GPU [Not Folding - Mint 20.04 LTS]
JamesMcCann
Hi can you add TU106 [GeForce RTX 2060 SUPER] ASUS
but my GPU shows on the programme its FahCore is 0x22 it is waiting on a FahCore Run and it is just waiting on The ETA of 24 hours 00 mins but it keeps jumping from job to job in this condition
can you help please
0x8086:0x2020:0:0:0:Intel Corporation:
0x8086:0x2021:0:4:0:Intel Corporation:
0x8086:0x2021:0:4:1:Intel Corporation:
0x8086:0x2021:0:4:2:Intel Corporation:
0x8086:0x2021:0:4:3:Intel Corporation:
0x8086:0x2021:0:4:4:Intel Corporation:
0x8086:0x2021:0:4:5:Intel Corporation:
0x8086:0x2021:0:4:6:Intel Corporation:
0x8086:0x2021:0:4:7:Intel Corporation:
0x8086:0x2024:0:5:0:Intel Corporation:
0x8086:0x2025:0:5:2:Intel Corporation:
0x8086:0x2026:0:5:4:Intel Corporation:
0x8086:0x2014:0:8:0:Intel Corporation:
0x8086:0x2015:0:8:1:Intel Corporation:
0x8086:0x2016:0:8:2:Intel Corporation:
0x8086:0xa2af:0:20:0:Intel Corporation:
0x8086:0xa2b1:0:20:2:Intel Corporation:
0x8086:0xa2ba:0:22:0:Intel Corporation:
0x8086:0xa282:0:23:0:Intel Corporation:
0x8086:0xa2e7:0:27:0:Intel Corporation:
0x8086:0xa2eb:0:27:4:Intel Corporation:
0x8086:0xa290:0:28:0:Intel Corporation:
0x8086:0xa294:0:28:4:Intel Corporation:
0x8086:0xa2d2:0:31:0:Intel Corporation:
0x8086:0xa2a1:0:31:2:Intel Corporation:
0x8086:0xa2f0:0:31:3:Intel Corporation:
0x8086:0xa2a3:0:31:4:Intel Corporation:
0x8086:0x15b8:0:31:6:Intel Corporation:
Segmentation fault (core dumped)
can you help please
Re: GPU
Please post the first 100-200 lines of your log. Directions for locating the log and posting its contents are here - viewtopic.php?f=61&t=26036.
Based on you mentioning that Core_22 is shown as running, this GPU is already added as one of the three different Device ID numbers for a 2060 Super GPU in the GPUs.txt file. If the WU is not running, the slot cn be waiting for your system to be idle, no user input detected from keyboard, mouse, etc.
If the runs just keep ending with an error, you may be running on just the MS Windows Update drivers. You will need to download drivers from nVidia to support your 2060 Super which includes the OpenCL support that MS leaves out.
Re: GPU
The information you posed about devices 0x8086:0x....0:Intel Corporation... is not useful so we're ignoring it. The Intel IGPs are not supported at this time.
Additional information about the Segmentation fault (core dumped) will probably be useful. Please post that segment of FAH's log along with the portion mentione above.
JamesMcCann
Re: GPU
Hi I am running it on Linux mint 20.04 LTS if that helps
JamesMcCann
Re: GPU
*********************** Log Started 2020-07-19T03:39:50Z ***********************
03:39:50:Trying to access database...
