02:44: <team v='111065'/>
23:02:44: <user v='Braffy'/>
23:02:44:
23:02:44: <!-- Folding Slots -->
23:02:44: <slot id='1' type='GPU'/>
23:02:44:</config>
23:02:44:FS00:Shutting core down
23:02:45:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7236
23:02:45:WU00:FS00:0xa7:Exiting, please wait. . .
23:02:47:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:02:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:02:47:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
23:02:47:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:16424 run:497 clone:1 gen:71 core:0xa7 unit:0x00000058a8f5c67d5e8f69b3da9adcda
23:02:47:WU00:Connecting to 168.245.198.125:8080
23:02:49:WU00:Server responded WORK_ACK (400)
23:02:49:WU00:Cleaning up
23:02:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:02:52:WU01:FS01:Connecting to 192.0.2.1:80
23:03:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:03:13:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:03:14:WU01:FS01:Assigned to work server 192.0.2.1
23:03:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:03:14:WU01:FS01:Connecting to 192.0.2.1:8080
23:03:30:Removing old file 'configs/config-20200711-231924.xml'
23:03:30:Saving configuration to config.xml
23:03:30:<config>
23:03:30: <!-- Network -->
23:03:30: <proxy v=':8080'/>
23:03:30:
23:03:30: <!-- Slot Control -->
23:03:30: <power v='full'/>
23:03:30:
23:03:30: <!-- User Information -->
23:03:30: <passkey v='*****'/>
23:03:30: <team v='111065'/>
23:03:30: <user v='Braffy'/>
23:03:30:
23:03:30: <!-- Folding Slots -->
23:03:30: <slot id='1' type='GPU'/>
23:03:30:</config>
23:03:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:03:35:WU01:FS01:Connecting to 192.0.2.1:80
23:03:56:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:04:14:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:04:14:WU01:FS01:Assigned to work server 192.0.2.1
23:04:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:04:14:WU01:FS01:Connecting to 192.0.2.1:8080
23:04:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:04:35:WU01:FS01:Connecting to 192.0.2.1:80
23:04:56:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:05:51:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:05:51:WU01:FS01:Assigned to work server 192.0.2.1
23:05:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:05:51:WU01:FS01:Connecting to 192.0.2.1:8080
23:06:12:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:06:12:WU01:FS01:Connecting to 192.0.2.1:80
23:06:33:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:08:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:08:28:WU01:FS01:Assigned to work server 192.0.2.1
23:08:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:08:28:WU01:FS01:Connecting to 192.0.2.1:8080
23:08:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:08:49:WU01:FS01:Connecting to 192.0.2.1:80
23:09:10:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:12:42:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:12:42:WU01:FS01:Assigned to work server 192.0.2.1
23:12:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:12:42:WU01:FS01:Connecting to 192.0.2.1:8080
23:13:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:13:24:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:19:34:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:19:34:WU01:FS01:Assigned to work server 192.0.2.1
23:19:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:19:34:WU01:FS01:Connecting to 192.0.2.1:8080
23:19:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:19:55:WU01:FS01:Connecting to 192.0.2.1:80
23:20:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:30:39:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:30:39:WU01:FS01:Assigned to work server 192.0.2.1
23:30:39:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:30:39:WU01:FS01:Connecting to 192.0.2.1:8080
23:31:00:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:31:00:WU01:FS01:Connecting to 192.0.2.1:80
23:31:22:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:48:36:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:48:36:WU01:FS01:Assigned to work server 192.0.2.1
23:48:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:48:36:WU01:FS01:Connecting to 192.0.2.1:8080
23:48:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:48:57:WU01:FS01:Connecting to 192.0.2.1:80
23:49:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
These setups have been running for months, and all the other, exactly the same GPUs, as can be seen in the log, are folding fine on the same machines at the same time in the other slots, so since this 192 thing suddenly happened on several different machines when requesting a new WU in the last few hours, I am guessing the AS has a hiccup.
As i said earlier, without being able to see your configuration, it is hard to see where the process is failing. Consider helping us see the problem.
The log tells you where it is failing, the slots asks for a new WU assignment after finishing the previous one, then gets a WU assignment for 192.0.2.1, makes the directory in the work folder, but there is nothing to download, since the IP is invalid.
Well, I can hope one of the others with the problem will post the configuration portion of the log.
The fact that it just started to happen on several already running systems should probably tell you something.
23:27:43:Trying to access database...
23:27:43:Successfully acquired database lock
23:27:43:Read GPUs.txt
23:27:46:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 02: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 03: READY gpu:2:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 05: READY gpu:4:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 06: READY gpu:5:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 07: READY gpu:6:Ellesmere XT [Radeon RX 470/480/570/580/590]
23:27:46:Enabled folding slot 08: PAUSED gpu:7:Ellesmere XT [Radeon RX 470/480/570/580/590] (by user)
23:27:46:Enabled folding slot 09: PAUSED gpu:8:Ellesmere XT [Radeon RX 470/480/570/580/590] (by user)
23:27:46:****************************** FAHClient ******************************
23:27:46: Version: 7.6.13
23:27:46: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:27:46: Copyright: 2020 foldingathome.org
23:27:46: Homepage: https://foldingathome.org/
23:27:46: Date: Apr 27 2020
23:27:46: Time: 21:21:01
23:27:46: Revision: 5a652817f46116b6e135503af97f18e094414e3b
23:27:46: Branch: master
23:27:46: Compiler: Visual C++ 2008
23:27:46: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:27:46: Platform: win32 10
23:27:46: Bits: 32
23:27:46: Mode: Release
23:27:46: Args: --open-web-control
23:27:46: Config: C:\Users\Admin\AppData\Roaming\FAHClient\config.xml
23:27:46:******************************** CBang ********************************
23:27:46: Date: Apr 24 2020
23:27:46: Time: 17:07:55
23:27:46: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
23:27:46: Bits: 32
23:27:46:******************************* System ********************************
23:27:46: CPU: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz
23:27:46: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:27:46: CPUs: 4
23:27:46: Memory: 15.69GiB
23:27:46: Free Memory: 13.22GiB
23:27:46: Threads: WINDOWS_THREADS
23:27:46: OS Version: 6.2
23:27:46: Has Battery: false
23:27:46: On Battery: false
23:27:46: UTC Offset: 2
23:27:46: PID: 7300
23:27:46: CWD: C:\Users\Admin\AppData\Roaming\FAHClient
23:27:46: Win32 Service: false
23:27:46: OS: Windows 10 Enterprise
23:27:46: OS Arch: AMD64
23:27:46: GPUs: 9
23:27:46: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: 470/480/570/580/590]
23:27:46: GPU 1: Bus:12 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 2: Bus:13 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 3: Bus:9 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 4: Bus:2 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 5: Bus:11 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 6: Bus:10 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 7: Bus:3 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: GPU 8: Bus:7 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:27:46: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:27:46: specified module could not be found.
