Shortage of CPU WUs or GRO-A7 servers struggling?
ajm
Post by ajm »
No big deal yet, but so exceptional I thought I'd make a thread. It looks like some GRO_A7 servers are struggling.
This log (only the CPU slot) starts last week and shows no issue until a couple hours back. Since then either no connection or no WU available. On the same machine, the GPU is happily folding, WUs back to back, and just got a new one a few minutes ago.
*********************** Log Started 2020-07-15T09:46:49Z ***********************
14:13:14:WU02:FS00:Connecting to assign1.foldingathome.org:80
14:13:14:WU02:FS00:Assigned to work server 40.114.52.201
14:13:14:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 40.114.52.201
14:13:14:WU02:FS00:Connecting to 40.114.52.201:8080
14:13:16:WU02:FS00:Downloading 2.14MiB
14:13:17:WU02:FS00:Download complete
14:13:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:27596 gen:201 core:0xa7 unit:0x000000f4287234c95e788586c834e749
14:14:34:WU02:FS00:Starting
14:14:34:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 16868 -checkpoint 15 -np 16
14:14:34:WU02:FS00:Started FahCore on PID 16200
14:14:34:WU02:FS00:Core PID:13352
14:14:34:WU02:FS00:FahCore 0xa7 started
14:14:35:WU02:FS00:0xa7:*********************** Log Started 2020-07-15T14:14:34Z ***********************
14:14:35:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:14:35:WU02:FS00:0xa7:       Type: 0xa7
14:14:35:WU02:FS00:0xa7:       Core: Gromacs
14:14:35:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 16200 -checkpoint 15 -np
14:14:35:WU02:FS00:0xa7:             16
14:14:35:WU02:FS00:0xa7:************************************ CBang *************************************
14:14:35:WU02:FS00:0xa7:       Date: Nov 27 2019
14:14:35:WU02:FS00:0xa7:       Time: 03:40:09
14:14:35:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:14:35:WU02:FS00:0xa7:     Branch: master
14:14:35:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:14:35:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:14:35:WU02:FS00:0xa7:   Platform: win32 10
14:14:35:WU02:FS00:0xa7:       Bits: 64
14:14:35:WU02:FS00:0xa7:       Mode: Release
14:14:35:WU02:FS00:0xa7:************************************ System ************************************
14:14:35:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
14:14:35:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
14:14:35:WU02:FS00:0xa7:       CPUs: 20
14:14:35:WU02:FS00:0xa7:     Memory: 63.69GiB
14:14:35:WU02:FS00:0xa7:Free Memory: 59.50GiB
14:14:35:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:14:35:WU02:FS00:0xa7: OS Version: 6.2
14:14:35:WU02:FS00:0xa7:Has Battery: false
14:14:35:WU02:FS00:0xa7: On Battery: false
14:14:35:WU02:FS00:0xa7: UTC Offset: 2
14:14:35:WU02:FS00:0xa7:        PID: 13352
14:14:35:WU02:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
14:14:35:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:14:35:WU02:FS00:0xa7:    Version: 0.0.19
14:14:35:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:14:35:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:14:35:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:14:35:WU02:FS00:0xa7:       Date: Nov 25 2019
14:14:35:WU02:FS00:0xa7:       Time: 17:12:41
14:14:35:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:14:35:WU02:FS00:0xa7:************************************ Build *************************************
14:14:35:WU02:FS00:0xa7:       SIMD: avx_256
14:14:35:WU02:FS00:0xa7:********************************************************************************
14:14:35:WU02:FS00:0xa7:Project: 13851 (Run 0, Clone 27596, Gen 201)
14:14:35:WU02:FS00:0xa7:Unit: 0x000000f4287234c95e788586c834e749
14:14:35:WU02:FS00:0xa7:Reading tar file core.xml
14:14:35:WU02:FS00:0xa7:Reading tar file frame201.tpr
14:14:35:WU02:FS00:0xa7:Digital signatures verified
14:14:35:WU02:FS00:0xa7:Calling: mdrun -s frame201.tpr -o frame201.trr -x frame201.xtc -e frame201.edr -cpt 15 -nt 16
14:14:35:WU02:FS00:0xa7:Steps: first=100500000 total=500000
14:14:35:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
(...no problem...)
