gpu won't start folding
Will3720
Post by Will3720 »
it's stuck on download and won't start folding, specs are intel i3-9100F and an RX570 graphics card, and before anyone asks, yes the drivers are up to date. Here is the error only log
*********************** Log Started 2020-07-07T13:02:52Z ***********************
13:02:59:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:03:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:04:04:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:05:42:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:08:20:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:12:34:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:19:25:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:30:31:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
13:48:31:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:48:36:ERROR:WU00:FS00:Exception: Failed to connect to 3.21.157.11:80: No connection could be made because the target machine actively refused it.
14:17:31:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:04:30:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
16:04:30:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
17:04:35:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
18:04:35:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
18:10:21:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:10:28:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:11:28:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
******************************* Date: 2020-07-07 *******************************
19:04:34:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:04:34:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:04:36:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
22:04:36:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
22:26:05:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:28:41:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:32:56:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:39:47:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:04:39:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
23:04:45:ERROR:WU00:FS00:Exception: Failed to connect to 3.21.157.11:80: No connection could be made because the target machine actively refused it.
23:18:14:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
23:18:20:ERROR:WU00:FS00:Exception: Failed to connect to 3.21.157.11:80: No connection could be made because the target machine actively refused it.
23:19:51:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:22:28:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:25:42:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:27:24:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:30:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:34:15:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:37:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:38:16:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:39:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
23:39:25:ERROR:WU00:FS00:Exception: Failed to connect to 3.21.157.11:80: No connection could be made because the target machine actively refused it.
23:40:54:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:43:31:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:47:45:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:54:37:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
23:56:59:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10072
23:57:03:WARNING:WU00:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
23:57:03:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
23:57:07:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:58:45:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:58:58:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7260
23:58:59:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
23:58:59:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
23:59:42:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 13668
23:59:52:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:59:59:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
00:01:29:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:04:06:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:06:30:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2164
00:06:31:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
00:06:40:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:08:17:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:10:54:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:15:09:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:18:52:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11320
00:18:54:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
00:19:03:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:20:39:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:23:17:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:27:33:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:34:25:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
00:45:30:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
01:03:27:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
******************************* Date: 2020-07-08 *******************************
Re: gpu won't start folding fold
Welcome to Folding@Home!
It is not easy to help you as you did not post the first 200 lines of the log, where the configuration portion is. Here are instructions
viewtopic.php?f=24&t=26036
Since I don't know your Operating System, I do not know anything about your firewall, but my first guess is that it is keeping you from downloading.
I would try to open a hole in the firewall for fahclient
Will3720
Post by Will3720 »
My os is windows 10 pro and here is the log again, the cpu is folding just fine it's only the gpu that's not working. and fahclient is allowed through firewall.
*********************** Log Started 2020-07-08T13:31:24Z ***********************
13:31:24:Trying to access database...
13:31:24:Successfully acquired database lock
13:31:24:Downloading GPUs.txt from assign1.foldingathome.org:80
13:31:24:Connecting to assign1.foldingathome.org:80
13:31:24:Read GPUs.txt
13:31:25:Enabled folding slot 00: READY cpu:3
13:31:25:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
13:31:25:****************************** FAHClient ******************************
13:31:25:        Version: 7.6.13
13:31:25:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:31:25:      Copyright: 2020 foldingathome.org
13:31:25:       Homepage: https://foldingathome.org/
13:31:25:           Date: Apr 27 2020
13:31:25:           Time: 21:21:01
13:31:25:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
13:31:25:         Branch: master
13:31:25:       Compiler: Visual C++ 2008
13:31:25:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:31:25:       Platform: win32 10
13:31:25:           Bits: 32
13:31:25:           Mode: Release
13:31:25:         Config: C:\Users\Sector48\AppData\Roaming\FAHClient\config.xml
13:31:25:******************************** CBang ********************************
13:31:25:           Date: Apr 24 2020
13:31:25:           Time: 17:07:55
13:31:25:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
13:31:25:           Bits: 32
13:31:25:******************************* System ********************************
13:31:25:            CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
13:31:25:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 11
13:31:25:           CPUs: 4
13:31:25:         Memory: 15.95GiB
13:31:25:    Free Memory: 12.72GiB
13:31:25:        Threads: WINDOWS_THREADS
13:31:25:     OS Version: 6.2
13:31:25:    Has Battery: false
13:31:25:     On Battery: false
13:31:25:     UTC Offset: -5
13:31:25:            PID: 12764
13:31:25:            CWD: C:\Users\Sector48\AppData\Roaming\FAHClient
13:31:25:  Win32 Service: false
13:31:25:             OS: Windows 10 Enterprise
13:31:25:        OS Arch: AMD64
13:31:25:           GPUs: 1
13:31:25:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
13:31:25:                 470/480/570/580/590]
13:31:25:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:31:25:                 specified module could not be found.