03:39:50:Successfully acquired database lock
03:39:50:Read GPUs.txt
03:39:50:Enabled folding slot 00: PAUSED cpu:10 (by user)
03:39:50:Enabled folding slot 01: PAUSED gpu:0:TU106 [GeForce RTX 2060 SUPER] (by user)
03:39:50:****************************** FAHClient ******************************
03:39:50: Version: 7.6.13
03:39:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:39:50: Copyright: 2020 foldingathome.org
03:39:50: Homepage: https://foldingathome.org/
03:39:50: Date: Apr 28 2020
03:39:50: Time: 04:20:16
03:39:50: Revision: 5a652817f46116b6e135503af97f18e094414e3b
03:39:50: Branch: master
03:39:50: Compiler: GNU 8.3.0
03:39:50: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
03:39:50: -fno-pie
03:39:50: Platform: linux2 4.19.0-5-amd64
03:39:50: Bits: 64
03:39:50: Mode: Release
03:39:50: Args: --child /etc/fahclient/config.xml --run-as fahclient
03:39:50: --pid-file=/var/run/fahclient.pid --daemon
03:39:50: Config: /etc/fahclient/config.xml
03:39:50:******************************** CBang ********************************
03:39:50: Date: Apr 25 2020
03:39:50: Time: 00:07:53
03:39:50: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
03:39:50: -fno-pie -fPIC
03:39:50: Bits: 64
03:39:50:******************************* System ********************************
03:39:50: CPU: Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz
03:39:50: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
03:39:50: CPUs: 12
03:39:50: Memory: 62.51GiB
03:39:50: Free Memory: 61.59GiB
03:39:50: Threads: POSIX_THREADS
03:39:50: OS Version: 5.4
03:39:50: Has Battery: false
03:39:50: On Battery: false
03:39:50: UTC Offset: 1
03:39:50: PID: 1725
03:39:50: CWD: /var/lib/fahclient
03:39:50: OS: Linux 5.4.0-40-generic x86_64
03:39:50: OS Arch: AMD64
03:39:50: GPUs: 1
03:39:50: GPU 0: Bus:101 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2060 SUPER]
03:39:50:CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:7.5 Driver:10.2
03:39:50: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
03:39:50: libOpenCL.so: cannot open shared object file: No such file or
03:39:50: directory
03:39:50:******************************* libFAH ********************************
03:39:50: Date: Apr 15 2020
03:39:50: Time: 21:43:24
03:39:50: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
03:39:50: -fno-pie
03:39:50: Bits: 64
03:39:50:***********************************************************************
03:39:50:<config>
03:39:50: <!-- Client Control -->
03:39:50: <fold-anon v='true'/>
03:39:50:
03:39:50: <!-- Folding Slot Configuration -->
03:39:50: <cause v='COVID_19'/>
03:39:50: <gpu v='false'/>
03:39:50:
03:39:50: <!-- Network -->
03:39:50: <proxy v=':8080'/>
03:39:50:
03:39:50: <!-- Slot Control -->
03:39:50: <pause-on-battery v='false'/>
03:39:50:
03:39:50: <!-- User Information -->
03:39:50: <passkey v='*****'/>
03:39:50: <user v='JamesMcCann'/>
03:39:50:
03:39:50: <!-- Folding Slots -->
03:39:50: <slot id='0' type='CPU'>
03:39:50: <paused v='true'/>
03:39:50: </slot>
03:39:50: <slot id='1' type='GPU'>
03:39:50: </slot>
03:39:50:</config>
03:39:50:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:39:50:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:39:50:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:39:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:39:51:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed[0m
03:39:51:WU02:FS00:Trying to send results to collection server
03:39:51:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:39:51:WU02:FS00:Connecting to 52.224.109.74:8080
[93m03:39:51:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[91m03:39:52:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:39:52:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:39:52:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:39:52:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:39:52:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:39:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:39:53:WU02:FS00:Trying to send results to collection server
03:39:53:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:39:53:WU02:FS00:Connecting to 52.224.109.74:8080
[93m03:39:53:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[91m03:39:53:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:40:52:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:40:52:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:40:52:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:40:52:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:40:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:40:52:WU02:FS00:Trying to send results to collection server
