F@H no longer "sees" nvidia quadro t2000
The_Bad_Penguin
Post by The_Bad_Penguin »
I can only assume some sort of microsoft/dell/??? update must have changed something.
Was crunching F@H for a month or so, then F@H said no w/u's. Didn't really investigate at the time, crunched gpu for some BOINC projects.
Kept checking F@H, and same, no wu's.
Finally looking into it, it seems that F@H no longer shows the nvidia as an option for my gpu slot.
It will only show the integrated Intel UHD 630.
Any ideas what might have happened, with a perfectly fine F@H cruncher that would suddenly make the nvidia gpu disappear, and only the intel remain?
How do I get F@H to once again "see" the nvidia gpu?
Thanks in advance!
EDIT --> I noticed that since this issue, I've been seeing:
Adding folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
Removing old file 'configs/config-20200614-215421.xml'
Saving configuration to config.xml
Something going on with my config files?
12:15:03:Adding folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
12:15:03:Removing old file 'configs/config-20200614-215421.xml'
12:15:03:Saving configuration to config.xml
12:15:03:<config>
12:15:03:  <!-- Folding Core -->
12:15:03:  <checkpoint v='5'/>
12:15:03:  <core-priority v='low'/>
12:15:03:
12:15:03:  <!-- Network -->
12:15:03:  <proxy v=':8080'/>
12:15:03:
12:15:03:  <!-- Slot Control -->
12:15:03:  <pause-on-battery v='false'/>
12:15:03:  <power v='full'/>
12:15:03:
12:15:03:  <!-- User Information -->
12:15:03:  <passkey v='*****'/>
12:15:03:  <team v='223518'/>
12:15:03:  <user v='The_Bad_Penguin'/>
12:15:03:
12:15:03:  <!-- Folding Slots -->
12:15:03:  <slot id='1' type='GPU'/>
12:15:03:</config>
<snip>
'assign1.foldingathome.org:80': No WUs available for this configuration
12:24:35:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:24:35:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:24:35:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:24:35:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:24:35:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:24:36:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:24:36:ERROR:WU01:FS01:Exception: Could not get an assignment
Re: F@H no longer "sees" nvidia quadro t2000
You have run into a bug in how the client handles some changes to the GPUs.txt. Apparently your client reached the once a month check for a new copy of the files. Entries have been added for a number of Intel iGPUs and some were enabled so the researchers could run internal tests on GPU processing on them and whether they could get accurate, usable results. An unintended side effect has been some folders configurations have been messed up.
First, could you post the very beginning of the log file where it shows the startup information such as hardware, software and client configuration. In the FAHControl log window you will need to use the Refresh to reload from the beginning. Unchecking the Follow will make it easier to scroll back to the beginning.
Then you will need to use Configure to keep the client from requesting work for the UHD Graphics 630. Pause that GPU slot, then in Configure select the Slots tab. Click on the GPU slot and then Edit. Add the parameter 'pause-on-start' and set it to 'true', OK the change and Save.
The client should detect GPU hardware for the Quadro T2000, that would be in the information shown during startup. If detected, you will need to manually add a slot for that GPU. Using Configure, go to the Slots tab again and click Add. Click on the radio button the left for GPU. Depending on the theme used, the CPU and GPU radio buttons may not be too visible. Then OK and Save the changes. The T2000 should have a GPU slot showing again and should be able to process WUs.
One note, do not remove the slot for the Intel iGPU, the client will just try to add one again the next time it is restarted. That will get you right back to where the client is now.
The_Bad_Penguin
Thanks for assist!
I can get as far as just before this: The client should detect GPU hardware for the Quadro T2000.
Does not detect the T2000, to the best of my knowledge.
*********************** Log Started 2020-07-05T10:43:44Z ***********************
10:43:44:Trying to access database...
10:43:44:Successfully acquired database lock
10:43:44:Read GPUs.txt
10:43:46:Enabled folding slot 01: PAUSED gpu:0:Gen9p5/GT2 [UHD Graphics 630] (by user)
10:43:47:****************************** FAHClient ******************************
10:43:47:        Version: 7.6.13
10:43:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:43:47:      Copyright: 2020 foldingathome.org
10:43:47:       Homepage: https://foldingathome.org/
10:43:47:           Date: Apr 27 2020
10:43:47:           Time: 21:21:01
10:43:47:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
10:43:47:         Branch: master
10:43:47:       Compiler: Visual C++ 2008
10:43:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:43:47:       Platform: win32 10
10:43:47:           Bits: 32
10:43:47:           Mode: Release
10:43:47:         Config: C:\Users\badpe\AppData\Roaming\FAHClient\config.xml
10:43:47:******************************** CBang ********************************
10:43:47:           Date: Apr 24 2020
10:43:47:           Time: 17:07:55
10:43:47:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
10:43:47:           Bits: 32
10:43:47:******************************* System ********************************
10:43:47:            CPU: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
10:43:47:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:43:47:           CPUs: 16
10:43:47:         Memory: 63.73GiB
10:43:47:    Free Memory: 57.59GiB
10:43:47:        Threads: WINDOWS_THREADS
10:43:47:     OS Version: 6.2
10:43:47:    Has Battery: true
10:43:47:     On Battery: true
10:43:47:     UTC Offset: -4
10:43:47:            PID: 12760
10:43:47:            CWD: C:\Users\badpe\AppData\Roaming\FAHClient
10:43:47:  Win32 Service: false
10:43:47:             OS: Windows 10 Enterprise
10:43:47:        OS Arch: AMD64
10:43:47:           GPUs: 2
10:43:47:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
10:43:47:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117GLM [Quadro T2000 Mobile /
10:43:47:                 Max-Q]
10:43:47:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
10:43:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.45
10:43:47:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
10:43:47:******************************* libFAH ********************************
10:43:47:           Date: Apr 15 2020
10:43:47:           Time: 14:53:14
10:43:47:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:43:47:           Bits: 32
10:43:47:***********************************************************************
10:43:47:<config>
10:43:47:  <!-- Folding Core -->
