osx 10.15.5 - FAHControl will not connect to localhost
nleco
Post by nleco »
I installed the software yesterday and it ran and monitored correctly. I restarted my computer today (mac) and FAHControl cannot connect to localhost. If i go to client.foldingathome.org, It shows that it is running. I tried stopping and starting via the web ui. still not connecting. I have 2 other linux computers, which have not been rebooted since install, and those do connect.
I don't recall adding a password to my localhost client. I only added them to the linux hosts, I believe. I am trying to find the osx config xml file to verify.
Re: osx 10.15.5 - FAHControl will not connect to loalhost
Under a default install, all data files including config.xml are located in /Library/Application Support/FAHClient.
Do you have the builtin firewall from the OS activated?
nleco
Post by nleco »
my firewall is turned off.
I did also try to kill the process via the pid for 'FAHClient'.
the config file seems to have default values aside from my username/passkey.
FAHClient is designed to run as a daemon (with permissions from Apple). If it's like the Linux daemon or the Windows service, it is supposed to restart itself... but I'm not an OS-X expert, so correct me if I'm wrong.
nleco
Post by nleco »
bruce wrote:FAHClient is designed to run as a daemon (with permissions from Apple). If it's like the Linux daemon or the Windows service, it is supposed to restart itself... but I'm not an OS-X expert, so correct me if I'm wrong.
I'm a bit unclear about this. I mentioned that the client does appear to be running. I can control it via the Web interface (client.foldingathome.org), which has an iframe pointing to the localhost ui. I can update it there, and via 'htop' I can see the cores begin to work based on the intensity.
The issue I am having is with FAHControl not connecting to the localhost instance. Curious if there is something that can help me diagnose why.
I do see this in the logs:
default	18:53:48.269076-0700	FAHControl	Connection Error: 32: Broken pipe
default	18:53:48.771380-0700	FAHControl	Connection lost
default	18:53:48.771485-0700	FAHControl	ERROR on connection to 127.0.0.1:36330: Lost connection
nleco
Re: osx 10.15.5 - FAHControl will not connect to localhost
Post by nleco »
Bruce,
I found this while searching. saw you recommended use of telnet to test:
viewtopic.php?f=108&t=35365&p=335385&hilit=can%27t+connect+port+36330#p335385
i did do that. and what's interesting is I get this.
Welcome to the FAHClient command server.
when I type 'help' it loses connection.
i see this when I ping what ports are in use:
19:08:06 $ sudo lsof -i -n -P | grep TCP | grep FAHC
FAHContro 1322        ssanchez    9u  IPv4 0x1b443986d2fb0bf7      0t0    TCP 127.0.0.1:32455 (LISTEN)
FAHContro 1322        ssanchez   20u  IPv4 0x1b443986d3c59837      0t0    TCP 192.168.86.45:50521->192.168.86.44:36330 (ESTABLISHED)
FAHClient 2066          nobody    5u  IPv4 0x1b443986cb75b837      0t0    TCP *:7396 (LISTEN)
FAHClient 2066          nobody    6u  IPv4 0x1b443986d029f477      0t0    TCP *:36330 (LISTEN)
Apple pulled out the native telnet from the command line environment, you can use the 'nc' command instead in Terminal:
nc 127.0.0.1 36330
That should give you the command server prompt. Does it still close after entering the 'help' command?
The output of the lsof command on my Mac looks like the following for comparison:
FAHClient    71         nobody    5u  IPv4 0xd3d925bc30dae605      0t0  TCP *:7396 (LISTEN)
FAHClient    71         nobody    7u  IPv4 0xd3d925bc30dad335      0t0  TCP *:36330 (LISTEN)
FAHClient    71         nobody    8u  IPv4 0xd3d925bc481f4335      0t0  TCP 127.0.0.1:36330->127.0.0.1:49339 (ESTABLISHED)
FAHContro 22459       --------    9u  IPv4 0xd3d925bc481f4c9d      0t0  TCP 127.0.0.1:32455 (LISTEN)
FAHContro 22459       --------   20u  IPv4 0xd3d925bc48b8a8d5      0t0  TCP 127.0.0.1:49339->127.0.0.1:36330 (ESTABLISHED)
I am running 10.13.6 on this particular Mac, don't currently have a system running a later version.
nleco
Post by nleco »
I installed telnet via homebrew. People ported it over.
https://formulae.brew.sh/formula/telnet
the 'nc' command you gave didn't seem to do anything. no prompt. What's interesting is that it actually did work right after I installed it.
We probably should try to contact calxalot.
Post by calxalot »
I would guess that you altered the allow/deny IP address settings. You should make sure that 127.0.0.1 is in all allow lists. You need to stop the client service before editing config.xml, which you should not do unless you absolutely have to. Make sure that config.xml is owned by user nobody after editing it, and before restarting the service.
nleco
Post by nleco »
calxalot wrote:I would guess that you altered the allow/deny IP address settings. You should make sure that 127.0.0.1 is in all allow lists. You need to stop the client service before editing config.xml, which you should not do unless you absolutely have to. Make sure that config.xml is owned by user nobody after editing it, and before restarting the service.
That was exactly what happened and it slipped my mind. It was set to my LAN's address vs 127.0.0.1. This resolved it.
thank you so much.