03:40:52:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:40:52:WU02:FS00:Connecting to 52.224.109.74:8080
[91m03:40:53:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:41:01:FS00:Unpaused
03:41:01:FS01:Unpaused
03:41:01:WU01:FS01:Starting
[91m03:41:01:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:41:01:WU00:FS00:Starting
03:41:01:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1725 -checkpoint 15 -np 10
03:41:01:WU00:FS00:Started FahCore on PID 3039
03:41:01:WU00:FS00:Core PID:3043
03:41:01:WU00:FS00:FahCore 0xa7 started
03:41:01:WU00:FS00:0xa7:*********************** Log Started 2020-07-19T03:41:01Z ***********************
03:41:01:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:41:01:WU00:FS00:0xa7: Type: 0xa7
03:41:01:WU00:FS00:0xa7: Core: Gromacs
03:41:01:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 3039 -checkpoint 15 -np
03:41:01:WU00:FS00:0xa7: 10
03:41:01:WU00:FS00:0xa7:************************************ CBang *************************************
03:41:01:WU00:FS00:0xa7: Date: Nov 27 2019
03:41:01:WU00:FS00:0xa7: Time: 11:26:54
03:41:01:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:41:01:WU00:FS00:0xa7: Branch: master
03:41:01:WU00:FS00:0xa7: Compiler: GNU 8.3.0
03:41:01:WU00:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
03:41:01:WU00:FS00:0xa7: -fno-pie -fPIC
03:41:01:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
03:41:01:WU00:FS00:0xa7: Bits: 64
03:41:01:WU00:FS00:0xa7: Mode: Release
03:41:01:WU00:FS00:0xa7:************************************ System ************************************
03:41:01:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz
03:41:01:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
03:41:01:WU00:FS00:0xa7: CPUs: 12
03:41:01:WU00:FS00:0xa7: Memory: 62.51GiB
03:41:01:WU00:FS00:0xa7:Free Memory: 60.03GiB
03:41:01:WU00:FS00:0xa7: Threads: POSIX_THREADS
03:41:01:WU00:FS00:0xa7: OS Version: 5.4
03:41:01:WU00:FS00:0xa7:Has Battery: false
03:41:01:WU00:FS00:0xa7: On Battery: false
03:41:01:WU00:FS00:0xa7: UTC Offset: 1
03:41:01:WU00:FS00:0xa7: PID: 3043
03:41:01:WU00:FS00:0xa7: CWD: /var/lib/fahclient/work
03:41:01:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:41:01:WU00:FS00:0xa7: Version: 0.0.19
03:41:01:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:41:01:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:41:01:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:41:01:WU00:FS00:0xa7: Date: Nov 26 2019
03:41:01:WU00:FS00:0xa7: Time: 00:41:42
03:41:01:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:41:01:WU00:FS00:0xa7:************************************ Build *************************************
03:41:01:WU00:FS00:0xa7: SIMD: avx_256
03:41:01:WU00:FS00:0xa7:********************************************************************************
03:41:01:WU00:FS00:0xa7:Project: 13794 (Run 8, Clone 333, Gen 16)
03:41:01:WU00:FS00:0xa7:Unit: 0x000000150002894c5dae0b31ae0f4e29
03:41:01:WU00:FS00:0xa7:Digital signatures verified
03:41:01:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpi state.cpt -cpt 15 -nt 10
03:41:01:WU00:FS00:0xa7:Steps: first=40000000 total=2500000
03:41:02:WU00:FS00:0xa7:Completed 2316822 out of 2500000 steps (92%)
03:41:51:WU00:FS00:0xa7:Completed 2325000 out of 2500000 steps (93%)
03:41:52:Removing old file 'configs/config-20200713-151705.xml'
03:41:52:Saving configuration to /etc/fahclient/config.xml
03:41:52:<config>
03:41:52: <!-- Client Control -->
03:41:52: <fold-anon v='true'/>
03:41:52:
03:41:52: <!-- Folding Slot Configuration -->
03:41:52: <cause v='COVID_19'/>
03:41:52: <gpu v='false'/>
03:41:52:
03:41:52: <!-- Network -->
03:41:52: <proxy v=':8080'/>
03:41:52:
03:41:52: <!-- Slot Control -->
03:41:52: <pause-on-battery v='false'/>
03:41:52:
03:41:52: <!-- User Information -->
03:41:52: <passkey v='*****'/>
03:41:52: <user v='JamesMcCann'/>
03:41:52:
03:41:52: <!-- Folding Slots -->
03:41:52: <slot id='0' type='CPU'/>
03:41:52: <slot id='1' type='GPU'/>
03:41:52:</config>
03:41:52:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:41:52:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:41:52:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:41:52:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:41:52:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:41:52:WU02:FS00:Trying to send results to collection server