23:27:46:
23:27:46:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 2: Platform:0 Device:2 Bus:11 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 3: Platform:0 Device:3 Bus:13 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 4: Platform:0 Device:4 Bus:3 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 5: Platform:0 Device:5 Bus:12 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 6: Platform:0 Device:6 Bus:10 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 7: Platform:0 Device:7 Bus:9 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:OpenCL Device 8: Platform:0 Device:8 Bus:7 Slot:0 Compute:1.2 Driver:3004.8
23:27:46:******************************* libFAH ********************************
23:27:46: Date: Apr 15 2020
23:27:46: Time: 14:53:14
23:27:46: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:27:46: Bits: 32
23:27:46:***********************************************************************
23:27:46:<config>
23:27:46: <!-- Folding Slot Configuration -->
23:27:46: <cause v='HIGH_PRIORITY'/>
23:27:46:
23:27:46: <!-- HTTP Server -->
23:27:46: <allow v='127.0.0.1 10.0.0.76'/>
23:27:46: <deny v=''/>
23:27:46:
23:27:46: <!-- Network -->
23:27:46: <proxy v=':8080'/>
23:27:46:
23:27:46: <!-- Remote Command Server -->
23:27:46: <command-allow-no-pass v='127.0.0.1 10.0.0.76'/>
23:27:46: <command-deny-no-pass v=''/>
23:27:46: <password v='*****'/>
23:27:46:
23:27:46: <!-- Slot Control -->
23:27:46: <power v='full'/>
23:27:46:
23:27:46: <!-- User Information -->
23:27:46: <passkey v='*****'/>
23:27:46: <team v='37651'/>
23:27:46: <user v='Sparkly'/>
23:27:46:
23:27:46: <!-- Folding Slots -->
23:27:46: <slot id='1' type='GPU'/>
23:27:46: <slot id='2' type='GPU'/>
23:27:46: <slot id='3' type='GPU'/>
23:27:46: <slot id='4' type='GPU'/>
23:27:46: <slot id='5' type='GPU'/>
23:27:46: <slot id='6' type='GPU'/>
23:27:46: <slot id='7' type='GPU'/>
23:27:46: <slot id='8' type='GPU'>
23:27:46: <paused v='true'/>
23:27:46: </slot>
23:27:46: <slot id='9' type='GPU'>
23:27:46: </slot>
23:27:46:</config>
I thank you for posting your log. It will help convince F@H experts that it is not a mere error on the client.
Dual rx470's, same problem here. Figured it was just a shortage of work units, or is this a different issue?
- Hardware configuration: MB: ASRock X570 Phantom Gaming X
CPU: AMD Ryzen 9 3950X
GPU: MSI Radeon VII, GIGABYTE AORUS Radeon RX 580
RAM: 32GB G.SKILL Ripjaws V DDR4-3200
SSD: 2x 1TB Sabrent Rocket NVMe PCIe 4.0 RAID0
PSU: CORSAIR AX1600i Digital
OS: Windows 10 Enterprise x64 v2004
MB: ASRock Fatal1ty X370 Gaming X
CPU: AMD Ryzen 7 1800X
GPU: 2x VisionTek Radeon RX 480 8GB
SSD: 3x 250GB Samsung 960 EVO NVMe PCIe 3.0 RAID0
PSU: Rosewill HERCULES-1600s
OS: Windows 10 Enterprise x64 v1909
MB: ASUS P8Z68 DELUXE/GEN3
CPU: Intel Core i7-2700K
GPU: Sapphire Radeon HD 7870 3GB
RAM: 16GB G.SKILL Ripjaws Z DDR3-2133
HDD: 2x 128GB Transcend SSD320 RAID0
PSU: Cooler Master SPG 1200w
MB: Gigabyte GA-EX38-DQ6
CPU: Intel Core 2 Quad Q6600
GPU: VisionTek Radeon HD 6870 1GB DDR5
RAM: 4GB Kingston HyperX DDR2-1066
HDD: 2TB Hitachi
PSU: Raidmax RX-850AE 850W
OS: Windows 7 Ultimate SP2
One system has a RX 580 and a Radeon VII, and the other has two RX 480's. The Radeon VII is the only card which is still receiving WU's. Has support for Radeon RX 470/480/570/580/590 abruptly come to an end?
The code below is from the machine with the 480's.
The code below is from the machine with the RX 580 and Radeon VII.