13:31:25:
13:31:25:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3075.12
13:31:25:******************************* libFAH ********************************
13:31:25:           Date: Apr 15 2020
13:31:25:           Time: 14:53:14
13:31:25:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:31:25:           Bits: 32
13:31:25:***********************************************************************
13:31:25:<config>
13:31:25:  <!-- Folding Slot Configuration -->
13:31:25:  <cause v='HIGH_PRIORITY'/>
13:31:25:
13:31:25:  <!-- Network -->
13:31:25:  <proxy v=':8080'/>
13:31:25:
13:31:25:  <!-- Slot Control -->
13:31:25:  <power v='full'/>
13:31:25:
13:31:25:  <!-- User Information -->
13:31:25:  <team v='223518'/>
13:31:25:  <user v='Will3720'/>
13:31:25:
13:31:25:  <!-- Folding Slots -->
13:31:25:  <slot id='0' type='CPU'/>
13:31:25:  <slot id='1' type='GPU'/>
13:31:25:</config>
13:31:25:WU00:FS00:Starting
13:31:25:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
13:31:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sector48\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 12764 -checkpoint 15 -np 1
13:31:26:WU00:FS00:Started FahCore on PID 12400
13:31:26:WU00:FS00:Core PID:12492
13:31:26:WU00:FS00:FahCore 0xa7 started
13:31:26:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:31:27:WU00:FS00:0xa7:*********************** Log Started 2020-07-08T13:31:26Z ***********************
13:31:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:31:27:WU00:FS00:0xa7:       Type: 0xa7
13:31:27:WU00:FS00:0xa7:       Core: Gromacs
13:31:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12400 -checkpoint 15 -np
13:31:27:WU00:FS00:0xa7:             1
13:31:27:WU00:FS00:0xa7:************************************ CBang *************************************
13:31:27:WU00:FS00:0xa7:       Date: Oct 26 2019
13:31:27:WU00:FS00:0xa7:       Time: 01:38:25
13:31:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:31:27:WU00:FS00:0xa7:     Branch: master
13:31:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:31:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:31:27:WU00:FS00:0xa7:   Platform: win32 10
13:31:27:WU00:FS00:0xa7:       Bits: 64
13:31:27:WU00:FS00:0xa7:       Mode: Release
13:31:27:WU00:FS00:0xa7:************************************ System ************************************
13:31:27:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
13:31:27:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 11
13:31:27:WU00:FS00:0xa7:       CPUs: 4
13:31:27:WU00:FS00:0xa7:     Memory: 15.95GiB
13:31:27:WU00:FS00:0xa7:Free Memory: 12.53GiB
13:31:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:31:27:WU00:FS00:0xa7: OS Version: 6.2
13:31:27:WU00:FS00:0xa7:Has Battery: false
13:31:27:WU00:FS00:0xa7: On Battery: false
13:31:27:WU00:FS00:0xa7: UTC Offset: -5
13:31:27:WU00:FS00:0xa7:        PID: 12492
13:31:27:WU00:FS00:0xa7:        CWD: C:\Users\Sector48\AppData\Roaming\FAHClient\work
13:31:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:31:27:WU00:FS00:0xa7:    Version: 0.0.18
13:31:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:31:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:31:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:31:27:WU00:FS00:0xa7:       Time: 01:52:30
13:31:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:31:27:WU00:FS00:0xa7:************************************ Build *************************************
13:31:27:WU00:FS00:0xa7:       SIMD: avx_256
13:31:27:WU00:FS00:0xa7:********************************************************************************
13:31:27:WU00:FS00:0xa7:Project: 16436 (Run 0, Clone 2796, Gen 282)
13:31:27:WU00:FS00:0xa7:Unit: 0x0000014580fccb015ea74e0a42c93c1b
13:31:27:WU00:FS00:0xa7:Digital signatures verified
13:31:27:WU00:FS00:0xa7:Calling: mdrun -s frame282.tpr -o frame282.trr -x frame282.xtc -cpi state.cpt -cpt 15 -nt 1
13:31:27:WU00:FS00:0xa7:Steps: first=141000000 total=500000
13:31:28:WU01:FS01:Assigned to work server 18.188.125.154
13:31:28:WU00:FS00:0xa7:Completed 188551 out of 500000 steps (37%)
13:31:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:31:28:WU01:FS01:Connecting to 18.188.125.154:8080
13:31:29:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:31:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:31:30:WU01:FS01:Assigned to work server 18.188.125.154
13:31:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:31:30:WU01:FS01:Connecting to 18.188.125.154:8080
13:31:31:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:32:27:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
13:32:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:32:29:WU01:FS01:Assigned to work server 18.188.125.154
13:32:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:32:30:WU01:FS01:Connecting to 18.188.125.154:8080
13:32:30:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:34:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:34:06:WU01:FS01:Assigned to work server 140.163.4.241
13:34:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
13:34:07:WU01:FS01:Connecting to 140.163.4.241:8080
