Linux PopOS and GTX 2060 folds one WU and quits silently
bunkermagnus
Post by bunkermagnus »
So I have been folding for a couple of months using various setups and operating systems.
This last couple of days I've run into an obstacle with Linux Pop_OS! 20.04 and a brand new RTX 2060.
The CPU slots folds without any problems but the GPU folds one WU and then it considers itself done until I reboot the computer, then it will eventually start again and do ONE WU and go idle in ready state.
I've tried installing the latest FAHclient as per instructions on the official fah website, fahclient_7.6.13_amd64.deb GUI install. when that didn't work as it should, I purghed it and installed the older 7.4.4 with CLI:
sudo dpkg -i --force-depends fahclient_7.4.4_amd64.deb which has worked for me before on other linux installations.
But the results are the same each time.
I've installed the OpenCL and the other dependencies which should be installed and the computer launches games and fahclioent detects my RTX2060, it just want to do one WU and quits silently.
I'm enclosing the log for the latest "full circle" below until I grew tired and restarted the fahclient at the end.
Thank you in advance for any hints / help you can provide :?: .
*********************** Log Started 2020-07-20T15:44:17Z ***********************
15:44:17:************************* Folding@home Client *************************
15:44:17:    Website: http://folding.stanford.edu/
15:44:17:  Copyright: (c) 2009-2014 Stanford University
15:44:17:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:44:17:       Args: --child --lifeline 1326 /etc/fahclient/config.xml --run-as
15:44:17:             fahclient --pid-file=/var/run/fahclient.pid --daemon
15:44:17:     Config: /etc/fahclient/config.xml
15:44:17:******************************** Build ********************************
15:44:17:    Version: 7.4.4
15:44:17:       Date: Mar 4 2014
15:44:17:       Time: 12:02:38
15:44:17:    SVN Rev: 4130
15:44:17:     Branch: fah/trunk/client
15:44:17:   Compiler: GNU 4.4.7
15:44:17:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
15:44:17:             -fno-unsafe-math-optimizations -msse2
15:44:17:   Platform: linux2 3.2.0-1-amd64
15:44:17:       Bits: 64
15:44:17:       Mode: Release
15:44:17:******************************* System ********************************
15:44:17:        CPU: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
15:44:17:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:44:17:       CPUs: 4
15:44:17:     Memory: 15.58GiB
15:44:17:Free Memory: 14.92GiB
15:44:17:    Threads: POSIX_THREADS
15:44:17: OS Version: 5.4
15:44:17:Has Battery: false
15:44:17: On Battery: false
15:44:17: UTC Offset: 2
15:44:17:        PID: 1328
15:44:17:        CWD: /var/lib/fahclient
15:44:17:         OS: Linux 5.4.0-7634-generic x86_64
15:44:17:    OS Arch: AMD64
15:44:17:       GPUs: 1
15:44:17:      GPU 0: NVIDIA:7 TU104 [GeForce RTX 2060]
15:44:17:       CUDA: 7.5
15:44:17:CUDA Driver: 10020
15:44:17:***********************************************************************
15:44:17:<config>
15:44:17:  <!-- Client Control -->
15:44:17:  <fold-anon v='true'/>
15:44:17:
15:44:17:  <!-- Folding Core -->
15:44:17:  <core-priority v='low'/>
15:44:17:
15:44:17:  <!-- HTTP Server -->
15:44:17:  <allow v='127.0.0.1 192.168.1.0/24'/>
15:44:17:
15:44:17:  <!-- Network -->
15:44:17:  <proxy v=':8080'/>
15:44:17:
15:44:17:  <!-- Remote Command Server -->
15:44:17:  <password v='*********'/>
15:44:17:
15:44:17:  <!-- User Information -->
15:44:17:  <passkey v='********************************'/>
15:44:17:  <team v='XXXXXX'/>
15:44:17:  <user v='XXXXXXXX'/>
15:44:17:
15:44:17:  <!-- Web Server -->
15:44:17:  <web-allow v='127.0.0.1 192.168.1.0/24'/>
15:44:17:
15:44:17:  <!-- Folding Slots -->
15:44:17:  <slot id='0' type='CPU'>
15:44:17:    <pause-on-start v='True'/>
15:44:17:  </slot>
15:44:17:  <slot id='1' type='GPU'>
15:44:17:    <pause-on-start v='true'/>
15:44:17:  </slot>
15:44:17:</config>
15:44:17:Switching to user fahclient
15:44:17:Trying to access database...