16:19:33:WU01:FS00:Starting
16:19:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 17208 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:19:33:WU01:FS00:Started FahCore on PID 78180
16:19:33:WU01:FS00:Core PID:68416
16:19:33:WU01:FS00:FahCore 0x22 started
16:19:34:WU01:FS00:0x22:*********************** Log Started 2020-07-24T16:19:34Z ***********************
16:19:34:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
16:19:34:WU01:FS00:0x22: Core: Core22
16:19:34:WU01:FS00:0x22: Type: 0x22
16:19:34:WU01:FS00:0x22: Version: 0.0.11
16:19:34:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:19:34:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
16:19:34:WU01:FS00:0x22: Homepage: https://foldingathome.org/
16:19:34:WU01:FS00:0x22: Date: Jun 26 2020
16:19:34:WU01:FS00:0x22: Time: 19:49:16
16:19:34:WU01:FS00:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
16:19:34:WU01:FS00:0x22: Branch: core22-0.0.11
16:19:34:WU01:FS00:0x22: Compiler: Visual C++ 2015
16:19:34:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:19:34:WU01:FS00:0x22: Platform: win32 10
16:19:34:WU01:FS00:0x22: Bits: 64
16:19:34:WU01:FS00:0x22: Mode: Release
16:19:34:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:19:34:WU01:FS00:0x22: <peastman@stanford.edu>
16:19:34:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 78180 -checkpoint 30
16:19:34:WU01:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:19:34:WU01:FS00:0x22:************************************ libFAH ************************************
16:19:34:WU01:FS00:0x22: Time: 19:47:12
16:19:34:WU01:FS00:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
16:19:34:WU01:FS00:0x22: Branch: HEAD
16:19:34:WU01:FS00:0x22:************************************ CBang *************************************
16:19:34:WU01:FS00:0x22: Time: 19:46:11
16:19:34:WU01:FS00:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
16:19:34:WU01:FS00:0x22: Branch: master
16:19:34:WU01:FS00:0x22:************************************ System ************************************
16:19:34:WU01:FS00:0x22: CPU: AMD Ryzen 7 1800X Eight-Core Processor
16:19:34:WU01:FS00:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
16:19:34:WU01:FS00:0x22: CPUs: 16
16:19:34:WU01:FS00:0x22: Memory: 31.93GiB
16:19:34:WU01:FS00:0x22:Free Memory: 15.77GiB
16:19:34:WU01:FS00:0x22: Threads: WINDOWS_THREADS
16:19:34:WU01:FS00:0x22: OS Version: 6.2
16:19:34:WU01:FS00:0x22:Has Battery: false
16:19:34:WU01:FS00:0x22: On Battery: false
16:19:34:WU01:FS00:0x22: UTC Offset: -4
16:19:34:WU01:FS00:0x22: PID: 68416
16:19:34:WU01:FS00:0x22: CWD: C:\Users\AppData\Roaming\FAHClient\work
16:19:34:WU01:FS00:0x22:********************************************************************************
16:19:34:WU01:FS00:0x22:Project: 13416 (Run 339, Clone 206, Gen 3)
16:19:34:WU01:FS00:0x22:Unit: 0x0000000412bc7d9a5f0f8f6617eaa1dc
16:19:34:WU01:FS00:0x22:Reading tar file core.xml
16:19:34:WU01:FS00:0x22:Reading tar file integrator.xml
16:19:34:WU01:FS00:0x22:Reading tar file state.xml.bz2
16:19:34:WU01:FS00:0x22:Reading tar file system.xml.bz2
16:19:34:WU01:FS00:0x22:Digital signatures verified
16:19:34:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
16:19:34:WU01:FS00:0x22:Version 0.0.11
16:19:34:WU01:FS00:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
16:19:34:WU01:FS00:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
16:19:34:WU01:FS00:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
16:19:34:WU01:FS00:0x22: Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
16:19:39:WU02:FS00:Upload 96.60%
16:19:39:WU02:FS00:Upload complete
16:19:39:WU02:FS00:Server responded WORK_ACK (400)
16:19:39:WU02:FS00:Final credit estimate, 172388.00 points
16:19:39:WU02:FS00:Cleaning up
16:19:53:WU01:FS00:0x22:Completed 0 out of 1000000 steps (0%)
16:23:03:WU00:FS01:0x22:Completed 20000000 out of 25000000 steps (80%)
16:23:28:WU01:FS00:0x22:Completed 10000 out of 1000000 steps (1%)
16:27:02:WU01:FS00:0x22:Completed 20000 out of 1000000 steps (2%)
16:28:39:WU00:FS01:0x22:Completed 20250000 out of 25000000 steps (81%)
16:30:36:WU01:FS00:0x22:Completed 30000 out of 1000000 steps (3%)
16:34:09:WU01:FS00:0x22:Completed 40000 out of 1000000 steps (4%)
16:34:14:WU00:FS01:0x22:Completed 20500000 out of 25000000 steps (82%)
16:37:44:WU01:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
16:39:49:WU00:FS01:0x22:Completed 20750000 out of 25000000 steps (83%)
16:41:18:WU01:FS00:0x22:Completed 60000 out of 1000000 steps (6%)
16:44:52:WU01:FS00:0x22:Completed 70000 out of 1000000 steps (7%)
16:45:25:WU00:FS01:0x22:Completed 21000000 out of 25000000 steps (84%)
16:48:26:WU01:FS00:0x22:Completed 80000 out of 1000000 steps (8%)
16:51:01:WU00:FS01:0x22:Completed 21250000 out of 25000000 steps (85%)
16:52:00:WU01:FS00:0x22:Completed 90000 out of 1000000 steps (9%)
16:55:34:WU01:FS00:0x22:Completed 100000 out of 1000000 steps (10%)
16:56:37:WU00:FS01:0x22:Completed 21500000 out of 25000000 steps (86%)
16:59:09:WU01:FS00:0x22:Completed 110000 out of 1000000 steps (11%)
17:02:12:WU00:FS01:0x22:Completed 21750000 out of 25000000 steps (87%)
17:02:42:WU01:FS00:0x22:Completed 120000 out of 1000000 steps (12%)
17:06:17:WU01:FS00:0x22:Completed 130000 out of 1000000 steps (13%)
17:07:48:WU00:FS01:0x22:Completed 22000000 out of 25000000 steps (88%)
17:09:51:WU01:FS00:0x22:Completed 140000 out of 1000000 steps (14%)
17:13:23:WU00:FS01:0x22:Completed 22250000 out of 25000000 steps (89%)
17:13:25:WU01:FS00:0x22:Completed 150000 out of 1000000 steps (15%)
17:16:59:WU01:FS00:0x22:Completed 160000 out of 1000000 steps (16%)
17:18:58:WU00:FS01:0x22:Completed 22500000 out of 25000000 steps (90%)
17:20:33:WU01:FS00:0x22:Completed 170000 out of 1000000 steps (17%)
17:24:07:WU01:FS00:0x22:Completed 180000 out of 1000000 steps (18%)
17:24:33:WU00:FS01:0x22:Completed 22750000 out of 25000000 steps (91%)
17:27:41:WU01:FS00:0x22:Completed 190000 out of 1000000 steps (19%)
17:30:09:WU00:FS01:0x22:Completed 23000000 out of 25000000 steps (92%)
17:31:15:WU01:FS00:0x22:Completed 200000 out of 1000000 steps (20%)
17:34:50:WU01:FS00:0x22:Completed 210000 out of 1000000 steps (21%)
17:35:44:WU00:FS01:0x22:Completed 23250000 out of 25000000 steps (93%)
17:38:24:WU01:FS00:0x22:Completed 220000 out of 1000000 steps (22%)
17:41:20:WU00:FS01:0x22:Completed 23500000 out of 25000000 steps (94%)
17:41:58:WU01:FS00:0x22:Completed 230000 out of 1000000 steps (23%)
17:45:32:WU01:FS00:0x22:Completed 240000 out of 1000000 steps (24%)
17:46:56:WU00:FS01:0x22:Completed 23750000 out of 25000000 steps (95%)
