Initializing Domain Decomposition on 48 ranks
Dynamic load balancing: auto
Will sort the charge groups at every domain (re)decomposition
Initial maximum inter charge-group distances:
two-body bonded interactions: 0.433 nm, LJ-14, atoms 307 316
multi-body bonded interactions: 0.433 nm, Proper Dih., atoms 307 316
Minimum cell size due to bonded interactions: 0.477 nm
Maximum distance for 7 constraints, at 120 deg. angles, all-trans: 1.134 nm
Estimated maximum distance required for P-LINCS: 1.134 nm
This distance will limit the DD cell size, you can override this with -rcon
Guess for relative PME load: 0.18
Will use 40 particle-particle and 8 PME only ranks
This is a guess, check the performance at the end of the log file
Using 8 separate PME ranks, as guessed by mdrun
Scaling the initial minimum size with 1/0.8 (option -dds) = 1.25
Optimizing the DD grid for 40 cells with a minimum initial size of 1.417 nm
The maximum allowed number of cells is: X 4 Y 4 Z 4