13:34:07:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:35:48:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
13:36:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:36:44:WU01:FS01:Assigned to work server 18.188.125.154
13:36:44:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:36:44:WU01:FS01:Connecting to 18.188.125.154:8080
13:36:45:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:39:02:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
13:40:58:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:40:58:WU01:FS01:Assigned to work server 128.252.203.1
13:40:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.1
13:40:59:WU01:FS01:Connecting to 128.252.203.1:8080
13:40:59:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:42:18:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
13:45:36:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
13:47:49:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:47:49:WU01:FS01:Assigned to work server 128.252.203.4
13:47:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.4
13:47:50:WU01:FS01:Connecting to 128.252.203.4:8080
13:47:50:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:48:54:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
13:52:12:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
13:55:31:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
13:58:49:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
13:58:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:58:55:WU01:FS01:Assigned to work server 18.188.125.154
13:58:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:58:56:WU01:FS01:Connecting to 18.188.125.154:8080
13:58:56:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:02:07:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
14:05:26:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
14:08:46:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
14:12:05:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
14:15:22:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
14:16:51:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:16:51:WU01:FS01:Assigned to work server 18.188.125.154
14:16:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
14:16:52:WU01:FS01:Connecting to 18.188.125.154:8080
14:16:52:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:18:40:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
14:21:55:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
14:25:12:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
14:28:32:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
14:31:54:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
14:35:16:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
14:38:37:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
14:41:58:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
14:45:18:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
14:45:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:45:54:WU01:FS01:Assigned to work server 140.163.4.241
14:45:54:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
14:45:54:WU01:FS01:Connecting to 140.163.4.241:8080
14:45:54:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:48:37:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
14:51:56:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
14:55:21:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
14:58:45:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
15:02:09:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
15:05:12:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
15:08:18:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
15:11:21:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
15:14:24:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
15:17:28:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
15:20:33:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
15:23:38:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
15:26:42:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
15:29:44:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
15:32:47:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
15:32:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:32:52:WU01:FS01:Assigned to work server 3.21.50.185
15:32:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.21.50.185
15:32:53:WU01:FS01:Connecting to 3.21.50.185:8080
15:32:53:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:35:51:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
15:38:54:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
15:42:13:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
15:45:36:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
15:48:59:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
15:52:37:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
15:58:11:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
16:03:25:FS00:Paused
16:03:25:FS01:Paused
16:03:25:FS00:Shutting core down
16:03:26:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 12492
16:03:26:WU00:FS00:0xa7:Exiting, please wait. . .