17:49:06:WU01:FS00:0x22:Completed 250000 out of 1000000 steps (25%)
17:52:32:WU00:FS01:0x22:Completed 24000000 out of 25000000 steps (96%)
17:52:41:WU01:FS00:0x22:Completed 260000 out of 1000000 steps (26%)
17:56:16:WU01:FS00:0x22:Completed 270000 out of 1000000 steps (27%)
17:58:08:WU00:FS01:0x22:Completed 24250000 out of 25000000 steps (97%)
17:59:51:WU01:FS00:0x22:Completed 280000 out of 1000000 steps (28%)
18:03:26:WU01:FS00:0x22:Completed 290000 out of 1000000 steps (29%)
18:03:43:WU00:FS01:0x22:Completed 24500000 out of 25000000 steps (98%)
18:07:01:WU01:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
18:09:18:WU00:FS01:0x22:Completed 24750000 out of 25000000 steps (99%)
18:10:37:WU01:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
18:14:12:WU01:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
18:14:53:WU00:FS01:0x22:Completed 25000000 out of 25000000 steps (100%)
18:14:53:WU00:FS01:0x22:Average performance: 5.15206 ns/day
18:14:53:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:14:53:WU00:FS01:0x22:Saving result file checkpointState.xml
18:14:53:WU00:FS01:0x22:Saving result file positions.xtc
18:14:53:WU00:FS01:0x22:Saving result file science.log
18:14:53:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:14:54:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:14:54:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16915 run:36 clone:27 gen:3 core:0x22 unit:0x000000030002894c5effa2f2ce3d2d9f
18:14:54:WU00:FS01:Uploading 22.90MiB to 155.247.166.220
18:14:54:WU00:FS01:Connecting to 155.247.166.220:8080
18:14:54:WU02:FS01:Connecting to assign1.foldingathome.org:80
18:14:55:WU02:FS01:Assigned to work server 128.252.203.10
18:14:55:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
18:14:55:WU02:FS01:Connecting to 128.252.203.10:8080
18:14:57:WU02:FS01:Downloading 5.82MiB
18:14:58:WU02:FS01:Download complete
18:14:58:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:765 gen:135 core:0x22 unit:0x000000ef80fccb0a5e6d7cd0f0d48bf7
18:14:59:WU02:FS01:Starting
18:14:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 17208 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
18:14:59:WU02:FS01:Started FahCore on PID 94604
18:14:59:WU02:FS01:Core PID:93548
18:14:59:WU02:FS01:FahCore 0x22 started
18:14:59:WU02:FS01:0x22:*********************** Log Started 2020-07-24T18:14:59Z ***********************
18:14:59:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:14:59:WU02:FS01:0x22: Core: Core22
18:14:59:WU02:FS01:0x22: Type: 0x22
18:14:59:WU02:FS01:0x22: Version: 0.0.11
18:14:59:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:14:59:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
18:14:59:WU02:FS01:0x22: Homepage: https://foldingathome.org/
18:14:59:WU02:FS01:0x22: Date: Jun 26 2020
18:14:59:WU02:FS01:0x22: Time: 19:49:16
18:14:59:WU02:FS01:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
18:14:59:WU02:FS01:0x22: Branch: core22-0.0.11
18:14:59:WU02:FS01:0x22: Compiler: Visual C++ 2015
18:14:59:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:14:59:WU02:FS01:0x22: Platform: win32 10
18:14:59:WU02:FS01:0x22: Bits: 64
18:14:59:WU02:FS01:0x22: Mode: Release
18:14:59:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:14:59:WU02:FS01:0x22: <peastman@stanford.edu>
18:14:59:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 94604 -checkpoint 30
18:14:59:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
18:14:59:WU02:FS01:0x22:************************************ libFAH ************************************
18:14:59:WU02:FS01:0x22: Time: 19:47:12
18:14:59:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
18:14:59:WU02:FS01:0x22: Branch: HEAD
18:14:59:WU02:FS01:0x22:************************************ CBang *************************************
18:14:59:WU02:FS01:0x22: Time: 19:46:11
18:14:59:WU02:FS01:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
18:14:59:WU02:FS01:0x22: Branch: master
18:14:59:WU02:FS01:0x22:************************************ System ************************************
18:14:59:WU02:FS01:0x22: CPU: AMD Ryzen 7 1800X Eight-Core Processor
18:14:59:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
18:14:59:WU02:FS01:0x22: CPUs: 16
18:14:59:WU02:FS01:0x22: Memory: 31.93GiB
18:14:59:WU02:FS01:0x22:Free Memory: 15.27GiB
18:14:59:WU02:FS01:0x22: Threads: WINDOWS_THREADS
18:14:59:WU02:FS01:0x22: OS Version: 6.2
18:14:59:WU02:FS01:0x22:Has Battery: false
18:14:59:WU02:FS01:0x22: On Battery: false
18:14:59:WU02:FS01:0x22: UTC Offset: -4
18:14:59:WU02:FS01:0x22: PID: 93548
18:14:59:WU02:FS01:0x22: CWD: C:\Users\AppData\Roaming\FAHClient\work
18:14:59:WU02:FS01:0x22:********************************************************************************
18:14:59:WU02:FS01:0x22:Project: 11760 (Run 0, Clone 765, Gen 135)
18:14:59:WU02:FS01:0x22:Unit: 0x000000ef80fccb0a5e6d7cd0f0d48bf7
18:14:59:WU02:FS01:0x22:Reading tar file core.xml
18:14:59:WU02:FS01:0x22:Reading tar file integrator.xml
18:14:59:WU02:FS01:0x22:Reading tar file state.xml
18:14:59:WU02:FS01:0x22:Reading tar file system.xml
18:15:00:WU02:FS01:0x22:Digital signatures verified
18:15:00:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:15:00:WU02:FS01:0x22:Version 0.0.11
18:15:00:WU00:FS01:Upload 21.84%
18:15:00:WU02:FS01:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
18:15:00:WU02:FS01:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
18:15:00:WU02:FS01:0x22: XTC frame write interval: 50000 steps (2.5%) [40 total]
18:15:00:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
18:15:06:WU00:FS01:Upload 48.31%
18:15:10:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
18:15:12:WU00:FS01:Upload 73.15%
18:15:18:WU00:FS01:Upload 99.08%
18:15:18:WU00:FS01:Upload complete
18:15:19:WU00:FS01:Server responded WORK_ACK (400)
18:15:19:WU00:FS01:Final credit estimate, 94115.00 points
18:15:19:WU00:FS01:Cleaning up
18:17:17:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
18:17:49:WU01:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
18:19:22:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
18:21:26:WU01:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
18:21:28:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
18:23:34:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
18:25:03:WU01:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
18:25:40:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
18:27:46:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
18:28:41:WU01:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
18:29:52:WU02:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