02:58:16:WU02:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
02:58:16:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
02:58:16:WU02:FS00:0xa7:Saving result file frame105.trr
02:58:16:WU02:FS00:0xa7:Saving result file frame105.xtc
02:58:16:WU02:FS00:0xa7:Saving result file md.log
02:58:16:WU02:FS00:0xa7:Saving result file science.log
02:58:16:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:58:17:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:58:17:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16404 run:0 clone:5304 gen:105 core:0xa7 unit:0x0000007ba8f5c67d5e7ed048cf0dee9b
02:58:17:WU02:FS00:Uploading 1.42MiB to 168.245.198.125
02:58:17:WU02:FS00:Connecting to 168.245.198.125:8080
02:58:26:WU02:FS00:Upload complete
02:58:26:WU02:FS00:Server responded WORK_ACK (400)
02:58:26:WU02:FS00:Final credit estimate, 4644.00 points
02:58:26:WU02:FS00:Cleaning up
03:58:29:WU02:FS00:Connecting to assign1.foldingathome.org:80
03:58:29:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
03:58:29:WU02:FS00:Connecting to assign2.foldingathome.org:80
03:58:30:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
03:58:30:WU02:FS00:Connecting to assign3.foldingathome.org:80
03:58:30:WU02:FS00:Assigned to work server 3.21.157.11
03:58:30:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 3.21.157.11
03:58:30:WU02:FS00:Connecting to 3.21.157.11:8080
03:58:52:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
03:58:52:WU02:FS00:Connecting to 3.21.157.11:80
03:59:13:ERROR:WU02:FS00:Exception: Failed to connect to 3.21.157.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:59:14:WU02:FS00:Connecting to assign1.foldingathome.org:80
03:59:14:WU02:FS00:Assigned to work server 3.21.157.11
03:59:14:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 3.21.157.11
03:59:14:WU02:FS00:Connecting to 3.21.157.11:8080
03:59:35:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
03:59:35:WU02:FS00:Connecting to 3.21.157.11:80
03:59:56:ERROR:WU02:FS00:Exception: Failed to connect to 3.21.157.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:00:14:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:00:14:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:00:14:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:00:15:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:00:15:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:00:15:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:00:15:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:00:16:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:00:16:ERROR:WU02:FS00:Exception: Could not get an assignment
******************************* Date: 2020-07-22 *******************************
04:01:51:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:01:51:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:01:51:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:01:52:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:01:52:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:01:53:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:01:53:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:01:53:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:01:53:ERROR:WU02:FS00:Exception: Could not get an assignment
04:04:28:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:04:29:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:04:29:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:04:29:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:04:29:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:04:30:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:04:30:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:04:30:WU02:FS00:Assigned to work server 3.21.157.11
04:04:30:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 3.21.157.11
04:04:30:WU02:FS00:Connecting to 3.21.157.11:8080
04:04:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
04:04:51:WU02:FS00:Connecting to 3.21.157.11:80
04:05:12:ERROR:WU02:FS00:Exception: Failed to connect to 3.21.157.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:08:43:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:08:43:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:08:43:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:08:44:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:08:44:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:08:44:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:08:44:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:08:45:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:08:45:ERROR:WU02:FS00:Exception: Could not get an assignment
04:15:34:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:15:34:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:15:34:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:15:35:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:15:35:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:15:36:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:15:36:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:15:36:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:15:36:ERROR:WU02:FS00:Exception: Could not get an assignment
04:26:39:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:26:40:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:26:40:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:26:40:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
04:26:40:WU02:FS00:Connecting to assign3.foldingathome.org:80
04:26:41:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
04:26:41:WU02:FS00:Connecting to assign4.foldingathome.org:80
04:26:42:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
04:26:42:ERROR:WU02:FS00:Exception: Could not get an assignment
04:44:36:WU02:FS00:Connecting to assign1.foldingathome.org:80
04:44:37:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:44:37:WU02:FS00:Connecting to assign2.foldingathome.org:80
04:44:37:WU02:FS00:Assigned to work server 69.94.66.7
04:44:37:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 69.94.66.7
04:44:37:WU02:FS00:Connecting to 69.94.66.7:8080
04:44:37:ERROR:WU02:FS00:Exception: Server did not assign work unit
05:13:38:WU02:FS00:Connecting to assign1.foldingathome.org:80
05:13:39:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
05:13:39:WU02:FS00:Connecting to assign2.foldingathome.org:80
05:13:39:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
05:13:39:WU02:FS00:Connecting to assign3.foldingathome.org:80
05:13:40:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
05:13:40:WU02:FS00:Connecting to assign4.foldingathome.org:80
05:13:40:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
05:13:40:ERROR:WU02:FS00:Exception: Could not get an assignment
EDIT: Still there:
06:00:37:WU02:FS00:Connecting to assign1.foldingathome.org:80
06:00:38:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:00:38:WU02:FS00:Connecting to assign2.foldingathome.org:80
06:00:38:WARNING:WU02:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:00:38:WU02:FS00:Connecting to assign3.foldingathome.org:80
06:00:39:WARNING:WU02:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:00:39:WU02:FS00:Connecting to assign4.foldingathome.org:80
06:00:39:WARNING:WU02:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:00:39:ERROR:WU02:FS00:Exception: Could not get an assignment
07:00:37:WU02:FS00:Connecting to assign1.foldingathome.org:80
07:00:38:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
07:00:38:WU02:FS00:Connecting to assign2.foldingathome.org:80
07:00:38:WU02:FS00:Assigned to work server 3.21.157.11
07:00:38:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 3.21.157.11
07:00:38:WU02:FS00:Connecting to 3.21.157.11:8080
07:00:59:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
07:00:59:WU02:FS00:Connecting to 3.21.157.11:80
07:01:21:ERROR:WU02:FS00:Exception: Failed to connect to 3.21.157.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:00:37:WU02:FS00:Connecting to assign1.foldingathome.org:80
08:00:38:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
08:00:38:WU02:FS00:Connecting to assign2.foldingathome.org:80
08:00:39:WU02:FS00:Assigned to work server 3.21.157.11
08:00:39:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 3.21.157.11
08:00:39:WU02:FS00:Connecting to 3.21.157.11:8080
08:01:00:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
08:01:00:WU02:FS00:Connecting to 3.21.157.11:80
08:01:21:ERROR:WU02:FS00:Exception: Failed to connect to 3.21.157.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Now at
Attempts 12
Next attempt 51 mins some secs
ajm
Re: Shortage of CPU WUs or GRO-A7 servers struggling?
