09:49:31:WU00:FS03:0x22:Completed 980000 out of 1000000 steps (98%)
09:55:10:WU00:FS03:0x22:Completed 990000 out of 1000000 steps (99%)
10:00:48:WU00:FS03:0x22:Completed 1000000 out of 1000000 steps (100%)
10:00:48:WU00:FS03:0x22:Average performance: 51.1545 ns/day
10:00:53:WU00:FS03:0x22:Saving result file ..\logfile_01.txt
10:00:53:WU00:FS03:0x22:Saving result file checkpointState.xml.bz2
10:00:53:WU00:FS03:0x22:Saving result file globals.csv
10:00:53:WU00:FS03:0x22:Saving result file positions.xtc
10:00:53:WU00:FS03:0x22:Saving result file science.log
10:00:53:WU00:FS03:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:00:55:WARNING:WU00:FS03:FahCore returned an unknown error code which probably indicates that it crashed
10:00:55:WARNING:WU00:FS03:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
10:00:55:WU00:FS03:Starting
10:00:55:WU00:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 7224 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:00:55:WU00:FS03:Started FahCore on PID 7204
10:00:55:WU00:FS03:Core PID:4560
10:00:55:WU00:FS03:FahCore 0x22 started
10:00:56:WU00:FS03:0x22:*********************** Log Started 2020-07-16T10:00:55Z ***********************
10:00:56:WU00:FS03:0x22:*************************** Core22 Folding@home Core ***************************
10:00:56:WU00:FS03:0x22: Core: Core22
10:00:56:WU00:FS03:0x22: Type: 0x22
10:00:56:WU00:FS03:0x22: Version: 0.0.11
10:00:56:WU00:FS03:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:00:56:WU00:FS03:0x22: Copyright: 2020 foldingathome.org
10:00:56:WU00:FS03:0x22: Homepage: https://foldingathome.org/
10:00:56:WU00:FS03:0x22: Date: Jun 26 2020
10:00:56:WU00:FS03:0x22: Time: 19:49:16
10:00:56:WU00:FS03:0x22: Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
10:00:56:WU00:FS03:0x22: Branch: core22-0.0.11
10:00:56:WU00:FS03:0x22: Compiler: Visual C++ 2015
10:00:56:WU00:FS03:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
10:00:56:WU00:FS03:0x22: Platform: win32 10
10:00:56:WU00:FS03:0x22: Bits: 64
10:00:56:WU00:FS03:0x22: Mode: Release
10:00:56:WU00:FS03:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:00:56:WU00:FS03:0x22: <peastman@stanford.edu>
10:00:56:WU00:FS03:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7204 -checkpoint 15
10:00:56:WU00:FS03:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:00:56:WU00:FS03:0x22:************************************ libFAH ************************************
10:00:56:WU00:FS03:0x22: Time: 19:47:12
10:00:56:WU00:FS03:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
10:00:56:WU00:FS03:0x22: Branch: HEAD
10:00:56:WU00:FS03:0x22:************************************ CBang *************************************
10:00:56:WU00:FS03:0x22: Time: 19:46:11
10:00:56:WU00:FS03:0x22: Revision: f8529962055b0e7bde23e429f5072ff758089dee
10:00:56:WU00:FS03:0x22: Branch: master
10:00:56:WU00:FS03:0x22:************************************ System ************************************
10:00:56:WU00:FS03:0x22: CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
10:00:56:WU00:FS03:0x22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
10:00:56:WU00:FS03:0x22: CPUs: 8
10:00:56:WU00:FS03:0x22: Memory: 7.69GiB
10:00:56:WU00:FS03:0x22:Free Memory: 3.40GiB
10:00:56:WU00:FS03:0x22: Threads: WINDOWS_THREADS
10:00:56:WU00:FS03:0x22: OS Version: 6.2
10:00:56:WU00:FS03:0x22:Has Battery: false
10:00:56:WU00:FS03:0x22: On Battery: false
10:00:56:WU00:FS03:0x22: UTC Offset: 2
10:00:56:WU00:FS03:0x22: PID: 4560
10:00:56:WU00:FS03:0x22: CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
10:00:56:WU00:FS03:0x22:********************************************************************************
10:00:56:WU00:FS03:0x22:Project: 13416 (Run 1040, Clone 205, Gen 0)
10:00:56:WU00:FS03:0x22:Unit: 0x0000000012bc7d9a5f0f8f4a3fff7242
10:00:56:WU00:FS03:0x22:Reading tar file core.xml
10:00:56:WU00:FS03:0x22:Reading tar file integrator.xml
10:00:56:WU00:FS03:0x22:Reading tar file state.xml.bz2
10:00:56:WU00:FS03:0x22:Reading tar file system.xml.bz2
10:00:56:WU00:FS03:0x22:Digital signatures verified
10:00:56:WU00:FS03:0x22:Folding@home GPU Core22 Folding@home Core
10:00:56:WU00:FS03:0x22:Version 0.0.11
10:00:59:WU00:FS03:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
10:00:59:WU00:FS03:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
10:00:59:WU00:FS03:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
10:00:59:WU00:FS03:0x22: Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
10:01:17:WU00:FS03:0x22:Completed 0 out of 1000000 steps (0%)
10:06:56:WU00:FS03:0x22:Completed 10000 out of 1000000 steps (1%)
10:12:33:WU00:FS03:0x22:Completed 20000 out of 1000000 steps (2%)
10:18:12:WU00:FS03:0x22:Completed 30000 out of 1000000 steps (3%)
10:23:50:WU00:FS03:0x22:Completed 40000 out of 1000000 steps (4%)
10:29:28:WU00:FS03:0x22:Completed 50000 out of 1000000 steps (5%)
10:35:06:WU00:FS03:0x22:Completed 60000 out of 1000000 steps (6%)
10:40:42:WU00:FS03:0x22:Completed 70000 out of 1000000 steps (7%)
10:46:20:WU00:FS03:0x22:Completed 80000 out of 1000000 steps (8%)
10:51:59:WU00:FS03:0x22:Completed 90000 out of 1000000 steps (9%)
10:57:36:WU00:FS03:0x22:Completed 100000 out of 1000000 steps (10%)
As an added issue the FAH client downloads a new WU to a new directory that doesn’t get started, since the client just restarts the old one from 0% again, so you end up with a downloaded WU that is doing nothing, in the hopes that the previous one will finish at some point.
I tried setting the “next-unit-percentage” to “100”, in the hopes that a new download would not happen until the previous one was fully completed, but it just downloads at 100% instead of 99%, so I would suggest adding another value to this configuration option “-1” or something, where a new WU download doesn’t happen until the FahCore returns a correct finishing code “FahCore returned: FINISHED_UNIT (100 = 0x64)”, to avoid any new WU download until the previous one is actually handled.