10:43:47:  <checkpoint v='5'/>
10:43:47:  <core-priority v='low'/>
10:43:47:
10:43:47:  <!-- Network -->
10:43:47:  <proxy v=':8080'/>
10:43:47:
10:43:47:  <!-- Slot Control -->
10:43:47:  <pause-on-battery v='false'/>
10:43:47:  <power v='full'/>
10:43:47:
10:43:47:  <!-- User Information -->
10:43:47:  <passkey v='*****'/>
10:43:47:  <team v='223518'/>
10:43:47:  <user v='The_Bad_Penguin'/>
10:43:47:
10:43:47:  <!-- Folding Slots -->
10:43:47:  <slot id='1' type='GPU'>
10:43:47:    <paused v='true'/>
10:43:47:  </slot>
10:43:47:</config>
11:17:52:17:127.0.0.1:New Web session
******************************* Date: 2020-07-05 *******************************
21:51:13:44:127.0.0.1:New Web session
******************************* Date: 2020-07-06 *******************************
13:43:08:71:127.0.0.1:New Web session
******************************* Date: 2020-07-07 *******************************
11:09:12:100:127.0.0.1:New Web session
21:31:21:128:127.0.0.1:New Web session
01:56:56:145:127.0.0.1:New Web session
******************************* Date: 2020-07-09 *******************************
18:24:30:172:127.0.0.1:New Web session
******************************* Date: 2020-07-10 *******************************
12:44:57:199:127.0.0.1:New Web session
13:28:46:227:127.0.0.1:New Web session
******************************* Date: 2020-07-13 *******************************
00:10:13:FS01:Unpaused
00:10:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:10:14:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:10:14:WU00:FS01:Connecting to assign2.foldingathome.org:80
00:10:15:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:10:15:WU00:FS01:Connecting to assign3.foldingathome.org:80
00:10:15:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:10:15:WU00:FS01:Connecting to assign4.foldingathome.org:80
00:10:15:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:10:15:ERROR:WU00:FS01:Exception: Could not get an assignment
00:10:16:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:10:16:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:10:16:WU00:FS01:Connecting to assign2.foldingathome.org:80
00:10:16:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:10:16:WU00:FS01:Connecting to assign3.foldingathome.org:80
00:10:17:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:10:17:WU00:FS01:Connecting to assign4.foldingathome.org:80
00:10:17:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:10:17:ERROR:WU00:FS01:Exception: Could not get an assignment
00:10:27:244:127.0.0.1:New Web session
00:10:56:Removing old file 'configs/config-20200603-053728.xml'
00:10:56:Saving configuration to config.xml
00:10:56:<config>
00:10:56:  <!-- Folding Core -->
00:10:56:  <checkpoint v='5'/>
00:10:56:  <core-priority v='low'/>
00:10:56:
00:10:56:  <!-- Network -->
00:10:56:  <proxy v=':8080'/>
00:10:56:
00:10:56:  <!-- Slot Control -->
00:10:56:  <pause-on-battery v='false'/>
00:10:56:  <power v='full'/>
00:10:56:
00:10:56:  <!-- User Information -->
00:10:56:  <passkey v='*****'/>
00:10:56:  <team v='223518'/>
00:10:56:  <user v='The_Bad_Penguin'/>
00:10:56:
00:10:56:  <!-- Folding Slots -->
00:10:56:  <slot id='1' type='GPU'/>
00:10:56:</config>
00:11:16:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:11:16:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:11:16:WU00:FS01:Connecting to assign2.foldingathome.org:80
00:11:17:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:11:17:WU00:FS01:Connecting to assign3.foldingathome.org:80
00:11:17:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:11:17:WU00:FS01:Connecting to assign4.foldingathome.org:80
00:11:17:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:11:17:ERROR:WU00:FS01:Exception: Could not get an assignment
00:12:53:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:12:53:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:12:53:WU00:FS01:Connecting to assign2.foldingathome.org:80
00:12:54:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:12:54:WU00:FS01:Connecting to assign3.foldingathome.org:80
00:12:54:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:12:54:WU00:FS01:Connecting to assign4.foldingathome.org:80
00:12:55:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:12:55:ERROR:WU00:FS01:Exception: Could not get an assignment
00:13:29:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:15:30:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:15:31:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:15:31:WU00:FS01:Connecting to assign2.foldingathome.org:80
00:15:31:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:15:31:WU00:FS01:Connecting to assign3.foldingathome.org:80
00:15:31:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:15:31:WU00:FS01:Connecting to assign4.foldingathome.org:80
00:15:32:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:15:32:ERROR:WU00:FS01:Exception: Could not get an assignment
00:17:32:FS01:Paused
00:18:03:Removing old file 'configs/config-20200603-144426.xml'
00:18:03:Saving configuration to config.xml
00:18:03:<config>
00:18:03:  <!-- Folding Core -->
00:18:03:  <checkpoint v='5'/>
00:18:03:  <core-priority v='low'/>
00:18:03:
00:18:03:  <!-- Network -->
00:18:03:  <proxy v=':8080'/>
00:18:03:
00:18:03:  <!-- Slot Control -->
00:18:03:  <pause-on-battery v='false'/>
00:18:03:  <power v='full'/>
00:18:03:
00:18:03:  <!-- User Information -->
00:18:03:  <passkey v='*****'/>
00:18:03:  <team v='223518'/>
00:18:03:  <user v='The_Bad_Penguin'/>
00:18:03:
00:18:03:  <!-- Folding Slots -->
00:18:03:  <slot id='1' type='GPU'>
00:18:03:    <paused v='true'/>
00:18:03:  </slot>
00:18:03:</config>
12:07:17:FS01:Unpaused
12:07:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:07:18:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:07:18:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:07:18:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:07:18:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:07:19:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:07:19:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:07:19:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:07:19:ERROR:WU00:FS01:Exception: Could not get an assignment
12:07:41:Removing old file 'configs/config-20200603-160344.xml'
12:07:41:Saving configuration to config.xml
12:07:41:<config>
12:07:41:  <!-- Folding Core -->
12:07:41:  <checkpoint v='5'/>
12:07:41:  <core-priority v='low'/>
12:07:41:
12:07:41:  <!-- Network -->
12:07:41:  <proxy v=':8080'/>
12:07:41:
12:07:41:  <!-- Slot Control -->
12:07:41:  <pause-on-battery v='false'/>
12:07:41:  <power v='full'/>
12:07:41:
12:07:41:  <!-- User Information -->
12:07:41:  <passkey v='*****'/>
12:07:41:  <team v='223518'/>
12:07:41:  <user v='The_Bad_Penguin'/>
12:07:41:
12:07:41:  <!-- Folding Slots -->
12:07:41:  <slot id='1' type='GPU'/>