18:31:57:WU02:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
18:32:18:WU01:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
18:34:03:WU02:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
18:35:55:WU01:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
18:36:09:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
18:38:15:WU02:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
18:39:33:WU01:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
18:40:21:WU02:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
18:42:26:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
18:43:10:WU01:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
18:44:33:WU02:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
18:46:38:WU02:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
18:46:48:WU01:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
18:48:44:WU02:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
18:50:26:WU01:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
18:50:50:WU02:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
18:52:55:WU02:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
18:54:03:WU01:FS00:0x22:Completed 430000 out of 1000000 steps (43%)
18:55:01:WU02:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
18:57:07:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
18:57:41:WU01:FS00:0x22:Completed 440000 out of 1000000 steps (44%)
18:59:13:WU02:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
19:01:18:WU01:FS00:0x22:Completed 450000 out of 1000000 steps (45%)
19:01:19:WU02:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
19:03:25:WU02:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
19:04:56:WU01:FS00:0x22:Completed 460000 out of 1000000 steps (46%)
19:05:31:WU02:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
19:07:37:WU02:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
19:08:33:WU01:FS00:0x22:Completed 470000 out of 1000000 steps (47%)
19:09:43:WU02:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
19:11:48:WU02:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
19:12:11:WU01:FS00:0x22:Completed 480000 out of 1000000 steps (48%)
19:13:54:WU02:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
19:15:48:WU01:FS00:0x22:Completed 490000 out of 1000000 steps (49%)
19:16:00:WU02:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
19:18:05:WU02:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
19:19:25:WU01:FS00:0x22:Completed 500000 out of 1000000 steps (50%)
19:20:12:WU02:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
******************************* Date: 2020-07-24 *******************************
19:22:18:WU02:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
19:23:02:WU01:FS00:0x22:Completed 510000 out of 1000000 steps (51%)
19:24:24:WU02:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
19:26:29:WU02:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
19:26:38:WU01:FS00:0x22:Completed 520000 out of 1000000 steps (52%)
19:28:35:WU02:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
19:30:14:WU01:FS00:0x22:Completed 530000 out of 1000000 steps (53%)
19:30:41:WU02:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
19:32:47:WU02:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
19:33:50:WU01:FS00:0x22:Completed 540000 out of 1000000 steps (54%)
19:34:53:WU02:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
19:36:59:WU02:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
19:37:26:WU01:FS00:0x22:Completed 550000 out of 1000000 steps (55%)
19:39:05:WU02:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
19:41:03:WU01:FS00:0x22:Completed 560000 out of 1000000 steps (56%)
19:41:11:WU02:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
19:43:17:WU02:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
19:44:39:WU01:FS00:0x22:Completed 570000 out of 1000000 steps (57%)
19:45:23:WU02:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
19:47:28:WU02:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
19:48:14:WU01:FS00:0x22:Completed 580000 out of 1000000 steps (58%)
19:49:34:WU02:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
19:51:40:WU02:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
19:51:50:WU01:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
19:53:46:WU02:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
19:55:26:WU01:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
19:55:52:WU02:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
19:57:58:WU02:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
19:59:03:WU01:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
20:00:04:WU02:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
20:02:10:WU02:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
20:02:39:WU01:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
20:04:16:WU02:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
20:06:15:WU01:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
20:06:21:WU02:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
20:08:27:WU02:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
20:09:50:WU01:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
20:10:33:WU02:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
20:12:39:WU02:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
20:13:26:WU01:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
20:14:45:WU02:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
20:16:51:WU02:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
20:17:03:WU01:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
20:18:57:WU02:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
20:20:39:WU01:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
20:21:03:WU02:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
20:23:09:WU02:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
20:24:15:WU01:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
20:25:14:WU02:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
20:27:20:WU02:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
20:27:50:WU01:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
20:29:26:WU02:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
20:31:26:WU01:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
20:31:32:WU02:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
20:33:39:WU02:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
20:35:03:WU01:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
20:35:44:WU02:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
20:37:50:WU02:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