15:44:17:Successfully acquired database lock
15:44:17:Enabled folding slot 00: PAUSED cpu:2 (by user)
15:44:17:Enabled folding slot 01: PAUSED gpu:0:TU104 [GeForce RTX 2060] (by user)
13:45:19:FS01:Unpaused
13:45:20:WU00:FS01:Connecting to 65.254.110.245:80
13:45:20:WU00:FS01:Assigned to work server 155.247.166.220
13:45:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2060] from 155.247.166.220
13:45:20:WU00:FS01:Connecting to 155.247.166.220:8080
13:45:20:WU00:FS01:Downloading 5.81MiB
13:46:03:WU00:FS01:Download 2.15%
13:46:10:WU00:FS01:Download 4.30%
13:46:17:WU00:FS01:Download 6.45%
13:46:59:WU00:FS01:Download 7.53%
13:47:24:WU00:FS01:Download 9.68%
13:49:46:WU00:FS01:Download 10.75%
[91m13:49:50:ERROR:WU00:FS01:Exception: Transfer failed[0m
13:49:52:WU00:FS01:Connecting to 65.254.110.245:80
13:49:53:WU00:FS01:Assigned to work server 18.188.125.154
13:49:53:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2060] from 18.188.125.154
13:49:53:WU00:FS01:Connecting to 18.188.125.154:8080
13:49:54:WU00:FS01:Downloading 7.08MiB
13:50:03:WU00:FS01:Download 2.65%
13:50:11:WU00:FS01:Download 4.41%
13:50:19:WU00:FS01:Download 6.18%
13:50:27:WU00:FS01:Download 7.06%
13:50:33:WU00:FS01:Download 8.83%
13:52:09:WU00:FS01:Download 9.71%
13:52:19:WU00:FS01:Download 12.36%
[91m13:52:21:ERROR:WU00:FS01:Exception: Transfer failed[0m
13:52:21:WU00:FS01:Connecting to 65.254.110.245:80
13:52:22:WU00:FS01:Assigned to work server 128.252.203.10
13:52:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2060] from 128.252.203.10
13:52:22:WU00:FS01:Connecting to 128.252.203.10:8080
13:52:25:WU00:FS01:Downloading 5.82MiB
13:52:31:WU00:FS01:Download 2.15%
13:52:41:WU00:FS01:Download 4.30%
13:52:48:WU00:FS01:Download 7.52%
13:52:55:WU00:FS01:Download 9.67%
13:53:03:WU00:FS01:Download 11.82%
13:53:11:WU00:FS01:Download 13.97%
13:53:19:WU00:FS01:Download 17.19%
13:53:28:WU00:FS01:Download 19.34%
13:53:36:WU00:FS01:Download 21.49%
13:53:47:WU00:FS01:Download 23.64%
13:53:55:WU00:FS01:Download 25.79%
13:54:05:WU00:FS01:Download 27.93%
13:54:15:WU00:FS01:Download 31.16%
13:54:31:WU00:FS01:Download 33.31%
13:54:40:WU00:FS01:Download 35.46%
13:54:55:WU00:FS01:Download 38.68%
13:55:02:WU00:FS01:Download 39.75%
13:55:12:WU00:FS01:Download 41.90%
13:55:23:WU00:FS01:Download 44.05%
13:55:30:WU00:FS01:Download 45.13%
13:55:36:WU00:FS01:Download 47.27%
13:55:45:WU00:FS01:Download 49.42%
13:55:53:WU00:FS01:Download 51.57%
13:56:03:WU00:FS01:Download 53.72%
13:56:14:WU00:FS01:Download 58.02%
13:56:21:WU00:FS01:Download 60.17%
13:56:27:WU00:FS01:Download 62.32%
13:56:34:WU00:FS01:Download 63.39%
13:56:48:WU00:FS01:Download 66.61%
13:56:59:WU00:FS01:Download 67.69%
13:57:07:WU00:FS01:Download 69.84%
13:57:13:WU00:FS01:Download 70.91%
13:57:21:WU00:FS01:Download 71.99%
13:57:29:WU00:FS01:Download 74.13%
13:57:36:WU00:FS01:Download 75.21%
13:57:42:WU00:FS01:Download 77.36%
13:57:48:WU00:FS01:Download 80.58%
13:57:58:WU00:FS01:Download 83.80%
13:58:07:WU00:FS01:Download 85.95%
13:58:16:WU00:FS01:Download 87.03%
13:58:26:WU00:FS01:Download 88.10%
13:58:32:WU00:FS01:Download 89.18%
13:58:39:WU00:FS01:Download 91.33%
13:58:46:WU00:FS01:Download 92.40%
13:58:52:WU00:FS01:Download 93.47%
13:59:09:WU00:FS01:Download 95.62%
13:59:19:WU00:FS01:Download 97.77%
13:59:32:WU00:FS01:Download 98.85%
13:59:35:WU00:FS01:Download complete
13:59:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:1052 gen:143 core:0x22 unit:0x000000fd80fccb0a5e6d7cd49d129cd5
13:59:35:WU00:FS01:Downloading core from http://cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah
13:59:35:WU00:FS01:Connecting to cores.foldingathome.org:80
13:59:36:WU00:FS01:FahCore 22: Downloading 3.66MiB
13:59:49:WU00:FS01:FahCore 22: 5.12%
14:00:02:WU00:FS01:FahCore 22: 6.83%
14:00:11:WU00:FS01:FahCore 22: 10.25%
14:00:27:WU00:FS01:FahCore 22: 11.95%
14:01:03:WU00:FS01:FahCore 22: 13.66%
14:02:32:WU00:FS01:FahCore 22: 15.37%
14:02:44:WU00:FS01:FahCore 22: 16.77%
[91m14:02:44:ERROR:WU00:FS01:Exception: Transfer failed[0m