12:07:41:</config>
12:08:41:281:127.0.0.1:New Web session
12:08:54:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:08:55:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:08:55:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:08:55:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:08:55:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:08:55:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:08:55:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:08:56:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:08:56:ERROR:WU00:FS01:Exception: Could not get an assignment
12:11:32:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:11:32:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:11:32:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:11:32:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:11:32:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:11:33:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:11:33:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:11:33:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:11:33:ERROR:WU00:FS01:Exception: Could not get an assignment
12:14:16:Adding folding slot 00: READY cpu:16
12:14:16:Removing old file 'configs/config-20200610-125958.xml'
12:14:16:Saving configuration to config.xml
12:14:16:<config>
12:14:16:  <!-- Folding Core -->
12:14:16:  <checkpoint v='5'/>
12:14:16:  <core-priority v='low'/>
12:14:16:
12:14:16:  <!-- Network -->
12:14:16:  <proxy v=':8080'/>
12:14:16:
12:14:16:  <!-- Slot Control -->
12:14:16:  <pause-on-battery v='false'/>
12:14:16:  <power v='full'/>
12:14:16:
12:14:16:  <!-- User Information -->
12:14:16:  <passkey v='*****'/>
12:14:16:  <team v='223518'/>
12:14:16:  <user v='The_Bad_Penguin'/>
12:14:16:
12:14:16:  <!-- Folding Slots -->
12:14:16:  <slot id='0' type='CPU'/>
12:14:16:</config>
12:14:16:WU00:FS01:Slot ID 1 no longer exists and not yet downloaded, dumping
12:14:16:WU00:FS01:Cleaning up
12:14:16:WU00:FS00:Connecting to assign1.foldingathome.org:80
12:14:17:WU00:FS00:Assigned to work server 3.21.50.185
12:14:17:WU00:FS00:Requesting new work unit for slot 00: READY cpu:16 from 3.21.50.185
12:14:17:WU00:FS00:Connecting to 3.21.50.185:8080
12:14:17:WU00:FS00:Downloading 2.22MiB
12:14:18:WU00:FS00:Download complete
12:14:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17201 run:0 clone:502 gen:50 core:0xa7 unit:0x0000003c031532b95efd3dd9af45277d
12:14:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
12:14:18:WU00:FS00:Connecting to cores.foldingathome.org:80
12:14:18:WU00:FS00:FahCore a7: Downloading 6.71MiB
12:14:23:WU00:FS00:FahCore a7: Download complete
12:14:23:WU00:FS00:Valid core signature
12:14:23:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
12:14:23:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
12:14:24:WU00:FS00:Starting
12:14:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\badpe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 12760 -checkpoint 5 -np 16
12:14:24:WU00:FS00:Started FahCore on PID 22160
12:14:24:WU00:FS00:Core PID:24968
12:14:24:WU00:FS00:FahCore 0xa7 started
12:14:25:WU00:FS00:0xa7:*********************** Log Started 2020-07-13T12:14:25Z ***********************
12:14:25:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:14:25:WU00:FS00:0xa7:       Type: 0xa7
12:14:25:WU00:FS00:0xa7:       Core: Gromacs
12:14:25:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 22160 -checkpoint 5 -np
12:14:25:WU00:FS00:0xa7:             16
12:14:25:WU00:FS00:0xa7:************************************ CBang *************************************
12:14:25:WU00:FS00:0xa7:       Date: Nov 27 2019
12:14:25:WU00:FS00:0xa7:       Time: 03:40:09
12:14:25:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
12:14:25:WU00:FS00:0xa7:     Branch: master
12:14:25:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:14:25:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:14:25:WU00:FS00:0xa7:   Platform: win32 10
12:14:25:WU00:FS00:0xa7:       Bits: 64
12:14:25:WU00:FS00:0xa7:       Mode: Release
12:14:25:WU00:FS00:0xa7:************************************ System ************************************
12:14:25:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
12:14:25:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
12:14:25:WU00:FS00:0xa7:       CPUs: 16
12:14:25:WU00:FS00:0xa7:     Memory: 63.73GiB
12:14:25:WU00:FS00:0xa7:Free Memory: 34.11GiB
12:14:25:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:14:25:WU00:FS00:0xa7: OS Version: 6.2
12:14:25:WU00:FS00:0xa7:Has Battery: true
12:14:25:WU00:FS00:0xa7: On Battery: false
12:14:25:WU00:FS00:0xa7: UTC Offset: -4
12:14:25:WU00:FS00:0xa7:        PID: 24968
12:14:25:WU00:FS00:0xa7:        CWD: C:\Users\badpe\AppData\Roaming\FAHClient\work
12:14:25:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:14:25:WU00:FS00:0xa7:    Version: 0.0.19
12:14:25:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:14:25:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:14:25:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:14:25:WU00:FS00:0xa7:       Date: Nov 25 2019
12:14:25:WU00:FS00:0xa7:       Time: 17:12:41
12:14:25:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
12:14:25:WU00:FS00:0xa7:************************************ Build *************************************
12:14:25:WU00:FS00:0xa7:       SIMD: avx_256
12:14:25:WU00:FS00:0xa7:********************************************************************************
12:14:25:WU00:FS00:0xa7:Project: 17201 (Run 0, Clone 502, Gen 50)
12:14:25:WU00:FS00:0xa7:Unit: 0x0000003c031532b95efd3dd9af45277d
12:14:25:WU00:FS00:0xa7:Reading tar file core.xml
12:14:25:WU00:FS00:0xa7:Reading tar file frame50.tpr
12:14:25:WU00:FS00:0xa7:Digital signatures verified
12:14:25:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpt 5 -nt 16
12:14:25:WU00:FS00:0xa7:Steps: first=12500000 total=250000
12:14:28:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
12:14:48:Removing old file 'configs/config-20200610-130616.xml'
12:14:48:Saving configuration to config.xml
12:14:48:<config>
12:14:48:  <!-- Folding Core -->
12:14:48:  <checkpoint v='5'/>
12:14:48:  <core-priority v='low'/>
12:14:48:
12:14:48:  <!-- Network -->
12:14:48:  <proxy v=':8080'/>
12:14:48:
12:14:48:  <!-- Slot Control -->
12:14:48:  <pause-on-battery v='false'/>
12:14:48:  <power v='full'/>
12:14:48:
12:14:48:  <!-- User Information -->
12:14:48:  <passkey v='*****'/>
12:14:48:  <team v='223518'/>
12:14:48:  <user v='The_Bad_Penguin'/>
12:14:48:
12:14:48:  <!-- Folding Slots -->
12:14:48:  <slot id='0' type='CPU'/>
12:14:48:</config>
12:15:03:<config>
12:15:03:
12:15:03:
12:15:03:
12:15:03:
12:15:03:</config>
12:15:03:FS00:Shutting core down
12:15:04:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 24968
12:15:04:WU00:FS00:0xa7:Exiting, please wait. . .