20:38:39:WU01:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
20:39:56:WU02:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
20:42:02:WU02:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
20:42:14:WU01:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
20:44:08:WU02:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
20:45:50:WU01:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
20:46:14:WU02:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
20:48:19:WU02:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
20:49:26:WU01:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
20:50:25:WU02:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
20:52:31:WU02:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
20:53:04:WU01:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
20:54:37:WU02:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
20:56:42:WU01:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
20:56:43:WU02:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
20:58:49:WU02:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
21:00:19:WU01:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
21:00:54:WU02:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
21:03:00:WU02:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
21:03:57:WU01:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
21:05:06:WU02:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
21:07:12:WU02:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
21:07:34:WU01:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
21:09:18:WU02:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
21:11:12:WU01:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
21:11:24:WU02:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
21:13:29:WU02:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
21:14:49:WU01:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
21:15:36:WU02:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
21:17:41:WU02:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
21:18:26:WU01:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
21:19:47:WU02:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
21:21:53:WU02:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
21:22:04:WU01:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
21:23:58:WU02:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
21:25:41:WU01:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
21:26:05:WU02:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
21:28:11:WU02:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
21:29:19:WU01:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
21:30:16:WU02:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
21:32:22:WU02:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
21:32:57:WU01:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
21:34:28:WU02:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
21:36:34:WU01:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
21:36:34:WU02:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
21:38:40:WU02:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
21:40:11:WU01:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
21:40:46:WU02:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
21:42:51:WU02:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
21:43:48:WU01:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
21:44:57:WU02:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
21:44:57:WU02:FS01:0x22:Average performance: 27.4722 ns/day
21:44:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:44:58:WU00:FS01:Assigned to work server 192.0.2.1
21:44:58:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:44:58:WU00:FS01:Connecting to 192.0.2.1:8080
21:44:59:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:44:59:WU02:FS01:0x22:Saving result file checkpointState.xml
21:45:00:WU02:FS01:0x22:Saving result file positions.xtc
21:45:00:WU02:FS01:0x22:Saving result file science.log
21:45:00:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:45:01:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:45:01:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11760 run:0 clone:765 gen:135 core:0x22 unit:0x000000ef80fccb0a5e6d7cd0f0d48bf7
21:45:01:WU02:FS01:Uploading 5.71MiB to 128.252.203.10
21:45:01:WU02:FS01:Connecting to 128.252.203.10:8080
21:45:07:WU02:FS01:Upload 75.55%
21:45:09:WU02:FS01:Upload complete
21:45:09:WU02:FS01:Server responded WORK_ACK (400)
21:45:09:WU02:FS01:Final credit estimate, 61041.00 points
21:45:09:WU02:FS01:Cleaning up
21:45:19:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:45:19:WU00:FS01:Connecting to 192.0.2.1:80
21:45:40:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:45:41:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:45:41:WU00:FS01:Assigned to work server 192.0.2.1
21:45:41:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:45:41:WU00:FS01:Connecting to 192.0.2.1:8080
21:46:02:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:46:02:WU00:FS01:Connecting to 192.0.2.1:80
21:46:23:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:46:41:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:46:41:WU00:FS01:Assigned to work server 192.0.2.1
21:46:41:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:46:41:WU00:FS01:Connecting to 192.0.2.1:8080
21:47:02:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:47:02:WU00:FS01:Connecting to 192.0.2.1:80
21:47:23:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:47:28:WU01:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
21:48:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:48:18:WU00:FS01:Assigned to work server 192.0.2.1
21:48:18:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:48:18:WU00:FS01:Connecting to 192.0.2.1:8080
21:48:39:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:48:39:WU00:FS01:Connecting to 192.0.2.1:80
21:49:00:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:50:55:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:50:55:WU00:FS01:Assigned to work server 192.0.2.1
21:50:55:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:50:55:WU00:FS01:Connecting to 192.0.2.1:8080
21:51:07:WU01:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
21:51:16:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:51:16:WU00:FS01:Connecting to 192.0.2.1:80
21:51:37:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:54:45:WU01:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
21:55:09:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:55:09:WU00:FS01:Assigned to work server 192.0.2.1