14:02:44:WU00:FS01:Downloading core from http://cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah
14:02:44:WU00:FS01:Connecting to cores.foldingathome.org:80
14:02:44:WU00:FS01:FahCore 22: Downloading 3.66MiB
14:02:56:WU00:FS01:FahCore 22: 3.42%
14:03:04:WU00:FS01:FahCore 22: 5.12%
14:03:21:WU00:FS01:FahCore 22: 6.83%
14:03:29:WU00:FS01:FahCore 22: 8.54%
14:03:39:WU00:FS01:FahCore 22: 10.25%
14:03:52:WU00:FS01:FahCore 22: 11.95%
14:04:27:WU00:FS01:FahCore 22: 13.66%
14:04:48:WU00:FS01:FahCore 22: 15.37%
14:05:28:WU00:FS01:FahCore 22: 17.08%
14:05:39:WU00:FS01:FahCore 22: 18.78%
14:05:54:WU00:FS01:FahCore 22: 20.49%
14:06:13:WU00:FS01:FahCore 22: 22.20%
14:06:46:WU00:FS01:FahCore 22: 25.61%
14:07:13:WU00:FS01:FahCore 22: 27.32%
14:07:25:WU00:FS01:FahCore 22: 29.03%
14:07:36:WU00:FS01:FahCore 22: 30.74%
14:07:43:WU00:FS01:FahCore 22: 32.45%
14:07:59:WU00:FS01:FahCore 22: 34.15%
14:09:03:WU00:FS01:FahCore 22: 35.86%
14:09:32:WU00:FS01:FahCore 22: 37.57%
14:09:52:WU00:FS01:FahCore 22: 39.28%
14:10:07:WU00:FS01:FahCore 22: 40.98%
14:10:59:WU00:FS01:FahCore 22: 42.69%
14:11:34:WU00:FS01:FahCore 22: 44.40%
14:11:48:WU00:FS01:FahCore 22: 46.11%
14:11:58:WU00:FS01:FahCore 22: 47.81%
14:12:17:WU00:FS01:FahCore 22: 49.52%
14:12:24:WU00:FS01:FahCore 22: 51.23%
14:12:44:WU00:FS01:FahCore 22: 52.94%
14:13:26:WU00:FS01:FahCore 22: 54.64%
14:13:38:WU00:FS01:FahCore 22: 56.35%
14:14:01:WU00:FS01:FahCore 22: 58.06%
14:14:14:WU00:FS01:FahCore 22: 59.77%
14:14:34:WU00:FS01:FahCore 22: 61.48%
14:15:01:WU00:FS01:FahCore 22: 63.18%
14:15:16:WU00:FS01:FahCore 22: 64.89%
14:16:00:WU00:FS01:FahCore 22: 66.60%
14:16:21:WU00:FS01:FahCore 22: 68.31%
14:16:29:WU00:FS01:FahCore 22: 70.01%
14:16:42:WU00:FS01:FahCore 22: 71.72%
14:17:21:WU00:FS01:FahCore 22: 73.43%
14:17:36:WU00:FS01:FahCore 22: 76.84%
14:17:43:WU00:FS01:FahCore 22: 78.55%
14:18:07:WU00:FS01:FahCore 22: 80.26%
14:18:34:WU00:FS01:FahCore 22: 81.97%
14:18:47:WU00:FS01:FahCore 22: 83.67%
14:18:58:WU00:FS01:FahCore 22: 85.38%
14:19:24:WU00:FS01:FahCore 22: 87.09%
14:19:46:WU00:FS01:FahCore 22: 88.80%
14:20:07:WU00:FS01:FahCore 22: 90.50%
14:20:35:WU00:FS01:FahCore 22: 92.21%
14:21:22:WU00:FS01:FahCore 22: 93.92%
14:22:04:WU00:FS01:FahCore 22: 95.63%
14:22:10:WU00:FS01:FahCore 22: 97.34%
14:22:26:WU00:FS01:FahCore 22: 99.04%
14:22:30:WU00:FS01:FahCore 22: Download complete
14:22:30:WU00:FS01:Valid core signature
14:22:30:WU00:FS01:Unpacked 9.32MiB to cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22
14:22:30:WU00:FS01:Starting
14:22:30:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.11/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 704 -lifeline 1328 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:22:30:WU00:FS01:Started FahCore on PID 4652
14:22:30:WU00:FS01:Core PID:4656
14:22:30:WU00:FS01:FahCore 0x22 started
14:22:31:WU00:FS01:0x22:*********************** Log Started 2020-07-20T14:22:30Z ***********************
14:22:31:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:22:31:WU00:FS01:0x22:       Core: Core22
14:22:31:WU00:FS01:0x22:       Type: 0x22
14:22:31:WU00:FS01:0x22:    Version: 0.0.11
14:22:31:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:22:31:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:22:31:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:22:31:WU00:FS01:0x22:       Date: Jun 27 2020
14:22:31:WU00:FS01:0x22:       Time: 22:50:00
14:22:31:WU00:FS01:0x22:   Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
14:22:31:WU00:FS01:0x22:     Branch: core22-0.0.11
14:22:31:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
14:22:31:WU00:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
14:22:31:WU00:FS01:0x22:             -funroll-loops
14:22:31:WU00:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
14:22:31:WU00:FS01:0x22:       Bits: 64
14:22:31:WU00:FS01:0x22:       Mode: Release
14:22:31:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:22:31:WU00:FS01:0x22:             <peastman@stanford.edu>
14:22:31:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 704 -lifeline 4652 -checkpoint 15 -gpu