12:15:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:15:04:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:15:04:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:15:04:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:15:04:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:15:05:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:15:05:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:15:05:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:15:05:ERROR:WU01:FS01:Exception: Could not get an assignment
12:15:05:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:15:06:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:15:06:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:15:06:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
12:15:06:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:15:06:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:15:06:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:15:07:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:15:07:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:15:07:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
12:15:07:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:17201 run:0 clone:502 gen:50 core:0xa7 unit:0x0000003c031532b95efd3dd9af45277d
12:15:07:WU00:Connecting to 3.21.50.185:8080
12:15:07:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:15:07:ERROR:WU01:FS01:Exception: Could not get an assignment
12:15:07:WU00:Server responded WORK_ACK (400)
12:15:07:WU00:Cleaning up
12:15:49:Removing old file 'configs/config-20200614-223158.xml'
12:15:49:Saving configuration to config.xml
12:15:49:<config>
12:15:49:  <!-- Folding Core -->
12:15:49:  <checkpoint v='5'/>
12:15:49:  <core-priority v='low'/>
12:15:49:
12:15:49:  <!-- Network -->
12:15:49:  <proxy v=':8080'/>
12:15:49:
12:15:49:  <!-- Slot Control -->
12:15:49:  <pause-on-battery v='false'/>
12:15:49:  <power v='full'/>
12:15:49:
12:15:49:  <!-- User Information -->
12:15:49:  <passkey v='*****'/>
12:15:49:  <team v='223518'/>
12:15:49:  <user v='The_Bad_Penguin'/>
12:15:49:
12:15:49:  <!-- Folding Slots -->
12:15:49:  <slot id='1' type='GPU'/>
12:15:49:</config>
12:16:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:16:06:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:16:06:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:16:06:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:16:06:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:16:07:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:16:07:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:16:07:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:16:07:ERROR:WU01:FS01:Exception: Could not get an assignment
12:17:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:17:43:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:17:43:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:17:44:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:17:44:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:17:44:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:17:44:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:17:44:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:17:44:ERROR:WU01:FS01:Exception: Could not get an assignment
12:20:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:20:20:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:20:20:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:20:21:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:20:21:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:20:21:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:20:21:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:20:22:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:20:22:ERROR:WU01:FS01:Exception: Could not get an assignment
12:24:34:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:24:35:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:31:26:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:31:26:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:31:26:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:31:27:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:31:27:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:31:27:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:31:27:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:31:27:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:31:27:ERROR:WU01:FS01:Exception: Could not get an assignment
12:42:31:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:42:32:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:42:32:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:42:32:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:42:32:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:42:32:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:42:32:WU01:FS01:Connecting to assign4.foldingathome.org:80
12:42:33:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:42:33:ERROR:WU01:FS01:Exception: Could not get an assignment
13:00:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:00:28:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:00:28:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:00:29:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:00:29:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:00:29:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:00:29:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:00:30:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:00:30:ERROR:WU01:FS01:Exception: Could not get an assignment
13:27:52:313:127.0.0.1:New Web session
13:29:31:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:29:31:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:29:31:WU01:FS01:Connecting to assign2.foldingathome.org:80
13:29:31:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:29:31:WU01:FS01:Connecting to assign3.foldingathome.org:80
13:29:31:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:29:31:WU01:FS01:Connecting to assign4.foldingathome.org:80
13:29:32:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:29:32:ERROR:WU01:FS01:Exception: Could not get an assignment
14:02:32:342:127.0.0.1:New Web session
14:03:27:Removing old file 'configs/config-20200615-154353.xml'
14:03:27:Saving configuration to config.xml
14:03:27:<config>
14:03:27:  <!-- Folding Core -->
14:03:27:  <checkpoint v='5'/>
14:03:27:  <core-priority v='low'/>