03:41:52:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:41:52:WU02:FS00:Connecting to 52.224.109.74:8080
[91m03:41:53:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:42:01:WU01:FS01:Starting
[91m03:42:01:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:43:29:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:43:29:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:43:29:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:43:30:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
03:43:30:WU02:FS00:Connecting to 40.114.52.201:80
[93m03:43:30:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:43:30:WU02:FS00:Trying to send results to collection server
03:43:30:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:43:30:WU02:FS00:Connecting to 52.224.109.74:8080
[91m03:43:30:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:43:38:WU01:FS01:Starting
[91m03:43:38:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:44:14:WU00:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
03:46:07:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:46:07:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:46:07:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:46:07:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:46:07:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:46:07:WU02:FS00:Trying to send results to collection server
03:46:07:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:46:07:WU02:FS00:Connecting to 52.224.109.74:8080
[91m03:46:07:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:46:16:WU01:FS01:Starting
[91m03:46:16:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:46:35:WU00:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
03:48:57:WU00:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
03:50:21:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13851 run:0 clone:9436 gen:264 core:0xa7 unit:0x00000136287234c95e72ea5df609a646
03:50:21:WU02:FS00:Uploading 2.51MiB to 40.114.52.201
03:50:21:WU02:FS00:Connecting to 40.114.52.201:8080
[93m03:50:21:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80[0m
[93m03:50:21:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection refused[0m
03:50:21:WU02:FS00:Trying to send results to collection server
03:50:21:WU02:FS00:Uploading 2.51MiB to 52.224.109.74
03:50:21:WU02:FS00:Connecting to 52.224.109.74:8080
[91m03:50:22:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: Connection refused[0m
03:50:30:WU01:FS01:Starting
[91m03:50:30:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:50:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:11761 run:0 clone:7595 gen:96 core:0x22 unit:0x000000b280fccb0a5e70019689e8ed1f
03:50:30:WU01:FS01:Connecting to 128.252.203.10:8080
03:50:31:WU01:FS01:Server responded WORK_ACK (400)
03:50:31:WU01:FS01:Cleaning up
03:50:31:WU03:FS01:Connecting to assign1.foldingathome.org:80
03:50:31:WU03:FS01:Assigned to work server 140.163.4.241
03:50:31:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2060 SUPER] from 140.163.4.241
03:50:31:WU03:FS01:Connecting to 140.163.4.241:8080
03:50:43:WU03:FS01:Downloading 7.85MiB
03:50:48:WU03:FS01:Download complete
03:50:48:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:3606 gen:108 core:0x22 unit:0x000000af8ca304f15e69ee08d31b0aec
03:50:48:WU03:FS01:Starting
[91m03:50:48:ERROR:WU03:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:51:18:WU00:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
03:51:48:WU03:FS01:Starting
[91m03:51:48:ERROR:WU03:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:53:25:WU03:FS01:Starting
[91m03:53:25:ERROR:WU03:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually[0m
03:53:39:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
Reason: added Code tags to log
Re: GPU
Part of the error messages are pointing to an incomplete install of support for OpenCL. For Linux you need the nVidia proprietary drivers and OpenCL support installed and the OpenCL dev kit. The user that FAHClient and the rest of the processes runs under may need to be added to the video and possibly the render groups as well.
JamesMcCann
Re: GPU [Not Folding - Mint 20.04 LTS]
hi Joe how would i go about doing that will i need to install the nvidia drivers form there website
Since you're running Linux Mint, it can be enough to install those proprietary drivers with Linux Mint's own driver install tool. You might already have them on your system.