Post by ajm »
Finally:
10:00:38:WU02:FS00:Connecting to assign1.foldingathome.org:80
10:00:38:WARNING:WU02:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:00:38:WU02:FS00:Connecting to assign2.foldingathome.org:80
10:00:39:WU02:FS00:Assigned to work server 150.136.14.110
10:00:39:WU02:FS00:Requesting new work unit for slot 00: READY cpu:16 from 150.136.14.110
10:00:39:WU02:FS00:Connecting to 150.136.14.110:8080
10:00:39:WU02:FS00:Downloading 1.25MiB
10:00:40:WU02:FS00:Download complete
10:00:40:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16401 run:449 clone:0 gen:94 core:0xa7 unit:0x0000006a96880e6e5e814ca1e545020f
10:00:40:WU02:FS00:Starting
10:00:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 16868 -checkpoint 15 -np 16
10:00:40:WU02:FS00:Started FahCore on PID 28884
10:00:40:WU02:FS00:Core PID:30676
10:00:40:WU02:FS00:FahCore 0xa7 started
10:00:40:WU02:FS00:0xa7:*********************** Log Started 2020-07-22T10:00:40Z ***********************
10:00:40:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:00:40:WU02:FS00:0xa7:       Type: 0xa7
10:00:40:WU02:FS00:0xa7:       Core: Gromacs
10:00:40:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 28884 -checkpoint 15 -np
10:00:40:WU02:FS00:0xa7:             16
10:00:40:WU02:FS00:0xa7:************************************ CBang *************************************
10:00:40:WU02:FS00:0xa7:       Date: Nov 27 2019
10:00:40:WU02:FS00:0xa7:       Time: 03:40:09
10:00:40:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:00:40:WU02:FS00:0xa7:     Branch: master
10:00:40:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
10:00:40:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:00:40:WU02:FS00:0xa7:   Platform: win32 10
10:00:40:WU02:FS00:0xa7:       Bits: 64
10:00:40:WU02:FS00:0xa7:       Mode: Release
10:00:40:WU02:FS00:0xa7:************************************ System ************************************
10:00:40:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
10:00:40:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
10:00:40:WU02:FS00:0xa7:       CPUs: 20
10:00:40:WU02:FS00:0xa7:     Memory: 63.69GiB
10:00:40:WU02:FS00:0xa7:Free Memory: 57.12GiB
10:00:40:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
10:00:40:WU02:FS00:0xa7: OS Version: 6.2
10:00:40:WU02:FS00:0xa7:Has Battery: false
10:00:40:WU02:FS00:0xa7: On Battery: false
10:00:40:WU02:FS00:0xa7: UTC Offset: 2
10:00:40:WU02:FS00:0xa7:        PID: 30676
10:00:40:WU02:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
10:00:40:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
10:00:40:WU02:FS00:0xa7:    Version: 0.0.19
10:00:40:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:00:40:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:00:40:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
10:00:40:WU02:FS00:0xa7:       Date: Nov 25 2019
10:00:40:WU02:FS00:0xa7:       Time: 17:12:41
10:00:40:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:00:40:WU02:FS00:0xa7:************************************ Build *************************************
10:00:40:WU02:FS00:0xa7:       SIMD: avx_256
10:00:40:WU02:FS00:0xa7:********************************************************************************
10:00:40:WU02:FS00:0xa7:Project: 16401 (Run 449, Clone 0, Gen 94)
10:00:40:WU02:FS00:0xa7:Unit: 0x0000006a96880e6e5e814ca1e545020f
10:00:41:WU02:FS00:0xa7:Reading tar file core.xml
10:00:41:WU02:FS00:0xa7:Reading tar file frame94.tpr
10:00:41:WU02:FS00:0xa7:Digital signatures verified
10:00:41:WU02:FS00:0xa7:Calling: mdrun -s frame94.tpr -o frame94.trr -x frame94.xtc -cpt 15 -nt 16
10:00:41:WU02:FS00:0xa7:Steps: first=47000000 total=500000
10:00:41:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
_r2w_ben
Post by _r2w_ben »
Since 2020-07-21T01:25:46Z it's taken 2-5 attempts to get a CPU work unit on Windows for cpu:2. Several of the servers listed as down on the server status page were hosting CPU projects, listed as GRO_A7 in the project types column.