21:55:10:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
21:55:10:WU00:FS01:Connecting to 192.0.2.1:8080
21:55:31:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:55:31:WU00:FS01:Connecting to 192.0.2.1:80
21:55:52:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:58:24:WU01:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
22:02:01:WU00:FS01:Connecting to assign1.foldingathome.org:80
22:02:01:WU00:FS01:Assigned to work server 192.0.2.1
22:02:01:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
22:02:01:WU00:FS01:Connecting to 192.0.2.1:8080
22:02:03:WU01:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
22:02:22:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:02:22:WU00:FS01:Connecting to 192.0.2.1:80
22:02:43:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:05:43:WU01:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
22:09:22:WU01:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
22:13:00:WU01:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
22:13:06:WU00:FS01:Connecting to assign1.foldingathome.org:80
22:13:07:WU00:FS01:Assigned to work server 192.0.2.1
22:13:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
22:13:07:WU00:FS01:Connecting to 192.0.2.1:8080
22:13:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:13:28:WU00:FS01:Connecting to 192.0.2.1:80
22:13:49:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:16:39:WU01:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
22:20:18:WU01:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
22:20:18:WU01:FS00:0x22:Average performance: 78.9762 ns/day
22:20:19:WU02:FS00:Connecting to assign1.foldingathome.org:80
22:20:19:WU02:FS00:Assigned to work server 192.0.2.1
22:20:19:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
22:20:19:WU02:FS00:Connecting to 192.0.2.1:8080
22:20:22:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
22:20:22:WU01:FS00:0x22:Saving result file checkpointState.xml.bz2
22:20:22:WU01:FS00:0x22:Saving result file globals.csv
22:20:22:WU01:FS00:0x22:Saving result file positions.xtc
22:20:22:WU01:FS00:0x22:Saving result file science.log
22:20:22:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:20:23:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:20:23:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13416 run:339 clone:206 gen:3 core:0x22 unit:0x0000000412bc7d9a5f0f8f6617eaa1dc
22:20:28:WU01:FS00:Uploading 5.81MiB to 128.252.203.1
22:20:28:WU01:FS00:Connecting to 128.252.203.1:8080
22:20:34:WU01:FS00:Upload 78.55%
22:20:35:WU01:FS00:Upload complete
22:20:35:WU01:FS00:Server responded WORK_ACK (400)
22:20:35:WU01:FS00:Final credit estimate, 171198.00 points
22:20:35:WU01:FS00:Cleaning up
22:20:40:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
22:20:40:WU02:FS00:Connecting to 192.0.2.1:80
22:21:01:ERROR:WU02:FS00:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:21:01:WU02:FS00:Connecting to assign1.foldingathome.org:80
22:21:02:WU02:FS00:Assigned to work server 192.0.2.1
22:21:02:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
22:21:02:WU02:FS00:Connecting to 192.0.2.1:8080
22:21:23:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
22:21:23:WU02:FS00:Connecting to 192.0.2.1:80
22:21:44:ERROR:WU02:FS00:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:36:06:WU01:FS00:Starting
23:36:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" Y:\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 22076 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
23:36:06:WU01:FS00:Started FahCore on PID 14448
23:36:06:WU01:FS00:Core PID:15372
23:36:06:WU01:FS00:FahCore 0x22 started
23:36:06:WU01:FS00:0x22:*********************** Log Started 2020-07-24T23:36:06Z ***********************
23:36:06:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
23:36:06:WU01:FS00:0x22: Core: Core22
23:36:06:WU01:FS00:0x22: Type: 0x22
23:36:06:WU01:FS00:0x22: Version: 0.0.11
23:36:06:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:36:06:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
23:36:06:WU01:FS00:0x22: Homepage: https://foldingathome.org/
23:36:06:WU01:FS00:0x22: Date: Jun 26 2020
23:36:06:WU01:FS00:0x22: Time: 19:49:16
23:36:06:WU01:FS00:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
23:36:06:WU01:FS00:0x22: Branch: core22-0.0.11
23:36:06:WU01:FS00:0x22: Compiler: Visual C++ 2015
23:36:06:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:36:06:WU01:FS00:0x22: Platform: win32 10
23:36:06:WU01:FS00:0x22: Bits: 64
23:36:06:WU01:FS00:0x22: Mode: Release
23:36:06:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:36:06:WU01:FS00:0x22: <peastman@stanford.edu>
23:36:06:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 14448 -checkpoint 30
23:36:06:WU01:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
23:36:06:WU01:FS00:0x22:************************************ libFAH ************************************
23:36:06:WU01:FS00:0x22: Time: 19:47:12
23:36:06:WU01:FS00:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
23:36:06:WU01:FS00:0x22: Branch: HEAD
23:36:06:WU01:FS00:0x22:************************************ CBang *************************************
23:36:06:WU01:FS00:0x22: Time: 19:46:11
23:36:06:WU01:FS00:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
23:36:06:WU01:FS00:0x22: Branch: master
23:36:06:WU01:FS00:0x22:************************************ System ************************************
23:36:06:WU01:FS00:0x22: CPU: AMD Ryzen 9 3950X 16-Core Processor
23:36:06:WU01:FS00:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
23:36:06:WU01:FS00:0x22: CPUs: 32
23:36:06:WU01:FS00:0x22: Memory: 31.93GiB
23:36:06:WU01:FS00:0x22:Free Memory: 18.62GiB
23:36:06:WU01:FS00:0x22: Threads: WINDOWS_THREADS
23:36:06:WU01:FS00:0x22: OS Version: 6.2
23:36:06:WU01:FS00:0x22:Has Battery: false
23:36:06:WU01:FS00:0x22: On Battery: false
23:36:06:WU01:FS00:0x22: UTC Offset: -4
23:36:06:WU01:FS00:0x22: PID: 15372
23:36:06:WU01:FS00:0x22: CWD: Y:\FAHClient\work
23:36:06:WU01:FS00:0x22:********************************************************************************
23:36:06:WU01:FS00:0x22:Project: 13416 (Run 428, Clone 215, Gen 2)
23:36:06:WU01:FS00:0x22:Unit: 0x0000000512bc7d9a5f0f8f64533d58c9
23:36:06:WU01:FS00:0x22:Reading tar file core.xml
23:36:06:WU01:FS00:0x22:Reading tar file integrator.xml
23:36:06:WU01:FS00:0x22:Reading tar file state.xml.bz2
23:36:06:WU01:FS00:0x22:Reading tar file system.xml.bz2
23:36:06:WU01:FS00:0x22:Digital signatures verified
23:36:06:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
23:36:06:WU01:FS00:0x22:Version 0.0.11