16:03:27:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:03:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:03:54:Removing old file 'configs/config-20200629-175429.xml'
16:03:54:Saving configuration to config.xml
16:03:54:<config>
16:03:54:  <!-- Folding Slot Configuration -->
16:03:54:  <cause v='HIGH_PRIORITY'/>
16:03:54:
16:03:54:  <!-- Network -->
16:03:54:  <proxy v=':8080'/>
16:03:54:
16:03:54:  <!-- Slot Control -->
16:03:54:  <power v='full'/>
16:03:54:
16:03:54:  <!-- User Information -->
16:03:54:  <team v='223518'/>
16:03:54:  <user v='Will3720'/>
16:03:54:
16:03:54:  <!-- Folding Slots -->
16:03:54:  <slot id='0' type='CPU'>
16:03:54:    <paused v='true'/>
16:03:54:  </slot>
16:03:54:  <slot id='1' type='GPU'>
16:03:54:  </slot>
16:03:54:</config>
18:12:08:FS00:Unpaused
18:12:08:FS01:Unpaused
18:12:08:WU00:FS00:Starting
18:12:08:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
18:12:08:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sector48\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 12764 -checkpoint 15 -np 1
18:12:08:WU00:FS00:Started FahCore on PID 13456
18:12:08:WU00:FS00:Core PID:14328
18:12:08:WU00:FS00:FahCore 0xa7 started
18:12:08:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:12:08:WU00:FS00:0xa7:*********************** Log Started 2020-07-08T18:12:08Z ***********************
18:12:08:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:12:08:WU00:FS00:0xa7:       Type: 0xa7
18:12:08:WU00:FS00:0xa7:       Core: Gromacs
18:12:08:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13456 -checkpoint 15 -np
18:12:08:WU00:FS00:0xa7:             1
18:12:08:WU00:FS00:0xa7:************************************ CBang *************************************
18:12:08:WU00:FS00:0xa7:       Date: Oct 26 2019
18:12:08:WU00:FS00:0xa7:       Time: 01:38:25
18:12:08:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:12:08:WU00:FS00:0xa7:     Branch: master
18:12:08:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:12:08:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:12:08:WU00:FS00:0xa7:   Platform: win32 10
18:12:08:WU00:FS00:0xa7:       Bits: 64
18:12:08:WU00:FS00:0xa7:       Mode: Release
18:12:08:WU00:FS00:0xa7:************************************ System ************************************
18:12:08:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
18:12:08:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 11
18:12:08:WU00:FS00:0xa7:       CPUs: 4
18:12:08:WU00:FS00:0xa7:     Memory: 15.95GiB
18:12:08:WU00:FS00:0xa7:Free Memory: 11.77GiB
18:12:08:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:12:08:WU00:FS00:0xa7: OS Version: 6.2
18:12:08:WU00:FS00:0xa7:Has Battery: false
18:12:08:WU00:FS00:0xa7: On Battery: false
18:12:08:WU00:FS00:0xa7: UTC Offset: -5
18:12:08:WU00:FS00:0xa7:        PID: 14328
18:12:08:WU00:FS00:0xa7:        CWD: C:\Users\Sector48\AppData\Roaming\FAHClient\work
18:12:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:12:08:WU00:FS00:0xa7:    Version: 0.0.18
18:12:08:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:12:08:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:12:08:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:12:08:WU00:FS00:0xa7:       Time: 01:52:30
18:12:08:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:12:08:WU00:FS00:0xa7:************************************ Build *************************************
18:12:08:WU00:FS00:0xa7:       SIMD: avx_256
18:12:08:WU00:FS00:0xa7:********************************************************************************
18:12:08:WU00:FS00:0xa7:Project: 16436 (Run 0, Clone 2796, Gen 282)
18:12:08:WU00:FS00:0xa7:Unit: 0x0000014580fccb015ea74e0a42c93c1b
18:12:08:WU00:FS00:0xa7:Digital signatures verified
18:12:08:WU00:FS00:0xa7:Calling: mdrun -s frame282.tpr -o frame282.trr -x frame282.xtc -cpi state.cpt -cpt 15 -nt 1
18:12:08:WU00:FS00:0xa7:Steps: first=141000000 total=500000
18:12:08:WU00:FS00:0xa7:Completed 414752 out of 500000 steps (82%)
18:12:18:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
