140.163.4.231 not accepting uploads
ArcherBoy27
Hardware configuration: i5 7600k
MSI GTX 1060 6GB
16Gb RAM
Post by ArcherBoy27 »
Hi All,
Having an issue with server IP 140.163.4.231. Completed work units are not being accepted by the server and are being dropped. I had initially opened a post on Reddit but the forum won't let me post the link. It contains the full log that I took the important extract from below. In the comments there is another person having the same issue.
The log provided is the first occurrence I have seen, however i have seen it occur again today.
15:09:15:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
15:12:21:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
15:12:26:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
15:12:26:WU01:FS01:0x22:Saving result file checkpointState.xml
15:12:30:WU01:FS01:0x22:Saving result file checkpt.crc
15:12:30:WU01:FS01:0x22:Saving result file positions.xtc
15:12:31:WU01:FS01:0x22:Saving result file science.log
15:12:31:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:12:32:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:12:32:WU01:FS01:Sending unit results: id01 state:SEND error:NO_ERROR project:11752 run:0 clone:13357 gen:4 core:0x22 unit:0x000000088ca304e75e6d6cb98b6befc3
15:12:32:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
15:12:32:WU01:FS01:Connecting to 140.163.4.231:8080
15:12:38:WU01:FS01:Upload 14.39%
15:12:45:WU01:FS01:Upload 28.51%
15:12:51:WU01:FS01:Upload 37.25%
15:12:59:WU01:FS01:Upload 49.06%
15:13:05:WU01:FS01:Upload 62.16%
15:13:11:WU01:FS01:Upload 77.83%
15:13:17:WU01:FS01:Upload 93.25%
15:13:55:WU01:FS01:Upload complete
15:13:55:WU01:FS01:Server responded WORK_QUIT (404)
15:13:55:WARNING:WU01:FS01:Server did not like results, dumping
15:13:55:WU01:FS01:Cleaning up
Not really sure how to troubleshoot this. Is this a server side issue?
PC specs if it's important:
i5 7600k
MSI GTX 1060 6GB
16Gb RAM
If you need more information let me know.
favrepeoria
Re: 140.163.4.231 not accepting completed work
Post by favrepeoria »
Can confirm I too have had 2 units to this server do the same thing.
Post by Neil-B »
A quick search of the forums (out IP address in top right hand corner search window) will find you a number of discussions on this, but the short of it is this is a known issue and the team are working to resolve it as fast as possible.
VegaZhree3
Post by VegaZhree3 »
I have the same problem too. At least it didn't dumped the whole WU.
stylezlp604
Post by stylezlp604 »
I hope this is being looked at. I also just had my first WU that this server 140.163.4.231 "didn't like". Log extract below for said WU. In the meantime I am blocking this IP so that F@H can't connect to it.
06:11:47:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
06:13:53:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
06:16:03:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
06:18:14:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
06:20:25:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
06:22:37:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
06:24:49:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
06:26:56:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
06:29:03:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
06:31:11:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
06:33:18:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
06:35:28:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
06:37:35:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
06:39:36:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
06:41:43:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
06:43:50:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
06:45:59:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
06:48:06:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
06:50:13:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
06:52:21:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
06:54:27:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
06:56:33:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
06:58:36:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
07:00:44:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
07:02:48:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
07:04:47:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
07:06:51:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
07:08:52:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
07:10:52:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
07:12:52:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
07:14:52:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
07:16:54:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
07:18:53:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
07:20:52:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
07:22:51:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
07:24:50:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
07:26:50:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
07:28:49:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
07:30:47:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
07:32:45:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
07:34:44:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
07:36:45:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
07:38:44:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
07:40:42:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
07:42:41:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
07:44:40:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
07:46:41:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
07:48:39:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
07:50:37:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
07:52:36:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
07:54:34:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
07:56:34:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
07:58:32:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
08:00:31:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
08:02:29:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
08:04:27:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
08:06:28:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
08:08:26:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
08:10:24:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
08:12:22:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
08:14:21:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
08:16:21:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
08:18:19:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