23:36:06:WU01:FS00:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
23:36:06:WU01:FS00:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
23:36:06:WU01:FS00:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
23:36:06:WU01:FS00:0x22: Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
23:36:20:WU01:FS00:0x22:Completed 0 out of 1000000 steps (0%)
23:37:54:WU01:FS00:0x22:Completed 10000 out of 1000000 steps (1%)
23:39:26:WU01:FS00:0x22:Completed 20000 out of 1000000 steps (2%)
23:40:03:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:40:03:WU00:FS01:Assigned to work server 192.0.2.1
23:40:03:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:40:03:WU00:FS01:Connecting to 192.0.2.1:8080
23:40:24:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:40:24:WU00:FS01:Connecting to 192.0.2.1:80
23:40:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:40:57:WU01:FS00:0x22:Completed 30000 out of 1000000 steps (3%)
23:41:03:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:41:03:WU00:FS01:Assigned to work server 192.0.2.1
23:41:03:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:41:03:WU00:FS01:Connecting to 192.0.2.1:8080
23:41:24:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:41:24:WU00:FS01:Connecting to 192.0.2.1:80
23:41:45:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:42:29:WU01:FS00:0x22:Completed 40000 out of 1000000 steps (4%)
23:42:40:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:42:40:WU00:FS01:Assigned to work server 192.0.2.1
23:42:40:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:42:40:WU00:FS01:Connecting to 192.0.2.1:8080
23:43:01:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:43:01:WU00:FS01:Connecting to 192.0.2.1:80
23:43:22:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:44:01:WU01:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
23:45:17:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:45:17:WU00:FS01:Assigned to work server 192.0.2.1
23:45:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:45:17:WU00:FS01:Connecting to 192.0.2.1:8080
23:45:33:WU01:FS00:0x22:Completed 60000 out of 1000000 steps (6%)
23:45:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:45:38:WU00:FS01:Connecting to 192.0.2.1:80
23:46:00:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:47:04:WU01:FS00:0x22:Completed 70000 out of 1000000 steps (7%)
23:48:35:WU01:FS00:0x22:Completed 80000 out of 1000000 steps (8%)
23:49:32:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:49:32:WU00:FS01:Assigned to work server 192.0.2.1
23:49:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:49:32:WU00:FS01:Connecting to 192.0.2.1:8080
23:49:53:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:49:53:WU00:FS01:Connecting to 192.0.2.1:80
23:50:06:WU01:FS00:0x22:Completed 90000 out of 1000000 steps (9%)
23:50:14:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:51:36:WU01:FS00:0x22:Completed 100000 out of 1000000 steps (10%)
23:53:08:WU01:FS00:0x22:Completed 110000 out of 1000000 steps (11%)
23:54:42:WU01:FS00:0x22:Completed 120000 out of 1000000 steps (12%)
23:56:15:WU01:FS00:0x22:Completed 130000 out of 1000000 steps (13%)
23:56:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:56:23:WU00:FS01:Assigned to work server 192.0.2.1
23:56:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
23:56:23:WU00:FS01:Connecting to 192.0.2.1:8080
23:56:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
23:56:44:WU00:FS01:Connecting to 192.0.2.1:80
23:57:05:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:57:46:WU01:FS00:0x22:Completed 140000 out of 1000000 steps (14%)
23:59:17:WU01:FS00:0x22:Completed 150000 out of 1000000 steps (15%)
00:00:49:WU01:FS00:0x22:Completed 160000 out of 1000000 steps (16%)
00:02:24:WU01:FS00:0x22:Completed 170000 out of 1000000 steps (17%)
00:03:57:WU01:FS00:0x22:Completed 180000 out of 1000000 steps (18%)
00:05:31:WU01:FS00:0x22:Completed 190000 out of 1000000 steps (19%)
00:07:05:WU01:FS00:0x22:Completed 200000 out of 1000000 steps (20%)
00:07:28:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:07:28:WU00:FS01:Assigned to work server 192.0.2.1
00:07:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
00:07:28:WU00:FS01:Connecting to 192.0.2.1:8080
00:07:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
00:07:49:WU00:FS01:Connecting to 192.0.2.1:80
00:08:11:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:08:37:WU01:FS00:0x22:Completed 210000 out of 1000000 steps (21%)
00:10:09:WU01:FS00:0x22:Completed 220000 out of 1000000 steps (22%)
00:11:43:WU01:FS00:0x22:Completed 230000 out of 1000000 steps (23%)
00:13:17:WU01:FS00:0x22:Completed 240000 out of 1000000 steps (24%)
00:14:49:WU01:FS00:0x22:Completed 250000 out of 1000000 steps (25%)
00:16:21:WU01:FS00:0x22:Completed 260000 out of 1000000 steps (26%)
00:17:55:WU01:FS00:0x22:Completed 270000 out of 1000000 steps (27%)
00:19:29:WU01:FS00:0x22:Completed 280000 out of 1000000 steps (28%)
00:21:01:WU01:FS00:0x22:Completed 290000 out of 1000000 steps (29%)
00:22:33:WU01:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
00:24:07:WU01:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
00:25:25:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:25:25:WU00:FS01:Assigned to work server 192.0.2.1
00:25:25:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 192.0.2.1
00:25:25:WU00:FS01:Connecting to 192.0.2.1:8080
00:25:39:WU01:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
00:25:46:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
00:25:46:WU00:FS01:Connecting to 192.0.2.1:80
00:26:08:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:27:12:WU01:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
00:28:45:WU01:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
00:30:17:WU01:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
00:31:50:WU01:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
00:33:23:WU01:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
00:34:56:WU01:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
00:36:29:WU01:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
00:38:00:WU01:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
00:39:32:WU01:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
00:41:04:WU01:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
Re: Ellesmere XT Cards Directed to Work Server 192.0.2.1
viewtopic.php?f=24&t=35858
Bruce has stated that changes were made, now we will try to get them sorted out.
Re: 192.0.2.1 Work Server
GPUSpecies 4 is supposed to be supported. I don't know what happened. It'll take be a bit to undo a lot of today's work.