14:22:31:WU00:FS01:0x22:             0 -gpu-vendor nvidia
14:22:31:WU00:FS01:0x22:************************************ libFAH ************************************
14:22:31:WU00:FS01:0x22:       Time: 22:11:04
14:22:31:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
14:22:31:WU00:FS01:0x22:     Branch: HEAD
14:22:31:WU00:FS01:0x22:************************************ CBang *************************************
14:22:31:WU00:FS01:0x22:       Time: 22:10:11
14:22:31:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
14:22:31:WU00:FS01:0x22:             -funroll-loops -fPIC
14:22:31:WU00:FS01:0x22:************************************ System ************************************
14:22:31:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
14:22:31:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:22:31:WU00:FS01:0x22:       CPUs: 4
14:22:31:WU00:FS01:0x22:     Memory: 15.58GiB
14:22:31:WU00:FS01:0x22:Free Memory: 12.30GiB
14:22:31:WU00:FS01:0x22:    Threads: POSIX_THREADS
14:22:31:WU00:FS01:0x22: OS Version: 5.4
14:22:31:WU00:FS01:0x22:Has Battery: false
14:22:31:WU00:FS01:0x22: On Battery: false
14:22:31:WU00:FS01:0x22: UTC Offset: 2
14:22:31:WU00:FS01:0x22:        PID: 4656
14:22:31:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
14:22:31:WU00:FS01:0x22:********************************************************************************
14:22:31:WU00:FS01:0x22:Project: 11760 (Run 0, Clone 1052, Gen 143)
14:22:31:WU00:FS01:0x22:Unit: 0x000000fd80fccb0a5e6d7cd49d129cd5
14:22:31:WU00:FS01:0x22:Reading tar file core.xml
14:22:31:WU00:FS01:0x22:Reading tar file integrator.xml
14:22:31:WU00:FS01:0x22:Reading tar file state.xml
14:22:31:WU00:FS01:0x22:Reading tar file system.xml
14:22:31:WU00:FS01:0x22:Digital signatures verified
14:22:31:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:22:31:WU00:FS01:0x22:Version 0.0.11
14:22:31:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
14:22:31:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
14:22:31:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
14:22:31:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
14:22:39:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
14:23:41:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
14:24:43:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
14:25:48:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
14:26:56:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
14:28:04:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
14:29:15:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
14:30:24:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
14:31:34:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
14:32:43:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
14:33:52:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
14:35:02:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
14:36:12:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
14:37:21:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
14:38:29:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
14:39:39:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
14:40:48:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
14:41:58:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
14:43:07:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
14:44:17:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
14:45:26:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
14:46:35:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
14:47:39:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
14:48:44:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
14:49:49:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
14:50:54:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
14:51:59:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
14:53:04:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
14:54:08:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
14:55:13:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
14:56:18:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