First try this:
Install some OpenCL development files from ocl-icd-opencl-dev, either using synaptic or
Add fahclient to the video and render groups:
Make a file called /etc/systemd/system/FAHClient.service
and put this in the file:
Then run
Now look if the GPU is found. If it still doesn't work, then you probably don't have the correct driver. Try.
If that doesn't work either, it's time to look at https://docs.nvidia.com/cuda/cuda-insta ... index.html to install Nvidia's CUDA toolkit.
First try this:
sudo apt install ocl-icd-opencl-devCode: Select all
sudo adduser fahclient video
sudo adduser fahclient renderand put this in the file:
[Unit]
Description=Folding@Home Client
After=network.target
[Service]
Type=simple
ExecStart=/usr/bin/FAHClient /etc/fahclient/config.xml --pid-file=/var/run/fahclient/fahclient.pid --daemon
PIDFile=/var/run/fahclient/fahclient.pid
User=fahclient
RuntimeDirectory=fahclient
WorkingDirectory=~
[Install]
WantedBy=multi-user.target
sudo systemctl enable FAHClient.service
sudo systemctl restart FAHClient.serviceCode: Select all
sudo ubuntu-drivers autoinstall
sudo systemctl restart FAHClient.serviceOnline: GTX 1660 Super + occasional CPU folding in the cold.
JamesMcCann
how do you make a file what is the processes in Linux mint and how do i execute it as i fave made this folder in the location of etc/systemd/system/FAHClient.service
and then i just put it in as root and then made a file to execute called FHAClient.service with the contents of
[Unit]
[Service]
Type=simple
User=fahclient
WorkingDirectory=~
[Install]
but it will not work can anyone help as i have the Nvidia drivers of 440 installed it is the recommended one
thanks
james
[Unit]
[Service]
Type=simple
User=fahclient
WorkingDirectory=~
[Install]
thanks
james
That FAHClient.service file is a service start-up file which supersedes the regular init.d file.
You can make that file with for example
paste the code, and then press Ctrl-o Enter Ctrl-x
Make sure there are no line feeds in this one, it is one long line:
Test it by running the command
if it worked, make sure to enable it on bootup:
What is the ouput of the command
sudo pico /etc/systemd/system/FAHClient.serviceMake sure there are no line feeds in this one, it is one long line:
ExecStart=/usr/bin/FAHClient /etc/fahclient/config.xml --pid-file=/var/run/fahclient/fahclient.pid --daemonCode: Select all
sudo systemctl enable FAHClient.serviceCode: Select all
groups fahclientOnline: GTX 1660 Super + occasional CPU folding in the cold.
@Chabgood, why would you 'mutilate' Linux in that way?
Like, why is this even necessary?:
All you need to do is install the Nvidia drivers and opencl drivers, and set GPU to true in advanced.
If you're running multiple (Nvidia) GPUs, I wouldn't even try the included .deb files, and install from the .run files instead.
It gets better compatibility with everything...
CODE: SELECT ALL
sudo adduser fahclient renderIf you're running multiple (Nvidia) GPUs, I wouldn't even try the included .deb files, and install from the .run files instead.
Some newer versions of Linux require that the user the client runs under - fahclient - be a member of the video group and possibly the render group for it to access the video subsystem and be abe to do GPU processing. Without that membership the workaround is to run under root, not the best alternative.MeeLee wrote:Like, why is this even necessary?:Code: Select all
Add fahclient to the video and render groups: sudo adduser fahclient video sudo adduser fahclient render
Sometime in the future the installer for the client should have that as part of its creation of the fahclient user. But for now the installer was created at a time that Ubuntu 16.04 was the current LTS release, so is missing requirements added in later versions and the distributions that are offshoots from them.
I have had that issue only with an AMD card. I was able to fold on Ubuntu 18.04 with a Nvidia card without changing the group or do anything more than install Nvidia drivers and the opencl dev package. That hassle with permissions/groups began only while trying to fold with a 5700 XT.