14:03:27:
14:03:27:  <!-- Network -->
14:03:27:  <proxy v=':8080'/>
14:03:27:
14:03:27:  <!-- Slot Control -->
14:03:27:  <pause-on-battery v='false'/>
14:03:27:  <power v='full'/>
14:03:27:
14:03:27:  <!-- User Information -->
14:03:27:  <passkey v='*****'/>
14:03:27:  <team v='223518'/>
14:03:27:  <user v='The_Bad_Penguin'/>
14:03:27:
14:03:27:  <!-- Folding Slots -->
14:03:27:  <slot id='1' type='GPU'>
14:03:27:    <gpu-index v='1'/>
14:03:27:  </slot>
14:03:27:</config>
14:03:35:Removing old file 'configs/config-20200615-154656.xml'
14:03:35:Saving configuration to config.xml
14:03:35:<config>
14:03:35:  <!-- Folding Core -->
14:03:35:  <checkpoint v='5'/>
14:03:35:  <core-priority v='low'/>
14:03:35:
14:03:35:  <!-- Network -->
14:03:35:  <proxy v=':8080'/>
14:03:35:
14:03:35:  <!-- Slot Control -->
14:03:35:  <pause-on-battery v='false'/>
14:03:35:  <power v='full'/>
14:03:35:
14:03:35:  <!-- User Information -->
14:03:35:  <passkey v='*****'/>
14:03:35:  <team v='223518'/>
14:03:35:  <user v='The_Bad_Penguin'/>
14:03:35:
14:03:35:  <!-- Folding Slots -->
14:03:35:  <slot id='1' type='GPU'>
14:03:35:    <gpu-index v='1'/>
14:03:35:  </slot>
14:03:35:</config>
14:05:53:Removing old file 'configs/config-20200617-144913.xml'
14:05:53:Saving configuration to config.xml
14:05:53:<config>
14:05:53:  <!-- Folding Core -->
14:05:53:  <checkpoint v='5'/>
14:05:53:  <core-priority v='low'/>
14:05:53:
14:05:53:  <!-- Network -->
14:05:53:  <proxy v=':8080'/>
14:05:53:
14:05:53:  <!-- Slot Control -->
14:05:53:  <pause-on-battery v='false'/>
14:05:53:  <power v='full'/>
14:05:53:
14:05:53:  <!-- User Information -->
14:05:53:  <passkey v='*****'/>
14:05:53:  <team v='223518'/>
14:05:53:  <user v='The_Bad_Penguin'/>
14:05:53:
14:05:53:  <!-- Folding Slots -->
14:05:53:  <slot id='1' type='GPU'/>
14:05:53:</config>
14:06:38:Removing old file 'configs/config-20200618-001734.xml'
14:06:38:Saving configuration to config.xml
14:06:38:<config>
14:06:38:  <!-- Folding Core -->
14:06:38:  <checkpoint v='5'/>
14:06:38:  <core-priority v='low'/>
14:06:38:
14:06:38:  <!-- Network -->
14:06:38:  <proxy v=':8080'/>
14:06:38:
14:06:38:  <!-- Slot Control -->
14:06:38:  <pause-on-battery v='false'/>
14:06:38:  <power v='full'/>
14:06:38:
14:06:38:  <!-- User Information -->
14:06:38:  <passkey v='*****'/>
14:06:38:  <team v='223518'/>
14:06:38:  <user v='The_Bad_Penguin'/>
14:06:38:
14:06:38:  <!-- Folding Slots -->
14:06:38:  <slot id='1' type='GPU'/>
14:06:38:</config>
14:16:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:16:29:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:16:29:WU01:FS01:Connecting to assign2.foldingathome.org:80
14:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:16:30:WU01:FS01:Connecting to assign3.foldingathome.org:80
14:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:16:30:WU01:FS01:Connecting to assign4.foldingathome.org:80
14:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:16:30:ERROR:WU01:FS01:Exception: Could not get an assignment
15:16:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:16:30:WU01:FS01:Connecting to assign2.foldingathome.org:80
15:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:16:30:WU01:FS01:Connecting to assign3.foldingathome.org:80
15:16:30:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:16:30:WU01:FS01:Connecting to assign4.foldingathome.org:80
15:16:31:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:16:31:ERROR:WU01:FS01:Exception: Could not get an assignment
15:35:18:FS01:Paused
15:36:06:Removing old file 'configs/config-20200618-012945.xml'
15:36:06:Saving configuration to config.xml
15:36:06:<config>
15:36:06:  <!-- Folding Core -->
15:36:06:  <checkpoint v='5'/>
15:36:06:  <core-priority v='low'/>
15:36:06:
15:36:06:  <!-- Network -->
15:36:06:  <proxy v=':8080'/>
15:36:06:
15:36:06:  <!-- Slot Control -->
15:36:06:  <pause-on-battery v='false'/>
15:36:06:  <power v='full'/>
15:36:06:
15:36:06:  <!-- User Information -->
15:36:06:  <passkey v='*****'/>
15:36:06:  <team v='223518'/>
15:36:06:  <user v='The_Bad_Penguin'/>
15:36:06:
15:36:06:  <!-- Folding Slots -->
15:36:06:  <slot id='1' type='GPU'>
15:36:06:    <paused v='true'/>
15:36:06:  </slot>
15:36:06:</config>
15:37:03:Removing old file 'configs/config-20200619-112131.xml'
15:37:03:Saving configuration to config.xml
15:37:03:<config>
15:37:03:  <!-- Folding Core -->
15:37:03:  <checkpoint v='5'/>
15:37:03:  <core-priority v='low'/>
15:37:03:
15:37:03:  <!-- Network -->
15:37:03:  <proxy v=':8080'/>
15:37:03:
15:37:03:  <!-- Slot Control -->
15:37:03:  <pause-on-battery v='false'/>
15:37:03:  <power v='full'/>
15:37:03:
15:37:03:  <!-- User Information -->
15:37:03:  <passkey v='*****'/>
15:37:03:  <team v='223518'/>
15:37:03:  <user v='The_Bad_Penguin'/>
15:37:03:
15:37:03:  <!-- Folding Slots -->
15:37:03:  <slot id='1' type='GPU'>
15:37:03:    <pause-on-start v='true'/>
15:37:03:    <paused v='True'/>
15:37:03:  </slot>
15:37:03:</config>
15:37:07:Removing old file 'configs/config-20200619-150309.xml'
15:37:07:Saving configuration to config.xml
15:37:07:<config>
15:37:07:  <!-- Folding Core -->
15:37:07:  <checkpoint v='5'/>
15:37:07:  <core-priority v='low'/>
15:37:07:
15:37:07:  <!-- Network -->
15:37:07:  <proxy v=':8080'/>
15:37:07:
15:37:07:  <!-- Slot Control -->
15:37:07:  <pause-on-battery v='false'/>
15:37:07:  <power v='full'/>
15:37:07:
15:37:07:  <!-- User Information -->
15:37:07:  <passkey v='*****'/>
15:37:07:  <team v='223518'/>
15:37:07:  <user v='The_Bad_Penguin'/>
15:37:07:
15:37:07:  <!-- Folding Slots -->
15:37:07:  <slot id='1' type='GPU'>
15:37:07:    <pause-on-start v='true'/>
15:37:07:    <paused v='True'/>
15:37:07:  </slot>
15:37:07:</config>
15:37:28:371:127.0.0.1:New Web session
Okay, please leave GPU folding slot 1 alone. As I mentioned, it will need to stay there.
Follow the directions I gave you above, set that slot back to 'pause-on-start' and 'true' as shown in the early part of the log. When starting and stopping, the GPU slot you add should be right-clicked on in FAHControl, that will allow control of just that slot.
Did you want a CPU folding slot? You had one configured and then deleted it?
The_Bad_Penguin
Do not want to cpu fold. Accidentally added it when trying to see if t2000 could just be added back. Mistook "cpu" for "gpu".
Will not touch gpu slot 1.
Not sure I understand other directions.
Is this correct?