08:20:18:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
08:22:16:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
08:24:14:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
08:26:15:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
08:28:13:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
08:30:11:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
08:32:10:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
08:34:08:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
08:36:08:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
08:38:06:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
08:40:05:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
08:42:03:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
08:44:01:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
08:46:01:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
08:48:00:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
08:49:58:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
08:51:56:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
08:51:57:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:51:57:WU00:FS01:Assigned to work server 18.188.125.154
08:51:57:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
08:51:57:WU00:FS01:Connecting to 18.188.125.154:8080
08:52:02:WU00:FS01:Downloading 9.37MiB
08:52:02:WU00:FS01:Download complete
08:52:02:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13414 run:4772 clone:34 gen:0 core:0x22 unit:0x0000000012bc7d9a5efc078b330d51ac
08:53:55:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
08:53:55:WU01:FS01:0x22:Average performance: 29.2386 ns/day
08:54:02:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
08:54:02:WU01:FS01:0x22:Saving result file checkpointState.xml
08:54:06:WU01:FS01:0x22:Saving result file positions.xtc
08:54:07:WU01:FS01:0x22:Saving result file science.log
08:54:08:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:54:08:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:54:08:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11750 run:0 clone:9626 gen:61 core:0x22 unit:0x000000738ca304e75e6bbae6575bdb18
08:54:08:WU01:FS01:Uploading 14.51MiB to 140.163.4.231
08:54:08:WU00:FS01:Starting
08:54:08:WU01:FS01:Connecting to 140.163.4.231:8080
08:54:08:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:\Users\****\AppData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12044 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:54:08:WU00:FS01:Started FahCore on PID 12440
08:54:09:WU00:FS01:Core PID:11288
08:54:09:WU00:FS01:FahCore 0x22 started
08:54:09:WU00:FS01:0x22:*********************** Log Started 2020-07-04T08:54:09Z ***********************
08:54:09:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:54:09:WU00:FS01:0x22:       Core: Core22
08:54:09:WU00:FS01:0x22:       Type: 0x22
08:54:09:WU00:FS01:0x22:    Version: 0.0.11
08:54:09:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:54:09:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
08:54:09:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
08:54:09:WU00:FS01:0x22:       Date: Jun 26 2020
08:54:09:WU00:FS01:0x22:       Time: 19:49:16
08:54:09:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
08:54:09:WU00:FS01:0x22:     Branch: core22-0.0.11
08:54:09:WU00:FS01:0x22:   Compiler: Visual C++ 2015
08:54:09:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:54:09:WU00:FS01:0x22:   Platform: win32 10
08:54:09:WU00:FS01:0x22:       Bits: 64
08:54:09:WU00:FS01:0x22:       Mode: Release
08:54:09:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:54:09:WU00:FS01:0x22:             <peastman@stanford.edu>
08:54:09:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12440 -checkpoint 15
08:54:09:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:54:09:WU00:FS01:0x22:************************************ libFAH ************************************
08:54:09:WU00:FS01:0x22:       Time: 19:47:12
08:54:09:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
08:54:09:WU00:FS01:0x22:     Branch: HEAD
08:54:09:WU00:FS01:0x22:************************************ CBang *************************************
08:54:09:WU00:FS01:0x22:       Time: 19:46:11
08:54:09:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
08:54:09:WU00:FS01:0x22:     Branch: master
08:54:09:WU00:FS01:0x22:************************************ System ************************************
08:54:09:WU00:FS01:0x22:        CPU: AMD FX(tm)-6300 Six-Core Processor
08:54:09:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:54:09:WU00:FS01:0x22:       CPUs: 6
08:54:09:WU00:FS01:0x22:     Memory: 15.97GiB
08:54:09:WU00:FS01:0x22:Free Memory: 13.16GiB
08:54:09:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
08:54:09:WU00:FS01:0x22: OS Version: 6.2
08:54:09:WU00:FS01:0x22:Has Battery: false
08:54:09:WU00:FS01:0x22: On Battery: false
08:54:09:WU00:FS01:0x22: UTC Offset: -7
08:54:09:WU00:FS01:0x22:        PID: 11288
08:54:09:WU00:FS01:0x22:        CWD: D:\Users\******
08:54:09:WU00:FS01:0x22:********************************************************************************
08:54:09:WU00:FS01:0x22:Project: 13414 (Run 4772, Clone 34, Gen 0)
08:54:09:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5efc078b330d51ac
08:54:09:WU00:FS01:0x22:Reading tar file core.xml
08:54:09:WU00:FS01:0x22:Reading tar file integrator.xml
08:54:09:WU00:FS01:0x22:Reading tar file state.xml
08:54:09:WU00:FS01:0x22:Reading tar file system.xml
08:54:10:WU00:FS01:0x22:Digital signatures verified
08:54:10:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:54:10:WU00:FS01:0x22:Version 0.0.11
08:54:10:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
08:54:10:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
08:54:10:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
08:54:10:WU00:FS01:0x22:  Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
08:54:14:WU01:FS01:Upload 31.87%
08:54:20:WU01:FS01:Upload 66.33%
08:54:26:WU01:FS01:Upload 93.03%
08:54:29:WU01:FS01:Upload complete
08:54:29:WU01:FS01:Server responded WORK_QUIT (404)
08:54:29:WARNING:WU01:FS01:Server did not like results, dumping
08:54:29:WU01:FS01:Cleaning up
Post by Neil-B »
You have posted into an old thread ... the current thread relating to issues with this server has a post indicating the current issue may have been resolved.
DRQ
Post by DRQ »
Neil-B wrote:You have posted into an old thread ... the current thread relating to issues with this server has a post indicating the current issue may have been resolved.
Here is a link to a more current thread "Can't upload to 140.163.4.231 again". I think this is the one Neil-B is referring to.