18:12:29:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': Failed to connect to assign1.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:12:29:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:12:50:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': Failed to connect to assign2.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:12:50:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:13:01:Removing old file 'configs/config-20200629-214314.xml'
18:13:01:Saving configuration to config.xml
18:13:01:<config>
18:13:01:  <!-- Folding Slot Configuration -->
18:13:01:  <cause v='HIGH_PRIORITY'/>
18:13:01:
18:13:01:  <!-- Network -->
18:13:01:  <proxy v=':8080'/>
18:13:01:
18:13:01:  <!-- Slot Control -->
18:13:01:  <power v='full'/>
18:13:01:
18:13:01:  <!-- User Information -->
18:13:01:  <team v='223518'/>
18:13:01:  <user v='Will3720'/>
18:13:01:
18:13:01:  <!-- Folding Slots -->
18:13:01:  <slot id='0' type='CPU'/>
18:13:01:  <slot id='1' type='GPU'/>
18:13:01:</config>
18:13:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': Failed to connect to assign3.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:13:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:13:32:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': Failed to connect to assign4.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:13:32:ERROR:WU01:FS01:Exception: Could not get an assignment
18:13:45:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:14:06:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': Failed to connect to assign1.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:14:06:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:14:27:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': Failed to connect to assign2.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:14:27:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:14:49:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': Failed to connect to assign3.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:14:49:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:15:10:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': Failed to connect to assign4.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:15:10:ERROR:WU01:FS01:Exception: Could not get an assignment
18:15:22:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
18:16:22:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:16:43:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': Failed to connect to assign1.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:16:43:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:17:04:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': Failed to connect to assign2.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:17:04:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:17:26:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': Failed to connect to assign3.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:17:26:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:17:47:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': Failed to connect to assign4.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:17:47:ERROR:WU01:FS01:Exception: Could not get an assignment
18:18:25:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
Reason: added Code tags to log
Yes, that is the part of the log that tells us about your PC, sadly I don't see an Obvious fix to your issue. In desperation I would reapply the driver from AMD.
Other minor errors in your log, that I don't think will fix your issue.
13:31:25: <cause v='HIGH_PRIORITY'/> I don't think this is a valid cause, but I don't do causes so what do I know?
I would add a passkey, it will get you more points.
https://foldingathome.org/support/faq/points/passkey/
i hope the log helps another helper.
Will3720
Post by Will3720 »
The driver is validated and yes high priority is a cause they recently added. I also just realized I added an extra fold to the end of the title... lol
Will3720
Post by Will3720 »
Oh and now the cpu isn't working....
Will3720
Post by Will3720 »
Problem solved thx for the help JimboPalmer, a wifi add on was blocking the vpn