16:13:00:Removing old file 'configs/config-20200702-084452.xml'
16:13:00:Saving configuration to config.xml
16:13:00:<config>
16:13:00:  <!-- Folding Core -->
16:13:00:  <checkpoint v='5'/>
16:13:00:  <core-priority v='low'/>
16:13:00:
16:13:00:  <!-- Network -->
16:13:00:  <proxy v=':8080'/>
16:13:00:
16:13:00:  <!-- Slot Control -->
16:13:00:  <pause-on-battery v='false'/>
16:13:00:  <power v='full'/>
16:13:00:
16:13:00:  <!-- User Information -->
16:13:00:  <passkey v='*****'/>
16:13:00:  <team v='223518'/>
16:13:00:  <user v='The_Bad_Penguin'/>
16:13:00:
16:13:00:  <!-- Folding Slots -->
16:13:00:  <slot id='1' type='GPU'>
16:13:00:    <opencl-index v='2'/>
16:13:00:    <pause-on-start v='True'/>
16:13:00:    <paused v='True'/>
16:13:00:  </slot>
16:13:00:</config>
Remove the opencl-index entry if you added that. If the client accepted 'True', then that should be okay, prior versions insisted on 'true'.
When you Add a second GPU slot, you should just need to click on the radio button for GPU and leave the index settings at their default. Then save the changed settings. The new slot may get given the id of 0 since you do not have a CPU slot defined, otherwise it should be 2.
After saving the new slot should request a WU for the T2000. If there is a problem after that, possibly the OpenCL device index will need to be set. From the startup portion of the log that is '1'.
With a GPU slot that should be left paused, using Web Control will be okay for pausing folding. But the start from Web Control will start all slots. In FAHControl (Advanced Control) if you right click on a folding slot a pop-up menu will show up. From that you can Pause, Start, Finish, etc. a particular slot without changing other folding slots.
The_Bad_Penguin
I did not add the opencl -index entry. But I just changed the value from "2" to "-1".
I added a second gpu slot.
Now, in addition to slot "1", there is a slot "-1".
Yes, that seems to work !!! (I think, F@H web control: no wu named, 0.00 secs, 0 estimated points)
EDIT --> Now shows "13416 (856, 26, 3)" with ETA and estimated points.
EDIT 2 --> Does F@H need to "test" the intel 630? I would be happy to help with that, if I am able to.
16:57:31:Adding folding slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q]
16:57:31:Removing old file 'configs/config-20200713-001803.xml'
16:57:31:Saving configuration to config.xml
16:57:31:<config>
16:57:31:  <!-- Folding Core -->
16:57:31:  <checkpoint v='5'/>
16:57:31:  <core-priority v='low'/>
16:57:31:
16:57:31:  <!-- Network -->
16:57:31:  <proxy v=':8080'/>
16:57:31:
16:57:31:  <!-- Slot Control -->
16:57:31:  <pause-on-battery v='false'/>
16:57:31:  <power v='full'/>
16:57:31:
16:57:31:  <!-- User Information -->
16:57:31:  <passkey v='*****'/>
16:57:31:  <team v='223518'/>
16:57:31:  <user v='The_Bad_Penguin'/>
16:57:31:
16:57:31:  <!-- Folding Slots -->
16:57:31:  <slot id='1' type='GPU'>
16:57:31:    <pause-on-start v='True'/>
16:57:31:    <paused v='True'/>
16:57:31:  </slot>
16:57:31:  <slot id='0' type='GPU'/>
16:57:31:</config>
16:57:32:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:57:32:WU00:FS00:Assigned to work server 18.188.125.154
16:57:32:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 18.188.125.154
16:57:32:WU00:FS00:Connecting to 18.188.125.154:8080
16:57:32:WU00:FS00:Downloading 7.06MiB
16:57:34:WU00:FS00:Download complete
16:57:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13416 run:856 clone:26 gen:3 core:0x22 unit:0x0000000712bc7d9a5f02af93e4429e5c
16:57:34:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah
16:57:34:WU00:FS00:Connecting to cores.foldingathome.org:80
16:57:34:WU00:FS00:FahCore 22: Downloading 4.39MiB
16:57:35:WU00:FS00:FahCore 22: Download complete
16:57:35:WU00:FS00:Valid core signature
16:57:36:WU00:FS00:Unpacked 14.46MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe
16:57:36:WU00:FS00:Starting
16:57:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\badpe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12760 -checkpoint 5 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:57:36:WU00:FS00:Started FahCore on PID 19848
16:57:36:WU00:FS00:Core PID:8640
16:57:36:WU00:FS00:FahCore 0x22 started
16:57:36:WU00:FS00:0x22:*********************** Log Started 2020-07-13T16:57:36Z ***********************
16:57:36:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
16:57:36:WU00:FS00:0x22:       Core: Core22
16:57:36:WU00:FS00:0x22:       Type: 0x22
16:57:36:WU00:FS00:0x22:    Version: 0.0.11
16:57:36:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:57:36:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
16:57:36:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
16:57:36:WU00:FS00:0x22:       Date: Jun 26 2020
16:57:36:WU00:FS00:0x22:       Time: 19:49:16
16:57:36:WU00:FS00:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
16:57:36:WU00:FS00:0x22:     Branch: core22-0.0.11
16:57:36:WU00:FS00:0x22:   Compiler: Visual C++ 2015
16:57:36:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:57:36:WU00:FS00:0x22:   Platform: win32 10
16:57:36:WU00:FS00:0x22:       Bits: 64
16:57:36:WU00:FS00:0x22:       Mode: Release
16:57:36:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:57:36:WU00:FS00:0x22:             <peastman@stanford.edu>
16:57:36:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 19848 -checkpoint 5
16:57:36:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:57:36:WU00:FS00:0x22:             0 -gpu 0
16:57:36:WU00:FS00:0x22:************************************ libFAH ************************************
16:57:36:WU00:FS00:0x22:       Time: 19:47:12
16:57:36:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
16:57:36:WU00:FS00:0x22:     Branch: HEAD
16:57:36:WU00:FS00:0x22:************************************ CBang *************************************
16:57:36:WU00:FS00:0x22:       Time: 19:46:11
16:57:36:WU00:FS00:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
16:57:36:WU00:FS00:0x22:     Branch: master
16:57:36:WU00:FS00:0x22:************************************ System ************************************
16:57:36:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
16:57:36:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
16:57:36:WU00:FS00:0x22:       CPUs: 16
16:57:36:WU00:FS00:0x22:     Memory: 63.73GiB
16:57:36:WU00:FS00:0x22:Free Memory: 45.77GiB
16:57:36:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
16:57:36:WU00:FS00:0x22: OS Version: 6.2
16:57:36:WU00:FS00:0x22:Has Battery: true
16:57:36:WU00:FS00:0x22: On Battery: true
16:57:36:WU00:FS00:0x22: UTC Offset: -4
16:57:36:WU00:FS00:0x22:        PID: 8640
16:57:36:WU00:FS00:0x22:        CWD: C:\Users\badpe\AppData\Roaming\FAHClient\work
16:57:36:WU00:FS00:0x22:********************************************************************************
16:57:36:WU00:FS00:0x22:Project: 13416 (Run 856, Clone 26, Gen 3)
16:57:36:WU00:FS00:0x22:Unit: 0x0000000712bc7d9a5f02af93e4429e5c
16:57:36:WU00:FS00:0x22:Reading tar file core.xml
16:57:36:WU00:FS00:0x22:Reading tar file integrator.xml
16:57:36:WU00:FS00:0x22:Reading tar file state.xml.bz2
16:57:36:WU00:FS00:0x22:Reading tar file system.xml.bz2
16:57:36:WU00:FS00:0x22:Digital signatures verified
16:57:36:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
16:57:36:WU00:FS00:0x22:Version 0.0.11