14:57:23:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
14:58:27:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
14:59:32:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
15:00:37:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
15:01:41:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
15:02:47:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
15:03:51:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
15:04:56:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
15:06:01:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
15:07:06:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
15:08:11:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
15:09:15:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
15:10:20:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
15:11:25:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
15:12:29:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
15:13:35:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
15:14:39:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
15:15:44:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
15:16:49:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
15:17:53:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
15:18:58:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
15:20:05:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
15:21:15:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
15:22:24:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
15:23:33:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
15:24:43:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
15:25:53:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
15:27:02:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
15:28:10:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
15:29:14:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
15:30:20:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
15:31:24:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
15:32:29:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
15:33:34:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
15:34:39:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
15:35:44:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
15:36:49:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
15:37:53:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
15:38:58:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
15:40:03:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
15:41:08:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
15:42:13:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
15:43:17:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
15:44:22:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
15:45:27:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
15:46:32:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
15:47:36:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
15:48:41:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
15:49:46:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
15:50:56:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
15:52:06:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
15:53:15:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
15:54:25:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
15:55:34:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
15:56:43:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
15:57:53:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
15:58:58:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
16:00:02:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
16:01:07:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
16:02:12:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
16:03:17:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
16:04:22:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
16:05:26:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
16:06:31:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