16:57:37:WU00:FS00:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
16:57:37:WU00:FS00:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
16:57:37:WU00:FS00:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
16:57:37:WU00:FS00:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
16:58:14:WU00:FS00:0x22:Completed 0 out of 1000000 steps (0%)
16:58:27:Removing old file 'configs/config-20200713-120741.xml'
16:58:27:Saving configuration to config.xml
16:58:27:<config>
16:58:27:  <!-- Folding Core -->
16:58:27:  <checkpoint v='5'/>
16:58:27:  <core-priority v='low'/>
16:58:27:
16:58:27:  <!-- Network -->
16:58:27:  <proxy v=':8080'/>
16:58:27:
16:58:27:  <!-- Slot Control -->
16:58:27:  <pause-on-battery v='false'/>
16:58:27:  <power v='full'/>
16:58:27:
16:58:27:  <!-- User Information -->
16:58:27:  <passkey v='*****'/>
16:58:27:  <team v='223518'/>
16:58:27:  <user v='The_Bad_Penguin'/>
16:58:27:
16:58:27:  <!-- Folding Slots -->
16:58:27:  <slot id='1' type='GPU'>
16:58:27:    <pause-on-start v='True'/>
16:58:27:    <paused v='True'/>
16:58:27:  </slot>
16:58:27:  <slot id='0' type='GPU'/>
16:58:27:</config>
The_Bad_Penguin wrote:Now, in addition to slot "1", there is a slot "-1".
The '-1' in the Configure window means leave it to the software to set the value. From the configuration information shown in the log the T2000 is there as Slot 0. It appears to be functioning fine, so the appropriate settings for the other index values have been made by the software.
The_Bad_Penguin wrote:EDIT 2 --> Does F@H need to "test" the intel 630? I would be happy to help with that, if I am able to.
For now all testing is being done internally. Last I heard was that there were errors and other problems they needed to look into. If they can get past those, at some point in the future they may release to Beta testing. At that point they will be looking for testers
The_Bad_Penguin
Was able to crunch 2 wu's on the newly reconfigured t2000.
Now running into:
WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
20:44:38:WU00:FS00:Connecting to 3.133.76.19:8080
20:44:39:ERROR:WU00:FS00:Exception: Server did not assign work unit
Are the servers out of wu's (for t2000's)?
Or is something else happening?
TIA!
14:16:15:WU02:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
14:24:28:WU02:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
14:32:42:WU02:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
14:40:55:WU02:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
14:49:08:WU02:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
14:57:22:WU02:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
15:05:34:WU02:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
15:10:09:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
15:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:10:10:WU01:FS01:Connecting to assign3.foldingathome.org:80
15:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
15:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
15:13:44:WU02:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
15:21:57:WU02:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
15:30:09:WU02:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
15:38:25:WU02:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
15:46:43:WU02:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
15:54:58:WU02:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
16:03:11:WU02:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
16:10:09:WU01:FS01:Connecting to assign1.foldingathome.org:80
16:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
16:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:10:10:WU01:FS01:Connecting to assign3.foldingathome.org:80
16:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
16:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
16:11:30:WU02:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
16:19:56:WU02:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
16:28:15:WU02:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
16:36:33:WU02:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
16:44:52:WU02:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
16:53:09:WU02:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
17:01:30:WU02:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
17:09:41:WU02:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
17:10:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
17:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:10:10:WU01:FS01:Connecting to assign3.foldingathome.org:80
17:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
17:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
17:12:16:598:127.0.0.1:New Web session
17:17:56:WU02:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
17:26:07:WU02:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
17:34:19:WU02:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
17:42:31:WU02:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
17:50:41:WU02:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
17:58:50:WU02:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
18:07:02:WU02:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
******************************* Date: 2020-07-14 *******************************
18:10:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:10:11:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
18:15:11:WU02:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
18:23:27:WU02:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
18:31:46:WU02:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
18:40:03:WU02:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
18:48:27:WU02:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
18:56:46:WU02:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
19:05:04:WU02:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
19:10:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
19:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:10:11:WU01:FS01:Connecting to assign3.foldingathome.org:80
19:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
19:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
19:13:25:WU02:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
19:21:47:WU02:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
19:30:11:WU02:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
19:30:11:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:30:11:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:30:11:WU00:FS00:Connecting to assign2.foldingathome.org:80
19:30:12:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:30:12:WU00:FS00:Connecting to assign3.foldingathome.org:80
19:30:12:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:30:12:WU00:FS00:Connecting to assign4.foldingathome.org:80
19:30:13:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:30:13:ERROR:WU00:FS00:Exception: Could not get an assignment
19:30:13:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:30:13:WU00:FS00:Assigned to work server 3.133.76.19
19:30:13:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:30:13:WU00:FS00:Connecting to 3.133.76.19:8080
19:30:14:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:31:13:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:31:13:WU00:FS00:Assigned to work server 3.133.76.19
19:31:13:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:31:13:WU00:FS00:Connecting to 3.133.76.19:8080
19:31:14:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:32:50:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:32:50:WU00:FS00:Assigned to work server 3.133.76.19
19:32:50:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:32:50:WU00:FS00:Connecting to 3.133.76.19:8080
19:32:51:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:35:27:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:35:28:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:35:28:WU00:FS00:Connecting to assign2.foldingathome.org:80
19:35:28:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:35:28:WU00:FS00:Connecting to assign3.foldingathome.org:80
19:35:28:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:35:28:WU00:FS00:Connecting to assign4.foldingathome.org:80
19:35:29:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:35:29:ERROR:WU00:FS00:Exception: Could not get an assignment
19:38:35:WU02:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
19:38:35:WU02:FS00:0x22:Average performance: 34.4498 ns/day
19:38:44:WU02:FS00:0x22:Saving result file ..\logfile_01.txt
19:38:44:WU02:FS00:0x22:Saving result file checkpointState.xml.bz2
19:38:44:WU02:FS00:0x22:Saving result file globals.csv
19:38:44:WU02:FS00:0x22:Saving result file positions.xtc
19:38:44:WU02:FS00:0x22:Saving result file science.log
19:38:44:WU02:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:38:45:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:38:45:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13416 run:752 clone:39 gen:3 core:0x22 unit:0x0000000912bc7d9a5f02af9a5c40ce1d
19:38:45:WU02:FS00:Uploading 5.83MiB to 18.188.125.154
19:38:45:WU02:FS00:Connecting to 18.188.125.154:8080
19:38:51:WU02:FS00:Upload 32.19%
19:38:57:WU02:FS00:Upload 60.08%
19:39:03:WU02:FS00:Upload 87.98%
19:39:07:WU02:FS00:Upload complete
19:39:07:WU02:FS00:Server responded WORK_ACK (400)
19:39:07:WU02:FS00:Final credit estimate, 113354.00 points
19:39:07:WU02:FS00:Cleaning up
19:39:42:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:39:42:WU00:FS00:Assigned to work server 3.133.76.19
19:39:42:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:39:42:WU00:FS00:Connecting to 3.133.76.19:8080
19:39:42:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:46:33:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:46:33:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:46:33:WU00:FS00:Connecting to assign2.foldingathome.org:80
19:46:34:WU00:FS00:Assigned to work server 3.133.76.19
19:46:34:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:46:34:WU00:FS00:Connecting to 3.133.76.19:8080
19:46:34:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:57:39:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:57:39:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:57:39:WU00:FS00:Connecting to assign2.foldingathome.org:80
19:57:39:WU00:FS00:Assigned to work server 3.133.76.19
19:57:39:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
19:57:39:WU00:FS00:Connecting to 3.133.76.19:8080
19:57:40:ERROR:WU00:FS00:Exception: Server did not assign work unit
20:10:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
20:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
20:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
20:10:10:WU01:FS01:Connecting to assign3.foldingathome.org:80
20:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
20:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
20:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
20:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
20:14:36:640:127.0.0.1:New Web session
20:15:35:WU00:FS00:Connecting to assign1.foldingathome.org:80
20:15:36:WU00:FS00:Assigned to work server 3.133.76.19
20:15:36:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
20:15:36:WU00:FS00:Connecting to 3.133.76.19:8080
20:15:36:ERROR:WU00:FS00:Exception: Server did not assign work unit
20:18:24:649:127.0.0.1:New Web session
20:44:38:WU00:FS00:Connecting to assign1.foldingathome.org:80
20:44:38:WU00:FS00:Assigned to work server 3.133.76.19
20:44:38:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
21:10:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:10:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:10:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:10:11:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:10:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:10:11:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
21:31:36:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:31:37:WU00:FS00:Assigned to work server 3.133.76.19
21:31:37:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
21:31:37:WU00:FS00:Connecting to 3.133.76.19:8080
21:31:37:ERROR:WU00:FS00:Exception: Server did not assign work unit
Re: F@H no longer "sees" nvidia quadro t2000
Post by Neil-B »
Not sure about your t2000 slot (fs00) may just be no suitable projects ... but you need to pause what I guess is your iGPU slot (FS01) as it keeps trying to get a WU
The_Bad_Penguin
Post by The_Bad_Penguin »
Ok, thanx, paused the iGPU (intel 630), thought I had previously done so.
Still waiting to see what is happening with T2000. Will wait a bit longer, and then switch to BOINC. <friends don't let friends waste gpu cycles, lol!>
22:24:27:FS01:Paused
22:25:25:Removing old file 'configs/config-20200713-121416.xml'
22:25:25:Saving configuration to config.xml
22:25:25:<config>
22:25:25:  <!-- Folding Core -->
22:25:25:  <checkpoint v='5'/>
22:25:25:  <core-priority v='low'/>
22:25:25:
22:25:25:  <!-- Network -->
22:25:25:  <proxy v=':8080'/>
22:25:25:
22:25:25:  <!-- Slot Control -->
22:25:25:  <pause-on-battery v='false'/>
22:25:25:  <power v='full'/>
22:25:25:
22:25:25:  <!-- User Information -->
22:25:25:  <passkey v='*****'/>
22:25:25:  <team v='223518'/>
22:25:25:  <user v='The_Bad_Penguin'/>
22:25:25:
22:25:25:  <!-- Folding Slots -->
22:25:25:  <slot id='1' type='GPU'>
22:25:25:    <pause-on-start v='True'/>
22:25:25:    <paused v='true'/>
22:25:25:  </slot>
22:25:25:  <slot id='0' type='GPU'/>
22:25:25:</config>
22:31:37:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:31:37:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
22:31:37:WU00:FS00:Connecting to assign2.foldingathome.org:80
22:31:37:WU00:FS00:Assigned to work server 3.133.76.19
22:31:37:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU117GLM [Quadro T2000 Mobile / Max-Q] from 3.133.76.19
22:31:37:WU00:FS00:Connecting to 3.133.76.19:8080
22:31:37:ERROR:WU00:FS00:Exception: Server did not assign work unit
_r2w_ben
Post by _r2w_ben »
The last part of your log shows an assignment to 3.133.76.19, which only shows as having CPU work on psummary. Have you tried deleting and recreating the slot?
The_Bad_Penguin
Thanks for the observation.
Didn't do anything, just continued to wait.
Seems to be crunching again, project 11746.
Maybe F@H really did run out of wu's for a spell . . .
The intel 630 iGPs are unsupported ... though the might be someday depending on the outcome of some early testing. You shouldn't be able to get an assignment for them so leaving them paused is the right thing to do. Personally, I not only pause mine manually, I add the setting pause-on-start = 'true' just to be sure.