16:07:36:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
16:08:41:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
16:09:46:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
16:10:50:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
16:11:55:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
16:11:56:WU01:FS01:Connecting to 65.254.110.245:80
16:11:57:WU01:FS01:Assigned to work server 140.163.4.241
16:11:57:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104 [GeForce RTX 2060] from 140.163.4.241
16:11:57:WU01:FS01:Connecting to 140.163.4.241:8080
16:12:08:WU01:FS01:Downloading 7.85MiB
16:12:24:WU01:FS01:Download 2.39%
16:13:00:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
16:13:00:WU00:FS01:0x22:Average performance: 53.3333 ns/day
16:13:01:WU00:FS01:0x22:Saving result file ../logfile_01.txt
16:13:01:WU00:FS01:0x22:Saving result file checkpointState.xml
16:13:02:WU00:FS01:0x22:Saving result file positions.xtc
16:13:02:WU00:FS01:0x22:Saving result file science.log
16:13:02:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:13:02:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:13:02:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11760 run:0 clone:1052 gen:143 core:0x22 unit:0x000000fd80fccb0a5e6d7cd49d129cd5
16:13:02:WU00:FS01:Uploading 5.71MiB to 128.252.203.10
16:13:02:WU00:FS01:Connecting to 128.252.203.10:8080
16:13:08:WU00:FS01:Upload 40.51%
16:13:14:WU00:FS01:Upload 86.50%
16:13:17:WU00:FS01:Upload complete
16:13:17:WU00:FS01:Server responded WORK_ACK (400)
16:13:17:WU00:FS01:Final credit estimate, 74553.00 points
16:13:17:WU00:FS01:Cleaning up
**/// The lines below happened after i issued "sudo service FAHclient restart"
16:37:46:Lost lifeline PID 1326, exiting
16:47:44:Caught signal SIGTERM(15) on PID 1328
16:47:44:Exiting, please wait. . .
MeeLee
Re: Linux PopOS and GTX 2060 folds one WU and quits silently
Post by MeeLee »
7.4.4 is an old client.
Try downloading the newer one here:
or on the main page: https://foldingathome.org/start-folding/
Post by Neil-B »
OP states they tried both current client first then tried the old one both with same results
Rel25917
Post by Rel25917 »
The folding client has long had a bug where it doesn't detect stalled connections. Yours tried to get a new unit but didn't finish the download but the client didn't detect it and was just waiting for it to finish. I also see you had trouble getting the core downloaded and the unit you did run had a download error. Is your internet that unstable or just this computer that has problems?
bunkermagnus
Rel25917 wrote:The folding client has long had a bug where it doesn't detect stalled connections. Yours tried to get a new unit but didn't finish the download but the client didn't detect it and was just waiting for it to finish. I also see you had trouble getting the core downloaded and the unit you did run had a download error. Is your internet that unstable or just this computer that has problems?
Thank you for your reply.
I finally seem to have found the problem for the one-WU only problem since my installation has been crunching 3 WU during the night. The only difference is that I added the 'fahclient' user to the groups 'render' and 'video' as I found in another thread here on these forums.
Regarding the download speeds / troubles, yes, they have been absolutely ridiculous the last month, I havs 100Mbps fiber that is very stable, but the last month the speeds overseas to the US have dropped completely, especially for the FAH servers, downloading a 3 Mb core takes 10 minutes, a 7 Mb WU takes 15 min and then it gives up etc.
BUT, for the last 12 hours it has worked flawlessly, albeit a bit slow download speeds but no failures. I'll keep monitoring.
Thank you.
Yes, I have been going back an forth a couple of times between 7.6.13 to 7.4.4 but they've yielded the same result until I did the 'fahclient' fix above.
Welcome to the F@H Forum bunkermagnus,
Since you have already configured your identity, you no longer need this line so you can remove it from the configuration:
